    4. Test Adapter deConz v2.0.x
    • Jey Cee
      Jey Cee Developer @GiuseppeS last edited by
      @GiuseppeS nein das geht nicht. Du würdest die Alte Version einfach Überschreiben. Man müsste mal prüfen ob die Alte Struktur innerhalb der neuen Version noch voll Funktionsfähig ist.
      Theoretisch sollte das gehen.
        dickimo last edited by dickimo
        Hallo allerseits.
        Bin neu hier. Nutze den Adapter schon längere Zeit. Läuft super.
        Die 2.0 mal installiert, jedoch bleibt die Instanz nicht grün.
        2020-06-11 10:00:53.672 - info: host.raspberrypi "system.adapter.deconz.0" enabled
        2020-06-11 10:00:53.712 - info: host.raspberrypi instance system.adapter.deconz.0 started with pid 3270
        2020-06-11 10:00:57.883 - info: deconz.0 (3270) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.21.0, js-controller: 3.1.4
        2020-06-11 10:00:58.120 - info: deconz.0 (3270) deConz Version: 2.5.77; API version: 1.16.0
        2020-06-11 10:00:59.155 - info: deconz.0 (3270) Code 404: Ressource not found get devices: []
        2020-06-11 10:01:01.919 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2020-06-11 10:01:01.921 - error: deconz.0 (3270) unhandled promise rejection: ids.push is not a function
        2020-06-11 10:01:01.936 - error: deconz.0 (3270) TypeError: ids.push is not a function
        at Request.request [as _callback] (/opt/iobroker/node_modules/iobroker.deconz/main.js:1438:60)
        at process._tickCallback (internal/process/next_tick.js:68:7)
        2020-06-11 10:01:01.940 - info: deconz.0 (3270) cleaned everything up...
        2020-06-11 10:01:02.075 - info: deconz.0 (3270) terminating
        2020-06-11 10:01:02.078 - info: deconz.0 (3270) Terminated (NO_ERROR): Without reason
        2020-06-11 10:01:02.637 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        2020-06-11 10:01:02.640 - error: host.raspberrypi Caught by controller[1]: TypeError: ids.push is not a function
        2020-06-11 10:01:02.641 - error: host.raspberrypi Caught by controller[1]: at Request.request [as _callback] (/opt/iobroker/node_modules/iobroker.deconz/main.js:1438:60)
        2020-06-11 10:01:02.641 - error: host.raspberrypi Caught by controller[1]: at process._tickCallback (internal/process/next_tick.js:68:7)
        2020-06-11 10:01:02.642 - info: host.raspberrypi instance system.adapter.deconz.0 terminated with code 0 (NO_ERROR)
        2020-06-11 10:01:02.643 - info: host.raspberrypi Restart adapter system.adapter.deconz.0 because enabled
        2020-06-11 10:01:06.689 - info: host.raspberrypi "system.adapter.deconz.0" disabled
        • Jey Cee
          @GiuseppeS hab es getest die Alten Objekte werden nicht Aktualisiert. Steuerung geht aber.
          @dickimo kannst du mir ein Log machen bei dem die Instantz mit dem Log level debug läuft?
            dickimo @Jey Cee last edited by
            @Jey-Cee
            Habe gerade nochmal die 2.0 installiert. Geräte werden alle gefunden und bei Neustart des Adapters auch der Schaltzustand in den Objekten aktuallisiert.
