    3. Entwicklung
    4. Adapter: broadlink2
    Adapter: broadlink2
      moj090 last edited by
      @frankjoke bei mir läuft es leider nicht so rund. Benutze ein RM4pro und bekomme folgendes angezeigt:
      broadlink2.0	2020-06-06 00:06:23.216	info	(23386) debug: Device UN:RM4 already found!
      broadlink2.0	2020-06-06 00:06:23.215	info	(23386) debug: Device UN:RM4 already found!
      broadlink2.0	2020-06-06 00:06:22.318	info	(23386) found macs: 24:df:a7:e4:66:e7
      broadlink2.0	2020-06-06 00:06:22.317	info	(23386) broadlink2.0 started and found 1 devices named UN:RM4
      broadlink2.0	2020-06-06 00:06:22.316	info	(23386) Poll every 31 secods.
      broadlink2.0	2020-06-06 00:06:22.209	info	(23386) debug: Device UN:RM4 already found!
      broadlink2.0	2020-06-06 00:06:16.742	info	(23386) debug: discover from [ '192.168.0.154' ]
      broadlink2.0	2020-06-06 00:06:16.739	info	(23386) debug: broadlink2 has 7 old states!
      broadlink2.0	2020-06-06 00:06:16.738	warn	(23386) Unknown UN:RM4 with { address: '192.168.0.154', port: 80, devtype: 24994, maco: <Buffer e7 66 e4 a7 df 24>, mac: '24:df:a7:e4:66:e7', type: 'unknown', name: 'UN:RM4', devname: 'UKN', devhex: '
      broadlink2.0	2020-06-06 00:06:16.691	silly	(23386) States user redis pmessage broadlink2.0.*/broadlink2.0._NewDeviceScan:{"val":false,"ack":true,"ts":1591394776683,"q":0,"from":"system.adapter.broadlink2.0","user":"system.user.admin","lc":1591
      broadlink2.0	2020-06-06 00:06:16.688	info	(23386) debug: ChangeState ack:true of _NewDeviceScan = false
      broadlink2.0	2020-06-06 00:06:16.686	silly	(23386) States user redis pmessage broadlink2.0.*/broadlink2.0._NewDeviceScan:{"val":false,"ack":true,"ts":1591394776683,"q":0,"from":"system.adapter.broadlink2.0","user":"system.user.admin","lc":1591
      broadlink2.0	2020-06-06 00:06:14.201	info	(23386) Device UN:RM4 dedected: address=192.168.0.154, mac=24:df:a7:e4:66:e7, typ=unknown, id=0x61a2 devtype=UKN
      broadlink2.0	2020-06-06 00:06:08.971	info	(23386) debug: discover from [ '192.168.0.255', '255.255.255.255', '224.0.0.251' ]
      broadlink2.0	2020-06-06 00:06:08.964	info	(23386) debug: ChangeState ack:true of _NewDeviceScan = true
      broadlink2.0	2020-06-06 00:06:08.909	info	(23386) UDP socket listening on 0.0.0.0:15001
      broadlink2.0	2020-06-06 00:06:08.904	info	(23386) Discover Broadlink devices for 10sec on broadlink2.0
      broadlink2.0	2020-06-06 00:06:08.891	info	(23386) debug: Config IP-Address end to remove: .fritz.box
      broadlink2.0	2020-06-06 00:06:08.891	info	(23386) macObjects: [ '24:df:a7:e4:66:e7' ]
      broadlink2.0	2020-06-06 00:06:08.889	info	(23386) debug: interface to be used: { address: '192.168.0.211', netmask: '255.255.255.0', mac: '94:c6:91:10:f9:7b', cidr: '192.168.0.211/24' }:
      broadlink2.0	2020-06-06 00:06:08.887	info	(23386) Devices to rename:
      broadlink2.0	2020-06-06 00:06:08.886	info	(23386) Devices to add:
      broadlink2.0	2020-06-06 00:06:08.882	info	(23386) broadlink2 initialization started...
      broadlink2.0	2020-06-06 00:06:08.878	info	(23386) debug: broadlink2 received undefined objects and 7 states, with config ip,scenes,switches,poll,new,rename,lang,latitude,longitude,adapterConf,loglevel
      broadlink2.0	2020-06-06 00:06:08.791	info	(23386) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.20.1
      broadlink2.0	2020-06-06 00:06:04.779	warn	(22649) Adapter will exit in latest 1 sec with code false!
      broadlink2.0	2020-06-06 00:06:04.778	info	(22649) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      broadlink2.0	2020-06-06 00:06:04.777	info	(22649) terminating
      broadlink2.0	2020-06-06 00:06:04.775	info	(22649) Close all connections...
      broadlink2.0	2020-06-06 00:06:04.774	info	(22649) Adapter disconnected and stopped with dostop(false) and callback(true)
      broadlink2.0	2020-06-06 00:06:04.773	info	(22649) Got terminate signal TERMINATE_YOURSELF
      Außerdem werden die Objekte nicht richtig angelegt z.B. der bzw. die learn Buttons
      moJO
      frankjoke 1 Reply Last reply Reply Quote 0
        deta Most Active @frankjoke last edited by
        @frankjoke So nun meine Rückmeldung: Funktioniert jetzt auch der RMmini3 👍
        Wurde dann erkannt und man kann auch Anlernen, senden hab ich noch nicht probiert,
        aber denke es wird auch gehen.
        Klasse. Danke
          deta Most Active last edited by deta
          So da es nun geht , brauche ich bitte mal jetzt einen Anschubs um das nun noch zu verstehen. Hab ich bis heute nicht kappiert.
          Was kann ich hier , und wie einstellen, welchen Nutzen hat das?
          Kapiere das nicht.
          Habe z.b. ein Paar Tasten der Satbox angelernt, wie was kann ich jetzt damit in Verbindung
          machen?
          padrino 1 Reply Last reply Reply Quote 0
            A Former User @frankjoke last edited by
            @frankjoke
            Hi, läuft hier einwandfrei mit js-controller 3.1.5, node 12, Linux Mint 18.3.
            Habe einen rm2 pro plus, einen rmpro3 Mini und 2 so Steckdosen.
            • padrino
              padrino Most Active @deta last edited by padrino
              @deta sagte in Adapter: broadlink2:
              Also brauchen tust Du die Einstellungen nicht zwingend.
              Man kann den Adapter auch (in Skripten) ohne Nutzen.
              Du kannst hier (bei States) Geräte anlegen, indem Du Ihnen Ihre an/aus Befehle zuweist.
              Die Namen der Befehle sind die, wie Du sie in den Datenpunkten der Instanz unter "L" angelernt hast.
              Diese Geräte kannst Du dann z.B., wie normal, über den iot Adapter Alexa bekannt machen.
              Szenen sind eine Reihenfolge von Befehlen, ähnlich, wie man das von einer Logitech Harmony kennt.
              Du kannst also wiederkehrende Kombinationen nutzen, zB Kino = TV an, Verstärker an...
                deta Most Active @padrino last edited by
                @padrino sagte in Adapter: broadlink2:
                Das geht doch auch so. Über den iot Adapter, den datenpunkt habe ich bis jetzt immer so über den iot Adapter für Alexa hinterlegt. Warum muss man da einen anderen Namen vergeben?
