    5. Pumpe alle 10min für 2min anschalten
      Hamudulu last edited by
      Ok, neuer versuch...
      • Slowman
        Slowman @Accu last edited by
        @Accu
        Kannst du bitte von diesem Blocky einen Export machen und zur Verfügung stellen?
          Hamudulu @Slowman last edited by Hamudulu
          @Slowman Nein leider nicht mehr, hab’s komplett geändert, so funktioniert es glaub ich...
            <variables>
              <variable type="undefined" id="Intervall">Intervall</variable>
            </variables>
            <block type="on_ext" id="wy=;:gN{v?g?Y[VmH0qe" x="-538" y="-38">
              <value name="OID0">
                <shadow type="field_oid" id="@gg2Q^c}1ZHN;OXW_s9;">
                  <field name="oid">node-red.0.Einspeisung</field>
                <block type="controls_if" id="}+^4WXEQg5*5(WHS},F!">
                    <block type="logic_operation" id="x*9;Lwzpr1^XIHT7R_P6" inline="false">
                      <field name="OP">AND</field>
                        <block type="time_compare" id="]xsncBb11%fR+7XlV,hR">
                          <mutation end_time="true"></mutation>
                          <field name="START_TIME">11:00</field>
                          <field name="END_TIME">18:00</field>
                        <block type="logic_compare" id="B-%HPu5~NHk,BexsP?*R">
                          <field name="OP">GT</field>
                            <block type="get_value" id="PSHZ~N_Ma=9XSP/OL`I(">
                              <field name="OID">node-red.0.Einspeisung</field>
                            <block type="math_number" id="dI%cfqw?BxMTFp-U~mvz">
                              <field name="NUM">100</field>
                    <block type="controls_if" id=")%%Rq[;mznqn=%eHt2PJ">
                        <block type="logic_negate" id="WcK7eI^b]|i_WP15si|E">
                          <value name="BOOL">
                            <block type="variables_get" id="E_+kF:ux:A=*Z)E;$F+-">
                              <field name="VAR" id="Intervall" variabletype="undefined">Intervall</field>
                        <block type="control" id="L1zWdsEYl{!rsoM~@_Ox">
                          <field name="OID">homee.0.MeteringPlug-201.OnOff-1120</field>
                            <block type="logic_boolean" id="PZ0i[8uKk]{l2q!7zzEb">
                            <block type="control" id="g9,rE5u{84NHkG)3;_SC">
                              <mutation delay_input="true"></mutation>
                              <field name="DELAY_MS">60</field>
                                <block type="logic_boolean" id="o(lT7cJ[Vy%*s6JE8_L1">
                                <block type="timeouts_setinterval" id="(d.56)?5gj3SVQ9Gi`AZ">
                                  <field name="NAME">Intervall</field>
                                  <field name="INTERVAL">60</field>
                                    <block type="control" id="q-(Q?O+hS(c2iKvf@Kba">
                                        <block type="logic_boolean" id="9#Q;8zd+qPNwFpxG@n+_">
                                        <block type="control" id="9eB@Ytv[t||)u/wU/^={">
                                            <block type="logic_boolean" id="6NIgNBi*DuQ@MHz6XXeQ">
                  <statement name="ELSE">
                    <block type="timeouts_clearinterval" id="Hvf9L#-kvf?r1H=g=FFs">
                        <block type="controls_if" id="L!Anv6?Ig^7zeBR!6Z6g">
                            <block type="logic_compare" id="u9wS#=pc}qu/P[31:F*0">
                              <field name="OP">LTE</field>
                                <block type="get_value" id="0UuBNgiSVc@GaHU^kFp{">
                                <block type="math_number" id="c9KXrO$bFU(Rv9tA}hE,">
                            <block type="control" id="9;q[tc5D(8LJHNvY#};}">
                                <block type="logic_boolean" id="]KUic+TJLB/3#y])}?eF">
          • Xenon
            Xenon Forum Testing Developer last edited by
            Das wird dir um die Ohren fliegen, was ist Intervall für eine Variable und wo wird sie gesetzt? Aktuell wird bei jeder Änderung dein Script getriggert, dass kann hunderte male pro sekunde passieren oder entprellst du mit der Variable? Und wieso Intervall und nochmal davor normal an und aus? Wenn du Pech hast, wird andauernd ein und aus geschaltet
              Hamudulu @Xenon last edited by
              @Xenon ich hab das hiervon abgeleitet...https://forum.iobroker.net/post/411521
              Ich teste heute mal das Verhalten...
