    4. host.iobroker Fehlermeldung
    UNSOLVED host.iobroker Fehlermeldung
      Thomas Braun Most Active @karstent last edited by
      @karstent
      Die anderen Ausgaben waren geheim?
        mehr kommt da nicht
        iobroker:~$ which nodejs && which node && which npm
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        ktrepte@iobroker:~$ apt policy nodejs
        nodejs:
          Installiert:           10.20.1-1nodesource1
          Installationskandidat: 10.20.1-1nodesource1
          Versionstabelle:
         *** 10.20.1-1nodesource1 500
                500 https://deb.nodesource.com/node_10.x stretch/main amd64 Packages
                100 /var/lib/dpkg/status
             4.8.2~dfsg-1 500
                500 http://ftp.de.debian.org/debian stretch/main amd64 Packages
          @karstent
          iobroker update
          iobroker upgrade
            das ist alles:
            ktrepte@iobroker:~$ iobroker update
            internal/modules/cjs/loader.js:638
                throw err;
            Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                at startup (internal/bootstrap/node.js:283:19)
                at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
            ktrepte@iobroker:~$ iobroker upgrade
                throw err;
              @karstent
              cd /opt/iobroker
              sudo -H -u iobroker npm install iobroker.js-controller
                wieder so eine Ellenlange Ausgabe:
                ktrepte@iobroker:~$ cd /opt/iobroker
                ktrepte@iobroker:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                > iobroker.js-controller@2.2.10 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                > node lib/preinstallCheck.js
                NPM version: 6.14.4
                > iobroker.js-controller@2.2.10 install /opt/iobroker/node_modules/iobroker.js-controller
                > node iobroker.js setup first
                110 file(s) successfully synchronized with ioBroker storage.
                Please DO NOT copy files manually into ioBroker storage directories!
                The following notifications happened during sync:
                - Added 94 Files in Directory "iqontrol.meta"
                - Added 16 Files in Directory "javascript.admin"
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                + iobroker.js-controller@2.2.10
                added 59 packages from 83 contributors and audited 1498 packages in 48.098s
                7 packages are looking for funding
                  run `npm fund` for details
                found 76 vulnerabilities (56 low, 20 high)
                  run `npm audit fix` to fix them, or `npm audit` for details
                ktrepte@iobroker:/opt/iobroker$ npm audit fix
                npm ERR! code ELOCKVERIFY
                npm ERR! Errors were found in your package-lock.json, run  npm install  to fix them.
                npm ERR!     Invalid: lock file's iobroker.admin@3.6.0 does not satisfy iobroker.admin@^4.1.1
                npm ERR!     Missing: iobroker.alexa2@^3.1.2
                npm ERR!     Missing: iobroker.backitup@^1.5.7
                npm ERR!     Missing: iobroker.cloud@^2.6.2
                npm ERR!     Missing: iobroker.devices@^0.3.6
                npm ERR!     Invalid: lock file's iobroker.discovery@1.2.4 does not satisfy iobroker.discovery@^2.3.3
                npm ERR!     Missing: iobroker.flot@^1.9.2
                npm ERR!     Missing: iobroker.fritzdect@^0.3.2
                npm ERR!     Missing: iobroker.history@^1.9.6
                npm ERR!     Missing: iobroker.hm-rega@^2.6.7
                npm ERR!     Missing: iobroker.hm-rpc@^1.14.2
                npm ERR!     Missing: iobroker.ical@^1.7.0
                npm ERR!     Missing: iobroker.influxdb@^1.8.6
                npm ERR!     Invalid: lock file's iobroker.info@1.3.7 does not satisfy iobroker.info@^1.7.2
                npm ERR!     Missing: iobroker.iot@^1.2.0
                npm ERR!     Missing: iobroker.iqontrol@https://github.com/sbormann/ioBroker.iqontrol/tarball/master
                npm ERR!     Missing: iobroker.javascript@^4.6.4
                npm ERR!     Invalid: lock file's iobroker.js-controller@1.4.2 does not satisfy iobroker.js-controller@^2.2.10
                npm ERR!     Missing: iobroker.meross@^1.3.13
                npm ERR!     Missing: iobroker.mihome@^1.3.0
                npm ERR!     Missing: iobroker.mobile@^0.5.0
                npm ERR!     Missing: iobroker.mqtt@^2.1.3
                npm ERR!     Missing: iobroker.mqtt-client@^1.3.1
                npm ERR!     Missing: iobroker.node-red@^1.16.5
                npm ERR!     Missing: iobroker.nut@^1.1.3
                npm ERR!     Missing: iobroker.parser@^1.0.7
                npm ERR!     Missing: iobroker.proxmox@^1.0.2
                npm ERR!     Missing: iobroker.rickshaw@^1.0.0
                npm ERR!     Missing: iobroker.scenes@^1.1.0
                npm ERR!     Missing: iobroker.simple-api@^2.4.1
                npm ERR!     Missing: iobroker.snmp@^0.5.0
