    4. Test Adapter Gartenbewässerung v0.0.x
      sigi234 Forum Testing Most Active @tombox last edited by
      @tombox
      Hallo, kannst du das Date Format ändern?
      https://forum.iobroker.net/topic/22301/neuer-adapter-linkeddevices/219
        tombox @sigi234 last edited by
        @sigi234 habe mal für alle timestamps hinzugefügt
          @tombox sagte in Test Adapter Gartenbewässerung v0.0.x:
          Hm, sehe es nur bei 3 DP
          • wawyo
            wawyo Developer last edited by
            Ergänzung für tombox (alle Variablen sind auf Englisch):
            async checkautomaticTimer() {
                    let automatic = [];
                    automatic = [
                        ["starttime1", this.config.starttime1_enable, this.config.starttime1, this.config.starttime1duration, this.config.starttime1tempforecast, this.config.starttime1rainforecast, this.config.starttime1moistureforecast],
                        ["starttime2", this.config.starttime2_enable, this.config.starttime2, this.config.starttime2duration, this.config.starttime2tempforecast, this.config.starttime2rainforecast, this.config.starttime2moistureforecast],
                        ["starttime3", this.config.starttime3_enable, this.config.starttime3, this.config.starttime3duration, this.config.starttime3tempforecast, this.config.starttime3rainforecast, this.config.starttime3moistureforecast]
                    for (let i = 0; i <= automatic.length - 1; i++) {
                        if (this.automatic[i][1] && this.automatic[i][0].startsWith("starttime")) {
                            let nextautomatic = this.gettimediff(this.automatic[i][2]);
                            this.setState("state." + this.automatic[i][0] + ".still", this.convertseconds(nextautomatic));
                            this.setState("state." + this.automatic[i][0] + ".progress", 100 - ((nextautomatic / 86400) * 100).toFixed(2));
                            this.setState("state." + this.automatic[i][0] + ".stillseconds", nextautomatic);
                        } else if (!this.automatic[i][1]) {
                            this.setState("state." + this.automatic[i][0] + ".still", "--:--:--");
                            this.setState("state." + this.automatic[i][0] + ".progress", "00");
                            this.setState("state." + this.automatic[i][0] + ".stillseconds", "00");
                gettimediff(datetime) {
                    var tempnow = Date();
                    var pattern = /(\d{2})\:(\d{2})\:(\d{2})/;
                    var convertednow = tempnow.replace(pattern, "" + datetime + ":00");
                    var convertednowSec = new Date(convertednow).getTime();
                    var nowtemp = new Date();
                    var now = nowtemp.getTime();
                    if (isNaN(convertednowSec)) {
                        return "";
                    if (convertednowSec < now) {
                        var milisec_diff = (convertednowSec + (24 * 60 * 60 * 1000)) - now;
                    } else {
                        var milisec_diff = convertednowSec - now;
                    var date_diff = (milisec_diff / 1000).toFixed(0);
                    return date_diff;
                convertseconds(totalSeconds) {
                    var hours = Math.floor(totalSeconds / 3600);
                    var minutes = Math.floor((totalSeconds - (hours * 3600)) / 60);
                    var seconds = (totalSeconds - (hours * 3600) - (minutes * 60)).toFixed(0);
                    var result = (hours < 10 ? "0" + hours : hours);
                    result += ":" + (minutes < 10 ? "0" + minutes : minutes);
                    result += ":" + (seconds < 10 ? "0" + seconds : seconds);
                    return result;
              tombox @wawyo last edited by
              @wawyo was macht das genau?
              wawyo 1 Reply Last reply Reply Quote 0
              • wawyo
                wawyo Developer @tombox last edited by wawyo
                @tombox
                Der Code ist zum berechnen alle Restzeiten bis zum nächsten automatische Start.
                Ich habe die Zeiteinstellungen zum Automatikbetrieb ergänzt.
                20200609_213518_edited.mp4
                  f0rd42 last edited by
                  Mal ne blöde Frage:
                  So wie es aussieht, habt ihr entweder alle eine Pumpe oder allgemein genügend Druck um alle Kreise gleichzeitig betreiben zu können. Das ist bei mir leider nicht so!
