    4. Test Adapter mihome-vacuum v2.0.x
      dirkhe Developer @Xenon last edited by
      @Xenon das hat mswiege gefixt und ich habe das eben gemergt
        seppel786 last edited by seppel786
        Hi zusammen,
        ich bekomme die Karte ebenso nicht in den Objekten angezeigt.
        JS-Controller: 3.1.4
        Node.js: v12.16.3
        Adapter: 2.0.9
        Valetudo: 0.4
        FW: 3.3.9_003468 - rockrobo.vacuum.v1
        Anbei das Debuglog:
        mihome-vacuum.0	2020-05-28 10:32:09.274	debug	(5526) Receive <<< {"result":[{"msg_ver":8,"msg_seq":768,"state":2,"battery":99,"clean_time":0,"clean_area":1317500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":63,"dnd_enabled":0}],"id"
        mihome-vacuum.0	2020-05-28 10:32:09.265	debug	(5526) sendMsg[1] >>> {"id":40,"method":"get_status"}
        mihome-vacuum.0	2020-05-28 10:31:49.269	debug	(5526) Receive <<< {"result":[{"msg_ver":8,"msg_seq":767,"state":2,"battery":99,"clean_time":0,"clean_area":1317500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":63,"dnd_enabled":0}],"id"
        mihome-vacuum.0	2020-05-28 10:31:49.263	debug	(5526) sendMsg[1] >>> {"id":39,"method":"get_status"}
        mihome-vacuum.0	2020-05-28 10:31:36.702	warn	(5526) Could not receive Mappointer, giving up
        mihome-vacuum.0	2020-05-28 10:31:36.702	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":38}
        mihome-vacuum.0	2020-05-28 10:31:36.698	debug	(5526) 9. Mappointer_nomap___map_upload_handler
        mihome-vacuum.0	2020-05-28 10:31:36.697	debug	(5526) sendMsg[1] >>> {"id":38,"method":"get_map_v1"}
        mihome-vacuum.0	2020-05-28 10:31:36.197	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":37}
        mihome-vacuum.0	2020-05-28 10:31:36.190	debug	(5526) 8. Mappointer_nomap___map_upload_handler
        mihome-vacuum.0	2020-05-28 10:31:36.190	debug	(5526) sendMsg[1] >>> {"id":37,"method":"get_map_v1"}
        mihome-vacuum.0	2020-05-28 10:31:35.689	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":36}
        mihome-vacuum.0	2020-05-28 10:31:35.681	debug	(5526) 7. Mappointer_nomap___map_upload_handler
        mihome-vacuum.0	2020-05-28 10:31:35.681	debug	(5526) sendMsg[1] >>> {"id":36,"method":"get_map_v1"}
        mihome-vacuum.0	2020-05-28 10:31:35.246	debug	(5526) CLEAN_LOGGING[{"Datum":"28.5","Start":"10:11","Saugzeit":"0 min","Fläche":"1.32 m²","Error":0,"Ende":false},{"Datum":"25.5","Start":"15:23","Saugzeit":"0 min","Fläche":"0.75 m²","Error":0,"Ende
        mihome-vacuum.0	2020-05-28 10:31:35.181	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":35}
        mihome-vacuum.0	2020-05-28 10:31:35.177	debug	(5526) 6. Mappointer_nomap___map_upload_handler
        mihome-vacuum.0	2020-05-28 10:31:35.177	debug	(5526) sendMsg[1] >>> {"id":35,"method":"get_map_v1"}
        mihome-vacuum.0	2020-05-28 10:31:35.050	debug	(5526) Receive <<< {"result":[[1589796884,1589796954,0,1200000,0,0]],"id":34}
        mihome-vacuum.0	2020-05-28 10:31:35.045	debug	(5526) sendMsg[1] >>> {"id":34,"method":"get_clean_record","params":[1589796884]}
        mihome-vacuum.0	2020-05-28 10:31:34.850	debug	(5526) Receive <<< {"result":[[1589801327,1589801603,276,4907500,0,1]],"id":33}
        mihome-vacuum.0	2020-05-28 10:31:34.845	debug	(5526) sendMsg[1] >>> {"id":33,"method":"get_clean_record","params":[1589801327]}
        mihome-vacuum.0	2020-05-28 10:31:34.676	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":32}
        mihome-vacuum.0	2020-05-28 10:31:34.673	debug	(5526) 5. Mappointer_nomap___map_upload_handler
        mihome-vacuum.0	2020-05-28 10:31:34.672	debug	(5526) sendMsg[1] >>> {"id":32,"method":"get_map_v1"}
        mihome-vacuum.0	2020-05-28 10:31:34.649	debug	(5526) Receive <<< {"result":[[1589802735,1589802837,102,0,0,1]],"id":31}
        mihome-vacuum.0	2020-05-28 10:31:34.644	debug	(5526) sendMsg[1] >>> {"id":31,"method":"get_clean_record","params":[1589802735]}
        mihome-vacuum.0	2020-05-28 10:31:34.449	debug	(5526) Receive <<< {"result":[[1589804616,1589804632,0,0,0,0]],"id":30}
        mihome-vacuum.0	2020-05-28 10:31:34.444	debug	(5526) sendMsg[1] >>> {"id":30,"method":"get_clean_record","params":[1589804616]}
        mihome-vacuum.0	2020-05-28 10:31:34.248	debug	(5526) Receive <<< {"result":[[1589804656,1589804717,0,1457500,0,0]],"id":29}
