    3. Entwicklung
    4. Adapter: broadlink2
    Adapter: broadlink2
      smet-o last edited by
      @frankjoke
      Jetzt funktioniert alles, ohne jegliche Fehlermeldungen.
      Dankeschön!
      • Knallochse
        Knallochse last edited by Knallochse
        Habe garade auf die aktuelle Beta 2.0.9 geupdatet. Ist ein RM3pro+
        Hier die Logausgaben zum Adapter. Anlernmodus lässt sich nicht aktivieren.
        broadlink2.0	2020-06-08 11:42:15.043	warn	(24205) cannot get code to send for: RM:RMPROPLUS-4a-2e-b8.Learn=RM:RMPROPLUS-4a-2e-b8 { val: true,ack: false,ts: 1591609335037,q: 0,from: 'system.adapter.admin.0',user: 'system.user.admin',lc: 159144
        broadlink2.0	2020-06-08 11:41:23.893	warn	(24205) cannot get code to send for: RM:RMPROPLUS-4a-2e-b8.LearnRF=RM:RMPROPLUS-4a-2e-b8 { val: true,ack: false,ts: 1591609283886,q: 0,from: 'system.adapter.admin.0',user: 'system.user.admin',lc: 1591
        broadlink2.0	2020-06-08 11:40:36.006	info	(24205) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-4a-2e-b8, 34:ea:34:4a:2e:b8, 192.168.178.87
        broadlink2.0	2020-06-08 11:40:36.005	warn	(24205) sendPacket error: could not send after 3 trials!: SendPacketErr { here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-4a-2e-b8' }
        broadlink2.0	2020-06-08 11:38:57.813	info	(24205) found macs: 34:ea:34:4a:2e:b8
        broadlink2.0	2020-06-08 11:38:57.812	info	(24205) broadlink2.0 started and found 1 devices named RM:RMPROPLUS-4a-2e-b8
        broadlink2.0	2020-06-08 11:38:57.812	info	(24205) Poll every 30 secods.
        broadlink2.0	2020-06-08 11:38:49.945	info	(24205) Device RM:RMPROPLUS-4a-2e-b8 dedected: address=192.168.178.87, mac=34:ea:34:4a:2e:b8, typ=rmp, id=0x279d devtype=RM3 Pro Plus
        broadlink2.0	2020-06-08 11:38:49.812	info	(24205) UDP socket listening on 0.0.0.0:15001
        broadlink2.0	2020-06-08 11:38:49.806	info	(24205) Discover Broadlink devices for 10sec on broadlink2.0
        broadlink2.0	2020-06-08 11:38:49.784	info	(24205) macObjects: [ '34:ea:34:4a:2e:b8', '9d:27:57:b2:a8:c0' ]
        broadlink2.0	2020-06-08 11:38:49.781	info	(24205) Devices to rename:
        broadlink2.0	2020-06-08 11:38:49.780	info	(24205) Devices to add:
        broadlink2.0	2020-06-08 11:38:49.775	info	(24205) broadlink2 initialization started...
        broadlink2.0	2020-06-08 11:38:49.647	info	(24205) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.20.1, js-controller: 3.1.4
        broadlink2.0	2020-06-08 11:38:43.270	error	at processImmediate (timers.js:658:5)
        broadlink2.0	2020-06-08 11:38:43.270	error	at tryOnImmediate (timers.js:676:5)
        broadlink2.0	2020-06-08 11:38:43.270	error	at runCallback (timers.js:706:11)
        broadlink2.0	2020-06-08 11:38:43.270	error	at Broadlink.parsePublic (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink_fj.js:1194:28)
        broadlink2.0	2020-06-08 11:38:43.270	error	(696) TypeError: Cannot read property '34:ea:34:4a:2e:b8' of null
        broadlink2.0	2020-06-08 11:38:43.269	error	(696) uncaught exception: Cannot read property '34:ea:34:4a:2e:b8' of null
        broadlink2.0	2020-06-08 11:38:42.996	warn	(696) Adapter will exit in latest 1 sec with code false!
        broadlink2.0	2020-06-08 11:38:42.992	info	(696) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        broadlink2.0	2020-06-08 11:38:42.990	info	(696) terminating
        broadlink2.0	2020-06-08 11:38:42.983	info	(696) Close all connections...
        broadlink2.0	2020-06-08 11:38:42.982	info	(696) Adapter disconnected and stopped with dostop(false) and callback(true)
        broadlink2.0	2020-06-08 11:38:42.968	info	(696) Got terminate signal TERMINATE_YOURSELF
        Edit: Anlernmodus starten wohl jetzt mit _Lern & _LernRF (Unterstrich davor - Neue Buttons)
        Es wird auch in den Anlernmodus gegangen (rot LED am RM3pro+ leuchtet)
        Ich bekomme aber leider keine Taste angelernt.