                  Gibt es irgendwie eine Möglichkeit, dass die Ventile nur nacheinander abgearbeitet werden oder habe ich hier was übersehen?
                    mameier1234 @f0rd42 last edited by
                    @f0rd42 Das ist doch genau die Funktion des Adapters.. In einer Instanz werden die einzelnen Ventile nacheinander abgearbeitet...
                    Einige wollen hier genau das Gegenteil, das geht aber noch nicht...
                      f0rd42 @mameier1234 last edited by
                      @mameier1234 ok, dann war / bin ich blind 🙂
                      Danke, ich tüftele mal weiter
                        Gerni last edited by Gerni
                        Hi. Erstmal Danke für die Arbeit und den Adapter.
                        Vermutlich blöde Frage aber was genau muss ich denn angeben um Ventil eins, was ein sonoff 4CH Pro wäre, schalten zu können. In Log steht zwar, dass Ventil 1 geschaltet wird, ist es aber in der 4CH Konfig (Tasmo) nicht. "4CH Pro POWER1" reicht vermutlich nicht
                        EDIT:
                        Hab es: "sonoff.0.4CH Pro.POWER1" und läuft. Super Geil!!!!
                          Habe dann doch mal ne Frage.
                          Zu Ermittlung von Wetterdaten nutze ich den wetter.com Adapter. Der liefert auch Infos. Zu verschiedenen Tagen usw.
                          Nun möchte ich an jedem Tag der Woche Sprinkler aktivieren jedoch nicht wenn es zB 5 mm regnet.
                          Jetzt kann ich hier im Adapter Regenwert für heute und morgen hinterlegen. Und was ist Mittwoch, Donnerstag usw?
                          Oder habe ich die passenden Datenpunkte nicht vor Augen?
                          Wie holt ihr euch die Wetterdaten und bindet sie in den Adapter ein?
                          Stefan
                            f0rd42 @Gerni last edited by
                            @Gerni Die sind direkt im Adapter:
                              Gerni @f0rd42 last edited by Gerni
                              @f0rd42 ist Nextdays Day 1 also heute. Wenn dem so ist, Asche über mein haupt.
                              Wenn also morgen geprüft wird wäre Day 1 dann tatsächlich Dienstag? Ich dachte Day 1 ist immer Montag, Day 2 Dienstag usw.
                              Dann würde doch Day 2 immer Dienstag sein und nie Mittwoch wenn der Wert hier im Adapter für Folgetag steht.
                              Vielleicht schnall ich die Logik auch nicht
                                @Gerni day 1 ist immer heute, day 2 morgen.
                                • AtomicIX
                                  AtomicIX last edited by
                                  Hallo, mag mir bitte einer sagen, wo ich die Links im "daswetter" im Adapter finde? Ich steige da nicht durch. Ich finde im Adapter keine Links
                                    sigi234 Forum Testing Most Active @AtomicIX last edited by sigi234
                                    @AtomicIX sagte in Test Adapter Gartenbewässerung v0.0.x:
                                    https://www.daswetter.com/api/#/login
                                    This adapter reads weather forecast data from DasWetter.com.
                                    You need an account on DasWetter.com. Register at https://www.daswetter.com/api/#/login
                                    The account is for free under certain conditions.
                                    In your account you will find three URL for four different data models:
                                    Forecast for the next 7 days and general information of the day: high and low, wind (symbol and description), Day symbol and weather conditions
                                    detailed information for 5 days and every 3 hours: The general daily information is the following: peak, lows, wind, gusts, Precipitation, relative humidity,
                                    sea level air pressure, snow line, Sunrise and sunset, dates related to the moon, local time
                                    Preview with detailed data every hour (only for the first 2 days, then every 3 hours)
                                    Prediction for 5 days and every 3 hours (in JSON format)
                                    All four models are implemented and one should be used at least.
                                    In settings URL like http://api.daswetter.com/index.php?api_lang=de&localidad=xxxx must be used. Just copy the complete URL from your account.
