    4. Test Coronavirus Statistics for ioBroker
    • Webranger
      Webranger last edited by Webranger
      Hab immer noch diese Fehler im log
      coronavirus-statistics.0	2020-05-25 19:00:54.708	info	(15619) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      coronavirus-statistics.0	2020-05-25 19:00:54.285	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":415,"GEN":"Berlin Tempelhof-Schöneberg","BEZ":"Bezirk","death_rate":3.6036036036036,"cases":666,"deaths":24,"cases_per_100k":189.3
      coronavirus-statistics.0	2020-05-25 19:00:54.284	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":414,"GEN":"Berlin Friedrichshain-Kreuzberg","BEZ":"Bezirk","death_rate":1.15830115830116,"cases":518,"deaths":6,"cases_per_100k":1
      coronavirus-statistics.0	2020-05-25 19:00:54.275	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":413,"GEN":"Berlin Mitte","BEZ":"Bezirk","death_rate":1.2565445026178,"cases":955,"deaths":12,"cases_per_100k":248.586570598586,"ca
      coronavirus-statistics.0	2020-05-25 19:00:54.274	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":412,"GEN":"Berlin Steglitz-Zehlendorf","BEZ":"Bezirk","death_rate":2.41187384044527,"cases":539,"deaths":13,"cases_per_100k":174.6
      coronavirus-statistics.0	2020-05-25 19:00:54.273	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":411,"GEN":"Berlin Spandau","BEZ":"Bezirk","death_rate":2.66666666666667,"cases":300,"deaths":8,"cases_per_100k":122.962410391143,"
      coronavirus-statistics.0	2020-05-25 19:00:54.272	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":410,"GEN":"Berlin Marzahn-Hellersdorf","BEZ":"Bezirk","death_rate":0.84985835694051,"cases":353,"deaths":3,"cases_per_100k":131.44
      coronavirus-statistics.0	2020-05-25 19:00:54.261	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":409,"GEN":"Berlin Lichtenberg","BEZ":"Bezirk","death_rate":3.44827586206897,"cases":290,"deaths":10,"cases_per_100k":99.5018047568
      coronavirus-statistics.0	2020-05-25 19:00:54.260	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":408,"GEN":"Berlin Neukölln","BEZ":"Bezirk","death_rate":4.32432432432432,"cases":740,"deaths":32,"cases_per_100k":224.452593489055
      coronavirus-statistics.0	2020-05-25 19:00:54.255	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":407,"GEN":"Berlin Pankow","BEZ":"Bezirk","death_rate":4.14285714285714,"cases":700,"deaths":29,"cases_per_100k":171.667504567582,"
      coronavirus-statistics.0	2020-05-25 19:00:54.254	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":406,"GEN":"Berlin Treptow-Köpenick","BEZ":"Bezirk","death_rate":2.89855072463768,"cases":345,"deaths":10,"cases_per_100k":127.2344
      coronavirus-statistics.0	2020-05-25 19:00:54.253	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":405,"GEN":"Berlin Charlottenburg-Wilmersdorf","BEZ":"Bezirk","death_rate":2.97297297297297,"cases":740,"deaths":22,"cases_per_100k
      coronavirus-statistics.0	2020-05-25 19:00:54.241	error	(15619) Unknown Bezirk received containing {"attributes":{"OBJECTID":404,"GEN":"Berlin Reinickendorf","BEZ":"Bezirk","death_rate":4.43548387096774,"cases":496,"deaths":22,"cases_per_100k":187.0110283
      und diese:
      coronavirus-statistics.0	2020-05-25 19:00:28.066	warn	(15619) State attribute definition missing for + criticalPerOneMillion
      coronavirus-statistics.0	2020-05-25 19:00:27.834	warn	(15619) State attribute definition missing for + recoveredPerOneMillion
      coronavirus-statistics.0	2020-05-25 19:00:27.497	warn	(15619) State attribute definition missing for + activePerOneMillion
      coronavirus-statistics.0	2020-05-25 19:00:27.282	warn	(15619) State attribute definition missing for + population
      Hab ich was überlesen was ich machen muss und gibt es da schon eine Lösung?
      Gruss
      crunchip K 2 Replies Last reply Reply Quote 0
        crunchip Forum Testing Most Active @Webranger last edited by
        @Webranger habs manuell geändert
        https://github.com/iobroker-community-adapters/ioBroker.coronavirus-statistics/pull/52
          Kampfratte @Webranger last edited by
          @Webranger der Pull Request liegt Dutchman schon seit geraumer Zeit vor.