        broadlink2.0	2020-06-08 12:04:21.368	info	(25263) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-4a-2e-b8, 34:ea:34:4a:2e:b8, 192.168.178.87
        broadlink2.0	2020-06-08 12:04:21.368	warn	(25263) sendPacket error: could not send after 3 trials!: SendPacketErr { here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-4a-2e-b8' }
        broadlink2.0	2020-06-08 12:04:15.572	info	(25263) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-4a-2e-b8, 34:ea:34:4a:2e:b8, 192.168.178.87
        broadlink2.0	2020-06-08 12:04:15.571	warn	(25263) sendPacket error: could not send after 3 trials!: SendPacketErr { here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-4a-2e-b8' }
        broadlink2.0	2020-06-08 12:03:47.511	warn	(25263) cannot get code to send for: RM:RMPROPLUS-4a-2e-b8.SendCode=RM:RMPROPLUS-4a-2e-b8 { val:'b2058403180b0c18170c0c18170b0c18170c0c181700021104000128992f0c170c180b18180c0b180b180c18170c0c170c180b1
        broadlink2.0	2020-06-08 12:03:34.312	warn	(25263) Code to send to RM:RMPROPLUS-4a-2e-b8 needs to start with CODE_
        broadlink2.0	2020-06-08 12:03:25.316	warn	(25263) Code to send to RM:RMPROPLUS-4a-2e-b8 needs to start with CODE_
        broadlink2.0	2020-06-08 12:01:37.203	warn	(25263) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = TypeError: Cannot read property 'checkError' of undefinedat enterRFSweep (/opt/iobroker/node_modules/iobroker.broadlink2/
        broadlink2.0	2020-06-08 12:01:37.089	info	(25263) Should learn RF-sweep on RM:RMPROPLUS-4a-2e-b8
        broadlink2.0	2020-06-08 12:01:37.043	info	(25263) Start RF-learning for device: RM:RMPROPLUS-4a-2e-b8
        broadlink2.0	2020-06-08 12:00:49.145	info	(25263) found macs: 34:ea:34:4a:2e:b8
        broadlink2.0	2020-06-08 12:00:49.144	info	(25263) broadlink2.0 started and found 1 devices named RM:RMPROPLUS-4a-2e-b8
        broadlink2.0	2020-06-08 12:00:49.144	info	(25263) Poll every 30 secods.
        broadlink2.0	2020-06-08 12:00:41.302	info	(25263) Device RM:RMPROPLUS-4a-2e-b8 dedected: address=192.168.178.87, mac=34:ea:34:4a:2e:b8, typ=rmp, id=0x279d devtype=RM3 Pro Plus
        broadlink2.0	2020-06-08 12:00:41.152	info	(25263) UDP socket listening on 0.0.0.0:15001
        broadlink2.0	2020-06-08 12:00:41.147	info	(25263) Discover Broadlink devices for 10sec on broadlink2.0
        broadlink2.0	2020-06-08 12:00:41.129	info	(25263) macObjects: [ '34:ea:34:4a:2e:b8', '9d:27:57:b2:a8:c0' ]
        broadlink2.0	2020-06-08 12:00:41.125	info	(25263) Devices to rename:
        broadlink2.0	2020-06-08 12:00:41.125	info	(25263) Devices to add:
        broadlink2.0	2020-06-08 12:00:41.121	info	(25263) broadlink2 initialization started...
        broadlink2.0	2020-06-08 12:00:40.973	info	(25263) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.20.1, js-controller: 3.1.4
        broadlink2.0	2020-06-08 12:00:36.139	warn	(25102) Adapter will exit in latest 1 sec with code false!
        broadlink2.0	2020-06-08 12:00:36.139	info	(25102) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        broadlink2.0	2020-06-08 12:00:36.138	info	(25102) terminating
        broadlink2.0	2020-06-08 12:00:36.136	info	(25102) Close all connections...
        broadlink2.0	2020-06-08 12:00:36.135	info	(25102) Adapter disconnected and stopped with dostop(false) and callback(true)
        broadlink2.0	2020-06-08 12:00:36.134	info	(25102) Got terminate signal TERMINATE_YOURSELF
        broadlink2.0	2020-06-08 11:59:55.317	warn	(25102) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = Error: Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!at startLearning (/opt/iobroker/n
        broadlink2.0	2020-06-08 11:59:55.315	warn	(25102) Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!
        broadlink2.0	2020-06-08 11:58:39.943	warn	(25102) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = TypeError: Cannot read property 'checkError' of undefinedat enterRFSweep (/opt/iobroker/node_modules/iobroker.broadlink2/
        broadlink2.0	2020-06-08 11:58:39.820	info	(25102) Should learn RF-sweep on RM:RMPROPLUS-4a-2e-b8
        broadlink2.0	2020-06-08 11:58:39.770	info	(25102) Start RF-learning for device: RM:RMPROPLUS-4a-2e-b8
        broadlink2.0	2020-06-08 11:58:30.507	info	(25102) found macs: 34:ea:34:4a:2e:b8
        broadlink2.0	2020-06-08 11:58:30.506	info	(25102) broadlink2.0 started and found 1 devices named RM:RMPROPLUS-4a-2e-b8
        broadlink2.0	2020-06-08 11:58:30.505	info	(25102) Poll every 30 secods.
        broadlink2.0	2020-06-08 11:58:22.646	info	(25102) Device RM:RMPROPLUS-4a-2e-b8 dedected: address=192.168.178.87, mac=34:ea:34:4a:2e:b8, typ=rmp, id=0x279d devtype=RM3 Pro Plus
        broadlink2.0	2020-06-08 11:58:22.444	info	(25102) UDP socket listening on 0.0.0.0:15001
        broadlink2.0	2020-06-08 11:58:22.439	info	(25102) Discover Broadlink devices for 10sec on broadlink2.0
        broadlink2.0	2020-06-08 11:58:22.421	info	(25102) macObjects: [ '34:ea:34:4a:2e:b8', '9d:27:57:b2:a8:c0' ]
        broadlink2.0	2020-06-08 11:58:22.417	info	(25102) Devices to rename:
        broadlink2.0	2020-06-08 11:58:22.416	info	(25102) Devices to add:
        broadlink2.0	2020-06-08 11:58:22.411	info	(25102) broadlink2 initialization started...
        broadlink2.0	2020-06-08 11:58:22.254	info	(25102) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.20.1, js-controller: 3.1.4
        broadlink2.0	2020-06-08 11:58:17.356	warn	(25026) Adapter will exit in latest 1 sec with code false!
        broadlink2.0	2020-06-08 11:58:17.356	info	(25026) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        broadlink2.0	2020-06-08 11:58:17.355	info	(25026) terminating
        broadlink2.0	2020-06-08 11:58:17.353	info	(25026) Close all connections...
