    4. Zigbee Adapter Fehler nach Update auf JS-Controller 3.1.5
    UNSOLVED Zigbee Adapter Fehler nach Update auf JS-Controller 3.1.5
      gifftstaub @arteck last edited by gifftstaub
      @arteck
      Probiert habe ich auch mit sudo rm -R /opt/iobroker/node_modules/@serialport und ein npm install serialport --build-from-source
      > @serialport/bindings@8.0.8 install /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings
      > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
      make: Verzeichnis „/opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/build“ wird betreten
        CXX(target) Release/obj.target/bindings/src/serialport.o
      In file included from ../src/./serialport.h:6,
                       from ../src/serialport.cpp:1:
      ../../../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
      ../../../../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
      ../src/serialport.cpp: At global scope:
      ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
       SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
      ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
       SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
      In file included from ../../../../../nan/nan.h:56,
      /home/iobroker/.cache/node-gyp/12.18.0/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
             (node::addon_register_func) (regfunc),                          \
      /home/iobroker/.cache/node-gyp/12.18.0/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’
         NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
      ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’
       NODE_MODULE(serialport, init);
        CXX(target) Release/obj.target/bindings/src/serialport_unix.o
      In file included from ../src/serialport.h:6,
                       from ../src/serialport_unix.cpp:2:
      ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
      ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
           snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
      ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
      ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
      ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
           snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
      ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
        CXX(target) Release/obj.target/bindings/src/poller.o
      In file included from ../src/poller.cpp:1:
        CXX(target) Release/obj.target/bindings/src/serialport_linux.o
        SOLINK_MODULE(target) Release/obj.target/bindings.node
        COPY Release/bindings.node
      make: Verzeichnis „/opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/build“ wird verlassen
      > @serialport/bindings@9.0.0 install /opt/iobroker/node_modules/@serialport/bindings
      make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird betreten
      In file included from ../../../nan/nan.h:56,
      make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird verlassen
      > serialport@8.0.8 postinstall /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport
      > node thank-you.js
      Thank you for using serialport!
      If you rely on this package, please consider supporting our open collective:
      > https://opencollective.com/serialport/donate
      > serialport@9.0.0 postinstall /opt/iobroker/node_modules/serialport
      > node thank-you.js
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.12 (node_modules/zigbee-herdsman/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.12: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      + serialport@9.0.0
      added 31 packages from 3 contributors and updated 1 package in 50.316s
      49 packages are looking for funding
        run `npm fund` for details
      trozdem die gleichen fehlermeldungen.
      ich sehe gerade beim installieren des Adapters ergibt sich folgende Meldungen.
      $ ./iobroker add zigbee  --host raspberrypi
      NPM version: 6.14.5
      npm install iobroker.zigbee@1.1.1 --loglevel error --prefix "/opt/iobroker" (System call)
      In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);        ^~~~~~~~~~~~~
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);        ^~~~~~~~~~~~~~~
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);        ^~~~~~~~~~~~~~
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);        ^~~~~~~~~~~~~~
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);        ^~~~~~~~~~~~
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);        ^~~~~~~~~~~~
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);        ^~~~~~~~~~~~~~~~~~~~
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);        ^~~~~~~~~~~~~~
      ../src/serialport.cpp: At global scope:../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {                            ^
      ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses] SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {                              ^
      In file included from ../../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.18.0/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.cache/node-gyp/12.18.0/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(serialport, init); ^~~~~~~~~~~
      In file included from ../src/serialport.h:6,                 from ../src/serialport_unix.cpp:2:../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
      ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);                                                            ^~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);     ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
      ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);                                                            ^~~~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);     ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
      In file included from ../src/poller.cpp:1:../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
      host.raspberrypi install adapter zigbee
      upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
      upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_lightbar.png img/philips_hue_lightbar.png image/png
      upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lifecontrol_lamp.png img/lifecontrol_lamp.png image/png
      upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/jiawen.png img/jiawen.png image/png
      upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/iluminize_511_040.png img/iluminize_511_040.png image/png
      upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_led1837r5.PNG img/ikea_led1837r5.PNG image/png
      upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hue_go.png img/hue_go.png image/png
      upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gledopto_bulb.png img/gledopto_bulb.png image/png
      upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ewelink_MS01.png img/ewelink_MS01.png image/png
      upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_neutral1.png img/ctrl_neutral1.png image/png
      upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_switch.png img/aqara_switch.png image/png
      upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_numan_body_sensor.png img/aqara_numan_body_sensor.png image/png
      upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_curtain.png img/aqara_curtain.png image/png
      upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_bulb.png img/aqara_bulb.png image/png
      upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZWLD-100.png img/ZWLD-100.png image/png
      upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0218.png img/TS0218.png image/png
      upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0215.png img/TS0215.png image/png
      upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LTW017.png img/LTW017.png image/png
      upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LTC015.png img/LTC015.png image/png
      upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LTC014.png img/LTC014.png image/png
      upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LCT002.png img/LCT002.png image/png
      upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Ikea_fyrtur.png img/Ikea_fyrtur.png image/png
      upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
      upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
      upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
      upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
      upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
      upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
      upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
      upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
      upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
      host.raspberrypi object system.adapter.zigbee created/updated
      host.raspberrypi create instance zigbee
      host.raspberrypi object zigbee.0.info.groups created
      host.raspberrypi object zigbee.0.info.pairingMessage created
      host.raspberrypi object zigbee.0.info.pairingCountdown created
      host.raspberrypi object zigbee.0.info.pairingMode created
      host.raspberrypi object zigbee.0.info.connection created
      host.raspberrypi object zigbee.0.info created
      host.raspberrypi object system.adapter.zigbee.0.sigKill created
      host.raspberrypi object system.adapter.zigbee.0.eventLoopLag created
      host.raspberrypi object system.adapter.zigbee.0.outputCount created
      host.raspberrypi object system.adapter.zigbee.0.inputCount created
      host.raspberrypi object system.adapter.zigbee.0.uptime created
      host.raspberrypi object system.adapter.zigbee.0.memRss created
      host.raspberrypi object system.adapter.zigbee.0.memHeapTotal created
      host.raspberrypi object system.adapter.zigbee.0.memHeapUsed created
      host.raspberrypi object system.adapter.zigbee.0.cputime created
      host.raspberrypi object system.adapter.zigbee.0.cpu created
      host.raspberrypi object system.adapter.zigbee.0.compactMode created
      host.raspberrypi object system.adapter.zigbee.0.connected created
      host.raspberrypi object system.adapter.zigbee.0.alive created
      host.raspberrypi Set default value of zigbee.0.info.groups:
      host.raspberrypi Set default value of zigbee.0.info.pairingMessage:
      host.raspberrypi Set default value of zigbee.0.info.pairingCountdown: 0
      host.raspberrypi Set default value of zigbee.0.info.pairingMode: false
      host.raspberrypi Set default value of zigbee.0.info.connection: false
      host.raspberrypi object system.adapter.zigbee.0 created
      process exited with code 0
      lg
        gifftstaub last edited by
        Push
        Ich habe nun folgendes gemacht.