                                    AtomicIX 1 Reply Last reply Reply Quote 0
                                    • AtomicIX
                                      AtomicIX @sigi234 last edited by
                                      @sigi234 ah, cool, danke.
                                      • JB_Sullivan
                                        JB_Sullivan last edited by
                                        Hat von Euch jemand schon mal so einen Umbau mit einem TFK von INNOGY gemacht? Sind ja eigentlich Baugleich zu Homematic nur das Innogy ein anderes Verschlüsselungsprotokoll verwendet.
                                        Ich habe das nämlich gemacht und trotz 47kOhm Widerstand bekomme ich immer nur ein geschlossen Signal - egal ob trocken oder feucht. Hat jemand einen Tip für mich?
                                        https://homematic-guru.de/homematic-bodenfeuchtesensor-mit-gardena
                                        • AtomicIX
                                          Ich glaube ich bin gerade zu Blöd.
                                          Ich möchte bei mir im Garten den Adapter auf dem Raspberry / iobroker installieren.
                                          Garten-ioBroker
                                          Betriebssystem
                                              linux
                                          Betriebssystem
                                              linux
                                          Architektur
                                              arm
                                          CPUs
                                          Geschwindigkeit
                                              1500 MHz
                                          Modell
                                              ARMv7 Processor rev 3 (v7l)
                                          RAM
                                              3.81 GB
                                          System Betriebszeit
                                              3 T. 01:09:26
                                          Node.js
                                              v10.20.1 (Es gibt eine neuere Version: v10.21.0 - Empfohlene Version v12.18.0)
                                          NPM
                                              6.14.4
                                          Festplatte Größe
                                              116.87 GB
                                          Festplatte frei
                                              114.03 GB
                                          Anzahl der Adapter
                                              296
                                          Zuhause auf meinem Testsystem ist ein Clone des Aktuellen iobroker system. Da läuft der Adapter ohne Probleme. Jetzt im Garrten ( Habe nur Edge Internet verbindung) bekomme ich ihn nicht installiert. Wo ist das Problem? Die systeme sind identisch.
                                          $ ./iobroker url "https://github.com/TA2k/ioBroker.gartenbewaesserung" --debug
                                          install https://github.com/TA2k/ioBroker.gartenbewaesserung/tarball/39c3d009800d7bf4504327002087636619982ce6
                                          NPM version: 6.14.4
                                          npm install https://github.com/TA2k/ioBroker.gartenbewaesserung/tarball/39c3d009800d7bf4504327002087636619982ce6 --loglevel error --prefix "/opt/iobroker" (System call)
                                          npm
                                           ERR! code EINTEGRITY
                                          npm ERR! sha512-cBMXjSW+fjOb4tyaVHuaVE/A5TqkukDWiOfxxAjY+PEqmmBQlLwn+8OzwPiG3brouXKY5Un4pBjAeB6UToXHaQ== integrity checksum failed when using sha512: wanted sha512-cBMXjSW+fjOb4tyaVHuaVE/A5TqkukDWiOfxxAjY+PEqmmBQlLwn+8OzwPiG3brouXKY5Un4pBjAeB6UToXHaQ== but got sha512-HV2uDGzXXVjT2754hSwBxAz1Semt/uato+9tUwWTaRT/hE08zDJ260MZ0hhjkBilSG2vujCGke3LZCgUJTMfQQ==. (52570 bytes)
                                          npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-06-17T14_05_18_802Z-debug.log
                                          ERROR: host.Garten-ioBroker Cannot install https://github.com/TA2k/ioBroker.gartenbewaesserung/tarball/39c3d009800d7bf4504327002087636619982ce6: 1
                                          ERROR: process exited with code 25
                                          • AtomicIX
                                            AtomicIX @AtomicIX last edited by
                                            @AtomicIX ok, es läuft. das Internet war einfach zu langsam 😞
                                            31.7k
                                            79.9k
                                            beregnungssteuerung bewässerung garten gartenbewässerung magnetventil ventil ventile
                                            66
                                            567
                                            109709