        broadlink2.0	2020-06-08 11:58:17.352	info	(25026) Adapter disconnected and stopped with dostop(false) and callback(true)
        broadlink2.0	2020-06-08 11:58:17.351	info	(25026) Got terminate signal TERMINATE_YOURSELF
        broadlink2.0	2020-06-08 11:58:09.197	warn	(25026) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = Error: Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!at startLearning (/opt/iobroker/n
        broadlink2.0	2020-06-08 11:58:09.196	warn	(25026) Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!
        broadlink2.0	2020-06-08 11:58:04.236	warn	(25026) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = Error: Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!at startLearning (/opt/iobroker/n
        broadlink2.0	2020-06-08 11:58:04.235	warn	(25026) Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!
        broadlink2.0	2020-06-08 11:57:37.335	warn	(25026) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = Error: Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!at startLearning (/opt/iobroker/n
        broadlink2.0	2020-06-08 11:57:37.332	warn	(25026) Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!
        broadlink2.0	2020-06-08 11:56:53.917	warn	(25026) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = TypeError: Cannot read property 'checkError' of undefinedat enterRFSweep (/opt/iobroker/node_modules/iobroker.broadlink2/
        broadlink2.0	2020-06-08 11:56:52.947	info	(25026) Should learn RF-sweep on RM:RMPROPLUS-4a-2e-b8
        broadlink2.0	2020-06-08 11:56:52.900	info	(25026) Start RF-learning for device: RM:RMPROPLUS-4a-2e-b8
        broadlink2.0	2020-06-08 11:56:49.729	info	(25026) found macs: 34:ea:34:4a:2e:b8
        broadlink2.0	2020-06-08 11:56:49.729	info	(25026) broadlink2.0 started and found 1 devices named RM:RMPROPLUS-4a-2e-b8
        broadlink2.0	2020-06-08 11:56:49.728	info	(25026) Poll every 30 secods.
        broadlink2.0	2020-06-08 11:56:41.899	info	(25026) Device RM:RMPROPLUS-4a-2e-b8 dedected: address=192.168.178.87, mac=34:ea:34:4a:2e:b8, typ=rmp, id=0x279d devtype=RM3 Pro Plus
        broadlink2.0	2020-06-08 11:56:41.187	info	(25026) UDP socket listening on 0.0.0.0:15001
        broadlink2.0	2020-06-08 11:56:41.181	info	(25026) Discover Broadlink devices for 10sec on broadlink2.0
        broadlink2.0	2020-06-08 11:56:41.163	info	(25026) macObjects: [ '34:ea:34:4a:2e:b8', '9d:27:57:b2:a8:c0' ]
        broadlink2.0	2020-06-08 11:56:41.159	info	(25026) Devices to rename:
        broadlink2.0	2020-06-08 11:56:41.158	info	(25026) Devices to add:
        broadlink2.0	2020-06-08 11:56:41.153	info	(25026) broadlink2 initialization started...
        broadlink2.0	2020-06-08 11:56:40.975	info	(25026) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.20.1, js-controller: 3.1.4
        broadlink2.0	2020-06-08 11:56:36.247	warn	(24899) Adapter will exit in latest 1 sec with code false!
        broadlink2.0	2020-06-08 11:56:36.247	info	(24899) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        broadlink2.0	2020-06-08 11:56:36.246	info	(24899) terminating
        broadlink2.0	2020-06-08 11:56:36.243	info	(24899) Close all connections...
        broadlink2.0	2020-06-08 11:56:36.243	info	(24899) Adapter disconnected and stopped with dostop(false) and callback(true)
        broadlink2.0	2020-06-08 11:56:36.241	info	(24899) Got terminate signal TERMINATE_YOURSELF
        broadlink2.0	2020-06-08 11:55:12.308	warn	(24899) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = TypeError: Cannot read property 'checkError' of undefinedat enterRFSweep (/opt/iobroker/node_modules/iobroker.broadlink2/
        broadlink2.0	2020-06-08 11:55:11.351	info	(24899) Should learn RF-sweep on RM:RMPROPLUS-4a-2e-b8
        broadlink2.0	2020-06-08 11:55:11.305	info	(24899) Start RF-learning for device: RM:RMPROPLUS-4a-2e-b8
        broadlink2.0	2020-06-08 11:55:07.742	info	(24899) found macs: 34:ea:34:4a:2e:b8
        broadlink2.0	2020-06-08 11:55:07.741	info	(24899) broadlink2.0 started and found 1 devices named RM:RMPROPLUS-4a-2e-b8
        broadlink2.0	2020-06-08 11:55:07.741	info	(24899) Poll every 30 secods.
        broadlink2.0	2020-06-08 11:54:59.891	info	(24899) Device RM:RMPROPLUS-4a-2e-b8 dedected: address=192.168.178.87, mac=34:ea:34:4a:2e:b8, typ=rmp, id=0x279d devtype=RM3 Pro Plus
        broadlink2.0	2020-06-08 11:54:59.731	info	(24899) UDP socket listening on 0.0.0.0:15001
        broadlink2.0	2020-06-08 11:54:59.725	info	(24899) Discover Broadlink devices for 10sec on broadlink2.0
        broadlink2.0	2020-06-08 11:54:59.700	info	(24899) macObjects: [ '34:ea:34:4a:2e:b8', '9d:27:57:b2:a8:c0' ]
        broadlink2.0	2020-06-08 11:54:59.696	info	(24899) Devices to rename:
        broadlink2.0	2020-06-08 11:54:59.695	info	(24899) Devices to add:
        broadlink2.0	2020-06-08 11:54:59.691	info	(24899) broadlink2 initialization started...
