    4. Kein Update von Adapter möglich
    UNSOLVED Kein Update von Adapter möglich
    • I
      igloh last edited by
      Erst mal nur das Protokoll vom Docker und das sieht auf den ersten Bick fehlerfrei aus.
      Die Webseiten vom Admin oder Vis lassen sich halt nicht öffnet.
      2020-05-27 18:49:50
      stdout
      host.buanet-iobroker1 check instance "system.adapter.systeminfo.0" for host "buanet-iobroker1"
      2020-05-27 18:49:50
      stdout
      host.buanet-iobroker1 check instance "system.adapter.synology.0" for host "buanet-iobroker1"
      2020-05-27 18:49:50
      stdout
      host.buanet-iobroker1 check instance "system.adapter.fritzdect.0" for host "buanet-iobroker1"
      2020-05-27 18:49:50
      stdout
      host.buanet-iobroker1 check instance "system.adapter.vis-justgage.0" for host "buanet-iobroker1"
      2020-05-27 18:49:50
      stdout
      host.buanet-iobroker1 check instance "system.adapter.firetv.0" for host "buanet-iobroker1"
      2020-05-27 18:49:50
      stdout
      host.buanet-iobroker1 check instance "system.adapter.javascript.0" for host "buanet-iobroker1"
      2020-05-27 18:49:50
      stdout
      host.buanet-iobroker1 check instance "system.adapter.alexa2.0" for host "buanet-iobroker1"
      2020-05-27 18:49:50
      stdout
      host.buanet-iobroker1 check instance "system.adapter.tr-064.0" for host "buanet-iobroker1"
      2020-05-27 18:49:50
      stdout
      host.buanet-iobroker1 check instance "system.adapter.hm-rpc.2" for host "buanet-iobroker1"
      2020-05-27 18:49:50
      stdout
      host.buanet-iobroker1 check instance "system.adapter.ical.0" for host "buanet-iobroker1"
      2020-05-27 18:49:50
      stdout
      host.buanet-iobroker1 check instance "system.adapter.fritzbox.0" for host "buanet-iobroker1"
      2020-05-27 18:49:50
      stdout
      host.buanet-iobroker1 check instance "system.adapter.daswetter.0" for host "buanet-iobroker1"
      2020-05-27 18:49:50
      stdout
      host.buanet-iobroker1 check instance "system.adapter.terminal.0" for host "buanet-iobroker1"
      2020-05-27 18:49:50
      stdout
      host.buanet-iobroker1 check instance "system.adapter.vis-timeandweather.0" for host "buanet-iobroker1"
      2020-05-27 18:49:50
      stdout
      host.buanet-iobroker1 check instance "system.adapter.vis.0" for host "buanet-iobroker1"
      2020-05-27 18:49:50
      stdout
      host.buanet-iobroker1 check instance "system.adapter.web.0" for host "buanet-iobroker1"
      2020-05-27 18:49:50
      stdout
      host.buanet-iobroker1 check instance "system.adapter.hm-rpc.1" for host "buanet-iobroker1"
      2020-05-27 18:49:50
      stdout
      host.buanet-iobroker1 check instance "system.adapter.hm-rega.0" for host "buanet-iobroker1"
      2020-05-27 18:49:50
      stdout
      host.buanet-iobroker1 check instance "system.adapter.hm-rpc.0" for host "buanet-iobroker1"
      2020-05-27 18:49:50
      stdout
      host.buanet-iobroker1 check instance "system.adapter.hue.0" for host "buanet-iobroker1"
      2020-05-27 18:49:50
      stdout
      host.buanet-iobroker1 check instance "system.adapter.info.0" for host "buanet-iobroker1"
      2020-05-27 18:49:50
      stdout
      host.buanet-iobroker1 check instance "system.adapter.discovery.0" for host "buanet-iobroker1"
      2020-05-27 18:49:50
      stdout
      host.buanet-iobroker1 check instance "system.adapter.admin.0" for host "buanet-iobroker1"
      2020-05-27 18:49:49
      stdout
      2020-05-27 18:49:49
      stdout
      Starting ioBroker...
      2020-05-27 18:49:49
      stdout
      2020-05-27 18:49:49
      stdout
      2020-05-27 18:49:49
      stdout
      -----          Step 5 of 5: ioBroker startup           -----
      2020-05-27 18:49:49
      stdout
      2020-05-27 18:49:44
      stdout
      2020-05-27 18:49:44
      stdout
      For more information take a look at readme.md on Github!
      2020-05-27 18:49:44
      stdout
      Some adapters have special requirements/ settings which can be activated by the use of environment variables.
