    4. FHEM Adapter
    FHEM Adapter
      Robin82 last edited by
      @LausiD
      Besten Dank, hat geklappt!
      • LausiD
        LausiD last edited by
        @Robin82
        Prima.....vielen Dank für die Rückmeldung.
        Demnächst sollte V1.5.3 am Start sein..
        Gruß LausiD
          Scooty last edited by Scooty
          Hallo @LausiD,
          erst einmal Danke für Deine Arbeit.
          Hatte Version 1.3.0 am Start und nun auf 1.5.3 aktualisiert.
          Instanz bekommt aber leider keine Verbindung zu FHEM hin:
          -Verbunden mit Host: wahr
          -Lebenszeichen: wahr
          -Verbunden mit Host: falsch
          Wiederholt kommt im Log jetzt:
          fhem.0	2020-06-12 11:32:31.570	error	(1587) TypeError: Cannot read property 'val' of null at adapter.getForeignStates (/opt/iobroker/node_modules/iobroker.fhem/main.js:573:41) at adapterStates.getStates (/opt/iobroker/node_module
          fhem.0	2020-06-12 11:32:31.569	error	(1587) uncaught exception: Cannot read property 'val' of null
          fhem.0	2020-06-12 11:31:56.856	error	at process._tickCallback (internal/process/next_tick.js:68:7)
          fhem.0	2020-06-12 11:31:56.856	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
          fhem.0	2020-06-12 11:31:56.856	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
          fhem.0	2020-06-12 11:31:56.856	error	at client.mget (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:673:13)
          fhem.0	2020-06-12 11:31:56.856	error	at adapterStates.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6757:17)
          fhem.0	2020-06-12 11:31:56.856	error	at adapter.getForeignStates (/opt/iobroker/node_modules/iobroker.fhem/main.js:573:41)
          fhem.0	2020-06-12 11:31:56.856	error	(1572) TypeError: Cannot read property 'val' of null
          fhem.0	2020-06-12 11:31:56.856	error	(1572) uncaught exception: Cannot read property 'val' of null
          fhem.0	2020-06-12 11:31:21.766	error	at process._tickCallback (internal/process/next_tick.js:68:7)
          fhem.0	2020-06-12 11:31:21.766	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
          fhem.0	2020-06-12 11:31:21.766	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
          fhem.0	2020-06-12 11:31:21.766	error	at client.mget (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:673:13)
          fhem.0	2020-06-12 11:31:21.766	error	at adapterStates.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6757:17)
          fhem.0	2020-06-12 11:31:21.766	error	at adapter.getForeignStates (/opt/iobroker/node_modules/iobroker.fhem/main.js:573:41)
          fhem.0	2020-06-12 11:31:21.766	error	(1557) TypeError: Cannot read property 'val' of null
          fhem.0	2020-06-12 11:31:21.754	error	(1557) uncaught exception: Cannot read property 'val' of null
          Objekt-Tabelle wurde jedoch nach und nach gefüllt.
          Zurück auf 1.3.0 gibt leider die gleichen Fehler.
          Kann ich noch weitere Infos liefern um den Fehler einzugrenzen?
          Viele Grüße,
          Andreas
          • LausiD
            @Scooty
            Hi Andreas,
            du hast die Version 1.5.2 von github, oder?
            Läuft der Adapter beim Start bis STEP 6?
            Hast du unter fhem.0.info.Configurations.allowedIOBin ( Übertrag ioBroker zu FHEM) einen Eintrag?
            Gruß LausiD
              Scooty @LausiD last edited by
              @LausiD
              Danke für die prompte Reaktion.
              Ja, direkt aus github, Version 1.5.3: https://github.com/iobroker-community-adapters/ioBroker.fhem
              Ja, Abbruch lt. Log nach/bei STEP 6.
              fhem.0	2020-06-12 12:43:01.529	warn	(3399) TypeError: Cannot read property 'val' of null
              fhem.0	2020-06-12 12:43:01.522	warn	(3399) Exception: TypeError: Cannot read property 'val' of null
              fhem.0	2020-06-12 12:43:01.504	info	(3399) > detected 9 state(s) of "vw-connect.0.TMBJW7NP7L70XXXXX.remote"
              fhem.0	2020-06-12 12:43:01.185	info	(3399) STEP 06 ===== check Subscribe - check fhem.0.info.Configurations.allowedIOBin
              Bingo, das scheint's zu sein, ohne Einträge in fhem.0.info.Configurations.allowedIOBin startet der Adapter.
              fhem.0	2020-06-12 12:49:26.731	info	(3455) END ===== Synchronised FHEM in 10199 ms :-)
              Hat sich die Syntax geändert? Ist doch eine Liste komma-separierter Einträge aus der Objekttabelle, oder ?
