    4. JavaScript
    5. Servicemeldungen - All inclusive für Homematic -
      Knusterus last edited by
      @cash
      So dein Script läuft wirklich prima. Ich habe mir erlaubt die Zeile 1809 leicht zu ändern das die Meldungen im Vis untereinander kommen.
      //Ab hier eigentliches Script
      const SelectorLOWBAT  = $('channel[state.id=hm-rpc.*.0.LOWBAT_ALARM$]');
      const SelectorLOW_BAT  = $('channel[state.id=hm-rpc.*.0.LOW_BAT_ALARM$]');
      const SelectorUNREACH  = $('channel[state.id=hm-rpc.*.0.UNREACH_ALARM$]');
      const SelectorSTICKY_UNREACH  = $('channel[state.id=hm-rpc.*.0.STICKY_UNREACH_ALARM$]');
      const SelectorCONFIG_PENDING  = $('channel[state.id=hm-rpc.*.0.CONFIG_PENDING_ALARM$]');
      const SelectorUPDATE_PENDING  = $('channel[state.id=hm-rpc.*.0.UPDATE_PENDING_ALARM$]');
      const SelectorDEVICE_IN_BOOTLOADER  = $('channel[state.id=hm-rpc.*.0.DEVICE_IN_BOOTLOADER_ALARM$]');
      const SelectorERROR  = $('channel[state.id=hm-rpc.*.1.ERROR$]');
      const SelectorERROR_CODE  = $('channel[state.id=hm-rpc.*.ERROR_CODE$]');
      const SelectorFAULT_REPORTING  = $('channel[state.id=hm-rpc.*.4.FAULT_REPORTING$]');
      const SelectorSABOTAGE  = $('channel[state.id=hm-rpc.*.0.SABOTAGE_ALARM$]');
      const SelectorERROR_NON_FLAT_POSITIONING = $('channel[state.id=hm-rpc.*.0.ERROR_NON_FLAT_POSITIONING_ALARM$]');
      let timer = null;
      let timer_sticky_unreach = null;
      let meldung_alt = [];
      let meldung_neu = [];
      function send_pushover (device, message, titel, prio) {
          //Version V4.01 vom 10.04.19
          let pushover_Instanz;
          if (prio === 0){pushover_Instanz =  pushover_Instanz0;}
          else if (prio == 1){pushover_Instanz =  pushover_Instanz1;}
          else if (prio == 2){pushover_Instanz =  pushover_Instanz2;}
          else {pushover_Instanz =  pushover_Instanz3;}
          sendTo(pushover_Instanz, {
              device: device,
              message: message,
              title: titel,
              priority: prio,
              retry: 60,
              expire: 600,
              html: 1
      function send_telegram (message, user_telegram) {
          sendTo('telegram.0', {
              text: message,
              user: user_telegram,
              parse_mode: 'HTML'
      function send_mail (message) {
          sendTo("email", {
              //from:    "iobroker@mydomain.com",
              //to:      "aabbcc@gmail.com",
              subject: "Servicemeldung",
              text:    message
      function replaceAll(string, token, newtoken) {
          if(token!=newtoken)
          while(string.indexOf(token) > -1) {
              string = string.replace(token, newtoken);
          return string;
      function func_translate_status(meldungsart, native_type, status){
          let status_text;
          if(meldungsart == 'UNREACH_ALARM' || meldungsart == 'STICKY_UNREACH_ALARM'){
              if(status == 0){
                  status_text = 'keine Kommunikationsfehler';
              else if (status == 1){
                  status_text = 'Kommunikation gestört';
              else if (status == 2){
                  status_text = 'Kommunikation war gestört';
          else if(meldungsart == 'SABOTAGE_ALARM'){
              if(status == 0){
                  status_text = 'Keine Sabotage';
              else if(status == 1){
                  status_text = 'Sabotage';
              else if(status == 2){
                  status_text = 'Sabotage aufgehoben';
          else if(meldungsart == 'ERROR'){
              if((native_type == 'HM-Sec-RHS') || (native_type == 'HM-Sec-RHS-2') || (native_type == 'HM-Sec-SC') || (native_type == 'HM-Sec-SC-2') ||
                  (native_type == 'HM-Sec-SCo') || (native_type == 'HM-Sec-MD') || (native_type == 'HM-Sec-MDIR') || (native_type == 'HM-Sec-MDIR-2')){
                  if(status == 7){
                  else {
                      status_text = 'ERROR mit dem Wert: ' +status;
              else if ((native_type=='HM-Sec-Key') || (native_type=='HM-Sec-Key-S') || (native_type=='HM-Sec-Key-O')){
                  if(status == 1){
                      status_text = 'Einkuppeln fehlgeschlagen';
                      status_text = 'Motorlauf abgebrochen';
                  else {
              else if (native_type=='HM-CC-VD'){
                  if(status == 1){
                      status_text = 'Ventil Antrieb blockiert';
                      status_text = 'Ventil nicht montiert';
                  else if(status == 3){
                      status_text = 'Stellbereich zu klein';
                  else if(status == 4){
                      status_text = 'Batteriezustand niedrig';
                  else {
              else {
                  status_text = meldungsart +' mit dem Wert: ' +status;
          else if(meldungsart == 'LOWBAT_ALARM' || meldungsart == 'LOW_BAT_ALARM'){
              if(status === 0){
                  status_text = 'Batterie ok';
                  status_text = 'Batterie niedrig';
          else if(meldungsart == 'ERROR_NON_FLAT_POSITIONING_ALARM'){
              if(status === 0){
                  status_text = 'Keine Meldung';
                  status_text = 'Gerät wurde angehoben.';
                  status_text = 'Gerät wurde angehoben. Bestätigt';
          else if(meldungsart == 'CONFIG_PENDING_ALARM'){
              if(status === 0){
                  status_text = 'keine Meldung';
                  status_text = 'Konfigurationsdaten stehen zur Übertragung an';
                  status_text = 'Konfigurationsdaten standen zur Übertragung an';
          else if(meldungsart == 'UPDATE_PENDING_ALARM'){
              if(status === 0){
                  status_text = 'kein Update verfügbar';
                  status_text = 'Update verfügbar';
                  status_text = 'Update wurde eingespielt';
          else if(meldungsart == 'DEVICE_IN_BOOTLOADER_ALARM'){
              if(status === 0){
                  status_text = 'Gerät startet neu';
                  status_text = 'Gerät wurde neu getsartet';
          else if(meldungsart == 'FAULT_REPORTING'){
              if(native_type == 'HM-CC-RT-DN'){
                  if(status == 0){
                      status_text = 'keine Störung';
                      status_text = 'Ventil blockiert';
                      status_text = 'Einstellbereich Ventil zu groß';
                      status_text = 'Einstellbereich Ventil zu klein';
                      status_text = 'Kommunikationsfehler';
                  else if(status == 6){
                      status_text = 'Spannung Batterien/Akkus gering';
                  else if(status == 7){
                      status_text = 'Fehlstellung Ventil';
                  else{
                      status_text = meldungsart+' mit dem Wert: ' +status;
              else{
          return(status_text);
      function func_get_datum(id){
          let datum = formatDate(getState(id).lc, "TT.MM.JJ SS:mm:ss");
          let datum_seit;
          if(datum < '01.01.71 01:00:00'){
              datum_seit = '';
          }else{
              datum_seit=  ' --- seit: ' +datum +' Uhr';
          return(datum_seit);
      function func_Batterie(native_type){
          let Batterie = 'unbekannt';
          let cr2016 = ['HM-RC-4', 'HM-RC-4-B', 'HM-RC-Key3', 'HM-RC-Key3-B', 'HM-RC-P1', 'HM-RC-Sec3', 'HM-RC-Sec3-B', 'ZEL STG RM HS 4'];
          let cr2032 = ['HM-PB-2-WM', 'HM-PB-4-WM', 'HM-PBI-4-FM', 'HM-SCI-3-FM', 'HM-Sec-TiS', 'HM-SwI-3-FM', 'HmIP-FCI1'];
          let lr14x2 = ['HM-Sec-Sir-WM', 'HM-OU-CFM-TW', 'HM-OU-CFM-Pl', 'HM-OU-CF-Pl'];
          let lr44x2 = ['HM-Sec-SC', 'HM-Sec-SC2L', 'HM-Sec-SC-2', 'HM-Sec-RHS'];
          let lr6x2 = ['HM-CC-VD', 'HM-CC-RT-DN', 'HM-Sec-WDS', 'HM-Sec-WDS-2', 'HM-CC-TC', 'HM-Dis-TD-T', 'HB-UW-Sen-THPL-I', 'HM-WDS40-TH-I', 'HM-WDS40-TH-I-2', 'HM-WDS10-TH-O', 'HmIP-SMI', 'HMIP-eTRV', 'HM-WDS30-OT2-SM-2', 'HmIP-SMO', 'HmIP-SMO-A', 'HmIP-SPI', 'HmIP-eTRV-2', 'HmIP-SPDR', 'HmIP-SWD', 'HmIP-STHO-A', 'HmIP-eTRV-B', 'HmIP-PCBS-BAT','HmIP-STHO'];
          let lr6x3 = ['HmIP-SWO-PL', 'HM-Sec-MDIR', 'HM-Sec-MDIR-2', 'HM-Sec-SD', 'HM-Sec-Key', 'HM-Sec-Key-S', 'HM-Sec-Key-O', 'HM-Sen-Wa-Od', 'HM-Sen-MDIR', 'HM-Sen-MDIR-O', 'HM-Sen-MDIR-O-2', 'HM-WDS100-C6-O', 'HM-WDS100-C6-O-2', 'HM-WDS100-C6-O-2', 'HmIP-ASIR', 'HmIP-SWO-B', 'HM-Sen-MDIR-O-3', 'HM-Sec-MDIR-3'];
          let lr6x4 = ['HM-CCU-1', 'HM-ES-TX-WM', 'HM-WDC7000'];
          let lr3x1 = ['HM-RC-4-2', 'HM-RC-4-3', 'HM-RC-Key4-2', 'HM-RC-Key4-3', 'HM-RC-Sec4-2', 'HM-RC-Sec4-3', 'HM-Sec-RHS-2', 'HM-Sec-SCo', 'HmIP-KRC4', 'HmIP-KRCA', 'HmIP-SRH', 'HMIP-SWDO', 'HmIP-DBB', 'HmIP-RCB1'];
          let lr3x2 = ['HM-TC-IT-WM-W-EU', 'HM-Dis-WM55', 'HM-Dis-EP-WM55', 'HM-PB-2-WM55', 'HM-PB-2-WM55-2', 'HM-PB-6-WM55', 'HM-PBI-2-FM', 'HM-RC-8', 'HM-Sen-DB-PCB', 'HM-Sen-EP', 'HM-Sen-MDIR-SM', 'HM-Sen-MDIR-WM55', 'HM-WDS30-T-O', 'HM-WDS30-OT2-SM', 'HmIP-STH', 'HmIP-STHD', 'HmIP-WRC2', 'HmIP-WRC6', 'HmIP-WTH', 'HmIP-WTH-2', 'HmIP-SAM', 'HmIP-SLO', 'HMIP-SWDO-I', 'HmIP-FCI6', 'HmIP-SMI55', 'HM-PB-2-FM', 'HmIP-SWDM', 'HmIP-SCI', 'HmIP-SWDM-B2', 'HmIP-RC8', 'ALPHA-IP-RBG'];
          let lr3x3 = ['HM-PB-4Dis-WM', 'HM-PB-4Dis-WM-2', 'HM-RC-Dis-H-x-EU', 'HM-Sen-LI-O'];
          let lr3x3a = ['HM-RC-19', 'HM-RC-19-B', 'HM-RC-12', 'HM-RC-12-B', 'HM-RC-12-W'];
          let lr14x3 = ['HmIP-MP3P'];
          let block9 = ['HM-LC-Sw1-Ba-PCB', 'HM-LC-Sw4-PCB', 'HM-MOD-EM-8', 'HM-MOD-Re-8', 'HM-Sen-RD-O', 'HM-OU-CM-PCB', 'HM-LC-Sw4-WM'];
          let fixed    = ['HM-Sec-SD-2', 'HmIP-SWSD'];
          let ohne = ['HM-LC-Sw1PBU-FM', 'HM-LC-Sw1-Pl-DN-R1', 'HM-LC-Sw1-DR', 'HM-LC-RGBW-WM', 'HM-LC-Sw1-Pl-CT-R1', 'HmIP-HEATING', 'HM-LC-Sw1-FM', 'HM-LC-Sw2-FM', 'HM-LC-Sw4-DR', 'HM-LC-Sw1-Pl', 'HM-LC-Sw1-Pl-2', 'HM-LC-Sw4-Ba-PCB', 'HM-LC-Sw1-SM', 'HM-LC-Sw4-SM', 'HM-Sys-sRP-Pl', 'HM-LC-Sw2PBU-FM', 'HM-LC-Sw1-PCB', 'HM-LC-Sw4-DR-2'];
          let recharge = ['HM-Sec-Win', 'HM-Sec-SFA-SM',  'HM-RC-19-SW'];
          for (var i = 0; i < cr2016.length; i++) {
              if (cr2016[i].toUpperCase() == native_type.toUpperCase()) {
                  Batterie = '1x CR2016';
                  break;
          for (i = 0; i < cr2032.length; i++) {
              if (cr2032[i].toUpperCase() == native_type.toUpperCase()) {
                  Batterie = '1x CR2032';
                  break;
          for (i = 0; i < lr14x2.length; i++) {
              if (lr14x2[i].toUpperCase() == native_type.toUpperCase()) {
                  Batterie = '2x LR14';
                  break;
          for (i = 0; i <lr44x2.length; i++) {
              if (lr44x2[i].toUpperCase() == native_type.toUpperCase()) {
                  Batterie = '2x LR44/AG13';
                  break;
          for (i = 0; i <lr6x2.length; i++) {
              if (lr6x2[i].toUpperCase() == native_type.toUpperCase()) {
                  Batterie = '2x LR6/AA';
                  break;
          for (i = 0; i < lr6x3.length; i++) {
              if (lr6x3[i].toUpperCase() == native_type.toUpperCase()) {
                  Batterie = '3x LR6/AA';
                  break;
          for (i = 0; i < lr6x4.length; i++) {
              if (lr6x4[i].toUpperCase() == native_type.toUpperCase()) {
