    4. Backitup löscht keine alten Sicherungen
    SOLVED Backitup löscht keine alten Sicherungen
    • simatec
      @Homoran
      Hmm eas sagt der Log beim Start von Backitup?
      Findet Backitup die vorhandenen Backups beim Start?
        Homoran Global Moderator Administrators @simatec last edited by
        @simatec sagte in Backitup löscht keine alten Sicherungen:
        2020-06-06 11:39:48.706 - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
        2020-06-06 11:39:48.707 - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
        2020-06-06 11:39:48.710 - info: backitup.0 (29386) Got terminate signal TERMINATE_YOURSELF
        2020-06-06 11:39:48.712 - info: backitup.0 (29386) cleaned everything up...
        2020-06-06 11:39:48.713 - info: backitup.0 (29386) terminating
        2020-06-06 11:39:48.715 - info: backitup.0 (29386) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2020-06-06 11:39:49.245 - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (156)
        2020-06-06 11:39:51.255 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 27917
        2020-06-06 11:39:58.999 - debug: backitup.0 (27917) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2020-06-06 11:40:02.999 - warn: backitup.0 (27917) no connection to objects DB
        2020-06-06 11:40:03.919 - debug: backitup.0 (27917) Objects client ready ... initialize now
        2020-06-06 11:40:04.286 - debug: backitup.0 (27917) Objects create System PubSub Client
        2020-06-06 11:40:04.287 - debug: backitup.0 (27917) Objects create User PubSub Client
        2020-06-06 11:40:04.288 - debug: backitup.0 (27917) Objects client initialize lua scripts
        2020-06-06 11:40:09.759 - debug: backitup.0 (27917) Objects connected to redis: 127.0.0.1:9001
        2020-06-06 11:40:09.766 - debug: backitup.0 (27917) objectDB connected
        2020-06-06 11:40:09.769 - debug: backitup.0 (27917) Redis States: Use Redis connection: 127.0.0.1:9000
        2020-06-06 11:40:09.899 - debug: backitup.0 (27917) States create User PubSub Client
        2020-06-06 11:40:09.901 - debug: backitup.0 (27917) States create System PubSub Client
        2020-06-06 11:40:09.920 - debug: backitup.0 (27917) States connected to redis: 127.0.0.1:9000
        2020-06-06 11:40:09.921 - debug: backitup.0 (27917) statesDB connected
        2020-06-06 11:40:12.521 - info: backitup.0 (27917) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.19.0
        2020-06-06 11:40:12.628 - info: backitup.0 (27917) [iobroker] backup was activated at 02:00 every 1 day(s)
        Bin auf wiederherstellen - Lokal - Backups suchen gegangen.
        Meckert es erstmal wieder dass ich erst sichern solle.
        Danach geht brav der Button auf grau, aber passiert erst mal nichts.
        Inzwischen ist der Button immer noch grau
        • simatec
          @Homoran
          Starte den Adapter einfach mal mit debuglog neu.
          Da sollten alle Backups im Log erscheinen
            Habe ich jetzt bereits zigmal gemacht (Instanz neu gestartet)
            • simatec
              @Homoran
              Welche Version ist installiert? 1.5.8?
                @Homoran
                1.4.5 (actual stable!)
                • simatec
                  @Homoran
                  OK ... da gab es die Logausgaben noch nicht.
                  Ich denke da ist irgendwas schief und ich würde sagen Instanz und Adapter löschen, neustarten und nochmal neu installieren.
                  Eventuell direkt die aktuelle Version aus der latest
                    @simatec
                    Gut - ich wollte nur warten ob du noch weitere Infos brauchst, die dir vielleicht helfen würden.
                    • simatec
                      @Homoran
                      Nein brauch ich nicht ... glaube das eher Systembedingt, wo eventuell bei der Installation was schief gelaufen ist
                        Homoran Global Moderator Administrators @simatec last edited by Homoran
                        @simatec
                        irgendwas ist oberfaul.
                        habe den Adapter gelöscht , auf latest gestellt und neu installiert - immer noch 1.4.5
                        refresh bringt weiterhin nur die 1.4.5, egal welchen Pfad zum repo
                        host.raspberrypi	2020-06-06 12:47:30.262	info	Update repository "das_allerletzte" under "http://iobroker.live/repo/sources-dist-latest.json"
                        host.raspberrypi	2020-06-06 12:46:51.061	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                        host.raspberrypi	2020-06-06 12:46:28.313	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                        Ich denke ich mach mal heute abend ne neue Installation
                        Bevor du fragst: reboot des Raspi und neustart von ioB habe ich auch schon mehrfach, genau wie upload
                        • simatec
                          @Homoran sagte in Backitup löscht keine alten Sicherungen:
                          Ja das scheint es wirklich. Wie ist es bei anderen installierten Adaptern? Will er da auch bei jedem Aufruf der Config, dass du diese speichern sollst?