                @Xenon Du hast recht, ist ein Scheis. Kannst du mir bitte bei der Lösung helfen? Problemstellung ist klar. Eine Stunde an, eine Stunde aus. usw.
                Wie mach ich das jetzt sinnvoll ins Blockly?
                  So nochmal...vielleicht kann mir mal bitte jemand helfen oder ein Tip geben?
                  Wie bekomm ich das in Griff dass nicht immer eingeschaltet wird...?
                  Wie sieht eine Lösung aus: 1h laufen bei genug PV und Zeitraum, dann 1h aus, und dann wieder an...
                    <variables>
                    </variables>
                    <block type="on_ext" id="(-n!f)hvoZoMgmus$0e$" x="-1538" y="-1013">
                      <value name="OID0">
                        <shadow type="field_oid" id="xp7To.fbATjEnhW{|^WQ">
                          <field name="oid">node-red.0.Erzeugung</field>
                        <block type="controls_if" id=",]X8n{]$%iE(X/|!rY*+">
                          <mutation elseif="1" else="1"></mutation>
                            <block type="logic_operation" id="pwUknR5Gk~$@oD_1/mx7">
                                <block type="logic_compare" id="!tqV^qhccI@@ly:}dK`d">
                                  <field name="OP">GTE</field>
                                    <block type="on_source" id="jQ06+Y/ON:)DCtXupw5Z">
                                    <block type="math_number" id="S`a@].0**0jxP}%D+5+I">
                                      <field name="NUM">400</field>
                            <block type="controls_if" id="{@jnx{4U27CW;[gJ09KK">
                                <block type="logic_compare" id="lXCN(di)KbQRQd|)z@XH">
                                  <field name="OP">EQ</field>
                                    <block type="get_value" id="K:jrJDmL%AZU{APyVmy9">
                                    <block type="logic_boolean" id="MzGc/Kc4[X^Gjar3iH6A">
                                <block type="control" id="H]%iZmji}q4kZL3$Dncc">
                                    <block type="logic_boolean" id="%((b;1s]|iv]9}MDZ3[+">
                                    <block type="control" id="_2G0=~f@(ufq@J6_)L{h">
                                        <block type="logic_boolean" id="|L|4r|kCkT+khB1}xCCX">
                                            <block type="debug" id="rS*l.hfk^NU:V3+0Fy{g">
                                              <field name="Severity">warn</field>
                                              <value name="TEXT">
                                                <shadow type="text" id="`sBF`/{u9sLT1kcX5rRh">
                                                  <field name="TEXT">Dazwischen </field>
                                                <block type="text_join" id="PE69pUHWaA%[#).)403r">
                                                  <value name="ADD0">
                                                    <block type="text" id="(AFNf9dR4U90zcdEkw7s">
                                                      <field name="TEXT">Pumpe an</field>
                                <block type="debug" id="SZ+7KdJ|u/jc-1=BW0.#">
                                  <value name="TEXT">
                                    <block type="text_join" id="i.4eKcmglYrls;?LhW1b">
                                      <value name="ADD0">
                                        <block type="text" id="a=VI22zn,2?]aXOkvGX;">
                                          <field name="TEXT">Pumpe läuft</field>
                          <value name="IF1">
                            <block type="logic_compare" id="EvR#lQB2wi(9QlGsyW}K">
                                <block type="on_source" id="8SF+S@NfyDL_LP}2TajZ">
                                <block type="math_number" id="U%%S2e!9]@.hCSD-=2uN">
                                  <field name="NUM">200</field>
                          <statement name="DO1">
                                    <block type="debug" id="5/#m#/Hi6[USY8rr#m2V">
                                      <value name="TEXT">
                                        <block type="text_join" id="@6I;5o_rzce]8YQ%(f=l">
                                          <value name="ADD0">
                                            <block type="text" id="buiCb4KegO95x$0B`b^|">
                                              <field name="TEXT">Pumpe aus</field>
                            <block type="debug" id="dR3VA4-M%Jk}7H3hNPO$">
                              <value name="TEXT">
                                <block type="text_join" id="(as;RzTfmo9*B*ulEnak">
                                  <value name="ADD0">
                                    <block type="text" id="fQgW~gK-Uud|6$@8P-7%">
                                      <field name="TEXT">PV Erzeugung</field>
                                  <value name="ADD1">
                                    <block type="on_source" id="XGj3wWu9BW74(MXW+}OS">
                  Xenon 1 Reply Last reply Reply Quote 0
                  • AlCalzone
                    AlCalzone Developer @Accu last edited by
                    @Accu sagte in Pumpe alle 10min für 2min anschalten:
                    Man soll ja sein system des öfteren neu starten
                    Nee...