                  Batterie = '4x LR6/AA';
                  break;
          for (i = 0; i < lr3x1.length; i++) {
              if (lr3x1[i].toUpperCase() == native_type.toUpperCase()) {
                  Batterie = '1x LR3/AAA';
                  break;
          for (i = 0; i < lr3x2.length; i++) {
              if (lr3x2[i].toUpperCase() == native_type.toUpperCase()) {
                  Batterie = '2x LR3/AAA';
                  break;
          for (i = 0; i < lr3x3.length; i++) {
              if (lr3x3[i].toUpperCase() == native_type.toUpperCase()) {
                  Batterie = '3x LR3/AAA';
                  break;
          for (i = 0; i < lr3x3a.length; i++) {
              if (lr3x3a[i].toUpperCase() == native_type.toUpperCase()) {
                  Batterie = '3x AAA Akkus - bitte laden';
                  break;
          for (i = 0; i < lr14x3.length; i++) {
              if (lr14x3[i].toUpperCase() == native_type.toUpperCase()) {
                  Batterie = '3x LR14/C';
                  break;
          for (i = 0; i < block9.length; i++) {
              if (block9[i].toUpperCase() == native_type.toUpperCase()) {
                  Batterie = '9Volt Block leer oder unbestimmt';
                  break;
          for (i = 0; i < fixed.length; i++) {
              if (fixed[i].toUpperCase() == native_type.toUpperCase()) {
                  Batterie = 'Festbatterie leer';
                  break;
          for (i = 0; i < ohne.length; i++) {
              if (ohne[i].toUpperCase() == native_type.toUpperCase()) {
                  Batterie = 'ohne Batterie';
                  break;
          for (i = 0; i < recharge.length; i++) {
              if (recharge[i].toUpperCase() == native_type.toUpperCase()) {
                  Batterie = 'Akku entladen - bitte aufladen';
                  break;
          return(Batterie);
      function func_IST_Gesamt(){
          //wird nicht mehr verwendet
          log('Fehler function func_IST_Gesamt wurde aufgerufen.');
          let IST_LOWBAT = 0;
          let IST_LOW_BAT = 0;
          let IST_UNREACH = 0;
          let IST_STICKY_UNREACH = 0;
          let IST_CONFIG_PENDING = 0;
          let IST_UPDATE_PENDING = 0;
          let IST_DEVICE_IN_BOOTLOADER = 0;
          let IST_ERROR = 0;
          let IST_ERROR_NON_FLAT_POSITIONING = 0;
          let IST_ERROR_CODE = 0;
          let IST_FAULT_REPORTING = 0;
          let IST_SABOTAGE = 0;
          let IST_Gesamt = 0;
          if(write_state){
              if(id_IST_LOWBAT !== ''){
                   IST_LOWBAT = parseFloat(getState(id_IST_LOWBAT).val);
              if(id_IST_LOW_BAT !== ''){
                  IST_LOW_BAT = parseFloat(getState(id_IST_LOW_BAT).val);
              if(id_IST_UNREACH !== ''){
                  IST_UNREACH = parseFloat(getState(id_IST_UNREACH).val);
              if(id_IST_STICKY_UNREACH !== ''){
                  IST_STICKY_UNREACH = parseFloat(getState(id_IST_STICKY_UNREACH).val);
              if(id_IST_CONFIG_PENDING !== ''){
                  IST_CONFIG_PENDING = parseFloat(getState(id_IST_CONFIG_PENDING).val);
              if(id_IST_UPDATE_PENDING !== ''){
                  IST_UPDATE_PENDING = parseFloat(getState(id_IST_UPDATE_PENDING).val);
              if(id_IST_DEVICE_IN_BOOTLOADER !== ''){
                  IST_DEVICE_IN_BOOTLOADER = parseFloat(getState(id_IST_DEVICE_IN_BOOTLOADER).val);
              if(id_IST_ERROR !== ''){
                  IST_ERROR = parseFloat(getState(id_IST_ERROR).val);
              if(id_IST_ERROR_CODE !== ''){
                   IST_ERROR_CODE = parseFloat(getState(id_IST_ERROR_CODE).val);
              if(id_IST_FAULT_REPORTING !== ''){
                  IST_FAULT_REPORTING = parseFloat(getState(id_IST_FAULT_REPORTING).val);
              if(id_IST_SABOTAGE !== ''){
                  IST_SABOTAGE = parseFloat(getState(id_IST_SABOTAGE).val);
              if(id_IST_Gesamt === ''){
                  if(debugging){
                      log('Feld id_IST_Gesamt nicht ausgewählt');
              else{
                  IST_Gesamt = IST_LOWBAT + IST_LOW_BAT + IST_UNREACH + IST_STICKY_UNREACH + IST_CONFIG_PENDING + IST_UPDATE_PENDING + IST_DEVICE_IN_BOOTLOADER + IST_ERROR + IST_ERROR_CODE + IST_FAULT_REPORTING + IST_SABOTAGE;
                  if(debugging){
                      log('Derzeitige Servicemeldungen: ' +IST_Gesamt +' --- Ergebnis in Objekt geschrieben');
                  setState(id_IST_Gesamt,IST_Gesamt);
      function Servicemeldung(obj) {
          var prio = h_prio
          var common_name;
          var obj;
          var id_name;
          var native_type;
          var meldungsart;
          var Gesamt = 0;
          var Gesamt_UNREACH = 0;
          var Gesamt_STICKY_UNREACH = 0;
          var Gesamt_SABOTAGE = 0;
          var Gesamt_ERROR = 0;
          var Gesamt_LOWBAT = 0;
          var Gesamt_LOW_BAT = 0;
          var Gesamt_ERROR_NON_FLAT_POSITIONING = 0;
          var Gesamt_CONFIG_PENDING = 0;
          var Gesamt_UPDATE_PENDING = 0;
          var Gesamt_DEVICE_IN_BOOTLOADER = 0;
          var Gesamt_FAULT_REPORTING = 0;
          var Betroffen = 0;
          var Betroffen_no_observation = 0;
          var Betroffen_UNREACH = 0;
          var Betroffen_STICKY_UNREACH = 0;
          var Betroffen_SABOTAGE = 0;
          var Betroffen_ERROR = 0;
          var Betroffen_LOWBAT = 0;
          var Betroffen_LOW_BAT = 0;
          var Betroffen_ERROR_NON_FLAT_POSITIONING = 0;
          var Betroffen_CONFIG_PENDING = 0;
          var Betroffen_UPDATE_PENDING = 0;
          var Betroffen_DEVICE_IN_BOOTLOADER = 0;
          var Betroffen_FAULT_REPORTING = 0;
          var Betroffen_UNREACH_no_observation = 0;
          var Betroffen_STICKY_UNREACH_no_observation = 0;
          var Betroffen_SABOTAGE_no_observation = 0;
          var Betroffen_ERROR_no_observation = 0;
          var Betroffen_LOWBAT_no_observation = 0;
          var Betroffen_LOW_BAT_no_observation = 0;
          var Betroffen_ERROR_NON_FLAT_POSITIONING_no_observation = 0;
          var Betroffen_CONFIG_PENDING_no_observation = 0;
          var Betroffen_UPDATE_PENDING_no_observation = 0;
          var Betroffen_DEVICE_IN_BOOTLOADER_no_observation = 0;
          var Betroffen_FAULT_REPORTING_no_observation = 0;
          var id_UNREACH;
          var servicemeldung = [];
          var formatiert_servicemeldung = [];
          var log_manuell = false;
          if (obj) {
              common_name = obj.common.name.substr(0, obj.common.name.indexOf(':'));
              id_name = obj.id.split('.')[2];
              native_type = getObject(obj.id.substring(0, obj.id.lastIndexOf('.') - 2)).native.TYPE;
              meldungsart = obj.id.split('.')[4];
              var status = obj.newState.val;
              var status_text = func_translate_status(meldungsart, native_type, status);
              common_name = replaceAll(common_name, '.', ' ');          // Umwandeln aller "." in Leerzeichen
              common_name = replaceAll(common_name, 'ae', 'ä');         // Sonderzeichen umwandeln für bessere Text- und Sprachausgabe
              common_name = replaceAll(common_name, 'ue', 'ü');
              common_name = replaceAll(common_name, 'oe', 'ö');
              common_name = replaceAll(common_name, 'ss', 'ß');
              if(no_observation.search(id_name) == -1){
                  if(meldungsart != 'ERROR' && meldungsart != 'FAULT_REPORTING' && status != 1){
                      log('Servicemeldung aufgehoben: ' +common_name +' ('+id_name +') --- ' +native_type +'--- Typ: '+meldungsart +' --- Status: ' +status +' ' +status_text);
                  else{
                      log('Neue Servicemeldung: ' +common_name +' ('+id_name +') --- ' +native_type +'--- Typ: '+meldungsart +' --- Status: ' +status +' ' +status_text);
              else{
                  if(debugging){
                      log('[DEBUG] ' +'Neue Servicemeldung außerhalb der Überwachung: ' +common_name +' ('+id_name +') --- ' +native_type +'--- Typ: '+meldungsart +' --- Status: ' +status +' ' +status_text);
          else {
              if(logging){
                  log('Script manuell gestartet. log_manuell ist deshalb true.');
              log_manuell = true;
          SelectorLOWBAT.each(function (id, i) {                         // Schleife für jedes gefundenen Element *.LOWBAT
              if(existsObject(id)){
                  if(CUXD != id.split('.')[1]){
                      if(id.search('CUX') == -1){
                          common_name = getObject(id.substring(0, id.lastIndexOf('.') - 2)).common.name;
                          id_name = id.split('.')[2];
                          obj    = getObject(id);
                          native_type = getObject(id.substring(0, id.lastIndexOf('.') - 2)).native.TYPE;
                          meldungsart = id.split('.')[4];
                          var status = getState(id).val;
                          var Batterie = func_Batterie(native_type);
                          var datum_seit = func_get_datum(id);
                          if (status === 1 && no_observation.search(id_name) != -1) {
                              ++Betroffen_no_observation
                              ++Betroffen_LOWBAT_no_observation
                          if (status === 1 && no_observation.search(id_name) == -1) {      // wenn Zustand = true, dann wird die Anzahl der Geräte hochgezählt
                              ++Betroffen;
                              ++Betroffen_LOWBAT
                              if(prio < prio_LOWBAT){prio = prio_LOWBAT;}
                              if(with_time && datum_seit !== ''){
                                  formatiert_servicemeldung.push(common_name +' ('+id_name +')' + ' - <font color="red">Spannung Batterien/Akkus gering.</font> '+Batterie +datum_seit);
                                  servicemeldung.push(common_name +' ('+id_name +')' + ' - Spannung Batterien/Akkus gering. '+Batterie);
                              else{
                          ++Gesamt;                                        // Zählt die Anzahl der vorhandenen Geräte unabhängig vom Status
                          ++Gesamt_LOWBAT
                          if(show_each_device && log_manuell){
                              log('Geräte Nr. ' +i  +' Name: '+ common_name +' ('+id_name+') --- '+native_type +' --- Typ: '+meldungsart +' --- Status: ' +status +' ' +status_text +datum_seit +' --- ' +Batterie);
                          //wenn Batterie unbekannt dann Log
                          if(Batterie == 'unbekannt' && native_type !=='' && id_name.substring(0, 3) != 'CUX'){
                              log('Bitte melden: ' + common_name +' ('+id_name+') --- '+native_type +' --- Batterietyp fehlt im Script');
                      else{
                          log('[Script wird gestoppt] LOWBAT: Die Cuxd-Instanz wurde im Script auf ' +CUXD +' gestellt. Ein Objekt hat folgenden Namen: ' +id ,'warn');
                          return false;
              else{
                  log('[Script wird gestoppt] Der Datenpunkt ' +id +' existiert nicht.', 'warn');
                  return false;
          // Schleife ist durchlaufen.
