    4. Zigbee Adapter Fehler nach Update auf JS-Controller 3.1.5
    UNSOLVED Zigbee Adapter Fehler nach Update auf JS-Controller 3.1.5
      arteck Developer Most Active @JB_Sullivan last edited by
      @JB_Sullivan ne das was schon unter 8 auch so..
        gifftstaub @arteck last edited by gifftstaub
        @arteck
        ich habe die gleichen probleme, keine Chance.
        nodejs -v && which nodejs && node -v && which node && npm -v && which npm && apt policy nodejs
        v12.18.0
        /usr/bin/nodejs
        v12.18.0
        /usr/bin/node
        6.14.4
        /usr/bin/npm
        nodejs:
          Installiert:           12.18.0-1nodesource1
          Installationskandidat: 12.18.0-1nodesource1
          Versionstabelle:
         *** 12.18.0-1nodesource1 500
                500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                100 /var/lib/dpkg/status
             10.21.0~dfsg-1~deb10u1+rpi1 500
        zigbee.0	2020-06-15 06:38:02.899	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
        zigbee.0	2020-06-15 06:38:02.899	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
        zigbee.0	2020-06-15 06:38:02.899	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:111:49)
        zigbee.0	2020-06-15 06:38:02.899	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:4:12)
        zigbee.0	2020-06-15 06:38:02.899	error	at new Promise (<anonymous>)
        zigbee.0	2020-06-15 06:38:02.899	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:8:71
        zigbee.0	2020-06-15 06:38:02.899	error	at Generator.next (<anonymous>)
        zigbee.0	2020-06-15 06:38:02.899	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:113:32)
        zigbee.0	2020-06-15 06:38:02.899	error	(19322) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
        zigbee.0	2020-06-15 06:38:02.898	error	(19322) Failed to start Zigbee
        zigbee.0	2020-06-15 06:38:02.655	info	(19322) Starting Zigbee...
        komisch ist auch obwohl der COM-Anschlussname angegeben wurde kommt immer diese fehlermeldung.
        Bildschirmfoto von 2020-06-15 06-34-50.png Bildschirmfoto von 2020-06-15 06-34-20.png
        ich hoffe es gibt dafür abhilfe.
        lg
          arteck Developer Most Active @gifftstaub last edited by
          @gifftstaub hmm ok.. ich schau mal .. muss erst mein DEV auf node 12 bringen
            @arteck
            Probiert habe ich auch mit sudo rm -R /opt/iobroker/node_modules/@serialport und ein npm install serialport --build-from-source
            > @serialport/bindings@8.0.8 install /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings
            > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
            make: Verzeichnis „/opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/build“ wird betreten
              CXX(target) Release/obj.target/bindings/src/serialport.o
            In file included from ../src/./serialport.h:6,
                             from ../src/serialport.cpp:1:
            ../../../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
            ../../../../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                 , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
            ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
            ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
               uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
            ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
            ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
               uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
            ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
            ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
               uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
            ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
            ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
               uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
            ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
            ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
               uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
            ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
            ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
               uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
            ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
            ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
               uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
            ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
            ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
               uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
            ../src/serialport.cpp: At global scope:
            ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
             SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
            ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
             SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
            In file included from ../../../../../nan/nan.h:56,
            /home/iobroker/.cache/node-gyp/12.18.0/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                   (node::addon_register_func) (regfunc),                          \
            /home/iobroker/.cache/node-gyp/12.18.0/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’
               NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
            ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’
             NODE_MODULE(serialport, init);
              CXX(target) Release/obj.target/bindings/src/serialport_unix.o
            In file included from ../src/serialport.h:6,
                             from ../src/serialport_unix.cpp:2:
            ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
            ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
                 snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
            ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
            ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
            ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
                 snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
            ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
              CXX(target) Release/obj.target/bindings/src/poller.o
            In file included from ../src/poller.cpp:1:
              CXX(target) Release/obj.target/bindings/src/serialport_linux.o
              SOLINK_MODULE(target) Release/obj.target/bindings.node
              COPY Release/bindings.node
            make: Verzeichnis „/opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/build“ wird verlassen
            > @serialport/bindings@9.0.0 install /opt/iobroker/node_modules/@serialport/bindings
            make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird betreten
            In file included from ../../../nan/nan.h:56,
            make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird verlassen
            > serialport@8.0.8 postinstall /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport
            > node thank-you.js
            Thank you for using serialport!
            If you rely on this package, please consider supporting our open collective:
            > https://opencollective.com/serialport/donate
            > serialport@9.0.0 postinstall /opt/iobroker/node_modules/serialport
            > node thank-you.js
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.12 (node_modules/zigbee-herdsman/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.12: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            + serialport@9.0.0
            added 31 packages from 3 contributors and updated 1 package in 50.316s
            49 packages are looking for funding
              run `npm fund` for details
            trozdem die gleichen fehlermeldungen.
            ich sehe gerade beim installieren des Adapters ergibt sich folgende Meldungen.
