    4. Nach Scriptausführung nur noch Fehler und keine Funkion
    UNSOLVED Nach Scriptausführung nur noch Fehler und keine Funkion
    • Sunshinemaker
      Sunshinemaker @Homoran last edited by Sunshinemaker
      @Homoran
      Beide Dateien von der Dockerinstallatioen.
      package.json
      package-lock.json
      so, nach einigem hin und her Funktioniert jetzt auch
      npm install --production
      in Docker
      das Ergebnis:
      root@iobroker2:/opt/iobroker/node_modules/iobroker.javascript# npm install --production
      npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
      npm WARN deprecated chokidar@2.1.8: Chokidar 2 will break on node v14+. Upgrade to chokidar 3 with 15x less dependencies.
      npm WARN deprecated fsevents@1.2.13: fsevents 1 will break on node v14+ and could be using insecure binaries. Upgrade to fsevents 2.
      npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
      npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.2.7 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.1 (node_modules/mocha/node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm ERR! code EACCES
      npm ERR! syscall access
      npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types
      npm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types'
      npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types']
      npm ERR!   stack:
      npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types\'',
      npm ERR!   errno: -13,
      npm ERR!   code: 'EACCES',
      npm ERR!   syscall: 'access',
      npm ERR!   path:
      npm ERR!    '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types' }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator.
      npm ERR!     /opt/iobroker/.npm/_logs/2020-06-08T17_54_10_994Z-debug.log
      • AlCalzone
        AlCalzone Developer @Sunshinemaker last edited by AlCalzone
        @Sören Mal den Fixer ausgeführt? EACCES ist meist ein deutlicher Hinweis, dass es mal Zeit ist.
        package.json
        package-lock.json
        War das vor oder nach npm install --production?
        Sunshinemaker 1 Reply Last reply Reply Quote 0
        • Sunshinemaker
          Sunshinemaker @AlCalzone last edited by
          @AlCalzone
          cd /opt/iobroker/node_modules/iobroker.javascript
          oder was Meinst du?
          So jetzt mal ganz von vorne. Ich hab JETZT eben ein Backup erstellt, ioBroker neu aufgesetzt. Geupdatet, den fixer drüber laufen lassen. Backup wieder hergestellt. Und hab jetzt das Problem das ich gerade nicht mehr auf die oberfläche komme. 😠
          • AlCalzone
            @Sören sagte in Nach Scriptausführung nur noch Fehler und keine Funkion:
            oder was Meinst du?
            Stellen die geposteten Dateien den Zustand vor oder nach diesen Befehlen dar? Mich würde interessieren, was vorher war.
            Was steht im Log? Kannst du mit iobroker logs ausgeben lassen.
            • Sunshinemaker
              @AlCalzone said in Nach Scriptausführung nur noch Fehler und keine Funkion:
              die Zeilen sind nach
              vor ging kein nem befehl, das gib erst nachdem ich das Netzwerk von Host auf Bridge geändert hab.
              Terminal geht zum glück.
              iobroker.2020-06-08.log
              • Sunshinemaker
                Ich hab einiges hin und her Probiert. Aber es hat nicht funktioniert. ich weiß nicht was ich verstellt hab. aber ich bin gerade an dem Punkt das ich nicht mal eine komplett Neue Docker Instanz vom ioBroker zum laufen bekommen.
                Ich hab aktuell wieder originale Instanz am Laufen in der keine npm befehle funktionieren. Dafür kann ich kann alles andere erstmal wieder nutzen.
                Vielleicht hat ja noch jemand eine Idee wie ich typescriptim Docker wieder zum laufen kommen.
                Ich danke euch allen aber schon mal jetzt für eure mühe und eure zeit 👏 👏 👏 👍
                • AlCalzone
                  vor ging kein npm befehl
                  Hä? Bevor du npm ausgeführt hast ging npm nicht? Versteh ich nicht
                  In deinem Log sehe ich eigentlich nur Fehler, die mit Netzwerk zu tun haben (falsche IP, Port schon belegt, ...)