          if(Gesamt_LOWBAT === 0){
              if(log_manuell){
                  log('Keine Geräte gefunden mit dem Datenpunkt LOWBAT.');
          else{
              if(Betroffen_LOWBAT_no_observation > 0){
                  if(debugging || log_manuell){
                      log('Es gibt: '+Gesamt_LOWBAT +' Geräte mit dem Datenpunkt ' +meldungsart+'. Derzeit: '+Betroffen_LOWBAT_no_observation +' unterdrückte Servicemeldung(en).');
              if(Betroffen_LOWBAT > 0){
                      log('Es gibt: '+Gesamt_LOWBAT +' Geräte mit dem Datenpunkt ' +meldungsart+'. Derzeit: '+Betroffen_LOWBAT +' Servicemeldung(en).');
                  if(write_state){
                      if(id_IST_LOWBAT){
                          setState(id_IST_LOWBAT,Betroffen_LOWBAT);
                      else{
                          if(debugging){
                              log('[DEBUG] ' +'id_IST Feld für LOWBAT nicht gefüllt');
                  else{
                      if(debugging){
                          log('[DEBUG] ' +'Variable write_state steht auf false');
              else{
                  if((log_manuell) || (onetime && log_manuell)){
                      log('Es gibt: '+Gesamt_LOWBAT +' Geräte mit dem Datenpunkt LOWBAT.');
                  if(write_state){
                      if(id_IST_LOWBAT){
                          setState(id_IST_LOWBAT,0);
                      else{
                          if(debugging){
                  else{
                      if(debugging){
          SelectorLOW_BAT.each(function (id, i) {                         // Schleife für jedes gefundenen Element
              //var datum = formatDate(getState(id).lc, "TT.MM.JJ SS:mm:ss");
                  ++Betroffen_LOW_BAT_no_observation
              if(status == 1 && native_type =='HmIP-HEATING'){
                  if(debugging){
                      log(common_name +' ('+id_name +') hat eine Servicemeldung gemeldet. Da es eine Heizungsgruppe ist erfolgt keine Push');
              if (status == 1 && no_observation.search(id_name) == -1 && native_type !='HmIP-HEATING') {
                  ++Betroffen;
                  ++Betroffen_LOW_BAT
                      servicemeldung.push(common_name +' ('+id_name +')' + ' - Spannung Batterien/Akkus gering. '+Batterie +datum_seit);
                  else{
                      formatiert_servicemeldung.push(common_name +' ('+id_name +')' + ' - <font color="red">Spannung Batterien/Akkus gering.</font> '+Batterie);
              ++Gesamt_LOW_BAT
              if(Batterie == 'unbekannt' && native_type !==''){
          if(Gesamt_LOW_BAT === 0){
              if(log_manuell){
                  log('Keine Geräte gefunden mit dem Datenpunkt LOW_BAT.');
          else{
              if(Betroffen_LOW_BAT_no_observation > 0){
                      log('Es gibt: '+Gesamt_LOW_BAT +' Geräte mit dem Datenpunkt ' +meldungsart+'. Derzeit: '+Betroffen_LOW_BAT_no_observation +' unterdrückte Servicemeldung(en).');
              if(Betroffen_LOW_BAT > 0){
                      log('Es gibt: '+Gesamt_LOW_BAT +' Geräte mit dem Datenpunkt ' +meldungsart+'. Derzeit: '+Betroffen_LOW_BAT +' Servicemeldung(en).');
                  if(write_state){
                      if(id_IST_LOW_BAT){
                          setState(id_IST_LOW_BAT,Betroffen_LOW_BAT);
                      else{
                          if(debugging){
                              log('[DEBUG] ' +'id_IST Feld für LOW_BAT nicht gefüllt');
                  else{
                      if(debugging){
              else{
                      log('Es gibt: '+Gesamt_LOW_BAT +' Geräte mit dem Datenpunkt LOW_BAT.');
                  if(write_state){
                      if(id_IST_LOW_BAT){
                          setState(id_IST_LOW_BAT,0);
                      else{
                          if(debugging){
                  else{
                      if(debugging){
          SelectorUNREACH.each(function (id, i) {                         // Schleife für jedes gefundenen Element
                          var id_STICKY_UNREACH = id.substring(0, id.lastIndexOf('.')+1) +'STICKY_UNREACH_ALARM';
                          if(native_type.substring(0, 3) == 'HM-' && id_name.substring(0, 3) != 'CUX'){
                              var statusSTICKY_UNREACH = getState(id_STICKY_UNREACH).val;
                              ++Betroffen_UNREACH_no_observation
                              if(debugging){
                              ++Betroffen;
                              ++Betroffen_UNREACH;
                              if(prio < prio_UNREACH){prio = prio_UNREACH;}
                                  formatiert_servicemeldung.push(common_name +' ('+id_name +')' + ' - <font color="red">Kommunikation gestört.</font>' +datum_seit);
                                  servicemeldung.push(common_name +' ('+id_name +')' + ' - Kommunikation gestört.' +datum_seit);
                              else{
                                  formatiert_servicemeldung.push(common_name +' ('+id_name +')' + ' - <font color="red">Kommunikation gestört.</font>');
                                  servicemeldung.push(common_name +' ('+id_name +')' + ' - Kommunikation gestört.');
                          ++Gesamt_UNREACH;
                              log('Geräte Nr. ' +(i + 1)  +' Name: '+ common_name +' ('+id_name+') --- '+native_type +' --- Typ: '+meldungsart +' --- Status: ' +status +' ' +status_text +datum_seit);
                      else{
                          log('[Script wird gestoppt] UNREACH: Die Cuxd-Instanz wurde im Script auf ' +CUXD +' gestellt. Ein Objekt hat folgenden Namen: ' +id ,'warn');
                          return false;
              else{
                  return false;
          if(Gesamt_UNREACH === 0){
              if(log_manuell){
                  log('Keine Geräte gefunden mit dem Datenpunkt UNREACH.');
          else{
              if(Betroffen_UNREACH_no_observation > 0){
                      log('Es gibt: '+Gesamt_UNREACH +' Geräte mit dem Datenpunkt ' +meldungsart+'. Derzeit: '+Betroffen_UNREACH_no_observation +' unterdrückte Servicemeldung(en).');
              if(Betroffen_UNREACH > 0){
                      log('Es gibt: '+Gesamt_UNREACH +' Geräte mit dem Datenpunkt ' +meldungsart+'. Derzeit: '+Betroffen_UNREACH +' Servicemeldung(en).');
                  if(write_state){
                      if(id_IST_UNREACH){
                          setState(id_IST_UNREACH,Betroffen_UNREACH);
                      else{
                          if(debugging){
                              log('[DEBUG] ' +'id_IST Feld für UNREACH nicht gefüllt');
                  else{
                      if(debugging){
              else{
                      log('Es gibt: '+Gesamt_UNREACH +' Geräte mit dem Datenpunkt UNREACH.');
                  if(write_state){
                      if(id_IST_UNREACH){
                          setState(id_IST_UNREACH,0);
                      else{
                          if(debugging){
                  else{
                      if(debugging){
          SelectorSTICKY_UNREACH.each(function (id, i) {
                          var id_UNREACH = id.substring(0, id.lastIndexOf('.')+1) +'UNREACH_ALARM';
                          var statusUNREACH = getState(id_UNREACH).val;
                              ++Betroffen_STICKY_UNREACH_no_observation
                              var log_autoAck = common_name +' ('+id_name +')';
                              ++Betroffen;
                              ++Betroffen_STICKY_UNREACH;
                              if(prio < prio_STICKY_UNREACH){prio = prio_STICKY_UNREACH;}
                              if(timer_sticky_unreach){
                                  clearTimeout(timer_sticky_unreach);
                              timer_sticky_unreach = setTimeout(function() {
                                  if(autoAck && statusUNREACH != 1){
                                      if(logging){
                                          log(log_autoAck + ' - Hinweis über bestätigbare Kommunikationsstörung wird jetzt gelöscht.');
                                      setStateDelayed(id,2);
                              }, 180 * 1000);  // 180 Sekunden Verzögerung
                              if(autoAck){
                                      formatiert_servicemeldung.push(common_name +' ('+id_name +')' + ' - <font color="red">Meldung über bestätigbare Kommunikationsstörung gelöscht.</font> ' +datum_seit);
                                      servicemeldung.push(common_name +' ('+id_name +')' + ' - Meldung über bestätigbare Kommunikationsstörung gelöscht. ' +datum_seit);
                                  else{
                                      formatiert_servicemeldung.push(common_name +' ('+id_name +')' + ' - <font color="red">Meldung über bestätigbare Kommunikationsstörung gelöscht.</font> ');
                                      servicemeldung.push(common_name +' ('+id_name +')' + ' - Meldung über bestätigbare Kommunikationsstörung gelöscht. ');
                              else {
                                      formatiert_servicemeldung.push(common_name +' ('+id_name +')' + ' - <font color="red">bestätigbare Kommunikationsstörung.</font>');
                                      servicemeldung.push(common_name +' ('+id_name +')' + ' - bestätigbare Kommunikationsstörung.');
                                  else{
                          ++Gesamt_STICKY_UNREACH;
                      else{
                          log('[Script wird gestoppt] STICKY:_UNREACH: Die Cuxd-Instanz wurde im Script auf ' +CUXD +' gestellt. Ein Objekt hat folgenden Namen: ' +id ,'warn');
                          return false;
              else{
                  return false;
          if(Gesamt_STICKY_UNREACH === 0){
              if(log_manuell){
                  log('Keine Geräte gefunden mit dem Datenpunkt STICKY_UNREACH.');
          else{
              if(Betroffen_STICKY_UNREACH_no_observation > 0){
                      log('Es gibt: '+Gesamt_STICKY_UNREACH +' Geräte mit dem Datenpunkt ' +meldungsart+'. Derzeit: '+Betroffen_STICKY_UNREACH_no_observation +' unterdrückte Servicemeldung(en).');
              if(Betroffen_STICKY_UNREACH > 0){
                      log('Es gibt: '+Gesamt_STICKY_UNREACH +' Geräte mit dem Datenpunkt ' +meldungsart+'. Derzeit: '+Betroffen_STICKY_UNREACH +' Servicemeldung(en).');
                  if(write_state){
                      if(id_IST_STICKY_UNREACH){
                          setState(id_IST_STICKY_UNREACH,Betroffen_STICKY_UNREACH);
                      else{
                          if(debugging){
                              log('[DEBUG] ' +'id_IST Feld für STICKY_UNREACH nicht gefüllt');
                  else{
                      if(debugging){
              else{
                      log('Es gibt: '+Gesamt_STICKY_UNREACH +' Geräte mit dem Datenpunkt STICKY_UNREACH.');
                  if(write_state){
                          setState(id_IST_STICKY_UNREACH,0);
                      else{
                          if(debugging){
                  else{
                      if(debugging){
          SelectorSABOTAGE.each(function (id, i) {