              Gerade getestet, Probleme sind wohl wie auch oben im Log ersichtlich die Objekte des VW-Connect Adapters.
              Viele Grüße,
              Andreas
              LausiD 1 Reply Last reply Reply Quote 0
              • LausiD
                LausiD last edited by LausiD
                @Scooty
                Von github kommt noch V 1.5.2 oder?
                Ok Fehler erkannt....in den Objekten von vw-connect sind states ohne val (Wert)
                Muss ich noch ändern 🙂
                Gruß LausiD
                  @LausiD said in FHEM Adapter:
                  Ups, ja, von github ist Version 1.5.2
                  Alles klar, danke für die Unterstützung.
                  Viele Grüße,
                  Andreas
                    pole23 last edited by
                    ich habe gerade den Adapter installiert und mir ist dabei aufgefallen, das der Adapter bei KNX Geräten leider kein "state_switch" Objekt im ioBroker anlegt. Daduch kann ich in der VIS einige Toggles nicht benutzen.
                    ein jsonlist2 vom KNX Device sieht wie folgt aus:
                      "Arg":"bu_LichtDecke",
                      "Results": [
                        "Name":"bu_LichtDecke",
                        "PossibleSets":"g1:off,on",
                        "PossibleAttrs":"alias comment:textField-long eventMap:textField-long group room suppressReading userReadings:textField-long verbose:0,1,2,3,4,5 IODev do_not_notify:1,0 showtime:1,0 answerReading:1,0 stateRegex:textField-long stateCmd:textField-long putCmd:textField-long format listenonly:1,0 readonly:1,0 slider useSetExtensions:1,0 event-aggregator event-min-interval event-on-change-reading event-on-update-reading oldreadings stateFormat:textField-long timestamp-on-change-reading  DbLogExclude DbLogInclude DbLogValueFn:textField-long alarmDevice:Actor,Sensor alarmSettings alexaName alexaProactiveEvents:1,0 alexaRoom cmdIcon devStateIcon devStateIcon:textField-long devStateStyle genericDeviceType:security,ignore,switch,outlet,light,blind,thermometer,TemperatureSensor,thermostat,contact,garage,window,lock,MotionSensor,speaker homebridgeMapping:textField-long icon siriName sortby webCmd webCmdLabel:textField-long widgetOverride userattr",
                        "Internals": {
                          "DEF": "1/0/40:dpt1.001",
                          "DEVNAME": "bu_LichtDecke",
                          "FIRSTGADNAME": "g1",
                          "FUUID": "5c7bd032-f33f-6f0b-03c9-1fd93b0796862f01",
                          "GETSTRING": "g1:noArg",
                          "KNX_MSGCNT": "17",
                          "KNX_RAWMSG": "C0113cw0102800",
                          "KNX_TIME": "2020-06-14 09:57:42",
                          "LASTInputDev": "KNX",
                          "MSGCNT": "17",
                          "NAME": "bu_LichtDecke",
                          "NR": "92",
                          "NTFY_ORDER": "50-bu_LichtDecke",
                          "SETSTRING": "g1:off,on",
                          "STATE": "off",
                          "TYPE": "KNX"
                        "Readings": {
                          "getG1": { "Value":"off", "Time":"2020-06-14 09:57:42" },
                          "last-sender": { "Value":"1/1/60", "Time":"2020-06-14 09:57:42" },
                          "setG1": { "Value":"off", "Time":"2020-06-13 16:37:03" },
                          "state": { "Value":"off", "Time":"2020-06-14 09:57:42" }
                        "Attributes": {
                          "DbLogExclude": ".*",
                          "IODev": "KNX",
                          "alexaName": "Deckenlicht",
                          "alexaRoom": "Büro",
                          "alias": "Deckenlicht",
                          "devStateIcon": "off:light_light_dim_00 on:light_light_dim_100@orange",
                          "genericDeviceType": "light",
                          "group": "Licht",
                          "homebridgeMapping": "On=state,valueOn=on,valueOff=off,cmdOn=g1+on,cmdOff=g1+off",
                          "icon": "light_ceiling_light",
                          "room": "Buero,Homekit,alexa,ioBroker",
                          "siriName": "Deckenlicht"
                      "totalResultsReturned":1
                    Im ioBroker sieht es wie folgt aus:
                    Wäre es möglich, dies noch in den Adapter mit einzubauen?
