    4. Test Adapter Gartenbewässerung v0.0.x
      sigi234 Forum Testing Most Active @tombox last edited by
      @tombox sagte in Test Adapter Gartenbewässerung v0.0.x:
      @sigi234 habe mal für alle timestamps hinzugefügt
      Hm, sehe es nur bei 3 DP
      • wawyo
        wawyo Developer last edited by
        Ergänzung für tombox (alle Variablen sind auf Englisch):
        async checkautomaticTimer() {
                let automatic = [];
                automatic = [
                    ["starttime1", this.config.starttime1_enable, this.config.starttime1, this.config.starttime1duration, this.config.starttime1tempforecast, this.config.starttime1rainforecast, this.config.starttime1moistureforecast],
                    ["starttime2", this.config.starttime2_enable, this.config.starttime2, this.config.starttime2duration, this.config.starttime2tempforecast, this.config.starttime2rainforecast, this.config.starttime2moistureforecast],
                    ["starttime3", this.config.starttime3_enable, this.config.starttime3, this.config.starttime3duration, this.config.starttime3tempforecast, this.config.starttime3rainforecast, this.config.starttime3moistureforecast]
                for (let i = 0; i <= automatic.length - 1; i++) {
                    if (this.automatic[i][1] && this.automatic[i][0].startsWith("starttime")) {
                        let nextautomatic = this.gettimediff(this.automatic[i][2]);
                        this.setState("state." + this.automatic[i][0] + ".still", this.convertseconds(nextautomatic));
                        this.setState("state." + this.automatic[i][0] + ".progress", 100 - ((nextautomatic / 86400) * 100).toFixed(2));
                        this.setState("state." + this.automatic[i][0] + ".stillseconds", nextautomatic);
                    } else if (!this.automatic[i][1]) {
                        this.setState("state." + this.automatic[i][0] + ".still", "--:--:--");
                        this.setState("state." + this.automatic[i][0] + ".progress", "00");
                        this.setState("state." + this.automatic[i][0] + ".stillseconds", "00");
            gettimediff(datetime) {
                var tempnow = Date();
                var pattern = /(\d{2})\:(\d{2})\:(\d{2})/;
                var convertednow = tempnow.replace(pattern, "" + datetime + ":00");
                var convertednowSec = new Date(convertednow).getTime();
                var nowtemp = new Date();
                var now = nowtemp.getTime();
                if (isNaN(convertednowSec)) {
                    return "";
                if (convertednowSec < now) {
                    var milisec_diff = (convertednowSec + (24 * 60 * 60 * 1000)) - now;
                } else {
                    var milisec_diff = convertednowSec - now;
                var date_diff = (milisec_diff / 1000).toFixed(0);
                return date_diff;
            convertseconds(totalSeconds) {
                var hours = Math.floor(totalSeconds / 3600);
                var minutes = Math.floor((totalSeconds - (hours * 3600)) / 60);
                var seconds = (totalSeconds - (hours * 3600) - (minutes * 60)).toFixed(0);
                var result = (hours < 10 ? "0" + hours : hours);
                result += ":" + (minutes < 10 ? "0" + minutes : minutes);
                result += ":" + (seconds < 10 ? "0" + seconds : seconds);
                return result;
          tombox @wawyo last edited by
          @wawyo was macht das genau?
          wawyo 1 Reply Last reply Reply Quote 0
          • wawyo
            wawyo Developer @tombox last edited by wawyo
            @tombox
            Der Code ist zum berechnen alle Restzeiten bis zum nächsten automatische Start.
            Ich habe die Zeiteinstellungen zum Automatikbetrieb ergänzt.
            20200609_213518_edited.mp4
              f0rd42 last edited by
              Mal ne blöde Frage:
              So wie es aussieht, habt ihr entweder alle eine Pumpe oder allgemein genügend Druck um alle Kreise gleichzeitig betreiben zu können. Das ist bei mir leider nicht so!
              Gibt es irgendwie eine Möglichkeit, dass die Ventile nur nacheinander abgearbeitet werden oder habe ich hier was übersehen?
                mameier1234 @f0rd42 last edited by
                @f0rd42 Das ist doch genau die Funktion des Adapters.. In einer Instanz werden die einzelnen Ventile nacheinander abgearbeitet...
                Einige wollen hier genau das Gegenteil, das geht aber noch nicht...
                  f0rd42 @mameier1234 last edited by
                  @mameier1234 ok, dann war / bin ich blind 🙂
                  Danke, ich tüftele mal weiter
                    Gerni last edited by Gerni
                    Hi. Erstmal Danke für die Arbeit und den Adapter.
                    Vermutlich blöde Frage aber was genau muss ich denn angeben um Ventil eins, was ein sonoff 4CH Pro wäre, schalten zu können. In Log steht zwar, dass Ventil 1 geschaltet wird, ist es aber in der 4CH Konfig (Tasmo) nicht. "4CH Pro POWER1" reicht vermutlich nicht
                    EDIT:
                    Hab es: "sonoff.0.4CH Pro.POWER1" und läuft. Super Geil!!!!
