    4. [gelöst] SQL # Datenbankname wird nicht genutzt
    • derAuge
      derAuge last edited by
      EDIT
      Lösung wurde in neuer Version von SQLerstellt
      EDIT Off
      Laut beschreibung kann man dern Datenbankname ändern
      Default Database name is "iobroker", but it can be changed in configuration.
      Es wird jedoch die StandartDB genommen
      2016-05-30 23:00:15.848  - info: host.DS instance system.adapter.sql.0 started with pid 23862
      2016-05-30 23:00:19.141  - debug: sql.0 objectDB connected
      2016-05-30 23:00:19.163  - debug: sql.0 statesDB connected
      2016-05-30 23:00:19.260  - info: sql.0 starting. Version 1.0.5 in /volume2/ioBroker/Master/node_modules/iobroker.sql
      2016-05-30 23:00:19.612  - info: sql.0 enabled logging of yr.0.forecast.day0.wind_speed
      2016-05-30 23:00:19.614  - info: sql.0 enabled logging of yr.0.forecast.day0.temperature_actual
      2016-05-30 23:00:19.700  - debug: sql.0 CREATE DATABASE iobroker;
      2016-05-30 23:00:19.724  - debug: sql.0 Response: {"code":"ER_DB_CREATE_EXISTS","errno":1007,"sqlState":"HY000","index":0}
      2016-05-30 23:00:19.750  - debug: sql.0 CREATE TABLE iobroker.sources    (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT);
      2016-05-30 23:00:19.760  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlState":"42S01","index":0}
      2016-05-30 23:00:19.770  - debug: sql.0 CREATE TABLE iobroker.datapoints (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT, type INTEGER);
      2016-05-30 23:00:19.774  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlState":"42S01","index":0}
      2016-05-30 23:00:19.779  - debug: sql.0 CREATE TABLE iobroker.ts_number  (id INTEGER, ts BIGINT, val REAL,    ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY                                     (id, ts));
      2016-05-30 23:00:19.782  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlState":"42S01","index":0}
      2016-05-30 23:00:19.789  - debug: sql.0 CREATE TABLE iobroker.ts_string  (id INTEGER, ts BIGINT, val TEXT,    ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY                                     (id, ts));
      2016-05-30 23:00:19.794  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlState":"42S01","index":0}
      2016-05-30 23:00:19.803  - debug: sql.0 CREATE TABLE iobroker.ts_bool    (id INTEGER, ts BIGINT, val BOOLEAN, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY                                     (id, ts));
      2016-05-30 23:00:19.806  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlState":"42S01","index":0}
      2016-05-30 23:00:19.807  - info: sql.0 Connected to mysql
      Somit keine unterschiedlichen DB möglich
      Jürgen
      • Bluefox
        Bluefox last edited by
        Kannst du die Version 1.0.5 vom git ausprobieren?
        https://github.com/ioBroker/ioBroker.sql
        1.0.5 (2016-05-30)
        • (bluefox) allow setup DB name for mysql and mssql
        • derAuge
          @Bluefox:
          1.0.5 (2016-05-30)
          • (bluefox) allow setup DB name for mysql and mssql `
          Installation durchgeführt: (Ich hoffe das es so richtig war)
          admin@DS:/volume2/ioBroker/Master$ iobroker upgrade sql https://github.com/ioBroker/ioBroker.sql
          host.DS Adapter "system.adapter.sql.0" is stopped.