                      Homoran Global Moderator Administrators @pole23 last edited by
                      @pole23 geht es um den KNX-Adapter oder den FHEM Adapter?
                        Hallo, es geht um den FHEM Adapter.
                        • LausiD
                          @pole23 sagte in FHEM Adapter:
                          Um ein state_switch anzulegen müsste hier on und off definiert sein.
                          Ist das Device bu_LichtDecke von FHEM so angelegt oder hast du manuell was geändert?
                          Sorry, KNX habe ich hier nicht 😞
                          Schaltest du mit g1 off?
                          Gruß LausiD
                            Das Device wurde so von FHEM angelegt. Ich kann es innerhalb von FHEM mit „set bu_LichtDecke on“ und „set bu_LichtDecke g1 on“ schalten.
                            • LausiD
                              LausiD @pole23 last edited by LausiD
                              Und mit was schaltest du in FHEM aus?
                              Eine Möglichkeit die immer geht 🙂
                              Du legst ein dummy als Schalter an ( sehr einfach mit fhem.0.info.Commands.createSwitch) und machst in FHEM ein kleines notify dazu -> fertig
                              Gruß LausiD
                              • LausiD
                                LausiD @Scooty last edited by
                                @Scooty sagte in FHEM Adapter:
                                Kannst du mal bitte mit Update von github versuchen...Danke 🙂
                                  pole23 @LausiD last edited by
                                  @LausiD Ich schalte mit „set bu_LichtDecke on“ die Devices an und aus. Ich bin aber der Meinung, dass das mit einer älteren Version des Adapters funktioniert hatte. Ich muss mal schauen, ob ich das noch rausbekomme, welche das genau war.
                                    Nach Update startet die Instanz nun ohne Probleme👍 :
                                    (4631) END ===== Synchronised FHEM in 65238 ms :-)
                                    Klasse, vielen Dank, sollte bei weiteren Tests noch etwas auffallen, melde ich mich (ist keine Drohung 😉) .
                                    Viele Grüße,
                                    Andreas
                                      Hallo @LausiD,
                                      tja, da bin ich schon wieder.
                                      Leider schaffe ich es, durch eine Aktion in FHEM die FHEM-Instanz in IOBroker abzuschiessen (Neustart erfolgt aber zuverlässig).
                                      Möchte die Bedienung aus FHEM etwas komfortabler gestalten, daher habe ich im FHEM-Device "fhem.0.send2ioB" eine setList definiert (RAW-Definition):
                                      attr fhem.0.send2ioB setList vw-connect.0.TMBJW7NP7L70XXXXX.remote.batterycharge:true,false\
                                      vw-connect.0.TMBJW7NP7L70XXXXX.remote.climatisation:true,false\
                                      vw-connect.0.TMBJW7NP7L70XXXXX.remote.flash:true,false\
                                      vw-connect.0.TMBJW7NP7L70XXXXX.remote.honk:true,false\
                                      vw-connect.0.TMBJW7NP7L70XXXXX.remote.lock:true,false\
                                      vw-connect.0.TMBJW7NP7L70XXXXX.remote.standheizung:true,false\
                                      vw-connect.0.TMBJW7NP7L70XXXXX.remote.windowheating:true,false\
                                      chromecast.0.SZDG_GHOME01.status.volume:slider,0,5,100,1\
                                      chromecast.0.SZDG_GHOME01.player.stop:true,false\
                                      chromecast.0.SZDG_GHOME01.player.pause:true,false\
                                      chromecast.0.SZDG_GHOME01.player.play:true
                                      Kann es sein, dass beim Speichern von Änderungen dieser setList FHEM wohl einen Event erzeugt, den der FHEM-Adapter in IOBRoker nicht verträgt (s. letzte Zeile im Log):
                                      fhem.0	2020-06-15 12:02:37.362	info	(4782) Terminated (NO_ERROR): Without reason
                                      fhem.0	2020-06-15 12:02:37.361	info	(4782) terminating
                                      fhem.0	2020-06-15 12:02:37.353	debug	(4782) [stateChange] stateChange (in): fhem.0.info.Info.alive false {"val":false,"ack":true,"ts":1592215357339,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1592215357339}
