    4. FireTv 1.0.0 testen
    FireTv 1.0.0 testen
      sigi234 Forum Testing Most Active @harrym last edited by
      @harrym
      Wie schaut der Pfad aus? Hast du Windows?
      harrym 2 Replies Last reply Reply Quote 0
      • harrym
        harrym @sigi234 last edited by
        @sigi234 ne. ich hab linux am laufen.
        /usr/lib/android-sdk/platform-tools/adb
        • harrym
          @sigi234 eventuell den FireTV mal resetten/updaten und die Entwicklereinstellungen vom Stick checken ?
          • foxriver76
            Bitte auch mal nicht js-c 3 Tester testen ob es tut. 😉
              sigi234 Forum Testing Most Active @harrym last edited by sigi234
              @harrym sagte in FireTv 1.0.0 testen:
              firetv.0	2020-04-12 20:21:42.027	debug	(12848) system.adapter.admin.0: logging true
              firetv.0	2020-04-12 20:19:42.661	debug	(12848) system.adapter.admin.0: logging false
              firetv.0	2020-04-12 20:18:04.882	error	(12848) can not connect to 192.168.178.54 Error=unable to connect to 192.168.178.54:5555: cannot connect to 192.168.178.54:5555: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die
              firetv.0	2020-04-12 20:18:02.864	info	(12848) 192.168.178.57: ADB version: 39, Android Version: , API Level:
              firetv.0	2020-04-12 20:18:02.863	error	(12848) ID: 192.168.178.57 Error=Failure: 'device '192.168.178.57:5555' not found'
              firetv.0	2020-04-12 20:18:02.860	error	(12848) ID: 192.168.178.57 Error=Failure: 'device '192.168.178.57:5555' not found'
              firetv.0	2020-04-12 20:18:02.858	error	(12848) ID: 192.168.178.57 Error=Failure: 'device '192.168.178.57:5555' not found'
              firetv.0	2020-04-12 20:18:02.855	error	(12848) ID: 192.168.178.57 Error=Failure: 'device '192.168.178.57:5555' not found'
              firetv.0	2020-04-12 20:18:02.854	debug	(12848) Connected to 192.168.178.57 id=192.168.178.57:5555
              firetv.0	2020-04-12 20:18:02.848	debug	(12848) Device 192.168.178.57:5555 was unplugged
              firetv.0	2020-04-12 20:18:02.839	debug	(12848) Device 192.168.178.57:5555 + type=offline was plugged in
              firetv.0	2020-04-12 20:18:02.799	debug	(12848) FireTV: 192.168.178.57
              firetv.0	2020-04-12 20:18:02.798	debug	(12848) FireTV: 192.168.178.54
              firetv.0	2020-04-12 20:18:02.724	info	(12848) starting. Version 1.0.0 in C:/Program Files/iobroker/Test/node_modules/iobroker.firetv, node: v10.16.3, js-controller: 3.0.7
              firetv.0	2020-04-12 20:18:02.590	debug	(12848) statesDB connected
              firetv.0	2020-04-12 20:18:02.590	debug	(12848) States connected to redis: 127.0.0.1:9000
              firetv.0	2020-04-12 20:18:02.580	debug	(12848) States create System PubSub Client
              firetv.0	2020-04-12 20:18:02.579	debug	(12848) States create User PubSub Client
              firetv.0	2020-04-12 20:18:02.575	debug	(12848) Redis States: Use Redis connection: 127.0.0.1:9000
              firetv.0	2020-04-12 20:18:02.574	debug	(12848) objectDB connected
              firetv.0	2020-04-12 20:18:02.572	debug	(12848) Objects connected to redis: 127.0.0.1:9013
              firetv.0	2020-04-12 20:18:02.562	debug	(12848) Objects client initialize lua scripts
              firetv.0	2020-04-12 20:18:02.562	debug	(12848) Objects create User PubSub Client
              firetv.0	2020-04-12 20:18:02.562	debug	(12848) Objects create System PubSub Client
              firetv.0	2020-04-12 20:18:02.561	debug	(12848) Objects client ready ... initialize now
              firetv.0	2020-04-12 20:18:02.543	debug	(12848) Redis Objects: Use Redis connection: 127.0.0.1:9013
              firetv.0	2020-04-12 20:17:59.210	info	(2544) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              firetv.0	2020-04-12 20:17:59.209	info	(2544) terminating
              firetv.0	2020-04-12 20:17:59.208	info	(2544) Got terminate signal TERMINATE_YOURSELF
                A Former User @foxriver76 last edited by
                @foxriver76 sagte in FireTv 1.0.0 testen:
                Tut auch unter 2.2.9 🙂
                • capitaenz
                  capitaenz last edited by capitaenz
                  Ich habe den Adapter auch zum laufen bekommen mit dem JS-Controller 2.2.9 (bekomme kein Update auf V3 angeboten).
                  Was mich zum verzweifeln gebracht hat:
                  • Folgendes ist falsch:
                  Client = require('/opt/iobroker/node_modules/adbkit/lib/adb/client'),
                  richtig:
                  Client = require('/opt/iobroker/node_modules/adbkit/lib/adb/client');
                  • Außderdem muss mit:
                  sudo apt-get install -y android-tools-adb android-tools-fastboot
                  Auf dem Tinkerboard (Raspberry) noch etwas nachinstalliert werden.
                  • Zum Hinzufügen +-Button betätigen
                    Das "+" ist gaaaaaaanz unten links versteckt!!!