            $ ./iobroker add zigbee  --host raspberrypi
            NPM version: 6.14.5
            npm install iobroker.zigbee@1.1.1 --loglevel error --prefix "/opt/iobroker" (System call)
            In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
            ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);        ^~~~~~~~~~~~~
            ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);        ^~~~~~~~~~~~~~~
            ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);        ^~~~~~~~~~~~~~
            ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);        ^~~~~~~~~~~~~~
            ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);        ^~~~~~~~~~~~
            ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);        ^~~~~~~~~~~~
            ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);        ^~~~~~~~~~~~~~~~~~~~
            ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);        ^~~~~~~~~~~~~~
            ../src/serialport.cpp: At global scope:../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {                            ^
            ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses] SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {                              ^
            In file included from ../../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.18.0/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.cache/node-gyp/12.18.0/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(serialport, init); ^~~~~~~~~~~
            In file included from ../src/serialport.h:6,                 from ../src/serialport_unix.cpp:2:../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
            ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);                                                            ^~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);     ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
            ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);                                                            ^~~~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);     ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
            In file included from ../src/poller.cpp:1:../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
            host.raspberrypi install adapter zigbee
            upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
            upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_lightbar.png img/philips_hue_lightbar.png image/png
            upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lifecontrol_lamp.png img/lifecontrol_lamp.png image/png
            upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/jiawen.png img/jiawen.png image/png
            upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/iluminize_511_040.png img/iluminize_511_040.png image/png
            upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_led1837r5.PNG img/ikea_led1837r5.PNG image/png
            upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hue_go.png img/hue_go.png image/png
            upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gledopto_bulb.png img/gledopto_bulb.png image/png
            upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ewelink_MS01.png img/ewelink_MS01.png image/png
            upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_neutral1.png img/ctrl_neutral1.png image/png
            upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_switch.png img/aqara_switch.png image/png
            upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_numan_body_sensor.png img/aqara_numan_body_sensor.png image/png
            upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_curtain.png img/aqara_curtain.png image/png
            upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_bulb.png img/aqara_bulb.png image/png
            upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZWLD-100.png img/ZWLD-100.png image/png
            upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0218.png img/TS0218.png image/png
            upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0215.png img/TS0215.png image/png
            upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LTW017.png img/LTW017.png image/png
            upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LTC015.png img/LTC015.png image/png
            upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LTC014.png img/LTC014.png image/png
            upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LCT002.png img/LCT002.png image/png
            upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Ikea_fyrtur.png img/Ikea_fyrtur.png image/png
            upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
            upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
            upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
            upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
            upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
            upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
            upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
            upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
            upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
            host.raspberrypi object system.adapter.zigbee created/updated
            host.raspberrypi create instance zigbee
            host.raspberrypi object zigbee.0.info.groups created
            host.raspberrypi object zigbee.0.info.pairingMessage created
            host.raspberrypi object zigbee.0.info.pairingCountdown created
            host.raspberrypi object zigbee.0.info.pairingMode created
            host.raspberrypi object zigbee.0.info.connection created
            host.raspberrypi object zigbee.0.info created
            host.raspberrypi object system.adapter.zigbee.0.sigKill created
            host.raspberrypi object system.adapter.zigbee.0.eventLoopLag created
            host.raspberrypi object system.adapter.zigbee.0.outputCount created
            host.raspberrypi object system.adapter.zigbee.0.inputCount created
            host.raspberrypi object system.adapter.zigbee.0.uptime created
            host.raspberrypi object system.adapter.zigbee.0.memRss created
            host.raspberrypi object system.adapter.zigbee.0.memHeapTotal created
            host.raspberrypi object system.adapter.zigbee.0.memHeapUsed created
            host.raspberrypi object system.adapter.zigbee.0.cputime created
            host.raspberrypi object system.adapter.zigbee.0.cpu created
            host.raspberrypi object system.adapter.zigbee.0.compactMode created
            host.raspberrypi object system.adapter.zigbee.0.connected created
            host.raspberrypi object system.adapter.zigbee.0.alive created
            host.raspberrypi Set default value of zigbee.0.info.groups:
            host.raspberrypi Set default value of zigbee.0.info.pairingMessage:
            host.raspberrypi Set default value of zigbee.0.info.pairingCountdown: 0
            host.raspberrypi Set default value of zigbee.0.info.pairingMode: false
            host.raspberrypi Set default value of zigbee.0.info.connection: false
            host.raspberrypi object system.adapter.zigbee.0 created
            process exited with code 0
            lg
              Push
              Ich habe nun folgendes gemacht.
              pi@raspberrypi:/opt/iobroker/node_modules/serialport $ npm install --production
              > @serialport/bindings@8.0.8 install /opt/iobroker/node_modules/serialport/node_modules/@serialport/bindings
              prebuild-install WARN install No prebuilt binaries found (target=12.18.0 runtime=node arch=arm libc= platform=linux)
              make: Verzeichnis „/opt/iobroker/node_modules/serialport/node_modules/@serialport/bindings/build“ wird betreten
              make: Verzeichnis „/opt/iobroker/node_modules/serialport/node_modules/@serialport/bindings/build“ wird verlassen
              > serialport@8.0.8 postinstall /opt/iobroker/node_modules/serialport
              > node thank-you.js
              npm notice created a lockfile as package-lock.json. You should commit this file.
              added 73 packages from 43 contributors and audited 78 packages in 16.172s
              1 package is looking for funding
              found 0 vulnerabilities
              pi@raspberrypi:/opt/iobroker/node_modules/serialport $ npm fund
              serialport@8.0.8
              └─┬ https://github.com/sponsors/sindresorhus
                └── mimic-response@2.1.0
              liegt das Problem an der 12.18.0?
              lg
                Thomas Braun Most Active @gifftstaub last edited by
                @gifftstaub
                Nein, mit 12.18.0 hat das grundsätzlich nichts zu tun, denn:
                pi@raspberrypi:/opt/iobroker $ nodejs -v
                v12.18.0
                pi@raspberrypi:/opt/iobroker $ npm ls serialport
                iobroker.inst@2.0.3 /opt/iobroker
                ├─┬ iobroker.discovery@2.3.7
                │ └── serialport@8.0.8
                └─┬ iobroker.zigbee@1.1.1
                  └─┬ zigbee-herdsman@0.12.83
                    └── serialport@8.0.7
                  gifftstaub @Thomas Braun last edited by
                  @Thomas-Braun
                  könnte der Stick defekt sein?
