    4. Gelöst: Probleme beim Javascript-Update auf 4.5.1 auf 4.6.17
    SOLVED Gelöst: Probleme beim Javascript-Update auf 4.5.1 auf 4.6.17
    • crepp1967
      crepp1967 @Thomas Braun last edited by
      @Thomas-Braun sagte in Probleme beim Javascript-Update auf 4.5.1 auf 4.6.17:
      iobroker del admin.0.0
      ohne sudo kommt das: (die Hilfe ?)
      pi@raspisuper:~ $ iobroker del admin.0.0
      Commands:
      iobroker setup [--objects <host>] [--states <host>] [custom]
      iobroker start - starts the js-controller
      iobroker stop - stops the js-controller
      iobroker start <adapter>[.instance] - starts a specified adapter instance
      iobroker stop <adapter>.[instance] - stops a specified adapter instance
      iobroker start all - starts js-controller and all adapters
      iobroker restart - restarts the js-controller
      iobroker restart <adapter>[.instance] - restarts a specified adapter
      iobroker debug <adapter> [--ip=<ip>] [--port=<port>] [--wait] - Starts a Node.js debugging session for the adapter
          --wait stops the execution until the debugger is attached.
          --ip and --port can be used to change the listen IP and port. Use IP 0.0.0.0 for remote debugging.
      iobroker info - shows the host info
      iobroker logs [adapter] [--watch] [--lines=1000]
      iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
      iobroker install <adapter> - installs a specified adapter
      iobroker rebuild <adapter>|self [--install]
      iobroker url <url> [<name>] - install adapter from specified url, e.g. GitHub
      iobroker del <adapter> - remove adapter from system
      iobroker del <adapter>.<instance> - remove adapter instance
      iobroker update [repository url] [--updatable/--u] [--installed/--i] [--force/--f] - update repository and optionally filter installed/updateable adapters, use --force to bypass hash check
      iobroker upgrade [repository url]
      iobroker upgrade self [repository url] - upgrade js-controller and all adapters, optionally you can specify the repository url
      iobroker upgrade <adapter> [repository url] - upgrade specified adapter, optionally you can specify the repository url
      iobroker upload <pathToLocalFile> <pathIniobroker>
      iobroker upload all - upload all adapter files to make them available for instances
      iobroker upload <adapter> - upload specified adapter files to make them available for instan
      • crepp1967
        crepp1967 last edited by
        soll ich es mal mit sudo probieren ?
          Thomas Braun Most Active @crepp1967 last edited by
          @crepp1967
          sudo sollte eigentlich nicht erforderlich sein.
          Probier mal ein
          iobroker stop
          iobroker fix
          • crepp1967
            trotz stop und fix kommt die gleiche Ausgabe beim Befehl:
              Thomas Braun Most Active @crepp1967 last edited by Thomas Braun
              @crepp1967
              Dann weiß ich auch nicht weiter.
              @haselchen hat's kaputt gemacht!1!11 😉
              • haselchen
                haselchen Most Active @Thomas Braun last edited by
                @Thomas-Braun
                Ruhig Brauner
                Verantwortlich ist immer noch jeder für sich selber.
                Ich habe zu nichts geraten ,sondern ein Link gepostet und auch zu Bedenken gegeben ob das überhaupt auf das Problem vom TE aufwendbar ist.
                Ich wäre dir zu Dank verpflichtet ,wenn Du diese unsinnige Aussage löschen würdest.
                Thomas Braun 1 Reply Last reply Reply Quote -1
                  Thomas Braun Most Active @haselchen last edited by Thomas Braun
                  @haselchen War nicht ernst gemeint. Sollte man an dem !111!!1 erkennen.
                  • crepp1967
                    nein ist schon klar das jeder für sich selbst verantwortlich ist. Ein Backup ist selbstverständlich vorhanden - es nützt hier bloß nicht viel weil der verdammte admin1 dann immer noch da ist...
                    • crepp1967
                      Habe mittlerweile ein Backup vom 4.6. wiederhergestellt und natürlich den Ausgangszustand u. natürlich auch den Ausgangsfehler.
                      Iregndjemand eine Idee wie ich meinen Javascript Adapter updaten kann und vor allen Dingen wie ich die widerspenstige admin.1 Instanz loswerde ?
                      Torsten
                      • crepp1967
                        Zusätzlich zum Javascript Adapter steht auch noch ein Update des JS Controllers an:
                          was wäre denn mit iobroker del admin
                          das müsste dochh eigentlich alle Instanzen mit löschen
                          • Bluefox
                            Bluefox last edited by
                            Man kann auch Objekt löschen:
                            iobroker state del system.adapter.admin.0.0
                            Usw
                              apollon77 @Bluefox last edited by
                              @Bluefox aber dann eher "object del" oder?
                              crepp1967 1 Reply Last reply Reply Quote 0
                              • crepp1967
                                crepp1967 @apollon77 last edited by
                                @apollon77
                                Aktuell habe ich ein Backup zurückgespielt und wieder den Ausgangszustand vom Start des Threads:
                                  @crepp1967
                                  iobroker object del system.adapter.admin.1
                                  • crepp1967
                                    Das war der notwendige Befehl, alles OK !
                                    Vielen Dank für Eure Hilfe.
                                    Auch das Javascript Update lief durch.
                                    Bin happy...
                                    Torsten
                                    admin adapter javascript adapter master slave
                                    1900