        mihome-vacuum.0	2020-05-28 10:31:34.243	debug	(5526) sendMsg[1] >>> {"id":29,"method":"get_clean_record","params":[1589804656]}
        mihome-vacuum.0	2020-05-28 10:31:34.173	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":28}
        mihome-vacuum.0	2020-05-28 10:31:34.169	debug	(5526) 4. Mappointer_nomap___map_upload_handler
        mihome-vacuum.0	2020-05-28 10:31:34.169	debug	(5526) sendMsg[1] >>> {"id":28,"method":"get_map_v1"}
        mihome-vacuum.0	2020-05-28 10:31:34.049	debug	(5526) Receive <<< {"result":[[1589804971,1589804993,0,0,0,0]],"id":27}
        mihome-vacuum.0	2020-05-28 10:31:34.042	debug	(5526) sendMsg[1] >>> {"id":27,"method":"get_clean_record","params":[1589804971]}
        mihome-vacuum.0	2020-05-28 10:31:33.866	debug	(5526) Receive <<< {"result":[[1589805818,1589805869,0,380000,0,0]],"id":26}
        mihome-vacuum.0	2020-05-28 10:31:33.841	debug	(5526) sendMsg[1] >>> {"id":26,"method":"get_clean_record","params":[1589805818]}
        mihome-vacuum.0	2020-05-28 10:31:33.668	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":25}
        mihome-vacuum.0	2020-05-28 10:31:33.664	debug	(5526) 3. Mappointer_nomap___map_upload_handler
        mihome-vacuum.0	2020-05-28 10:31:33.664	debug	(5526) sendMsg[1] >>> {"id":25,"method":"get_map_v1"}
        mihome-vacuum.0	2020-05-28 10:31:33.645	debug	(5526) Receive <<< {"result":[[1589806003,1589806009,0,0,0,0]],"id":24}
        mihome-vacuum.0	2020-05-28 10:31:33.640	debug	(5526) sendMsg[1] >>> {"id":24,"method":"get_clean_record","params":[1589806003]}
        mihome-vacuum.0	2020-05-28 10:31:33.448	debug	(5526) Receive <<< {"result":[[1589807338,1589807420,0,1222500,0,0]],"id":23}
        mihome-vacuum.0	2020-05-28 10:31:33.440	debug	(5526) sendMsg[1] >>> {"id":23,"method":"get_clean_record","params":[1589807338]}
        mihome-vacuum.0	2020-05-28 10:31:33.244	debug	(5526) Receive <<< {"result":[[1589807988,1589808017,0,565000,0,0]],"id":22}
        mihome-vacuum.0	2020-05-28 10:31:33.239	debug	(5526) sendMsg[1] >>> {"id":22,"method":"get_clean_record","params":[1589807988]}
        mihome-vacuum.0	2020-05-28 10:31:33.156	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":21}
        mihome-vacuum.0	2020-05-28 10:31:33.153	debug	(5526) 2. Mappointer_nomap___map_upload_handler
        mihome-vacuum.0	2020-05-28 10:31:33.152	debug	(5526) sendMsg[1] >>> {"id":21,"method":"get_map_v1"}
        mihome-vacuum.0	2020-05-28 10:31:33.044	debug	(5526) Receive <<< {"result":[[1589811051,1589811123,12,0,0,0]],"id":20}
        mihome-vacuum.0	2020-05-28 10:31:33.039	debug	(5526) sendMsg[1] >>> {"id":20,"method":"get_clean_record","params":[1589811051]}
        mihome-vacuum.0	2020-05-28 10:31:32.843	debug	(5526) Receive <<< {"result":[[1589811788,1589811799,9,0,0,0]],"id":19}
        mihome-vacuum.0	2020-05-28 10:31:32.838	debug	(5526) sendMsg[1] >>> {"id":19,"method":"get_clean_record","params":[1589811788]}
        mihome-vacuum.0	2020-05-28 10:31:32.653	debug	(5526) Receive <<< {"result":[[1589811799,1589811812,13,0,0,1]],"id":18}
        mihome-vacuum.0	2020-05-28 10:31:32.652	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":17}
        mihome-vacuum.0	2020-05-28 10:31:32.637	debug	(5526) sendMsg[1] >>> {"id":18,"method":"get_clean_record","params":[1589811799]}
        mihome-vacuum.0	2020-05-28 10:31:32.631	debug	(5526) 1. Mappointer_nomap___map_upload_handler
        mihome-vacuum.0	2020-05-28 10:31:32.631	debug	(5526) sendMsg[1] >>> {"id":17,"method":"get_map_v1"}
        mihome-vacuum.0	2020-05-28 10:31:32.442	debug	(5526) Receive <<< {"result":[[1589811915,1589812051,8,0,0,0]],"id":16}
        mihome-vacuum.0	2020-05-28 10:31:32.437	debug	(5526) sendMsg[1] >>> {"id":16,"method":"get_clean_record","params":[1589811915]}
        mihome-vacuum.0	2020-05-28 10:31:32.241	debug	(5526) Receive <<< {"result":[[1589812855,1589813020,137,2762500,0,0]],"id":15}
        mihome-vacuum.0	2020-05-28 10:31:32.236	debug	(5526) sendMsg[1] >>> {"id":15,"method":"get_clean_record","params":[1589812855]}
        mihome-vacuum.0	2020-05-28 10:31:32.130	debug	(5526) Receive <<< {"result":["map_upload_handler"],"id":14}
        mihome-vacuum.0	2020-05-28 10:31:32.126	debug	(5526) 0. Mappointer_nomap___retry
        mihome-vacuum.0	2020-05-28 10:31:32.126	debug	(5526) sendMsg[1] >>> {"id":14,"method":"get_map_v1"}