                  └─┬ iobroker.zigbee@1.0.0
                    └─┬ zigbee-herdsman@0.12.95
                  lg
                    @gifftstaub
                    Hast du eigentlich im Raspberry auch den Serialport in
                    sudo raspi-config
                    aktiviert?
                    Geht unter 5 - P6 - No - Yes
                      @Thomas-Braun
                      eingentlich ja am serialport war ich nocch nie dran.
                      ich habe das mal proformer gemacht wie du beschrieben hast, nach einem reboot immer noch die gleichen Meldungen.
                      zigbee.0	2020-06-16 14:21:14.793	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
                      zigbee.0	2020-06-16 14:21:14.793	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
                      zigbee.0	2020-06-16 14:21:14.793	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:111:49)
                      zigbee.0	2020-06-16 14:21:14.793	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:4:12)
                      zigbee.0	2020-06-16 14:21:14.793	error	at new Promise (<anonymous>)
                      zigbee.0	2020-06-16 14:21:14.793	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:8:71
                      zigbee.0	2020-06-16 14:21:14.793	error	at Generator.next (<anonymous>)
                      zigbee.0	2020-06-16 14:21:14.793	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:113:32)
                      zigbee.0	2020-06-16 14:21:14.793	error	(2686) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
                      zigbee.0	2020-06-16 14:21:14.792	error	(2686) Failed to start Zigbee
                      zigbee.0	2020-06-16 14:21:14.554	info	(2686) Starting Zigbee...
                      lg
                        Thomas Braun Most Active @gifftstaub last edited by Thomas Braun
                        @gifftstaub sagte in Zigbee Adapter Fehler nach Update auf JS-Controller 3.1.5:
                        Da greift wohl schon irgendwas anderes drauf zu. Hast du noch deConz parallel laufen?
                          @Thomas-Braun
                          nein nur zigbee
                            liste der Installierten Adapter
                            Used repository: latest
                            hash unchanged, use cached sources
                            update done
                            Adapter    "accuweather"   : 1.1.3
                            Adapter    "admin"         : 4.1.1    , installed 4.1.1
                            Adapter    "alarm"         : 0.7.5
                            Adapter    "alexa2"        : 3.1.2    , installed 3.1.2
                            Adapter    "alpha2"        : 1.0.0
                            Adapter    "amazon-dash"   : 1.1.0
                            Adapter    "artnet"        : 1.2.2
                            Adapter    "asterisk"      : 1.0.6
                            Adapter    "asuswrt"       : 1.0.1
                            Adapter    "b-control-em"  : 0.2.1
                            Adapter    "backitup"      : 1.5.8    , installed 1.5.8
                            Adapter    "beckhoff"      : 1.2.2
                            Adapter    "benq"          : 0.2.2
                            Adapter    "binance"       : 1.1.2
                            Adapter    "ble"           : 0.11.6
                            Adapter    "blink4home"    : 0.1.1
                            Adapter    "bmw"           : 1.4.0
                            Adapter    "boblight"      : 0.0.1
                            Adapter    "bosesoundtouch": 0.9.2
                            Adapter    "botvac"        : 1.0.0
                            Adapter    "bring"         : 1.7.2
                            Adapter    "broadlink2"    : 2.0.3
                            Adapter    "bsblan"        : 0.1.2
                            Adapter    "bshb"          : 0.1.10
                            Adapter    "calendar"      : 1.2.0
                            Adapter    "cameras"       : 0.1.2
                            Adapter    "chromecast"    : 2.3.1
                            Adapter    "cloud"         : 3.0.3
                            Adapter    "comfoair"      : 1.1.1
                            Adapter    "contact"       : 1.1.3
                            Adapter    "contactid"     : 1.0.0
                            Adapter    "coronavirus-statistics": 0.5.9
                            Adapter    "corrently"     : 0.0.2
                            Adapter    "countdown"     : 1.1.0
                            Adapter    "cul"           : 1.2.1
                            Adapter    "daikin"        : 1.0.5
                            Adapter    "daswetter"     : 3.0.1
                            Adapter    "deconz"        : 1.3.9
                            Adapter    "denon"         : 1.7.7
                            Adapter    "devices"       : 0.3.6
                            Adapter    "digitalstrom"  : 2.0.5
                            Adapter    "discovergy"    : 0.5.4
                            Adapter    "discovery"     : 2.3.7    , installed 2.3.7
                            Adapter    "doorbird"      : 0.1.5
                            Adapter    "ds18b20"       : 1.1.4
                            Adapter    "dwd"           : 2.4.10
                            Adapter    "ebus"          : 2.0.0
                            Adapter    "ecovacs-deebot": 1.0.3
                            Adapter    "egigeozone"    : 0.1.2
                            Adapter    "ekey"          : 1.1.0
                            Adapter    "email"         : 1.0.7    , installed 1.0.7
                            Adapter    "emby"          : 1.0.2
                            Adapter    "energymanager" : 1.2.2
                            Adapter    "enet"          : 1.0.1
                            Adapter    "epson_stylus_px830": 0.2.1
                            Adapter    "exchangerates" : 0.0.13
                            Adapter    "fakeroku"      : 0.2.1
                            Adapter    "fb-checkpresence": 1.0.3
                            Adapter    "feiertage"     : 1.0.19
                            Adapter    "fhem"          : 1.5.2
                            Adapter    "find-my-iphone": 0.2.17
