      sigi234 Forum Testing Most Active @s.bormann last edited by sigi234
      @s-bormann
      Hallo, bekomme immer diese Meldung: Immer wenn ich auf speichern klicke, egal ob ich was ändere oder nicht.
      Version 1.1.0 in C:/Program Files/iobroker/Test/node_modules/iobroker.iqontrol, node: v12.18.0, js-controller: 3.1.5
      web.0	2020-06-14 13:24:51.236	warn	(15220) readDir will not read this directory () in future versions: undefined
      web.0	2020-06-14 13:24:50.718	info	(15220) ==>Connected system.user.admin from ::1
      web.0	2020-06-14 13:24:49.742	info	(15220) <==Disconnect system.user.admin from ::1 iqontrol.meta
      iqontrol.0	2020-06-14 13:24:47.900	debug	(13700) Adapter Object IDs: 0 ()
      iqontrol.0	2020-06-14 13:24:47.899	debug	(13700) Got Adapter Objects
      iqontrol.0	2020-06-14 13:24:47.856	info	(13700) iQontrol ready.
      iqontrol.0	2020-06-14 13:24:47.855	info	(13700) Deleting unused Objects...
      iqontrol.0	2020-06-14 13:24:47.842	info	(13700) starting. Version 1.1.0 in C:/Program Files/iobroker/Test/node_modules/iobroker.iqontrol, node: v12.18.0, js-controller: 3.1.5
      iqontrol.0	2020-06-14 13:24:47.689	debug	(13700) statesDB connected
      iqontrol.0	2020-06-14 13:24:47.689	debug	(13700) States connected to redis: 127.0.0.1:9000
      iqontrol.0	2020-06-14 13:24:47.678	debug	(13700) States create System PubSub Client
      iqontrol.0	2020-06-14 13:24:47.677	debug	(13700) States create User PubSub Client
      iqontrol.0	2020-06-14 13:24:47.671	debug	(13700) Redis States: Use Redis connection: 127.0.0.1:9000
      iqontrol.0	2020-06-14 13:24:47.670	debug	(13700) objectDB connected
      iqontrol.0	2020-06-14 13:24:47.668	debug	(13700) Objects connected to redis: 127.0.0.1:9013
      iqontrol.0	2020-06-14 13:24:47.654	debug	(13700) Objects client initialize lua scripts
      iqontrol.0	2020-06-14 13:24:47.654	debug	(13700) Objects create User PubSub Client
      iqontrol.0	2020-06-14 13:24:47.653	debug	(13700) Objects create System PubSub Client
      iqontrol.0	2020-06-14 13:24:47.652	debug	(13700) Objects client ready ... initialize now
      iqontrol.0	2020-06-14 13:24:47.635	debug	(13700) Redis Objects: Use Redis connection: 127.0.0.1:9013
      • s.bormann
        s.bormann Most Active @rebel85 last edited by
        @rebel85 sagte in Test Adapter iQontrol 1.1.x:
        hi,
        wie kann ich in den kachel den wert 0% anzeigen lassen?
        wenn die quelle der werte ausgabe 0% hat sagt iqontrol in der kachel "Aus" das irritiert da die ausgabe eine % Last ausgabe ist und unter Aus auch zu verstehen währe das die maschine aus ist ....
        da gibt es doich bestimmt einen trick 17 oder?
        kann mir da jemand mal bitte kuzrz sagen wie ich das hin bekomme ?
        danke
        ich glaube, mir ist doch was eingefallen. iQontrol interpretiert den Wert "0%" als "aus".
        Der Wert "0% " (leerzeichen dahinter" müsste dieser Prüfung entgehen.
        Probier mal folgendes: Geh auf den Schraubenschlüssel für den Datenpunkt und gib bei iQontrol als Einheit beim Wert 0 "% " mit Leerzeichen dahinter an. Falls das nicht geht, nimmt statt des Leerzeichens "&nbps;", das steht in HTML für ein Leerzeichen. Vielleicht geht das (habs nicht probiert). Sag mal bescheid!
        VG!
        • metaxa
          metaxa @s.bormann last edited by metaxa
          @s-bormann sagte in Test Adapter iQontrol 1.1.x:
          Die entsprechende Variable ist dann (zumindest bei Chrome) rot unterstrichen.
          Wo soll ich jetzt mit der Maus drauffahren?
          LG
          • s.bormann
            s.bormann Most Active @sigi234 last edited by
            @sigi234 Ja, bekomme ich auch. Ein issue bei admin ist angelegt - vermutlich wird es in der nächsten größeren Admin-Version behoben sein. Aktuell gibt es keinen mir bekannten Workaround.
              Ok, Danke für die Info.
