    4. Probleme mit Sonoff Adapter
    UNSOLVED Probleme mit Sonoff Adapter
    • 2
      2hot4you last edited by
      moin,
      habe seit heute Probleme mit dem Sonoff Adapter. Beim hinzufügen neuer Klients werden nicht mehr
      alle Datenpunkte geschrieben. Habe schon den Adapter neu installiert, auch keine Änderung.
      Adapter Version : 2.3.3
      Tasmota Version: 8.3.1
      in der Log werden die Datenpunkte angezeigt, angelegt werden diese aber nicht ??
      Jemand ne Idee ?
      Auszug vom Log
      sonoff.0	2020-06-16 12:50:09.391	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS11 = {"StatusSTS":{"Time":"2020-06-16T11:50:06","Uptime":"0T01:26:14","UptimeSec":5174,"Heap":12,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":50,"Mqt
      sonoff.0	2020-06-16 12:50:09.391	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS10 = {"StatusSNS":{"Time":"2020-06-16T11:50:06","DS18B20":{"Id":"0517B007B3FF","Temperature":19.2},"TempUnit":"C"}}
      sonoff.0	2020-06-16 12:50:09.391	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS7 = {"StatusTIM":{"UTC":"2020-06-16T10:50:06","Local":"2020-06-16T11:50:06","StartDST":"2020-03-29T02:00:00","EndDST":"2020-10-25T03:00:00","Timezo
      sonoff.0	2020-06-16 12:50:09.391	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS6 = {"StatusMQT":{"MqttHost":"192.168.30.94","MqttPort":1883,"MqttClientMask":"Tasmota_Teich","MqttClient":"Tasmota_Teich","MqttUser":"Sonoff","Mqt
      sonoff.0	2020-06-16 12:50:09.391	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS5 = {"StatusNET":{"Hostname":"Tasmota_Teich-1221","IPAddress":"192.168.30.51","Gateway":"192.168.30.1","Subnetmask":"255.255.255.0","DNSServer":"19
      sonoff.0	2020-06-16 12:50:09.365	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS4 = {"StatusMEM":{"ProgramSize":616,"Free":384,"Heap":14,"ProgramFlashSize":1024,"FlashSize":1024,"FlashChipId":"14405E","FlashMode":3,"Features":[
      sonoff.0	2020-06-16 12:50:09.365	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS3 = {"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["xxxxxx",""],"TelePeriod":300,"Resolution":"
      sonoff.0	2020-06-16 12:50:09.365	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS2 = {"StatusFWR":{"Version":"8.3.1(sensors)","BuildDateTime":"2020-05-18T15:41:26","Boot":6,"Core":"2_7_1","SDK":"2.2.2-dev(38a443e)","Hardware":"E
      sonoff.0	2020-06-16 12:50:09.364	debug	(2267) [Tasmota_Teich] Received: Tasmota_Teich/STATUS1 = {"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"sonoffs","OtaUrl":"http://thehackbox.org/tasmota/release/sonoff-DE.bin","Res
      Gruß Michael
      • Glasfaser
        Glasfaser @2hot4you last edited by
        @2hot4you
        hier ... alle Haken gesetzt !?
        • 2
          ja, waren immer an, nichts geändert
          • Glasfaser
            @2hot4you
            hier alles richtig ausgefüllt !?
            bzw. schau mal in der Konsole von deinem Sonoff was er sendet !?
            653ef64b-2eaa-410b-86b4-a0c60ee2436f-image.png c0cf4160-8563-4dd4-9104-6467a5b238fe-image.png 6398a7e3-a080-44fa-857f-60111673a099-image.png
            • 2
              2hot4you last edited by 2hot4you
              Hallo @Glasfaser
              ich habe die Punkte auch so eingestellt. Bisher lief alles ohne Probleme. Wollte jetzt nur ein neues Gerät
              einfügen, da ist es mir aufgefallen. Auch wenn ich die Datenpunkte eines bisher ohne Probleme laufendes
              Gerät lösche und neu erstellen lasse, werden nur die oben gezeigten beiden Datenpunkte erstellt.
              Nachtrag: HAbe die topic und full topic und das Passwort nochmal neu eingegeben, die
              Datenpunkte wurde erstellt, Danke noch mal für den Tipp
                crunchip Forum Testing Most Active @2hot4you last edited by
                @2hot4you hast du das Gerät mal neu gestartet, (hatte ich auch mal, das erst nach Neustart, nach ner weile die DP`s angelegt wurden)
                übrigens @Glasfaser ist in v8.x das topic nicht mehr sonoff, sondern tasmota
                • Glasfaser
                  Glasfaser @crunchip last edited by Glasfaser
                  @crunchip
                  Das war dein Screenshot ... aus einem anderen Beitrag die Tage 🙂 😉 😀
                  Link Text
                    crunchip Forum Testing Most Active @Glasfaser last edited by
                    @Glasfaser ich weiss, kam mir sofort bekannt vor😁
                    deshalb war die Info dazu, weil der screen meiner Dose mit V6.4.1) (passend beim anderen Beitrag)war,
                    hier es sich jedoch um v8.3.1 handelt
                      Kugelkopf @Glasfaser last edited by
                      @Glasfaser @2hot4you Auch gerne mal die Häkchen wegmachen speichern, Adapter neustarten, Häkchen wieder anklicken, neu starten. Hat bei mir geholfen.
                        Buko last edited by Buko
                        Bei mir klappen 1-2 s2x nicht keine ahnung alles lief vorher wunderbar !
                        Update gemacht von 8.2 auf 8.3.1 auch keine besserung häcken nmeu gesetzt und und und
                          Buko last edited by
                          Fritzbox löst iobroker server name nicht richtig auf muste ie IP angeben
                          sonoff tasmota
                          1025