          npm install iobroker.sql --production --prefix "/volume2/ioBroker/Master" (System call)
          host.DS Adapter "system.adapter.sql.0" is started
          npm install --production --prefix "/volume2/ioBroker/Master/node_modules/iobroker.sql" (System call)
          got /volume2/ioBroker/Master/node_modules/iobroker.sql/admin
          upload [2] sql.admin /volume2/ioBroker/Master/node_modules/iobroker.sql/admin/storage.html storage.html text/html
          Update "system.adapter.sql.0"
          upload [1] sql.admin /volume2/ioBroker/Master/node_modules/iobroker.sql/admin/sql.png sql.png image/png
          upload [0] sql.admin /volume2/ioBroker/Master/node_modules/iobroker.sql/admin/index.html index.html text/html
          Adapter "sql" updated
          nach dem upgrade den Adapter auf DEBUG gestellt
          folgendes ist im LOG:
          2016-05-31 20:27:32.298  - info: host.DS object change system.adapter.sql.0
          2016-05-31 20:27:32.304  - info: host.DS "system.adapter.sql.0" disabled
          2016-05-31 20:27:32.307  - info: host.DS stopInstance system.adapter.sql.0
          2016-05-31 20:27:32.308  - info: host.DS stopInstance system.adapter.sql.0 killing pid 27821
          2016-05-31 20:27:32.377  - info: host.DS instance system.adapter.sql.0 terminated with code 0 (OK)
          2016-05-31 20:28:33.227  - info: host.DS object change system.adapter.sql.0
          2016-05-31 20:28:45.903  - info: host.DS object change system.adapter.sql.0
          2016-05-31 20:28:45.904  - info: host.DS "system.adapter.sql.0" enabled
          2016-05-31 20:28:46.179  - info: host.DS instance system.adapter.sql.0 started with pid 24171
          2016-05-31 20:28:50.554  - info: sql.0 starting. Version 1.0.5 in /volume2/ioBroker/Master/node_modules/iobroker.sql
          2016-05-31 20:28:51.716  - info: sql.0 Connected to mysql
          2016-05-31 20:28:54.086  - info: host.DS object change system.adapter.sql.0
          2016-05-31 20:28:54.087  - info: host.DS stopInstance system.adapter.sql.0
          2016-05-31 20:28:54.087  - info: host.DS stopInstance system.adapter.sql.0 killing pid 24171
          2016-05-31 20:28:54.102  - info: sql.0 terminating
          2016-05-31 20:28:54.123  - info: host.DS instance system.adapter.sql.0 terminated with code 0 (OK)
          2016-05-31 20:28:56.625  - info: host.DS instance system.adapter.sql.0 started with pid 24204
          2016-05-31 20:28:58.959  - info: sql.0 starting. Version 1.0.5 in /volume2/ioBroker/Master/node_modules/iobroker.sql
          2016-05-31 20:28:59.377  - info: sql.0 Connected to mysql
          2016-05-31 20:29:16.633  - info: host.DS object change system.adapter.sql.0
          2016-05-31 20:29:16.633  - info: host.DS stopInstance system.adapter.sql.0
          2016-05-31 20:29:16.634  - info: host.DS stopInstance system.adapter.sql.0 killing pid 24204
          2016-05-31 20:29:16.682  - info: host.DS instance system.adapter.sql.0 terminated with code 0 (OK)
          2016-05-31 20:29:19.171  - info: host.DS instance system.adapter.sql.0 started with pid 24237
          2016-05-31 20:29:21.327  - debug: sql.0 objectDB connected
          2016-05-31 20:29:21.350  - debug: sql.0 statesDB connected
          2016-05-31 20:29:21.477  - info: sql.0 starting. Version 1.0.5 in /volume2/ioBroker/Master/node_modules/iobroker.sql
          2016-05-31 20:29:21.739  - info: sql.0 enabled logging of yr.0.forecast.day0.wind_speed
          2016-05-31 20:29:21.740  - info: sql.0 enabled logging of yr.0.forecast.day0.temperature_actual
          2016-05-31 20:29:21.769  - debug: sql.0 CREATE DATABASE iobroker;
          2016-05-31 20:29:21.788  - debug: sql.0 Response: {"code":"ER_DB_CREATE_EXISTS","errno":1007,"sqlState":"HY000","index":0}
          2016-05-31 20:29:21.812  - debug: sql.0 CREATE TABLE iobroker.sources    (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT);
          2016-05-31 20:29:21.817  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlState":"42S01","index":0}
          2016-05-31 20:29:21.826  - debug: sql.0 CREATE TABLE iobroker.datapoints (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT, type INTEGER);
          2016-05-31 20:29:21.830  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlState":"42S01","index":0}
          2016-05-31 20:29:21.835  - debug: sql.0 CREATE TABLE iobroker.ts_number  (id INTEGER, ts BIGINT, val REAL,    ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
          2016-05-31 20:29:21.838  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlState":"42S01","index":0}
          2016-05-31 20:29:21.843  - debug: sql.0 CREATE TABLE iobroker.ts_string  (id INTEGER, ts BIGINT, val TEXT,    ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
          2016-05-31 20:29:21.846  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlState":"42S01","index":0}
          2016-05-31 20:29:21.855  - debug: sql.0 CREATE TABLE iobroker.ts_bool    (id INTEGER, ts BIGINT, val BOOLEAN, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
          2016-05-31 20:29:21.858  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlState":"42S01","index":0}
          2016-05-31 20:29:21.859  - info: sql.0 Connected to mysql
          Es wurden keine Tabellen angelegt
          Jürgen
          • Bluefox
            Bitte
            cd /opt/iobroker
            iobroker stop sql
            npm install https://github.com/ioBroker/ioBroker.sql
            iobroker start sql
            Ausführen
            • derAuge
              admin@DS:~$ cd /volume2/ioBroker/Master/
              admin@DS:/volume2/ioBroker/Master$ iobroker stop sql
              Adapter "sql.0 stopped.