        mihome-vacuum.0	2020-05-28 10:31:32.040	debug	(5526) Receive <<< {"result":[[1589813020,1589813058,0,0,0,0]],"id":13}
        mihome-vacuum.0	2020-05-28 10:31:32.035	debug	(5526) sendMsg[1] >>> {"id":13,"method":"get_clean_record","params":[1589813020]}
        mihome-vacuum.0	2020-05-28 10:31:31.838	debug	(5526) Receive <<< {"result":[[1590047127,1590047214,38,467500,0,0]],"id":12}
        mihome-vacuum.0	2020-05-28 10:31:31.834	debug	(5526) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1590047127]}
        mihome-vacuum.0	2020-05-28 10:31:31.643	debug	(5526) Receive <<< {"result":[[1590159774,1590165262,5454,78777500,0,1]],"id":11}
        mihome-vacuum.0	2020-05-28 10:31:31.633	debug	(5526) sendMsg[1] >>> {"id":11,"method":"get_clean_record","params":[1590159774]}
        mihome-vacuum.0	2020-05-28 10:31:31.625	debug	(5526) Receive <<< {"result":["retry"],"id":10}
        mihome-vacuum.0	2020-05-28 10:31:31.621	debug	(5526) sendMsg[1] >>> {"id":10,"method":"get_map_v1"}
        mihome-vacuum.0	2020-05-28 10:31:31.439	debug	(5526) Receive <<< {"result":[[1590412996,1590413044,0,745000,0,0]],"id":9}
        mihome-vacuum.0	2020-05-28 10:31:31.432	debug	(5526) sendMsg[1] >>> {"id":9,"method":"get_clean_record","params":[1590412996]}
        mihome-vacuum.0	2020-05-28 10:31:31.426	debug	(5526) Receive <<< {"result":"unknown_method","id":8}
        mihome-vacuum.0	2020-05-28 10:31:31.426	info	(5526) create state for carpet_mode
        mihome-vacuum.0	2020-05-28 10:31:31.426	debug	(5526) Receive <<< {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":7}
        mihome-vacuum.0	2020-05-28 10:31:31.421	debug	(5526) sendMsg[1] >>> {"id":8,"method":"get_room_mapping"}
        mihome-vacuum.0	2020-05-28 10:31:31.420	debug	(5526) sendMsg[1] >>> {"id":7,"method":"get_carpet_mode"}
        mihome-vacuum.0	2020-05-28 10:31:31.236	debug	(5526) Receive <<< {"result":[[1590653494,1590653563,0,1317500,0,0]],"id":6}
        mihome-vacuum.0	2020-05-28 10:31:31.231	debug	(5526) sendMsg[1] >>> {"id":6,"method":"get_clean_record","params":[1590653494]}
        mihome-vacuum.0	2020-05-28 10:31:31.231	debug	(5526) Receive <<< {"result":[373752,5385070000,197,[1590653494,1590412996,1590159774,1590047127,1589813020,1589812855,1589811915,1589811799,1589811788,1589811051,1589807988,1589807338,1589806003,158
        mihome-vacuum.0	2020-05-28 10:31:31.221	debug	(5526) sendMsg[1] >>> {"id":5,"method":"get_clean_summary"}
        mihome-vacuum.0	2020-05-28 10:31:31.028	debug	(5526) Receive <<< {"result":[{"main_brush_work_time":131848,"side_brush_work_time":30132,"filter_work_time":22124,"sensor_dirty_time":30126}],"id":4}
        mihome-vacuum.0	2020-05-28 10:31:31.020	debug	(5526) sendMsg[1] >>> {"id":4,"method":"get_consumable"}
        mihome-vacuum.0	2020-05-28 10:31:30.825	debug	(5526) Receive <<< {"result":[80],"id":3}
        mihome-vacuum.0	2020-05-28 10:31:30.821	debug	(5526) sendMsg[1] >>> {"id":3,"method":"get_sound_volume"}
        mihome-vacuum.0	2020-05-28 10:31:30.625	debug	(5526) Receive <<< {"partner_id":"","id":2,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.3.9_003468","ap":{"ssid":"Roundhousekick","bssid":"44:4E:6D:2C:FC:F0","rssi":-60},"netif":{"l
        mihome-vacuum.0	2020-05-28 10:31:30.621	debug	(5526) Next WiFi check: 28.05 10:32
        mihome-vacuum.0	2020-05-28 10:31:30.621	debug	(5526) sendMsg[1] >>> {"id":2,"method":"miIO.info"}
        mihome-vacuum.0	2020-05-28 10:31:30.420	info	(5526) Connected
        mihome-vacuum.0	2020-05-28 10:31:30.044	debug	(5526) TypeError: Cannot read property 'id' of undefined
        mihome-vacuum.0	2020-05-28 10:31:30.040	debug	(5526) 25175
        mihome-vacuum.0	2020-05-28 10:31:30.005	debug	(5526) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
        mihome-vacuum.0	2020-05-28 10:31:30.004	debug	(5526) Receive <<< {"result":[{"msg_ver":8,"msg_seq":766,"state":2,"battery":99,"clean_time":0,"clean_area":1317500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":63,"dnd_enabled":0}],"id
        mihome-vacuum.0	2020-05-28 10:31:29.991	debug	(5526) sendMsg[1] >>> {"id":1,"method":"get_status"}
        mihome-vacuum.0	2020-05-28 10:31:29.972	debug	(5526) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
        mihome-vacuum.0	2020-05-28 10:31:29.972	info	(5526) connecting, this can take up to 10 minutes ...