              if (status == 1 && no_observation.search(id_name) != -1) {
                  ++Betroffen_SABOTAGE_no_observation
                  if(debugging){
                      log(common_name +' ('+id_name +') hat eine Sabotage gemeldet. Da es eine Heizungsgruppe ist erfolgt keine Push');
                  ++Betroffen;
                  ++Betroffen_SABOTAGE;
                  if(prio < prio_SABOTAGE){prio = prio_SABOTAGE;}
                      formatiert_servicemeldung.push(common_name +' ('+id_name +')' + ' - <font color="red">' +status_text +'.</font> ' +datum_seit);
                      servicemeldung.push(common_name +' ('+id_name +')' + ' - ' +status_text +'.' +datum_seit);
                  else{
                      formatiert_servicemeldung.push(common_name +' ('+id_name +')' + ' - <font color="red">' +status_text +'.</font> ');
                      servicemeldung.push(common_name +' ('+id_name +')' + ' - ' +status_text +'.');
              ++Gesamt_SABOTAGE;
                  log('Geräte Nr. ' +i  +' Name: '+ common_name +' ('+id_name+') --- '+native_type +' --- Typ: '+meldungsart +' --- Status: ' +status +' ' +status_text +datum_seit);
          if(Gesamt_SABOTAGE === 0){
              if(log_manuell){
                  log('Keine Geräte gefunden mit dem Datenpunkt SABOTAGE.');
          else{
              if(Betroffen_SABOTAGE_no_observation > 0){
                      log('Es gibt: '+Gesamt_SABOTAGE +' Geräte mit dem Datenpunkt ' +meldungsart+'. Derzeit: '+Betroffen_SABOTAGE_no_observation +' unterdrückte Servicemeldung(en).');
              if(Betroffen_SABOTAGE > 0){
                      log('Es gibt: '+Gesamt_SABOTAGE +' Geräte mit dem Datenpunkt ' +meldungsart+'. Derzeit: '+Betroffen_SABOTAGE +' Servicemeldung(en).');
                  if(write_state){
                      if(id_IST_SABOTAGE){
                          setState(id_IST_SABOTAGE,Betroffen_SABOTAGE);
                      else{
                          if(debugging){
                              log('[DEBUG] ' +'id_IST Feld für SABOTAGE nicht gefüllt');
                  else{
                      if(debugging){
              else{
                      log('Es gibt: '+Gesamt_SABOTAGE +' Geräte mit dem Datenpunkt SABOTAGE.');
                  if(write_state){
                          setState(id_IST_SABOTAGE,0);
                      else{
                          if(debugging){
                  else{
                      if(debugging){
          SelectorERROR.each(function (id, i) {
                  ++Betroffen_ERROR_no_observation
              if (status > 0 && no_observation.search(id_name) == -1) {      // wenn Zustand größer 0, dann wird die Anzahl der Geräte hochgezählt
                  ++Betroffen;
                  ++Betroffen_ERROR;
                  if(prio < prio_ERROR){prio = prio_ERROR;}
                      formatiert_servicemeldung.push(common_name +' ('+id_name +')' + ' - <font color="red">'+status_text +'.</font> ' +datum_seit);
                      servicemeldung.push(common_name +' ('+id_name +')' + ' - '+status_text +datum_seit);
                  else{
                      formatiert_servicemeldung.push(common_name +' ('+id_name +')' + ' - <font color="red">'+status_text +'.</font> ');
                      servicemeldung.push(common_name +' ('+id_name +')' + ' - '+status_text);
              ++Gesamt_ERROR
          if(Gesamt_ERROR === 0){
              if(log_manuell){
                  log('Keine Geräte gefunden mit dem Datenpunkt ERROR.');
          else{
              if(Betroffen_ERROR_no_observation > 0){
                      log('Es gibt: '+Gesamt_ERROR +' Geräte mit dem Datenpunkt ' +meldungsart+'. Derzeit: '+Betroffen_ERROR_no_observation +' unterdrückte Servicemeldung(en).');
              if(Betroffen_ERROR > 0){
                      log('Es gibt: '+Gesamt_ERROR +' Geräte mit dem Datenpunkt ' +meldungsart+'. Derzeit: '+Betroffen_ERROR +' Servicemeldung(en).');
                  if(write_state){
                      if(id_IST_ERROR){
                          setState(id_IST_ERROR,Betroffen_ERROR);
                      else{
                          if(debugging){
                              log('[DEBUG] ' +'id_IST Feld für ERROR nicht gefüllt');
                  else{
                      if(debugging){
              else{
                      log('Es gibt: '+Gesamt_ERROR +' Geräte mit dem Datenpunkt ERROR.');
                  if(write_state){
                      if(id_IST_ERROR){
                          setState(id_IST_ERROR,0);
                      else{
                          if(debugging){
                  else{
                      if(debugging){
          SelectorERROR_NON_FLAT_POSITIONING.each(function (id, i) {
                  ++Betroffen_ERROR_NON_FLAT_POSITIONING_no_observation
                  ++Betroffen;
                  if(prio < prio_ERROR_NON_FLAT_POSITIONING){prio = prio_ERROR_NON_FLAT_POSITIONING;}
                      formatiert_servicemeldung.push(common_name +' ('+id_name +')' + ' - <font color="red">wurde angehoben.</font> ' +datum_seit);
                      servicemeldung.push(common_name +' ('+id_name +')' + ' - wurde angehoben.' +datum_seit);
                  else{
                      formatiert_servicemeldung.push(common_name +' ('+id_name +')' + ' - <font color="red">wurde angehoben.</font> ');
                      servicemeldung.push(common_name +' ('+id_name +')' + ' - wurde angehoben.');
              ++Gesamt_ERROR_NON_FLAT_POSITIONING
          if(Gesamt_ERROR_NON_FLAT_POSITIONING === 0){
              if(log_manuell){
                  log('Keine Geräte gefunden mit dem Datenpunkt ERROR_NON_FLAT_POSITIONING.');
          else{
              if(Betroffen_ERROR_NON_FLAT_POSITIONING_no_observation > 0){
                      log('Es gibt: '+Gesamt_ERROR_NON_FLAT_POSITIONING +' Geräte mit dem Datenpunkt ' +meldungsart+'. Derzeit: '+Betroffen_ERROR_NON_FLAT_POSITIONING_no_observation +' unterdrückte Servicemeldung(en).');
              if(Betroffen_ERROR_NON_FLAT_POSITIONING > 0){
                      log('Es gibt: '+Gesamt_ERROR_NON_FLAT_POSITIONING +' Geräte mit dem Datenpunkt ' +meldungsart+'. Derzeit: '+Betroffen_ERROR_NON_FLAT_POSITIONING +' Servicemeldung(en).');
                  if(write_state){
                      if(id_IST_ERROR_NON_FLAT_POSITIONING){
                          setState(id_IST_ERROR_NON_FLAT_POSITIONING,Betroffen_ERROR_NON_FLAT_POSITIONING);
                      else{
                          if(debugging){
                              log('[DEBUG] ' +'id_IST Feld für ERROR_NON_FLAT_POSITIONING nicht gefüllt');
                  else{
                      if(debugging){
              else{
                      log('Es gibt: '+Gesamt_ERROR_NON_FLAT_POSITIONING +' Geräte mit dem Datenpunkt ERROR_NON_FLAT_POSITIONING.');
                  if(write_state){
                          setState(id_IST_ERROR_NON_FLAT_POSITIONING,0);
                      else{
                          if(debugging){
                  else{
                      if(debugging){
          SelectorFAULT_REPORTING.each(function (id, i) {
                  ++Betroffen_FAULT_REPORTING_no_observation
                  ++Betroffen;
                  ++Betroffen_FAULT_REPORTING;
                  if(prio < prio_FAULT_REPORTING){prio = prio_FAULT_REPORTING;}
                  else{
              ++Gesamt_FAULT_REPORTING;
          if(Gesamt_FAULT_REPORTING === 0){
              if(log_manuell){
                  log('Keine Geräte gefunden mit dem Datenpunkt FAULT_REPORTING.');
          else{
              if(Betroffen_FAULT_REPORTING_no_observation > 0){
                      log('Es gibt: '+Gesamt_FAULT_REPORTING +' Geräte mit dem Datenpunkt ' +meldungsart+'. Derzeit: '+Betroffen_FAULT_REPORTING_no_observation +' unterdrückte Servicemeldung(en).');
              if(Betroffen_FAULT_REPORTING > 0){
                      log('Es gibt: '+Gesamt_FAULT_REPORTING +' Geräte mit dem Datenpunkt ' +meldungsart+'. Derzeit: '+Betroffen_FAULT_REPORTING +' Servicemeldung(en).');
                  if(write_state){
                      if(id_IST_FAULT_REPORTING){
                          setState(id_IST_FAULT_REPORTING,Betroffen_FAULT_REPORTING);
                      else{
                          if(debugging){
                              log('[DEBUG] ' +'id_IST Feld für FAULT_REPORTING nicht gefüllt');
                  else{
                      if(debugging){
              else{
                      log('Es gibt: '+Gesamt_FAULT_REPORTING +' Geräte mit dem Datenpunkt FAULT_REPORTING.');
                  if(write_state){
                          setState(id_IST_FAULT_REPORTING,0);
                      else{
                          if(debugging){
                  else{
                      if(debugging){
          SelectorDEVICE_IN_BOOTLOADER.each(function (id, i) {
                  ++Betroffen_DEVICE_IN_BOOTLOADER_no_observation
                  ++Betroffen;
                  ++Betroffen_DEVICE_IN_BOOTLOADER;
                  if(prio < prio_DEVICE_IN_BOOTLOADER){prio = prio_DEVICE_IN_BOOTLOADER;}
                      formatiert_servicemeldung.push(common_name +' ('+id_name +')' + ' - <font color="red">Gerät startet neu.</font> ' +datum_seit);
                      servicemeldung.push(common_name +' ('+id_name +')' + ' - Gerät startet neu.' +datum_seit);
                  else{
                       formatiert_servicemeldung.push(common_name +' ('+id_name +')' + ' - <font color="red">Gerät startet neu.</font> ');
                      servicemeldung.push(common_name +' ('+id_name +')' + ' - Gerät startet neu.');
              ++Gesamt_DEVICE_IN_BOOTLOADER;
          if(Gesamt_DEVICE_IN_BOOTLOADER === 0){
              if(log_manuell){
                  log('Keine Geräte gefunden mit dem Datenpunkt DEVICE_IN_BOOTLOADER.');
          else{
              if(Betroffen_DEVICE_IN_BOOTLOADER_no_observation > 0){
                      log('Es gibt: '+Gesamt_DEVICE_IN_BOOTLOADER +' Geräte mit dem Datenpunkt ' +meldungsart+'. Derzeit: '+Betroffen_DEVICE_IN_BOOTLOADER_no_observation +' unterdrückte Servicemeldung(en).');
              if(Betroffen_DEVICE_IN_BOOTLOADER > 0){
                      log('Es gibt: '+Gesamt_DEVICE_IN_BOOTLOADER +' Geräte mit dem Datenpunkt ' +meldungsart+'. Derzeit: '+Betroffen_DEVICE_IN_BOOTLOADER +' Servicemeldung(en).');
                  if(write_state){
                      if(id_IST_DEVICE_IN_BOOTLOADER){
                          setState(id_IST_DEVICE_IN_BOOTLOADER,Betroffen_DEVICE_IN_BOOTLOADER);
                      else{
                          if(debugging){
                              log('[DEBUG] ' +'id_IST Feld für DEVICE_IN_BOOTLOADER nicht gefüllt');
                  else{
                      if(debugging){
              else{
                      log('Es gibt: '+Gesamt_DEVICE_IN_BOOTLOADER +' Geräte mit dem Datenpunkt DEVICE_IN_BOOTLOADER.');
                  if(write_state){
                          setState(id_IST_DEVICE_IN_BOOTLOADER,0);
                      else{
                          if(debugging){
                  else{
                      if(debugging){
          SelectorCONFIG_PENDING.each(function (id, i) {