                      Habe dann doch mal ne Frage.
                      Zu Ermittlung von Wetterdaten nutze ich den wetter.com Adapter. Der liefert auch Infos. Zu verschiedenen Tagen usw.
                      Nun möchte ich an jedem Tag der Woche Sprinkler aktivieren jedoch nicht wenn es zB 5 mm regnet.
                      Jetzt kann ich hier im Adapter Regenwert für heute und morgen hinterlegen. Und was ist Mittwoch, Donnerstag usw?
                      Oder habe ich die passenden Datenpunkte nicht vor Augen?
                      Wie holt ihr euch die Wetterdaten und bindet sie in den Adapter ein?
                      Stefan
                        f0rd42 @Gerni last edited by
                        @Gerni Die sind direkt im Adapter:
                          Gerni @f0rd42 last edited by Gerni
                          @f0rd42 ist Nextdays Day 1 also heute. Wenn dem so ist, Asche über mein haupt.
                          Wenn also morgen geprüft wird wäre Day 1 dann tatsächlich Dienstag? Ich dachte Day 1 ist immer Montag, Day 2 Dienstag usw.
                          Dann würde doch Day 2 immer Dienstag sein und nie Mittwoch wenn der Wert hier im Adapter für Folgetag steht.
                          Vielleicht schnall ich die Logik auch nicht
                            @Gerni day 1 ist immer heute, day 2 morgen.
                            • AtomicIX
                              AtomicIX last edited by
                              Hallo, mag mir bitte einer sagen, wo ich die Links im "daswetter" im Adapter finde? Ich steige da nicht durch. Ich finde im Adapter keine Links
                                sigi234 Forum Testing Most Active @AtomicIX last edited by sigi234
                                @AtomicIX sagte in Test Adapter Gartenbewässerung v0.0.x:
                                https://www.daswetter.com/api/#/login
                                This adapter reads weather forecast data from DasWetter.com.
                                You need an account on DasWetter.com. Register at https://www.daswetter.com/api/#/login
                                The account is for free under certain conditions.
                                In your account you will find three URL for four different data models:
                                Forecast for the next 7 days and general information of the day: high and low, wind (symbol and description), Day symbol and weather conditions
                                detailed information for 5 days and every 3 hours: The general daily information is the following: peak, lows, wind, gusts, Precipitation, relative humidity,
                                sea level air pressure, snow line, Sunrise and sunset, dates related to the moon, local time
                                Preview with detailed data every hour (only for the first 2 days, then every 3 hours)
                                Prediction for 5 days and every 3 hours (in JSON format)
                                All four models are implemented and one should be used at least.
                                In settings URL like http://api.daswetter.com/index.php?api_lang=de&localidad=xxxx must be used. Just copy the complete URL from your account.
                                AtomicIX 1 Reply Last reply Reply Quote 0
                                • AtomicIX
                                  AtomicIX @sigi234 last edited by
                                  @sigi234 ah, cool, danke.
                                  • JB_Sullivan
                                    JB_Sullivan last edited by
                                    Hat von Euch jemand schon mal so einen Umbau mit einem TFK von INNOGY gemacht? Sind ja eigentlich Baugleich zu Homematic nur das Innogy ein anderes Verschlüsselungsprotokoll verwendet.
                                    Ich habe das nämlich gemacht und trotz 47kOhm Widerstand bekomme ich immer nur ein geschlossen Signal - egal ob trocken oder feucht. Hat jemand einen Tip für mich?
                                    https://homematic-guru.de/homematic-bodenfeuchtesensor-mit-gardena
                                    • AtomicIX
                                      Ich glaube ich bin gerade zu Blöd.
                                      Ich möchte bei mir im Garten den Adapter auf dem Raspberry / iobroker installieren.
                                      Garten-ioBroker
                                      Betriebssystem
                                          linux
                                      Betriebssystem
                                          linux
                                      Architektur
                                          arm
                                      CPUs
                                      Geschwindigkeit
                                          1500 MHz
                                      Modell
                                          ARMv7 Processor rev 3 (v7l)
                                      RAM
                                          3.81 GB
                                      System Betriebszeit
                                          3 T. 01:09:26
                                      Node.js
                                          v10.20.1 (Es gibt eine neuere Version: v10.21.0 - Empfohlene Version v12.18.0)
                                      NPM
                                          6.14.4
                                      Festplatte Größe
                                          116.87 GB
                                      Festplatte frei
                                          114.03 GB
                                      Anzahl der Adapter
                                          296
                                      Zuhause auf meinem Testsystem ist ein Clone des Aktuellen iobroker system. Da läuft der Adapter ohne Probleme. Jetzt im Garrten ( Habe nur Edge Internet verbindung) bekomme ich ihn nicht installiert. Wo ist das Problem? Die systeme sind identisch.