        pi@raspberrypi:/opt/iobroker/node_modules/serialport $ npm install --production
        > @serialport/bindings@8.0.8 install /opt/iobroker/node_modules/serialport/node_modules/@serialport/bindings
        prebuild-install WARN install No prebuilt binaries found (target=12.18.0 runtime=node arch=arm libc= platform=linux)
        make: Verzeichnis „/opt/iobroker/node_modules/serialport/node_modules/@serialport/bindings/build“ wird betreten
        make: Verzeichnis „/opt/iobroker/node_modules/serialport/node_modules/@serialport/bindings/build“ wird verlassen
        > serialport@8.0.8 postinstall /opt/iobroker/node_modules/serialport
        > node thank-you.js
        npm notice created a lockfile as package-lock.json. You should commit this file.
        added 73 packages from 43 contributors and audited 78 packages in 16.172s
        1 package is looking for funding
        found 0 vulnerabilities
        pi@raspberrypi:/opt/iobroker/node_modules/serialport $ npm fund
        serialport@8.0.8
        └─┬ https://github.com/sponsors/sindresorhus
          └── mimic-response@2.1.0
        liegt das Problem an der 12.18.0?
        lg
          Thomas Braun Most Active @gifftstaub last edited by
          @gifftstaub
          Nein, mit 12.18.0 hat das grundsätzlich nichts zu tun, denn:
          pi@raspberrypi:/opt/iobroker $ nodejs -v
          v12.18.0
          pi@raspberrypi:/opt/iobroker $ npm ls serialport
          iobroker.inst@2.0.3 /opt/iobroker
          ├─┬ iobroker.discovery@2.3.7
          │ └── serialport@8.0.8
          └─┬ iobroker.zigbee@1.1.1
            └─┬ zigbee-herdsman@0.12.83
              └── serialport@8.0.7
            gifftstaub @Thomas Braun last edited by
            @Thomas-Braun
            könnte der Stick defekt sein?
            └─┬ iobroker.zigbee@1.0.0
              └─┬ zigbee-herdsman@0.12.95
            lg
              @gifftstaub
              Hast du eigentlich im Raspberry auch den Serialport in
              sudo raspi-config
              aktiviert?
              Geht unter 5 - P6 - No - Yes
                @Thomas-Braun
                eingentlich ja am serialport war ich nocch nie dran.
                ich habe das mal proformer gemacht wie du beschrieben hast, nach einem reboot immer noch die gleichen Meldungen.
                zigbee.0	2020-06-16 14:21:14.793	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
                zigbee.0	2020-06-16 14:21:14.793	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
                zigbee.0	2020-06-16 14:21:14.793	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:111:49)
                zigbee.0	2020-06-16 14:21:14.793	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:4:12)
                zigbee.0	2020-06-16 14:21:14.793	error	at new Promise (<anonymous>)
                zigbee.0	2020-06-16 14:21:14.793	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:8:71
                zigbee.0	2020-06-16 14:21:14.793	error	at Generator.next (<anonymous>)
                zigbee.0	2020-06-16 14:21:14.793	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:113:32)
                zigbee.0	2020-06-16 14:21:14.793	error	(2686) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
                zigbee.0	2020-06-16 14:21:14.792	error	(2686) Failed to start Zigbee
                zigbee.0	2020-06-16 14:21:14.554	info	(2686) Starting Zigbee...
                lg
                  Thomas Braun Most Active @gifftstaub last edited by Thomas Braun
                  @gifftstaub sagte in Zigbee Adapter Fehler nach Update auf JS-Controller 3.1.5:
                  Da greift wohl schon irgendwas anderes drauf zu. Hast du noch deConz parallel laufen?
