    4. js-controller 3.0/3.1 jetzt im Latest!
      apollon77 @UweRLP last edited by
      @UweRLP Am besten wäre es
      • Ins Verzeichnis des adapter swechseln ... also vom ioBroker verzeichnis aus in node_modules/iobroker.javascript wechseln
      • "npm install --production"
      gehts danach
      UweRLP 1 Reply Last reply Reply Quote 0
      • JackDaniel
        JackDaniel last edited by JackDaniel
        bei mir das selbe nach dem js-controller update mit dem javascript adapter aber unter linux
        das "npm install --production" hat bei mir keine verbesserung gebracht
        host.raspberrypi	2020-06-08 19:28:53.785	info	Restart adapter system.adapter.javascript.0 because enabled
        host.raspberrypi	2020-06-08 19:28:53.785	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.raspberrypi	2020-06-08 19:28:53.784	error	Caught by controller[0]: }
        host.raspberrypi	2020-06-08 19:28:53.784	error	Caught by controller[0]: ]
        host.raspberrypi	2020-06-08 19:28:53.784	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
        host.raspberrypi	2020-06-08 19:28:53.783	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/index.js',
        host.raspberrypi	2020-06-08 19:28:53.783	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/compiler.js',
        host.raspberrypi	2020-06-08 19:28:53.783	error	Caught by controller[0]: requireStack: [
        host.raspberrypi	2020-06-08 19:28:53.782	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        host.raspberrypi	2020-06-08 19:28:53.782	error	Caught by controller[0]: {
        host.raspberrypi	2020-06-08 19:28:53.782	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
        host.raspberrypi	2020-06-08 19:28:53.782	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)
        host.raspberrypi	2020-06-08 19:28:53.781	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
        host.raspberrypi	2020-06-08 19:28:53.781	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
        host.raspberrypi	2020-06-08 19:28:53.781	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
        host.raspberrypi	2020-06-08 19:28:53.780	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
        host.raspberrypi	2020-06-08 19:28:53.780	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
        host.raspberrypi	2020-06-08 19:28:53.780	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
        host.raspberrypi	2020-06-08 19:28:53.779	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
        host.raspberrypi	2020-06-08 19:28:53.779	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
        host.raspberrypi	2020-06-08 19:28:53.779	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
        host.raspberrypi	2020-06-08 19:28:53.778	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
        host.raspberrypi	2020-06-08 19:28:53.778	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
        host.raspberrypi	2020-06-08 19:28:53.778	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/index.js:3:18)
        host.raspberrypi	2020-06-08 19:28:53.777	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
        host.raspberrypi	2020-06-08 19:28:53.777	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
        host.raspberrypi	2020-06-08 19:28:53.777	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
        host.raspberrypi	2020-06-08 19:28:53.776	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
        host.raspberrypi	2020-06-08 19:28:53.776	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
        host.raspberrypi	2020-06-08 19:28:53.776	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
        host.raspberrypi	2020-06-08 19:28:53.775	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/compiler.js:3:10)
        host.raspberrypi	2020-06-08 19:28:53.775	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
        host.raspberrypi	2020-06-08 19:28:53.775	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
        host.raspberrypi	2020-06-08 19:28:53.774	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:842:27)
        host.raspberrypi	2020-06-08 19:28:53.773	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:966:15)
        host.raspberrypi	2020-06-08 19:28:53.773	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
        host.raspberrypi	2020-06-08 19:28:53.773	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/index.js
        host.raspberrypi	2020-06-08 19:28:53.772	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/compiler.js
        host.raspberrypi	2020-06-08 19:28:53.772	error	Caught by controller[0]: Require stack:
        host.raspberrypi	2020-06-08 19:28:53.771	error	Caught by controller[0]: Error: Cannot find module 'typescript'
        host.raspberrypi	2020-06-08 19:28:53.771	error	Caught by controller[0]: ^
        host.raspberrypi	2020-06-08 19:28:53.770	error	Caught by controller[0]: throw err;
        host.raspberrypi	2020-06-08 19:28:53.769	error	Caught by controller[0]: internal/modules/cjs/loader.js:969
        host.raspberrypi	2020-06-08 19:28:53.443	info	instance system.adapter.javascript.0 started with pid 6547
        host.raspberrypi	2020-06-08 19:28:53.384	info	"system.adapter.javascript.0" enabled
        edit:
        hab den adapter nochmal beendet und dann erneut mit:
        cd /opt/iobroker/node_modules/iobroker.javascript
        jetzt läuft er wieder 👍
        • UweRLP
          UweRLP @apollon77 last edited by
          @apollon77 sagte in js-controller 3.0/3.1 jetzt im Latest!:
          gehts danach
          Ja, das hat bei mir geholfen. javascript läuft wieder und alle Adapter sind aktuell.
