Adapter: broadlink2
ja, funktioniert mit der app und pingen kann ich es natürlich auch.
das ist doch ein auth- error oder?
sendPacket error: could not send after 3 trials!: SendPacketErr {command: 233,cmdHex: '0xe9',payload: <Buffer >,err: 'Authentication failed'}p.s.: 2.0.9 version installiert vom GIT
so, alles neu gemacht. adapter/instance/objects
selbes ergebnis:
broadlink2.0 2020-06-17 19:15:28.539 info (24020) found macs: broadlink2.0 2020-06-17 19:15:28.539 info (24020) broadlink2.0 started and found 0 devices named broadlink2.0 2020-06-17 19:15:28.538 info (24020) Poll every 30 secods. broadlink2.0 2020-06-17 19:15:19.457 info (24020) sendPacket error: could not send after 3 trials!: SendPacketErr {command: 233,cmdHex: '0xe9',payload: <Buffer >,err: 'Authentication failed'} broadlink2.0 2020-06-17 19:15:18.995 info (24020) sendPacket error: could not send after 3 trials!: SendPacketErr {command: 233,cmdHex: '0xe9',payload: <Buffer >,err: 'Authentication failed'} broadlink2.0 2020-06-17 19:15:18.497 info (24020) sendPacket error: could not send after 3 trials!: SendPacketErr {command: 233,cmdHex: '0xe9',payload: <Buffer >,err: 'Authentication failed'} broadlink2.0 2020-06-17 19:15:18.234 info (24020) UDP socket listening on 0.0.0.0:15001 broadlink2.0 2020-06-17 19:15:18.231 info (24020) Discover Broadlink devices for 10sec on broadlink2.0 broadlink2.0 2020-06-17 19:15:18.230 info (24020) macObjects: [] broadlink2.0 2020-06-17 19:15:18.228 info (24020) Devices to rename: broadlink2.0 2020-06-17 19:15:18.228 info (24020) Devices to add: [] broadlink2.0 2020-06-17 19:15:18.227 info (24020) Scanning additional IP's: 192.168.0.140 broadlink2.0 2020-06-17 19:15:18.226 info (24020) broadlink2 initialization started... broadlink2.0 2020-06-17 19:15:18.073 info (24020) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v12.16.2, js-controller: 3.1.5 -
@muckel ja, ok. Heute installiert, es gab gestern spät ein update, da sind viele Fehler weg..
Hallo muckel, mit welcher app hast du den mini ins netz geholt? wenn du das mit einer neueren app (die auch Alexa unterstützt) machst dann geht er nicht in broadlink2 da der mini dann in der 'cloud-mode' arbeitet und und er meine Authentifizierungsanfragen nicht beantwortet. Du musst eine alte broadlink-app ( ich verwende
e smart homeodere-control) verwenden und dabei sicherstellen dass dein Handy dabei im2.4GHz-Wlan ist wo auch der RM hin soll. -
@ilovegym
anscheinend nicht alle fehler.
du weißt auch nicht mehr weiter? -
verstehe, das muss ich ausprobieren.
Aus irgend einem - mir nicht bekannten - Grund hat dein Gerät intern keinen Speicher mehr :
The device storage is full
Vielleicht hast beim Anlernen ein Problem dass die Taste zu lang sendet oder die Kombination zu lang ist und damit nicht in den Speicher des Gerätes passt. -
Das Fehlen von false/true bedeutet nur dass du wahrscheinlich die taste noch nie gedrückt hast, aber da der state ein Button ist ist es wurst was du sendest, er reagiert bei jedem Schalten/umschalten.
wegen dem 'L': Das werde ich in der neuen 3.0-Version ändern, dort wird dann für alle RM's in einem zentralen Folder mit benennbaren Unterfoldern und Namen gelernt und alle RM's die der Adapter erkennt können dann auf diese einzige, auch in der Konfig editierbare Basis Zugreifen (und exportieren/importieren).
@ilovegym sagte in Adapter: broadlink2:
Würde vorschlagen, den Adapter so ins latest zu schieben.
Weitere Änderungen an Datenpunkten oder Config dann für ne neue Rev... oder?genau das hab ich vor, muss noch readme etwas anpassen und einige Texte und debug/infos ändern aber dann wird er als V2.1 bis zum Wochenende auf latest gehen bevor ich mit 2.9.9 auf einem neuen branch die beta für 3.0 starten werde (in 2-3 Wochen).
@frankjoke sagte in Adapter: broadlink2:
e smart homeodere-control) verwenden und dabei sicherstellen dass dein Handy dabei im2.4GHz-Wlan ist wo auch der RM hin soll.Alles erledigt und funktioniert.
Danke für den Tipp mit der App. -
Ok, habe readme und einige andere 'Kleinigkeiten' upgedatet und den Adapter jetzt als 2.1.0 auf git.
Habe ihn von dort auf 4 meiner Testsysteme installiert (Windows, Linux und js-controller 2+ und 3+ sowie nodejs 10+ und 12+) installiert und er funktioniert überall.Wenn ich kein negatives feedback von euch krieg dann werd ich morgen ein npm-release von 2.1.0 machen und damit sollte er dann bald als solcher auch auf latest erscheinen.
LG!
Vielen Dank für die Änderungen, besonders das finden von Geräten außerhalb des eigenen Netzwerkes.
Allerdings funktioniert dies nicht direkt mit docker Containern, da hier kein bi-direktionales routing stattfindet: Ein docker container kann standardmäßig ohne Probleme in Zugriff auf das host-lan nehmen. Umgekehrt geht dies allerdings nicht.Das Problem liegt nun darin, dass "Broadlink.discover" die IP des jeweiligen hots in das "discover-paket" schreibt. In einem docker container wäre dies die interne docker ip. Das paket wird nun erfolgreich das broadlink Gerät erreichen, diese allerdings wird nun versuchen, eine Antwort an die interne IP des docker container zu senden -> Dies schlägt fehl.
Ich habe einen Kommentar mit ausführlichen Beispielen auf github hinzugefügt: https://github.com/frankjoke/ioBroker.broadlink2/issues/79#issuecomment-645655995
@frankjoke Sehr cool! Ich bin gespannt
Bei mir kommt folgende Fehlermeldung:
Failed to authenticate device RM4:undefined, 24:df:a7:34:ab:f2, 192.168.1.127 with err TypeError: Cannot read property 'command' of null
Broadlink 4 mini wird nicht erkannt, hat jemand eine Idee? -
Wäre es eventuell sinnvoller für die neue Version einen eigenen Thread zu eröffnen?
Hier wird es langsam zu voll. -
ich habe Probleme beim Einrichten eines States.
Ich habe im Objektebaum folgende angelernten Codes:
Den State "Klima_Schlafzimmer" (zum Ein- und Ausschalten der Klimaanlage) habe ich wie folgt angelegt:
Wenn ich den jedoch schalten will, kommt folgendes im Log:
Hat da jemand eine Idee zu?
Kannst mal schauen, sehe keinen RM: unter broadlink.0 und dort sollte dann
Statesdrunter sein.Wenn du direkt irgendwo states anlegst weiß er nicht mit welchen RM er das senden soll!
@Muchul sagte in Adapter: broadlink2:
Hier wird es langsam zu voll.Mach ich bei V3.0 dann!
@Flugschüler sagte in Adapter: broadlink2:
Broadlink 4 mini wird nicht erkannt, hat jemand eine Idee?Hast du ein paar Einträge zurück gelesen mit welcher app du den RM4 inst netz geholt hast? die nneuesten Apps funktionieren nicht mit broadlink2!