              admin@DS:/volume2/ioBroker/Master$ npm install https://github.com/ioBroker/ioBroker.sql
              npm ERR! git clone --template=/var/services/homes/admin/.npm/_git-remotes/_templates --mirror https://github.com/ioBroker/ioBroker.sql.git /var/services/homes/admin/.npm/_git-remotes/https-github-com-ioBroker-ioBroker-sql-git-ee17b8ff: undefined
              npm ERR! Linux 3.10.77
              npm ERR! argv "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/bin/npm" "install" "https://github.com/ioBroker/ioBroker.sql"
              npm ERR! node v4.2.6
              npm ERR! npm  v2.14.12
              npm ERR! code ENOGIT
              npm ERR! not found: git
              npm ERR!
              npm ERR! Failed using git.
              npm ERR! This is most likely not a problem with npm itself.
              npm ERR! Please check if you have git installed and in your PATH.
              npm ERR! Please include the following file with any support request:
              npm ERR!     /volume2/ioBroker/Master/npm-debug.log
              • Bluefox
                Sorry. Sollte sein:
                npm install https://github.com/ioBroker/ioBroker.sql/tarball/master
                • derAuge
                  admin@DS:/volume2/ioBroker/Master$ npm install https://github.com/ioBroker/ioBroker.sql/tarball/master
                  > sqlite3@3.1.4 install /volume2/ioBroker/Master/node_modules/iobroker.sql/node_modules/sqlite3
                  > node-pre-gyp install --fallback-to-build
                  [sqlite3] Success: "/volume2/ioBroker/Master/node_modules/iobroker.sql/node_modules/sqlite3/lib/binding/node-v46-linux-x64/node_sqlite3.node" is installed via remote
                  iobroker.sql@1.0.7 node_modules/iobroker.sql
                  ├── mysql@2.10.2 (bignumber.js@2.1.4, readable-stream@1.1.14)
                  ├── pg@4.5.5 (packet-reader@0.2.0, pg-connection-string@0.1.3, generic-pool@2.1.1, buffer-writer@1.0.1, semver@4.3.6, pg-types@1.11.0, pgpass@0.0.3)
                  ├── sql-client@0.7.0 (argf@0.0.1, optimist@0.6.1, inote-util@0.8.1)
                  ├── mssql@3.3.0 (generic-pool@2.4.2, promise@7.1.1, tedious@1.14.0)
                  └── sqlite3@3.1.4 (nan@2.3.5)
                  So sieht es besser aus.