          Vielen Dank.
          Bei diesem Versuch habe ich die Adapter einzeln mit
          iobroker upgrade adaptername
          bei laufendem iobroker geupdatet, ohne späteres
          iobroker upload all
          Nach einem stoppen vom iobroker und wieder starten hatte ich dann wieder den Fehler mit dem javascript Adapter.
          Nach dem
          im ../node_module/iobroker.javascript läuft es nun wieder.
          • UweRLP
            Der Fehler tritt immer wieder bei Adapterupdates auf.
              hannoi last edited by
              Hatte auch gerade nach dem JS-controller Update von 3.1.4 auf 3.1.5 folgende Fehlermeldung und der Javascript Adapter hat nicht mehr gestartet:
              2020-06-11 10:30:15.045	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2020-06-11 10:30:15.045	error	Caught by controller[0]: }
              2020-06-11 10:30:15.045	error	Caught by controller[0]: ]
              2020-06-11 10:30:15.045	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
              2020-06-11 10:30:15.045	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/index.js',
              2020-06-11 10:30:15.045	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/compiler.js',
              2020-06-11 10:30:15.044	error	Caught by controller[0]: requireStack: [
              2020-06-11 10:30:15.044	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
              2020-06-11 10:30:15.044	error	Caught by controller[0]: {
              2020-06-11 10:30:15.044	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
              2020-06-11 10:30:15.044	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)
              2020-06-11 10:30:15.044	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
              2020-06-11 10:30:15.044	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
              2020-06-11 10:30:15.043	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
              2020-06-11 10:30:15.043	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
              2020-06-11 10:30:15.043	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
              2020-06-11 10:30:15.043	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
              2020-06-11 10:30:15.043	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
              2020-06-11 10:30:15.043	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
              2020-06-11 10:30:15.043	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
              2020-06-11 10:30:15.042	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
              2020-06-11 10:30:15.042	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/index.js:3:18)
              2020-06-11 10:30:15.042	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
              2020-06-11 10:30:15.042	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
              2020-06-11 10:30:15.042	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
              2020-06-11 10:30:15.042	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
              2020-06-11 10:30:15.042	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
              2020-06-11 10:30:15.041	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
              2020-06-11 10:30:15.041	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/compiler.js:3:10)
              2020-06-11 10:30:15.041	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
              2020-06-11 10:30:15.041	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
              2020-06-11 10:30:15.041	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:842:27)
              2020-06-11 10:30:15.041	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:966:15)
              2020-06-11 10:30:15.041	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
              2020-06-11 10:30:15.040	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/index.js
              2020-06-11 10:30:15.040	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/compiler.js
              2020-06-11 10:30:15.040	error	Caught by controller[0]: Require stack:
              2020-06-11 10:30:15.040	error	Caught by controller[0]: Error: Cannot find module 'typescript'
              2020-06-11 10:30:15.040	error	Caught by controller[0]: ^
              2020-06-11 10:30:15.040	error	Caught by controller[0]: throw err;
              2020-06-11 10:30:15.039	error	Caught by controller[0]: internal/modules/cjs/loader.js:969
              Nach einem "npm install typescript" im iobroker dir hat die ScriptEngine wieder funktioniert.
              • FragMike
                FragMike last edited by
                habe mir bereits einmal mein IOBROKER WIN SYSTEM geschrottet 😵 ....Klappt das Update nun?
                • haselchen
                  haselchen Most Active @FragMike last edited by haselchen
                  @FragMike
                  Unsere Forums- Glaskugel hat heute leider frei.....also wären ein paar Infos nicht schlecht.
                  Systeminfos
                  Welches Update (von wo nach wo)
                  und und und....
                  einfach mal ein wenig Input.
                  • FragMike
                    Hi Sorry....
                    Habe IOBROKER auf WIN 10 SYSTEM mit Atom Dualcore 4 gig RAM mit SSD
                    Sytemauslastung liegt normalerweise bei 55% wenn alle Skripte laufen.
                    Das ist aktuell :
                    Typ: js-controller
                    Titel: JS controller
                    OS: win32
                    Verfügbar: 3.1.5
                    Installiert: 2.1.0
                    Ereignisse: ⇥10 / ↦12
                    Ein update des JS Controllers hatte bereits in der Vergangenheit katastrophale Folgen.
                    Hatte hier gelesen, dass es ein gesondertes Installationspaket für WIN geben wird...
                    Thomas Braun Garfonso 2 Replies Last reply Reply Quote 0
                      Thomas Braun Most Active @FragMike last edited by
                      @FragMike Ja, da soll was kommen für Windows.
                      FragMike 1 Reply Last reply Reply Quote 0
                      • FragMike
                        FragMike @Thomas Braun last edited by
                        @Thomas-Braun sagte in js-controller 3.0/3.1 jetzt im Latest!:
                        schon seid 6 Monaten 😉
                        Muss ich wieder auf Linux System umziehen?