                            Adapter    "firetv"        : 1.0.0
                            Adapter    "fitbit-api"    : 0.1.1
                            Adapter    "flot"          : 1.10.0
                            Adapter    "foobar2000"    : 2.0.3
                            Adapter    "fritzbox"      : 0.2.1
                            Adapter    "fritzdect"     : 0.3.2
                            Adapter    "fronius"       : 1.0.5
                            Adapter    "fullcalendar"  : 1.1.0
                            Adapter    "fullybrowser"  : 1.0.3
                            Adapter    "g-homa"        : 0.5.3
                            Adapter    "geofency"      : 0.3.2
                            Adapter    "gruenbeck"     : 0.0.18
                            Adapter    "habpanel"      : 0.4.1
                            Adapter    "haier"         : 1.0.3
                            Adapter    "ham"           : 1.1.2
                            Adapter    "ham-wemo"      : 1.0.1
                            Adapter    "harmony"       : 1.2.2
                            Adapter    "hass-mqtt"     : 0.0.7
                            Adapter    "heatingcontrol": 0.5.6
                            Adapter    "heytech"       : 0.2.0
                            Adapter    "hid"           : 0.1.17
                            Adapter    "hilink"        : 0.2.7
                            Adapter    "history"       : 1.9.8    , installed 1.9.8
                            Adapter    "hm-rega"       : 2.6.14
                            Adapter    "hm-rpc"        : 1.14.10
                            Adapter    "hmip"          : 1.0.1
                            Adapter    "hombot"        : 0.1.3
                            Adapter    "homeconnect"   : 0.0.30
                            Adapter    "homee"         : 1.0.7
                            Adapter    "homepilot"     : 1.1.4
                            Adapter    "hp-ilo"        : 1.0.5
                            Adapter    "hs100"         : 2.0.0
                            Adapter    "hue"           : 3.3.5
                            Adapter    "hue-extended"  : 1.3.2
                            Adapter    "hyperion"      : 0.0.9
                            Adapter    "i2c"           : 0.0.6
                            Adapter    "ical"          : 1.7.0    , installed 1.7.0
                            Adapter    "icons-addictive-flavour-png": 0.1.0
                            Adapter    "icons-fatcow-hosting": 0.1.0
                            Adapter    "icons-icons8"  : 0.0.1
                            Adapter    "icons-material-png": 0.1.0
                            Adapter    "icons-material-svg": 0.1.0
                            Adapter    "icons-mfd-png" : 1.0.2
                            Adapter    "icons-mfd-svg" : 1.0.2
                            Adapter    "icons-open-icon-library-png": 0.1.2
                            Adapter    "icons-ultimate-png": 1.0.1
                            Adapter    "influxdb"      : 1.8.6
                            Adapter    "info"          : 1.7.5    , installed 1.7.5
                            Adapter    "innogy-smarthome": 0.3.4
                            Adapter    "intesishome"   : 0.1.2
                            Adapter    "iogo"          : 0.5.10
                            Adapter    "iot"           : 1.5.3    , installed 1.5.3
                            Adapter    "iqontrol"      : 1.1.0    , installed 1.1.0
                            Adapter    "javascript"    : 4.6.17   , installed 4.6.17
                            Adapter    "jeelink"       : 0.1.3
                            Controller "js-controller" : 3.1.5    , installed 3.1.5
                            Adapter    "js2fs"         : 0.1.5
                            Adapter    "kecontact"     : 0.1.0
                            Adapter    "klf200"        : 0.9.5
                            Adapter    "km200"         : 2.0.3
                            Adapter    "knmi-weather"  : 0.2.0
                            Adapter    "knx"           : 1.0.41
                            Adapter    "kodi"          : 2.0.4
                            Adapter    "kress"         : 2.5.5
                            Adapter    "lametric"      : 0.0.9
                            Adapter    "landroid"      : 1.0.3
                            Adapter    "lcn"           : 0.6.3
                            Adapter    "legrand-ecocompteur": 0.0.4
                            Adapter    "letrika_comgw" : 0.0.5
                            Adapter    "lgtv"          : 1.1.6
                            Adapter    "lgtv-rs"       : 0.1.0
                            Adapter    "lgtv11"        : 1.0.5
                            Adapter    "lifx"          : 0.1.1
                            Adapter    "lightify"      : 0.2.16
                            Adapter    "link"          : 0.5.9
                            Adapter    "linkeddevices" : 1.1.4
                            Adapter    "logparser"     : 0.4.11
                            Adapter    "lovelace"      : 1.1.0
                            Adapter    "loxone"        : 1.0.0
                            Adapter    "luftdaten"     : 0.0.15
                            Adapter    "lupusec"       : 1.2.7
                            Adapter    "luxtronik1"    : 0.2.3
                            Adapter    "material"      : 0.13.8
                            Adapter    "maxcube"       : 0.1.2
                            Adapter    "maxcul"        : 1.3.0
                            Adapter    "mbus"          : 2.2.0
                            Adapter    "mclighting"    : 0.1.1
                            Adapter    "megad"         : 1.2.1
                            Adapter    "megadd"        : 0.2.0
                            Adapter    "megaesp"       : 0.1.0
                            Adapter    "mercedesme"    : 0.0.21
                            Adapter    "mercury"       : 0.1.1
                            Adapter    "meross"        : 1.4.1
                            Adapter    "meteoalarm"    : 1.1.0
                            Adapter    "midea"         : 0.0.6
                            Adapter    "miele"         : 0.1.5
                            Adapter    "mielecloudservice": 1.2.4
