    4. Fire TV Adapter
    SOLVED Fire TV Adapter
    • harrym
      harrym @Sali84 last edited by
      @Sali84 nö! nur einen fg https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten
        Thomas Braun Most Active @Sali84 last edited by
        @Sali84 sagte in Fire TV Adapter:
        @Thomas-Braun aber du bist dir sicher das an diesem Fehler nun node schuld ist?
        Sicher ist der Tod.
        harrym S 2 Replies Last reply Reply Quote 0
          sigi234 Forum Testing Most Active @Sali84 last edited by sigi234
          Ich glaube nicht, mal geht er mal wieder nicht. Habe aber Windows.
          firetv.0	2020-05-27 23:31:01.908	error	(13268) can not connect to 192.168.178.54 Error=unable to connect to 192.168.178.54:5555: cannot connect to 192.168.178.54:5555: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die
          firetv.0	2020-05-27 23:30:59.642	info	(13268) 192.168.178.57: ADB version: 39, Android Version: , API Level:
          firetv.0	2020-05-27 23:30:59.641	error	Otherwise check for a confirmation dialog on your device.'
          firetv.0	2020-05-27 23:30:59.641	error	Try 'adb kill-server' if that seems wrong.
          firetv.0	2020-05-27 23:30:59.641	error	This adb server's $ADB_VENDOR_KEYS is not set
          firetv.0	2020-05-27 23:30:59.641	error	(13268) ID: 192.168.178.57 Error=Failure: 'device unauthorized.
          firetv.0	2020-05-27 23:30:59.615	error	(13268) ID: 192.168.178.57 Error=Failure: 'device offline'
          firetv.0	2020-05-27 23:30:59.612	error	(13268) ID: 192.168.178.57 Error=Failure: 'device offline'
          firetv.0	2020-05-27 23:30:59.367	info	(13268) starting. Version 1.0.0 in C:/Program Files/iobroker/Test/node_modules/iobroker.firetv, node: v12.16.3, js-controller: 3.1.4
          firetv.0	2020-05-27 23:30:53.206	info	(8704) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          firetv.0	2020-05-27 23:30:53.205	info	(8704) terminating
          firetv.0	2020-05-27 23:30:53.202	info	(8704) Got terminate signal TERMINATE_YOURSELF
          harrym 1 Reply Last reply Reply Quote 0
          • harrym
            harrym @Thomas Braun last edited by
            @Thomas-Braun und der kosts lebe
            • harrym
              harrym @sigi234 last edited by
              @sigi234 also bei mir läuft der absolut sauber .... unter linux
                sigi234 Forum Testing Most Active @harrym last edited by
                @harrym sagte in Fire TV Adapter:
                Lief bei mir auch bis vor kurzen, bring ihn nicht mehr dazu sich zu verbinden.
                • harrym
                  @sigi234 eventuell es pairing zwischen stick und broker wiederholen? .... da hats mir auch mal en hund reinghaut gggggggg
                    Sali84 @Thomas Braun last edited by
                    @Thomas-Braun Das muss ich aufs Wochenende verschieben. Denn wenn bei der Node Installation was schief läuft, brauch ich Zeit und Nerven 🙂
                      @Sali84 Keinen Ahnung was ihr da immer für Bauchweh habt...
                      Hier läuft das immer ganz geschmeidig ab.
                        sigi234 Forum Testing Most Active @harrym last edited by sigi234
                        Ca 1000 Mal gemacht. 😀
                        Mein Verdacht ist ADB Debugging beim TV
                        • harrym
                          @Thomas-Braun stimmt scho ... aber du siehst ja, wieviele user da in problme kommen .... warum auch immer g
                            @Thomas-Braun was ich schon Stunden damit vebracht habe in der "Heimautomatisierung" Fehler oder missratene Updates zu flicken....unglaublich. Und eigentlich soll die Automatisierung ja Zeit sparen als Zeit kosten 🙂
                            sigi234 Thomas Braun 2 Replies Last reply Reply Quote 0
                            • harrym
                              @sigi234 mach nen reset aufn stick .... hab ich auch gemacht, nachdem ich mim adapter zuviel gespielt hatte .... und mim adb aufn broker ggggggggggg
                                Und das ist das Schöne daran, so lange testen bis es geht. 😀
                                harrym 1 Reply Last reply Reply Quote 1
                                • harrym
                                  @sigi234 😁 👍
                                    @Sali84 Zumindest was die Paketverwaltung des Grundsystems angeht ist das bei Debian echt kein Eiertanz. Nicht ohne Grund sind die da was oldstable oder stable angeht wirklich konservativ unterwegs.
                                      @Thomas-Braun ich werde auf dich zurückkommen wenn das Feuer entfacht ist 🙂
                                        @Sali84 Mach das. Wärst nicht der erste, dem ich die node-Installation geraderücke.
                                          @Thomas-Braun Besten Dank. Der Support in diesem Forum ist wirklich einmalig !
                                            Dann bist du EINER von 2 laut Git. 😀
                                            181
                                            52274
