    3. Entwicklung
    4. [Major Update] UniFi Adapter v0.5.0
      mikiline @liv-in-sky last edited by
      @liv-in-sky sagte in [Major Update] UniFi Adapter v0.5.0:
      @mikiline
      mal ein beispiel - ohne alias-anlegerei :
      als einzelwert- mit string-widget:
      oder als z.b. tabelle
      Vielen Dank!
      Ich wollte die Bindings nutzen um Farben zu ändern (grün=anwesend, rot=abwesend) und das geht bei mir leider nicht.
      "b:unifi.unifi.0.default.clients.84:ad:8d:df:48:90.is_online;b="true" ? "green" : "red"}"
      liv-in-sky D 2 Replies Last reply Reply Quote 0
        liv-in-sky @mikiline last edited by
        @mikiline ok - sorry - da hast du recht - das ist ein problem - dann doch alias
          darkiop Most Active @mikiline last edited by darkiop
          @mikiline Oder so:
          [{"tpl":"tplValueBool","data":{"oid":"nothing_selected","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_false":"<span style=\"color: red\">false</span>","html_true":"<span style=\"color: green\">true</span>"},"style":{"left":"416px","top":"592px"},"widgetSet":"basic"}]
          @mikiline sagte in [Major Update] UniFi Adapter v0.5.0:
          Die Alias Funktion Kenne ich nicht. Wo kann ich hier die Namen ändern?
          @braindead meinte die Aliase im Unifi-Controller - die sind Variabel - die MAC Adresse statisch.
          In meinem Post oben sind die Links um dich zum Thema Alias im ioBroker einlesen zu können - dann gehts auch mit Bindings in VIS.
          braindead 1 Reply Last reply Reply Quote 0
          • braindead
            braindead Developer @darkiop last edited by
            @darkiop said in [Major Update] UniFi Adapter v0.5.0:
            Der erste Satz bezog sich auf die Aliase im UniFi Controller und der zweite Satz auf den Alias bzw. LinkedDevices Adapter. 😉
              falls interesse an einer html tabelle für die clients existiert - https://forum.iobroker.net/topic/34491/htmltabelle-unificlients-newadapter
              Chaot 1 Reply Last reply Reply Quote 1
              • Chaot
                Chaot @liv-in-sky last edited by
                @liv-in-sky Das ganze Haus auf Sonoff und Wemos 👏 👍
                Ich gehe jetzt ne Runde 😥
                  liv-in-sky @Chaot last edited by liv-in-sky
                  @Chaot oh ja - weiß gar nicht mehr wo die alle verbaut sind - die tabelle erinnert mich wenigstens daran, dass sie tatsächlich irgendwo im haus sind 🙂
                    simonlaessig last edited by
                    Hallo, bei mir funktioniert die auswertung der Clients nicht richtig. Geräte die im Wlan sind werden einwandfrei erkannt und aufgelistet, aber sobald das Gerät das Wlan verlässt bleiben alle Werte in den Objekten eingefroren, im Unifi Controler sind die Geräte nicht mehr in den aktiven clients drin. Was kann ich tun? Habe einen neuen UDM Pro.
                    • braindead
                      braindead Developer @simonlaessig last edited by
                      @simonlaessig said in [Major Update] UniFi Adapter v0.5.0:
                      Bitte den Hinweis zu is_online auf der Konfigurationsseite befolgen.
                        simonlaessig @braindead last edited by
                        @braindead Ja habe das aktiviert, aber es bleibt auch immer auf True, obwohl last seen eigentlich richtig ist. Deshalb wollte ich die anwesenheitsauswertung über "satisfaction" oder "signal" machen. Aber die werte bleiben eben auf dem letzten wert eingefroren.
                        • braindead
                          braindead Developer @simonlaessig last edited by braindead
                          Wenn Du es richtig hättest, dann würde is_online auf false gehen, sobald der Client offline ist. Bitte Screenshot von Deiner Konfiguration der Clients posten. Zusätzlich einen Screenshot von den Objekten (inkl. Werten) eine Clients posten. Welche Adapter Version hast Du installiert?