          Bis er es integriert hat, kannst du den Adapter incl. des Pull requests auch von meinem Fork installieren
          https://github.com/Kampfratte/ioBroker.coronavirus-statistics
          Lg
          crunchip M 2 Replies Last reply Reply Quote 2
            crunchip Forum Testing Most Active @Kampfratte last edited by crunchip
            @Kampfratte gibt schon wieder was zu tun😜
            	(26469) State attribute definition missing for + todayRecovered
            Ah...hast du schon...grad gesehen
            C K 2 Replies Last reply Reply Quote 0
              Coffeelover @crunchip last edited by
              @crunchip sagte in Test Coronavirus Statistics for ioBroker:
              +1
                Michi68 @Kampfratte last edited by
                Danke @Kampfratte
                hat er schon gemacht einfach noch mal von hier https://github.com/Kampfratte/ioBroker.coronavirus-statistics
                die zwei main.js, stateAttr.js austauschen
                  Kampfratte @crunchip last edited by
                  @crunchip jupp, ist schon gemacht und auch wieder gleich per Pull Request weiter gegeben worden 🙂
                  • Dutchman
                    Hi all,
                    Sorry ich hatte eine kleine (notwendige) Auszeit um bissl zur ruhe zu kommen, werden ab dieser/spaetestens nieste Woche wieder aktiver unterwegs sein.
                    (manchmal hat man solche Momente)
                    Cheers,
                    Dutch
                    Chaot K 2 Replies Last reply Reply Quote 3
                    • Chaot
                      Chaot @Dutchman last edited by
                      @Dutchman
                      In das Ruhe liegt der Kraft.
                      Ales Gut!
                        Kampfratte @Dutchman last edited by
                        @Dutchman kein Ding. Braucht jeder mal, denke ich.
                        Heute kam wieder ne Meldung, die ich angepasst habe und auch gleich per Pull Request angepasst habe.
                        • V
                          vsa @sigi234 last edited by
                          Hallo @sigi234 und @Scrounger ,
                          danke erst mal an alle hier für diesen tollen Adapter und Idden für Views.
                          Ich habe Scroungers View vom 19.3. hier mal testweise implementiert. Ich bin noch Anfänger, steige nach un d nach mehr durch. Mi Chats hatte ich noch nichts zu tun.
                          Bei mir werden auch keine Charts angezeigt. Klar, ich habe die materila-design-widgets in der neusten Version installiert. Auch iobroker läuft in der neusten Version auf meinem pi3.
                          Frage: Muss ich noch sql oder history installieren?
                          Danke schon mal,
                          vsa
                            Coffeelover @vsa last edited by Coffeelover
                            @vsa sagte in Test Coronavirus Statistics for ioBroker:
                            Ja. Der einfachste Weg ist: History Adapter installieren und dann die Datenpunkte, die in das Chart sollen im Reiter Objekte mit dem Schraubenschlüssel zur Historisierung "aktivieren".
                            PS: Zum lernen hast du dir mit der View von Scrounger eine ziemlich komplexe rausgesucht, weil diese aus Detailviews je Land und der Patternview inkl. persönlich angelegter Datenpunkte zum Umschalten usw. besteht. Der Start wäre also zunächst das einzelne Länderview ans Laufen zu bringen.
                            V 1 Reply Last reply Reply Quote 1
                            • V
                              vsa @Coffeelover last edited by
                              @Coffeelover
                              danke, das ist schon mal eine Hilfe. SQL auch?
                              VG vsa
                                @vsa Nein, beide Lösungen (History und SQL) erfüllen in dem Fall den gleichen Anwendungszweck: Sie speichern kontinuierlich oder bei Änderungen Datensätze ab, welche dann im Widget dargestellt werden können. SQL ist mächtiger, weil du darüber SQL-Abfragen etc. ausführen kannst. Nur für die Charts genügt History.
                                • V
                                  @Coffeelover Vielen Dank. Dann wage ich mich mal an ein Detailview eines Landes ran...
                                    @vsa Die Scrounger ja z.B. auch hochgeladen hat... 😉
                                    • V
                                      Hallo @Coffeelover und alle zusammen,
                                      mittelmäßig gut durchgestiegen. Siehe Bilder.
