    4. MQTT String aufteilen
      albi_63 last edited by
      Hallo paul
      Besten Dank für dein script. Ich habe dieses in JS implementiert, allerdings sehe ich im IoBroker keine weiteren Datenpunkte und das script sendet mir fortlaufend falsche Werte:
      22:00:15.124	warn	javascript.0 (768) at Object.<anonymous> (script.js.common.Wassertank.WemosD1:17:4)
      22:00:15.128	warn	javascript.0 (768) at Object.<anonymous> (script.js.common.Wassertank.WemosD1:19:4)
      22:00:15.133	warn	javascript.0 (768) at Object.<anonymous> (script.js.common.Wassertank.WemosD1:21:4)
      22:00:15.138	warn	javascript.0 (768) at Object.<anonymous> (script.js.common.Wassertank.WemosD1:23:4)
      22:00:25.118	warn	javascript.0 (768) at Object.<anonymous> (script.js.common.Wassertank.WemosD1:17:4)
      22:00:25.126	warn	javascript.0 (768) at Object.<anonymous> (script.js.common.Wassertank.WemosD1:19:4)
      22:00:25.140	warn	javascript.0 (768) at Object.<anonymous> (script.js.common.Wassertank.WemosD1:21:4)
      22:00:25.150	warn	javascript.0 (768) at Object.<anonymous> (script.js.common.Wassertank.WemosD1:23:4)
      22:00:35.159	warn	javascript.0 (768) at Object.<anonymous> (script.js.common.Wassertank.WemosD1:17:4)
      22:00:35.167	warn	javascript.0 (768) at Object.<anonymous> (script.js.common.Wassertank.WemosD1:19:4)
      22:00:35.175	warn	javascript.0 (768) at Object.<anonymous> (script.js.common.Wassertank.WemosD1:21:4)
      22:00:35.178	warn	javascript.0 (768) at Object.<anonymous> (script.js.common.Wassertank.WemosD1:23:4)
      22:00:45.126	warn	javascript.0 (768) at Object.<anonymous> (script.js.common.Wassertank.WemosD1:17:4)
      22:00:45.132	warn	javascript.0 (768) at Object.<anonymous> (script.js.common.Wassertank.WemosD1:19:4)
      22:00:45.137	warn	javascript.0 (768) at Object.<anonymous> (script.js.common.Wassertank.WemosD1:21:4)
      22:00:45.142	warn	javascript.0 (768) at Object.<anonymous> (script.js.common.Wassertank.WemosD1:23:4)
      22:00:55.101	warn	javascript.0 (768) at Object.<anonymous> (script.js.common.Wassertank.WemosD1:17:4)
      22:00:55.108	warn	javascript.0 (768) at Object.<anonymous> (script.js.common.Wassertank.WemosD1:19:4)
      22:00:55.114	warn	javascript.0 (768) at Object.<anonymous> (script.js.common.Wassertank.WemosD1:21:4)
      22:00:55.120	warn	javascript.0 (768) at Object.<anonymous> (script.js.common.Wassertank.WemosD1:23:4)
      Das sind die aktuellen Werte:
      Leider stehe ich hier voll an......
      Was muss ich anpassen damit das script funktioniert?
      Danke dir
        paul53 @albi_63 last edited by
        @albi_63 sagte:
        Du must die 4 Datenpunkte erstellen (z.B. manuell im Tab "Objekte" unter "0_userdata.0") und die IDs dieser Datenpunkte oben im Script eintragen.
          Hoi Paul
          Bitte entschuldige aber ich komme nicht weiter.
          Bitte mache mir ein Beispiel für einen Datenpunkt.
          Ich bin noch am Anfänger....😧
            Hoi Paul
            Jetzt habe ich es geschnallt, hat ein weilchen gedauert. Habe null Ahnung von JS.......
            Hier ein Datenpunkt:
            Vielen Dank dir.
              Jan.S100 @albi_63 last edited by
              @albi_63 Hallo.
              Benutzt du eigentlich nur Sonoff Geräte?
              Wenn ja probiere Mal den Sonoff Adapter.
              Aber bitte darauf achten, das entweder der MQTT Adapter läuft oder der Sonoff Adapter.
                Hallo Jan
                Ich habe ein Wemos D1 mit Sonos geflasht auf welchem ich die Zustände des Wassertanks abfrage, ansonsten habe ich gar keine Sonosgeräte am laufen.
                Gruss Albi
                  Jan.S100 @albi_63 last edited by Jan.S100
                  @albi_63 Dann solltest du mit dem Sonoff Adapter besser zu recht kommen.
                  Hast du es schon ausprobiert?
                  So sieht die Datenstruktur aus.