                            Adapter    "mihome"        : 1.3.0
                            Adapter    "mihome-airpurifier": 0.1.8
                            Adapter    "mihome-lamp"   : 1.1.0
                            Adapter    "mihome-plug"   : 0.2.1
                            Adapter    "mihome-vacuum" : 2.0.7
                            Adapter    "miio"          : 0.0.13
                            Adapter    "mikrotik"      : 1.0.12
                            Adapter    "milight"       : 0.3.6
                            Adapter    "milight-smart-light": 0.6.0
                            Adapter    "mobile"        : 0.5.0
                            Adapter    "modbus"        : 3.1.3
                            Adapter    "moma"          : 1.2.6
                            Adapter    "mpd"           : 1.0.5
                            Adapter    "mqtt"          : 2.1.3
                            Adapter    "mqtt-client"   : 1.3.1
                            Adapter    "multicast"     : 0.1.5
                            Adapter    "musiccast"     : 0.1.3
                            Adapter    "mydlink"       : 1.1.2
                            Adapter    "myq"           : 0.1.1
                            Adapter    "mysensors"     : 2.0.1
                            Adapter    "myvbus"        : 0.0.6
                            Adapter    "nanoleaf-lightpanels": 0.8.2
                            Adapter    "nello"         : 2.0.8
                            Adapter    "netatmo"       : 1.3.1
                            Adapter    "nibeuplink"    : 0.3.0
                            Adapter    "nina"          : 0.0.23
                            Adapter    "node-red"      : 1.17.2
                            Adapter    "noolitef"      : 0.0.2
                            Adapter    "nuki"          : 1.2.3
                            Adapter    "nuki-extended" : 2.2.5    , installed 2.2.5
                            Adapter    "nut"           : 1.1.3
                            Adapter    "octoprint"     : 0.0.4
                            Adapter    "odl"           : 1.0.5
                            Adapter    "oilfox"        : 2.1.0
                            Adapter    "onkyo"         : 2.0.3
                            Adapter    "onvif"         : 0.4.3
                            Adapter    "openhab"       : 1.1.0
                            Adapter    "openligadb"    : 1.2.0
                            Adapter    "opentherm"     : 0.1.9
                            Adapter    "openweathermap": 0.1.0
                            Adapter    "opi"           : 0.1.1
                            Adapter    "oppoplayer"    : 0.2.1
                            Adapter    "owfs"          : 0.6.4
                            Adapter    "owntracks"     : 0.6.3
                            Adapter    "panasonic-viera": 1.0.2
                            Adapter    "parser"        : 1.0.7
                            Adapter    "paw"           : 0.3.2
                            Adapter    "phantomjs"     : 1.0.1
                            Adapter    "pi-hole"       : 1.2.3
                            Adapter    "piface"        : 1.0.0
                            Adapter    "pimatic"       : 0.3.0
                            Adapter    "ping"          : 1.4.7
                            Adapter    "places"        : 0.7.0
                            Adapter    "plenticore"    : 2.1.3
                            Adapter    "plex"          : 0.8.11
                            Adapter    "plexconnect"   : 0.0.7
                            Adapter    "pollenflug"    : 1.0.6
                            Adapter    "primelab"      : 1.0.2
                            Adapter    "proxmox"       : 1.0.2
                            Adapter    "proxy"         : 1.2.1
                            Adapter    "pushbullet"    : 0.0.11
                            Adapter    "pushover"      : 2.0.2
                            Adapter    "pushsafer"     : 0.1.8
                            Adapter    "radar2"        : 2.0.1
                            Adapter    "radiohead"     : 1.0.7
                            Adapter    "rainbird"      : 0.2.2
                            Adapter    "rflink"        : 2.1.5
                            Adapter    "rickshaw"      : 1.0.0
                            Adapter    "ring"          : 1.1.3
                            Adapter    "roadtraffic"   : 0.2.0
                            Adapter    "robonect"      : 0.1.3
                            Adapter    "roomba"        : 1.1.1
                            Adapter    "rpi2"          : 1.2.0    , installed 1.2.0
                            Adapter    "rssfeed"       : 0.0.28
                            Adapter    "s7"            : 1.1.8
                            Adapter    "samsung"       : 0.2.9
                            Adapter    "sanext"        : 0.0.4
                            Adapter    "sayit"         : 1.9.8
                            Adapter    "sbfspot"       : 3.0.0
                            Adapter    "scenes"        : 2.0.7    , installed 1.1.0 [Updateable]
                            Adapter    "schoolfree"    : 0.6.2
                            Adapter    "senec"         : 1.0.9
                            Adapter    "shelly"        : 3.3.1
                            Adapter    "shuttercontrol": 0.6.2
                            Adapter    "sia"           : 1.0.4
                            Adapter    "siegenia"      : 1.0.0
                            Adapter    "simple-api"    : 2.4.6    , installed 2.4.6
                            Adapter    "sma-em"        : 0.5.7
                            Adapter    "smappee"       : 0.2.2
                            Adapter    "smartmeter"    : 3.1.2
                            Adapter    "snips"         : 1.5.0
                            Adapter    "snmp"          : 0.5.0
                            Adapter    "socketio"      : 3.0.9    , installed 3.0.9
                            Adapter    "solarlog"      : 2.0.0
                            Adapter    "solarviewdatareader": 0.2.1
                            Adapter    "solarwetter"   : 1.0.0
                            Adapter    "sonnen"        : 1.5.2
                            Adapter    "sonoff"        : 2.3.3    , installed 2.3.3