                  ++Betroffen_CONFIG_PENDING_no_observation
                  if(debugging){
                  ++Betroffen;
                  ++Betroffen_CONFIG_PENDING;
                  if(prio < prio_CONFIG_PENDING){prio = prio_CONFIG_PENDING;}
                      formatiert_servicemeldung.push(common_name +' ('+id_name +')' + ' - <font color="red">Konfigurationsdaten stehen zur Übertragung an.</font> ' +datum_seit);
                      servicemeldung.push(common_name +' ('+id_name +')' + ' - Konfigurationsdaten stehen zur Übertragung an. ' +datum_seit);
                  else{
                      formatiert_servicemeldung.push(common_name +' ('+id_name +')' + ' - <font color="red">Konfigurationsdaten stehen zur Übertragung an.</font> ');
                      servicemeldung.push(common_name +' ('+id_name +')' + ' - Konfigurationsdaten stehen zur Übertragung an. ');
              ++Gesamt_CONFIG_PENDING;
          if(Gesamt_CONFIG_PENDING === 0){
              if(log_manuell){
                  log('Keine Geräte gefunden mit dem Datenpunkt CONFIG_PENDING.');
          else{
              if(Betroffen_CONFIG_PENDING_no_observation > 0){
                      log('Es gibt: '+Gesamt_CONFIG_PENDING +' Geräte mit dem Datenpunkt ' +meldungsart+'. Derzeit: '+Betroffen_CONFIG_PENDING_no_observation +' unterdrückte Servicemeldung(en).');
              if(Betroffen_CONFIG_PENDING > 0){
                      log('Es gibt: '+Gesamt_CONFIG_PENDING +' Geräte mit dem Datenpunkt ' +meldungsart+'. Derzeit: '+Betroffen_CONFIG_PENDING +' Servicemeldung(en).');
                  if(write_state){
                      if(id_IST_CONFIG_PENDING){
                          setState(id_IST_CONFIG_PENDING,Betroffen_CONFIG_PENDING);
                      else{
                          if(debugging){
                              log('[DEBUG] ' +'id_IST Feld für CONFIG_PENDING nicht gefüllt');
                  else{
                      if(debugging){
              else{
                      log('Es gibt: '+Gesamt_CONFIG_PENDING +' Geräte mit dem Datenpunkt CONFIG_PENDING.');
                  if(write_state){
                          setState(id_IST_CONFIG_PENDING,0);
                      else{
                          if(debugging){
                  else{
                      if(debugging){
          SelectorUPDATE_PENDING.each(function (id, i) {
                  ++Betroffen_UPDATE_PENDING_no_observation
                  if(debugging){
                  ++Betroffen;
                  ++Betroffen_UPDATE_PENDING;
                  if(prio < prio_UPDATE_PENDING){prio = prio_UPDATE_PENDING;}
                      servicemeldung.push(common_name +' ('+id_name +')' + ' - Gerät startet neu. ' +datum_seit);
                  else{
                      servicemeldung.push(common_name +' ('+id_name +')' + ' - Gerät startet neu. ');
              ++Gesamt_UPDATE_PENDING;
          if(Gesamt_UPDATE_PENDING === 0){
              if(log_manuell){
                  log('Keine Geräte gefunden mit dem Datenpunkt UPDATE_PENDING.');
          else{
              if(Betroffen_UPDATE_PENDING_no_observation > 0){
                      log('Es gibt: '+Gesamt_UPDATE_PENDING +' Geräte mit dem Datenpunkt ' +meldungsart+'. Derzeit: '+Betroffen_UPDATE_PENDING_no_observation +' unterdrückte Servicemeldung(en).');
              if(Betroffen_UPDATE_PENDING > 0){
                      log('Es gibt: '+Gesamt_UPDATE_PENDING +' Geräte mit dem Datenpunkt ' +meldungsart+'. Derzeit: '+Betroffen_UPDATE_PENDING +' Servicemeldung(en).');
                  if(write_state){
                      if(id_IST_UPDATE_PENDING){
                          setState(id_IST_UPDATE_PENDING,Betroffen_UPDATE_PENDING);
                      else{
                          if(debugging){
                              log('[DEBUG] ' +'id_IST Feld für UPDATE_PENDING nicht gefüllt');
                  else{
                      if(debugging){
              else{
                      log('Es gibt: '+Gesamt_UPDATE_PENDING +' Geräte mit dem Datenpunkt UPDATE_PENDING.');
                  if(write_state){
                          setState(id_IST_UPDATE_PENDING,0);
                      else{
                          if(debugging){
                  else{
                      if(debugging){
          //Verarbeitung aller Datenpunkte
          if(Betroffen_no_observation > 0){
              if(debugging){
                  log('[DEBUG] ' +'Derzeit gibt es insgesamt ' +Betroffen_no_observation +' unterdrückte Servicemeldungen');
          //if(Betroffen > 0 && native_type !=='HmIP-HEATING'){
          if(Betroffen > 0){
              if(debugging){
                  log('[DEBUG] ' +'Betroffen mehr als 0. Es sind '+Betroffen);
                  log('[DEBUG] ' +'log_manuell: '+log_manuell);
              if(write_state){
                      if(debugging){
                          log('[DEBUG] ' +'Feld id_IST_Gesamt nicht ausgewählt');
                  else{
                      if(debugging){
                          log('[DEBUG] ' +'Derzeit gibt es Servicemeldungen. Ergebnis in Objekt geschrieben');
                          log('[DEBUG] ' +'Betroffen: '+Betroffen);
                      setState(id_IST_Gesamt,Betroffen);
              else{
                  if(debugging){
              if(write_message){
                  if(id_Text_Servicemeldung === ''){
                      if(debugging){
                          log('[DEBUG] ' +'Feld id_Text_Servicemeldung nicht ausgewählt');
                  else{
                      if(debugging){
                          log('[DEBUG] ' +'write_message steht auf true. Ergebnis in Objekt geschrieben');
                          log('[DEBUG] ' +'Betroffen: '+servicemeldung.join(', '));
                      setState(id_Text_Servicemeldung,servicemeldung.join('<br> '));
              else{
                  if(debugging){
                      log('[DEBUG] ' +'Variable write_message steht auf false');
              if(meldung_neu != servicemeldung){
                  meldung_alt = meldung_neu;
                  meldung_neu = servicemeldung;
                  if(debugging){
                      log('[DEBUG] ' +'meldung alt und neu geändert');
              else{
                  if(debugging && !log_manuell){
                      log('[DEBUG] ' +'Else Teil Meldung_neu');
                  meldung_neu = ['Derzeit keine neue Servicemeldung'];
              if(timer){
                  clearTimeout(timer);
                  timer = null;
                  if(debugging){
                      log('[DEBUG] ' +'Es gibt bereits eine Servicemeldung. Abruch des Timers .');
                  if(debugging){
                      log('[DEBUG] ' +'Übersicht aller Servicemeldungen: '+ servicemeldung.join(', '));
                  //Push verschicken (20.11.19 hinzugefügt wegen doppelter Meldung)
                  //meldung_neu = meldung_neu.filter(item => !meldung_alt.includes(item));
                  //if(meldung_neu.length === 0){
                          log('[DEBUG] ' +'Pushnachricht unterdrückt, da es über diese Servicemeldung bereits eine Push gab.');
                  //else{
                      //Push verschicken
                      if(sendpush && !log_manuell){
                          //prio wird durch Servicemeldung vergeben
                          titel = 'Servicemeldung';
                          message = formatiert_servicemeldung.join('\n');
                          send_pushover(device, message, titel, prio);
                      if(sendtelegram && !log_manuell){
                          message = servicemeldung.join('\n');
                          send_telegram(message, user_telegram);
                      if(sendmail && !log_manuell){
                          send_mail(message);
              else{
                  timer = setTimeout(function() {
                      timer = null;
                          log('[DEBUG] ' +'Timer abgelaufen. Verarbeitung der Servicemeldung');
                          log('Es werden: '+Gesamt +' Datenpunkte überwacht. Derzeit: '+Betroffen +' Servicemeldung(en).');
                      if(Betroffen == 1){
                          if(debugging){
                              log('[DEBUG] ' +'Es gibt eine Servicemeldung: ' + servicemeldung.join(', '));
                      if(Betroffen >1){
                          if(debugging){
                      //Push verschicken
                      else{
                          //log('Test: '+meldung_neu);
                              //prio = 0;
                              send_mail(message);
                  }, 3 * 1000);  // 3 Sekunden Verzögerung
          else{
              meldung_alt = ['Derzeit keine Servicemedungen.'];
              if((debugging) || (onetime && log_manuell)){
                  log(Gesamt +' Datenpunkte werden insgesamt vom Script ' +name +' (Version: '+Version +') überwacht. Instance: '+instance);
                  log('logging: '+logging +' debugging: '+debugging +' find_bug: '+find_bug +' show_each_device: ' +show_each_device +' autoAck: '+autoAck +' observation: '+ observation +' ohnetime: '+onetime +' CUXD: '+CUXD);
              if(write_message){
                  if(id_Text_Servicemeldung){
                      setState(id_Text_Servicemeldung,'Derzeit keine Servicemeldungen');
              if(write_state){
                      if(debugging){
                  else{
                      if(debugging){
                          log('[DEBUG] ' +'Derzeitige keine Servicemeldungen. Ergebnis in Objekt geschrieben');
                      setState(id_IST_Gesamt,0);
      //Auslösen durch Zustandsänderung
      if(observation){
          SelectorUNREACH.on(function(obj) {
              Servicemeldung(obj);
          SelectorSTICKY_UNREACH.on(function(obj) {
          SelectorSABOTAGE.on(function(obj) {
          SelectorERROR.on(function(obj) {
          SelectorLOWBAT.on(function(obj) {
          SelectorLOW_BAT.on(function(obj) {
          SelectorERROR_NON_FLAT_POSITIONING.on(function(obj) {
          SelectorFAULT_REPORTING.on(function(obj) {
          SelectorCONFIG_PENDING.on(function(obj) {
          SelectorUPDATE_PENDING.on(function(obj) {
          SelectorDEVICE_IN_BOOTLOADER.on(function(obj) {
      if(onetime){
          //beim Start
          Servicemeldung();
      Das funktioniert auch prima . Jetzt hätte ich noch eine Bitte.Was muß ich ändern ,das bei der Vis-Anzeige nur der Name und nicht die Nummer zu sehen ist.
      Du hast es ja hier schon mal beschrieben ,aber ich verstehe es nicht.
      Könntest du mir bitte genauer erklären , was ich wie ändern muß?
      Ich sage schon mal vielen Dank
      Volker
      cash 1 Reply Last reply Reply Quote 0
      • cash
        cash Most Active @Knusterus last edited by
        @Knusterus said in Servicemeldungen - All inclusive für Homematic -:
        Wie schon geschrieben ist die br Methode nicht die Beste Methode aber das muss jeder selber wissen. Qucik & Dirty suchst Du im Script nach den String bzw auch die Zeile darunter. Da bin ich mir nicht so 100% sicher aber dort musst Du quasi alles hinter common_name löschen und schon sollte es weg sein. Heißt halt bei jeder neuen Version musst Du es wieder machen...