            2020-06-12 09:03:39.138 - info: host.raspberrypi "system.adapter.deconz.0" enabled
            2020-06-12 09:03:39.216 - info: host.raspberrypi instance system.adapter.deconz.0 started with pid 32442
            2020-06-12 09:03:41.786 - debug: deconz.0 (32442) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2020-06-12 09:03:41.867 - debug: deconz.0 (32442) Objects client ready ... initialize now
            2020-06-12 09:03:41.874 - debug: deconz.0 (32442) Objects create System PubSub Client
            2020-06-12 09:03:41.876 - debug: deconz.0 (32442) Objects create User PubSub Client
            2020-06-12 09:03:41.879 - debug: deconz.0 (32442) Objects client initialize lua scripts
            2020-06-12 09:03:41.908 - debug: deconz.0 (32442) Objects connected to redis: 127.0.0.1:9001
            2020-06-12 09:03:41.923 - debug: deconz.0 (32442) objectDB connected
            2020-06-12 09:03:41.930 - debug: deconz.0 (32442) Redis States: Use Redis connection: 127.0.0.1:9000
            2020-06-12 09:03:41.966 - debug: deconz.0 (32442) States create User PubSub Client
            2020-06-12 09:03:41.971 - debug: deconz.0 (32442) States create System PubSub Client
            2020-06-12 09:03:41.994 - debug: deconz.0 (32442) States connected to redis: 127.0.0.1:9000
            2020-06-12 09:03:41.996 - debug: deconz.0 (32442) statesDB connected
            2020-06-12 09:03:42.868 - debug: deconz.0 (32442) Plugin sentry Initialize Plugin (enabled=true)
            2020-06-12 09:03:43.301 - info: deconz.0 (32442) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.deconz, node: v12.18.0, js-controller: 3.1.4
            2020-06-12 09:03:43.505 - debug: deconz.0 (32442) Code 200: Request succeded get config: {"UTC":"2020-06-12T08:03:43","apiversion":"1.16.0","backup":{"errorcode":0,"status":"idle"},"bridgeid":"00212EFFFF04D5AD","datastoreversion":"60","devicename":"ConBee II","dhcp":true,"factorynew":false,"fwversion":"0x264a0700","gateway":"192.168.178.1","internetservices":{"remoteaccess":"disconnected"},"ipaddress":"192.168.178.50","linkbutton":false,"localtime":"2020-06-12T09:03:43","mac":"b8:27:eb:c7:1f:e5","modelid":"deCONZ","name":"PhosconGW","netmask":"255.255.255.0","networkopenduration":600,"panid":9047,"portalconnection":"disconnected","portalservices":false,"portalstate":{"communication":"disconnected","incoming":false,"outgoing":false,"signedon":false},"proxyaddress":"none","proxyport":0,"replacesbridgeid":null,"rfconnected":true,"starterkitid":"","swupdate":{"checkforupdate":false,"devicetypes":{"bridge":false,"lights":[],"sensors":[]},"notify":false,"text":"","updatestate":0,"url":""},"swupdate2":{"autoinstall":{"on":false,"updatetime":""},"bridge":{"lastinstall":"2020-05-24T19:34:25","state":"allreadytoinstall"},"checkforupdate":false,"install":false,"lastchange":"","lastinstall":"","state":"allreadytoinstall"},"swversion":"2.5.77","timeformat":"24h","timezone":"Etc/GMT-1","uuid":"a490a7c6-2b27-431c-837a-61f149f550e3","websocketnotifyall":true,"websocketport":443,"whitelist":{"021B2209E5":{"create date":"2020-06-05T15:50:41","last use date":"2020-06-05T18:53:19","name":"Phoscon#B1396x686"},"0329328FCF":{"create date":"2020-04-04T09:46:39","last use date":"2020-04-05T18:38:33","name":"Phoscon#B1396x641"},"03E087A45B":{"create date":"2020-06-11T08:05:28","last use date":"2020-06-11T11:49:29","name":"ioBroker"},"048736ACF4":{"create date":"2019-12-01T07:13:06","last use date":"2019-12-08T18:29:26","name":"Phoscon#B360x258"},"04B49EEF39":{"create date":"2019-12-16T22:35:15","last use date":"2019-12-17T02:09:59","name":"Phoscon#B602x475"},"04FEAB6313":{"create date":"2020-05-17T10:27:37","last use date":"2020-05-17T10:29:46","name":"ioBroker"},"0B9402E57E":{"create date":"2020-01-19T15:07:33","last use date":"2020-01-19T19:16:11","name":"Phoscon#B800x808"},"0D44743FA3":{"create