                Ok, kann man das nicht sowieso mit den Szenen Adapter machen? Habs noch nicht probiert.
                • padrino
                  @deta
                  Du hast gefragt, wofür die Einstellungen sind und das hab ich Dir gesagt. 😉
                  Auch, dass Du sie nicht nutzen musst/brauchst. 😃
                  In ioB gibt es eben oft mehrere Wege zum selben Ziel, welchen man wählt bleibt einem selbst überlassen. 🙂
                  Den Szenen Adapter kenn ich z.B. nicht.
                  • frankjoke
                    frankjoke @moj090 last edited by
                    @moj090
                    Die devicetype 24994 (hex 0x61a2) war mir leider noch nicht bekannt, werde sie beim nächsten Upload dazugeben .
                    Inzwischen kannst probieren in der Konfig rechts oben 24994=RM4P einzugeben und mal sehen was der Adapter dann (hoffentlich) besser macht.
                    • Knallochse
                      Knallochse last edited by
                      Ich kann leider momentan keine Geräte anlernen.
                      Wenn ich den Anlernprozess auslöse (Lern oder LearnRF) kommt folgender Logeintrag
                      broadlink2.0	2020-06-06 12:53:26.506	warn	(11423) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8.LearnRF = 'cannot get code to send for: RM:RMPROPLUS-4a-2e-b8.LearnRF=RM:RMPROPLUS-4a-2e-b8 { val: true,ack: false,ts: 1591440806500
                      broadlink2.0	2020-06-06 12:53:26.505	warn	(11423) cannot get code to send for: RM:RMPROPLUS-4a-2e-b8.LearnRF=RM:RMPROPLUS-4a-2e-b8 { val: true,ack: false,ts: 1591440806500,q: 0,from: 'system.adapter.admin.0',user: 'system.user.admin',lc: 1591
                      Mein System
                      Docker auf Syn918+
                      JS-Conroller 3.1.4
                      Admin 4.0.9
                      Node.js 10.20.1
                      Broadlink Adapter 2.0.3
                      Ich betreilige mich gern mit testen an der Weiterentwicklung.
                      Vielen Dank für deine Entwicklungsarbeit
                        moj090 @frankjoke last edited by
                        @frankjoke danke das hat geklappt! Die Objekte werden jetzt angezeigt und das Anlernen und Steuern funktioniert auch 🙂
                        Falls du noch Logs oder andere Infos vom RM4Pro für die Entwicklung brauchst sag Bescheid.
                        Danke und Gruß
                        moJO
                          Einklaus last edited by Einklaus
                          Funktioniert bei mir ohne Probleme (Nachtrag - Leider doch nicht).
                          Habe allerdings nur 7 Flureon und die RM3 Mini am laufen.
                          Beim starten des Adapters erscheint nur die Warnung: sendPacket error: could not send after 3 trials!: SendPacketErr Error: socket not created
                          Aber scheint keinerlei Auswirkung zu haben im laufenden Betrieb.
                          broadlink2.0	2020-06-07 18:41:41.519	info	(6504) found macs: 34:ea:34:9b:9b:0c, 34:ea:34:9b:98:2f, 34:ea:34:9b:99:1f, 34:ea:34:9f:cb:f2, 34:ea:34:75:cf:45, 34:ea:34:9b:92:95, 34:ea:34:9a:6c:4c, 24:df:a7:d6:15:46
                          broadlink2.0	2020-06-07 18:41:41.518	info	(6504) broadlink2.0 started and found 8 devices named T1:Heizung-Bad, T1:Heizung-Bjoern, T1:Heizung-Kueche, T1:Heizung-Wohnzimmer, T1:Heizung-WC, T1:Heizung-Flur, T1:Heizung-Schlafzimmer, RM:0x5f36_2
                          broadlink2.0	2020-06-07 18:41:41.518	info	(6504) Poll every 30 secods.
                          broadlink2.0	2020-06-07 18:41:40.546	warn	(6504) sendPacket error: could not send after 3 trials!: SendPacketErr Error: socket not created/bound or closed or waiting!at T1._send (D:\ioBroker\node_modules\iobroker.broadlink2\broadlink_fj.js:1
                          broadlink2.0	2020-06-07 18:41:40.511	warn	(6504) sendPacket error: could not send after 3 trials!: SendPacketErr Error: socket not created/bound or closed or waiting!at T1._send (D:\ioBroker\node_modules\iobroker.broadlink2\broadlink_fj.js:1
                          broadlink2.0	2020-06-07 18:41:40.477	warn	(6504) sendPacket error: could not send after 3 trials!: SendPacketErr Error: socket not created/bound or closed or waiting!at T1._send (D:\ioBroker\node_modules\iobroker.broadlink2\broadlink_fj.js:1
                          broadlink2.0	2020-06-07 18:41:32.852	info	(6504) Device RM:0x5f36_24:df:a7:d6:15:46 dedected: address=192.168.178.30, mac=24:df:a7:d6:15:46, typ=rm4, id=0x5f36 devtype=RM Mini 3
                          broadlink2.0	2020-06-07 18:41:32.850	info	(6504) Device T1:Heizung-Schlafzimmer dedected: address=192.168.178.34, mac=34:ea:34:9a:6c:4c, typ=t1, id=0x4ead devtype=T1 Floureon, originalName=T1:0x4ead_34:ea:34:9a:6c:4c
                          broadlink2.0	2020-06-07 18:41:32.848	info	(6504) Device T1:Heizung-Flur dedected: address=192.168.178.37, mac=34:ea:34:9b:92:95, typ=t1, id=0x4ead devtype=T1 Floureon, originalName=T1:0x4ead_34:ea:34:9b:92:95
                          broadlink2.0	2020-06-07 18:41:32.846	info	(6504) Device T1:Heizung-WC dedected: address=192.168.178.39, mac=34:ea:34:75:cf:45, typ=t1, id=0x4ead devtype=T1 Floureon, originalName=T1:0x4ead_34:ea:34:75:cf:45
                          broadlink2.0	2020-06-07 18:41:32.843	info	(6504) Device T1:Heizung-Wohnzimmer dedected: address=192.168.178.35, mac=34:ea:34:9f:cb:f2, typ=t1, id=0x4ead devtype=T1 Floureon, originalName=T1:0x4ead_34:ea:34:9f:cb:f2
                          broadlink2.0	2020-06-07 18:41:32.824	info	(6504) Device T1:Heizung-Kueche dedected: address=192.168.178.38, mac=34:ea:34:9b:99:1f, typ=t1, id=0x4ead devtype=T1 Floureon, originalName=T1:0x4ead_34:ea:34:9b:99:1f
                          broadlink2.0	2020-06-07 18:41:32.795	info	(6504) Device T1:Heizung-Bjoern dedected: address=192.168.178.36, mac=34:ea:34:9b:98:2f, typ=t1, id=0x4ead devtype=T1 Floureon, originalName=T1:0x4ead_34:ea:34:9b:98:2f
                          broadlink2.0	2020-06-07 18:41:32.765	info	(6504) Device T1:Heizung-Bad dedected: address=192.168.178.33, mac=34:ea:34:9b:9b:0c, typ=t1, id=0x4ead devtype=T1 Floureon, originalName=T1:0x4ead_34:ea:34:9b:9b:0c
                          broadlink2.0	2020-06-07 18:41:32.624	info	(6504) UDP socket listening on 0.0.0.0:15001
                          broadlink2.0	2020-06-07 18:41:32.615	info	(6504) Discover Broadlink devices for 10sec on broadlink2.0
                          broadlink2.0	2020-06-07 18:41:32.612	info	]
                          broadlink2.0	2020-06-07 18:41:32.612	info	(6504) macObjects: [ '24:df:a7:d6:15:46', '34:ea:34:75:cf:45', '34:ea:34:9a:6c:4c', '34:ea:34:9b:92:95', '34:ea:34:9b:98:2f', '34:ea:34:9b:99:1f', '34:ea:34:9b:9b:0c', '34:ea:34:9f:cb:f2'
                          broadlink2.0	2020-06-07 18:41:32.599	info	(6504) Devices to rename: T1:0x4ead_34:ea:34:9b:9b:0c=T1:Heizung-Bad,T1:0x4ead_34:ea:34:9b:98:2f=T1:Heizung-Bjoern,T1:0x4ead_34:ea:34:9a:6c:4c=T1:Heizung-Schlafzimmer,T1:0x4ead_34:ea:34:9b:92:95=T1:H
                          broadlink2.0	2020-06-07 18:41:32.598	info	(6504) Devices to add: []
                          broadlink2.0	2020-06-07 18:41:32.593	info	(6504) broadlink2 initialization started...