                                      $ ./iobroker url "https://github.com/TA2k/ioBroker.gartenbewaesserung" --debug
                                      install https://github.com/TA2k/ioBroker.gartenbewaesserung/tarball/39c3d009800d7bf4504327002087636619982ce6
                                      NPM version: 6.14.4
                                      npm install https://github.com/TA2k/ioBroker.gartenbewaesserung/tarball/39c3d009800d7bf4504327002087636619982ce6 --loglevel error --prefix "/opt/iobroker" (System call)
                                      npm
                                       ERR! code EINTEGRITY
                                      npm ERR! sha512-cBMXjSW+fjOb4tyaVHuaVE/A5TqkukDWiOfxxAjY+PEqmmBQlLwn+8OzwPiG3brouXKY5Un4pBjAeB6UToXHaQ== integrity checksum failed when using sha512: wanted sha512-cBMXjSW+fjOb4tyaVHuaVE/A5TqkukDWiOfxxAjY+PEqmmBQlLwn+8OzwPiG3brouXKY5Un4pBjAeB6UToXHaQ== but got sha512-HV2uDGzXXVjT2754hSwBxAz1Semt/uato+9tUwWTaRT/hE08zDJ260MZ0hhjkBilSG2vujCGke3LZCgUJTMfQQ==. (52570 bytes)
                                      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-06-17T14_05_18_802Z-debug.log
                                      ERROR: host.Garten-ioBroker Cannot install https://github.com/TA2k/ioBroker.gartenbewaesserung/tarball/39c3d009800d7bf4504327002087636619982ce6: 1
                                      ERROR: process exited with code 25
                                      • AtomicIX
                                        AtomicIX @AtomicIX last edited by
                                        @AtomicIX ok, es läuft. das Internet war einfach zu langsam 😞
                                          anwa last edited by
                                          habe gerade mit der Tasmota PulseTime rumgespielt. Habs jetzt am laufen, danke für den Hinweis.
                                          Die Bewässerungssteuerung ist mit Wemos D1 (eventuell ESP32 falls noch Display dazu soll) geplant. Ich benutze den Sonoff Adapter für alle meine Tasmota Geräte.
                                          Die Datenpunkte PulseTime1...x werden vom Sonoff Adapter nicht automatisch angelegt. Das musste ich von Hand machen. Danach hat's aber funktioniert.
                                          2 Probleme habe ich dabei allerdings festgestellt:
                                          1. Tasmota hat ein eigenwilliges Format für die PuleTime...
                                          1..111 = set PulseTime for Relay<x> in 0.1 second increments
                                          112..64900 = set PulseTime for Relay<x>, offset by 100, in 1 second increments.
                                          Add 100 to desired interval in seconds, e.g.,
                                          PulseTime 113 = 13 seconds and PulseTime 460 = 6 minutes (i.e., 360 seconds)
                                          Ok, da muss man halt rechnen.
                                          1. Für die Pumpe gibt es keine Einstellung... die würde also für 3 Wochen laufen wenn ich im Urlaub bin und das WLAN weg ist 😞
                                          Man könnte ja die Gesamtlaufzeit berechnen und diese für die Pumpe (als PulseTime) verwenden.
                                          Für die Pumpe wäre auch eine Vorlauf/Nachlaufzeit praktisch
                                          Was die Eingabe der Zeiten (Laufzeiten) angeht, finde ich das eh sehr verwirrend.
                                          Wie wäre es mit "Wert" Dropdown "sec/min/h" Dropdown "Gardena/Tasmota/.../Raw"
                                          Die ersten beiden Legen die Bewässerungsdauer fest.
                                          Falls ein DP bei "State für Schaltdauer" eingetragen ist kann man über das dritte Dropdown (sonst grau) auswählen in welcher Form die Zeit in den DP geschrieben wird.
                                          Die Tasmota z.B. dann 100+sec, bei Raw einfach der Wert.
                                          Der Feuchte Sensor wird bei mir nicht korrekt angezeigt. Obwohl er im Sonoff Adapter stimmt. Muß ich noch weiter untersuchen.
                                          Ich habe übrigens ein kleine Script geschrieben für Tasmota um schlimmeres bei Verbindungsproblemen zu verhindern...
                                          Link Text
                                          Gruß Andreas
                                          • JB_Sullivan
                                            Moin zusammen - ich habe eine Frage zur Feuchte Funktion. Habe ich hier einen Fehler gefunden oder verstehe ich etwas nicht?
                                            Also ich habe einen umgebauten GARDENA Senor angeschlossen.
                                            Feucht = False (0)
                                            Trocken = True (1)
                                            Somit habe ich den Adapter wie folgt konfiguriert.
                                            Der Datenpunkt des Feuchte Sensor wird im Innogy Adapter (umgebauter TFS) auf False gesteuert.
                                            ... leider kommt das aber nicht in den Datenpunkten der Gartenbewässerung an - man achte auf den Zeitstempel
                                            Wo liegt hier der Fehler?
                                            79.9k
                                            beregnungssteuerung bewässerung garten gartenbewässerung magnetventil ventil ventile
                                            66
                                            567
                                            109874