                    @Thomas-Braun
                    nein nur zigbee
                      liste der Installierten Adapter
                      Used repository: latest
                      hash unchanged, use cached sources
                      update done
                      Adapter    "accuweather"   : 1.1.3
                      Adapter    "admin"         : 4.1.1    , installed 4.1.1
                      Adapter    "alarm"         : 0.7.5
                      Adapter    "alexa2"        : 3.1.2    , installed 3.1.2
                      Adapter    "alpha2"        : 1.0.0
                      Adapter    "amazon-dash"   : 1.1.0
                      Adapter    "artnet"        : 1.2.2
                      Adapter    "asterisk"      : 1.0.6
                      Adapter    "asuswrt"       : 1.0.1
                      Adapter    "b-control-em"  : 0.2.1
                      Adapter    "backitup"      : 1.5.8    , installed 1.5.8
                      Adapter    "beckhoff"      : 1.2.2
                      Adapter    "benq"          : 0.2.2
                      Adapter    "binance"       : 1.1.2
                      Adapter    "ble"           : 0.11.6
                      Adapter    "blink4home"    : 0.1.1
                      Adapter    "bmw"           : 1.4.0
                      Adapter    "boblight"      : 0.0.1
                      Adapter    "bosesoundtouch": 0.9.2
                      Adapter    "botvac"        : 1.0.0
                      Adapter    "bring"         : 1.7.2
                      Adapter    "broadlink2"    : 2.0.3
                      Adapter    "bsblan"        : 0.1.2
                      Adapter    "bshb"          : 0.1.10
                      Adapter    "calendar"      : 1.2.0
                      Adapter    "cameras"       : 0.1.2
                      Adapter    "chromecast"    : 2.3.1
                      Adapter    "cloud"         : 3.0.3
                      Adapter    "comfoair"      : 1.1.1
                      Adapter    "contact"       : 1.1.3
                      Adapter    "contactid"     : 1.0.0
                      Adapter    "coronavirus-statistics": 0.5.9
                      Adapter    "corrently"     : 0.0.2
                      Adapter    "countdown"     : 1.1.0
                      Adapter    "cul"           : 1.2.1
                      Adapter    "daikin"        : 1.0.5
                      Adapter    "daswetter"     : 3.0.1
                      Adapter    "deconz"        : 1.3.9
                      Adapter    "denon"         : 1.7.7
                      Adapter    "devices"       : 0.3.6
                      Adapter    "digitalstrom"  : 2.0.5
                      Adapter    "discovergy"    : 0.5.4
                      Adapter    "discovery"     : 2.3.7    , installed 2.3.7
                      Adapter    "doorbird"      : 0.1.5
                      Adapter    "ds18b20"       : 1.1.4
                      Adapter    "dwd"           : 2.4.10
                      Adapter    "ebus"          : 2.0.0
                      Adapter    "ecovacs-deebot": 1.0.3
                      Adapter    "egigeozone"    : 0.1.2
                      Adapter    "ekey"          : 1.1.0
                      Adapter    "email"         : 1.0.7    , installed 1.0.7
                      Adapter    "emby"          : 1.0.2
                      Adapter    "energymanager" : 1.2.2
                      Adapter    "enet"          : 1.0.1
                      Adapter    "epson_stylus_px830": 0.2.1
                      Adapter    "exchangerates" : 0.0.13
                      Adapter    "fakeroku"      : 0.2.1
                      Adapter    "fb-checkpresence": 1.0.3
                      Adapter    "feiertage"     : 1.0.19
                      Adapter    "fhem"          : 1.5.2
                      Adapter    "find-my-iphone": 0.2.17
                      Adapter    "firetv"        : 1.0.0
                      Adapter    "fitbit-api"    : 0.1.1
                      Adapter    "flot"          : 1.10.0
                      Adapter    "foobar2000"    : 2.0.3
                      Adapter    "fritzbox"      : 0.2.1
                      Adapter    "fritzdect"     : 0.3.2
                      Adapter    "fronius"       : 1.0.5
                      Adapter    "fullcalendar"  : 1.1.0
                      Adapter    "fullybrowser"  : 1.0.3
                      Adapter    "g-homa"        : 0.5.3
                      Adapter    "geofency"      : 0.3.2
                      Adapter    "gruenbeck"     : 0.0.18
                      Adapter    "habpanel"      : 0.4.1
                      Adapter    "haier"         : 1.0.3
                      Adapter    "ham"           : 1.1.2
                      Adapter    "ham-wemo"      : 1.0.1
                      Adapter    "harmony"       : 1.2.2
                      Adapter    "hass-mqtt"     : 0.0.7
                      Adapter    "heatingcontrol": 0.5.6
                      Adapter    "heytech"       : 0.2.0
                      Adapter    "hid"           : 0.1.17
                      Adapter    "hilink"        : 0.2.7
                      Adapter    "history"       : 1.9.8    , installed 1.9.8
                      Adapter    "hm-rega"       : 2.6.14
                      Adapter    "hm-rpc"        : 1.14.10
                      Adapter    "hmip"          : 1.0.1
                      Adapter    "hombot"        : 0.1.3
                      Adapter    "homeconnect"   : 0.0.30
                      Adapter    "homee"         : 1.0.7
                      Adapter    "homepilot"     : 1.1.4
                      Adapter    "hp-ilo"        : 1.0.5
                      Adapter    "hs100"         : 2.0.0
                      Adapter    "hue"           : 3.3.5
                      Adapter    "hue-extended"  : 1.3.2
                      Adapter    "hyperion"      : 0.0.9
                      Adapter    "i2c"           : 0.0.6
                      Adapter    "ical"          : 1.7.0    , installed 1.7.0