                          broadlink2.0	2020-06-07 18:41:32.435	info	(6504) starting. Version 2.0.9 in D:/ioBroker/node_modules/iobroker.broadlink2, node: v12.16.3, js-controller: 3.1.4
                            smet-o last edited by
                            Ich habe die Beta auch gerade heruntergeladen, stoße jedoch beim klicken auf den Learn Button auf folgendes Problem:
                            broadlink2.0	2020-06-07 20:01:32.382	warn	(16860) Error in StateChange for broadlink2.0.RM:RM3-7a-cd-5f._Learn = ReferenceError: Cannot access 'err' before initializationat /opt/iobroker/node_modules/iobroker.broadlink2/broadlink_fj.js:325:2
                            Ich habe einen RM 3 Mini (0x5f36).
                            @frankjoke Vielen Dank für deine tolle Arbeit!
                            LG
                              Habe eben versucht einen Neuen Taster anzulernen. Geht leider nicht
                              Fehlermeldung wie bei saemet.
                              Wenn ich den Learnbutton betätige dann folgende Meldungen
                              broadlink2.0	2020-06-07 22:29:03.407	warn	(8624) Error in StateChange for broadlink2.0.RM:0x5f36_24:df:a7:d6:15:46._Learn = ReferenceError: Cannot access 'err' before initializationat D:\ioBroker\node_modules\iobroker.broadlink2\broadlink_fj.
                              broadlink2.0	2020-06-07 22:29:03.340	info	(8624) Should learn on RM:0x5f36_24:df:a7:d6:15:46
                              broadlink2.0	2020-06-07 22:29:03.303	info	(8624) Start -learning for device: RM:0x5f36_24:df:a7:d6:15:46
                              Ebenfalls ein RM 3 Mini (0x5f36).
                              • frankjoke
                                frankjoke @Einklaus last edited by
                                @Einklaus
                                Habe das Problem gerade selbst gehabt und gelöst, leider nicht auf alle 'Ergebnisse' gewatet und Befehe gleichzeitig ausgesendet 😞
                                Habe auch noch 'ne menege checks eingefügt und einige mögliche promise rejection fehler ausgemärzt.
                                Die neue Version ist uinter der gleichen Versionsnummer am git.
                                Die could not send after 3 trials-Fehler tauchen auch bei mir auf, aber nach sehr unterschiedlichen Zeiten (alle 5-20 Minuten) bei unterschiedlichen Geräten (habe 9 von meinen 15 in Betrieb). In der neuen Version mag nach einem solchen Fehler ein anderer info-log auftauchen, der sagt mir nur dass das Gerät nichts zurücksendet!
                                Ich habe keine Ahnung warum die Geräte manchmal nicht ansprechbar sind, 5-10 Sekunden Später sind sie es wieder. Ich dachte schon dass sie self-reboots machen und dann einige Sekunden nicht ansprechbar sind ....
                                Bei normalen Statusabfragen ist das nicht sooo wichtig da der Adapter einfach den letzten Status nimmt, aber bei Lern uder anderen Befehlen mag das problematisch scheinen. Ich versuche (mit Verzögerung) 3x die Befehle zu senden aber es kommt immer noch vor.
                                p.s.: Die Version ist deswegen nicht schlechter als 2.02 oder 2.03 , die haben nur die Fehler nicht gemeldet sondern einfach weitergemacht!
                                Bezüglich dem Anlernen, mein RMPro+ und RM4Mini funktionieren momentan, das mögliche Problem mit den scenes muss ich getrennt überprüfen.
                                  @frankjoke
                                  Einlernen der RM Mini geht wieder.
                                  Habe jetzt nur ein Unknown Error bei den Flureons die aber scheinbar keine Auswirkung haben.
                                  Meldung wird dann auch alle 30 Sekunden neu ausgegeben
                                  broadlink2.0	2020-06-08 07:59:54.740	info	(10084) Error 'Unknown error 5632 in response!' in device.checkError for T1 T1:Heizung-Schlafzimmer, 34:ea:34:9a:6c:4c, 192.168.178.34
                                  broadlink2.0	2020-06-08 07:59:54.451	info	(10084) Error 'Unknown error 5632 in response!' in device.checkError for T1 T1:Heizung-WC, 34:ea:34:75:cf:45, 192.168.178.39
                                  broadlink2.0	2020-06-08 07:59:54.274	info	(10084) Error 'Unknown error 5632 in response!' in device.checkError for T1 T1:Heizung-Kueche, 34:ea:34:9b:99:1f, 192.168.178.38
                                  broadlink2.0	2020-06-08 07:59:54.084	info	(10084) Error 'Unknown error 5632 in response!' in device.checkError for T1 T1:Heizung-Flur, 34:ea:34:9b:92:95, 192.168.178.37
                                  broadlink2.0	2020-06-08 07:59:53.932	info	(10084) Error 'Unknown error 5632 in response!' in device.checkError for T1 T1:Heizung-Wohnzimmer, 34:ea:34:9f:cb:f2, 192.168.178.35
                                  broadlink2.0	2020-06-08 07:59:53.743	info	(10084) Error 'Unknown error 5632 in response!' in device.checkError for T1 T1:Heizung-Bjoern, 34:ea:34:9b:98:2f, 192.168.178.36
                                  broadlink2.0	2020-06-08 07:59:53.595	info	(10084) Error 'Unknown error 5376 in response!' in device.checkError for T1 T1:Heizung-Bad, 34:ea:34:9b:9b:0c, 192.168.178.33
                                  broadlink2.0	2020-06-08 07:59:23.408	info	(10084) found macs: 34:ea:34:9b:9b:0c, 34:ea:34:9b:98:2f, 34:ea:34:9f:cb:f2, 34:ea:34:9b:92:95, 34:ea:34:9b:99:1f, 24:df:a7:d6:15:46, 34:ea:34:75:cf:45, 34:ea:34:9a:6c:4c
                                  broadlink2.0	2020-06-08 07:59:23.407	info	(10084) broadlink2.0 started and found 8 devices named T1:Heizung-Bad, T1:Heizung-Bjoern, T1:Heizung-Wohnzimmer, T1:Heizung-Flur, T1:Heizung-Kueche, RM:0x5f36_24:df:a7:d6:15:46, T1:Heizung-WC, T1:Heiz
                                  broadlink2.0	2020-06-08 07:59:23.406	info	(10084) Poll every 30 secods.