        broadlink2.0	2020-06-08 11:54:59.528	info	(24899) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.20.1, js-controller: 3.1.4
        broadlink2.0	2020-06-08 11:54:54.694	warn	(24790) Adapter will exit in latest 1 sec with code false!
        broadlink2.0	2020-06-08 11:54:54.693	info	(24790) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        broadlink2.0	2020-06-08 11:54:54.692	info	(24790) terminating
        broadlink2.0	2020-06-08 11:54:54.690	info	(24790) Close all connections...
        broadlink2.0	2020-06-08 11:54:54.690	info	(24790) Adapter disconnected and stopped with dostop(false) and callback(true)
        broadlink2.0	2020-06-08 11:54:54.688	info	(24790) Got terminate signal TERMINATE_YOURSELF
        broadlink2.0	2020-06-08 11:54:09.692	warn	(24790) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._Learn = Error: Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!at startLearning (/opt/iobroker/nod
        broadlink2.0	2020-06-08 11:54:09.691	warn	(24790) Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!
        broadlink2.0	2020-06-08 11:53:45.954	warn	(24790) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = Error: Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!at startLearning (/opt/iobroker/n
        broadlink2.0	2020-06-08 11:53:45.952	warn	(24790) Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!
        broadlink2.0	2020-06-08 11:52:26.943	warn	(24790) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = TypeError: Cannot read property 'checkError' of undefinedat enterRFSweep (/opt/iobroker/node_modules/iobroker.broadlink2/
        broadlink2.0	2020-06-08 11:52:26.803	info	(24790) Should learn RF-sweep on RM:RMPROPLUS-4a-2e-b8
        broadlink2.0	2020-06-08 11:52:26.755	info	(24790) Start RF-learning for device: RM:RMPROPLUS-4a-2e-b8
        broadlink2.0	2020-06-08 11:52:07.159	info	(24790) found macs: 34:ea:34:4a:2e:b8
        broadlink2.0	2020-06-08 11:52:07.159	info	(24790) broadlink2.0 started and found 1 devices named RM:RMPROPLUS-4a-2e-b8
        broadlink2.0	2020-06-08 11:52:07.158	info	(24790) Poll every 30 secods.
        broadlink2.0	2020-06-08 11:51:59.370	info	(24790) Device RM:RMPROPLUS-4a-2e-b8 dedected: address=192.168.178.87, mac=34:ea:34:4a:2e:b8, typ=rmp, id=0x279d devtype=RM3 Pro Plus
        broadlink2.0	2020-06-08 11:51:59.118	info	(24790) UDP socket listening on 0.0.0.0:15001
        broadlink2.0	2020-06-08 11:51:59.113	info	(24790) Discover Broadlink devices for 10sec on broadlink2.0
        broadlink2.0	2020-06-08 11:51:59.090	info	(24790) macObjects: [ '34:ea:34:4a:2e:b8', '9d:27:57:b2:a8:c0' ]
        broadlink2.0	2020-06-08 11:51:59.086	info	(24790) Devices to rename:
        broadlink2.0	2020-06-08 11:51:59.085	info	(24790) Devices to add:
        broadlink2.0	2020-06-08 11:51:59.081	info	(24790) broadlink2 initialization started...
        broadlink2.0	2020-06-08 11:51:58.948	info	(24790) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.20.1, js-controller: 3.1.4
        broadlink2.0	2020-06-08 11:51:54.404	warn	(24205) Adapter will exit in latest 1 sec with code false!
        broadlink2.0	2020-06-08 11:51:54.403	info	(24205) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        broadlink2.0	2020-06-08 11:51:54.402	info	(24205) terminating
        broadlink2.0	2020-06-08 11:51:54.400	info	(24205) Close all connections...
        broadlink2.0	2020-06-08 11:51:54.399	info	(24205) Adapter disconnected and stopped with dostop(false) and callback(true)
        broadlink2.0	2020-06-08 11:51:54.397	info	(24205) Got terminate signal TERMINATE_YOURSELF
        broadlink2.0	2020-06-08 11:51:01.448	warn	(24205) cannot get code to send for: RM:RMPROPLUS-4a-2e-b8.LearnRF=RM:RMPROPLUS-4a-2e-b8 { val: true,ack: false,ts: 1591609861443,q: 0,from: 'system.adapter.admin.0',user: 'system.user.admin',lc: 1591
        broadlink2.0	2020-06-08 11:50:43.238	warn	(24205) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = Error: Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!at startLearning (/opt/iobroker/n
        broadlink2.0	2020-06-08 11:50:43.237	warn	(24205) Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!
        broadlink2.0	2020-06-08 11:50:19.531	warn	(24205) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = Error: Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!at startLearning (/opt/iobroker/n
        broadlink2.0	2020-06-08 11:50:19.529	warn	(24205) Device RM:RMPROPLUS-4a-2e-b8 is still in learning mode and cannot start it again!
        broadlink2.0	2020-06-08 11:48:13.964	warn	(24205) Error in StateChange for broadlink2.0.RM:RMPROPLUS-4a-2e-b8._LearnRF = TypeError: Cannot read property 'checkError' of undefinedat enterRFSweep (/opt/iobroker/node_modules/iobroker.broadlink2/
        broadlink2.0	2020-06-08 11:48:13.865	info	(24205) Should learn RF-sweep on RM:RMPROPLUS-4a-2e-b8
        broadlink2.0	2020-06-08 11:48:13.819	info	(24205) Start RF-learning for device: RM:RMPROPLUS-4a-2e-b8
        Edit2: Anlernen von IR Signalen per _Learn geht . Das senden bereits angelernter RF-Signale funktioniert auch.
          deta Most Active last edited by deta
          Irgendwas stimmt jetzt nicht mehr.... Aktuelle Version vom Git gestern Abend.
