    4. Pi 3 als Bluetooth LE Scanner (Beispielscript)
      rascal last edited by
      wenn ich noble mittels npm installieren will (wie auf github beschrieben) kommt das:
      root@Rasp-Radio-Garage:~# npm install noble
      npm WARN optional dep failed, continuing xpc-connection@0.1.4
      > usb@1.1.2 install /root/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usb
      > node-pre-gyp install --fallback-to-build
      make: Entering directory '/root/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usb/build'
        CC(target) Release/obj.target/libusb/libusb/libusb/core.o
        CC(target) Release/obj.target/libusb/libusb/libusb/descriptor.o
        CC(target) Release/obj.target/libusb/libusb/libusb/hotplug.o
        CC(target) Release/obj.target/libusb/libusb/libusb/io.o
        CC(target) Release/obj.target/libusb/libusb/libusb/strerror.o
        CC(target) Release/obj.target/libusb/libusb/libusb/sync.o
        CC(target) Release/obj.target/libusb/libusb/libusb/os/poll_posix.o
        CC(target) Release/obj.target/libusb/libusb/libusb/os/threads_posix.o
        CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_usbfs.o
        CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_udev.o
        AR(target) Release/obj.target/usb.a
        COPY Release/usb.a
        CXX(target) Release/obj.target/usb_bindings/src/node_usb.o
        CXX(target) Release/obj.target/usb_bindings/src/device.o
        CXX(target) Release/obj.target/usb_bindings/src/transfer.o
        SOLINK_MODULE(target) Release/obj.target/usb_bindings.node
        COPY Release/usb_bindings.node
        COPY /root/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usb/src/binding/usb_bindings.node
        TOUCH Release/obj.target/action_after_build.stamp
      make: Leaving directory '/root/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usb/build'
      > bluetooth-hci-socket@0.4.4 install /root/node_modules/noble/node_modules/bluetooth-hci-socket
      > node-gyp rebuild
      make: Entering directory '/root/node_modules/noble/node_modules/bluetooth-hci-socket/build'
        CXX(target) Release/obj.target/binding/src/BluetoothHciSocket.o
        SOLINK_MODULE(target) Release/obj.target/binding.node
        COPY Release/binding.node
      make: Leaving directory '/root/node_modules/noble/node_modules/bluetooth-hci-socket/build'
      noble@1.6.0 node_modules/noble
      ├── bplist-parser@0.0.6
      ├── debug@2.2.0 (ms@0.7.1)
      └── bluetooth-hci-socket@0.4.4 (nan@2.3.5, usb@1.1.2)
      • ruhr70
        ruhr70 last edited by
        @rascal:
        ja,
        apt-get install bluetooth bluez libbluetooth-dev libudev-dev
        alles installiert und die neueste version `
        Ist noble vorhanden?
        In den Einstellungen des JavaScript Adapters unter "zusätzliche npm Module laden" eingetragen?
        Und auf dem Slave auch wirklich installiert?
        /opt/iobroker/node_modules/iobroker.javascript/node_modules/noble
        (Aus dem Kopf)
        Gesendet von iPad mit Tapatalk
          dass habe ich in dem von dir angegebenem Verzeichnis:
          root@Rasp-Radio-Garage:/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble# ls
          CHANGELOG.md  examples  index.js  lib  LICENSE  package.json  README.md  test  test.js  with-bindings.js  ws-slave.js
          • ruhr70
            Ja, sorry. Steht ja auch oben im Log.
            Mmmh…
              meine Adapter Konfig:
                ist das hier normal?
                root@Rasp-Radio-Garage:~# service bluetooth status
                * bluetooth.service - Bluetooth service
                   Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled)
                   Active: active (running) since Mit 2016-06-08 23:01:46 CEST; 1min 52s ago
                     Docs: man:bluetoothd(8)
                 Main PID: 1007 (bluetoothd)
                   Status: "Running"
                   CGroup: /system.slice/bluetooth.service
                           `-1007 /usr/lib/bluetooth/bluetoothd
                Jun 08 23:01:46 Rasp-Radio-Garage bluetoothd[1007]: Bluetooth daemon 5.23
                Jun 08 23:01:46 Rasp-Radio-Garage bluetoothd[1007]: Starting SDP server
                Jun 08 23:01:46 Rasp-Radio-Garage systemd[1]: Started Bluetooth service.
                Jun 08 23:01:46 Rasp-Radio-Garage bluetoothd[1007]: Bluetooth management interface 1.10 initialized
                Jun 08 23:01:46 Rasp-Radio-Garage bluetoothd[1007]: Sap driver initialization failed.
                Jun 08 23:01:46 Rasp-Radio-Garage bluetoothd[1007]: sap-server: Operation not permitted (1)
                • ruhr70
                  Das passt schon.
                  Ich werde aus dem ersten Fehler nach "Start Skript" nicht schlau. Module Debug?
                  Als ob noble ein Problem hat.
                  Node Version ist 4.x?
                  Ich kann leider erst am Wochenende mir die Details ansehen
                  • ruhr70
                    Das passt schon bezog sich auf deinen Post davor 🙂
                      root@Rasp-Radio-Garage:~# node -v
                      v4.4.5
                        soll ich alles, inklusive, raspbian nochmals installieren?
                          hat das was damit zu tun, dass ich "RASPBIAN JESSIE LITE" als System habe?
                          • ruhr70
                            Per Ferndiagnose gerade schwierig zu beurteilen. Wenn Du die Zeit hast 😉 Vieleicht erst einmal als Standalone Version und nicht als Slave.
                            Node.js 4-4.5 ist auch gut
                            Auf dem Raspberry Pi 3 läuft es eigentlich problemlos.
                            • derAuge
                              derAuge last edited by
                              Nein
                              Das passt schon.
                              Du mußte nur die bt-tools mit installieren
                              Gesendet von meinem SM-T530 mit Tapatalk
                                läuft das skript auf dem raspi3?
                                • lobomau
                                  lobomau last edited by
                                  @Homoran:
                                  läuft das skript auf dem raspi3? `
                                  Definitiv ja! Hab es laufen. Wie beschrieben installiert, aber nix Slave oder raspbian Lite.
                                    ok… nur LOL... habe nur iobroker neu installiert und NICHT als client konfiguriert.. jetzt läuft das script
                                    jetzt habe ich iobroker gestoppt, iobroker setup custom.... siehe da, jetzt funktioniert das script auch als client iobroker und die werte werden alle eingetragen.
                                    strange.. .ist aber so
                                      die Frage war an rascal gerichtet!
                                      Ob er das skript auf seinem neuen RasPi3 laufen hat, der als slave eingebunden ist.
                                      Und nicht auf seinem Master!
                                      Natürlich läuft es auf EINEM Raspi3, dafür ist es ja, und dafür hat rascal ja auch einen gekauft.
                                      Rainer
                                      • ruhr70
                                        Schön, dass es nun klappt 🙂
                                        Den Schritt, den Pi3 als Slave an meine Hauptinstallation anzubinden steht mir noch bevor. Wenn ich dazu Fragen habe, weiß ich jetzt an wen ich mich wenden kann 😉
                                          ich helfe gerne wenn ich kann…. wild Befehle in die Console klopfen und hoffen, dass irgendwas davon hilft ist meine Spezialität.
                                          Danke nochmals für Eure Hilfe und Geduld, gn8
                                          • lobomau
                                            Wie funktioniert da genau mit dem löschen und auf blacklist setzen?
                                            Habe einfach in den Objekten den Haken auf true gestellt. Sollte das device jetzt aus der Aufstellung verschwinden? Tut es nicht.
                                            254
                                            57806