                        Raspi hat seinerzeit nur rumgezickt und 2 SD Karten zernichtet.
                        VM mit Linux unter WIN ...dann kann ich auch ein SNAPSHOT als Backup machen...
                        macht das Sinn?
                          Thomas Braun Most Active @FragMike last edited by Thomas Braun
                          @FragMike sagte in js-controller 3.0/3.1 jetzt im Latest!:
                          Keine Ahnung. Mein Linux läuft jedenfalls klag- und problemlos.
                          iobroker auf einen Raspbian Buster. Ich persönlich bin kein Fan von VMs.
                          • Garfonso
                            Garfonso Developer @FragMike last edited by
                            @FragMike
                            Das mit dem "speziellen Paket" hab ich auch gelesen. Irgendwo hatte ich auch mal nachgefragt, da hieß es dann, man soll "einfach nochmal den Installer runterladen und ausführen" -> wobei mir dann total unklar ist, was man da machen soll... ein "update" gibt es da leider nicht, nur neuanlegen (beschwert sich, dass es den Instanznamen schon gibt), Löschen und importieren. Vermutlich könnte Instanz Löschen, dann neu anlegen mit Import der "richtige" Weg sein... war mir aber zu unsicher das so zu machen, ohne dass ich da eine offzielle Bestätigung hab (und fände ich auch einen ganz schön umständlichen weg).
                            Daher habe ich das Update auch unter Windows "von Hand" gemacht, ging gut.
                            Also:
                            • mit Startmenü Eintrag die ioBroker Konsole starten
                            • ioBroker stoppen (iob stop bzw. Dienst manuell anhalten)
                            • iob upgrade self (oder, wenn er "nervt" npm install iobroker.js-controller, weiß nicht mehr, welches ging) -> upgrade wird ausgeführt
                            • ioBroker wieder starten iob start / Dienst manuell starten)
                            • FragMike
                              FragMike @Garfonso last edited by
                              @Garfonso
                              Hi..danke für deine Antwort...ich glaube genau so habe ich das seinerzeit gemacht. Ging leider in die Hose...danach half nur noch den Rechner komplett neu aufzusetzen und das Backup wieder einzuspielen. Mal schauen, ob es diesmal klappt 😳🤷
                              • JB_Sullivan
                                JB_Sullivan @FragMike last edited by JB_Sullivan
                                @FragMike
                                Wir haben das Thema Windows und ioBroker in einem anderen Thread ausführlich durchgekaut.
                                Der Knackpunkt ist diese Vorgehensweise wie sie AlCalzone dort beschreibt.
                                Dann gibt es auch keine Probleme mehr mit dem zerschießen, wenn ein Adapter aktualisiert / neu installiert oder gelöscht wird.
                                https://forum.iobroker.net/topic/33421/iobroker-unter-windows-installieren-ohne-installer/125
                                • FragMike
                                  FragMike @JB_Sullivan last edited by
                                  @JB_Sullivan
                                  Danke...Lesestoff👍
                                    Aus gegebenem Anlass hier noch ein Controller Update auf 3.1.6 ab bald im Latest:
                                    3.1.6 (2020-06-18) Release Francesca
                                    • (foxriver76) fix output of iobroker plugin status command
                                    • (foxriver76) fix deletion of states on instance-deletion
                                    • (Apollon77) add additional checks to prevent Errors (Sentry)
                                    • (Apollon77) Make sure Sentry activation info is also shown on upgrade self command
                                    • (Apollon77) Upgrade winston-daily-rotate-file library to prevent a crash case
                                    ? UweRLP 2 Replies Last reply Reply Quote 0
                                      A Former User @apollon77 last edited by
                                      @apollon77 Hi, hier verträgt sich die Francesca mit der Silvia und dem Buster einwandfrei. 🙂
                                      • UweRLP
                                        @apollon77 Das Problem https://forum.iobroker.net/post/445338 ist mit js-controller 3.1.6 leider noch nicht behoben. Sowohl nach update vom js-controller auf die 3.1.6 trat das Problem auf, habe ich dann repariert. Aber werden mit der 3.1.6 dann Adapter geupdatet starte der javascript Adaper wieder nicht und eine Reparatur des Adapters ist erneut notwendig.
                                          @UweRLP Da kann der Controller nichts dran ändern, das hat mit npm und damit wie die Windows Systeme teilweise installiert sind zu tun ...
                                          • UweRLP
                                            @apollon77 Ok, danke für die Info.
                                            Wenn ich das dann richtig verstanden habe wird es vielleicht eines Tages mit einem Update von NodeJS behoben sein?
                                            js-controller
                                            127
                                            1340
                                            437428