          Wenn ich das auch Manuell mal auslöse in den Objekten gehts nicht und das Log sagt das:
          (Adapter gerade extra neu gestartet)
          broadlink2.0	2020-06-08 15:04:39.223	info	(19157) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80
          broadlink2.0	2020-06-08 15:04:39.222	warn	(19157) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'}
          broadlink2.0	2020-06-08 15:04:34.753	info	(19157) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80
          broadlink2.0	2020-06-08 15:04:34.752	warn	(19157) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'}
          broadlink2.0	2020-06-08 15:04:13.950	info	(19157) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80
          broadlink2.0	2020-06-08 15:04:13.947	warn	(19157) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'}
          broadlink2.0	2020-06-08 15:03:32.527	info	(19157) found macs: c8:f7:42:da:2d:ad
          broadlink2.0	2020-06-08 15:03:32.525	info	(19157) broadlink2.0 started and found 1 devices named RM:RMPROPLUS-da-2d-ad
          broadlink2.0	2020-06-08 15:03:32.523	info	(19157) Poll every 30 secods.
          broadlink2.0	2020-06-08 15:03:25.019	info	(19157) Device RM:RMPROPLUS-da-2d-ad dedected: address=192.168.178.80, mac=c8:f7:42:da:2d:ad, typ=rmp, id=0x279d devtype=RM3 Pro Plus
          broadlink2.0	2020-06-08 15:03:24.385	info	(19157) UDP socket listening on 0.0.0.0:15001
          broadlink2.0	2020-06-08 15:03:24.377	info	(19157) Discover Broadlink devices for 10sec on broadlink2.0
          broadlink2.0	2020-06-08 15:03:24.342	info	(19157) macObjects: [ '24:df:a7:7a:70:92', 'c8:f7:42:da:2d:ad' ]
          broadlink2.0	2020-06-08 15:03:24.335	info	(19157) Devices to rename:
          broadlink2.0	2020-06-08 15:03:24.333	info	(19157) Devices to add: []
          broadlink2.0	2020-06-08 15:03:24.324	info	(19157) broadlink2 initialization started...
          broadlink2.0	2020-06-08 15:03:24.042	info	(19157) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v12.18.0, js-controller: 3.1.5
          broadlink2.0	2020-06-08 15:03:10.521	warn	(11721) Adapter will exit in latest 1 sec with code false!
          broadlink2.0	2020-06-08 15:03:10.518	info	(11721) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          broadlink2.0	2020-06-08 15:03:10.515	info	(11721) terminating
          broadlink2.0	2020-06-08 15:03:10.512	info	(11721) Close all connections...
          broadlink2.0	2020-06-08 15:03:10.510	info	(11721) Adapter disconnected and stopped with dostop(false) and callback(true)
          broadlink2.0	2020-06-08 15:03:10.507	info	(11721) Got terminate signal TERMINATE_YOURSELF
          Update: Nach dem Neustart des Broadlink, also Strom am Broadlink selber geht es wieder mh.
          Update2: Geht doch nicht, kurz dann gehts wieder nicht Log:
          broadlink2.0	2020-06-08 15:34:57.365	info	(2279) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80
          broadlink2.0	2020-06-08 15:34:57.362	warn	(2279) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'}
          broadlink2.0	2020-06-08 15:34:28.467	info	(2279) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80
          broadlink2.0	2020-06-08 15:34:28.466	warn	(2279) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'}
          broadlink2.0	2020-06-08 15:34:25.932	info	(2279) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80
          broadlink2.0	2020-06-08 15:34:25.931	warn	(2279) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'}
          broadlink2.0	2020-06-08 15:34:24.708	info	(2279) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80
          broadlink2.0	2020-06-08 15:34:24.706	warn	(2279) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'}
          broadlink2.0	2020-06-08 15:34:22.501	info	(2279) Error 'No result delivered! No err check possible!' in device.checkError for RMP RM:RMPROPLUS-da-2d-ad, c8:f7:42:da:2d:ad, 192.168.178.80
          broadlink2.0	2020-06-08 15:34:22.499	warn	(2279) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:RMPROPLUS-da-2d-ad'}
          broadlink2.0	2020-06-08 15:33:25.137	info	(2279) found macs: c8:f7:42:da:2d:ad
          broadlink2.0	2020-06-08 15:33:25.136	info	(2279) broadlink2.0 started and found 1 devices named RM:RMPROPLUS-da-2d-ad
          broadlink2.0	2020-06-08 15:33:25.135	info	(2279) Poll every 30 secods.
          broadlink2.0	2020-06-08 15:33:17.283	info	(2279) Device RM:RMPROPLUS-da-2d-ad dedected: address=192.168.178.80, mac=c8:f7:42:da:2d:ad, typ=rmp, id=0x279d devtype=RM3 Pro Plus
          broadlink2.0	2020-06-08 15:33:17.125	info	(2279) UDP socket listening on 0.0.0.0:15001
          broadlink2.0	2020-06-08 15:33:17.117	info	(2279) Discover Broadlink devices for 10sec on broadlink2.0
          broadlink2.0	2020-06-08 15:33:17.082	info	(2279) macObjects: [ '24:df:a7:7a:70:92', 'c8:f7:42:da:2d:ad' ]
          broadlink2.0	2020-06-08 15:33:17.076	info	(2279) Devices to rename:
          broadlink2.0	2020-06-08 15:33:17.074	info	(2279) Devices to add: []
          broadlink2.0	2020-06-08 15:33:17.065	info	(2279) broadlink2 initialization started...
          broadlink2.0	2020-06-08 15:33:16.822	info	(2279) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v12.18.0, js-controller: 3.1.5
          frankjoke 1 Reply Last reply Reply Quote 0
          • frankjoke
            frankjoke @deta last edited by
            @deta
            das Error 'No result delivered! No err check possible!' resultiert automatisch aus could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send'
            Dieses besagt dass das Gerät nicht auf irgendwelche Kommuniklation reagiert, 3x versucht der Adapter ein Ikommando zu senden und das Gerät meldet sich nicht mit der Bestätigung das Kommando empüfangen bzw ausgeführt zu haben.
