    4. Summe aus verschiedenen Datenpunkte
    • tigertim08
      tigertim08 @paul53 last edited by
      @paul53 danke, Fehlermeldung compile failed besteht weiter
      javascript.0	2020-05-27 19:21:26.987	error	(394) at processTicksAndRejections (internal/process/task_queues.js:97:5)
      javascript.0	2020-05-27 19:21:26.986	error	(394) at runMicrotasks (<anonymous>:null:null)
      javascript.0	2020-05-27 19:21:26.986	error	(394) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
      javascript.0	2020-05-27 19:21:26.986	error	(394) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      javascript.0	2020-05-27 19:21:26.986	error	(394) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:580:17
      javascript.0	2020-05-27 19:21:26.986	error	(394) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1055:17
      javascript.0	2020-05-27 19:21:26.986	error	(394) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1464:17
      javascript.0	2020-05-27 19:21:26.985	error	(394) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1411:37)
      javascript.0	2020-05-27 19:21:26.985	error	(394) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:1188:28)
      javascript.0	2020-05-27 19:21:26.985	error	(394) at Object.createScript (vm.js:263:10)
      javascript.0	2020-05-27 19:21:26.985	error	(394) at new Script (vm.js:88:7)
      javascript.0	2020-05-27 19:21:26.985	error	(394) SyntaxError: Unexpected token 'function'
      javascript.0	2020-05-27 19:21:26.984	error	(394) ^^^^^^^^
      javascript.0	2020-05-27 19:21:26.984	error	(394) function(obj) {
      javascript.0	2020-05-27 19:21:26.984	error	at script.js.common.Test.Stromkosten_Gesamt:13
      javascript.0	2020-05-27 19:21:26.984	error	(394) script.js.common.Test.Stromkosten_Gesamt compile failed:
      javascript.0	2020-05-27 19:21:26.982	info	(394) Start javascript script.js.common.Test.Stromkosten_Gesamt
      javascript.0	2020-05-27 19:21:25.461	info	(394) Stop script script.js.common.Test.Stromkosten_Gesamt
        paul53 @tigertim08 last edited by paul53
        @tigertim08 sagte:
        Es fehlen eine schließende geschweifte Klammer und ein Komma.
        on({id: /\.05_current_year$/, change: 'any'}, function(obj) {
        und in Zeile 23 eine schließende runde Klammer.
        tigertim08 1 Reply Last reply Reply Quote 0
        • tigertim08
          @paul53 said in Summe aus verschiedenen Datenpunkte:
          Super, Danke! Jetzt meckert er nur noch das ich einen string zu einem state assigne. Die Werte werden doch aber auch als State ausgegeben oder habe ich da einen Denkfehler?
          javascript.0	2020-05-28 08:25:30.653	warn	(394) at processImmediate (internal/timers.js:456:21)
          javascript.0	2020-05-28 08:25:30.653	warn	(394) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
          javascript.0	2020-05-28 08:25:30.653	warn	(394) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:450:25)
          javascript.0	2020-05-28 08:25:30.652	warn	(394) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1051:38)
          javascript.0	2020-05-28 08:25:30.652	warn	(394) at Object.<anonymous> (script.js.common.Test.Stromkosten_Gesamt:22:5)
          javascript.0	2020-05-28 08:25:30.652	warn	(394) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1354:20)
          javascript.0	2020-05-28 08:25:30.651	warn	(394) You are assigning a string to the state "javascript.0.Stromkosten.2020.Summe" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning mig
          javascript.0	2020-05-28 08:25:30.651	info	(394) script.js.common.Test.Stromkosten_Gesamt: getState(id=sourceanalytix.0.hm-rpc__0__LEQ0536791__2__ENERGY_COUNTER.cost.05_current_year, timerId=undefined) => {"val":"1.88","ack":true,"ts":1590647
          javascript.0	2020-05-28 08:25:30.651	info	(394) script.js.common.Test.Stromkosten_Gesamt: getState(id=sourceanalytix.0.hm-rpc__0__MEQ0107335__2__ENERGY_COUNTER.cost.05_current_year, timerId=undefined) => {"val":"5.22","ack":true,"ts":1590647
          javascript.0	2020-05-28 08:25:30.650	info	(394) script.js.common.Test.Stromkosten_Gesamt: getState(id=sourceanalytix.0.hm-rpc__0__NEQ0153556__2__ENERGY_COUNTER.cost.05_current_year, timerId=undefined) => {"val":"0.00","ack":true,"ts":1590647
          javascript.0	2020-05-28 08:25:30.650	info	(394) script.js.common.Test.Stromkosten_Gesamt: getState(id=sourceanalytix.0.hm-rpc__0__NEQ0153678__2__ENERGY_COUNTER.cost.05_current_year, timerId=undefined) => {"val":"1.53","ack":true,"ts":1590647
          javascript.0	2020-05-28 08:25:30.650	info	(394) script.js.common.Test.Stromkosten_Gesamt: getState(id=sourceanalytix.0.sonoff__0__Tasmota_TV_Technik__ENERGY_Today.cost.05_current_year, timerId=undefined) => {"val":"0.00","ack":true,"ts":1590
          javascript.0	2020-05-28 08:25:30.649	info	(394) script.js.common.Test.Stromkosten_Gesamt: getState(id=sourceanalytix.0.sonoff__0__PC_Tim__ENERGY_Today.cost.05_current_year, timerId=undefined) => {"val":"0.01","ack":true,"ts":1590647120353,"q