                  2016-06-01 07:06:08.001  - info: host.DS instance system.adapter.yr.0 terminated with code 0 (OK)
                  2016-06-01 07:36:48.516  - warn: host.DS "system.host.RPi2-1" is offline
                  2016-06-01 07:36:48.522  - warn: host.DS too delayed answer
                  2016-06-01 07:36:48.570  - warn: host.DS "system.host.RPi2-1" is offline
                  2016-06-01 07:36:48.570  - warn: host.DS too delayed answer
                  2016-06-01 07:37:24.886  - info: host.DS object change system.adapter.sql.0
                  2016-06-01 07:37:24.888  - info: host.DS stopInstance system.adapter.sql.0
                  2016-06-01 07:37:24.889  - info: host.DS stopInstance system.adapter.sql.0 killing pid 25724
                  2016-06-01 07:37:25.060  - info: host.DS instance system.adapter.sql.0 terminated with code 0 (OK)
                  2016-06-01 07:37:27.417  - info: host.DS instance system.adapter.sql.0 started with pid 23321
                  2016-06-01 07:37:30.955  - debug: sql.0 objectDB connected
                  2016-06-01 07:37:30.978  - debug: sql.0 statesDB connected
                  2016-06-01 07:37:31.083  - info: sql.0 starting. Version 1.0.7 in /volume2/ioBroker/Master/node_modules/iobroker.sql
                  2016-06-01 07:37:31.438  - info: sql.0 enabled logging of yr.0.forecast.day0.wind_speed
                  2016-06-01 07:37:31.440  - info: sql.0 enabled logging of yr.0.forecast.day0.temperature_actual
                  2016-06-01 07:37:31.545  - debug: sql.0 CREATE DATABASE iobroker.master;
                  2016-06-01 07:37:31.583  - debug: sql.0 Response: {"code":"ER_PARSE_ERROR","errno":1064,"sqlState":"42000","index":0}
                  2016-06-01 07:37:31.584  - error: sql.0 CREATE DATABASE iobroker.master;
                  2016-06-01 07:37:31.584  - error: sql.0 Error: ER_PARSE_ERROR: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '.master' at line 1
                  2016-06-01 07:38:01.600  - debug: sql.0 CREATE DATABASE iobroker.master;
                  2016-06-01 07:38:01.605  - debug: sql.0 Response: {"code":"ER_PARSE_ERROR","errno":1064,"sqlState":"42000","index":0}
                  2016-06-01 07:38:01.605  - error: sql.0 CREATE DATABASE iobroker.master;
                  2016-06-01 07:38:01.605  - error: sql.0 Error: ER_PARSE_ERROR: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '.master' at line 1
                  2016-06-01 07:38:18.646  - debug: inMem message  *.logging system.adapter.admin.0.logging val=true, ack=true, ts=1464759498638, q=0, from=system.adapter.admin.0, lc=1464759393462
                  2016-06-01 07:38:31.613  - debug: sql.0 CREATE DATABASE iobroker.master;
                  2016-06-01 07:38:31.618  - debug: sql.0 Response: {"code":"ER_PARSE_ERROR","errno":1064,"sqlState":"42000","index":0}
                  2016-06-01 07:38:31.619  - error: sql.0 CREATE DATABASE iobroker.master;
                  2016-06-01 07:38:31.620  - error: sql.0 Error: ER_PARSE_ERROR: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '.master' at line 1
                  2016-06-01 07:38:40.963  - info: host.DS object change system.adapter.sql.0
                  2016-06-01 07:38:40.964  - info: host.DS stopInstance system.adapter.sql.0
                  2016-06-01 07:38:40.964  - info: host.DS stopInstance system.adapter.sql.0 killing pid 23321
                  2016-06-01 07:38:40.994  - debug: inMem message  * system.adapter.sql.0 _id=system.adapter.sql.0, type=instance, name=sql, title=SQL History, en=Logging of states into SQL DB, de=Loggt die Historie von einzelnen Zuständen in einer SQL DB, ru=Сохраняет историю событий для отдельных состояний в SQL DB, version=1.0.5, en=try to calculate old timestamps, de=try to calculate old timestamps, ru=try to calculate old timestamps, en=fix error with io-package, de=fix error with io-package, ru=fix error with io-package, en=fix error with SQLite, de=fix error with SQLite, ru=fix error with SQLite, en=change default aggregation name, de=change default aggregation name, ru=change default aggregation name, en=check retention of data if set [never], de=check retention of data if set [never], ru=check retention of data if set [never], en=switch max and min with each other, de=switch max and min with each other, ru=switch max and min with each other, mode=daemon, platform=Javascript/Node.js, loglevel=debug, messagebox=true, subscribe=messagebox, keywords=[charts, sql, logging, graphs, archive], preserveSettings=history, enabled=true, stopBeforeUpdate=true, authors=[bluefox <dogafox@gmail.com>], license=MIT, readme=https://github.com/ioBroker/ioBroker.sql/blob/master/README.md, icon=sql.png, extIcon=https://raw.githubusercontent.com/ioBroker/ioBroker.sql/master/admin/sql.png, type=storage, minWidth=570, width =435, minHeight=200, height=540, installedVersion=1.0.5, host=DS, connLink=, debounce=10000, retention=0, host=192.168.28.24, port=0, user=iobroker, password=jbu, dbtype=mysql, fileName=sqlite.db, encrypt=false, round=4, dbname=iobroker_master
                  2016-06-01 07:38:41.001  - info: sql.0 terminating
                  2016-06-01 07:38:41.018  - info: host.DS instance system.adapter.sql.0 terminated with code 0 (OK)</dogafox@gmail.com>
                  ABER: CREATE DATABASE iobroker.master
                  Der Datenbankname darf kein "." haben
                  Ohne "." geht es besser:
                  CREATE DATABASE iobroker_master
                  2016-06-01 07:38:43.481  - info: host.DS instance system.adapter.sql.0 started with pid 23390
                  2016-06-01 07:38:45.641  - debug: sql.0 objectDB connected
                  2016-06-01 07:38:45.663  - debug: sql.0 statesDB connected
                  2016-06-01 07:38:45.761  - info: sql.0 starting. Version 1.0.7 in /volume2/ioBroker/Master/node_modules/iobroker.sql
                  2016-06-01 07:38:46.005  - info: sql.0 enabled logging of yr.0.forecast.day0.wind_speed
                  2016-06-01 07:38:46.007  - info: sql.0 enabled logging of yr.0.forecast.day0.temperature_actual
                  2016-06-01 07:38:46.037  - debug: sql.0 CREATE DATABASE iobroker_master;
                  2016-06-01 07:38:46.132  - debug: sql.0 Response: null
                  2016-06-01 07:38:46.156  - debug: sql.0 CREATE TABLE iobroker_master.sources    (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT);
                  2016-06-01 07:38:46.704  - debug: sql.0 Response: null
                  2016-06-01 07:38:46.713  - debug: sql.0 CREATE TABLE iobroker_master.datapoints (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT, type INTEGER);
                  2016-06-01 07:38:46.802  - debug: sql.0 Response: null
                  2016-06-01 07:38:46.808  - debug: sql.0 CREATE TABLE iobroker_master.ts_number  (id INTEGER, ts BIGINT, val REAL,    ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
                  2016-06-01 07:38:46.963  - debug: sql.0 Response: null
                  2016-06-01 07:38:46.968  - debug: sql.0 CREATE TABLE iobroker_master.ts_string  (id INTEGER, ts BIGINT, val TEXT,    ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
                  2016-06-01 07:38:47.103  - debug: sql.0 Response: null
                  2016-06-01 07:38:47.108  - debug: sql.0 CREATE TABLE iobroker_master.ts_bool    (id INTEGER, ts BIGINT, val BOOLEAN, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
                  2016-06-01 07:38:47.218  - debug: sql.0 Response: null
                  2016-06-01 07:38:47.220  - info: sql.0 Connected to mysql
                  Die Datenbank wurde angelegt und Daten werden geschrieben.
                  interissant ist, dass nun eine Gruppe angelegt wurde
                  PS: die Datenbank "iobroker.master" hatte ich manuell angelegt. Die werde ich nun wieder löschen
                  Jürgen
                  • Bluefox
                    Was meinst du damit?
                    • derAuge
                      @Bluefox:
                      Was meinst du damit? `
                      bei SQL wurden die beiden Datenbanken (iobroker und iobroker_master) in dem "Ordner" (Gruppe) ioBroker zusammen gefasst. (Siehe Bild)
                      Ich kann nicht sagen wo das her kommt.
                      PS:
                      Nun steht im Admin dass es eine Version 1.0.7 gibt. (Installiert = 1.0.5) Er wird jedoch kein Update-Symbol angezeigt
                      Jürgen