              • s.bormann
                s.bormann Most Active @metaxa last edited by
                Da drauf klicken, dann mit der Maus auf dir rote Unterstreichung im Code fahren, wenn es eine gibt.
                metaxa 1 Reply Last reply Reply Quote 1
                • metaxa
                  • s.bormann
                    @metaxa Hi, kannst Du mal die aktuelle Version von Github installieren? Danach Upload nicht vergessen, Browser-Cache leeren etc. (siehe Troubleshooting-Sektion in der iQontrol-Readme). Gehts damit?
                    • metaxa
                      @s-bormann vorab mal zwischendurch danke für deine Mühen zu helfen!
                      Upload und Cache geleert, Browser geschlossen, neu gestartet. Leider nein in FF, leider nein in Chrome. Aber eine andere Nummer "index.js:2613".
                      LG
                      • s.bormann
                        @metaxa Ok, dann sind wir aber schon fast am Ziel.
                        Jetzt wirds noch mal etwas komplizierter:
                        Wenn der Fehler aufgetreten ist, dann markiere bitte mal in der Zeile 2613
                        (var deviceLinkedViewName = config[namespace].views[getViewIndex(deviceLinkedViewId)].commonName;')
                        einzeln folgende Bereiche mit der Maus und poste, was der Inhalt ist (wird dann beim drüber fahren angezeigt):
                        • deviceLinkedViewId
                        • getViewIndex(deviceLinkedViewId)
                        • config[namespace].views[getViewIndex(deviceLinkedViewId)]
                        metaxa 1 Reply Last reply Reply Quote 0
                        • metaxa
                          Sebastian, sorry! Da kommt nix bei MouseOver
                          bei keinem der Bereiche. In FF nicht und auch nicht in Chrome, meine Maus schweigt sich aus 😞
                          Einzig mit rechtsklick kann ich das Kontextmenü öffnen.
                          • s.bormann
                            @metaxa Hmm, schade. Habe jetzt eine Abfrage eingebaut, die alle Variablen auf Gültigkeit prüft. Hoffe, damit läuft es jetzt. Versuchs mal mit der aktuellen Version von Github.
                            • metaxa
                              😞 , aber jetzt ist der drehende Kreis auf dem Mamorhintergrund zu sehen, der ist jetzt neu.
                              Die angemeckerte Zeile hat wieder eine neue Nummer und sieht anders aus.
                              • s.bormann
                                @metaxa Ok, nächster Versuch auf Github 🙂
                                Wir kriegen es schon noch hin... muss nur bald weg, ggf. müssen wir die Tage dann weiter sehen. Aber einen Versuch machen wir noch 🙂
                                metaxa 2 Replies Last reply Reply Quote 1
                                • metaxa
                                  @s-bormann 🙂 + 👍 +💋 bin schon am installieren
                                  • metaxa
                                    @s-bormann 👍 👍 👍 👍 👍 👍 Bingo!
                                    Läuft in FF und Chrome tadellos, danke für deine Megageduld!
                                    Lieben Dank Sebastian
                                    s.bormann 1 Reply Last reply Reply Quote 1
                                    • s.bormann
                                      @metaxa Juhu, zum Glück. Dann viel Spaß damit! VG!
                                      • frankthegreat
                                        frankthegreat @s.bormann last edited by
                                        @frankthegreat Hi, die Playlist von iQontrol kann eine Value-List auslesen. D.h. man könnte im favorites_set-Datenpunkt eine Value-List anlegen (über den Schraubenschlüssel) mit allen zur Verfügung stehenden Einträgen. Dann bekommt man in iQontrol ein Drop-Down. Man muss allerdings die Value-Liste dann von Hand erstellen, das ist der Nachteil. Wäre aber ein Workaround, bis mir was besseres eingefallen ist.
                                        Hier auch alles im grünen Bereich 😊
                                        Läuft super, danke nochmal 👍
                                          blackeagle998 last edited by
                                          @s-bormann
                                          Hattest du das state Icon (Play/pause) verschoben?
                                          Ist bei mir noch an der gleichen Stelle wie vorher, deswegen wollte ich nochmal kurz nachfragen?!
                                          Ansonsten ist der Mediaplayer einfach super!
                                            Mac_Schmeck last edited by
                                            Hallo.
                                            Ich habe mir Mal iqontrol 1.0 raufgemacht aber leider wie auch schon jemand anderes kommt nur der Sicht drehende Kreis und weiter geht es nicht.
                                            Im Web Adapter steht auf integriert und der Haken bei nur web Sockets ist auch raus.
                                            Hat noch jemand eine Idee? Bin noch Einsteiger.
                                            F metaxa 2 Replies Last reply Reply Quote 1
                                            296
                                            7637
                                            7002301