                      Adapter    "icons-addictive-flavour-png": 0.1.0
                      Adapter    "icons-fatcow-hosting": 0.1.0
                      Adapter    "icons-icons8"  : 0.0.1
                      Adapter    "icons-material-png": 0.1.0
                      Adapter    "icons-material-svg": 0.1.0
                      Adapter    "icons-mfd-png" : 1.0.2
                      Adapter    "icons-mfd-svg" : 1.0.2
                      Adapter    "icons-open-icon-library-png": 0.1.2
                      Adapter    "icons-ultimate-png": 1.0.1
                      Adapter    "influxdb"      : 1.8.6
                      Adapter    "info"          : 1.7.5    , installed 1.7.5
                      Adapter    "innogy-smarthome": 0.3.4
                      Adapter    "intesishome"   : 0.1.2
                      Adapter    "iogo"          : 0.5.10
                      Adapter    "iot"           : 1.5.3    , installed 1.5.3
                      Adapter    "iqontrol"      : 1.1.0    , installed 1.1.0
                      Adapter    "javascript"    : 4.6.17   , installed 4.6.17
                      Adapter    "jeelink"       : 0.1.3
                      Controller "js-controller" : 3.1.5    , installed 3.1.5
                      Adapter    "js2fs"         : 0.1.5
                      Adapter    "kecontact"     : 0.1.0
                      Adapter    "klf200"        : 0.9.5
                      Adapter    "km200"         : 2.0.3
                      Adapter    "knmi-weather"  : 0.2.0
                      Adapter    "knx"           : 1.0.41
                      Adapter    "kodi"          : 2.0.4
                      Adapter    "kress"         : 2.5.5
                      Adapter    "lametric"      : 0.0.9
                      Adapter    "landroid"      : 1.0.3
                      Adapter    "lcn"           : 0.6.3
                      Adapter    "legrand-ecocompteur": 0.0.4
                      Adapter    "letrika_comgw" : 0.0.5
                      Adapter    "lgtv"          : 1.1.6
                      Adapter    "lgtv-rs"       : 0.1.0
                      Adapter    "lgtv11"        : 1.0.5
                      Adapter    "lifx"          : 0.1.1
                      Adapter    "lightify"      : 0.2.16
                      Adapter    "link"          : 0.5.9
                      Adapter    "linkeddevices" : 1.1.4
                      Adapter    "logparser"     : 0.4.11
                      Adapter    "lovelace"      : 1.1.0
                      Adapter    "loxone"        : 1.0.0
                      Adapter    "luftdaten"     : 0.0.15
                      Adapter    "lupusec"       : 1.2.7
                      Adapter    "luxtronik1"    : 0.2.3
                      Adapter    "material"      : 0.13.8
                      Adapter    "maxcube"       : 0.1.2
                      Adapter    "maxcul"        : 1.3.0
                      Adapter    "mbus"          : 2.2.0
                      Adapter    "mclighting"    : 0.1.1
                      Adapter    "megad"         : 1.2.1
                      Adapter    "megadd"        : 0.2.0
                      Adapter    "megaesp"       : 0.1.0
                      Adapter    "mercedesme"    : 0.0.21
                      Adapter    "mercury"       : 0.1.1
                      Adapter    "meross"        : 1.4.1
                      Adapter    "meteoalarm"    : 1.1.0
                      Adapter    "midea"         : 0.0.6
                      Adapter    "miele"         : 0.1.5
                      Adapter    "mielecloudservice": 1.2.4
                      Adapter    "mihome"        : 1.3.0
                      Adapter    "mihome-airpurifier": 0.1.8
                      Adapter    "mihome-lamp"   : 1.1.0
                      Adapter    "mihome-plug"   : 0.2.1
                      Adapter    "mihome-vacuum" : 2.0.7
                      Adapter    "miio"          : 0.0.13
                      Adapter    "mikrotik"      : 1.0.12
                      Adapter    "milight"       : 0.3.6
                      Adapter    "milight-smart-light": 0.6.0
                      Adapter    "mobile"        : 0.5.0
                      Adapter    "modbus"        : 3.1.3
                      Adapter    "moma"          : 1.2.6
                      Adapter    "mpd"           : 1.0.5
                      Adapter    "mqtt"          : 2.1.3
                      Adapter    "mqtt-client"   : 1.3.1
                      Adapter    "multicast"     : 0.1.5
                      Adapter    "musiccast"     : 0.1.3
                      Adapter    "mydlink"       : 1.1.2
                      Adapter    "myq"           : 0.1.1
                      Adapter    "mysensors"     : 2.0.1
                      Adapter    "myvbus"        : 0.0.6
                      Adapter    "nanoleaf-lightpanels": 0.8.2
                      Adapter    "nello"         : 2.0.8
                      Adapter    "netatmo"       : 1.3.1
                      Adapter    "nibeuplink"    : 0.3.0
                      Adapter    "nina"          : 0.0.23
                      Adapter    "node-red"      : 1.17.2
                      Adapter    "noolitef"      : 0.0.2
                      Adapter    "nuki"          : 1.2.3
                      Adapter    "nuki-extended" : 2.2.5    , installed 2.2.5
                      Adapter    "nut"           : 1.1.3
                      Adapter    "octoprint"     : 0.0.4
                      Adapter    "odl"           : 1.0.5
                      Adapter    "oilfox"        : 2.1.0
                      Adapter    "onkyo"         : 2.0.3
                      Adapter    "onvif"         : 0.4.3
                      Adapter    "openhab"       : 1.1.0
                      Adapter    "openligadb"    : 1.2.0
                      Adapter    "opentherm"     : 0.1.9
                      Adapter    "openweathermap": 0.1.0
                      Adapter    "opi"           : 0.1.1
