    4. Backitup löscht keine alten Sicherungen
    SOLVED Backitup löscht keine alten Sicherungen
      Homoran Global Moderator Administrators @simatec last edited by Homoran
      @simatec sagte in Backitup löscht keine alten Sicherungen:
      Hast du automatische Backups gemacht oder nur manuelle?
      Echt jetzt?
      2 manuelle, dann nur noch automatische
       "_id": "system.adapter.backitup.0",
       "common": {
         "name": "backitup",
         "version": "1.4.5",
         "title": "BackItUp",
         "authors": [
           "simatec <nais@gmx.net>",
           "peoples0815 <peoples0815github@gmail.com>",
           "bluefox <dogafox@gmail.com>"
         "docs": {
           "en": "docs/en/backitup.md",
           "de": "docs/de/backitup.md"
         "platform": "Javascript/Node.js",
         "mode": "daemon",
         "compact": true,
         "icon": "backitup.png",
         "materialize": true,
         "messagebox": true,
         "stopBeforeUpdate": true,
         "enabled": true,
         "extIcon": "https://raw.githubusercontent.com/simatec/ioBroker.backitup/master/admin/backitup.png",
         "keywords": [
           "Backup",
           "IoBroker",
           "Homematic"
         "readme": "https://github.com/simatec/ioBroker.backitup/blob/master/README.md",
         "loglevel": "info",
         "type": "general",
         "license": "MIT",
         "installedFrom": "iobroker.backitup@1.4.5",
         "installedVersion": "1.4.5",
         "host": "raspberrypi"
       "native": {
         "debugLevel": false,
         "notificationEnabled": false,
         "mySqlEnabled": false,
         "redisEnabled": false,
         "historyEnabled": true,
         "zigbeeEnabled": false,
         "cifsEnabled": false,
         "ftpEnabled": false,
         "dropboxEnabled": false,
         "googledriveEnabled": false,
         "historyEntriesNumber": "25",
         "minimalEnabled": true,
         "minimalTime": "02:00",
         "minimalEveryXDays": "1",
         "minimalDeleteAfter": "5",
         "minimalNameSuffix": "",
         "ccuEnabled": false,
         "ccuTime": "01:30",
         "ccuEveryXDays": "3",
         "ccuDeleteAfter": "5",
         "ccuHost": "192.168.yyy.xxx",
         "ccuUser": "Admin",
         "ccuPassword": "",
         "mySqlHost": "localhost",
         "mySqlPort": "3306",
         "mySqlName": "iobroker",
         "mySqlUser": "",
         "mySqlPassword": "",
         "mySqlDumpExe": "",
         "mysqlQuick": false,
         "mysqlSingleTransaction": false,
         "redisPath": "/var/lib/redis",
         "historyPath": "",
         "notificationsType": "Telegram",
         "telegramInstance": "",
         "telegramUser": null,
         "telegramNoticeType": "longTelegramNotice",
         "telegramWaitToSend": "0",
         "telegramSilentNotice": false,
         "telegramOnlyError": false,
         "pushoverInstance": "",
         "pushoverNoticeType": "longPushoverNotice",
         "pushoverWaitToSend": "0",
         "pushoverDeviceID": "",
         "pushoverSilentNotice": false,
         "pushoverOnlyError": false,
         "emailReceiver": "xxx@xxx.com",
         "emailSender": "xxx@xxx.com",
         "emailInstance": "",
         "emailNoticeType": "longEmailNotice",
         "emailWaitToSend": "0",
         "emailOnlyError": false,
         "connectType": "NFS",
         "cifsMount": "",
         "cifsDomain": "",
         "cifsUser": "",
         "cifsPassword": "",
         "smbType": "vers=1.0",
         "sudoMount": false,
         "cifsDeleteOldBackup": false,
         "cifsOwnDir": false,
         "wakeOnLAN": false,
         "macAd": "20:DE:20:DE:20:DE",
         "wolWait": "25",
         "cifsMinimalDir": "sharename/backupDir",
         "cifsCcuDir": "sharename/backupDir",
         "cifsDir": "sharename/backupDir",
         "ftpHost": "",
         "ftpPort": "21",
         "ftpUser": "",
         "ftpPassword": "",
         "ftpDeleteOldBackup": false,
         "ftpOwnDir": false,
         "ftpMinimalDir": "/backupDir/iobroker",
         "ftpCcuDir": "/backupDir/ccu",
         "ftpDir": "/backupDir",
         "dropboxAccessToken": "",
         "dropboxDeleteOldBackup": false,
         "dropboxOwnDir": false,
         "dropboxMinimalDir": "/backupDir/iobroker",
         "dropboxCcuDir": "/backupDir/ccu",
         "dropboxDir": "/backupDir",
         "googledriveAccessJson": "",
         "googledriveDeleteOldBackup": false,
         "googledriveOwnDir": false,
         "googledriveMinimalDir": "/backupDir/iobroker",
         "googledriveCcuDir": "/backupDir/ccu",
         "googledriveDir": "/backupDir",
         "restoreSource": "local",
         "startAllRestore": false
      simatec 2 Replies Last reply Reply Quote 0
      • simatec
        @Homoran
        Laut Config sieht alles gut aus.