          Knusterus @cash last edited by
          @cash said in Servicemeldungen - All inclusive für Homematic -:
          könntest Du mir mal bitte eine Beispielzeile schicken, ich kenn mich mit solchen Scripts nicht aus.
          Oder gibt es vielleicht ein Script , welches die Darstellung untereinander und ohne Nummer ergibt?
          Volker
          • cash
            @Knusterus Zeile 1871 ersetzen durch
            servicemeldung.push(common_name  + ' - Gerät startet neu. ');
            Du musst nach servicemeldung.push suchen und dort immer nach common_name
            +' ('+id_name +')'
            entfernen. Vermute ich 🙂 Ein Script dazu wird es wohl nicht geben. Ich würde mir die Arbeit auch nicht machen. Wenn ich die Meldungen in vis nutzen würde und sie untereinander haben wollte, würde ich in Vis halt ein Script nutzen. Mache ich aber nicht. Weil es für mich sinnlos ist, da ich eine Servicemeldung nie länger als ein paar Minuten habe und selbst leere Batterien wechsel ich immer sofort...
            Ich nutze sowas für die Anzeige beim Mähroboter wann der letzte Klingenwechsel war. Dort mache ich es wie folgt:
            {a:Systemvariable.0.Terrasse.Landroid.Klingenwechsel;a.replace(/,/g,"<br>")}
            Also nichts anderes wie suche im Feld nach Komma und ersetze durch <br>
              @cash
              Prima vielen Dank 👍 👏 hat super funktioniert. 😳
              Volker
                Bratwurst last edited by
                Zeile 220 und 2150 der V1.73 genieren bei mir folgende Warnings:
                javascript.0
                2020-05-24 19:21:31.076
                warn
                (1529) at script.js.Scripte.Servicemeldungen:2200:5
                javascript.0
                warn
                (1529) at Servicemeldung (script.js.Scripte.Servicemeldungen:2150:17)
                javascript.0
                2020-05-24 19:21:31.075
                warn
                (1529) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1354:20)
                javascript.0
                2020-05-24 19:21:31.074
                warn
                (1529) State "Systemvariable.0.Servicemeldungen.Anzahl_GESAMT" not found
                Welche Ursache kann das haben?
                Zweite Frage... mit welchen Trick kann ich mir zu Testzwecken Servicemeldungen generieren?
                Vielen Dank 🙂
                • cash
                  @Bratwurst said in Servicemeldungen - All inclusive für Homematic -:
                  1. State "Systemvariable.0.Servicemeldungen.Anzahl_GESAMT" not found
                  Bitte Konfiguration durcharbeiten. Ich würde keine Servicemeldung generieren sondern einfach abwarten bis eine Auftritt.
                  falke69 1 Reply Last reply Reply Quote 0
                  • falke69
                    falke69 @cash last edited by
                    @cash
                    ich musste bei mir ein Gerät gegen ein anderes tauschen.
                    Habe alle Instanzen bereits angehalten und alle Objekte gelöscht, danach alle nacheinander wieder gestartet.
                    Dennoch erhalte ich diese Fehlermeldung:
                    (2471) Object "hm-rpc.0.KEQ0xxxxx" does not exist.
                    Wo könnte ich noch schauen, um diese Meldung zu beseitigen, damit das Script nicht mehr angehalten wird?
                    • cash
                      cash Most Active @falke69 last edited by
                      @falke69 Hast Du die Javascript Instanz auch mal gestoppt und wieder gestartet?
                      • falke69
                        @cash habe ich auch schon versucht. 😞
                        • cash
                          @falke69 Reboot tut gut? Was Du auch noch probieren kannst. Script stoppen. Alle Instanzen von Homematic undJava stoppen. HM-Instanzen wieder starten, Java wieder starten. Script starten.
                          Ich musste zum Glück noch nie ein Gerät tauschen. Bei einem neuen reicht es wenn man das Gerät mittels Hm Adapter in ioBroker reinholt danach die Java Instanz neu startet und das Script nochmal. Wobei ich meistens die letzten Beiden sachen nicht mache, da bei mir jeden Freitrag Nacht ein Backup vom Docker Container erfolgt und dazu ioBroker neu gestartet wird. Somit habe ich spätestens Samstag das neue Gerät in der Überwachung.
                          • falke69
                            @cash
                            jetzt habe ich alle Instanzen gestoppt, danach sämmtliche Scripte gestoppt und das System neu gestartet. Danach die Instanzen einzeln neu gestartet und erneut alle Geräte einmal einlesen lassen.
                            Zum Schluss alle Blocklys und danach alle Javas wieder gestartet.
                            Hat funktioniert. Muss ich mir für das nächste Mal merken. 🙂
                            Das Heizkörperthermostat bei der Tochter hatte mehrfach am Tag Fehler gemeldet, dass es nicht erreichbar wäre (ist per Luftlinie ca. 6 Meter von der CCU entfernt). Aus diesem Grund habe ich es einfach gegen ein anderes Ausgetauscht.
                            Vielen Dank! und noch einen schönen Sonntag. 🙂
                              jwerlsdf last edited by jwerlsdf
                              ich bekomme beim Skriptstart immer folgende Fehler:
                              14:52:28.269 warn javascript.0 (3091) at Servicemeldung (script.js.Test.Servicemeldungen:2135:17)
                              14:52:28.269 warn javascript.0 (3091) at script.js.Test.Servicemeldungen:2185:5
                              Das Skript an sich läuft wohl, da ich per Telegram einige Warnungen schon mal reinbekommen habe. Was besagt dieser Fehler?
                              * 29.03.19 V1.20    Komplett umgeschrieben
                              *                   UNREACH, STICKY_UNREACH, SABOTAGE hinzugefügt
                              * 01.04.19 V1.21    Error hinzugefügt
                              * 02.04.19 V1.22    Übersetung Errormeldungen eingefügt
                              *                   Unterdrückung des Logeintrags wenn kein Datenpunkt zu einen bestimmten Servicetyp vorhanden ist. Wird nur beim manuellen Starten ausgegeben
                              * 04.04.19 V1.23    LOWBAT, LOW_BAT und ERROR_NON_FLAT_POSITIONING hinzugefügt
                              * 11.04.19 V1.24    Replace von ae zu ä usw hinzugefügt (erstmal nur wenn durch obj ausgeführt)
                              *                   Status_text in eigene Function ausgelaggert
                              *                   datum seit in eigene function ausgelaggert
                              *                   FAULT_REPORTING und DEVICE_IN_BOOTLOADER hinzugefügt
                              *                   Alle globalen Variablen auf const und let geändert
                              *                   Alle Nebenfuntionen auf let und const geändert
                              *                   Update Batterieliste
                              *                   Fehler bei Sticky_Unreach beseitigt
                              * 17.04.19 V1.25    Timer der Push verzögert verändert.
                              * 23.04.19 V1.26    Texte in Array eingebaut
                              *                   Timer verändert
                              * 28.04.19 V1.27    Timer verändert
                              * 11.05.19 V1.28    Timer verändert
                              * 13.05.19 V1.29    bestehender Timer wird abgebrochen und stattdessen neue Push verschickt
                              *                   Config_PENDING und UPDATE_PENDING aufgenommen
                              *                   Es wird die höchste Prio je nach Servicemeldung für Pushover gewählt.
                              * 14.05.19 V1.30    Parameter with_time wird wieder berücksichtigt
                              * 24.05.19 V1.31    Paramteer write_message wird wieder berücksichtigt
                              *                   Parameter write_state wird berücksichtigt für LOWBAT, LOW_BAT, UNREACH und STICKY_UNREACH die anderen folgen später
                              *                   Datenpunkte DEVICE_IN_BOOTLOADER wurde nicht überwacht nur ausgewertet
                              * 27.05.19 V1.32    Paramter write_state wird komplett berücksichtigt
                              *                   Erster Versuch doppelte Servicemelungen zu unterdrücken
                              *                   alte Variabe datum_neu übersehen
                              * 28.05.19 V1.33    Neuer Versuch doppelte zu unterdrücken (nur als log) etwas mehr logging
                              * 29.05.19 V1.34    Neuer Versuch doppelte zu unterdrücken
                              * 31.05.19 V1.35    Neuer Versuch
                              * 01.06.19 V1.36    doppelte Servicemeldungen werden unterdrückt. Logging reduziert
                              * 06.06.19 V1.37    Neuer Versuch. Mehr Logging
                              * 07.06.19 V1.38    und bzw oder Fehler entfernt.
                              * 09.06.19 V1.39    Zwei Abfragen seperat
                              * 10.06.19 V1.40    Abfrage vertauscht
                              * 15.06.19 V1.41    Einschränkung auf UNREACH und Sticky Unreach
                              * 18.06.19 V1.42    meldung_neu und meldung_alt werden nur unter bestimmten Umständen gefüllt
                              * 19.06.19 V1.43    Logging verändert. Evtl noch ein Problem bei der Unterdrückung doppelter Meldungen wenn schon ein Timer besteht
                              * 20.06.19 V1.44    Update Batterienliste
                              *                   Logging optimiert
                              * 22.06.19 V1.45    message_tmp und message_tmp1 entfernt (hatte ich beim ändern übersehen)
                              *                   Sticky_Unreach wird erst gezählt wenn Unreach erledigt ist (Danke an ArnoD)
                              * 01.07.19 V1.46    Update Batterieliste
                              *                   Bugfix Gesamtanzahl Servicemeldungen wurde nicht auf 0 gesetzt
                              * 02.07.19 V1.47    Logging reduziert
                              *                   Bugfix Gesamtzahl Servicemeldungen kein Aufruf der Function mehr. Feld wird direkt geschrieben
                              * 04.07.19 V1.48    Bugfix Feld mit Servicemeldungen wird bei keiner Servicemeldung nicht gelöscht.