                    Läuft wie ne 1.
                    Neustart war nur, weil ich vergessen habe, vor dem Update alle Adapter zu beenden (was bei nem Pi3 mit 15 Instanzen sonst gerne mal zu Überlastung führt).
                    Ich könnte wetten @Homoran hat nen Screenshot mit 2 Jahren Uptime (oder ähnlich groß) zur Hand.
                      Homoran Global Moderator Administrators @AlCalzone last edited by
                      @AlCalzone sagte in Pumpe alle 10min für 2min anschalten:
                      müsste da mal meine IPs zu den alten Installationen finden, die noch irgendwo vor sich hinlaufen 😉
                      Habe allerdings einiges zuletzt nach gut 450 Tagen zum Testen upgedated
                      • Xenon
                        Xenon Forum Testing Developer @Hamudulu last edited by Xenon
                        @Hamudulu
                        ich habe hier mal ein Grundblockly geschrieben, dass könntest du dir anpassen. Du brauchst nur die Kommentierten Bereiche anpassen und bim Vergleich von KleinerGleich auf GrößerGleich ändern, sowie die Zeit vom timeout anpassen
                          <variables>
                            <variable id="-!!!%oe4ppqH?|#z#XM~">Zustand_Aktor_1</variable>
                            <variable id="6vs1mxJz10C;Y`[KE${J">Trigger_1</variable>
                            <variable id="!KlSDB8b_%^Yexmq!3HA">Sperre</variable>
                            <variable id="auf20dFyBf.~[{:YRHRw">Aktor_1</variable>
                            <variable id="^bj1z4.DNX003R@%=U;O">Text_Telegram</variable>
                            <variable id="p/w(@wMvl;`u(^~Az~vs">Vorgabe_Wert</variable>
                          </variables>
                          <block type="procedures_callnoreturn" id="gM%DIi4R9`s.;`(=yVM%" x="187" y="-112">
                            <mutation name="PRG_INI"></mutation>
                              <block type="on_ext" id="%o`;]|iQdfx!T6_$|n1Z">
                                <value name="OID0">
                                  <shadow type="field_oid" id=";]X5XvT]/I^B#(~bW}=t">
                                  <block type="variables_get" id="0Zl5xWv@y(?Yg`l;^a[d">
                                    <field name="VAR" id="6vs1mxJz10C;Y`[KE${J">Trigger_1</field>
                                  <block type="procedures_callnoreturn" id="WEw:yD5fKj/b-ToFhM(A">
                                    <mutation name="Werte_in_VAR"></mutation>
                                      <block type="controls_if" id="DCeD46|YALHfir|.rI-i">
                                          <block type="logic_compare" id="n@wRq%S(Wk,ajT}Hh${{" inline="false">
                                              <block type="on_source" id="^jaj$^xI4W@]6rgN(y=@">
                                              <block type="variables_get" id="bPBsuxkAjcm4ae[M?QeM">
                                                <field name="VAR" id="p/w(@wMvl;`u(^~Az~vs">Vorgabe_Wert</field>
                                          <block type="controls_if" id="}4kN^q{7beH%=9Tc`:e?">
                                              <block type="logic_negate" id="2^dBLkE|-R%PAgjklhz6">
                                                <value name="BOOL">
                                                  <block type="variables_get" id="sZql:5]-Z7p;rEX44zGL">
                                                    <field name="VAR" id="!KlSDB8b_%^Yexmq!3HA">Sperre</field>
                                              <block type="variables_set" id="k,hIxCRF]VKALX0Tz7Av">
                                                  <block type="logic_boolean" id=",{xj53f=byzz7jgu.=e5">
                                                  <block type="timeouts_settimeout" id="sr2FPZ6N=@1y4l_2UDuz">
                                                    <field name="DELAY">5</field>
                                                      <block type="procedures_callnoreturn" id="S).vSxl*q%og=75Kuq^|">
                                                          <block type="controls_if" id="k|s{]:wTA~;7r}L|kzdf" collapsed="true">
                                                              <block type="variables_get" id="v-ms+m,GsE.1t[v`za+~">
        <field name="VAR" id="-!!!%oe4ppqH?|#z#XM~">Zustand_Aktor_1</field>
                                                              <block type="control_ex" id="}Z6%|a,IaQf`tH6$cqXa" inline="true">
        <value name="OID">
        <shadow type="field_oid" id="~d`_H-T9NfHPJ%tm2w_w">
        <field name="oid">Object ID</field>
        <block type="variables_get" id="_#r~7K?gJ2B}hhe[xse,">
        <field name="VAR" id="auf20dFyBf.~[{:YRHRw">Aktor_1</field>
        <shadow type="logic_boolean" id="#D=jQ4sa4lUej^aPz1_V">
        <block type="logic_boolean" id=",4/W%pFzT}Yv+uMspe+o">
        <value name="DELAY_MS">
        <shadow type="math_number" id="2p#XmCm.G5vMJI;d;fTY">
        <field name="NUM">0</field>
        <block type="math_number" id="Ucd4~ROM(Cn,x?pkY9BG">
        <block type="procedures_callnoreturn" id="|!-ni90:!o~?59-gCB4A">
        <mutation name="Telegram"></mutation>