        Schalte mal bitte auf debug und wir schauen mal, was er so beim Backup alles ausspuckt
        • simatec
          @Homoran sagte in Backitup löscht keine alten Sicherungen:
          Echt jetzt?
            @simatec Mach ich gerne.
            Was mir aber noch aufgefallen war ist, dass bei jedem Aufruf der Konfig IMMER der Button Speichern aktiv war.
            da habe ich dann auch mal drufgedrückt gehabt.
            • simatec
              @Homoran
              Das dürfte so nicht sein.
              Tritt es nach einmaligen speichern noch immer auf?
                @simatec grade jetzt am Tablet getestet:
                Ja!
                Immer noch
                Edit:
                Das Tablet ist langsamer da könnte man folgendes erkennen
                Nach speichern sind die Buttons grau,
                Nach schließen und wieder Öffnen sind die Buttons erst grau, die Seite baut sich auf, dann werden die Buttons blau und aktiv.
                • simatec
                  @Homoran
                  Dann stimmt da was nicht.
                  Lösche mal Instanz und Adapter und installiere den nach Restart mal neu
                    @simatec mache ich morgen wenn ich wieder am PC bin.
                    Habe eben noch was editiert
                      Nix 😉
                      2020-06-05 00:01:57.009 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 29386
                      2020-06-05 00:01:59.881 - debug: backitup.0 (29386) Redis Objects: Use Redis connection: 127.0.0.1:9001
                      2020-06-05 00:02:00.164 - debug: backitup.0 (29386) Objects client ready ... initialize now
                      2020-06-05 00:02:00.709 - debug: backitup.0 (29386) Objects create System PubSub Client
                      2020-06-05 00:02:00.711 - debug: backitup.0 (29386) Objects create User PubSub Client
                      2020-06-05 00:02:00.712 - debug: backitup.0 (29386) Objects client initialize lua scripts
                      2020-06-05 00:02:03.874 - warn: backitup.0 (29386) no connection to objects DB
                      2020-06-05 00:02:11.349 - debug: backitup.0 (29386) Objects connected to redis: 127.0.0.1:9001
                      Hab noch nicht neu installiert!
                      • simatec
                        @Homoran
                        Hmm eas sagt der Log beim Start von Backitup?
                        Findet Backitup die vorhandenen Backups beim Start?
                          2020-06-06 11:39:48.706 - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
                          2020-06-06 11:39:48.707 - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
                          2020-06-06 11:39:48.710 - info: backitup.0 (29386) Got terminate signal TERMINATE_YOURSELF
                          2020-06-06 11:39:48.712 - info: backitup.0 (29386) cleaned everything up...