                                      fhem.0	2020-06-15 12:02:37.351	debug	(4782) [stateChange] stateChange (in): fhem.0.info.connection false {"val":false,"ack":true,"ts":1592215357338,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1592215357338}
                                      fhem.0	2020-06-15 12:02:37.334	debug	(4782) adapter.on.unload: clearTimeout getAlive
                                      fhem.0	2020-06-15 12:02:37.333	debug	(4782) adapter.on.unload: clearTimeout setAlive
                                      fhem.0	2020-06-15 12:02:37.332	error	(4782) ReferenceError: channel is not defined at parseEvent (/opt/iobroker/node_modules/iobroker.fhem/main.js:2317:29) at processEvent (/opt/iobroker/node_modules/iobroker.fhem/main.js:2304:5)
                                      fhem.0	2020-06-15 12:02:37.331	error	(4782) uncaught exception: channel is not defined
                                      fhem.0	2020-06-15 12:02:37.329	warn	(4782) ReferenceError: channel is not defined at parseEvent (/opt/iobroker/node_modules/iobroker.fhem/main.js:2317:29) at processEvent (/opt/iobroker/node_modules/iobroker.fhem/main.js:2304:5)
                                      fhem.0	2020-06-15 12:02:37.326	warn	(4782) Exception: ReferenceError: channel is not defined
                                      fhem.0	2020-06-15 12:02:37.325	debug	(4782) [main] [eventFHEM] eventFHEM(in): "vw-connect.0.TMBJW7NP7L7057941.remote.climatisation:true,false"
                                      Zwei weitere Dinge:
                                      • Beim Neustart der FHEM-Instanz werden wohl alle IOBroker Devices in FHEM gelöscht und wieder neu angelegt? Ist das so gewollt? Damit werden leider auch alle von mir zwischenzeitlich geänderten Attribute (wie z.B. "room") auf Standard zurückgesetzt. Oder habe ich ein Verständnisproblem und sollte nicht mit den nativen IOBroker-Devices in FHEM arbeiten?
                                        Edit: Betrifft ggf. nur das "room" Attribut, Attribut "userReadings" bleibt bestehen.
                                      • Zumindest die "vw-connect" Objekte werden in FHEM mit einem "_" statt dem "-" im FHEM-Devicenamen angelegt, also z.B.
                                      #in FHEM
                                      vw_connect.0.TMBJW7NP7L70XXXXX.remote.climatisation
                                      # in IOBroker
                                      vw-connect.0.TMBJW7NP7L70XXXX.remote.climatisation
                                      Führte bei mir ein wenig zu Verwirrung, weil man in FHEM bei einem
                                      set fhem.0.send2ioB
                                      nicht den FHEM-Devicenamen sondern den IOBroker Objektnamen verwenden muss.
                                      Weißt Du, warum das "-" durch das "_" beim Anlage des Devices in FHEM ersetzt wird?
                                      Vielen Dank und Grüße,
                                      Andreas
                                      PS: Sorry, keine Ahnung woher dieses "Select all" in den Code-Bereichen herkommt....
                                      • LausiD
                                        Stimmt 😞 Nach Update von github sollte Absturz erledigt sein
                                        Werden nicht gelöscht jedoch im Raum ioB_IN erwartet.
                                        Zusätzlich zum Raum ioB_IN einen weiteren Raum zuordnen sollte gehen
                                        In FHEM darf der Device Name kein "-" enthalten, deshalb erfolgt die Umwandlung in "_"
                                        Vielen Dank für Deine Rückmeldung und Gruß
                                        LausiD
                                        • LausiD
                                          Sorry, verstehe ich nicht so ganz.
                                          Mit „set bu_LichtDecke on“ schaltest du im Wechsel an/aus?
                                          Wofür brauchst du dann ein state_switch?
                                          LausiD
                                            @LausiD Sorry, da habe ich mich falsch ausgedrückt. Ich schalte mit "set bu_LichtDecke on" die Lampe an und mit "set bu_LichtDecke off" die Lampe wieder aus. Daher würde hier ein Switch sinn machen, da ich sonst in der VIS ein Problem mit den Toggle habe.
                                            1.2k
                                            81.1k
                                            adapter fhem
                                            82
                                            676
                                            194200