                            Adapter    "sonos"         : 2.1.0    , installed 2.1.0
                            Adapter    "sonus"         : 0.1.1
                            Adapter    "sony-bravia"   : 1.0.1
                            Adapter    "sourceanalytix": 0.4.2
                            Adapter    "spotify-premium": 1.0.0
                            Adapter    "sql"           : 1.13.1
                            Adapter    "squeezebox"    : 1.0.0
                            Adapter    "squeezeboxrpc" : 1.2.1
                            Adapter    "starline"      : 1.0.0
                            Adapter    "statistics"    : 0.2.2
                            Adapter    "stiebel-isg"   : 1.4.11
                            Adapter    "stockmarket"   : 0.0.2
                            Adapter    "sunnyportal"   : 0.1.5
                            Adapter    "swiss-weather-api": 0.2.0
                            Adapter    "synology"      : 0.1.18
                            Adapter    "systeminfo"    : 0.3.1
                            Adapter    "tado"          : 0.1.9
                            Adapter    "tahoma"        : 0.3.3
                            Adapter    "tankerkoenig"  : 2.0.9
                            Adapter    "telegram"      : 1.5.9    , installed 1.5.9
                            Adapter    "terminal"      : 0.1.2
                            Adapter    "tesla-motors"  : 0.2.3
                            Adapter    "text2command"  : 1.3.0    , installed 1.3.0
                            Adapter    "tileboard"     : 0.1.1
                            Adapter    "tinker"        : 1.1.0
                            Adapter    "tino"          : 0.1.3
                            Adapter    "tinyrx4"       : 0.1.5
                            Adapter    "tr-064"        : 4.0.7
                            Adapter    "tradfri"       : 2.6.3
                            Adapter    "trashschedule" : 0.0.9    , installed 0.0.9
                            Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                            Adapter    "tuya"          : 3.3.5
                            Adapter    "tvspielfilm"   : 2.0.1
                            Adapter    "unifi"         : 0.5.5
                            Adapter    "unifi-protect" : 0.0.11
                            Adapter    "upnp"          : 1.0.16
                            Adapter    "vaillant"      : 0.0.10
                            Adapter    "valloxmv"      : 1.0.3
                            Adapter    "vcard"         : 0.0.9
                            Adapter    "vedirect"      : 0.1.0
                            Adapter    "velux"         : 0.0.6
                            Adapter    "viessmann"     : 1.2.4
                            Adapter    "viessmannapi"  : 1.3.2
                            Adapter    "virtualpowermeter": 1.2.1
                            Adapter    "vis"           : 1.2.6    , installed 1.2.6
                            Adapter    "vis-bars"      : 0.1.4
                            Adapter    "vis-canvas-gauges": 0.1.5
                            Adapter    "vis-colorpicker": 1.2.0
                            Adapter    "vis-fancyswitch": 1.1.0
                            Adapter    "vis-google-fonts": 0.1.0
                            Adapter    "vis-history"   : 1.0.0
                            Adapter    "vis-hqwidgets" : 1.1.4    , installed 1.1.4
                            Adapter    "vis-inventwo"  : 1.3.8
                            Adapter    "vis-jqui-mfd"  : 1.0.12
                            Adapter    "vis-justgage"  : 1.0.2
                            Adapter    "vis-keyboard"  : 0.0.2
                            Adapter    "vis-lcars"     : 1.0.4
                            Adapter    "vis-map"       : 1.0.4
                            Adapter    "vis-material"  : 0.1.3
                            Adapter    "vis-material-webfont": 0.0.3
                            Adapter    "vis-materialdesign": 0.3.14
                            Adapter    "vis-metro"     : 1.1.2
                            Adapter    "vis-players"   : 0.1.6
                            Adapter    "vis-plumb"     : 1.0.2
                            Adapter    "vis-rgraph"    : 0.0.2
                            Adapter    "vis-timeandweather": 1.1.7
                            Adapter    "vis-weather"   : 2.5.2
                            Adapter    "vodafone-speedtest": 0.0.5
                            Adapter    "volvo"         : 0.0.2
                            Adapter    "vr200"         : 1.0.0
                            Adapter    "vw-connect"    : 0.0.16
                            Adapter    "weatherunderground": 3.2.1
                            Adapter    "web"           : 3.0.9    , installed 3.0.9
                            Adapter    "web-speedy"    : 0.2.0
                            Adapter    "weishaupt-wem" : 0.0.8
                            Adapter    "wiffi-wz"      : 2.2.0
                            Adapter    "wifilight"     : 1.1.0
                            Adapter    "windows-control": 0.1.3
                            Adapter    "wlanthermo-nano": 0.1.1
                            Adapter    "wled"          : 0.5.0
                            Adapter    "wm-bus"        : 0.3.1
                            Adapter    "wolf"          : 1.2.0
                            Adapter    "worx"          : 1.0.2
                            Adapter    "xbox"          : 0.6.5
                            Adapter    "xs1"           : 1.0.2
                            Adapter    "yahka"         : 0.11.0
                            Adapter    "yamaha"        : 0.3.19
                            Adapter    "yeelight-2"    : 1.0.3
                            Adapter    "youtube"       : 0.0.11
                            Adapter    "yr"            : 2.0.3
                            Adapter    "zigbee"        : 1.1.1    , installed 1.1.1
                            Adapter    "zoneminder"    : 0.3.3
                            Adapter    "zont"          : 0.5.4
                            Adapter    "zwave"         : 2.0.1
                            Adapter    "zwave2"        : 1.3.3
                            da ist auch nichts dabei was mein usb blockieren sollte.