                          2020-06-06 11:39:48.713 - info: backitup.0 (29386) terminating
                          2020-06-06 11:39:48.715 - info: backitup.0 (29386) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                          2020-06-06 11:39:49.245 - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (156)
                          2020-06-06 11:39:51.255 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 27917
                          2020-06-06 11:39:58.999 - debug: backitup.0 (27917) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          2020-06-06 11:40:02.999 - warn: backitup.0 (27917) no connection to objects DB
                          2020-06-06 11:40:03.919 - debug: backitup.0 (27917) Objects client ready ... initialize now
                          2020-06-06 11:40:04.286 - debug: backitup.0 (27917) Objects create System PubSub Client
                          2020-06-06 11:40:04.287 - debug: backitup.0 (27917) Objects create User PubSub Client
                          2020-06-06 11:40:04.288 - debug: backitup.0 (27917) Objects client initialize lua scripts
                          2020-06-06 11:40:09.759 - debug: backitup.0 (27917) Objects connected to redis: 127.0.0.1:9001
                          2020-06-06 11:40:09.766 - debug: backitup.0 (27917) objectDB connected
                          2020-06-06 11:40:09.769 - debug: backitup.0 (27917) Redis States: Use Redis connection: 127.0.0.1:9000
                          2020-06-06 11:40:09.899 - debug: backitup.0 (27917) States create User PubSub Client
                          2020-06-06 11:40:09.901 - debug: backitup.0 (27917) States create System PubSub Client
                          2020-06-06 11:40:09.920 - debug: backitup.0 (27917) States connected to redis: 127.0.0.1:9000
                          2020-06-06 11:40:09.921 - debug: backitup.0 (27917) statesDB connected
                          2020-06-06 11:40:12.521 - info: backitup.0 (27917) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.19.0
                          2020-06-06 11:40:12.628 - info: backitup.0 (27917) [iobroker] backup was activated at 02:00 every 1 day(s)
                          Bin auf wiederherstellen - Lokal - Backups suchen gegangen.
                          Meckert es erstmal wieder dass ich erst sichern solle.
                          Danach geht brav der Button auf grau, aber passiert erst mal nichts.
                          Inzwischen ist der Button immer noch grau
                          • simatec
                            @Homoran
                            Starte den Adapter einfach mal mit debuglog neu.
                            Da sollten alle Backups im Log erscheinen
                              Habe ich jetzt bereits zigmal gemacht (Instanz neu gestartet)
                              • simatec
                                @Homoran
                                Welche Version ist installiert? 1.5.8?
                                  @Homoran
                                  1.4.5 (actual stable!)
                                  • simatec
                                    @Homoran
                                    OK ... da gab es die Logausgaben noch nicht.
                                    Ich denke da ist irgendwas schief und ich würde sagen Instanz und Adapter löschen, neustarten und nochmal neu installieren.
                                    Eventuell direkt die aktuelle Version aus der latest
                                      @simatec
                                      Gut - ich wollte nur warten ob du noch weitere Infos brauchst, die dir vielleicht helfen würden.
                                      • simatec
                                        @Homoran
                                        Nein brauch ich nicht ... glaube das eher Systembedingt, wo eventuell bei der Installation was schief gelaufen ist
                                          @simatec
                                          irgendwas ist oberfaul.
                                          habe den Adapter gelöscht , auf latest gestellt und neu installiert - immer noch 1.4.5
                                          refresh bringt weiterhin nur die 1.4.5, egal welchen Pfad zum repo
                                          host.raspberrypi	2020-06-06 12:47:30.262	info	Update repository "das_allerletzte" under "http://iobroker.live/repo/sources-dist-latest.json"
                                          host.raspberrypi	2020-06-06 12:46:51.061	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                                          host.raspberrypi	2020-06-06 12:46:28.313	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                                          Ich denke ich mach mal heute abend ne neue Installation
                                          Bevor du fragst: reboot des Raspi und neustart von ioB habe ich auch schon mehrfach, genau wie upload
                                          • simatec
                                            Ja das scheint es wirklich. Wie ist es bei anderen installierten Adaptern? Will er da auch bei jedem Aufruf der Config, dass du diese speichern sollst?
                                            backitup
                                            2373