                                  broadlink2.0	2020-06-08 07:59:23.404	info	(10084) Error 'Unknown error 5632 in response!' in device.checkError for T1 T1:Heizung-Schlafzimmer, 34:ea:34:9a:6c:4c, 192.168.178.34
                                  broadlink2.0	2020-06-08 07:59:23.157	info	(10084) Error 'Unknown error 5632 in response!' in device.checkError for T1 T1:Heizung-WC, 34:ea:34:75:cf:45, 192.168.178.39
                                  broadlink2.0	2020-06-08 07:59:22.881	info	(10084) Error 'Unknown error 5632 in response!' in device.checkError for T1 T1:Heizung-Kueche, 34:ea:34:9b:99:1f, 192.168.178.38
                                  broadlink2.0	2020-06-08 07:59:22.691	info	(10084) Error 'Unknown error 5632 in response!' in device.checkError for T1 T1:Heizung-Flur, 34:ea:34:9b:92:95, 192.168.178.37
                                  broadlink2.0	2020-06-08 07:59:22.542	info	(10084) Error 'Unknown error 5632 in response!' in device.checkError for T1 T1:Heizung-Wohnzimmer, 34:ea:34:9f:cb:f2, 192.168.178.35
                                  broadlink2.0	2020-06-08 07:59:22.393	info	(10084) Error 'Unknown error 5632 in response!' in device.checkError for T1 T1:Heizung-Bjoern, 34:ea:34:9b:98:2f, 192.168.178.36
                                  broadlink2.0	2020-06-08 07:59:22.242	info	(10084) Error 'Unknown error 5376 in response!' in device.checkError for T1 T1:Heizung-Bad, 34:ea:34:9b:9b:0c, 192.168.178.33
                                  broadlink2.0	2020-06-08 07:59:13.342	info	(10084) Device T1:Heizung-Schlafzimmer dedected: address=192.168.178.34, mac=34:ea:34:9a:6c:4c, typ=t1, id=0x4ead devtype=T1 Floureon, originalName=T1:0x4ead_34:ea:34:9a:6c:4c
                                  broadlink2.0	2020-06-08 07:59:13.336	info	(10084) Device T1:Heizung-WC dedected: address=192.168.178.39, mac=34:ea:34:75:cf:45, typ=t1, id=0x4ead devtype=T1 Floureon, originalName=T1:0x4ead_34:ea:34:75:cf:45
                                  broadlink2.0	2020-06-08 07:59:13.309	info	(10084) Device RM:0x5f36_24:df:a7:d6:15:46 dedected: address=192.168.178.30, mac=24:df:a7:d6:15:46, typ=rm4, id=0x5f36 devtype=RM Mini 3
                                    P-A-L-A-D-I-N last edited by
                                    @frankjoke :
                                    Wäre es vielleicht möglich, die angelernten Geräte aus der ihc bzw. ihc for EU App irgendwie in den Broadlink-Adapter zu übernehmen (am besten inkl. der Gruppen/Räume und der Geräteklassen, wie z.B. Lampe, Steckdose, Fernseher etc.)?
                                    Ich dachte da an eine Art Verknüpfung von App und Adapter, so wie ja auch die Alexa-Skills teilweise Zugriff auf Konten gewährt bekommen, wenn man den Skill aktiviert und verknüpft.
                                    Wäre vielleicht ein nettes "Goodie" für Einsteiger, die ihre IR-/RF-Geräte noch nicht im ioBroker eingelernt haben.
                                      @frankjoke
                                      Jetzt funktioniert alles, ohne jegliche Fehlermeldungen.
                                      Dankeschön!
                                      • Knallochse
                                        Knallochse last edited by Knallochse
                                        Habe garade auf die aktuelle Beta 2.0.9 geupdatet. Ist ein RM3pro+
                                        Hier die Logausgaben zum Adapter. Anlernmodus lässt sich nicht aktivieren.
                                        broadlink2.0	2020-06-08 11:42:15.043	warn	(24205) cannot get code to send for: RM:RMPROPLUS-4a-2e-b8.Learn=RM:RMPROPLUS-4a-2e-b8 { val: true,ack: false,ts: 1591609335037,q: 0,from: 'system.adapter.admin.0',user: 'system.user.admin',lc: 159144
                                        broadlink2.0	2020-06-08 11:41:23.893	warn	(24205) cannot get code to send for: RM:RMPROPLUS-4a-2e-b8.LearnRF=RM:RMPROPLUS-4a-2e-b8 { val: true,ack: false,ts: 1591609283886,q: 0,from: 'system.adapter.admin.0',user: 'system.user.admin',lc: 1591
                                        broadlink2.0	2020-06-08 11:40:36.006	info	(24205) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-4a-2e-b8, 34:ea:34:4a:2e:b8, 192.168.178.87
                                        broadlink2.0	2020-06-08 11:40:36.005	warn	(24205) sendPacket error: could not send after 3 trials!: SendPacketErr { here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-4a-2e-b8' }
                                        broadlink2.0	2020-06-08 11:38:57.813	info	(24205) found macs: 34:ea:34:4a:2e:b8
                                        broadlink2.0	2020-06-08 11:38:57.812	info	(24205) broadlink2.0 started and found 1 devices named RM:RMPROPLUS-4a-2e-b8
                                        broadlink2.0	2020-06-08 11:38:57.812	info	(24205) Poll every 30 secods.
                                        broadlink2.0	2020-06-08 11:38:49.945	info	(24205) Device RM:RMPROPLUS-4a-2e-b8 dedected: address=192.168.178.87, mac=34:ea:34:4a:2e:b8, typ=rmp, id=0x279d devtype=RM3 Pro Plus
                                        broadlink2.0	2020-06-08 11:38:49.812	info	(24205) UDP socket listening on 0.0.0.0:15001
                                        broadlink2.0	2020-06-08 11:38:49.806	info	(24205) Discover Broadlink devices for 10sec on broadlink2.0
                                        broadlink2.0	2020-06-08 11:38:49.784	info	(24205) macObjects: [ '34:ea:34:4a:2e:b8', '9d:27:57:b2:a8:c0' ]
                                        broadlink2.0	2020-06-08 11:38:49.781	info	(24205) Devices to rename:
                                        broadlink2.0	2020-06-08 11:38:49.780	info	(24205) Devices to add:
                                        broadlink2.0	2020-06-08 11:38:49.775	info	(24205) broadlink2 initialization started...