        mihome-vacuum.0	2020-05-28 10:31:29.971	debug	(5526) Receive <<< Helo <<< 213100200000000005c604885ecf76e0ffffffffffffffffffffffffffffffff
        mihome-vacuum.0	2020-05-28 10:31:29.769	info	(5526) set nächster Timer: Nicht verfügbar
        mihome-vacuum.0	2020-05-28 10:31:29.302	debug	(5526) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
        mihome-vacuum.0	2020-05-28 10:31:29.296	info	(5526) New generation or new fw(3.3.9,003468) detected, create new states goto and zoneclean
        mihome-vacuum.0	2020-05-28 10:31:29.264	debug	(5526) server started on 0.0.0.0:53421
        mihome-vacuum.0	2020-05-28 10:31:29.260	info	(5526) Cloud control disabled
        mihome-vacuum.0	2020-05-28 10:31:29.259	info	(5526) Expert mode disabled, states deleted
        mihome-vacuum.0	2020-05-28 10:31:29.255	debug	(5526) load Map creator... true
        mihome-vacuum.0	2020-05-28 10:31:29.233	info	(5526) starting. Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.16.3, js-controller: 3.1.4
        mihome-vacuum.0	2020-05-28 10:31:28.865	debug	(5526) statesDB connected
        mihome-vacuum.0	2020-05-28 10:31:28.865	debug	(5526) States connected to redis: 127.0.0.1:9000
        mihome-vacuum.0	2020-05-28 10:31:28.861	debug	(5526) States create System PubSub Client
        mihome-vacuum.0	2020-05-28 10:31:28.860	debug	(5526) States create User PubSub Client
        mihome-vacuum.0	2020-05-28 10:31:28.856	debug	(5526) Redis States: Use Redis connection: 127.0.0.1:9000
        mihome-vacuum.0	2020-05-28 10:31:28.855	debug	(5526) objectDB connected
        mihome-vacuum.0	2020-05-28 10:31:28.853	debug	(5526) Objects connected to redis: 127.0.0.1:9001
        mihome-vacuum.0	2020-05-28 10:31:28.842	debug	(5526) Objects client initialize lua scripts
        mihome-vacuum.0	2020-05-28 10:31:28.841	debug	(5526) Objects create User PubSub Client
        mihome-vacuum.0	2020-05-28 10:31:28.841	debug	(5526) Objects create System PubSub Client
        mihome-vacuum.0	2020-05-28 10:31:28.840	debug	(5526) Objects client ready ... initialize now
        mihome-vacuum.0	2020-05-28 10:31:28.725	debug	(5526) Redis Objects: Use Redis connection: 127.0.0.1:9001
        host.IoBroker	2020-05-28 10:31:28.510	info	instance system.adapter.mihome-vacuum.0 started with pid 5526
        Bin über jede Hilfe dankbar.
        Gruß Daniel
          Coffeelover @seppel786 last edited by
          @seppel786 Hast du die Beiträge von Xenon (https://forum.iobroker.net/topic/30137/test-adapter-mihome-vacuum-v2-0-x/862) und mir darüber gesehen / getestet?
            seppel786 @Coffeelover last edited by seppel786
            @Coffeelover
            folgende Schritte habe ich durchlaufen lassen:
            sudo iobroker stop
            cd /opt/iobroker
            sudo apt update
            sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
            sudo npm install canvas --unsafe-perm=true
            Anbei noch ein kurzer Auszug der Konsole:
            Zusätzlich habe ich noch eine neue VM auf meinem NUC aufgesetzt um auszuschließen, dass in meiner produktiven Umgebung
            irgendetwas "krumm" ist oder beim Update auf nodejs 12 irgendwas in die Hose gegangen ist (wie teilweise auf GIT schon berichtet).
            Auf der Test-VM habe ich allerdings dasselbe verhalten.
            Anbei das Debuglog nach dem Update von Canvas:
            mihome-vacuum.0	2020-05-28 11:22:39.288	debug	(6826) sendMsg[3] >>> {"id":52,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:22:37.298	debug	(6826) sendMsg[2] >>> {"id":53,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:34.288	debug	(6826) sendMsg[2] >>> {"id":52,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:22:32.297	debug	(6826) 9. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:32.297	debug	(6826) sendMsg[1] >>> {"id":53,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:31.796	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":51}
            mihome-vacuum.0	2020-05-28 11:22:31.792	debug	(6826) sendMsg[2] >>> {"id":51,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:29.287	debug	(6826) sendMsg[1] >>> {"id":52,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:22:26.791	debug	(6826) 8. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:26.791	debug	(6826) sendMsg[1] >>> {"id":51,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:26.290	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":50}
            mihome-vacuum.0	2020-05-28 11:22:26.286	debug	(6826) 7. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:26.286	debug	(6826) sendMsg[1] >>> {"id":50,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:25.785	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":49}
            mihome-vacuum.0	2020-05-28 11:22:25.782	debug	(6826) 6. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:25.781	debug	(6826) sendMsg[1] >>> {"id":49,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:25.280	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":48}
            mihome-vacuum.0	2020-05-28 11:22:25.276	debug	(6826) 5. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:25.276	debug	(6826) sendMsg[1] >>> {"id":48,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:24.775	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":47}
            mihome-vacuum.0	2020-05-28 11:22:24.771	debug	(6826) 4. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:24.771	debug	(6826) sendMsg[1] >>> {"id":47,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:24.271	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":46}
            mihome-vacuum.0	2020-05-28 11:22:24.267	debug	(6826) 3. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:24.267	debug	(6826) sendMsg[1] >>> {"id":46,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:23.766	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":45}
            mihome-vacuum.0	2020-05-28 11:22:23.762	debug	(6826) 2. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:23.762	debug	(6826) sendMsg[1] >>> {"id":45,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:23.261	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":44}
            mihome-vacuum.0	2020-05-28 11:22:23.257	debug	(6826) 1. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:23.257	debug	(6826) sendMsg[1] >>> {"id":44,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:22.756	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":43}