                          Die UniFi API gibt nur Clients zurück, die online sind. Das ist der Grund, warum is_online = false umständlich berechnet werden muss. Der Adapter wiederum aktualisiert absichtlich nur DPs von Clients, die von der API zurückkommen.
                          Das was Du vorhast, wird mit dem Adapter also nicht funktionieren. Sobald Dein is_online Problem gelöst ist, ist das aber auch nicht mehr nötig. 😉
                            Camuri last edited by
                            Hätte bitte jemand mal ein funktionierendes Skript für die Anwesenheit, am besten über Blockly :D, java kenn ich mich nucht so gut aus und habe 5 Geräte für die Anwesenheit.
                            crunchip Sunshinemaker dslraser 3 Replies Last reply Reply Quote -1
                              crunchip Forum Testing Most Active @Camuri last edited by
                              @Camuri https://forum.iobroker.net/post/436788
                              • Sunshinemaker
                                Sunshinemaker @Camuri last edited by
                                @Camuri Wozu? Der Adapter sagt dir doch ob jemand anwesend ist oder nicht. Und das Script macht genau das gleich und genau die selbe Berechnung die der Adapter.
                                C 1 Reply Last reply Reply Quote 1
                                • dslraser
                                  dslraser Forum Testing Most Active @Camuri last edited by
                                  @Camuri
                                  oder hier (das sind 2 Benutzer). Kannst Du ja nach dem gleichen Prinzip erweitern. Entweder Du stellst die Verzögerung im Blockly auf 0 und regelst das Offset im Adapter, oder im Blockly eine Verzögerung einstellen, aber dafür im Adapter das Offset auf 0.
                                  Vorteil der Verzögerung im Blockly wäre, das Du unterschiedliche Verzögerungen je Benutzer einstellen könntest.
                                  https://forum.iobroker.net/post/438565
                                    @braindead
                                    okay, jetzt scheint es zu funktionieren, die Offset Zeit habe ich etwas verkürzt. Aber mir ist das alles etwas zu langsam, kann man den Adapter noch irgendwie beschleunigen? Habe die Update Zeit schon auf 10s gestellt, aber die Objekte aktualisieren sich dennoch erst so nach 30s. (Hätte genug Ressourcen, läuft auf einem sehr schnellen PC)
                                    Oder ist iobroker einfach nicht so flott?
                                    Chaot braindead Scrounger 3 Replies Last reply Reply Quote 0
                                    • Chaot
                                      Chaot @simonlaessig last edited by
                                      @simonlaessig Wenn der AP alle 10s dein Telefon anpingt ob er noch online ist wird dein Akku wohl blitzschnell absaufen.
                                      Warum reichen dir 30 Sekunden nicht?
                                      • braindead
                                        Sorry, aber dazu fällt mir nichts mehr ein.
                                        • Scrounger
                                          Scrounger Developer @simonlaessig last edited by Scrounger
                                          @simonlaessig sagte in [Major Update] UniFi Adapter v0.5.0:
                                          @braindead
                                          Ursache hierfür ist nicht der Adapter sondern der Unifi Controller selbst, der benötigt ja auch schon einige sekunden bis er mit bekommt das ein client on bzw. offline gegangen ist.
                                          Und der UDM Pro Controller ist hier noch langsamer bei der erkennung als ein controller der z.b. im linux lxc läuft.
                                            simonlaessig @Chaot last edited by
                                            @Chaot
                                            Hehe, ja versteht keiner. Ich lass mit der Anwesenheit durch das Handy das Garagentor auffahren wenn ich mit dem Motorrad unterwegs bin, Ist doof wenn ich da eine Minute warte bis das Tor endlich auf geht, dann kann ichs auch händisch auf machen 😊 😊
                                            unifi
                                            54
                                            510
                                            114616