                                        broadlink2.0	2020-06-08 11:38:49.647	info	(24205) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.20.1, js-controller: 3.1.4
                                        broadlink2.0	2020-06-08 11:38:43.270	error	at processImmediate (timers.js:658:5)
                                        broadlink2.0	2020-06-08 11:38:43.270	error	at tryOnImmediate (timers.js:676:5)
                                        broadlink2.0	2020-06-08 11:38:43.270	error	at runCallback (timers.js:706:11)
                                        broadlink2.0	2020-06-08 11:38:43.270	error	at Broadlink.parsePublic (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink_fj.js:1194:28)
                                        broadlink2.0	2020-06-08 11:38:43.270	error	(696) TypeError: Cannot read property '34:ea:34:4a:2e:b8' of null
                                        broadlink2.0	2020-06-08 11:38:43.269	error	(696) uncaught exception: Cannot read property '34:ea:34:4a:2e:b8' of null
                                        broadlink2.0	2020-06-08 11:38:42.996	warn	(696) Adapter will exit in latest 1 sec with code false!
                                        broadlink2.0	2020-06-08 11:38:42.992	info	(696) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        broadlink2.0	2020-06-08 11:38:42.990	info	(696) terminating
                                        broadlink2.0	2020-06-08 11:38:42.983	info	(696) Close all connections...
                                        broadlink2.0	2020-06-08 11:38:42.982	info	(696) Adapter disconnected and stopped with dostop(false) and callback(true)
                                        broadlink2.0	2020-06-08 11:38:42.968	info	(696) Got terminate signal TERMINATE_YOURSELF
                                        Edit: Anlernmodus starten wohl jetzt mit _Lern & _LernRF (Unterstrich davor - Neue Buttons)
                                        Es wird auch in den Anlernmodus gegangen (rot LED am RM3pro+ leuchtet)
                                        Ich bekomme aber leider keine Taste angelernt.
                                        broadlink2.0	2020-06-08 12:04:21.368	info	(25263) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-4a-2e-b8, 34:ea:34:4a:2e:b8, 192.168.178.87
                                        broadlink2.0	2020-06-08 12:04:21.368	warn	(25263) sendPacket error: could not send after 3 trials!: SendPacketErr { here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-4a-2e-b8' }
                                        broadlink2.0	2020-06-08 12:04:15.572	info	(25263) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-4a-2e-b8, 34:ea:34:4a:2e:b8, 192.168.178.87
                                        broadlink2.0	2020-06-08 12:04:15.571	warn	(25263) sendPacket error: could not send after 3 trials!: SendPacketErr { here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-4a-2e-b8' }
                                        broadlink2.0	2020-06-08 12:03:47.511	warn	(25263) cannot get code to send for: RM:RMPROPLUS-4a-2e-b8.SendCode=RM:RMPROPLUS-4a-2e-b8 { val:'b2058403180b0c18170c0c18170b0c18170c0c181700021104000128992f0c170c180b18180c0b180b180c18170c0c170c180b1
                                        broadlink2.0	2020-06-08 12:03:34.312	warn	(25263) Code to send to RM:RMPROPLUS-4a-2e-b8 needs to start with CODE_
                                        broadlink2.0	2020-06-08 12:03:25.316	warn	(25263) Code to send to RM:RMPROPLUS-4a-2e-b8 needs to start with CODE_
                                        broadlink2.0	2020-06-08 12:01:37.203	warn	(25263) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = TypeError: Cannot read property 'checkError' of undefinedat enterRFSweep (/opt/iobroker/node_modules/iobroker.broadlink2/
                                        broadlink2.0	2020-06-08 12:01:37.089	info	(25263) Should learn RF-sweep on RM:RMPROPLUS-4a-2e-b8
                                        broadlink2.0	2020-06-08 12:01:37.043	info	(25263) Start RF-learning for device: RM:RMPROPLUS-4a-2e-b8
                                        broadlink2.0	2020-06-08 12:00:49.145	info	(25263) found macs: 34:ea:34:4a:2e:b8
                                        broadlink2.0	2020-06-08 12:00:49.144	info	(25263) broadlink2.0 started and found 1 devices named RM:RMPROPLUS-4a-2e-b8
                                        broadlink2.0	2020-06-08 12:00:49.144	info	(25263) Poll every 30 secods.
                                        broadlink2.0	2020-06-08 12:00:41.302	info	(25263) Device RM:RMPROPLUS-4a-2e-b8 dedected: address=192.168.178.87, mac=34:ea:34:4a:2e:b8, typ=rmp, id=0x279d devtype=RM3 Pro Plus
                                        broadlink2.0	2020-06-08 12:00:41.152	info	(25263) UDP socket listening on 0.0.0.0:15001
                                        broadlink2.0	2020-06-08 12:00:41.147	info	(25263) Discover Broadlink devices for 10sec on broadlink2.0
                                        broadlink2.0	2020-06-08 12:00:41.129	info	(25263) macObjects: [ '34:ea:34:4a:2e:b8', '9d:27:57:b2:a8:c0' ]
                                        broadlink2.0	2020-06-08 12:00:41.125	info	(25263) Devices to rename:
                                        broadlink2.0	2020-06-08 12:00:41.125	info	(25263) Devices to add:
                                        broadlink2.0	2020-06-08 12:00:41.121	info	(25263) broadlink2 initialization started...
                                        broadlink2.0	2020-06-08 12:00:40.973	info	(25263) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.20.1, js-controller: 3.1.4
                                        broadlink2.0	2020-06-08 12:00:36.139	warn	(25102) Adapter will exit in latest 1 sec with code false!
                                        broadlink2.0	2020-06-08 12:00:36.139	info	(25102) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        broadlink2.0	2020-06-08 12:00:36.138	info	(25102) terminating
                                        broadlink2.0	2020-06-08 12:00:36.136	info	(25102) Close all connections...
                                        broadlink2.0	2020-06-08 12:00:36.135	info	(25102) Adapter disconnected and stopped with dostop(false) and callback(true)
                                        broadlink2.0	2020-06-08 12:00:36.134	info	(25102) Got terminate signal TERMINATE_YOURSELF
                                        broadlink2.0	2020-06-08 11:59:55.317	warn	(25102) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = Error: Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!at startLearning (/opt/iobroker/n
                                        broadlink2.0	2020-06-08 11:59:55.315	warn	(25102) Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!
                                        broadlink2.0	2020-06-08 11:58:39.943	warn	(25102) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = TypeError: Cannot read property 'checkError' of undefinedat enterRFSweep (/opt/iobroker/node_modules/iobroker.broadlink2/
                                        broadlink2.0	2020-06-08 11:58:39.820	info	(25102) Should learn RF-sweep on RM:RMPROPLUS-4a-2e-b8
                                        broadlink2.0	2020-06-08 11:58:39.770	info	(25102) Start RF-learning for device: RM:RMPROPLUS-4a-2e-b8
                                        broadlink2.0	2020-06-08 11:58:30.507	info	(25102) found macs: 34:ea:34:4a:2e:b8
                                        broadlink2.0	2020-06-08 11:58:30.506	info	(25102) broadlink2.0 started and found 1 devices named RM:RMPROPLUS-4a-2e-b8
                                        broadlink2.0	2020-06-08 11:58:30.505	info	(25102) Poll every 30 secods.
