    4. Test Coronavirus Statistics for ioBroker
      Kampfratte @varg last edited by
      @varg liegt @Dutchman auch in der selben Pull Request vor.
      • Webranger
        Webranger last edited by
        Kommen bei euch noch aktuelle Daten an?
        Hab bis jetzt für Heute null neu infizierte!?
        Gruss
          Kampfratte @Webranger last edited by
          @Webranger jupp, ich hab bei Deutschland heute 98 neuinfizierte. Stand 16:00 Uhr.
          • Webranger
            Komisch .......
            • Webranger
              Webranger last edited by Webranger
              Hab immer noch diese Fehler im log
              coronavirus-statistics.0	2020-05-25 19:00:54.708	info	(15619) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              coronavirus-statistics.0	2020-05-25 19:00:54.285	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":415,"GEN":"Berlin Tempelhof-Schöneberg","BEZ":"Bezirk","death_rate":3.6036036036036,"cases":666,"deaths":24,"cases_per_100k":189.3
              coronavirus-statistics.0	2020-05-25 19:00:54.284	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":414,"GEN":"Berlin Friedrichshain-Kreuzberg","BEZ":"Bezirk","death_rate":1.15830115830116,"cases":518,"deaths":6,"cases_per_100k":1
              coronavirus-statistics.0	2020-05-25 19:00:54.275	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":413,"GEN":"Berlin Mitte","BEZ":"Bezirk","death_rate":1.2565445026178,"cases":955,"deaths":12,"cases_per_100k":248.586570598586,"ca
              coronavirus-statistics.0	2020-05-25 19:00:54.274	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":412,"GEN":"Berlin Steglitz-Zehlendorf","BEZ":"Bezirk","death_rate":2.41187384044527,"cases":539,"deaths":13,"cases_per_100k":174.6
              coronavirus-statistics.0	2020-05-25 19:00:54.273	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":411,"GEN":"Berlin Spandau","BEZ":"Bezirk","death_rate":2.66666666666667,"cases":300,"deaths":8,"cases_per_100k":122.962410391143,"
              coronavirus-statistics.0	2020-05-25 19:00:54.272	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":410,"GEN":"Berlin Marzahn-Hellersdorf","BEZ":"Bezirk","death_rate":0.84985835694051,"cases":353,"deaths":3,"cases_per_100k":131.44
              coronavirus-statistics.0	2020-05-25 19:00:54.261	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":409,"GEN":"Berlin Lichtenberg","BEZ":"Bezirk","death_rate":3.44827586206897,"cases":290,"deaths":10,"cases_per_100k":99.5018047568
              coronavirus-statistics.0	2020-05-25 19:00:54.260	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":408,"GEN":"Berlin Neukölln","BEZ":"Bezirk","death_rate":4.32432432432432,"cases":740,"deaths":32,"cases_per_100k":224.452593489055
              coronavirus-statistics.0	2020-05-25 19:00:54.255	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":407,"GEN":"Berlin Pankow","BEZ":"Bezirk","death_rate":4.14285714285714,"cases":700,"deaths":29,"cases_per_100k":171.667504567582,"
              coronavirus-statistics.0	2020-05-25 19:00:54.254	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":406,"GEN":"Berlin Treptow-Köpenick","BEZ":"Bezirk","death_rate":2.89855072463768,"cases":345,"deaths":10,"cases_per_100k":127.2344
              coronavirus-statistics.0	2020-05-25 19:00:54.253	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":405,"GEN":"Berlin Charlottenburg-Wilmersdorf","BEZ":"Bezirk","death_rate":2.97297297297297,"cases":740,"deaths":22,"cases_per_100k
              coronavirus-statistics.0	2020-05-25 19:00:54.241	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":404,"GEN":"Berlin Reinickendorf","BEZ":"Bezirk","death_rate":4.43548387096774,"cases":496,"deaths":22,"cases_per_100k":187.0110283
              und diese:
              coronavirus-statistics.0	2020-05-25 19:00:28.066	warn	(15619) State attribute definition missing for + criticalPerOneMillion
              coronavirus-statistics.0	2020-05-25 19:00:27.834	warn	(15619) State attribute definition missing for + recoveredPerOneMillion
              coronavirus-statistics.0	2020-05-25 19:00:27.497	warn	(15619) State attribute definition missing for + activePerOneMillion
              coronavirus-statistics.0	2020-05-25 19:00:27.282	warn	(15619) State attribute definition missing for + population
              Hab ich was überlesen was ich machen muss und gibt es da schon eine Lösung?
