    4. js-controller 3.0/3.1 jetzt im Latest!
    • O
      Opa75+ last edited by
      pi@raspberrypi:/opt/iobroker $ pi@raspberrypi:/opt/iobroker $ npm i       iobroker.js-controller
      -bash: pi@raspberrypi:/opt/iobroker: Datei oder Verzeichnis nicht g      efunden
      pi@raspberrypi:/opt/iobroker $ > iobroker.js-controller@2.2.9 prein      stall /opt/iobroker/node_modules/iobroker.js-controller
      -bash: preinstall: Kommando nicht gefunden.
      pi@raspberrypi:/opt/iobroker $ > node lib/preinstallCheck.js
      -bash: lib/preinstallCheck.js: Datei oder Verzeichnis nicht gefunde      n
      pi@raspberrypi:/opt/iobroker $ NPM version: 6.14.4
      -bash: NPM: Kommando nicht gefunden.
      pi@raspberrypi:/opt/iobroker $ > iobroker.js-controller@2.2.9 insta      ll /opt/iobroker/node_modules/iobroker.js-controller
      install: Fehlender Zieldatei‐Operand hinter '/opt/iobroker/node_mod      ules/iobroker.js-controller'
      „install --help“ liefert weitere Informationen.
      pi@raspberrypi:/opt/iobroker $ > node iobroker.js setup first
      -bash: iobroker.js: Kommando nicht gefunden.
      pi@raspberrypi:/opt/iobroker $ npm WARN optional SKIPPING OPTIONAL       DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fse      ve      nts):
      -bash: Syntaxfehler beim unerwarteten Wort `('
      pi@raspberrypi:/opt/iobroker $ npm WARN notsup SKIPPING OPTIONAL DE      PENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"da      rw      in","arch":"any"} (current: {"os":"linux","arch":"arm"})
      pi@raspberrypi:/opt/iobroker $ npm WARN optional SKIPPING OPTIONAL       DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperat      ur      e-sensor):
      pi@raspberrypi:/opt/iobroker $ npm WARN notsup SKIPPING OPTIONAL DE      PENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wa      nt      ed {"os":"darwin","arch":"any"} (current: {"os":"linux","ar      ch":"arm"})
      pi@raspberrypi:/opt/iobroker $ + iobroker.js-controller@2.2.9
      -bash: +: Kommando nicht gefunden.
      pi@raspberrypi:/opt/iobroker $ updated 2 packages in 28.702s
      -bash: updated: Kommando nicht gefunden.
      pi@raspberrypi:/opt/iobroker $ 6 packages are looking for funding
      -bash: 6: Kommando nicht gefunden.
      pi@raspberrypi:/opt/iobroker $   run `npm fund` for details
      -bash: run: Kommando nicht gefunden.
      Passt das?
        Jan1 @Opa75+ last edited by Jan1
        @Opa75
        OK, Code Tacks hast gefunden 😉
        Wobei das sehr merkwürdig aussieht.
        • O
          Ich habe durch das irrtümliche kopieren einen großen Teil meiner Befehle nicht mehr am Schirm. Kann man die ersten Befehle wieder herholen???
            Thomas Braun Most Active @Opa75+ last edited by Thomas Braun
            @Opa75
            clear
            und dann mit der Pfeil-nach-oben-Taste und am besten nochmal ganz sauber neu...
            • O
              Geht nur zu einem bestimmten Zeikle, aber nicht zum Anfang:
              Zur Info: Ich habe die Befehle im Thread von Thomas Braun durchgeführt bis zum Wechsel mit dem Internet. Vielleicht hilft das.
              Thomas Braun J 2 Replies Last reply Reply Quote 0
                @Opa75
                Mir ist absolut schleierhaft wo du da jetzt hängst..
                Wir brauchen klare Rückmeldungen von der Konsole.
                • O
                  Diesen Code habe ich auch noch eingegeben.```
                  pi@raspberrypi:/opt/iobroker $ pi@raspberrypi:/opt/iobroker $ curl       -sL https://iobroker.net/fix.sh | bash -
                  pi@raspberrypi:/opt/iobroker $ library: loaded
                  -bash: library:: Kommando nicht gefunden.
                    @Opa75
                    Wie geschrieben, eigentlich macht man nur das was im Popup steht und fertig.
                    Genau das will ich sehen und was dann als Antwort kommt. Wenn Du das Konsolen Fenster maximierst, dann musst auch nicht so viel scrollen.
                      @Opa75 sagte in js-controller 3.0/3.1 jetzt im Latest!:
                      ist ja auch Quatsch...
                      Nur die Commands eingeben, nicht den login prompt.
                      Deswegen kommt da halt auch nur Quatsch bei dir rum.
                        @Opa75
                        So wie Thomas das schreibt machen und nicht so viel Zeug das da nicht hingehört.
                        Dann machst da was mit dem Fixer, ich dachte Du willst den JS Controller updaten.
                        • O
                          ok
                          Ich dbedanke mich recht herzlich für deine fast unendliche Gedukld. Ich werde das ganze Prozedere nochmals von vorne machen. Ich hoffe dann klappt es. Sollte dies nicht sein, so würde ich mich nach den Feiertagen wieder melden. Morgen wirst Du ja nicht da sein.
                            @Opa75
                            Das sind eigentlich nur 3 Befehle, den IOBroker stoppen, das Update starten und den und anschießend IOBroker wieder starten. Das kannst einfach aus dem Popup raus kopieren und in die Konsole einfügen.
                            • O
                              Das habe ich ja gemacht, aber da wurde mir die Version 2.2.9 angezeigt und nicht die 3.x
                              Ich mache es gleich nochmals.
                                @Opa75 Der Verwahrungsort ist auch auf 'latest' eingestellt? Denn in 'default' ist die 2.2.9 die aktuellste.
                                • O
                                  ist im default ändere ich => Danke
                                    Jan1 @Thomas Braun last edited by
                                    @Thomas-Braun
                                    wenn ich auf default umstelle, dann wäre das 1.5.11 die aktuelle angebotene Version, kann das sein? Denn das hab ich als erstes mal nachgeschaut, was dort überhaupt aktuell wäre.
                                    • O
                                      kleinen Moment muss meinen PC neu starten = Iobroker nicht aufrufbar
                                        Thomas Braun Most Active @Jan1 last edited by
                                        @Jan1
                                        Typ: js-controller
                                        Verfügbar: 2.2.9
                                        Installiert: 3.1.4
                                        J O 2 Replies Last reply Reply Quote 0
                                          Jan1 @Thomas Braun last edited by Jan1
                                          @Thomas-Braun
                                          Hm, warum zeigt er mir dann diese Version beim Wechsel ins default an?
                                          Dann ist noch was komisch, woher weiß er dass es neue Version gibt, wenn er im default wäre und das gemacht hat was im Popup steht? Denn das kannst nur aufrufen, wenn ein Update ansteht.
                                            @Jan1 Das weiß ich nicht.
                                            Aber irgendwie klemmt es auch auf npmjs.org im Moment heftig, scheint mir. Kann sein das da einiges Durcheinander ist z. Zt.
                                            js-controller
                                            127
                                            1340
                                            435267