                                          <block type="timeouts_cleartimeout" id=";D,:7xNZ5hDl2r2H$n[E">
                                              <block type="variables_set" id="_f%a(3WJx.d3-+2(*$5f">
                                                  <block type="logic_boolean" id="BP_Lr6y8b]X!8T!jS5q0">
                          <block type="procedures_defnoreturn" id="^6O2[WD1D12,dz3]}/}c" x="662" y="-112">
                            <field name="NAME">Werte_Vorgeben</field>
                            <statement name="STACK">
                              <block type="comment" id="P!j~+j+I.XEDAzh)85fd">
                                <field name="COMMENT">Hier den ENERGY state auswaehlen</field>
                                  <block type="variables_set" id="e@c,Ezp]}KPEaWt9ly4U">
                                      <block type="field_oid" id="8a^/qbaA0`k/Ag2taO-[">
                                        <field name="oid">sonoff.0.DVES_39AF78.ENERGY_Power</field>
                                      <block type="comment" id="SZ_C4O9$;-`Lc:9T3fj?">
                                        <field name="COMMENT">Hier den POWER state auswaehlen</field>
                                          <block type="variables_set" id="Z(2xpkY*sW;cx,,?F?CA">
                                              <block type="field_oid" id="1m~MH}OV!:SlDab]$(U.">
                                                <field name="oid">sonoff.0.DVES_39AF78.POWER</field>
                                              <block type="comment" id="A2r.k1;Wu3I(tjY(OJn$">
                                                <field name="COMMENT">Wert, der unterschritten werden soll</field>
                                                  <block type="variables_set" id="yjk|l~?u5525v*-|Ad-{">
                                                      <block type="math_number" id="p{dw?$tt-:5{$?vKiV*Z">
                                                        <field name="NUM">1</field>
                                                      <block type="comment" id="n?0N#~1ZMI[nnp7N!`aW">
                                                        <field name="COMMENT">Hier den Telegram Text eingeben</field>
                                                          <block type="comment" id="$g}#?:%twPIvJ4P$?+LK">
                                                            <field name="COMMENT">Wird nichts eingetragen, ist Telegram deaktiviert</field>
                                                              <block type="variables_set" id="$fc.plY2s}b@X-RGR=s_">
        <field name="VAR" id="^bj1z4.DNX003R@%=U;O">Text_Telegram</field>
        <block type="text" id=")a#kZ^(rDrr$@*twL]4$">
        <field name="TEXT"></field>
                          <block type="procedures_defnoreturn" id="LsQzF_4}1pkmBjxPPcYo" collapsed="true" x="1187" y="-113">
                            <field name="NAME">PRG_INI</field>
                              <block type="procedures_callnoreturn" id="0S*xi[+C)tUfwe6-2vVL">
                                <mutation name="Werte_Vorgeben"></mutation>
                                  <block type="variables_set" id="Qg*{Pd[8gC#EHQy-uudL">
                                      <block type="logic_boolean" id="laDOKTLe./ynmo-~h4!I">
                          <block type="procedures_defnoreturn" id="m|svt~0-wSzL}D?gIELX" collapsed="true" x="1188" y="-88">
                            <field name="NAME">Werte_in_VAR</field>
                              <block type="variables_set" id="~lLswh]^~P/U.R_0Ji26">
                                  <block type="get_value_var" id="Y#;OdIHSmIWFuO].Tu{O">
                                    <value name="OID">
                                      <shadow type="text" id="skAIPOSCNT*tn2W`02-e">
                                      <block type="variables_get" id="AjpE_xj/`4Xd~;tPpHVH">
                          <block type="procedures_defnoreturn" id=")^w}T@56fhQI57EzBs3:" x="1188" y="-63">
                            <field name="NAME">Telegram</field>
                              <block type="controls_if" id="$WHVdHwE`XCMUB5iwN@@">
                                  <block type="logic_compare" id="Wb*Ir5darRMhl0mx4aQd" inline="false" collapsed="true">
                                    <field name="OP">NEQ</field>
                                      <block type="variables_get" id="/b^u[!z]`D$9:,BV,ZVe">
                                      <block type="text" id="6@CMu2!4?o,AR}|Y=9W@">
                                  <block type="telegram" id="q_wiGI7SXqN77ZhFG.3z">
                                    <field name="LOG"></field>
                                    <value name="MESSAGE">
                                      <shadow type="text" id="!T4mV!0Z_jp;`?$%`s{]">
                                      <block type="variables_get" id="i+%V#_5V;csfhzAKY9D@">
                          @Xenon cool, aber das ist mir leider zu hoch...dein script versteh ich nicht. Und funktioniert bei mir auch nicht. Das geht geht bestimm einfacher, oder besser verständlich. Vielen Dank trotzdem, vielleicht komm ich eines Tages auf das Grundblockly zurück.
