    4. Material Design Widgets: Input, Select, Autocompl.
    • 0
      0018 @Scrounger last edited by
      @Scrounger sagte in Material Design Widgets: Input, Select, Autocompl.:
      @0018
      Unter CSS Test auf zentrieren stellen
      Wenn du im Reiter "CSS Font & Text" unter CSS "text-align = center" meinst, funktioniert es leider nicht.
      Hier mein Widget:
      [{"tpl":"tplVis-materialdesign-Input","data":{"oid":"javascript.0.Rolladen.Bad.Timer.Hoch_Uhrzeit_WE","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","inputType":"time","inputLayout":"outlined-rounded","showInputMessageAlways":false,"showInputCounter":false,"clearIconShow":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"inputMaxLength":"","inputMask":"","inputLayoutBackgroundColor":"#37474F","inputLayoutBackgroundColorHover":"","inputLayoutBorderColor":"#63a4ff","inputLayoutBorderColorHover":"#FFCA28","inputTextColor":"#ffffff","inputLabelText":"","inputMessage":"","inputLayoutBorderColorSelected":""},"style":{"left":"300px","top":"130px","width":"120px","height":"40px","z-index":"10","text-align":"center"},"widgetSet":"materialdesign"}]
      • Scrounger
        Scrounger Developer @0018 last edited by
        @0018 #
        Dann geht es nur mit css klasse überschreiben.
        Alternativ kannst auch nen Issue auf github erstellen, dann bau ich die funktion mal in den editor ein.
        0 3 Replies Last reply Reply Quote 0
        • 0
          @Scrounger
          Danke! Da ich keinen Plan von CSS habe, könntest du mir vielleicht den Code dazu nennen?
          • 0
            Erledigt, GIT
            Kannst du mir als workaraound evtl den CSS Code zur Verfügung stellen, damit ich meine Vis schon mal fertig machen kann?
            • 0
              Kannst du mir vielleicht beschreiben wie ich den css-code überschreiben kann?
              • O
                oxident last edited by oxident
                Hi!
                Kann man beim Select-Widget irgendwie den Knopf zum Löschen des Wertes ("X") ausblenden? Habe das Problem, dass sonst der DP immer auf einen leeren String gesetzt werden würde.
                Sorry, erledigt. Unter "Symbole" gibt es die Option "Symbol zum Löschen des Textes anzeigen".
                  Coffeelover last edited by
                  wie muss ich das Select Widget für Datumswerte konfigurieren?
                  VG
                  • 0
                    0018 last edited by
                    @Scrounger ist es möglich das du mir den css code nennst um die Uhrzeit im widget zu zentrieren?
                    • Scrounger
                      @0018 sagte in Material Design Widgets: Input, Select, Autocompl.:
                      .v-select__selection.v-select__selection--comma{
                          width: 100%;
                          text-align: center;
                      0 1 Reply Last reply Reply Quote 0
                        Coffeelover @Coffeelover last edited by
                        @Coffeelover sagte in Material Design Widgets: Input, Select, Autocompl.:
                        Ich antworte mal selbst: Im Prinzip ist die Einstellung total banal. Während ich in Android (Fully) dann auch den Datumsdialog bekomme, muss ich am WIN-Rechner die Infos selbst eintippen.
                        • 0
                          width: 100%;
                          text-align: center;
                          @Scrounger Danke dir!
                          Kann es sein das du hier auf das select-widget den Code geschrieben hast? Es funktioniert leider nicht. Ich verwende das Input widget mit dem InputType = time, vielleicht liegt es daran?
                          ich hab mal ein wenig rum probiert und z.B:
                          .v-text-field__slot{
                              text-align: center;
                          verwendet, aber keine Änderung. Wie müsste die richtige Zuweisung sein?
                          • 0
                            0018 last edited by
                            @Scrounger ?
                              saeft_2003 Most Active last edited by
                              In dem roten Bereich sieht man ganz leicht eine schwarze Uhr. Diese hätte ich gerne in der Farbe weiß.
                              Kann mir einer von euch sagen wo man die Farbe umstellen kann, ich habe lange gesucht aber es nicht gefunden 😞
                              • 0
                                0018 @0018 last edited by
                                @Scrounger könntest du dir den Code evtl nochmal ansehen?
                                • Scrounger
                                  @0018
                                  .v-text-field__slot > input {
                                      text-align: center;
                                  • 0
                                    @Scrounger
                                    danke das hat soweit geklappt. Allerdings funktioniert das nur auf meinem Win10 Rechner unter Chrome. Auf meinem Andoid-Tablet im Fully-Browser hat das leider keine Änderung gebracht. Hast du eine Idee warum das im Fully nicht klappt?
                                      saeft_2003 Most Active @saeft_2003 last edited by
                                      @saeft_2003 sagte in Material Design Widgets: Input, Select, Autocompl.:
                                      @Scrounger
                                      weißt du das vielleicht?
                                      • Scrounger
                                        @Scrounger
                                            text-align: center !important;
                                        müsste aber eigentlich gehen.
                                        @Scrounger
                                        Ne leider nicht, wie hast du denn diese Uhr da rein bekommen?
                                        C S 0 3 Replies Last reply Reply Quote 0
                                          Conquest @Scrounger last edited by Conquest
                                          Hab bei mir auch diese Uhr. Scheint mit einem Update von Chrome gekommen zu sein. Kann man das entfernen?
                                          Gerade nachgesehen hängt definitiv an Chrome bei Firefox ist keine Uhr.
                                            saeft_2003 Most Active @Scrounger last edited by saeft_2003
                                            @Scrounger
                                            @Scrounger
                                            Wenn ich das wüsste, ist die "Uhr" kein Bestandteil von deinem Input widget?
                                            Edit: Sorry habe gerade erst die Aufklärung von conquest gelesen. Würde mich aber auch interessieren ob man die Uhr entfernen kann, ich nutze für meine VIS auch chrome.
                                            vis
                                            38
                                            147
                                            19819