          javascript.0	2020-05-28 08:25:30.649	info	(394) script.js.common.Test.Stromkosten_Gesamt: getState(id=sourceanalytix.0.sonoff__0__Wasserbett__ENERGY_Today.cost.05_current_year, timerId=undefined) => {"val":"0.01","ack":true,"ts":159064712735
          javascript.0	2020-05-28 08:25:29.695	info	(394) script.js.common.Test.Stromkosten_Gesamt: registered 1 subscription and 0 schedules
          javascript.0	2020-05-28 08:25:29.695	info	(394) script.js.common.Test.Stromkosten_Gesamt: subscribe: {"pattern":{"id":{},"change":"any","q":0},"name":"script.js.common.Test.Stromkosten_Gesamt"}
            Homoran Global Moderator Administrators @tigertim08 last edited by Homoran
            @tigertim08 sagte in Summe aus verschiedenen Datenpunkte:
            Dein Datenpunkt ist vom Typ "Logikwert"
            Der muss "Zahl" sein
            • tigertim08
              laut Datenpunkt ist er das. Habe ihn auch nochmal gelöscht und fom Skript anlegen lassen
              var idSumme = 'javascript.0.Stromkosten.2020.Summe';
              {1}
              createState(idSumme,  {
                  name: 'Summe aller Verbraucher',
                  unit: '€',
                  type: 'number',
                  def:  0,
                  min: 0
                  change: 'any'},
              function(obj) {
                  var a = getState('sourceanalytix.0.sonoff__0__Wasserbett__ENERGY_Today.cost.05_current_year').val,
                      b = getState('sourceanalytix.0.sonoff__0__PC_Tim__ENERGY_Today.cost.05_current_year').val,
                      c = getState('sourceanalytix.0.sonoff__0__Tasmota_TV_Technik__ENERGY_Today.cost.05_current_year').val,
                      d = getState('sourceanalytix.0.hm-rpc__0__NEQ0153678__2__ENERGY_COUNTER.cost.05_current_year').val,
                      e = getState('sourceanalytix.0.hm-rpc__0__NEQ0153556__2__ENERGY_COUNTER.cost.05_current_year').val,
                      f = getState('sourceanalytix.0.hm-rpc__0__MEQ0107335__2__ENERGY_COUNTER.cost.05_current_year').val,
                      g = getState('sourceanalytix.0.hm-rpc__0__LEQ0536791__2__ENERGY_COUNTER.cost.05_current_year').val;
                  var summe = a + b + c + d + e + f + g;
                  setState(idSumme, summe);
                dann gilt wohl der erste Tei lder Meldung:
                Also das Ergebnis nach Zahl wandeln
                • tigertim08
                  tigertim08 last edited by tigertim08
                  Wie ändere ich das denn? Hatte die einzelnen Datenpunkte schon gecheckt, diese sind auch als "number" klassifiziert.
                  Kann es an der Unit liegen? Also das die Unit dazu führt das es bei der Folgeverarbeitung ein String und keine Nummer mehr ist?
                    nicht die datenpunkte!
                    Die Variable im Skript scheint Typ String zu sein
                    • tigertim08
                      (gelöst) DANKE! Für die Unterstützung 🙂
                      okay, also wenn ich den State umwandle sollte es gehen?
                      var idSumme = 'javascript.0.Stromkosten.2020';
                      {1}
                          name: 'Summe der Verbraucher',
                          unit: '€',
                          type: 'number',
                          def:  0,
                          min: 0
                          change: 'any'},
                      function(obj) {
                          var a = parseFloat(getState('sourceanalytix.0.sonoff__0__Wasserbett__ENERGY_Today.cost.05_current_year').val),
                              b = parseFloat(getState('sourceanalytix.0.sonoff__0__PC_Tim__ENERGY_Today.cost.05_current_year').val),
                              c = parseFloat(getState('sourceanalytix.0.sonoff__0__Tasmota_TV_Technik__ENERGY_Today.cost.05_current_year').val),
                              d = parseFloat(getState('sourceanalytix.0.hm-rpc__0__NEQ0153678__2__ENERGY_COUNTER.cost.05_current_year').val),
                              e = parseFloat(getState('sourceanalytix.0.hm-rpc__0__NEQ0153556__2__ENERGY_COUNTER.cost.05_current_year').val),
                              f = parseFloat(getState('sourceanalytix.0.hm-rpc__0__MEQ0107335__2__ENERGY_COUNTER.cost.05_current_year').val),
                              g = parseFloat(getState('sourceanalytix.0.hm-rpc__0__LEQ0536791__2__ENERGY_COUNTER.cost.05_current_year').val);
                      habe es mit parseFloat probiert allerdings bleibt jetzt der Datenpunkt leer. Warnmeldungen werden mir aber nicht mehr angezeit.
                        ticaki Developer @tigertim08 last edited by ticaki
                        @tigertim08
                        Werfe mal das parseFloat() raus und füge:
                        log('a: '+a);
                        log('b: '+b);
                        log('c: '+c);
                        log('d: '+d);
                        log('e: '+e);
                        log('f: '+f);
                        log('g: '+g);
                        nach Zeile 20 ein. Poste die Logeinträge. Denke mal das es ein Problem mit ".," oder Einheitenangaben ist.
                        javascript
                        1162