            mihome-vacuum.0	2020-05-28 11:22:22.752	debug	(6826) 0. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:22.752	debug	(6826) sendMsg[1] >>> {"id":43,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:22.252	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":42}
            mihome-vacuum.0	2020-05-28 11:22:22.248	debug	(6826) sendMsg[1] >>> {"id":42,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:22.247	debug	(6826) stateChange mihome-vacuum.0.map.loadMap {"val":true,"ack":false,"ts":1590657742246,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1589621974319}
            mihome-vacuum.0	2020-05-28 11:22:16.971	warn	(6826) Could not receive Mappointer, giving up
            mihome-vacuum.0	2020-05-28 11:22:16.970	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":41}
            mihome-vacuum.0	2020-05-28 11:22:16.964	debug	(6826) 9. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:16.963	debug	(6826) sendMsg[1] >>> {"id":41,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:16.464	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":40}
            mihome-vacuum.0	2020-05-28 11:22:16.460	debug	(6826) 8. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:16.459	debug	(6826) sendMsg[1] >>> {"id":40,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:15.959	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":39}
            mihome-vacuum.0	2020-05-28 11:22:15.956	debug	(6826) 7. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:15.955	debug	(6826) sendMsg[1] >>> {"id":39,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:15.456	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":38}
            mihome-vacuum.0	2020-05-28 11:22:15.451	debug	(6826) 6. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:15.451	debug	(6826) sendMsg[1] >>> {"id":38,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:14.950	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":37}
            mihome-vacuum.0	2020-05-28 11:22:14.946	debug	(6826) 5. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:14.946	debug	(6826) sendMsg[1] >>> {"id":37,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:14.445	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":36}
            mihome-vacuum.0	2020-05-28 11:22:14.441	debug	(6826) 4. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:14.441	debug	(6826) sendMsg[1] >>> {"id":36,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:14.123	debug	(6826) CLEAN_LOGGING[{"Datum":"28.5","Start":"11:20","Saugzeit":"0 min","Fläche":"0.12 m²","Error":0,"Ende":false},{"Datum":"28.5","Start":"10:11","Saugzeit":"0 min","Fläche":"1.32 m²","Error":0,"End
            mihome-vacuum.0	2020-05-28 11:22:13.953	debug	(6826) Receive <<< {"result":[[1589801327,1589801603,276,4907500,0,1]],"id":35}
            mihome-vacuum.0	2020-05-28 11:22:13.950	debug	(6826) Receive <<< {"result":[[1589802735,1589802837,102,0,0,1]],"id":34}
            mihome-vacuum.0	2020-05-28 11:22:13.949	debug	(6826) Receive <<< {"result":[[1589804616,1589804632,0,0,0,0]],"id":33}
            mihome-vacuum.0	2020-05-28 11:22:13.949	debug	(6826) Receive <<< {"result":[[1589804656,1589804717,0,1457500,0,0]],"id":32}
            mihome-vacuum.0	2020-05-28 11:22:13.949	debug	(6826) Receive <<< {"result":[[1589804971,1589804993,0,0,0,0]],"id":31}
            mihome-vacuum.0	2020-05-28 11:22:13.948	debug	(6826) Receive <<< {"result":[[1589805818,1589805869,0,380000,0,0]],"id":30}
            mihome-vacuum.0	2020-05-28 11:22:13.940	debug	(6826) Receive <<< {"result":[[1589806003,1589806009,0,0,0,0]],"id":29}
            mihome-vacuum.0	2020-05-28 11:22:13.940	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":28}
            mihome-vacuum.0	2020-05-28 11:22:13.940	debug	(6826) Receive <<< {"result":[[1589807338,1589807420,0,1222500,0,0]],"id":27}
            mihome-vacuum.0	2020-05-28 11:22:13.921	debug	(6826) sendMsg[1] >>> {"id":35,"method":"get_clean_record","params":[1589801327]}
            mihome-vacuum.0	2020-05-28 11:22:13.721	debug	(6826) sendMsg[1] >>> {"id":34,"method":"get_clean_record","params":[1589802735]}
            mihome-vacuum.0	2020-05-28 11:22:13.520	debug	(6826) sendMsg[1] >>> {"id":33,"method":"get_clean_record","params":[1589804616]}
            mihome-vacuum.0	2020-05-28 11:22:13.319	debug	(6826) sendMsg[1] >>> {"id":32,"method":"get_clean_record","params":[1589804656]}
            mihome-vacuum.0	2020-05-28 11:22:13.118	debug	(6826) sendMsg[1] >>> {"id":31,"method":"get_clean_record","params":[1589804971]}
            mihome-vacuum.0	2020-05-28 11:22:12.917	debug	(6826) sendMsg[1] >>> {"id":30,"method":"get_clean_record","params":[1589805818]}
            mihome-vacuum.0	2020-05-28 11:22:12.716	debug	(6826) sendMsg[1] >>> {"id":29,"method":"get_clean_record","params":[1589806003]}
            mihome-vacuum.0	2020-05-28 11:22:12.518	debug	(6826) 3. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:12.518	debug	(6826) sendMsg[1] >>> {"id":28,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:12.515	debug	(6826) sendMsg[1] >>> {"id":27,"method":"get_clean_record","params":[1589807338]}
            mihome-vacuum.0	2020-05-28 11:22:12.319	debug	(6826) Receive <<< {"result":[[1589807988,1589808017,0,565000,0,0]],"id":26}
            mihome-vacuum.0	2020-05-28 11:22:12.314	debug	(6826) sendMsg[1] >>> {"id":26,"method":"get_clean_record","params":[1589807988]}
            mihome-vacuum.0	2020-05-28 11:22:12.118	debug	(6826) Receive <<< {"result":[[1589811051,1589811123,12,0,0,0]],"id":25}
            mihome-vacuum.0	2020-05-28 11:22:12.113	debug	(6826) sendMsg[1] >>> {"id":25,"method":"get_clean_record","params":[1589811051]}
            mihome-vacuum.0	2020-05-28 11:22:12.018	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":24}
            mihome-vacuum.0	2020-05-28 11:22:12.015	debug	(6826) 2. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:12.014	debug	(6826) sendMsg[1] >>> {"id":24,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:11.916	debug	(6826) Receive <<< {"result":[[1589811788,1589811799,9,0,0,0]],"id":23}
            mihome-vacuum.0	2020-05-28 11:22:11.912	debug	(6826) sendMsg[1] >>> {"id":23,"method":"get_clean_record","params":[1589811788]}
            mihome-vacuum.0	2020-05-28 11:22:11.716	debug	(6826) Receive <<< {"result":[[1589811799,1589811812,13,0,0,1]],"id":22}