                npm ERR!     Missing: iobroker.socketio@^3.0.7
                npm ERR!     Missing: iobroker.sonoff@^2.3.3
                npm ERR!     Missing: iobroker.sql@^1.9.5
                npm ERR!     Missing: iobroker.squeezebox@^1.0.0
                npm ERR!     Missing: iobroker.statistics@^0.2.2
                npm ERR!     Missing: iobroker.synology@^0.1.10
                npm ERR!     Missing: iobroker.systeminfo@^0.3.1
                npm ERR!     Missing: iobroker.terminal@^0.1.2
                npm ERR!     Missing: iobroker.tr-064@^0.4.18
                npm ERR!     Missing: iobroker.tr-064-community@https://github.com/iobroker-community-adapters/ioBroker.tr-064-community/tarball/master
                npm ERR!     Missing: iobroker.upnp@^1.0.14
                npm ERR!     Missing: iobroker.viessmannapi@^1.3.2
                npm ERR!     Missing: iobroker.virtualpowermeter@^1.0.1
                npm ERR!     Missing: iobroker.vis@^1.2.3
                npm ERR!     Missing: iobroker.vis-hqwidgets@^1.1.2
                npm ERR!     Missing: iobroker.vis-jqui-mfd@^1.0.12
                npm ERR!     Missing: iobroker.web@^3.0.5
                npm ERR!     /home/ktrepte/.npm/_logs/2020-05-18T20_42_42_679Z-debug.log
                  Nach dem ich die ioBroker Instanz wieder starten konnte ergibt sich folgendes im log:
                  host.iobroker	2020-05-18 22:49:03.812	error	instance system.adapter.sql.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  host.iobroker	2020-05-18 22:49:03.812	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                  host.iobroker	2020-05-18 22:49:03.811	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                  host.iobroker	2020-05-18 22:49:03.807	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
                  host.iobroker	2020-05-18 22:49:03.807	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/mmmagic/lib/index.js:1:13)
                  host.iobroker	2020-05-18 22:49:03.806	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
                  host.iobroker	2020-05-18 22:49:03.806	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
                  host.iobroker	2020-05-18 22:49:03.806	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                  host.iobroker	2020-05-18 22:49:03.805	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                  host.iobroker	2020-05-18 22:49:03.805	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                  host.iobroker	2020-05-18 22:49:03.805	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
                  host.iobroker	2020-05-18 22:49:03.804	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                  host.iobroker	2020-05-18 22:49:03.804	error	Caught by controller[0]: NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
                  host.iobroker	2020-05-18 22:49:03.804	error	Caught by controller[0]: NODE_MODULE_VERSION 57. This version of Node.js requires
                  host.iobroker	2020-05-18 22:49:03.803	error	Caught by controller[0]: was compiled against a different Node.js version using
                  host.iobroker	2020-05-18 22:49:03.803	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/mmmagic/build/Release/magic.node'
                  host.iobroker	2020-05-18 22:49:03.802	error	Caught by controller[0]: ^
                  host.iobroker	2020-05-18 22:49:03.802	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
                  host.iobroker	2020-05-18 22:49:03.801	error	Caught by controller[0]: internal/modules/cjs/loader.js:807
                    @karstent
                    iobroker rebuild
                      karstent @Thomas Braun last edited by
                      Vielen Dank für deine Hilfe. Nach dem ich aus Verzweiflung noch einmal die befehle
                      cd /opt/iobroker
                      npm cache clean
                      sudo iobroker stop
                      sudo iobroker update
                      sudo iobroker upgrade self
                      sudo iobroker start
                      in die Console getippt habe hat sich, oh Wunder, die Instanz wieder selber zum leben erweckt. Im Moment habe ich keinerlei Fehlermeldungen mehr und der Controller ist jetzt dort wo er sein soll:
                      Typ: js-controller
                      Titel: JS controller
                      Verfügbar: 3.1.4
                      Installiert: 3.1.4
                      Also, vielen Dank noch mal 🙂
                        Stejin last edited by
                        sry fürs raus kramen, aber ich hatte das gleiche Problem, mir hat das update auf node12 geholfen!
                        sudo apt-get install curl software-properties-common
                        curl -sL https://deb.nodesource.com/setup_12.x | sudo bash -
                        apt-get install nodejs
                        npm install iobroker.js-controller@3.1.4 --unsafe-perm --loglevel error --prefix "/opt/iobroker"
                        host.iobroker
                        2582