      2020-05-27 18:49:44
      stdout
      2020-05-27 18:49:44
      stdout
      2020-05-27 18:49:44
      stdout
      -----      Step 4 of 5: Applying special settings      -----
      2020-05-27 18:49:44
      stdout
      2020-05-27 18:49:40
      stdout
      2020-05-27 18:49:40
      stdout
      Done.
      2020-05-27 18:49:40
      stdout
      Fixing "sudo-bug" by replacing sudo in iobroker with gosu...
      2020-05-27 18:49:40
      stdout
      2020-05-27 18:49:40
      stdout
      Done.
      2020-05-27 18:49:40
      stdout
      (Re)Setting folder permissions (This might take a while! Please be patient!)...
      2020-05-27 18:49:40
      stdout
      2020-05-27 18:49:40
      stdout
      2020-05-27 18:49:40
      stdout
      -----   Step 3 of 5: Checking ioBroker installation    -----
      2020-05-27 18:49:40
      stdout
      2020-05-27 18:49:40
      stdout
      2020-05-27 18:49:40
      stdout
      Existing installation of ioBroker detected in /opt/iobroker.
      2020-05-27 18:49:39
      stdout
      2020-05-27 18:49:39
      stdout
      2020-05-27 18:49:39
      stdout
      -----   Step 2 of 5: Detecting ioBroker installation   -----
      2020-05-27 18:49:39
      stdout
      2020-05-27 18:49:39
      stdout
      2020-05-27 18:49:39
      stdout
      Done.
      2020-05-27 18:49:39
      stdout
      E: Paket vi kann nicht gefunden werden.
      2020-05-27 18:49:34
      stdout
      The following packages will be installed: vi...
      2020-05-27 18:49:34
      stdout
      Installing additional packages is set by ENV.
      2020-05-27 18:49:34
      stdout
      2020-05-27 18:49:34
      stdout
      2020-05-27 18:49:34
      stdout
      -----         Step 1 of 5: Preparing container         -----
      2020-05-27 18:49:34
      stdout
      2020-05-27 18:49:34
      stdout
      2020-05-27 18:49:34
      stdout
      2020-05-27 18:49:34
      stdout
      -----               SETUID:    1000                    -----
      2020-05-27 18:49:34
      stdout
      -----               SETGID:    1000                    -----
      2020-05-27 18:49:34
      stdout
      -----               PACKAGES:  vi                      -----
      2020-05-27 18:49:34
      stdout
      -----                       ENV                        -----
      2020-05-27 18:49:34
      stdout
      2020-05-27 18:49:34
      stdout
      -----               npm:       6.14.4                  -----
      2020-05-27 18:49:33
      stdout
      -----               node:      v12.16.3                -----
      2020-05-27 18:49:33
      stdout
      -----               image:     v4.2.0                  -----
      2020-05-27 18:49:33
      stdout
      -----                     Versions                     -----
      2020-05-27 18:49:33
      stdout
      2020-05-27 18:49:33
      stdout
      -----               arch:      x86_64                  -----
      2020-05-27 18:49:33
      stdout
      -----                      System                      -----
      2020-05-27 18:49:33
      stdout
      2020-05-27 18:49:33
      stdout
      -----              Debugging information               -----
      2020-05-27 18:49:33
      stdout
      2020-05-27 18:49:33
      stdout
      2020-05-27 18:49:33
      stdout
      2020-05-27 18:49:33
      stdout
      -----                Please be patient!                -----
      2020-05-27 18:49:33
      stdout
      -----          Startupscript is now running.           -----
      2020-05-27 18:49:33
      stdout
      -----       Welcome to your ioBroker-container!        -----
      2020-05-27 18:49:33
      stdout
      2020-05-27 18:49:33
      stdout
      2020-05-27 18:49:33
      stdout
      2020-05-27 18:49:33
      stdout
      ---------------     2020-05-27 20:49:33      ---------------
      2020-05-27 18:49:33
      stdout
      2020-05-27 18:49:33
      stdout
      2020-05-27 18:43:03
      stdout
      2020-05-27 18:38:26
      stdout
      • Glasfaser
        Glasfaser @igloh last edited by
        @igloh
        Zeige mal
        iobroker status
        iobroker list instances
          Thomas Braun Most Active @igloh last edited by Thomas Braun
          @igloh Da ist node aber nicht sauber installiert, wenn du da mit symlinks arbeiten musst.
          apt policy nodejs
          which nodejs && which node && which npm
          • I
            Danke das hat geholfen!
            Genau die Module die ich vorhin von Hand gestoppt habe, waren immer noch gestoppt.
            Auch Admin und Web.