                              *                   Bugfix Feld mit Servicemeldungen wurde nicht immer zuverlässig oder verzögert aktualisiert
                              *                   Neuer Parameter "find_bug"
                              * 05.07.19 V1.49    Update Batterieliste
                              * 08.07.19 V1.50    Meldung das der Batterietyp für Cux-Geräte fehlt unterdrückt
                              *                   Log fehlerhafter Eintrag LOWBAT statt LOW_BAT
                              *                   Status von FAULT_REPORTING wurde nicht übersetzt
                              * 09.07.19 V1.51    Unterschiedlicher Loggingtext beim auftreten und aufheben einer Servicemeldung
                              *                   Wenn Sticky_UNreach und Unreach gleichzeitig auftreten wird eine Push verschickt
                              *                   find_bug geändert auf Zeitstempel von UNREACH Meldungen
                              * 11.07.19 V1.52    Update Batterieliste
                              * 19.07.19 V1.53    Logging für Zeitstempel Unreach geändert (find_bug)
                              *                   Bei V1.45 wurde nicht auf die Alarm Punkte abgefragt sondern auf UNREACH und STICKY_UNREACH
                              * 31.07.19 V1.54    Erstmal wieder find_bug auf false
                              * 21.08.19 V1.55    Vergleich von neuen und alten Servicemeldungen nun als Array damit bei mehr als 2 Meldungen die Meldung korrekt unterdrückt wird
                              * 23.08.19 V1.56    Änderungen im Umgang mit Unreach und Sticky_Unreach
                              * 06.09.19 V1.57    no_observation arbeitet nicht richtig. Korrekur erstmal nur für LOWBAT und LOW_BAT
                              * 07.09.19 V1.58    Vergleich no_oberservation bei der Verarbeitung aller Datenpunkte erntfernt da zukünftig überflüssig
                              *                   Neuer Paramter show_each_device zeigt von jedem Gerät die überwachten Datenpunkte beim Scriptstart an
                              *                   no_observation auch für UNREACH
                              * 08.09.19 V1.59    Korrektur aller Servicemeldungen für no_observation
                              * 11.09.19 V1.60    Update Batterieliste
                              * 12.09.19 V1.61    Problem mit Cuxd Geräten behoben
                              * 12.11.19 V1.62    neue Option für Cuxd-Geräte
                              * 13.11.19 V1.63    Kleinere anpassungen
                              * 20.11.19 V1.64    Meldungen wurden immer mit Prio 0 verschickt
                              *                   doppelte Meldungen unterdrückt
                              * 23.11.19 V1.65    Bugfix Prio
                              * 02.12.19 V1.66    Unterdrückung bereits aufgetreter Meldungen
                              * 21.01.20 V1.67    Bei Stati abfragen von === auf ==
                              *                   Wenn Betroffen größer 0 kein Vergleich mehr auf Heating Gruppen (erstmal nur Testweise)
                              * 22.01.20 V1.68    Unterdrückund doppelter Push bei HMIP wenn Gerät in Heizungsgruppe für Sabotage
                              * 03.02.20 V1.69    Unterdrückund doppelter Push bei HMIP wenn Gerät in Heizungsgruppe für alle anderen Serviemeldungen
                              * 05.02.20 V1.70    Änderung für cuxd Geräte
                              * 17.02.20 V1.71    Update Batterieliste
                              *                   Überprüfung ob bestimmte Datenpunkte die überwacht werden sollen existieren
                              *                   Plausi-Prüfung CUXD
                              * 18.02.20 V1.72    Abfrage ob weitere Datenpunkte existieren
                              *                   Version wird bei Scriptstart angezeigt
                              * 18.05.20 V1.73    Versuch Fehler abzufangen falls common_name nicht existiert
                              * Andere theoretisch mögliche LOWBAT_REPORTING, U_SOURCE_FAIL, USBH_POWERFAIL, STICKY_SABOTAGE, ERROR_REDUCED, ERROR_SABOTAGE
                              const Version = 1.73;
                              const logging = true;             //Sollte immer auf true stehen. Bei false wird garnicht protokolliert
                              const debugging = true;          //true protokolliert viele zusätzliche Infos
                              const find_bug = false;         //erhöht das Logging wird nur verwendet wenn ein aktulles Bug gesucht wird
                              const show_each_device = false; //zeigt alle verfügbaren Datenpunkte je Device
                              const autoAck = true;             //Löschen bestätigbarer Kommunikationsstörungen (true = an, false = aus)
                              const observation = true;        //Dauerhafte Überwachung der Geräte auf Servicemeldungen aktiv (true = aktiv // false =inaktiv)
                              const onetime = true;             //Prüft beim Script Start ob derzeit Geräte eine Servicemeldung haben
                              const with_time = false;           //Hängt die Uhrzeit an die Serviemeldung
                              //Geräte die nicht überwacht werden sollen. Komma getrennt erfassen
                              const no_observation = 'LEQ092862x9, XXX';
                              //Instanz Cuxd ausschließen. Instanz als Zahl z. B. '1' oder bei Nichtnutzung hohe Nr eintragen z. B. '9'
                              const CUXD = '2';
                              //pro Fehlertyp kann eine andere Prio genutzt werden
                              const prio_LOWBAT = 0;
                              const prio_UNREACH = 0;
                              const prio_STICKY_UNREACH = 0;
                              const prio_CONFIG_PENDING = 0;
                              const prio_UPDATE_PENDING = 0;
                              const prio_DEVICE_IN_BOOTLOADER = 0;
                              const prio_ERROR = 0;
                              const prio_ERROR_CODE = 0;
                              const prio_FAULT_REPORTING = 0;
                              const prio_SABOTAGE= 0;
                              const prio_ERROR_NON_FLAT_POSITIONING = 0;
                              //Variablen für Servicemeldung in Objekt schreiben // Wenn einer Meldung auftritt wird diese in ein Textfeld geschrieben. z. B. für vis
                              const write_message = false;        // true schreibt beim auftreten einer Servicemeldung die Serviemeldung in ein Objekt
                              const id_Text_Servicemeldung = '';  // Objekt wo die Servicemeldung hingeschrieben werden soll (String)
                              //Variablen für Pushover
                              const sendpush = false;     //true = verschickt per Pushover Nachrchten // false = Pushover wird nicht benutzt
                              const pushover_Instanz0 =  'pushover.0';     // Pushover instance für Pio = 0
                              const pushover_Instanz1 =  'pushover.1';     // Pushover instance für Pio = 1
                              const pushover_Instanz2 =  'pushover.2';     // Pushover instance für Pio = 2
                              const pushover_Instanz3 =  'pushover.3';     // Pushover instance für Pio = -1 oder -2
                              let h_prio = -2;              //nicht verändern die höchste Prio nach Fehlertyp wird verwendet
                              let titel;
                              let message;
                              let device = 'TPhone';         //Welches Gerät soll die Nachricht bekommen
                              //let _device = 'All';
                              //Variablen für Telegram
                              const sendtelegram = true;            //true = verschickt per Telegram Nachrchten // false = Telegram wird nicht benutzt
                              const user_telegram = 'Michael';             //User der die Nachricht bekommen soll
                              //Variable zum verschicken der Servicemeldungen per eMail
                              const sendmail = false;            //true = verschickt per email Nachrchten // false = email wird nicht benutzt
                              //Ergebnis in Datenfelder schreiben
                              const write_state = true;          //Schreibt die Ergebnisse der Servicemeldungen in Datenfelder. (true = schreiben, false, kein schreiben)
                              //nicht benutzte Felder einfach leer lassen --> var id_IST_XXX = '';
                              //Müssen selber als Zahl angelegt werden
                              const id_IST_LOWBAT = 'Systemvariable.0.Servicemeldungen.Anzahl_LOWBAT'/*Anzahl LOWBAT*/;
                              const id_IST_LOW_BAT = '';
                              const id_IST_UNREACH = 'Systemvariable.0.Servicemeldungen.Anzahl_UNREACH'/*Anzahl_UNREACH*/;
                              const id_IST_STICKY_UNREACH = 'Systemvariable.0.Servicemeldungen.Anzahl_STICKY_UNREACH'/*Anzahl_STICKY_UNREACH*/;
                              const id_IST_CONFIG_PENDING = '';
                              const id_IST_UPDATE_PENDING = '';
                              const id_IST_DEVICE_IN_BOOTLOADER = '';
                              const id_IST_ERROR = '';
                              const id_IST_ERROR_NON_FLAT_POSITIONING = '';
                              const id_IST_ERROR_CODE = '';
                              const id_IST_FAULT_REPORTING = '';
                              const id_IST_SABOTAGE = '';
                              const id_IST_Gesamt = "Systemvariable.0.Servicemeldungen.Anzahl_GESAMT"/*Anzahl_GESAMT*/;
                              let timer = null;
                                 var pushover_Instanz =  'pushover.0';
                                     device: device,
                                     message: message,
                                     title: titel,
                                     priority: prio,
                                     retry: 60,
                                     expire: 600,
                                     html: 1
                                     text: message,
                                     parse_mode: 'HTML'
                                 sendTo("email", {
                                     text:    message
                                 if(token!=newtoken)
                                 return string;
                                 let status_text;
                                     if(status == 0){
                                     if(status == 0){
                                         if(status == 7){
                                         else {
                                         if(status == 1){
                                         else {
                                         if(status == 1){
                                         else {
                                     else {
                                     if(status === 0){
                                     if(status === 0){
                                     if(status === 0){
                                     if(status === 0){
                                     if(status === 0){
                                         if(status == 0){
                                         else{
                                     else{
                                 let datum_seit;
                                     datum_seit = '';
                                 }else{
                                 return(datum_seit);
                                         break;
                                         break;
                                         break;
                                         break;
                                         break;
                                         break;
                                         break;
                                         break;
                                         break;
                                         break;
                                         break;
                                         break;
                                         break;
                                         break;
                                         break;
                                         break;
                                 return(Batterie);
                                 let IST_LOWBAT = 0;
                                 let IST_ERROR = 0;
                                 let IST_Gesamt = 0;
                                 if(write_state){
                                         if(debugging){
                                     else{
                                         if(debugging){
                                 var prio = h_prio
                                 var common_name;
                                 var obj;
                                 var id_name;
                                 var native_type;
                                 var meldungsart;
                                 var Gesamt = 0;
                                 var Betroffen = 0;
                                 var id_UNREACH;
                                 if (obj) {
                                         else{
                                     else{
                                         if(debugging){
                                 else {
                                     if(logging){
                                         log('Script manuell gestartet. (Version: '+Version +')');
                                     log_manuell = true;
                                                 if(getObject(id.substring(0, id.lastIndexOf('.') - 2)).common.name){
                                                 else{
                                                     log('[Script wird gestoppt] Der Common_name-Datenpunkt ' +id +' existiert nicht.', 'warn');
                                                     return false;
                                                     ++Betroffen;
                                                     ++Betroffen_LOWBAT
                                                     else{
                                                 ++Gesamt_LOWBAT
                                             else{
                                                 return false;
                                     else{
                                         return false;
                                     if(log_manuell){
                                 else{
                                         if(write_state){
                                             if(existsObject(id_IST_LOWBAT)){
                                             else{
                                                 if(debugging){
                                         else{
                                             if(debugging){
                                     else{
                                         if(write_state){
                                             else{
                                                 if(debugging){
                                         else{
                                             if(debugging){
                                         else{
                                             return false;
                                             if(debugging){
                                             ++Betroffen;
                                             ++Betroffen_LOW_BAT
                                             else{
                                         ++Gesamt_LOW_BAT
                                     else{
                                         return false;
                                     if(log_manuell){
                                 else{
                                         if(write_state){
                                             if(existsObject(id_IST_LOW_BAT)){
                                             else{
                                                 if(debugging){
                                         else{
                                             if(debugging){
                                     else{
                                         if(write_state){
                                             else{
                                                 if(debugging){
                                         else{
                                             if(debugging){
                                                     if(debugging){
                                                     ++Betroffen;
                                                     else{
                                                 ++Gesamt_UNREACH;
                                             else{
                                                 return false;
                                     else{
                                         return false;
                                     if(log_manuell){
                                 else{
                                         if(write_state){
                                             if(existsObject(id_IST_UNREACH)){
                                             else{
                                                 if(debugging){
                                         else{
                                             if(debugging){
                                     else{
                                         if(write_state){
                                             else{
                                                 if(debugging){
                                         else{
                                             if(debugging){
                                                     ++Betroffen;
                                                             if(logging){
                                                     if(autoAck){
                                                         else{
                                                     else {
                                                         else{
                                             else{
                                                 return false;
                                     else{
                                         return false;
                                     if(log_manuell){
                                 else{
                                         if(write_state){
                                             if(existsObject(id_IST_STICKY_UNREACH)){
                                             else{
                                                 if(debugging){
                                         else{
                                             if(debugging){
                                     else{
                                         if(write_state){
                                             else{
                                                 if(debugging){
                                         else{
                                             if(debugging){
                                         if(debugging){
                                         ++Betroffen;
                                         else{
                                     ++Gesamt_SABOTAGE;
                                     if(log_manuell){
                                 else{
                                         if(write_state){
                                             if(existsObject(id_IST_SABOTAGE)){
                                             else{
                                                 if(debugging){
                                         else{
                                             if(debugging){
                                     else{
                                         if(write_state){
                                             else{
                                                 if(debugging){
                                         else{
                                             if(debugging){
                                         ++Betroffen;
                                         ++Betroffen_ERROR;
                                         else{
                                     ++Gesamt_ERROR
                                     if(log_manuell){
                                 else{
                                         if(write_state){
                                             if(existsObject(id_IST_ERROR)){
                                             else{
                                                 if(debugging){
                                         else{
                                             if(debugging){
                                     else{
                                         if(write_state){
                                             else{
                                                 if(debugging){
                                         else{
                                             if(debugging){
                                         ++Betroffen;
                                         else{
                                     if(log_manuell){
                                 else{
                                         if(write_state){
                                             if(existsObject(id_IST_ERROR_NON_FLAT_POSITIONING)){
                                             else{
                                                 if(debugging){
                                         else{
                                             if(debugging){
                                     else{
                                         if(write_state){
                                             else{
                                                 if(debugging){
                                         else{
                                             if(debugging){
                                         ++Betroffen;
                                         else{
                                     if(log_manuell){
                                 else{
                                         if(write_state){
                                             if(existsObject(id_IST_FAULT_REPORTING)){
                                             else{
                                                 if(debugging){
                                         else{
                                             if(debugging){
                                     else{
                                         if(write_state){
                                             else{
                                                 if(debugging){
                                         else{
                                             if(debugging){
                                         ++Betroffen;
                                         else{
                                     if(log_manuell){
                                 else{
                                         if(write_state){
                                             if(existsObject(id_IST_DEVICE_IN_BOOTLOADER)){
                                             else{
                                                 if(debugging){
                                         else{
                                             if(debugging){
                                     else{
                                         if(write_state){
                                             else{
                                                 if(debugging){
                                         else{
                                             if(debugging){
                                         if(debugging){
                                         ++Betroffen;
                                         else{
                                     if(log_manuell){
                                 else{
                                         if(write_state){
                                             if(existsObject(id_IST_CONFIG_PENDING)){
                                             else{
                                                 if(debugging){
                                         else{
                                             if(debugging){
                                     else{
                                         if(write_state){
                                             else{
                                                 if(debugging){
                                         else{
                                             if(debugging){
                                         if(debugging){
                                         ++Betroffen;
                                         else{
                                     if(log_manuell){
                                 else{
                                         if(write_state){
                                             if(existsObject(id_IST_UPDATE_PENDING)){
                                             else{
                                                 if(debugging){
                                         else{
                                             if(debugging){
                                     else{
                                         if(write_state){
                                             else{
                                                 if(debugging){
                                         else{
                                             if(debugging){
                                     if(debugging){
                                 if(Betroffen > 0){
                                     if(debugging){
                                     if(write_state){
                                             if(debugging){
                                         else{
                                             if(debugging){
                                     else{
                                         if(debugging){
                                     if(write_message){
                                             if(debugging){
                                         else{
                                             if(debugging){
                                             setState(id_Text_Servicemeldung,servicemeldung.join(', '));
                                     else{
                                         if(debugging){
                                         if(debugging){
                                     else{
                                     if(timer){
                                         timer = null;
                                         if(debugging){
                                         if(debugging){
                                         //else{
                                             //Push verschicken
                                                 send_mail(message);
                                     else{
                                             timer = null;
                                             if(Betroffen == 1){
                                                 if(debugging){
                                             if(Betroffen >1){
                                                 if(debugging){
                                             //Push verschicken
                                             else{
                                                     //prio = 0;
                                                     send_mail(message);
                                 else{
                                     if(write_message){
                                     if(write_state){
                                             if(debugging){
                                         else{
                                             if(debugging){
                              if(observation){
                              if(onetime){
                                 //beim Start
                                 Servicemeldung();
                              • cash
                                cash Most Active @jwerlsdf last edited by
                                @jwerlsdf said in Servicemeldungen - All inclusive für Homematic -:
                                id_IST_Gesamt
                                Hast Du dieses Objekt im Script angegeben? Und Du bekommst wirklich nur 2 Zeilen im Log? Nicht noch mehr Infos?