                                      • die Views gehen bei mir
                                      • die detailviews habe ich weitgehenst angepasst, sodass die Infos unter den Icons richtig zu den Werten angezeigt werden
                                      • history adapter installiert und loggt die Werte von coronavirus-statistics.0 mit
                                      Was muss ich noch malchen, dass die Chart angezeigt wird? Irgendetwas muss ich übersehen haben 😞
                                      VG vsa
                                        @vsa: Der Datenpunkt 0_userdata.0.vis.Corona.timeInterval scheint mir nicht angelegt oder nicht richtig verlinkt. DU musst dazu auf der Admin-Oberfläche unter Objects mit Plus einen Datenpunkt vom Typ Zahl hinzufügen und bei "Zeitintervall über Objekt steuern" im Widget eintragen.
                                        • V
                                          @Coffeelover Fast super! Danke für den Tipp. Der DP war da, jedoch wie du schon vermutet hast a) falsch verlinkt und b) vom Typ String. Ich habe auf Typ Zahl gesetzt.
                                          Sorry für die erneute Nachfrage....
                                          Ich sehe nun einen Chart. Warum auch immer plötzlich nicht die Tagesdarstellung sondern in Jahren... Ich habe nichts verändert an anderen Einstellungen...
                                            @vsa Na weil dein Datenpunkt selbst gerade noch leer ist. In dem exportierten VIS gibt es noch ein Auswahlwidget für den Zeitraum. Bei dem wird ebenfalls der neue Datenpunkt eingetragen und mit jedem Wechsel der Zeitraum des Diagramms angepasst. Damit du die Logik verstehst: In dem Select Widget wählst du einen Wert aus, welcher in den Datenpunkt geschrieben wird. Das Verlaufswidget nutzt diesen Datenpunkt, um die Zeitskalierung daran anzupassen.
                                            Hier mein Auswahl Widget. Passt bei dir farblich nicht, aber für die Funktion kannst das nutzen. (Datenpunkt neu verlinken!)
                                            [{"tpl":"tplVis-materialdesign-Select","data":{"oid":"0_userdata.0.MaterialDesign.History_DSL","g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"inputType":"text","inputLayout":"solo","showInputCounter":false,"clearIconShow":false,"listDataMethod":"valueList","countSelectItems":"9","listPosition":"auto","showSelectedIcon":"prepend-inner","showValue":"true","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"inputLayoutBackgroundColor":"transparent","inputLayoutBackgroundColorHover":"#000020","inputLayoutBackgroundColorSelected":"#000020","inputLayoutBorderColor":"#000020","inputTextFontFamily":"Jura-Regular","inputTextFontSize":"20","inputTextColor":"#bbb9b9","inputLabelText":"Zeitraum DSL Speed","inputLabelFontFamily":"Jura-Regular","inputLabelFontSize":"20","clearIconSize":"-1","valueList":"12 hours;1 day;2 days;7 days;14 days;1 month;2 months","value0":"","value1":"","value2":"","label0":"","label1":"","label2":"","inputPrefix":"","inputCounterColor":"","jsonStringObject":"","subLabel0":"","listIcon0":"","listIcon1":"","subLabel1":"","valueListLabels":"12 Stunden;1 Tag;2 Tage;7 Tage;14 Tage;1 Monat;2 Monate","inputLayoutBorderColorHover":"#000020","inputLayoutBorderColorSelected":"#000020","inputLabelColor":"#000020","inputLabelColorSelected":"#bbb9b9","inputTranslateY":"0","inputTranslateX":"0","g_inputSubText":false,"showInputMessageAlways":"true","listItemHeight":"-2","name":"Zeitauswahl","views":["055_Corona_AT_2","056_Corona_BY_2","057_Corona_Frankreich","058_Corona_Italien","059_Corona_USA"],"listItemValueFontSize":"","listItemFontSize":"-1","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","vibrateOnMobilDevices":"50"},"style":{"left":"1100px","top":"13px","z-index":"30","font-family":"Jura-DemiBold","font-size":"xx-large","width":"160px"},"widgetSet":"materialdesign"}]
                                            Noch ein Hinweis: Offensichtlich aktivierst du gerade sehr fleißig die Historisierung. Das ist eigentlich nur für den jeweiligen Datenpunkt selbst nötig, den du in einem Diagramm darstellen willst. An den letzten beiden Sceenshots sieht man, dass du das auch für das Timeintervall aktiviert hast. Kostet unnötig Performance und Speicherplatz - es sei denn du willst dir später anzeigen lassen, wann du welches Zeitintervall hast anzeigen lassen.
                                            Edit: Sorry - hab dir was falsches gesagt. Typ STRING / Zeichenkette war richtig. Bitte wieder zurück ändern. Habe das mit einem anderen Widget gerade verwechselt.
                                            adapter installation adapterentwicklung testen
                                            120
                                            1177
                                            334548