            Dachte sie kommen zumindest bei einen Neustart wieder mit hoch, das ist aber anscheinend nicht so.
            OK.
            Nun läuft wieder alles, die Node Version stimmt, das ursprüngliche Problem besteht aber leider immer noch.
            Beim Versuch des Updates kommt wieder der genannte Fehler.
            Für heute ist aber erst mal Schluss, schon mal vielen Dank für die lehrreichen Tipps!
            • Glasfaser
              @igloh
              siehe oben von @Thomas-Braun
              • I
                Könnte gut sein, da steht wieder die 10er Version...
                root@buanet-iobroker1:/opt/iobroker# apt policy nodejs
                nodejs:
                  Installiert:           10.20.1-1nodesource1
                  Installationskandidat: 10.20.1-1nodesource1
                  Versionstabelle:
                 *** 10.20.1-1nodesource1 100
                        100 /var/lib/dpkg/status
                root@buanet-iobroker1:/opt/iobroker# which nodejs && which node && which npm
                /usr/bin/nodejs
                /usr/local/bin/node
                /usr/local/bin/npm
                  @igloh Siehste...
                    @igloh
                    rm /usr/local/bin/node
                    rm /usr/local/bin/npm
                    curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
                    apt update
                    apt dist-upgrade
                    apt install nodejs --reinstall
                    Das sollte ein node 12 richtig auf das System spülen.
                      gifftstaub last edited by
                      ich würde es erstmal so machen wie Thomas Braun schon geschrieben hat die node sauber neu zu Installieren.
                      dann nochmals prüfen.
                      node -v
                      nodejs -v
                      und die pfade
                      which node
                      /usr/bin/node
                      which nodejs
                      /usr/bin/nodejs
                      lg
                      • I
                        Danke, habe node nun richtig installiert:
                        oot@buanet-iobroker1:/opt/iobroker# node -v
                        v12.17.0
                        root@buanet-iobroker1:/opt/iobroker# nodejs -v
                        v12.17.0
                        nodejs:
                          Installiert:           12.17.0-1nodesource1
                          Installationskandidat: 12.17.0-1nodesource1
                          Versionstabelle:
                         *** 12.17.0-1nodesource1 500
                                500 https://deb.nodesource.com/node_12.x buster/main amd64 Packages
                             10.19.0~dfsg1-1 500
                                500 http://deb.debian.org/debian buster/main amd64 Packages
                                500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
                        Aber dem eigentlichen Problem hat das leider nicht geholfen.
                        Ich kann weder die 4 Adatper noch den Controller (update self) upgraden.
                        Es kommt weiterhin die Fehlermeldung mit dem "3.12.1","istanbu"
                        code_text$ ./iobroker upgrade socketio
                        Update socketio from @3.0.6 to @3.0.7
                        NPM version: 6.14.4
                        npm install iobroker.socketio@3.0.7 --loglevel error --prefix "/opt/iobroker" (System call)
                        npm ERR! Unexpected end of JSON input while parsing near '..."^3.12.1","istanbul":'
                        npm ERR! A complete log of this run can be found in:npm ERR!     /opt/iobroker/.npm/_logs/2020-05-28T06_11_16_609Z-debug.log
                        upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/words.js words.js application/javascript
                        upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
                        upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index_m.html index_m.html text/html
                        upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index.html index.html text/html
                        Adapter "socketio" updated
                        process exited with code 0
                        • I
                          Problem gelöst!
                          Ein "npm cache clean --force" hat geholfen, danach konnte ich alle Adapter problemlos updaten.
                          Das war ja einfach..... 😉
                          Was ist noch gemerkt habe ist das zusätzlich zum "iobroker stop" das "pkill io" nicht reicht, die Module laufen trotzdem weiter. Ich habe dann letztendlich rausgefunden das man mit einen "iobroker stop all" wirklich alles stoppen kann. Man muss sie am Ende aber trotzdem wieder mit "iobroker start all" manuell starten, sonst kann man lange warten.
                          Ich kam da noch drauf weil ich den Adapter auf V3 hochziehen wollte.
                          Aber egal wo ist gucke oder was ich mache (z.B. iobroker upgrade self), er sagt das der aktuelle installiert ist.
                          Auch nach der manuellen Installation im o.g. Link wird noch mal die 2.9.9 installiert.
                          Falls mir noch einer sagen kann wie ich den V3 installieren kann wäre ich dankbar.
                          Ansonsten läuft jetzt alles bei mir.
                          Vielen Dank für die tolle Hilfe, ich habe zumindest auch viel dabei gelernt.
                          adapter update
                          2007