                                  jwerlsdf @cash last edited by
                                  @cash
                                  das ist der vollständige LOG nach einem neustart des Skriptes
                                  15:06:56.192	info	javascript.0 (3091) Stop script script.js.verschiedenes.Servicemeldungen_per_Telegram
                                  15:06:58.208	info	javascript.0 (3091) Start javascript script.js.verschiedenes.Servicemeldungen_per_Telegram
                                  15:06:59.247	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: Script manuell gestartet. (Version: 1.73)
                                  15:06:59.252	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: Es gibt: 5 Geräte mit dem Datenpunkt LOWBAT.
                                  15:06:59.253	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: [DEBUG] id_IST Feld für LOWBAT nicht gefüllt
                                  15:06:59.258	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: Es gibt: 10 Geräte mit dem Datenpunkt LOW_BAT.
                                  15:06:59.258	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: [DEBUG] id_IST Feld für LOW_BAT nicht gefüllt
                                  15:06:59.263	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: Es gibt: 18 Geräte mit dem Datenpunkt UNREACH.
                                  15:06:59.263	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: [DEBUG] id_IST Feld für UNREACH nicht gefüllt
                                  15:06:59.266	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: Es gibt: 5 Geräte mit dem Datenpunkt STICKY_UNREACH.
                                  15:06:59.266	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: [DEBUG] id_IST Feld für STICKY_UNREACH nicht gefüllt
                                  15:06:59.267	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: Keine Geräte gefunden mit dem Datenpunkt SABOTAGE.
                                  15:06:59.268	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: Es gibt: 2 Geräte mit dem Datenpunkt ERROR.
                                  15:06:59.268	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: [DEBUG] id_IST Feld für ERROR nicht gefüllt
                                  15:06:59.268	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: Keine Geräte gefunden mit dem Datenpunkt ERROR_NON_FLAT_POSITIONING.
                                  15:06:59.269	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: Keine Geräte gefunden mit dem Datenpunkt FAULT_REPORTING.
                                  15:06:59.270	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: Es gibt: 3 Geräte mit dem Datenpunkt DEVICE_IN_BOOTLOADER.
                                  15:06:59.270	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: [DEBUG] id_IST Feld für DEVICE_IN_BOOTLOADER nicht gefüllt
                                  15:06:59.274	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: Es gibt: 18 Geräte mit dem Datenpunkt CONFIG_PENDING.
                                  15:06:59.275	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: [DEBUG] id_IST Feld für CONFIG_PENDING nicht gefüllt
                                  15:06:59.279	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: Es gibt: 16 Geräte mit dem Datenpunkt UPDATE_PENDING.
                                  15:06:59.279	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: [DEBUG] id_IST Feld für UPDATE_PENDING nicht gefüllt
                                  15:06:59.280	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: 77 Datenpunkte werden insgesamt vom Script script.js.verschiedenes.Servicemeldungen_per_Telegram (Version: 1.73) überwacht. Instance: 0
                                  15:06:59.280	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: logging: true debugging: true find_bug: false show_each_device: false autoAck: true observation: true ohnetime: true CUXD: 2
                                  15:06:59.280	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: [DEBUG] Derzeitige keine Servicemeldungen. Ergebnis in Objekt geschrieben
                                  15:06:59.282	warn	javascript.0 (3091) at Servicemeldung (script.js.verschiedenes.Servicemeldungen_per_Telegram:2135:17)
                                  15:06:59.283	warn	javascript.0 (3091) at script.js.verschiedenes.Servicemeldungen_per_Telegram:2185:5
                                  15:06:59.283	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: registered 80 subscriptions and 0 schedules
                                  • cash
                                    @jwerlsdf Stell mal Zeile 149 auf false. Ich vermute Du hast den Datenpunkt nicht angelegt!?
                                      @cash
                                      Danke schon mal für die Rückmeldung!
                                      Das ist nun der LOG-Eintrag. Es gibt erst mal keine warn Meldung mehr. Datenpunkt anlegen, d.h. genau? Was/ Wie muss ich das machen?
                                      19:07:08.468	info	javascript.0 (3091) Stop script script.js.verschiedenes.Servicemeldungen_per_Telegram
                                      19:07:11.207	info	javascript.0 (3091) Start javascript script.js.verschiedenes.Servicemeldungen_per_Telegram
                                      19:07:12.234	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: Script manuell gestartet. (Version: 1.73)
                                      19:07:12.237	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: Es gibt: 5 Geräte mit dem Datenpunkt LOWBAT.
                                      19:07:12.237	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: [DEBUG] Variable write_state steht auf false
                                      19:07:12.242	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: Es gibt: 10 Geräte mit dem Datenpunkt LOW_BAT.
                                      19:07:12.242	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: [DEBUG] Variable write_state steht auf false
                                      19:07:12.246	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: Es gibt: 18 Geräte mit dem Datenpunkt UNREACH.
                                      19:07:12.246	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: [DEBUG] Variable write_state steht auf false
                                      19:07:12.248	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: Es gibt: 5 Geräte mit dem Datenpunkt STICKY_UNREACH.
                                      19:07:12.248	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: [DEBUG] Variable write_state steht auf false
                                      19:07:12.248	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: Keine Geräte gefunden mit dem Datenpunkt SABOTAGE.
                                      19:07:12.249	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: Es gibt: 2 Geräte mit dem Datenpunkt ERROR.
                                      19:07:12.249	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: [DEBUG] Variable write_state steht auf false
                                      19:07:12.250	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: Keine Geräte gefunden mit dem Datenpunkt ERROR_NON_FLAT_POSITIONING.
                                      19:07:12.250	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: Keine Geräte gefunden mit dem Datenpunkt FAULT_REPORTING.
                                      19:07:12.251	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: Es gibt: 3 Geräte mit dem Datenpunkt DEVICE_IN_BOOTLOADER.
                                      19:07:12.251	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: [DEBUG] Variable write_state steht auf false
                                      19:07:12.255	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: Es gibt: 18 Geräte mit dem Datenpunkt CONFIG_PENDING.
                                      19:07:12.255	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: [DEBUG] Variable write_state steht auf false
                                      19:07:12.259	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: Es gibt: 16 Geräte mit dem Datenpunkt UPDATE_PENDING.
                                      19:07:12.259	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: [DEBUG] Variable write_state steht auf false
                                      19:07:12.260	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: 77 Datenpunkte werden insgesamt vom Script script.js.verschiedenes.Servicemeldungen_per_Telegram (Version: 1.73) überwacht. Instance: 0
                                      19:07:12.260	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: logging: true debugging: true find_bug: false show_each_device: false autoAck: true observation: true ohnetime: true CUXD: 2
                                      19:07:12.260	info	javascript.0 (3091) script.js.verschiedenes.Servicemeldungen_per_Telegram: registered 80 subscriptions and 0 schedules
                                      • cash
                                        @jwerlsdf Also erstmal in der Zeile wo debug = true steht bitte ändern auf false...
                                        Das Script verschickt nicht nur per mail, Pushover oder Telegram Servicemeldungen sondern Du kannst das ganze auch nutzen um es zu visualisieren. Manche nutzen vis um ioBroker zu bedienen. Man kann nun selber Datenpunkte anlgegen und dort z. B. die Anzahl der Servicemeldungen reinzuschreiben oder einen anderen um das was man als Pushover, Telegram Nachricht bekommt auch in einen Datenpunkt zu schreiben. Und genau das muss man in dem Script konfigurieren. Nutzt man das nicht sollte man manche Punkte im Script mit „false“ ausschalten. Andernfalls bekommst Du eine Fehlermeldung. Was ja logisch ist. Das Script wollte bei Dir das Feld „Anzahl Servicemeldungen“ mit einer 0 belegen. Das geht aber nicht, da es das Feld bei Dir nicht gibt.
                                          jwerlsdf @cash last edited by jwerlsdf
                                          @cash
                                          Dann nur zu meinem Verständnis: Ich brauche nur auf false abzuändern, sonst muss ich nichts weiter ändern, wenn ich nur die Fehlermeldungen per Telegram bekommen möchte?!
                                          Und noch eine zweite Frage zu folgenden Zeilen:
                                          function send_telegram (message, user_telegram) {
                                          sendTo('telegram.0', {
                                          text: message,
                                          user: user_telegram,
                                          parse_mode: 'HTML'
                                          wenn ich user_telegram lösche und mit z.B. meinem Telegramnamen ersetze, bekomme ich nur die Fehlermeldungen und nicht noch die anderen?!
                                          • cash
                                            @jwerlsdf user_telegram sollst Du aber dort nicht löschen sondern oben in der Config angeben. Dann ersetzt das Script es an der Stelle und es funktioniert auch alles...
                                            Richtig der Wert auf false und er schreibt keine Daten. Du solltes Dir alle Konfig-Schalter angucken und so einstellen wie Du es willst....
                                            Was heißt Du bekommst nicht alles per Telegram?
                                            javascript
                                            93
                                            1038
                                            285433