            mihome-vacuum.0	2020-05-28 11:22:11.711	debug	(6826) sendMsg[1] >>> {"id":22,"method":"get_clean_record","params":[1589811799]}
            mihome-vacuum.0	2020-05-28 11:22:11.515	debug	(6826) Receive <<< {"result":[[1589811915,1589812051,8,0,0,0]],"id":21}
            mihome-vacuum.0	2020-05-28 11:22:11.515	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":20}
            mihome-vacuum.0	2020-05-28 11:22:11.510	debug	(6826) sendMsg[1] >>> {"id":21,"method":"get_clean_record","params":[1589811915]}
            mihome-vacuum.0	2020-05-28 11:22:11.510	debug	(6826) 1. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:11.509	debug	(6826) sendMsg[1] >>> {"id":20,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:11.314	debug	(6826) Receive <<< {"result":[[1589812855,1589813020,137,2762500,0,0]],"id":19}
            mihome-vacuum.0	2020-05-28 11:22:11.309	debug	(6826) sendMsg[1] >>> {"id":19,"method":"get_clean_record","params":[1589812855]}
            mihome-vacuum.0	2020-05-28 11:22:11.114	debug	(6826) Receive <<< {"result":[[1589813020,1589813058,0,0,0,0]],"id":18}
            mihome-vacuum.0	2020-05-28 11:22:11.109	debug	(6826) sendMsg[1] >>> {"id":18,"method":"get_clean_record","params":[1589813020]}
            mihome-vacuum.0	2020-05-28 11:22:11.009	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":17}
            mihome-vacuum.0	2020-05-28 11:22:11.005	debug	(6826) 0. Mappointer_nomap___map_upload_handler
            mihome-vacuum.0	2020-05-28 11:22:11.004	debug	(6826) sendMsg[1] >>> {"id":17,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:10.913	debug	(6826) Receive <<< {"result":[[1590047127,1590047214,38,467500,0,0]],"id":16}
            mihome-vacuum.0	2020-05-28 11:22:10.909	debug	(6826) sendMsg[1] >>> {"id":16,"method":"get_clean_record","params":[1590047127]}
            mihome-vacuum.0	2020-05-28 11:22:10.713	debug	(6826) Receive <<< {"result":[[1590159774,1590165262,5454,78777500,0,1]],"id":15}
            mihome-vacuum.0	2020-05-28 11:22:10.708	debug	(6826) sendMsg[1] >>> {"id":15,"method":"get_clean_record","params":[1590159774]}
            mihome-vacuum.0	2020-05-28 11:22:10.512	debug	(6826) Receive <<< {"result":[[1590412996,1590413044,0,745000,0,0]],"id":14}
            mihome-vacuum.0	2020-05-28 11:22:10.507	debug	(6826) sendMsg[1] >>> {"id":14,"method":"get_clean_record","params":[1590412996]}
            mihome-vacuum.0	2020-05-28 11:22:10.504	debug	(6826) Receive <<< {"result":["map_upload_handler"],"id":13}
            mihome-vacuum.0	2020-05-28 11:22:10.497	debug	(6826) sendMsg[1] >>> {"id":13,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:22:10.313	debug	(6826) Receive <<< {"result":[[1590653494,1590653563,0,1317500,0,0]],"id":12}
            mihome-vacuum.0	2020-05-28 11:22:10.306	debug	(6826) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1590653494]}
            mihome-vacuum.0	2020-05-28 11:22:10.304	debug	(6826) Receive <<< {"result":"unknown_method","id":11}
            mihome-vacuum.0	2020-05-28 11:22:10.304	info	(6826) create state for carpet_mode
            mihome-vacuum.0	2020-05-28 11:22:10.303	debug	(6826) Receive <<< {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":10}
            mihome-vacuum.0	2020-05-28 11:22:10.297	debug	(6826) sendMsg[1] >>> {"id":11,"method":"get_room_mapping"}
            mihome-vacuum.0	2020-05-28 11:22:10.296	debug	(6826) sendMsg[1] >>> {"id":10,"method":"get_carpet_mode"}
            mihome-vacuum.0	2020-05-28 11:22:10.110	debug	(6826) Receive <<< {"result":[[1590657608,1590657628,0,122500,0,0]],"id":9}
            mihome-vacuum.0	2020-05-28 11:22:10.105	debug	(6826) sendMsg[1] >>> {"id":9,"method":"get_clean_record","params":[1590657608]}
            mihome-vacuum.0	2020-05-28 11:22:10.105	debug	(6826) Receive <<< {"result":[373752,5385192500,198,[1590657608,1590653494,1590412996,1590159774,1590047127,1589813020,1589812855,1589811915,1589811799,1589811788,1589811051,1589807988,1589807338,158
            mihome-vacuum.0	2020-05-28 11:22:10.097	debug	(6826) sendMsg[1] >>> {"id":8,"method":"get_clean_summary"}
            mihome-vacuum.0	2020-05-28 11:22:09.906	debug	(6826) Receive <<< {"result":[{"main_brush_work_time":131848,"side_brush_work_time":30132,"filter_work_time":22124,"sensor_dirty_time":30126}],"id":7}
            mihome-vacuum.0	2020-05-28 11:22:09.897	debug	(6826) sendMsg[1] >>> {"id":7,"method":"get_consumable"}
            mihome-vacuum.0	2020-05-28 11:22:09.702	debug	(6826) Receive <<< {"result":[80],"id":6}
            mihome-vacuum.0	2020-05-28 11:22:09.696	debug	(6826) sendMsg[1] >>> {"id":6,"method":"get_sound_volume"}
            mihome-vacuum.0	2020-05-28 11:22:09.501	debug	(6826) Receive <<< {"partner_id":"","id":5,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.3.9_003468","ap":{"ssid":"Roundhousekick","bssid":"44:4E:6D:2C:FC:F0","rssi":-54},"netif":{"l
            mihome-vacuum.0	2020-05-28 11:22:09.497	debug	(6826) Next WiFi check: 28.05 11:23
            mihome-vacuum.0	2020-05-28 11:22:09.497	debug	(6826) sendMsg[1] >>> {"id":5,"method":"miIO.info"}
            mihome-vacuum.0	2020-05-28 11:22:09.296	info	(6826) Connected
            mihome-vacuum.0	2020-05-28 11:22:09.295	debug	(6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-05-28 11:22:09.295	debug	(6826) Receive <<< {"result":[{"msg_ver":8,"msg_seq":958,"state":3,"battery":97,"clean_time":0,"clean_area":122500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":63,"dnd_enabled":0}],"id"
            mihome-vacuum.0	2020-05-28 11:22:09.290	debug	(6826) sendMsg[1] >>> {"id":4,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:22:09.289	debug	(6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-05-28 11:22:09.289	info	(6826) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-05-28 11:22:09.289	debug	(6826) Receive <<< Helo <<< 213100200000000005c604885ecf82c0ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-05-28 11:22:04.293	debug	(6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-05-28 11:22:04.292	debug	(6826) no answer for undefined(id:3) received, giving up
            mihome-vacuum.0	2020-05-28 11:22:01.402	debug	(6826) system.adapter.admin.0: logging true