            Solche Kommandos sind auch momentaner Status oder Temperatur auslesen.
            Das eigenartige bei dir ist dass zwei verschiedene mac-Adressen auftauchen und aber nur ein Gerät davon gefunden wird.
            Kann es sein dass du ein altes Gerät noch irgenwie unter broadlink.0 hast?
            @Einklaus,
            Mein T1 hat leider beim Weihnachtsputz meiner Frau den Geist aufgegeben, ist runtergefallen und genau auf's displaqy und man kann es nicht mehr bedienen, deshalb kann ich nicht mehr testen 😞
            Habe nur zusätzlichen Fehlerstatus der Antwort abgefragt aber bin mir jetzt nicht sicher ob beim T1 die Fehlermeldung auch wirklich auf der gleichen Position ist wie bei den anderen Geräten da es doppelte Verschlüsselung macht.
            @Knallochse
            Hast schon mal 10 Sekunden gewartet und erneut auf lern geklickt?
            Übrigens, auch du hast 2 verschienene mac's in der konfig und nur eine wird gefunden!
            Ich arbeite daran den Adapter anders konfigurieren zu können und in der Konfig auch die angelernten states zu haben damit man a) die selben codes auf mehreren RM's verwenden kann oder b) nur einen Platz hat um gelerntes zu managen.
            @P-A-L-A-D-I-N
            das würde ich auch gerne aber kann ich nur wenn du die mobile app entschlüsselst und die Zugriff-api's und Schnittstelle auf die cloud kennst! Das Broadlink das nicht offenlegt kann ich das nicht.
            Ich persönlich verbiete allen BL-Geräten mit der cloud zu sprechen da ich nicht will dass wenn ich irgend ein Gerät sein oder ausschalte das an die cloud gemeldet wird! Ich steuere meine 9 aktiven Geräte NUR über ioBroker da ich über Vis und ioBroker-app sowieso das von überall machen kann ! Die Räüme und Gruppen kann ich auch nicht verwenden da bei mkir ein Homematic IR-Sensor einen Broadlink-UP-Schalter und vielleicht noch eine Zigbee-Lampe schalten muss und das nur mit ioBroker geht da die einzelnen Steuersysteme sich gegenseitig sonst nicht kennen.
            D Knallochse 2 Replies Last reply Reply Quote 1
              deta Most Active @frankjoke last edited by
              @frankjoke sagte in Adapter: broadlink2:
              @deta
              Nein kein altes Gerät, das ist der Mini der derzeit nicht im Betrieb ist, aber vom Test die Tage
              noch in den Objekten steht.
              • Knallochse
                Knallochse @frankjoke last edited by Knallochse
                @frankjoke Das mit den 2 Mac Adressen verstehe ich nicht. Ich habe und hatte immer nur den einen Broadlink 3.
                In der Fritzbox wird auch nur 1 Broadlink mit der Mac Adresse angezeigt. Die 2. Mac-Adresse gibt es in der Fritzbox nicht (Weder unter verbundene noch ungenutzte Verbindungen)
                Edit: Bin wieder auf 2.0.3 zurück und da wird nur 1 Mac Adresse gefunden
                  Einklaus last edited by
                  @frankjoke
                  Habe noch ein Reserve Gerät, kann es dir gerne zum Testen zusenden.
                  frankjoke 2 Replies Last reply Reply Quote 0
                  • frankjoke
                    frankjoke @Einklaus last edited by
                    @Einklaus
                    Habe ein kleines Update auf git gemacht bei dem ich den Zusatztest beim T1 wieder herausgenommen hab und auch sonst sollten weniger/keine Doppelmeldungen mehr auftauchen.
                    Warum allerdings Geräte manchmal einfach offline sind hab ich noch nicht herausgefunden.
                    • frankjoke
                      @Einklaus ,
                      Danke, aber das machen wir nur wenn du und andere Fehler finden sie ich mit euren Beschreibungen nicht beheben kann!
                      Übrigens, habe auch schon LB1 (die Glühbirnen) integriert und ich kann sie auslesen (den Zustand und Status) aber hab's nicht geschafft ihnen Befehle zu senden, muss mal ein Python-Programm schreiben um zu sehen ob's dort geht oder auch nicht!
                      BBTown ? 2 Replies Last reply Reply Quote 0
                      • BBTown
                        BBTown @frankjoke last edited by
                        @frankjoke
                        Wäre es sehr aufwendig etwas zu implementieren, dass zusätzlich zur "automatischen Gerätesuche" den Usern optional die Angabe von "IP-Adressen und Gerätenamen" für die Broadlinks ermöglicht?
                          @frankjoke
                          Wenn du irgendwann ein Gerät zum Testen brauchst, einfach schreiben. Schicke es dir dann natürlich zu.
                          Die Flureon Geräte machen auch keine Fehlermeldung mehr, deine Änderung haben gewirkt.
                          Danke nochmalig für deine Arbeiten
                            A Former User @frankjoke last edited by
                            @frankjoke
                            ich hab die aktuelle Version von Git gezogen, jetzt kommen sendPacket errors, die waren vorher nicht da, hier mal ein Logauszug, die Abstände sind vielleicht interesant?
