      deMarvin @simatec last edited by deMarvin
      @simatec
      Für mysql hat auch jeder die Rechte zum ausführen:
      pi@iobroker:~ $ ls -la /usr/bin/mysql
      -rwxr-xr-x 1 root root 3692872 Feb  2 14:33 /usr/bin/mysql
      Alle Rechte was mysql executables betrifft:
      pi@iobroker:~ $ ls -la /usr/bin/ | grep mysql
      lrwxrwxrwx  1 root root           5 Feb  2 14:33 mariadb -> mysql
      lrwxrwxrwx  1 root root          10 Feb  2 14:33 mariadb-check -> mysqlcheck
      -rwxr-xr-x  1 root root        1446 Feb  2 14:33 msql2mysql
      -rwxr-xr-x  1 root root     3692872 Feb  2 14:33 mysql
      -rwxr-xr-x  1 root root      111922 Feb  2 14:33 mysqlaccess
      -rwxr-xr-x  1 root root     3556544 Feb  2 14:33 mysqladmin
      lrwxrwxrwx  1 root root          10 Feb  2 14:33 mysqlanalyze -> mysqlcheck
      -rwxr-xr-x  1 root root     3738136 Feb  2 14:33 mysqlbinlog
      -rwxr-xr-x  1 root root     3520668 Feb  2 14:33 mysqlcheck
      -rwxr-xr-x  1 root root        4217 Feb  2 14:33 mysql_convert_table_format
      -rwxr-xr-x  1 root root       24714 Feb  2 14:33 mysqld_multi
      -rwxr-xr-x  1 root root       30290 Feb  2 14:33 mysqld_safe
      -rwxr-xr-x  1 root root     3263360 Feb  2 14:33 mysqld_safe_helper
      -rwxr-xr-x  1 root root     3593164 Feb  2 14:33 mysqldump
      -rwxr-xr-x  1 root root        8242 Feb  2 14:33 mysqldumpslow
      -rwxr-xr-x  1 root root    15645464 Feb  2 14:33 mysql_embedded
      -rwxr-xr-x  1 root root        3290 Feb  2 14:33 mysql_find_rows
      -rwxr-xr-x  1 root root        1250 Feb  2 14:33 mysql_fix_extensions
      -rwxr-xr-x  1 root root       34942 Feb  2 14:33 mysqlhotcopy
      -rwxr-xr-x  1 root root     3511772 Feb  2 14:33 mysqlimport
      -rwxr-xr-x  1 root root       19839 Feb  2 14:33 mysql_install_db
      lrwxrwxrwx  1 root root          10 Feb  2 14:33 mysqloptimize -> mysqlcheck
      -rwxr-xr-x  1 root root     3301148 Feb  2 14:33 mysql_plugin
      lrwxrwxrwx  1 root root          10 Feb  2 14:33 mysqlrepair -> mysqlcheck
      -rwxr-xr-x  1 root root       51235 Jan 29 06:38 mysqlreport
      -rwxr-xr-x  1 root root       12527 Feb  2 14:33 mysql_secure_installation
      -rwxr-xr-x  1 root root       17482 Feb  2 14:33 mysql_setpermission
      -rwxr-xr-x  1 root root     3510828 Feb  2 14:33 mysqlshow
      -rwxr-xr-x  1 root root     3529044 Feb  2 14:33 mysqlslap
      -rwxr-xr-x  1 root root     3304956 Feb  2 14:33 mysql_tzinfo_to_sql
      -rwxr-xr-x  1 root root     3373796 Feb  2 14:33 mysql_upgrade
      -rwxr-xr-x  1 root root     3292456 Feb  2 14:33 mysql_waitpid
      -rwxr-xr-x  1 root root        7878 Feb  2 14:33 wsrep_sst_mysqldump
      simatec 2 Replies Last reply Reply Quote 0
      • simatec
        simatec Developer Most Active @deMarvin last edited by
        @deMarvin
        Ich denke da muss ich etwas umbauen ... Hatte ich beim Backup damals schon gemacht, aber beim Restore bisher nicht, da noch keine Probleme hatte.
        Wird in der nächsten Version sein ... dann kannst du das nochmal testen
        • simatec
          @deMarvin
          habe da mal was zum testen für dich geändert ...
          Versuche mal bitte mit der Version 1.5.9 aus dem Githublink.
          https://github.com/simatec/ioBroker.backitup/tarball/dev
            @simatec
            Immer noch der gleiche Fehler.
            Mir ist noch ein Bug aufgefallen. Wenn der Restore nicht funktioniert bleibt eine mysql_restore_backupiobroker.sql über, und Backitup findet keine Backups mehr. Erst wieder wenn man die Datei löscht.