            mihome-vacuum.0	2020-05-28 11:21:59.291	debug	(6826) sendMsg[3] >>> {"id":3,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:21:54.291	debug	(6826) sendMsg[2] >>> {"id":3,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:21:49.290	debug	(6826) sendMsg[1] >>> {"id":3,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:21:49.289	debug	(6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-05-28 11:21:49.289	info	(6826) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-05-28 11:21:49.289	debug	(6826) Receive <<< Helo <<< 213100200000000005c604885ecf82acffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-05-28 11:21:44.291	debug	(6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-05-28 11:21:44.291	debug	(6826) no answer for undefined(id:2) received, giving up
            mihome-vacuum.0	2020-05-28 11:21:43.674	debug	(6826) system.adapter.admin.0: logging false
            mihome-vacuum.0	2020-05-28 11:21:39.290	debug	(6826) sendMsg[3] >>> {"id":2,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:21:34.290	debug	(6826) sendMsg[2] >>> {"id":2,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:21:29.289	debug	(6826) sendMsg[1] >>> {"id":2,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:21:29.288	debug	(6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-05-28 11:21:29.288	info	(6826) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-05-28 11:21:29.288	debug	(6826) Receive <<< Helo <<< 213100200000000005c604885ecf8298ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-05-28 11:21:24.359	debug	(6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-05-28 11:21:24.359	debug	(6826) no answer for undefined(id:1) received, giving up
            mihome-vacuum.0	2020-05-28 11:21:19.358	debug	(6826) sendMsg[3] >>> {"id":1,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:21:14.357	debug	(6826) sendMsg[2] >>> {"id":1,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:21:13.343	debug	(6826) system.adapter.admin.0: logging true
            mihome-vacuum.0	2020-05-28 11:21:12.509	debug	(6826) system.adapter.admin.0: logging false
            mihome-vacuum.0	2020-05-28 11:21:09.800	info	(6826) set nächster Timer: Nicht verfügbar
            mihome-vacuum.0	2020-05-28 11:21:09.397	debug	(6826) TypeError: Cannot read property 'id' of undefined
            mihome-vacuum.0	2020-05-28 11:21:09.396	debug	(6826) 25616
            mihome-vacuum.0	2020-05-28 11:21:09.356	debug	(6826) sendMsg[1] >>> {"id":1,"method":"get_status"}
            mihome-vacuum.0	2020-05-28 11:21:09.340	debug	(6826) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
            mihome-vacuum.0	2020-05-28 11:21:09.334	debug	(6826) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-05-28 11:21:09.334	info	(6826) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-05-28 11:21:09.334	debug	(6826) Receive <<< Helo <<< 213100200000000005c604885ecf8284ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-05-28 11:21:09.324	info	(6826) New generation or new fw(3.3.9,003468) detected, create new states goto and zoneclean
            mihome-vacuum.0	2020-05-28 11:21:09.287	debug	(6826) server started on 0.0.0.0:53421
            mihome-vacuum.0	2020-05-28 11:21:09.282	info	(6826) Cloud control disabled
            mihome-vacuum.0	2020-05-28 11:21:09.281	info	(6826) Expert mode disabled, states deleted
            mihome-vacuum.0	2020-05-28 11:21:09.277	debug	(6826) load Map creator... true
            mihome-vacuum.0	2020-05-28 11:21:09.258	info	(6826) starting. Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.16.3, js-controller: 3.1.4
            mihome-vacuum.0	2020-05-28 11:21:08.765	debug	(6826) statesDB connected
            mihome-vacuum.0	2020-05-28 11:21:08.765	debug	(6826) States connected to redis: 127.0.0.1:9000
            mihome-vacuum.0	2020-05-28 11:21:08.761	debug	(6826) States create System PubSub Client
            mihome-vacuum.0	2020-05-28 11:21:08.760	debug	(6826) States create User PubSub Client
            mihome-vacuum.0	2020-05-28 11:21:08.751	debug	(6826) Redis States: Use Redis connection: 127.0.0.1:9000
            mihome-vacuum.0	2020-05-28 11:21:08.750	debug	(6826) objectDB connected
            mihome-vacuum.0	2020-05-28 11:21:08.748	debug	(6826) Objects connected to redis: 127.0.0.1:9001
            mihome-vacuum.0	2020-05-28 11:21:08.742	debug	(6826) Objects client initialize lua scripts
            mihome-vacuum.0	2020-05-28 11:21:08.741	debug	(6826) Objects create User PubSub Client
            mihome-vacuum.0	2020-05-28 11:21:08.741	debug	(6826) Objects create System PubSub Client
            mihome-vacuum.0	2020-05-28 11:21:08.740	debug	(6826) Objects client ready ... initialize now
            mihome-vacuum.0	2020-05-28 11:21:08.627	debug	(6826) Redis Objects: Use Redis connection: 127.0.0.1:9001
            host.IoBroker	2020-05-28 11:21:08.414	info	instance system.adapter.mihome-vacuum.0 started with pid 6826
            host.IoBroker	2020-05-28 11:21:08.406	info	"system.adapter.mihome-vacuum.0" enabled
            host.IoBroker	2020-05-28 11:21:06.950	info	instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            host.IoBroker	2020-05-28 11:21:06.437	info	stopInstance system.adapter.mihome-vacuum.0 send kill signal
            mihome-vacuum.0	2020-05-28 11:21:06.439	info	(6811) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            mihome-vacuum.0	2020-05-28 11:21:06.439	info	(6811) terminating
            mihome-vacuum.0	2020-05-28 11:21:06.438	info	(6811) Got terminate signal TERMINATE_YOURSELF
            host.IoBroker	2020-05-28 11:21:06.436	info	stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
            host.IoBroker	2020-05-28 11:21:06.436	info	"system.adapter.mihome-vacuum.0" disabled
            mihome-vacuum.0	2020-05-28 11:21:04.528	debug	(6811) sendMsg[2] >>> {"id":8,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-28 11:21:04.331	debug	(6811) sendMsg[2] >>> {"id":7,"method":"get_room_mapping"}
            mihome-vacuum.0	2020-05-28 11:21:04.331	debug	(6811) sendMsg[2] >>> {"id":6,"method":"get_carpet_mode"}
            mihome-vacuum.0	2020-05-28 11:21:04.129	debug	(6811) sendMsg[2] >>> {"id":5,"method":"get_clean_summary"}
            Gruß Daniel aka Seppel
            • Diginix
              Diginix last edited by
              @seppel786 sagte in Test Adapter mihome-vacuum v2.0.x:
              Node.js: v12.16.3
              Adapter: 2.0.9
              Hilft jetzt sicher nicht viel, aber genau mit dieser Konstellation läuft bei mir alles. nodejs 12 ist also kein generelles Problem.