                                        broadlink2.0	2020-06-08 11:58:22.646	info	(25102) Device RM:RMPROPLUS-4a-2e-b8 dedected: address=192.168.178.87, mac=34:ea:34:4a:2e:b8, typ=rmp, id=0x279d devtype=RM3 Pro Plus
                                        broadlink2.0	2020-06-08 11:58:22.444	info	(25102) UDP socket listening on 0.0.0.0:15001
                                        broadlink2.0	2020-06-08 11:58:22.439	info	(25102) Discover Broadlink devices for 10sec on broadlink2.0
                                        broadlink2.0	2020-06-08 11:58:22.421	info	(25102) macObjects: [ '34:ea:34:4a:2e:b8', '9d:27:57:b2:a8:c0' ]
                                        broadlink2.0	2020-06-08 11:58:22.417	info	(25102) Devices to rename:
                                        broadlink2.0	2020-06-08 11:58:22.416	info	(25102) Devices to add:
                                        broadlink2.0	2020-06-08 11:58:22.411	info	(25102) broadlink2 initialization started...
                                        broadlink2.0	2020-06-08 11:58:22.254	info	(25102) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.20.1, js-controller: 3.1.4
                                        broadlink2.0	2020-06-08 11:58:17.356	warn	(25026) Adapter will exit in latest 1 sec with code false!
                                        broadlink2.0	2020-06-08 11:58:17.356	info	(25026) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        broadlink2.0	2020-06-08 11:58:17.355	info	(25026) terminating
                                        broadlink2.0	2020-06-08 11:58:17.353	info	(25026) Close all connections...
                                        broadlink2.0	2020-06-08 11:58:17.352	info	(25026) Adapter disconnected and stopped with dostop(false) and callback(true)
                                        broadlink2.0	2020-06-08 11:58:17.351	info	(25026) Got terminate signal TERMINATE_YOURSELF
                                        broadlink2.0	2020-06-08 11:58:09.197	warn	(25026) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = Error: Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!at startLearning (/opt/iobroker/n
                                        broadlink2.0	2020-06-08 11:58:09.196	warn	(25026) Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!
                                        broadlink2.0	2020-06-08 11:58:04.236	warn	(25026) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = Error: Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!at startLearning (/opt/iobroker/n
                                        broadlink2.0	2020-06-08 11:58:04.235	warn	(25026) Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!
                                        broadlink2.0	2020-06-08 11:57:37.335	warn	(25026) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = Error: Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!at startLearning (/opt/iobroker/n
                                        broadlink2.0	2020-06-08 11:57:37.332	warn	(25026) Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!
                                        broadlink2.0	2020-06-08 11:56:53.917	warn	(25026) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = TypeError: Cannot read property 'checkError' of undefinedat enterRFSweep (/opt/iobroker/node_modules/iobroker.broadlink2/
                                        broadlink2.0	2020-06-08 11:56:52.947	info	(25026) Should learn RF-sweep on RM:RMPROPLUS-4a-2e-b8
                                        broadlink2.0	2020-06-08 11:56:52.900	info	(25026) Start RF-learning for device: RM:RMPROPLUS-4a-2e-b8
                                        broadlink2.0	2020-06-08 11:56:49.729	info	(25026) found macs: 34:ea:34:4a:2e:b8
                                        broadlink2.0	2020-06-08 11:56:49.729	info	(25026) broadlink2.0 started and found 1 devices named RM:RMPROPLUS-4a-2e-b8
                                        broadlink2.0	2020-06-08 11:56:49.728	info	(25026) Poll every 30 secods.
                                        broadlink2.0	2020-06-08 11:56:41.899	info	(25026) Device RM:RMPROPLUS-4a-2e-b8 dedected: address=192.168.178.87, mac=34:ea:34:4a:2e:b8, typ=rmp, id=0x279d devtype=RM3 Pro Plus
                                        broadlink2.0	2020-06-08 11:56:41.187	info	(25026) UDP socket listening on 0.0.0.0:15001
                                        broadlink2.0	2020-06-08 11:56:41.181	info	(25026) Discover Broadlink devices for 10sec on broadlink2.0
                                        broadlink2.0	2020-06-08 11:56:41.163	info	(25026) macObjects: [ '34:ea:34:4a:2e:b8', '9d:27:57:b2:a8:c0' ]
                                        broadlink2.0	2020-06-08 11:56:41.159	info	(25026) Devices to rename:
                                        broadlink2.0	2020-06-08 11:56:41.158	info	(25026) Devices to add:
                                        broadlink2.0	2020-06-08 11:56:41.153	info	(25026) broadlink2 initialization started...
                                        broadlink2.0	2020-06-08 11:56:40.975	info	(25026) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.20.1, js-controller: 3.1.4
                                        broadlink2.0	2020-06-08 11:56:36.247	warn	(24899) Adapter will exit in latest 1 sec with code false!
                                        broadlink2.0	2020-06-08 11:56:36.247	info	(24899) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        broadlink2.0	2020-06-08 11:56:36.246	info	(24899) terminating
                                        broadlink2.0	2020-06-08 11:56:36.243	info	(24899) Close all connections...
                                        broadlink2.0	2020-06-08 11:56:36.243	info	(24899) Adapter disconnected and stopped with dostop(false) and callback(true)
                                        broadlink2.0	2020-06-08 11:56:36.241	info	(24899) Got terminate signal TERMINATE_YOURSELF
                                        broadlink2.0	2020-06-08 11:55:12.308	warn	(24899) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = TypeError: Cannot read property 'checkError' of undefinedat enterRFSweep (/opt/iobroker/node_modules/iobroker.broadlink2/
                                        broadlink2.0	2020-06-08 11:55:11.351	info	(24899) Should learn RF-sweep on RM:RMPROPLUS-4a-2e-b8
                                        broadlink2.0	2020-06-08 11:55:11.305	info	(24899) Start RF-learning for device: RM:RMPROPLUS-4a-2e-b8
                                        broadlink2.0	2020-06-08 11:55:07.742	info	(24899) found macs: 34:ea:34:4a:2e:b8
                                        broadlink2.0	2020-06-08 11:55:07.741	info	(24899) broadlink2.0 started and found 1 devices named RM:RMPROPLUS-4a-2e-b8
                                        broadlink2.0	2020-06-08 11:55:07.741	info	(24899) Poll every 30 secods.
                                        broadlink2.0	2020-06-08 11:54:59.891	info	(24899) Device RM:RMPROPLUS-4a-2e-b8 dedected: address=192.168.178.87, mac=34:ea:34:4a:2e:b8, typ=rmp, id=0x279d devtype=RM3 Pro Plus
                                        broadlink2.0	2020-06-08 11:54:59.731	info	(24899) UDP socket listening on 0.0.0.0:15001
                                        broadlink2.0	2020-06-08 11:54:59.725	info	(24899) Discover Broadlink devices for 10sec on broadlink2.0
                                        broadlink2.0	2020-06-08 11:54:59.700	info	(24899) macObjects: [ '34:ea:34:4a:2e:b8', '9d:27:57:b2:a8:c0' ]
                                        broadlink2.0	2020-06-08 11:54:59.696	info	(24899) Devices to rename:
                                        broadlink2.0	2020-06-08 11:54:59.695	info	(24899) Devices to add:
                                        broadlink2.0	2020-06-08 11:54:59.691	info	(24899) broadlink2 initialization started...