                            broadlink2.0	2020-06-09 17:29:42.730	warn	(20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                            broadlink2.0	2020-06-09 17:29:07.682	warn	(20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                            broadlink2.0	2020-06-09 17:28:33.368	warn	(20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                            broadlink2.0	2020-06-09 17:27:57.682	warn	(20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                            broadlink2.0	2020-06-09 17:27:22.703	warn	(20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                            broadlink2.0	2020-06-09 17:26:47.703	warn	(20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                            broadlink2.0	2020-06-09 17:21:32.607	warn	(20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'SP:0x2728_34:ea:34:f4:f3:e8'}
                            broadlink2.0	2020-06-09 17:19:12.814	warn	(20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                            broadlink2.0	2020-06-09 17:18:38.380	warn	(20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                            broadlink2.0	2020-06-09 17:18:02.668	warn	(20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                            broadlink2.0	2020-06-09 17:17:27.768	warn	(20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                            broadlink2.0	2020-06-09 17:16:52.758	warn	(20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                            host.iobroker	2020-06-09 17:15:08.753	info	instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
                            host.iobroker	2020-06-09 17:15:00.028	info	instance system.adapter.openweathermap.0 started with pid 12742
                            broadlink2.0	2020-06-09 17:12:12.752	warn	(20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'SP:0x2728_34:ea:34:f4:f3:e8'}
                            host.iobroker	2020-06-09 17:11:00.028	warn	instance system.adapter.odl.0 already running with pid 3398
                            broadlink2.0	2020-06-09 17:09:18.462	warn	(20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                            broadlink2.0	2020-06-09 17:08:42.741	warn	(20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                            broadlink2.0	2020-06-09 17:08:09.803	warn	(20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                            broadlink2.0	2020-06-09 17:08:07.580	warn	(20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'SP:0x2728_34:ea:34:f4:f3:e8'}
                            broadlink2.0	2020-06-09 17:07:32.678	warn	(20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                            broadlink2.0	2020-06-09 17:06:57.648	warn	(20291) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                            Es geht hier um den RM-Mini, den ich hab, der State sieht so aus:
                              "common": {
                                "name": "RM:0x2737_34:ea:34:41:45:14",
                                "read": true,
                                "write": true,
                                "state": "state",
                                "role": "level",
                                "type": "boolean"
                              "type": "state",
                              "_id": "broadlink2.0.RM:0x2737_34:ea:34:41:45:14",
                              "native": {
                                "host": {
                                  "address": "192.168.5.151",
                                  "family": "IPv4",
                                  "port": 80,
                                  "size": 128,
                                  "devtype": 10039,
                                  "type": "rm",
                                  "devname": "RM Mini",
                                  "mac": "34:ea:34:41:45:14"
                              "from": "system.adapter.broadlink2.0",
                              "user": "system.user.admin",
                              "ts": 1554387878423,
                              "acl": {
                                "object": 1636,
                                "state": 1636,
                                "owner": "system.user.admin",
                            Meine Geräte sehen in den Objekten so aus, ich habe in der konfig nichts eingetragen, und die Objekte vor dem Updaten des Adapters gelöscht, um zu sehen, obs an irgendwelchen alten Einträgen liegt..
                            D frankjoke 2 Replies Last reply Reply Quote 0
                              deta Most Active @Guest last edited by
                              @ilovegym Teste mal folgendes:
                              Broadlink ohne Strom, Adapter deaktivieren, Broadlink Strom wieder drann, kurz danach Adapter wieder aktivieren.
                              Dann geht er bei mir kurze Zeit und dann ist wieder Ende.
                                Arnulf last edited by
                                kannst du einen Dauer-Ping auf den Broadlink absetzen? Nicht dass es am Broadcom liegt
                                  A Former User @deta last edited by
                                  @deta hmm das geht bei mir.. keine Probleme.. der Adapter läuft.. halt n paar Warnings im log.. aber so funktioniert alles...
                                    @ilovegym sagte in Adapter: broadlink2:
                                    Kannst du damit auch Steuern , wenn er diese Warn ausgibt? Ich kann 1 2 Befehle geben und dann Ende, geht nix mehr.
                                      @deta nee wenn die warnings kommen, gehts nicht. aber die kommen so alle 10 -20 minuten mal.. dann ist wieder ruhe..
                                      • frankjoke
                                        frankjoke @Guest last edited by frankjoke
                                        @ilovegym
                                        Ich habe gerade auf Git das Timeout für sendMessage wieder heruntergestzt da ich sehe dass deshalb nicht weniger fehler kommen.
                                        Ich bin schon beim verzweifeln da mit der jetztigen ich mit der jetzigen Version nur noch sehr sporadisch timout-Fehler hab.
                                        Diese entstehen wenn der Adapter nicht nach (jetzt 900 ms, davor 2 Sekunden) ein Antwort vom gerät bekommt.
                                        Der adapter versucht das 3x (mit kurzer, steigender Wartezeit dazwischen von 100-600 ms) und gibt dann erst 'nen Fehler aus! Bei mir läft's oft stundenlang ohne Fehler und dann sind Fehler, aber bei unterschiedlichen Geräten und nicht permanent so wie bei dir.
                                        Ich tippe schon auf ein Netzwerkproblem da auch mein NAS ab und zu (>=1x / Woche) Fehlermeldungen liefert dass das Netzwerk was hat.
                                        Bitte wieder mit letzter Version weitertesten damit ich sehe ob Das einen Einfluss hat(te).
                                        edit:
                                        habe noch einige Parameter leicht geändert da ich herausgefunden hab das mein Pc (schnellstes gerät)= am wenigsten Probleme hatte und nie die Fehler brachte, die VM auf dem QNAP NAS hatte öfter Probleme, aber allesamt auch nur all 30-50 Minuten und der Rasp4 mit buster drauf zeigte öfter Probleme.
                                        Also nahm ich an dass vielleicht Probleme auftauchen wenn verschiedene Processe (das poll oder ein sen/learn-Befehl) zufällig fast gleichzeitig auftreten bzw inerhalb des timouts.