                      Adapter    "oppoplayer"    : 0.2.1
                      Adapter    "owfs"          : 0.6.4
                      Adapter    "owntracks"     : 0.6.3
                      Adapter    "panasonic-viera": 1.0.2
                      Adapter    "parser"        : 1.0.7
                      Adapter    "paw"           : 0.3.2
                      Adapter    "phantomjs"     : 1.0.1
                      Adapter    "pi-hole"       : 1.2.3
                      Adapter    "piface"        : 1.0.0
                      Adapter    "pimatic"       : 0.3.0
                      Adapter    "ping"          : 1.4.7
                      Adapter    "places"        : 0.7.0
                      Adapter    "plenticore"    : 2.1.3
                      Adapter    "plex"          : 0.8.11
                      Adapter    "plexconnect"   : 0.0.7
                      Adapter    "pollenflug"    : 1.0.6
                      Adapter    "primelab"      : 1.0.2
                      Adapter    "proxmox"       : 1.0.2
                      Adapter    "proxy"         : 1.2.1
                      Adapter    "pushbullet"    : 0.0.11
                      Adapter    "pushover"      : 2.0.2
                      Adapter    "pushsafer"     : 0.1.8
                      Adapter    "radar2"        : 2.0.1
                      Adapter    "radiohead"     : 1.0.7
                      Adapter    "rainbird"      : 0.2.2
                      Adapter    "rflink"        : 2.1.5
                      Adapter    "rickshaw"      : 1.0.0
                      Adapter    "ring"          : 1.1.3
                      Adapter    "roadtraffic"   : 0.2.0
                      Adapter    "robonect"      : 0.1.3
                      Adapter    "roomba"        : 1.1.1
                      Adapter    "rpi2"          : 1.2.0    , installed 1.2.0
                      Adapter    "rssfeed"       : 0.0.28
                      Adapter    "s7"            : 1.1.8
                      Adapter    "samsung"       : 0.2.9
                      Adapter    "sanext"        : 0.0.4
                      Adapter    "sayit"         : 1.9.8
                      Adapter    "sbfspot"       : 3.0.0
                      Adapter    "scenes"        : 2.0.7    , installed 1.1.0 [Updateable]
                      Adapter    "schoolfree"    : 0.6.2
                      Adapter    "senec"         : 1.0.9
                      Adapter    "shelly"        : 3.3.1
                      Adapter    "shuttercontrol": 0.6.2
                      Adapter    "sia"           : 1.0.4
                      Adapter    "siegenia"      : 1.0.0
                      Adapter    "simple-api"    : 2.4.6    , installed 2.4.6
                      Adapter    "sma-em"        : 0.5.7
                      Adapter    "smappee"       : 0.2.2
                      Adapter    "smartmeter"    : 3.1.2
                      Adapter    "snips"         : 1.5.0
                      Adapter    "snmp"          : 0.5.0
                      Adapter    "socketio"      : 3.0.9    , installed 3.0.9
                      Adapter    "solarlog"      : 2.0.0
                      Adapter    "solarviewdatareader": 0.2.1
                      Adapter    "solarwetter"   : 1.0.0
                      Adapter    "sonnen"        : 1.5.2
                      Adapter    "sonoff"        : 2.3.3    , installed 2.3.3
                      Adapter    "sonos"         : 2.1.0    , installed 2.1.0
                      Adapter    "sonus"         : 0.1.1
                      Adapter    "sony-bravia"   : 1.0.1
                      Adapter    "sourceanalytix": 0.4.2
                      Adapter    "spotify-premium": 1.0.0
                      Adapter    "sql"           : 1.13.1
                      Adapter    "squeezebox"    : 1.0.0
                      Adapter    "squeezeboxrpc" : 1.2.1
                      Adapter    "starline"      : 1.0.0
                      Adapter    "statistics"    : 0.2.2
                      Adapter    "stiebel-isg"   : 1.4.11
                      Adapter    "stockmarket"   : 0.0.2
                      Adapter    "sunnyportal"   : 0.1.5
                      Adapter    "swiss-weather-api": 0.2.0
                      Adapter    "synology"      : 0.1.18
                      Adapter    "systeminfo"    : 0.3.1
                      Adapter    "tado"          : 0.1.9
                      Adapter    "tahoma"        : 0.3.3
                      Adapter    "tankerkoenig"  : 2.0.9
                      Adapter    "telegram"      : 1.5.9    , installed 1.5.9
                      Adapter    "terminal"      : 0.1.2
                      Adapter    "tesla-motors"  : 0.2.3
                      Adapter    "text2command"  : 1.3.0    , installed 1.3.0
                      Adapter    "tileboard"     : 0.1.1
                      Adapter    "tinker"        : 1.1.0
                      Adapter    "tino"          : 0.1.3
                      Adapter    "tinyrx4"       : 0.1.5
                      Adapter    "tr-064"        : 4.0.7
                      Adapter    "tradfri"       : 2.6.3
                      Adapter    "trashschedule" : 0.0.9    , installed 0.0.9
                      Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                      Adapter    "tuya"          : 3.3.5
                      Adapter    "tvspielfilm"   : 2.0.1
                      Adapter    "unifi"         : 0.5.5
                      Adapter    "unifi-protect" : 0.0.11
                      Adapter    "upnp"          : 1.0.16
                      Adapter    "vaillant"      : 0.0.10
                      Adapter    "valloxmv"      : 1.0.3
                      Adapter    "vcard"         : 0.0.9
                      Adapter    "vedirect"      : 0.1.0
                      Adapter    "velux"         : 0.0.6
                      Adapter    "viessmann"     : 1.2.4
                      Adapter    "viessmannapi"  : 1.3.2
                      Adapter    "virtualpowermeter": 1.2.1