                                        broadlink2.0	2020-06-08 11:54:59.528	info	(24899) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.20.1, js-controller: 3.1.4
                                        broadlink2.0	2020-06-08 11:54:54.694	warn	(24790) Adapter will exit in latest 1 sec with code false!
                                        broadlink2.0	2020-06-08 11:54:54.693	info	(24790) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        broadlink2.0	2020-06-08 11:54:54.692	info	(24790) terminating
                                        broadlink2.0	2020-06-08 11:54:54.690	info	(24790) Close all connections...
                                        broadlink2.0	2020-06-08 11:54:54.690	info	(24790) Adapter disconnected and stopped with dostop(false) and callback(true)
                                        broadlink2.0	2020-06-08 11:54:54.688	info	(24790) Got terminate signal TERMINATE_YOURSELF
                                        broadlink2.0	2020-06-08 11:54:09.692	warn	(24790) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._Learn = Error: Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!at startLearning (/opt/iobroker/nod
                                        broadlink2.0	2020-06-08 11:54:09.691	warn	(24790) Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!
                                        broadlink2.0	2020-06-08 11:53:45.954	warn	(24790) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = Error: Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!at startLearning (/opt/iobroker/n
                                        broadlink2.0	2020-06-08 11:53:45.952	warn	(24790) Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!
                                        broadlink2.0	2020-06-08 11:52:26.943	warn	(24790) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = TypeError: Cannot read property 'checkError' of undefinedat enterRFSweep (/opt/iobroker/node_modules/iobroker.broadlink2/
                                        broadlink2.0	2020-06-08 11:52:26.803	info	(24790) Should learn RF-sweep on RM:RMPROPLUS-4a-2e-b8
                                        broadlink2.0	2020-06-08 11:52:26.755	info	(24790) Start RF-learning for device: RM:RMPROPLUS-4a-2e-b8
                                        broadlink2.0	2020-06-08 11:52:07.159	info	(24790) found macs: 34:ea:34:4a:2e:b8
                                        broadlink2.0	2020-06-08 11:52:07.159	info	(24790) broadlink2.0 started and found 1 devices named RM:RMPROPLUS-4a-2e-b8
                                        broadlink2.0	2020-06-08 11:52:07.158	info	(24790) Poll every 30 secods.
                                        broadlink2.0	2020-06-08 11:51:59.370	info	(24790) Device RM:RMPROPLUS-4a-2e-b8 dedected: address=192.168.178.87, mac=34:ea:34:4a:2e:b8, typ=rmp, id=0x279d devtype=RM3 Pro Plus
                                        broadlink2.0	2020-06-08 11:51:59.118	info	(24790) UDP socket listening on 0.0.0.0:15001
                                        broadlink2.0	2020-06-08 11:51:59.113	info	(24790) Discover Broadlink devices for 10sec on broadlink2.0
                                        broadlink2.0	2020-06-08 11:51:59.090	info	(24790) macObjects: [ '34:ea:34:4a:2e:b8', '9d:27:57:b2:a8:c0' ]
                                        broadlink2.0	2020-06-08 11:51:59.086	info	(24790) Devices to rename:
                                        broadlink2.0	2020-06-08 11:51:59.085	info	(24790) Devices to add:
                                        broadlink2.0	2020-06-08 11:51:59.081	info	(24790) broadlink2 initialization started...
                                        broadlink2.0	2020-06-08 11:51:58.948	info	(24790) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.20.1, js-controller: 3.1.4
                                        broadlink2.0	2020-06-08 11:51:54.404	warn	(24205) Adapter will exit in latest 1 sec with code false!
                                        broadlink2.0	2020-06-08 11:51:54.403	info	(24205) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        broadlink2.0	2020-06-08 11:51:54.402	info	(24205) terminating
                                        broadlink2.0	2020-06-08 11:51:54.400	info	(24205) Close all connections...
                                        broadlink2.0	2020-06-08 11:51:54.399	info	(24205) Adapter disconnected and stopped with dostop(false) and callback(true)
                                        broadlink2.0	2020-06-08 11:51:54.397	info	(24205) Got terminate signal TERMINATE_YOURSELF
                                        broadlink2.0	2020-06-08 11:51:01.448	warn	(24205) cannot get code to send for: RM:RMPROPLUS-4a-2e-b8.LearnRF=RM:RMPROPLUS-4a-2e-b8 { val: true,ack: false,ts: 1591609861443,q: 0,from: 'system.adapter.admin.0',user: 'system.user.admin',lc: 1591
                                        broadlink2.0	2020-06-08 11:50:43.238	warn	(24205) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = Error: Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!at startLearning (/opt/iobroker/n
                                        broadlink2.0	2020-06-08 11:50:43.237	warn	(24205) Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!
                                        broadlink2.0	2020-06-08 11:50:19.531	warn	(24205) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = Error: Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!at startLearning (/opt/iobroker/n
                                        broadlink2.0	2020-06-08 11:50:19.529	warn	(24205) Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!
                                        broadlink2.0	2020-06-08 11:48:13.964	warn	(24205) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = TypeError: Cannot read property 'checkError' of undefinedat enterRFSweep (/opt/iobroker/node_modules/iobroker.broadlink2/
                                        broadlink2.0	2020-06-08 11:48:13.865	info	(24205) Should learn RF-sweep on RM:RMPROPLUS-4a-2e-b8
                                        broadlink2.0	2020-06-08 11:48:13.819	info	(24205) Start RF-learning for device: RM:RMPROPLUS-4a-2e-b8
                                        Edit2: Anlernen von IR Signalen per _Learn geht . Das senden bereits angelernter RF-Signale funktioniert auch.
                                          Irgendwas stimmt jetzt nicht mehr.... Aktuelle Version vom Git gestern Abend.
                                          Wenn ich das auch Manuell mal auslöse in den Objekten gehts nicht und das Log sagt das:
                                          (Adapter gerade extra neu gestartet)
                                          broadlink2.0	2020-06-08 15:04:39.223	info	(19157) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80
                                          broadlink2.0	2020-06-08 15:04:39.222	warn	(19157) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'}
                                          broadlink2.0	2020-06-08 15:04:34.753	info	(19157) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80
                                          broadlink2.0	2020-06-08 15:04:34.752	warn	(19157) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'}
                                          broadlink2.0	2020-06-08 15:04:13.950	info	(19157) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80
                                          broadlink2.0	2020-06-08 15:04:13.947	warn	(19157) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'}
                                          broadlink2.0	2020-06-08 15:03:32.527	info	(19157) found macs: c8:f7:42:da:2d:ad
                                          broadlink2.0	2020-06-08 15:03:32.525	info	(19157) broadlink2.0 started and found 1 devices named RM:RMPROPLUS-da-2d-ad
                                          broadlink2.0	2020-06-08 15:03:32.523	info	(19157) Poll every 30 secods.