                            lg
                              @gifftstaub
                              Deaktivier mal den 'discovery' Adapter. Soweit ich weiß fragt der auch den serialport an.
                                gifftstaub @Thomas Braun last edited by gifftstaub
                                @Thomas-Braun said in Zigbee Adapter Fehler nach Update auf JS-Controller 3.1.5:
                                @gifftstaub
                                nein das liegt nicht am 'discovery' Adapter Serial ist nicht angehackt.
                                lg
                                Edit: Morgen kommt ein neuer USB Stick bericht folgt.
                                  Nabend Zusammen,
                                  Kurzes Feedback zum Porblem mit dem CC2531 Stick.
                                  Alte Stick ist Platt keine Ahnung wie das Passiert ist.
                                  Neuer Stick ran und siehe da läuft Sofort mit Adapter ( Zigbee 1.1.1 ) und folgende Komponenten.
                                  JS controller: 3.1.5
                                  Node : v12.18.0
                                  Node.js: v12.18.0
                                  NPM: 6.14.4
                                  Ich möchte mich bei allem sehr bedanken für die Hilfestellung 👍
                                  lg
                                    P-A-L-A-D-I-N last edited by
                                    Ich kann neuerdings meine Zigbee-Geräte nicht mehr steuern. In den Objekten werden auch falsche Angaben gemacht bez. ein/aus, Temperatur etc.
                                    Am System oder Adapter habe ich nichts verändert! Da Neustarts etc. nichts gebracht haben, habe ich dann von Github die neueste Version gezogen - hat aber auch nichts gebracht.
                                    Hier das Log, wenn ich versuche, mein Arbeitszimmerlicht zu schalten:
                                    zigbee.0	2020-06-17 22:35:45.628	error	(10296) Error on send command to 0x00158d0003cefef4. Error: Error: Command 0x00158d0003cefef4/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"s
                                    zigbee.0	2020-06-17 22:35:41.258	error	at rejected (C:\ioBroker\Zuhause\node_modules\zigbee-herdsman\dist\controller\model\endpoint.js:6:65)
                                    zigbee.0	2020-06-17 22:35:41.258	error	at Generator.throw (<anonymous>)
                                    zigbee.0	2020-06-17 22:35:41.258	error	at Endpoint.<anonymous> (C:\ioBroker\Zuhause\node_modules\zigbee-herdsman\dist\controller\model\endpoint.js:365:23)
                                    zigbee.0	2020-06-17 22:35:41.258	error	(10296) Error on send command to 0x00158d0003cefef4. Error: Error: Command 0x00158d0003cefef4/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,
                                    fritzdect.0	2020-06-17 22:35:15.828	warn	(12152) DECT200_34:31:C4:D3:D6:E3 is not present, check the device connection, no values are written
                                    Wäre toll, wenn mir jemand helfen könnte!
                                    JB_Sullivan ldittmar 2 Replies Last reply Reply Quote 0
                                    • JB_Sullivan
                                      JB_Sullivan @P-A-L-A-D-I-N last edited by
                                      @P-A-L-A-D-I-N
                                      ggf. ein COM Port Problem? Hatte ich auch nach nodesjs Update auf 12.18 mit rflink.
                                      npm rebuild gemacht bzw. npm install serialport --build-from-source?
                                        P-A-L-A-D-I-N @JB_Sullivan last edited by P-A-L-A-D-I-N
                                        @JB_Sullivan sagte in Zigbee Adapter Fehler nach Update auf JS-Controller 3.1.5:
                                        Hat leider nichts gebracht! Ich mache jetzt aber mal sicherheitshalber noch einen Neustart und schaue dann nochmal.
                                        EDIT: Neustart hat auch nichts gebracht. Scheinbar besteht keine Verbindung mehr zu den Zigbee-Geräten, obwohl der Port stimmt. In der Übersicht bei "Netzwerkkarte" ist auch alles auf rot und es sind keinerlei Verbindungen mehr zu den Geräten eingezeichnet.
                                          Das Aus- und Einstecken des USB-Adapters hat kurzzeitig geholfen - die Geräte waren in der Übersicht wieder zu sehen. Allerdings war die Freude nur von sehr, sehr kurzer Dauer. Jetzt ist wieder alles weg...