              Gruss
              crunchip K 2 Replies Last reply Reply Quote 0
                crunchip Forum Testing Most Active @Webranger last edited by
                @Webranger habs manuell geändert
                https://github.com/iobroker-community-adapters/ioBroker.coronavirus-statistics/pull/52
                Kampfratte created this issue in iobroker-community-adapters/ioBroker.coronavirus-statistics
                closed #51 #52
                  @Webranger der Pull Request liegt Dutchman schon seit geraumer Zeit vor.
                  Bis er es integriert hat, kannst du den Adapter incl. des Pull requests auch von meinem Fork installieren
                  https://github.com/Kampfratte/ioBroker.coronavirus-statistics
                  Lg
                  crunchip M 2 Replies Last reply Reply Quote 2
                    crunchip Forum Testing Most Active @Kampfratte last edited by crunchip
                    @Kampfratte gibt schon wieder was zu tun😜
                    	(26469) State attribute definition missing for + todayRecovered
                    Ah...hast du schon...grad gesehen
                    C K 2 Replies Last reply Reply Quote 0
                      Coffeelover @crunchip last edited by
                      @crunchip sagte in Test Coronavirus Statistics for ioBroker:
                      +1
                        Michi68 @Kampfratte last edited by
                        Danke @Kampfratte
                        hat er schon gemacht einfach noch mal von hier https://github.com/Kampfratte/ioBroker.coronavirus-statistics
                        die zwei main.js, stateAttr.js austauschen
                          Kampfratte @crunchip last edited by
                          @crunchip jupp, ist schon gemacht und auch wieder gleich per Pull Request weiter gegeben worden 🙂
                          • Dutchman
                            Hi all,
                            Sorry ich hatte eine kleine (notwendige) Auszeit um bissl zur ruhe zu kommen, werden ab dieser/spaetestens nieste Woche wieder aktiver unterwegs sein.
                            (manchmal hat man solche Momente)
                            Cheers,
                            Dutch
                            Chaot K 2 Replies Last reply Reply Quote 3
                            • Chaot
                              Chaot @Dutchman last edited by
                              @Dutchman
                              In das Ruhe liegt der Kraft.
                              Ales Gut!
                                Kampfratte @Dutchman last edited by
                                @Dutchman kein Ding. Braucht jeder mal, denke ich.
                                Heute kam wieder ne Meldung, die ich angepasst habe und auch gleich per Pull Request angepasst habe.
                                • V
                                  vsa @sigi234 last edited by
                                  Hallo @sigi234 und @Scrounger ,
                                  danke erst mal an alle hier für diesen tollen Adapter und Idden für Views.
                                  Ich habe Scroungers View vom 19.3. hier mal testweise implementiert. Ich bin noch Anfänger, steige nach un d nach mehr durch. Mi Chats hatte ich noch nichts zu tun.
                                  Bei mir werden auch keine Charts angezeigt. Klar, ich habe die materila-design-widgets in der neusten Version installiert. Auch iobroker läuft in der neusten Version auf meinem pi3.
                                  Frage: Muss ich noch sql oder history installieren?
                                  Danke schon mal,
                                  vsa
                                    Coffeelover @vsa last edited by Coffeelover
                                    @vsa sagte in Test Coronavirus Statistics for ioBroker:
                                    Ja. Der einfachste Weg ist: History Adapter installieren und dann die Datenpunkte, die in das Chart sollen im Reiter Objekte mit dem Schraubenschlüssel zur Historisierung "aktivieren".
                                    PS: Zum lernen hast du dir mit der View von Scrounger eine ziemlich komplexe rausgesucht, weil diese aus Detailviews je Land und der Patternview inkl. persönlich angelegter Datenpunkte zum Umschalten usw. besteht. Der Start wäre also zunächst das einzelne Länderview ans Laufen zu bringen.
                                    V 1 Reply Last reply Reply Quote 1
                                    • V
                                      vsa @Coffeelover last edited by
                                      @Coffeelover
                                      danke, das ist schon mal eine Hilfe. SQL auch?
                                      VG vsa
                                        @vsa Nein, beide Lösungen (History und SQL) erfüllen in dem Fall den gleichen Anwendungszweck: Sie speichern kontinuierlich oder bei Änderungen Datensätze ab, welche dann im Widget dargestellt werden können. SQL ist mächtiger, weil du darüber SQL-Abfragen etc. ausführen kannst. Nur für die Charts genügt History.
                                        • V
                                          @Coffeelover Vielen Dank. Dann wage ich mich mal an ein Detailview eines Landes ran...
                                            @vsa Die Scrounger ja z.B. auch hochgeladen hat... 😉
                                            adapter installation adapterentwicklung testen
                                            120
                                            1177
                                            333582