                                          broadlink2.0	2020-06-08 15:03:25.019	info	(19157) Device RM:RMPROPLUS-da-2d-ad dedected: address=192.168.178.80, mac=c8:f7:42:da:2d:ad, typ=rmp, id=0x279d devtype=RM3 Pro Plus
                                          broadlink2.0	2020-06-08 15:03:24.385	info	(19157) UDP socket listening on 0.0.0.0:15001
                                          broadlink2.0	2020-06-08 15:03:24.377	info	(19157) Discover Broadlink devices for 10sec on broadlink2.0
                                          broadlink2.0	2020-06-08 15:03:24.342	info	(19157) macObjects: [ '24:df:a7:7a:70:92', 'c8:f7:42:da:2d:ad' ]
                                          broadlink2.0	2020-06-08 15:03:24.335	info	(19157) Devices to rename:
                                          broadlink2.0	2020-06-08 15:03:24.333	info	(19157) Devices to add: []
                                          broadlink2.0	2020-06-08 15:03:24.324	info	(19157) broadlink2 initialization started...
                                          broadlink2.0	2020-06-08 15:03:24.042	info	(19157) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v12.18.0, js-controller: 3.1.5
                                          broadlink2.0	2020-06-08 15:03:10.521	warn	(11721) Adapter will exit in latest 1 sec with code false!
                                          broadlink2.0	2020-06-08 15:03:10.518	info	(11721) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          broadlink2.0	2020-06-08 15:03:10.515	info	(11721) terminating
                                          broadlink2.0	2020-06-08 15:03:10.512	info	(11721) Close all connections...
                                          broadlink2.0	2020-06-08 15:03:10.510	info	(11721) Adapter disconnected and stopped with dostop(false) and callback(true)
                                          broadlink2.0	2020-06-08 15:03:10.507	info	(11721) Got terminate signal TERMINATE_YOURSELF
                                          Update: Nach dem Neustart des Broadlink, also Strom am Broadlink selber geht es wieder mh.
                                          Update2: Geht doch nicht, kurz dann gehts wieder nicht Log:
                                          broadlink2.0	2020-06-08 15:34:57.365	info	(2279) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80
                                          broadlink2.0	2020-06-08 15:34:57.362	warn	(2279) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'}
                                          broadlink2.0	2020-06-08 15:34:28.467	info	(2279) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80
                                          broadlink2.0	2020-06-08 15:34:28.466	warn	(2279) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'}
                                          broadlink2.0	2020-06-08 15:34:25.932	info	(2279) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80
                                          broadlink2.0	2020-06-08 15:34:25.931	warn	(2279) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'}
                                          broadlink2.0	2020-06-08 15:34:24.708	info	(2279) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80
                                          broadlink2.0	2020-06-08 15:34:24.706	warn	(2279) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'}
                                          broadlink2.0	2020-06-08 15:34:22.501	info	(2279) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80
                                          broadlink2.0	2020-06-08 15:34:22.499	warn	(2279) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'}
                                          broadlink2.0	2020-06-08 15:33:25.137	info	(2279) found macs: c8:f7:42:da:2d:ad
                                          broadlink2.0	2020-06-08 15:33:25.136	info	(2279) broadlink2.0 started and found 1 devices named RM:RMPROPLUS-da-2d-ad
                                          broadlink2.0	2020-06-08 15:33:25.135	info	(2279) Poll every 30 secods.
                                          broadlink2.0	2020-06-08 15:33:17.283	info	(2279) Device RM:RMPROPLUS-da-2d-ad dedected: address=192.168.178.80, mac=c8:f7:42:da:2d:ad, typ=rmp, id=0x279d devtype=RM3 Pro Plus
                                          broadlink2.0	2020-06-08 15:33:17.125	info	(2279) UDP socket listening on 0.0.0.0:15001
                                          broadlink2.0	2020-06-08 15:33:17.117	info	(2279) Discover Broadlink devices for 10sec on broadlink2.0
                                          broadlink2.0	2020-06-08 15:33:17.082	info	(2279) macObjects: [ '24:df:a7:7a:70:92', 'c8:f7:42:da:2d:ad' ]
                                          broadlink2.0	2020-06-08 15:33:17.076	info	(2279) Devices to rename:
                                          broadlink2.0	2020-06-08 15:33:17.074	info	(2279) Devices to add: []
                                          broadlink2.0	2020-06-08 15:33:17.065	info	(2279) broadlink2 initialization started...
                                          broadlink2.0	2020-06-08 15:33:16.822	info	(2279) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v12.18.0, js-controller: 3.1.5
                                          • frankjoke
                                            frankjoke @deta last edited by
                                            @deta
                                            das Error 'No result delivered! No err check possible!' resultiert automatisch aus could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send'
                                            Dieses besagt dass das Gerät nicht auf irgendwelche Kommuniklation reagiert, 3x versucht der Adapter ein Ikommando zu senden und das Gerät meldet sich nicht mit der Bestätigung das Kommando empüfangen bzw ausgeführt zu haben.
                                            Solche Kommandos sind auch momentaner Status oder Temperatur auslesen.
                                            Das eigenartige bei dir ist dass zwei verschiedene mac-Adressen auftauchen und aber nur ein Gerät davon gefunden wird.
                                            Kann es sein dass du ein altes Gerät noch irgenwie unter broadlink.0 hast?
                                            @Einklaus,
                                            Mein T1 hat leider beim Weihnachtsputz meiner Frau den Geist aufgegeben, ist runtergefallen und genau auf's displaqy und man kann es nicht mehr bedienen, deshalb kann ich nicht mehr testen 😞
                                            Habe nur zusätzlichen Fehlerstatus der Antwort abgefragt aber bin mir jetzt nicht sicher ob beim T1 die Fehlermeldung auch wirklich auf der gleichen Position ist wie bei den anderen Geräten da es doppelte Verschlüsselung macht.
                                            @Knallochse
                                            Hast schon mal 10 Sekunden gewartet und erneut auf lern geklickt?
                                            Übrigens, auch du hast 2 verschienene mac's in der konfig und nur eine wird gefunden!
                                            Ich arbeite daran den Adapter anders konfigurieren zu können und in der Konfig auch die angelernten states zu haben damit man a) die selben codes auf mehreren RM's verwenden kann oder b) nur einen Platz hat um gelerntes zu managen.
                                            @P-A-L-A-D-I-N
                                            das würde ich auch gerne aber kann ich nur wenn du die mobile app entschlüsselst und die Zugriff-api's und Schnittstelle auf die cloud kennst! Das Broadlink das nicht offenlegt kann ich das nicht.
                                            Ich persönlich verbiete allen BL-Geräten mit der cloud zu sprechen da ich nicht will dass wenn ich irgend ein Gerät sein oder ausschalte das an die cloud gemeldet wird! Ich steuere meine 9 aktiven Geräte NUR über ioBroker da ich über Vis und ioBroker-app sowieso das von überall machen kann ! Die Räüme und Gruppen kann ich auch nicht verwenden da bei mkir ein Homematic IR-Sensor einen Broadlink-UP-Schalter und vielleicht noch eine Zigbee-Lampe schalten muss und das nur mit ioBroker geht da die einzelnen Steuersysteme sich gegenseitig sonst nicht kennen.
                                            D Knallochse 2 Replies Last reply Reply Quote 1
                                            81.1k
                                            broad2 broadlink rm pro rm3 mini rm4
                                            169
                                            1365
                                            613831