                                          Hier noch das Log des letzten Schaltversuchs:
                                          zigbee.0	2020-06-19 11:53:55.434	error	(19452) Error on send command to 0x00158d0003cefef4. Error: Error: Command 0x00158d0003cefef4/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"
                                          zigbee.0	2020-06-19 11:53:51.065	error	(19452) Error on send command to 0x00158d0003cefef4. Error: Error: Command 0x00158d0003cefef4/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"s
                                          zigbee.0	2020-06-19 11:53:25.956	error	at rejected (C:\ioBroker\Zuhause\node_modules\zigbee-herdsman\dist\controller\model\endpoint.js:6:65))
                                          zigbee.0	2020-06-19 11:53:25.956	error	at Generator.throw (<anonymous>)
                                          zigbee.0	2020-06-19 11:53:25.956	error	at Endpoint.<anonymous> (C:\ioBroker\Zuhause\node_modules\zigbee-herdsman\dist\controller\model\endpoint.js:255:23)
                                          zigbee.0	2020-06-19 11:53:25.956	error	(19452) Failed to configure 0x000d6f000fabe64e COSensor-EM, attempt 1 (Error: Bind 0x000d6f000fabe64e/1 genPowerCfg from '0x00124b0018e20893/1' failed (Error: AREQ - ZDO - bindRsp after 10000ms)
                                          zigbee.0	2020-06-19 11:53:15.837	info	(19452) Zigbee started
                                          zigbee.0	2020-06-19 11:53:15.837	info	(19452) 0x00158d0003cefef4 (addr 33236): LLKZMK11LM - Xiaomi Aqara wireless relay controller (Router)
                                          zigbee.0	2020-06-19 11:53:15.835	info	(19452) 0x000d6f000fabe64e (addr 36585): HS1CA-E - HEIMAN Smart carbon monoxide sensor (EndDevice)
                                          zigbee.0	2020-06-19 11:53:15.834	info	(19452) 0x00158d000340d5ad (addr 663): JTQJ-BF-01LM/BW - Xiaomi MiJia gas leak detector (Router)
                                          zigbee.0	2020-06-19 11:53:15.833	info	(19452) 0x7cb03eaa0a01e0f8 (addr 58413): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.0	2020-06-19 11:53:15.832	info	(19452) 0x7cb03eaa0a01bfef (addr 53682): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.0	2020-06-19 11:53:15.831	info	(19452) 0x84182600000f3893 (addr 44117): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          zigbee.0	2020-06-19 11:53:15.830	info	(19452) 0x00158d00036b9140 (addr 15766): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.0	2020-06-19 11:53:15.829	info	(19452) 0x00158d00032300c0 (addr 12784): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.0	2020-06-19 11:53:15.828	info	(19452) 0x00158d000349c4d0 (addr 4916): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                          zigbee.0	2020-06-19 11:53:15.824	info	(19452) Configuring 0x000d6f000fabe64e COSensor-EM
                                          zigbee.0	2020-06-19 11:53:15.818	info	(19452) Currently 9 devices are joined:
                                          zigbee.0	2020-06-19 11:53:15.764	info	(19452) --> transmitPower : normal
                                          zigbee.0	2020-06-19 11:53:15.740	info	(19452) Disable LED
                                          zigbee.0	2020-06-19 11:53:15.689	info	(19452) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190425}}
                                          zigbee.0	2020-06-19 11:53:13.296	info	(19452) Starting Zigbee...
                                          zigbee.0	2020-06-19 11:53:13.237	info	(19452) starting. Version 1.1.1 in C:/ioBroker/Zuhause/node_modules/iobroker.zigbee, node: v12.18.0, js-controller: 3.1.4
                                            Noch ein Nachtrag (wegen der Übersichtlichkeit als getrennter Beitrag):
                                            In der Übersicht des Adapters ("Netzwerkkarte") waren die Geräte zwischenzeitlich, auch ohne Aus- und Einstecken des USB-Sticks, wieder grün und um den Coordinator herum versammelt. Aber: Das Licht läßt sich trotzdem, auch in diesem Zustand, nicht schalten.
                                            Hier noch das Log des Schaltversuchs (im o.g. Zustand mit grünen Verbindungen in der Übersicht):
                                            info.0	2020-06-19 13:14:30.839	info	(11556) Popup news was read...
                                            zigbee.0	2020-06-19 13:14:21.861	error	(19452) Error on send command to 0x00158d0003cefef4. Error: Error: Command 0x00158d0003cefef4/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"
                                            zigbee.0	2020-06-19 13:14:17.316	error	at rejected (C:\ioBroker\Zuhause\node_modules\zigbee-herdsman\dist\controller\model\endpoint.js:6:65)
                                            zigbee.0	2020-06-19 13:14:17.316	error	at Generator.throw (<anonymous>)
                                            zigbee.0	2020-06-19 13:14:17.316	error	at Endpoint.<anonymous> (C:\ioBroker\Zuhause\node_modules\zigbee-herdsman\dist\controller\model\endpoint.js:365:23)
                                            zigbee.0	2020-06-19 13:14:17.316	error	(19452) Error on send command to 0x00158d0003cefef4. Error: Error: Command 0x00158d0003cefef4/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"
                                            info.0	2020-06-19 12:44:30.904	info	(11556) Popup news was read...
                                            Es muß also irgendetwas mit diesem verfluchten JS- und Node-Gelump zu tun haben - wie eigentlich immer, wenn es mal wieder klemmt!
                                            Keine Ahnung, warum die Entwickler des ioBroker nicht einfach mal eine stabile Version bestehen lassen und man da ständig irgendwas herumbasteln muß! Mich als einfachen Nutzer kotzt das alles jedenfalls einfach nur noch tierisch an! Ich möchte keine abgehobenen Schickimickisachen machen und auf Teufel komm raus den allerneusten "Controller XY, Node, NPM, WeißderTeufelwas" da stehen haben, sondern einfach nur ein stabiles, gerne auch "veraltetes", System betreiben, das solide seine Arbeit verrichtet! Es kann ja wohl nicht sein, daß ich alle zwei Wochen spätestens wieder stundenlang dasitze und auf Fehlersuche gehen muß, nur weil wieder irgendein verk... Update (wohlgemerkt auf "default", nicht auf "latest") alles zerschossen hat und meine ganze Beleuchtung oder irgendein anderes Zeug dann nicht mehr funktioniert! 👿
                                            arteck apollon77 2 Replies Last reply Reply Quote 0
                                            js controller update zigbee adapter
                                            10
                                            51
                                            4499