                            nein
                              @simatec
                              Habe noch ein wenig rumgespielt:
                              erst über github installiert - 1.5.8 passt
                              Fand aber immer noch keine Backups.
                              backitup.0	2020-06-06 13:22:47.628	debug	(1715) sendTo "list" to system.adapter.admin.0 from system.adapter.backitup.0
                              backitup.0	2020-06-06 13:22:45.623	debug	(1715) Backup list be read ...
                              backitup.0	2020-06-06 13:22:31.895	debug	(1715) [iobroker] exec: done
                              backitup.0	2020-06-06 13:22:31.893	debug	(1715) [iobroker] exec: done
                              backitup.0	2020-06-06 13:22:31.891	debug	(1715) [iobroker/history] backitup.0.history.json
                              backitup.0	2020-06-06 13:22:31.887	debug	(1715) [iobroker/history] backitup.0.history.html
                              backitup.0	2020-06-06 13:22:31.865	debug	(1715) [iobroker/clean] done
                              backitup.0	2020-06-06 13:22:31.863	debug	(1715) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                              backitup.0	2020-06-06 13:22:31.858	debug	(1715) [iobroker/historyDB] [IGNORED] No source for compress!
                              backitup.0	2020-06-06 13:22:31.850	debug	(1715) [iobroker/iobroker] done
                              backitup.0	2020-06-06 13:22:30.783	debug	(1715) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_06_06-13_22_09_backupiobroker.tar.gz
                              backitup.0	2020-06-06 13:22:19.799	debug	(1715) [iobroker/iobroker] host.raspberrypi 12915 objects saved
                              backitup.0	2020-06-06 13:22:19.739	debug	(1715) [iobroker/iobroker] host.raspberrypi 14516 states saved
                              backitup.0	2020-06-06 13:22:09.732	debug	(1715) Backup has started ...
                              backitup.0	2020-06-06 13:22:07.709	debug	(1715) No backup file was found
                              backitup.0	2020-06-06 13:22:07.702	debug	(1715) [iobroker] 10 00 02 */1 * *
                              backitup.0	2020-06-06 13:22:07.678	info	(1715) [iobroker] backup was activated at 02:00 every 1 day(s)
                              backitup.0	2020-06-06 13:22:07.610	info	(1715) starting. Version 1.5.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.19.0
                              backitup.0	2020-06-06 13:22:04.887	debug	(1715) statesDB connected
                              backitup.0	2020-06-06 13:22:04.886	debug	(1715) States connected to redis: 127.0.0.1:9000
                              backitup.0	2020-06-06 13:22:04.867	debug	(1715) States create System PubSub Client
                              backitup.0	2020-06-06 13:22:04.865	debug	(1715) States create User PubSub Client
                              backitup.0	2020-06-06 13:22:04.824	debug	(1715) Redis States: Use Redis connection: 127.0.0.1:9000
                              backitup.0	2020-06-06 13:22:04.819	debug	(1715) objectDB connected
                              backitup.0	2020-06-06 13:22:04.808	debug	(1715) Objects connected to redis: 127.0.0.1:9001
                              backitup.0	2020-06-06 13:22:04.730	debug	(1715) Objects client initialize lua scripts
                              backitup.0	2020-06-06 13:22:04.729	debug	(1715) Objects create User PubSub Client
                              backitup.0	2020-06-06 13:22:04.727	debug	(1715) Objects create System PubSub Client
                              backitup.0	2020-06-06 13:22:04.715	debug	(1715) Objects client ready ... initialize now
                              backitup.0	2020-06-06 13:22:04.148	debug	(1715) Redis Objects: Use Redis connection: 127.0.0.1:9001
                              backitup.0	2020-06-06 13:21:58.866	info	(1627) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              backitup.0	2020-06-06 13:21:58.865	info	(1627) terminating
                              backitup.0	2020-06-06 13:21:58.864	info	(1627) cleaned everything up...