                    Hallo Jan
                    Wenn ich die Sonoff Instanz starte bleibt die Rot. Wenn ich den Port von 1883 auf 1884 ändere und in den MQTT Einstellungungen des NodeMCU die Einstellungen vom Port und Passwort ändere geht der Adapter auf grün, allerdings sehe ich unter Objekte nur:
                    und keine weiteren Datenpunkte.
                    Temperatur, Distanz , Humidity ect nicht vorhanden.
                    Das kommt vom Nodemcu:
                    Was mache ich falsch?
                    Brauche ich die MQTT Instanz nicht mehr?
                      Hallo Paul
                      Wie definiere ich dein Script wenn ich zwei Temperatursensoren am laufen habe?
                      Ich habe da was versucht allerdings geht das in die Hose....
                      const idSensor = 'mqtt.0.Smarthome.Wassertank.tele.SENSOR';
                      // const idDSTemp1 = '0_userdata.0.Objekte.Wassertank.Temp_DS18B20-1';
                      // const idDSTemp2 = '0_userdata.0.Objekte.Wassertank.Temp_DS18B20-2';
                      const idDHTemp = '0_userdata.0.Objekte.Wassertank.idDHTemp';
                      const idDHHum  = '0_userdata.0.Objekte.Wassertank.idDSTemp';
                      const idDist = '0_userdata.0.Objekte.Wassertank.SR04_Distance';
                      on(idSensor, function(dp) { // triggert bei Wertänderung
                         let obj = JSON.parse(dp.state.val);
                        // setState(idDSTemp1, obj.DS18B20-1.Temperature, true);
                         // setState(idDSTemp2, obj.DS18B20-2.Temperature, true);
                         setState(idDHTemp, obj.DHT11.Temperature, true);
                         setState(idDHHum, obj.DHT11.Humidity, true);
                         setState(idDist, obj.SR04.Distance, true);
                      Der String kommt folgendermassen an:
                      {"Time":"2020-06-12T18:56:00","DS18B20-1":{"Id":"01192A390A6C","Temperature":24.8},"DS18B20-2":{"Id":"0301A279895F","Temperature":22.4},"DHT11":{"Temperature":27.2,"Humidity":44.0},"SR04":{"Distance":30.000},"TempUnit":"C"}
                      Danke für dein Feedback
                        @albi_63 sagte:
                        DS18B20-1 und DS18B20-2 enthalten unzulässige Zeichen (-) für die Punkt-Notation. Der Zugriff muss dann anders erfolgen:
                           setState(idDSTemp1, obj['DS18B20-1'].Temperature, true);
                           setState(idDSTemp2, obj['DS18B20-2'].Temperature, true);
                          Hallo Paul,
                          Ich danke dir vielmals. Es klappt wunderbar.😊
                            @albi_63
                            Alle drei Sachen angehakt?
                            Du kannst nur den Sonoff oder den MQTT Adapter laufen lassen.
                            Sonst kommen sie sich ins Gehege.
                            Oder wie du es gemacht hast, die Ports zu ändern.
                              @Jan-S100
                              Hy Jan
                              Hatte alles schon so angeklickt wie du mir gesendet hast. Bekomme keine Daten.
                              Kann es an der alten Firmware "Sonoff-Tasmota 6.7.1" liegen? Wenn ich die aktuellste mit "8.x.x" aufspiele, bekomme ich meinen SR04 Sensor nicht mehr zur Auswahl. Allerdings habe ich mit der neusten Firmware jetzt noch nicht getestet, ob mir die Daten übermittelt werden.
                              J harrym 2 Replies Last reply Reply Quote 0
                                @albi_63 Tja, da müssen wohl die Spezialisten ran. 🤔 So tief stecke ich dann doch nicht in der Materie.
                                • harrym
                                  harrym @albi_63 last edited by
                                  @albi_63 also 8.3.1.3 ist derzeit die aktuelleste (abseits von stable) .... und von 6.x auf 8.x ist ein großer sprung. andererseits werden da auch viele fehler behoben 😉
                                    @harrym
                                    Hy harrim
                                    Danke für dein Feedback.
                                    Ich hatte die 8.3.1 zu Anfang aufgespielt, bekam allerdings nicht mehr meinen Sensor SR04, danach ging ich Version um Version zurück bis mein Sensor wieder auftauchte und das bei der 6.7.1.
                                    Wenn ich jetzt die aktuellste wieder aufspiele funktioniert es vielleicht mit dem Sonos. Allerdings bringt mir das nichts, da ja die Werte vom SR04 nicht abesetzt werden können. Somit arbeite ich mit MQTT und dem Script von Paul. Das funktioniert soweit.
                                    Danke euch allen für die Unterstützung.
                                    blockly javascript
                                    1350