                      Adapter    "vis"           : 1.2.6    , installed 1.2.6
                      Adapter    "vis-bars"      : 0.1.4
                      Adapter    "vis-canvas-gauges": 0.1.5
                      Adapter    "vis-colorpicker": 1.2.0
                      Adapter    "vis-fancyswitch": 1.1.0
                      Adapter    "vis-google-fonts": 0.1.0
                      Adapter    "vis-history"   : 1.0.0
                      Adapter    "vis-hqwidgets" : 1.1.4    , installed 1.1.4
                      Adapter    "vis-inventwo"  : 1.3.8
                      Adapter    "vis-jqui-mfd"  : 1.0.12
                      Adapter    "vis-justgage"  : 1.0.2
                      Adapter    "vis-keyboard"  : 0.0.2
                      Adapter    "vis-lcars"     : 1.0.4
                      Adapter    "vis-map"       : 1.0.4
                      Adapter    "vis-material"  : 0.1.3
                      Adapter    "vis-material-webfont": 0.0.3
                      Adapter    "vis-materialdesign": 0.3.14
                      Adapter    "vis-metro"     : 1.1.2
                      Adapter    "vis-players"   : 0.1.6
                      Adapter    "vis-plumb"     : 1.0.2
                      Adapter    "vis-rgraph"    : 0.0.2
                      Adapter    "vis-timeandweather": 1.1.7
                      Adapter    "vis-weather"   : 2.5.2
                      Adapter    "vodafone-speedtest": 0.0.5
                      Adapter    "volvo"         : 0.0.2
                      Adapter    "vr200"         : 1.0.0
                      Adapter    "vw-connect"    : 0.0.16
                      Adapter    "weatherunderground": 3.2.1
                      Adapter    "web"           : 3.0.9    , installed 3.0.9
                      Adapter    "web-speedy"    : 0.2.0
                      Adapter    "weishaupt-wem" : 0.0.8
                      Adapter    "wiffi-wz"      : 2.2.0
                      Adapter    "wifilight"     : 1.1.0
                      Adapter    "windows-control": 0.1.3
                      Adapter    "wlanthermo-nano": 0.1.1
                      Adapter    "wled"          : 0.5.0
                      Adapter    "wm-bus"        : 0.3.1
                      Adapter    "wolf"          : 1.2.0
                      Adapter    "worx"          : 1.0.2
                      Adapter    "xbox"          : 0.6.5
                      Adapter    "xs1"           : 1.0.2
                      Adapter    "yahka"         : 0.11.0
                      Adapter    "yamaha"        : 0.3.19
                      Adapter    "yeelight-2"    : 1.0.3
                      Adapter    "youtube"       : 0.0.11
                      Adapter    "yr"            : 2.0.3
                      Adapter    "zigbee"        : 1.1.1    , installed 1.1.1
                      Adapter    "zoneminder"    : 0.3.3
                      Adapter    "zont"          : 0.5.4
                      Adapter    "zwave"         : 2.0.1
                      Adapter    "zwave2"        : 1.3.3
                      da ist auch nichts dabei was mein usb blockieren sollte.
                      lg
                        @gifftstaub
                        Deaktivier mal den 'discovery' Adapter. Soweit ich weiß fragt der auch den serialport an.
                          gifftstaub @Thomas Braun last edited by gifftstaub
                          @Thomas-Braun said in Zigbee Adapter Fehler nach Update auf JS-Controller 3.1.5:
                          @gifftstaub
                          nein das liegt nicht am 'discovery' Adapter Serial ist nicht angehackt.
                          lg
                          Edit: Morgen kommt ein neuer USB Stick bericht folgt.
                            Nabend Zusammen,
                            Kurzes Feedback zum Porblem mit dem CC2531 Stick.
                            Alte Stick ist Platt keine Ahnung wie das Passiert ist.
                            Neuer Stick ran und siehe da läuft Sofort mit Adapter ( Zigbee 1.1.1 ) und folgende Komponenten.
                            JS controller: 3.1.5
                            Node : v12.18.0
                            Node.js: v12.18.0
                            NPM: 6.14.4
                            Ich möchte mich bei allem sehr bedanken für die Hilfestellung 👍
                            lg
                              P-A-L-A-D-I-N last edited by
                              Ich kann neuerdings meine Zigbee-Geräte nicht mehr steuern. In den Objekten werden auch falsche Angaben gemacht bez. ein/aus, Temperatur etc.
                              Am System oder Adapter habe ich nichts verändert! Da Neustarts etc. nichts gebracht haben, habe ich dann von Github die neueste Version gezogen - hat aber auch nichts gebracht.
                              Hier das Log, wenn ich versuche, mein Arbeitszimmerlicht zu schalten:
                              zigbee.0	2020-06-17 22:35:45.628	error	(10296) Error on send command to 0x00158d0003cefef4. Error: Error: Command 0x00158d0003cefef4/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"s
                              zigbee.0	2020-06-17 22:35:41.258	error	at rejected (C:\ioBroker\Zuhause\node_modules\zigbee-herdsman\dist\controller\model\endpoint.js:6:65)
                              zigbee.0	2020-06-17 22:35:41.258	error	at Generator.throw (<anonymous>)
                              zigbee.0	2020-06-17 22:35:41.258	error	at Endpoint.<anonymous> (C:\ioBroker\Zuhause\node_modules\zigbee-herdsman\dist\controller\model\endpoint.js:365:23)
                              zigbee.0	2020-06-17 22:35:41.258	error	(10296) Error on send command to 0x00158d0003cefef4. Error: Error: Command 0x00158d0003cefef4/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,
                              fritzdect.0	2020-06-17 22:35:15.828	warn	(12152) DECT200_34:31:C4:D3:D6:E3 is not present, check the device connection, no values are written
                              Wäre toll, wenn mir jemand helfen könnte!