                  Jetzt kann ich zwar einen Reboot durchführen und links, rechts, usw bedienen, aber wie starte ich die Apps, z.B. You Tube?
                  Hat da jemand einen Tipp für mich?
                  VG
                  Leif
                  harrym 1 Reply Last reply Reply Quote 0
                  • harrym
                    harrym @capitaenz last edited by
                    @capitaenz sagte in FireTv 1.0.0 testen:
                    DP "startApp"
                    richtig:
                    Client = require('./node_modules/adbkit/lib/adb/client');
                    Nö ;)  Client = require('/opt/iobroker/node_modules/adbkit/lib/adb/client');
                    capitaenz 1 Reply Last reply Reply Quote 0
                    • capitaenz
                      capitaenz @harrym last edited by capitaenz
                      @harrym
                      Sorry, hab das falsche kopiert:
                      falsch:
                      richtig:
                      Und dann unter startApp z.B. YouTube eingeben?
                      Funktioniert aber leider bei mir nicht 😞
                      • padrino
                        padrino Most Active last edited by
                        So, im Moment läuft er - endlich 😃
                        Direkt mal eine Frage, die ganzen "Keys" Datenpunkte, wäre es da nicht sinnvoll, wenn die Rolle "button" statt "state" wäre? 🤔
                          Sali84 last edited by
                          Gibt es irgendwo eine Übersicht über alle Funktionen die man machen kann?
                            SourKraut last edited by
                            Aloha zusammen
                            kennt zufällig jemand die Commands, die der Stick über ADB umsetzen kann.
                            Meines Wissens kann über die Bridge auch ein CEC-Signal vom Stick an den Fernseher gesendet werden.
                            Leider finde ich im Netz nichts was mir da weiterhilft.
                            Mir gehts darum meinen Samsung TV vom Stick wecken zu lassen. Per LAN geht`s ja bekannter Maßen nicht.
                            An sich funktioniert das ja, wenn ich den Stick per Adapter anspreche aber auch nur, wenn der TV schon länger aus ist.
                            Selbst wenn ich den AFTS per adb in den Ruhemodus schicke und wieder wecke, beeindruckt das den TV wenig.
                            Daher würde ich gern ein CEC-Signal vom Stick direkt mal triggern.
                              Sali84 @SourKraut last edited by
                              @SourKraut Sprich einfach die Taste Menu/home vom Stick an, dann wacht der TV auf.
                                SourKraut @Sali84 last edited by SourKraut
                                @Sali84
                                Um den Stick zu wecken nutze ich mittlerweile
                                adb shell input keyevent refresh
                                Allerdings reagiert der TV nicht, wenn der Stick dann läuft.
                                Ich kann den Stick auch nicht mehr in den Sleepmode schicken... Keine Ahnung warum.
                                Über den Adapter hat es einmal funktioniert, seid dem nicht mehr.
                                Direkt über die Bridge reagiert er auch nicht mehr auf
                                adb shell input keyevent 26
                                Das Ding treibt mich langsam aber sicher in den Wahnsinn. 😁
                                Der Adapter bekommt mittlerweile auch keine Verbindung mehr zum Stick.
                                  ich muss zugeben das der Adapter auch nicht so ganz funktioniert wie ich mir das vorstelle. Wird er noch grossartig weiterentwickelt?
                                    Für mich sieht es tatsächlich so aus, als wäre nicht der Adapter allein das Problem.
                                    Mein Stick z.B. zickt ja schon beim direkten ansprechen über die ADB.
                                    kaerichi 1 Reply Last reply Reply Quote 0
                                    • kaerichi
                                      kaerichi @SourKraut last edited by kaerichi
                                      Hallo zusammen, ich bekomme den Adapter gar nicht erst gestartet. Alles mögliche schon probiert,auch von hier https://forum.iobroker.net/topic/6804/fire-tv-adapter/105
                                      Ich glaube bei mir läuft es wohl komplett schief 😉 Bin aber auch Neuling bei iobroker und mit Linux habe ich schon Jahre nicht mehr rumhantiert 🙂 MFG
                                      EDIT: Hat sich erledigt. iobroker.firetv@1.0.0 manuell von der Konsole installiert, dann über Konsole die Instanz zu iobroker hinzugefügt. Wurde sofort grün, der Adapter findet ADB von alleine.
                                      • Z
                                        zombiee77 last edited by
                                        Wahrscheinlich steht es hier irgendwo, aber ich habe es nicht gefunden.
                                        In /usr/bin/ liegt der link zum adb:
                                        trotzdem erhalte ich folgende Meldung:
                                        firetv.0	2020-07-01 21:11:32.545	error	(3012264) adb executable not found. undefined
                                        firetv.0	2020-07-01 21:11:32.423	info	(3012264) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.firetv, node: v10.21.0, js-controller: 3.1.6
                                        host.ZBOX-NANO-Linux	2020-07-01 21:11:30.598	info	instance system.adapter.firetv.0 started with pid 3012264
                                        Was mache ich falsch?
                                          Thomas Braun Most Active @zombiee77 last edited by Thomas Braun
                                          @zombiee77 Folge dem Link und gib im Adapter den direkten Pfad zur adb ein. Muss ich bei mir auch machen
                                          • Z
                                            @Thomas-Braun Danke!!
                                            Jetzt spuckt er die Fehlermeldung nicht mehr aus.
                                            Aber finden tut er auch kein Device, obwohl ich USB-Debugging am Fire-Stick eingeschaltet habe.
                                            amazon firetv test
                                            21
                                            82
                                            7165