            • simatec
              @deMarvin
              Hast du nach der Installation über Github einen Upload gemacht und im Anschluss neugestartet?
                @simatec
                Ja, also hab's mehrfach getestet, auch den fix nochmal laufen gelassen, funktioniert nach wie vor nicht.
                • simatec
                  @deMarvin
                  Welche Version hast du installiert?
                  1.5.8?
                    @simatec
                    Nein, die 1.5.9
                    • simatec
                      @deMarvin
                      Was kommt für eine Fehlermeldung?
                      Bitte poste mal den Log aus dem WebIf vom Backitup Restore
                        @simatec
                        Log Backitup Restore:
                        [DEBUG] [mysql] Start mysql Restore ...
                        [ERROR] [mysql] Error: EPERM: operation not permitted, utime '/opt/iobroker/backups/mysql_restore_backupiobroker.sql'
                        [ERROR] [mysql] mysql Restore not completed
                        [EXIT] undefined **** Restore completed successfully!! ****
                        The log can be closed ...
                        backitup.0	2020-06-12 11:35:56.869	info	(20101) [iobroker] backup was activated at 04:00 every 1 day(s)
                        backitup.0	2020-06-12 11:35:56.841	warn	(20101) Cannot read log file: ReferenceError: config is not defined
                        backitup.0	2020-06-12 11:35:56.836	debug	(20101) [EXIT] undefined
                        backitup.0	2020-06-12 11:35:56.835	error	(20101) [ERROR] [mysql] mysql Restore not completed
                        backitup.0	2020-06-12 11:35:56.834	error	(20101) [ERROR] [mysql] Error: EPERM: operation not permitted, utime '/opt/iobroker/backups/mysql_restore_backupiobroker.sql'
                        backitup.0	2020-06-12 11:35:56.832	debug	(20101) [DEBUG] [mysql] Start mysql Restore ...
                        backitup.0	2020-06-12 11:35:56.826	debug	(20101) Printing logs of previous backup
                        backitup.0	2020-06-12 11:35:56.793	info	(20101) starting. Version 1.5.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.18.0, js-controller: 3.1.4
                        simatec Thomas Braun 3 Replies Last reply Reply Quote 0
                        • simatec
                          @deMarvin
                          Du hast keine Zugriffsrechte auf das mysql backup
                          • simatec
                            @deMarvin
                            Von welchem System gast du dieses Backup?
                            Ist das noch eine ältere Iobroker Installation, wo iobroker noch als root lief?
                              Thomas Braun Most Active @deMarvin last edited by Thomas Braun
                              @deMarvin sagte in Test Adapter Backitup v1.5.x:
                              Wie sehen denn die Rechte an der Datei aus?
                              ls -la /opt/iobroker/backups/mysql_restore_backupiobroker.sql
                                @simatec @Thomas-Braun
                                Doch ich habe Rechte an der Datei
                                pi@iobroker:~ $ ls -la /opt/iobroker/backups/mysql_restore_backupiobroker.sql
                                -rwxrwxrwx 1 root root 36787597 Jun 12 11:35 /opt/iobroker/backups/mysql_restore_backupiobroker.sql
                                @simatec said in Test Adapter Backitup v1.5.x:
                                @deMarvin
                                Nein, iobroker lief bei mir nie als Root
                                • simatec
                                  @deMarvin
                                  Ich schaue mit da mal die Tage den Installer bzw. auch den Fixer an.
                                  mysqldump ist da definitiv drin, aber für den Restore wird mysql direkt benötigt und da muss ich mal schauen, ob da alle Rechte für den User iobroker passen
                                  • simatec
                                    @deMarvin
                                    Noch ne andere Frage ... wie sieht denn deine Installation von mysql aus?
                                    Hast du User und dB bereits wieder angelegt und passen die Daten der Config für backitup?
                                    Mich wundert dein Fehler etwas ...
                                      @simatec
                                      Ja habe alles wie vorher angelegt, also gleicher User mit gleichem PW (ist ja nur für den Adapter wichtig) und die DB hat auch den gleichen Namen.
                                      • simatec
                                        @deMarvin
                                        Kannst du bitte trotzdem mal versuchen, ein backup, welches mit dem neuen System gemacht wurde wiederherzustellen?
                                          @simatec
                                          Mit Backup des neuen Systems kommt der gleiche Fehler.
                                          • simatec
                                            @deMarvin
                                            Mit 1.5.8 und 1.5.9?
                                            1.0k
                                            170
                                            2780
                                            2346092