                              JB_Sullivan ldittmar 2 Replies Last reply Reply Quote 0
                              • JB_Sullivan
                                JB_Sullivan @P-A-L-A-D-I-N last edited by
                                @P-A-L-A-D-I-N
                                ggf. ein COM Port Problem? Hatte ich auch nach nodesjs Update auf 12.18 mit rflink.
                                npm rebuild gemacht bzw. npm install serialport --build-from-source?
                                  P-A-L-A-D-I-N @JB_Sullivan last edited by P-A-L-A-D-I-N
                                  @JB_Sullivan sagte in Zigbee Adapter Fehler nach Update auf JS-Controller 3.1.5:
                                  Hat leider nichts gebracht! Ich mache jetzt aber mal sicherheitshalber noch einen Neustart und schaue dann nochmal.
                                  EDIT: Neustart hat auch nichts gebracht. Scheinbar besteht keine Verbindung mehr zu den Zigbee-Geräten, obwohl der Port stimmt. In der Übersicht bei "Netzwerkkarte" ist auch alles auf rot und es sind keinerlei Verbindungen mehr zu den Geräten eingezeichnet.
                                    Das Aus- und Einstecken des USB-Adapters hat kurzzeitig geholfen - die Geräte waren in der Übersicht wieder zu sehen. Allerdings war die Freude nur von sehr, sehr kurzer Dauer. Jetzt ist wieder alles weg...
                                    Hier noch das Log des letzten Schaltversuchs:
                                    zigbee.0	2020-06-19 11:53:55.434	error	(19452) Error on send command to 0x00158d0003cefef4. Error: Error: Command 0x00158d0003cefef4/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"
                                    zigbee.0	2020-06-19 11:53:51.065	error	(19452) Error on send command to 0x00158d0003cefef4. Error: Error: Command 0x00158d0003cefef4/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"s
                                    zigbee.0	2020-06-19 11:53:25.956	error	at rejected (C:\ioBroker\Zuhause\node_modules\zigbee-herdsman\dist\controller\model\endpoint.js:6:65))
                                    zigbee.0	2020-06-19 11:53:25.956	error	at Generator.throw (<anonymous>)
                                    zigbee.0	2020-06-19 11:53:25.956	error	at Endpoint.<anonymous> (C:\ioBroker\Zuhause\node_modules\zigbee-herdsman\dist\controller\model\endpoint.js:255:23)
                                    zigbee.0	2020-06-19 11:53:25.956	error	(19452) Failed to configure 0x000d6f000fabe64e COSensor-EM, attempt 1 (Error: Bind 0x000d6f000fabe64e/1 genPowerCfg from '0x00124b0018e20893/1' failed (Error: AREQ - ZDO - bindRsp after 10000ms)
                                    zigbee.0	2020-06-19 11:53:15.837	info	(19452) Zigbee started
                                    zigbee.0	2020-06-19 11:53:15.837	info	(19452) 0x00158d0003cefef4 (addr 33236): LLKZMK11LM - Xiaomi Aqara wireless relay controller (Router)
                                    zigbee.0	2020-06-19 11:53:15.835	info	(19452) 0x000d6f000fabe64e (addr 36585): HS1CA-E - HEIMAN Smart carbon monoxide sensor (EndDevice)
                                    zigbee.0	2020-06-19 11:53:15.834	info	(19452) 0x00158d000340d5ad (addr 663): JTQJ-BF-01LM/BW - Xiaomi MiJia gas leak detector (Router)
                                    zigbee.0	2020-06-19 11:53:15.833	info	(19452) 0x7cb03eaa0a01e0f8 (addr 58413): AB3257001NJ - OSRAM Smart+ plug (Router)
                                    zigbee.0	2020-06-19 11:53:15.832	info	(19452) 0x7cb03eaa0a01bfef (addr 53682): AB3257001NJ - OSRAM Smart+ plug (Router)
                                    zigbee.0	2020-06-19 11:53:15.831	info	(19452) 0x84182600000f3893 (addr 44117): AB3257001NJ - OSRAM Smart+ plug (Router)
                                    zigbee.0	2020-06-19 11:53:15.830	info	(19452) 0x00158d00036b9140 (addr 15766): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                    zigbee.0	2020-06-19 11:53:15.829	info	(19452) 0x00158d00032300c0 (addr 12784): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                    zigbee.0	2020-06-19 11:53:15.828	info	(19452) 0x00158d000349c4d0 (addr 4916): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                    zigbee.0	2020-06-19 11:53:15.824	info	(19452) Configuring 0x000d6f000fabe64e COSensor-EM
                                    zigbee.0	2020-06-19 11:53:15.818	info	(19452) Currently 9 devices are joined:
                                    zigbee.0	2020-06-19 11:53:15.764	info	(19452) --> transmitPower : normal
                                    zigbee.0	2020-06-19 11:53:15.740	info	(19452) Disable LED
                                    zigbee.0	2020-06-19 11:53:15.689	info	(19452) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190425}}
                                    zigbee.0	2020-06-19 11:53:13.296	info	(19452) Starting Zigbee...
                                    zigbee.0	2020-06-19 11:53:13.237	info	(19452) starting. Version 1.1.1 in C:/ioBroker/Zuhause/node_modules/iobroker.zigbee, node: v12.18.0, js-controller: 3.1.4
                                      Noch ein Nachtrag (wegen der Übersichtlichkeit als getrennter Beitrag):
                                      In der Übersicht des Adapters ("Netzwerkkarte") waren die Geräte zwischenzeitlich, auch ohne Aus- und Einstecken des USB-Sticks, wieder grün und um den Coordinator herum versammelt. Aber: Das Licht läßt sich trotzdem, auch in diesem Zustand, nicht schalten.