                              backitup.0	2020-06-06 13:21:58.863	info	(1627) Got terminate signal TERMINATE_YOURSELF
                              backitup.0	2020-06-06 13:21:55.978	debug	(1627) system.adapter.admin.0: logging false
                              backitup.0	2020-06-06 13:21:13.272	debug	(1627) No backup file was found
                              backitup.0	2020-06-06 13:21:13.255	info	(1627) [iobroker] backup was activated at 02:00 every 1 day(s)
                              backitup.0	2020-06-06 13:21:13.143	info	(1627) starting. Version 1.5.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.19.0
                              backitup.0	2020-06-06 13:21:10.635	debug	(1627) statesDB connected
                              backitup.0	2020-06-06 13:21:10.635	debug	(1627) States connected to redis: 127.0.0.1:9000
                              backitup.0	2020-06-06 13:21:10.616	debug	(1627) States create System PubSub Client
                              backitup.0	2020-06-06 13:21:10.613	debug	(1627) States create User PubSub Client
                              backitup.0	2020-06-06 13:21:10.598	debug	(1627) Redis States: Use Redis connection: 127.0.0.1:9000
                              backitup.0	2020-06-06 13:21:10.595	debug	(1627) objectDB connected
                              backitup.0	2020-06-06 13:21:10.588	debug	(1627) Objects connected to redis: 127.0.0.1:9001
                              backitup.0	2020-06-06 13:21:10.567	debug	(1627) Objects client initialize lua scripts
                              backitup.0	2020-06-06 13:21:10.566	debug	(1627) Objects create User PubSub Client
                              backitup.0	2020-06-06 13:21:10.565	debug	(1627) Objects create System PubSub Client
                              backitup.0	2020-06-06 13:21:10.560	debug	(1627) Objects client ready ... initialize now
                              backitup.0	2020-06-06 13:21:10.518	debug	(1627) Redis Objects: Use Redis connection: 127.0.0.1:9001
                              backitup.0	2020-06-06 13:21:04.784	info	(1359) Got terminate signal TERMINATE_YOURSELF
                              backitup.0	2020-06-06 13:21:04.545	info	(1359) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              backitup.0	2020-06-06 13:21:04.541	info	(1359) terminating
                              backitup.0	2020-06-06 13:21:04.540	info	(1359) cleaned everything up...
                              backitup.0	2020-06-06 13:21:04.539	info	(1359) Got terminate signal TERMINATE_YOURSELF
                              backitup.0	2020-06-06 13:20:44.018	info	(1359) [iobroker] backup was activated at 02:00 every 1 day(s)
                              backitup.0	2020-06-06 13:20:41.604	info	(1359) starting. Version 1.5.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.19.0
                              backitup.0	2020-06-06 13:19:28.242	warn	(1359) no connection to objects DB
                              backitup.0	2020-06-06 13:23:06.017	debug	(1715) system.adapter.admin.0: logging true
                              Dann habe ich mich erst einmal um die Repos gekümmert.
                              Das bekannte Bild: Pfad über Browser ok, im admin kein oder leeres Repo gefunden.
                              Umbennen des Pfads - abspeichern - neu benennen!
                              Voila, zumindest der Pfad nach iobroker.live klappte wieder
                              Dann wieder um die Backups.
                              Habe dann ein Backup manuell erzeugt.
                              Jetzt findet er auch die alten - ist auch oben im log drin
                                @simatec
                                Habe jetzt eine komplett neue Installation aufgesetzt nachdem backitup immer noch weiter gesponnen hatte
                                In allen Backups war kein history drin, obwohl angehakt.
                                Gottseidank hatte ich aus alter Gewohnheit eine neue Karte genommen und konnte die alte nochmal reinstecken un das history-Verzeichnis zu ziehen.
                                Im Moment läuft alles
                                • simatec
                                  Schaue mal bitte, ob auch der richtige Pfad eingetragen war.
                                  Wenn ja, wäre mal interessant, ob es irgendwelche Rechteprobleme für den User iobroker gab und er dadurch die History Daten nicht lesen konnte
                                    Genau, da lag das Problem.
                                    Es lief doch nicht alles 😞
                                    hatte auch vorher immer nur auf "Konfiguration ermitteln" geklickt. Dann kam die Meldung ...wurde übernommen.
                                    Damit war für mich die Konfiguration durch. Aber es wurde nichts eingetragen
                                    Habe jetzt manuell /opt/iobroker/iobroker-data/history eingetragen, jetzt läuft es und die Meldung "bitte erst Konfig sichern" kommt nciht mehr
                                      wenn ich beim mitlesen der posts von thomas braun alles verstanden haben sollte, wäre das korrekt?
                                      pi@raspberrypi:~ $ sudo -u iobroker groups
                                      iobroker tty dialout audio video bluetooth gpio i2c
                                      müsste da nicht auch sudo bei sein?
                                      • simatec
                                        sieht bei mir auch so aus ...
                                        iobroker tty dialout audio video bluetooth redis gpio i2c
                                          heißt ja gar nichts :duckundwech:
                                          • simatec
                                            backitup
                                            2373