              Abweichend bei mir ist es das Modell 1S und Karte aus der Xiaomi Cloud.
                seppel786 @Diginix last edited by seppel786
                @Diginix
                Spannende Kiste...Vlt liegt es auch am Zusammenspiel mit Valetudo?! Wäre jetzt interessant zu wissen,
                ob das bei jemand in der gleichen Konstellation läuft oder ob das Problem wieder vor dem Bildschirm sitzt 🙂
                  @seppel786 Bei mir genau das Setting von @Diginix Auch ein 1S, auch Xiaomi Cloud.
                    @All: Hat jemand ein ähnliches Setting wie ich, wo die Karte in Verbindung mit Valetudo funktioniert?
                    @Meistertr
                    Ist ein "Problem" mit Valetudo bekannt?!
                      dirkhe Developer last edited by
                      Bei den Karten kenne ich mich nicht so gut aus, aber kann es sein, dass man nicht auf die roborock App zurück darf, wenn man ioBroker nutzen möchte?
                        A Former User @dirkhe last edited by
                        @dirkhe die Karte funktioniert anscheinend nur, wenn der Sauger über die mihome App registriert ist.
                          radierer @backfisch88 last edited by
                          @backfisch88 said in Test Adapter mihome-vacuum v2.0.x:
                          Map reset hab ich noch nicht ausprobiert, aber eine Vorhandene Map widerherstellen lassen geht auf alle fälle nicht (zumindest nicht über den recover_map;[xxx] Befehl
                          Moin .. wie genau und wo hast du denn den Befehl "recover_map;[xxx]" ausgeführt?
                          • D3ltoroxp
                            D3ltoroxp @Xenon last edited by D3ltoroxp
                            @Xenon said in Test Adapter mihome-vacuum v2.0.x:
                            @dirkhe
                            damit habe ich die Canvas Fehler beseitigt
                            sudo iobroker stop
                            cd /opt/iobroker
                            sudo apt update
                            Ok, das scheint bei mir auch funktioniert zu haben. Leider scheint jetzt Port 80 belegt zu sein, den ich eigentlich für Alexa und Node.js benötige...
                            Kann das was mit dem Canvas Update zu tun haben oder mit dem hier ?
                            Ich hatte gleich noch upgrade mit gemacht, aber wenn sich bestehende SW updatet, ändert sich doch nicht einfach der Port oder ?
                              Jaschkopf @D3ltoroxp last edited by
                              Servus. Ich habe zwei Roborock S50 im Betrieb. Beide laufen über das selbe Xiaomi Konto auf dem Europa Server. Jedoch bekomme ich bei einem keine Karte geladen. Instanz 0 (Erdgeschoss) lädt sie einfach nicht. Bei Instanz 1 (Obergeschoss) klappt das wunderbar. Beide Roboter laufen mit stock Firmware 3.5.7_002008.
                              Das Update von canvas hab ich schon Probiert, hat jedoch nichts gebracht. Hat jemand eine Idee?
                              Gruß Jaschkopf
                                backfisch88 @radierer last edited by
                                @radierer
                                Genau so. Hatte bisher immer funktioniert.
                                J R 2 Replies Last reply Reply Quote 0
                                  Jaschkopf @backfisch88 last edited by
                                  @backfisch88 Habe das auch gerade mal probiert und bekomme im Log folgenden Fehler:
                                  mihome-vacuum.0	2020-06-05 18:18:00.833	warn	(28716) Could not receive Mappointer, giving up
                                  mihome-vacuum.0	2020-06-05 18:16:56.282	error	(28716) [69](X_send_command) -> response time out
                                  mihome-vacuum.0	2020-06-05 18:16:52.783	info	(28716) send message: Method: recover_map Params: [1]
                                  mihome-vacuum.0	2020-06-05 18:16:51.820	info	(28716) send message: Method: get_recover_maps
                                  Jetzt hat er zwar die Karte geladen, diese wird aber nicht aktualisiert wenn der Roboter saugt. Hat jemand noch eine Idee?
                                  Gruß Jaschkopf
                                    Einmal in die mihome App einloggen und nen Moment warten
                                      @radierer
                                      Besten Dank! Funktioniert wie gewünscht .. 👍🏻🙂
                                        Jaschkopf @dirkhe last edited by
                                        @dirkhe Ein Traum jetzt klappt es. Vielen Dank 💪💪
                                          @radierer bei mir sagt er nur „unknown command“ 🤣
                                            Hm .. seltsam. Ich hab ja nix anderes gemacht .. außer zusätzlich noch den Befehl zum zurückfahren an die Ladestation.
                                            Evtl. mal den Haken bei "eigene Befehle zulassen" in der Adapterkonfig raus- und wieder reinmachen!?
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            495351