                  Nur mit npm. Suche virtual-tsc (entweder in /opt/iobroker/node_modules oder /opt/iobroker/node_modules/iobroker.javascript/node_modules), geh in den Ordner und installiere TypeScript: npm i typescript
                  Anscheinend laufen wir derzeit (warum auch immer so plötzlich) in einen npm-Bug, der seit >1 Jahr bekannt und nicht gefixt ist.
                  • Sunshinemaker
                    Sunshinemaker @AlCalzone last edited by Sunshinemaker
                    Das Problem ist das iobroker in einer Dockerumgebung läuft. Und anscheinend gibt es ja Probleme mit den Rechten wenn als Netzwerk host gewählt ist. Ich bin aber in solchen dingen nicht wirklich der große Experte. Es gibt noch die Möglichkeit das ganze mit einem VLAN zu umgehen. Das hab ich ja versucht. Dann Funktionieren die befehle in Konsole, aber ich hab kein zugriff auf die Oberfläche. Zumindest was ich so alles im Internet irgendwo zusammen suchen konnte.
                    Ich hatte vorhin eine neue iobrocker Umgebung in Docker angelegt, bei der npmfunktioniert hat, aber ich hab eben keine zugriff auf die Oberfläche gehabt habe, sondern nur auf die Konsole.
                    jetzt bin ich wieder zurück zu meiner ausgangsitusation, das ich Zugriff auf die Grafische Oberfläche hab aber npmnicht mehr funktioniert. Und somit auch immer noch der fahler vorhanden ist. Da ich eine Multihost Umgebung habe, kann ich mir im moment damit behelfen das Javascript auf dem Pi3 läuft. Aber da der schon an seiner grenze ist, ist das keine dauerhafte Lösung, sondern nur ein Notbehelf. Aber so kann ich wenigstens alles andere vom Samrthome usw in betrieb halten und steh nciht ganz im Dunklen.
                    Wenn ich aktuell in der Konsole npm i typescripteingebe passiert das:
                    root@iobroker:/opt/iobroker# cd /opt/iobroker/node_modules/iobroker.javascrip
                    bash: cd: /opt/iobroker/node_modules/iobroker.javascrip: Datei oder Verzeichnis nicht gefunden
                    root@iobroker:/opt/iobroker# cd  /opt/iobroker/node_modules/iobroker.javascript/node_modules
                    root@iobroker:/opt/iobroker/node_modules/iobroker.javascript/node_modules# npm i typescript
                    sudo: Hostname iobroker kann nicht aufgelöst werden
                    sudo: Die Audit-Nachricht kann nicht gesendet werden: Unbekannter Fehler -1
                    sudo: pam_open_session: Systemfehler
                    sudo: Regelwerks-Plugin konnte Sitzung nicht initialisieren
                    root@iobroker:/opt/iobroker/node_modules/iobroker.javascript/node_modules# npm -v
                    Ich hoffe ich konnte mein Chaos etwas auflösen.
                    • Sunshinemaker
                      Ich hab jetzt nochmal einen neuen iobroker aufgesetzt und zwar nach dieser Anleitung buanet iobroker V3 und jetzt bin ich wieder an dem Punkt das ich keine zugriff auf die Oberfläche bekomme. Per Terminal kein Problem. Allerdings vermute ich den Fehler dieses mal irgendwo im Netzwerk bzw den Einstellungen.
                      • AlCalzone
                        Hast du irgendwie (unvollständig) den Hostnamen geändert?
                        Suche nach dem Fehler liefert Hinweise, dass man den manuell korrigieren kann:
                        https://linuxhandbook.com/sudo-unable-resolve-host/
                        • Sunshinemaker
                          @AlCalzone
                          Nicht das wüßte. Ich muß auch ehrlich zugeben, den Link von eben. Irgendwie versteh ich da nicht wirklich viel von 😲
                          • AlCalzone
                            @Sören Dann geh am besten mal auf den Link, den du mir gepostet hast und frag da nach. Oder erstelle hier ein Issue: https://github.com/buanet/docker-iobroker/issues
                            Von ioBroker im Docker hab ich leider nicht allzuviel Ahnung.
                            • Sunshinemaker
                              @AlCalzone Ich danke dir Trotzdem 🙂 für deine Zeit 👍
                              adapter fehler javascript adapter rot javascript.0 terminated
                              1058
