    5. Blockly - Wo liegt der Fehler
    • opossum
      opossum @Wszene last edited by opossum
      @Wszene sagte in Blockly - Wo liegt der Fehler:
      @opossum
      Kannst du mir mal dein dein Widget exportieren?
      Hier mal der Export, bitte vor dem Import Deine richtige VIN reinsetzen, ich habe meine unkenntlich gemacht.
      [{"tpl":"tplValueListHtml8","data":{"oid":"vw-connect.0.TMBLK7xxx.status.data08.field01.value","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","count":"3","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"value0":"","value1":" offen","style1":"color: red","style0":"","html_prepend":"<div style=\"color: white; float:left;font-size: 100%;text-align: left;\">Tür vorn links  </div>","test_list":"","style2":"color: white","value2":" zentral verriegelt","value3":"nicht gesichert","style3":"color: red"},"style":{"left":"254px","top":"766px","width":"270px","height":"36px","text-align":"right","font-weight":"bold","font-size":"medium","line-height":"2"},"widgetSet":"basic"}]
      • opossum
        opossum last edited by opossum
        Hallo, @Wszene
        Bei mir hat der Datenpunkt vw-connect.0.TMBLK7xxxx.status.data08.field01.value das Format " gemischt", auch bei mir ändert das Script den Zielwert nicht.
        • Wszene
          Wszene last edited by Wszene
          @opossum
          Danke das funktioniert
          Ich habe aber keinen Unterschied gefunden 🙄
          Kann ich irgendwie die Aktualisierungszeit des Adapters anpassen?
          Leider braucht der Adapter zulange für die Aktualisierung weil ich würde mir gern eine Telegram schicken lassen wenn die Fenster noch offen sind und das Auto verriegelt ist aber das macht nicht viel sind wenn der Adapter erst nach Ewigkeiten aktualisiert
          PS:
          Datenpunkt vw-connect.0.TMBLK7NS8J8021207.status.data08.field01.value das Format " gemischt"
          Das ist wie bei mir
          opossum 1 Reply Last reply Reply Quote 0
          • opossum
            Hallo, @Wszene ,
            sorry, hatte gesagt, dass das bei meinem Script nicht ändert. Stimmte so nicht. Mein Script ändert den Datenpunkt. Habe den aber unter 0_userdata.0.Tuer-vorn-links liegen. Da wird dann auch der Status sauber geändert. Hier mal mein Script:
            Du hast als Befehl "steuere" drin, versuche mal mit "aktualisiere".
              Jan1 @opossum last edited by
              @opossum
              Steuere ist mächtiger als aktualisieren, wobei hier aktualisieren reichen würde. Steuern hat im Gegensatz zu aktualisieren quasi ein Enter mit drin. Beim Aktualisieren wird nur geschrieben, sonst nichts.
              Möchte man aber gleich auf den im Trigger verwendeten DP in der FALLS reagieren, ist es ratsam dort eben auch Wert aus den Triggerblöcken zu verwenden. Erstens geht das schneller beim Klicken und es hat keine Laufzeit bedingte Fehler mit drin.
              • opossum
                Hallo, @Jan1 ,
                jetzt habe ich das gerafft, ist das so korrekt?
                • opossum
                  @opossum
                  Ich habe das in den Einstellungen des Adapters auf 15 Minuten stehen:
                  Wszene 1 Reply Last reply Reply Quote 0
                    @opossum
                    nein, aus den Triggerblöcken einfach" Wert" verwenden
                    • Wszene
                      Wszene @opossum last edited by
                      @opossum sagte in Blockly - Wo liegt der Fehler:
                      @opossum
                      Dort habe ich sogar auf 1min runter gestellt aber ohne Erfolg
                      • opossum
                        Hallo, @Wszene ,
                        die Frage wäre, ob der Server die minütliche Anfrage gestattet oder ob er diese Anfrage schon als "Angriff" wertet. Da habe ich keine Ahnung, wie klein das Abfrageintervall sein darf.
                        • opossum
                          Hallo,@Wszene ,
                          habe jetzt noch einmal getestet. Mein Script ändert den Datenpunkt 0_userdata.0.Tuer-vorn-links jetzt sauber bei Änderung des Datenpunktes vw-connect.0.TMBLK7NSxxx.status.data08.field01.value. Es sieht jetzt so aus:
                          (Die Änderung, die @Jan1 empfohlen hat, muss ich mir erst mal in Ruhe anschauen).
                          blockly
                          973