                                      Hier noch das Log des Schaltversuchs (im o.g. Zustand mit grünen Verbindungen in der Übersicht):
                                      info.0	2020-06-19 13:14:30.839	info	(11556) Popup news was read...
                                      zigbee.0	2020-06-19 13:14:21.861	error	(19452) Error on send command to 0x00158d0003cefef4. Error: Error: Command 0x00158d0003cefef4/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"
                                      zigbee.0	2020-06-19 13:14:17.316	error	at rejected (C:\ioBroker\Zuhause\node_modules\zigbee-herdsman\dist\controller\model\endpoint.js:6:65)
                                      zigbee.0	2020-06-19 13:14:17.316	error	at Generator.throw (<anonymous>)
                                      zigbee.0	2020-06-19 13:14:17.316	error	at Endpoint.<anonymous> (C:\ioBroker\Zuhause\node_modules\zigbee-herdsman\dist\controller\model\endpoint.js:365:23)
                                      zigbee.0	2020-06-19 13:14:17.316	error	(19452) Error on send command to 0x00158d0003cefef4. Error: Error: Command 0x00158d0003cefef4/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"
                                      info.0	2020-06-19 12:44:30.904	info	(11556) Popup news was read...
                                      Es muß also irgendetwas mit diesem verfluchten JS- und Node-Gelump zu tun haben - wie eigentlich immer, wenn es mal wieder klemmt!
                                      Keine Ahnung, warum die Entwickler des ioBroker nicht einfach mal eine stabile Version bestehen lassen und man da ständig irgendwas herumbasteln muß! Mich als einfachen Nutzer kotzt das alles jedenfalls einfach nur noch tierisch an! Ich möchte keine abgehobenen Schickimickisachen machen und auf Teufel komm raus den allerneusten "Controller XY, Node, NPM, WeißderTeufelwas" da stehen haben, sondern einfach nur ein stabiles, gerne auch "veraltetes", System betreiben, das solide seine Arbeit verrichtet! Es kann ja wohl nicht sein, daß ich alle zwei Wochen spätestens wieder stundenlang dasitze und auf Fehlersuche gehen muß, nur weil wieder irgendein verk... Update (wohlgemerkt auf "default", nicht auf "latest") alles zerschossen hat und meine ganze Beleuchtung oder irgendein anderes Zeug dann nicht mehr funktioniert! 👿
                                      arteck apollon77 2 Replies Last reply Reply Quote 0
                                        arteck Developer Most Active @P-A-L-A-D-I-N last edited by arteck
                                        @P-A-L-A-D-I-N also an der node12 liegts nicht.. allerdings auf Linux
                                        @P-A-L-A-D-I-N sagte in Zigbee Adapter Fehler nach Update auf JS-Controller 3.1.5:
                                        und wo ist das Problem.. hättest einfach alles so bestehen lassen wie es war.. also was regst dich auf ??
                                        wenn dich das System so ankotzt.. es gibt genug käufliche Systeme wo du für Support bezahlst.. also WO IST DAS PROBLEM
                                        ausserdem wen man mit BILLIG WARE, was du vor dir liegen hast laut dem Log
                                        also ein CC2531 zusätzlich mit einer Firmware von April die ehhh kaputt war, da wir ein BUG hatten versuch ein System aufzubauen was stabil laufen soll.. na dann holla im Not..
                                        also besorg dir erstmal ordentliche Hardware es gibt genug alternativen im Marktplatz
                                        dann bringst dein System zum laufen und dann und NUR DANN wenns nicht läuft dann kannst du MICH UND NUR MICH wenns um Zigbee geht anpöbeln.. ansonsten erspare mir dein Palaver...
                                          Thomas Braun Most Active last edited by
                                          An node 14 und js-controller 3.1.6 liegt es auch nicht (wiederum auf Linux):
                                          2020-06-19 15:22:11.887  - info: host.brokerslave "system.adapter.zigbee.0" enabled
                                          2020-06-19 15:22:11.995  - info: host.brokerslave instance system.adapter.zigbee.0 started with pid 19145
                                          2020-06-19 15:22:16.343  - info: zigbee.0 (19145) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.4.0, js-controller: 3.1.6
                                          2020-06-19 15:22:16.439  - info: zigbee.0 (19145) Starting Zigbee...
                                          2020-06-19 15:22:17.021  - info: zigbee.0 (19145) Coordinator firmware version: {"type":"RaspBee","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":53,"maintrel":0,"revisio
                                          n":"0x26350500"}}
                                          2020-06-19 15:22:17.227  - info: zigbee.0 (19145) Unable to disable LED, unsupported function.
                                          2020-06-19 15:22:17.228  - info: zigbee.0 (19145)   --> transmitPower : normal
                                          2020-06-19 15:22:17.231  - info: zigbee.0 (19145) Unable to set transmit power, unsupported function.
                                          2020-06-19 15:22:17.234  - info: zigbee.0 (19145) Currently no devices.
                                          2020-06-19 15:22:17.236  - info: zigbee.0 (19145) Zigbee started
                                            arteck Developer Most Active @Thomas Braun last edited by
                                            @Thomas-Braun das ist der cc2531 in Verbindung mit der Firmware vom April 2019
                                            js controller update zigbee adapter
                                            10
                                            51
                                            4499