                                        Deshalb hab ich zusätzliche checks eingeführt damit alte Befehle beendet werden bevor neue gesendet werden, das scheint zu wirken, zumindest hatte ich keine Fehler in der deltzten Stunde auf den 3 rechnern!
                                          @frankjoke
                                          vielen Dank! Ich habe gestern Abend den Mini mal beobachtet, und gesehen, dass er ab und zu 3x blau blinkt - schliesse doch auf ein Netzwerkproblem, er steht genau zwischen Repeater und Router.
                                          Ich habe die neue Version von dir mal installiert, beobachte das heute ein paar Stunden, und dann werde ich den RM mal woanders hinstellen.
                                            @frankjoke
                                            Also, nach kurzer Zeit sieht es so aus, ich habe um 7.54 Uhr deine neue Version von Git installiert, und um 8:33 habe ich den Broadlink umgestellt, da die Fehler immer noch kamen und er ab und blau blinkte.
                                            Die Fehlermeldung um 8.33 vom javascript stammt noch von einem alten Datenpunkt, den es nicht mehr gibt, hab dann direct aus dem Adapter auf den Button gedrückt, funktioneren tut er.
                                            Als nächstes werd ich ihn mal resetten und neu einbinden, dieses geblinke mag ich nicht..
                                            Zusammengefasst: blinken stört, fehlermeldungen im log stören, aber funktionieren tuts...
                                            Übrigens, nach Hause telefonieren dürfen die ganzen Broadlink bei mir nicht, sind im Router geblockt.
                                            2020-06-10 07:53:57.668  - info: host.iobroker iobroker url "https://github.com/frankjoke/ioBroker.broadlink2.git"
                                            2020-06-10 07:54:00.173  - info: host.iobroker iobroker install https://github.com/frankjoke/ioBroker.broadlink2/tarball/38c9254700134c52d28dd11b1dfa148ef3c89ce8
                                            2020-06-10 07:54:00.501  - info: host.iobroker iobroker npm install https://github.com/frankjoke/ioBroker.broadlink2/tarball/38c9254700134c52d28dd11b1dfa148ef3c89ce8 --loglevel error --prefix "/opt/iobroker" (System call)
                                            2020-06-10 07:54:39.037  - info: host.iobroker iobroker upload [5] broadlink2.admin /opt/iobroker/node_modules/iobroker.broadlink2/admin/words.js words.js application/javascript
                                            2020-06-10 07:54:39.166  - info: host.iobroker iobroker upload [4] broadlink2.admin /opt/iobroker/node_modules/iobroker.broadlink2/admin/style.css style.css text/css
                                            2020-06-10 07:54:39.221  - info: host.iobroker iobroker upload [3] broadlink2.admin /opt/iobroker/node_modules/iobroker.broadlink2/admin/index_m.html index_m.html text/html
                                            2020-06-10 07:54:39.277  - info: host.iobroker iobroker upload [2] broadlink2.admin /opt/iobroker/node_modules/iobroker.broadlink2/admin/index.html index.html text/html
                                            2020-06-10 07:54:39.335  - info: host.iobroker iobroker upload [1] broadlink2.admin /opt/iobroker/node_modules/iobroker.broadlink2/admin/broadlink2.png broadlink2.png image/png
                                            2020-06-10 07:54:39.391  - info: host.iobroker iobroker upload [0] broadlink2.admin /opt/iobroker/node_modules/iobroker.broadlink2/admin/broadlink.png broadlink.png image/png
                                            2020-06-10 07:54:39.854  - info: host.iobroker iobroker Update "system.adapter.broadlink2.0"
                                            2020-06-10 07:54:39.864  - info: host.iobroker stopInstance system.adapter.broadlink2.0 (force=false, process=true)
                                            2020-06-10 07:54:39.866  - info: host.iobroker stopInstance system.adapter.broadlink2.0 send kill signal
                                            2020-06-10 07:54:39.876  - warn: broadlink2.0 (20291) Adapter will exit in latest 1 sec with code false!
                                            2020-06-10 07:54:41.147  - info: host.iobroker instance system.adapter.broadlink2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            2020-06-10 07:54:42.899  - info: host.iobroker instance system.adapter.broadlink2.0 started with pid 25056
                                            2020-06-10 07:57:15.842  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'SP:0x2728_34:ea:34:f4:f3:e8'}
                                            2020-06-10 07:57:18.195  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 07:57:51.002  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 07:58:27.652  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 07:59:01.008  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 07:59:36.054  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 08:07:11.024  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 08:07:46.040  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 08:08:21.083  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 08:08:56.065  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 08:09:31.218  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 08:10:06.081  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 08:17:06.244  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 08:17:42.590  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 08:18:16.271  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 08:18:51.145  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 08:19:26.042  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 08:27:01.040  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 08:27:36.153  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 08:28:11.172  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 08:28:46.062  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 08:29:21.046  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 08:29:56.165  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 08:32:16.788  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 08:32:51.280  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 08:33:27.986  - warn: javascript.0 (19353) State "broadlink2.0.RM:RMMINI-41-45-14.L.TV_on" not found
                                            2020-06-10 08:33:36.453  - warn: javascript.0 (19353) State "broadlink2.0.RM:RMMINI-41-45-14.L.TV_on" not found
                                            2020-06-10 08:37:31.927  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 08:38:06.072  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 08:38:41.063  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 08:39:16.058  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            2020-06-10 08:39:51.776  - warn: broadlink2.0 (25056) sendPacket error: could not send after 3 trials!: SendPacketErr {here: false,err: 'timed out on send',name: 'RM:0x2737_34:ea:34:41:45:14'}
                                            81.1k
                                            broad2 broadlink rm pro rm3 mini rm4
                                            169
                                            1365
                                            611582