                          dslraser Xenon 2 Replies Last reply Reply Quote 0
                          • dslraser
                            dslraser Forum Testing Most Active @Hamudulu last edited by dslraser
                            @Hamudulu
                            So vielleicht ? (keine Ahnung ob es für Dich passt...)
                             <block type="on_ext" id="(-n!f)hvoZoMgmus$0e$" x="-1638" y="-912">
                               <value name="OID0">
                                     <block type="logic_operation" id="5T!dC~%OY%Z)8rf}eFg1" inline="false">
                                         <block type="logic_operation" id="pwUknR5Gk~$@oD_1/mx7" inline="false">
                                               <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true"></mutation>
                                         <block type="control" id="Z1`k~FfZvOvogs^6hCRZ">
                                             <block type="logic_boolean" id="owvwohyC_A30^-sn:9;0">
                                               <value name="TEXT">
                                                 <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="`sBF`/{u9sLT1kcX5rRh">
                                                   <value name="ADD0">
                                                       <field name="TEXT">Debug 1 Pumpe hat den Wert: </field>
                                                   <value name="ADD1">
                                                     <block type="get_value" id="0Z=T4@dncI=fyb.hX}q{">
                                   <value name="IF1">
                                     <block type="logic_operation" id="lyCfmd4f0YxE$^JEX@)b" inline="false">
                                         <block type="logic_operation" id="C}kS0*GkFd!fIzGeLcsl" inline="false">
                                             <block type="time_compare" id="9Z9$2$:nyPaH7=Vy^qy4">
                                             <block type="logic_compare" id="/oh)K,:[Ss9q!sd.X1_i">
                                                 <block type="get_value" id="ule?MXQ05tn|7vLzy#(R">
                                                 <block type="logic_boolean" id="!cesZH7#jr$Cc[h6HU-l">
                                     <block type="control" id="D(@sWTomlh,1eLh]evu|">
                                         <block type="logic_boolean" id="9lg.rHr8UBHl)#sBh#gI">
                                           <value name="TEXT">
                                             <block type="text_join" id=",1?L-mTT-X9E~Ix_z5I%">
                                               <value name="ADD0">
                                                 <block type="text" id="4n6E1Qqv/MJZ+#F+^vds">
                                                   <field name="TEXT">Debug 2 Pumpe hat den Wert: </field>
                                               <value name="ADD1">
                                                 <block type="get_value" id=".p;OZjOmwEN9c)j(=tC/">
                              Hamudulu @dslraser last edited by
                              @dslraser Vielen Dank, aber so läuft die Pumpe nur ein mal, oder? Ich will ja eine Stunde an und dann 1Stunde Pause und dann wieder an.
                              (Steh grad aufm Schlauch, hab schon sehr viel versucht)
                              • dslraser
                                @Hamudulu sagte in Pumpe alle 10min für 2min anschalten:
                                das habe ich nicht gelesen und ist auch nicht berücksichtigt.
                                nein, die würde immer wieder anlaufen (nach den 60 Minuten), wenn der Wert noch über oder gleich 400 ist.
                                Ich probiere sowas immer entweder nur mit debug, oder einer Steckdose wo ne Lampe drann ist.
                                • Xenon
                                  @Hamudulu wenn es dir zu hoch ist die kommentierten Bereiche anzupassen (einfach nur deine Datenpunkte auszuwählen), sowie den timeout abzuändern, dann kann ich leider auch nicht helfen. Leichter geht es nämlich nicht
                                    @Xenon das hier ist dank paul53 meine Lösung zu meinem Problem
                                    Mit deinem Vorschlag beschäftige ich mich andermal, vielleicht kann ich ihn woanders brauchen. Danke dafür.
                                    34
                                    2124