date":"2020-02-06T19:52:07","last use date":"2020-02-06T22:48:15","name":"Phoscon#B800x808"},"0D89159C02":{"create date":"2020-01-08T17:34:23","last use date":"2020-01-08T19:59:25","name":"Phoscon#B1707x838"},"0F8AC4A354":{"create date":"2020-01-26T08:01:05","last use date":"2020-01-26T08:26:08","name":"Phoscon#B800x808"},"14ABDF7C7F":{"create date":"2019-12-07T13:16:21","last use date":"2019-12-07T18:29:24","name":"Phoscon#B1707x838"},"1636272F04":{"create date":"2019-12-15T10:47:31","last use date":"2019-12-21T12:26:23","name":"Phoscon#B800x760"},"1674D38A4A":{"create date":"2020-01-18T11:39:13","last use date":"2020-01-18T21:42:18","name":"Phoscon#B800x808"},"182F450821":{"create date":"2020-01-22T15:48:23","last use date":"2020-01-23T06:17:17","name":"Phoscon#B800x808"},"18FA0EE462":{"create date":"2020-05-16T18:26:10","last use date":"2020-06-02T23:32:54","name":"Phoscon#B360x258"},"19854D404B":{"create date":"2019-12-08T11:07:08","last use date":"2019-12-08T15:03:33","name":"Phoscon#B1707x838"},"1A088C4E2B":{"create date":"2020-05-17T08:48:53","last use date":"2020-05-17T08:49:15","name":"ioBroker"},"21236DC89F":{"create date":"2019-11-05T18:30:56","last use date":"2019-11-05T23:24:01","name":"Phoscon#B1692x828"},"215168F337":{"create date":"2020-05-03T09:11:31","last use date":"2020-05-03T19:37:44","name":"Phoscon#B1396x686"},"2390B97731":{"create date":"2020-01-11T20:20:49","last use date":"2020-01-11T20:56:45","name":"Phoscon#B2048x1005"},"24CEA4D520":{"create date":"2019-12-11T22:05:53","last use date":"2019-12-16T06:11:20","name":"Phoscon#B360x258"},"271A50C835":{"create date":"2019-12-28T00:55:41","last use date":"2019-12-28T00:56:34","name":"192.168.178.50#null"},"27C9F7D104":{"create date":"2020-01-12T09:42:31","last use date":"2020-01-12T22:54:49","name":"Phoscon#B2008x962"},"2877717567":{"create date":"2019-12-08T20:58:34","last use date":"2019-12-08T21:01:10","name":"Phoscon#B360x258"},"2B0EB770D3":{"create date":"2019-12-08T16:21:02","last use date":"2019-12-08T16:25:59","name":"Hue 3#Amazon KFGIWI"},"2C8EF58737":{"create date":"2019-12-29T19:59:40","last use date":"2019-12-29T20:41:12","name":"Phoscon#B800x808"},"2ECB8B5EC1":{"create date":"2020-03-16T10:49:47","last use date":"2020-03-17T09:50:57","name":"Phoscon#B360x258"},"322C8BEC86":{"create date":"2019-12-08T13:00:25","last use date":"2019-12-28T13:07:35","name":"all 4 hue#SM-N9005"},"32E7E16CE7":{"create date":"2020-02-07T01:03:14","last use date":"2020-02-07T01:03:27","name":"Phoscon#B1280x328"},"338648192C":{"create date":"2020-05-13T16:10:56","last use date":"2020-05-13T16:39:52","name":"Phoscon#B1396x686"},"33D999C417":{"create date":"2019-10-21T05:40:46","last use date":"2019-11-06T06:54:26","name":"Phoscon#B360x258"},"3429190D04":{"create date":"2019-12-15T14:08:34","last use date":"2020-01-18T10:25:43","name":"ioBroker"},"3610FFFA6B":{"create date":"2020-01-04T19:20:30","last use date":"2020-01-08T21:38:55","name":"Phoscon#B800x808"},"37928F012F":{"create date":"2019-11-11T21:11:00","last use date":"2019-11-11T21:11:01","name":"Phoscon#B1707x838"},"39C3746418":{"create date":"2020-03-30T13:10:01","last use date":"2020-04-01T20:20:03","name":"Phoscon#B360x258"},"3D1A3F1F6F":{"create date":"2020-03-18T14:33:31","last use date":"2020-03-29T10:46:57","name":"Phoscon#B360x258"},"3F6DFEDF08":{"create date":"2020-06-07T22:48:35","last use date":"2020-06-12T08:03:33","name":"Phoscon#B1280x280"},"3F904DB7C2":{"create date":"2019-12-08T23:20:01","last use date":"2019-12-09T00:00:08","name":"Phoscon#B1707x838"},"3FA4028CCC":{"create date":"2020-05-17T09:37:40","last use date":"2020-05-17T09:37:45","name":"Phoscon#B1396x686"},"41784F32DC":{"create date":"2020-04-03T18:56:01","last use date":"2020-04-03T19:21:08","name":"Phoscon#B360x258"},"42A98C6DDC":{"create date":"2020-01-18T10:20:03","last use date":"2020-01-18T10:46:47","name":"Phoscon#B800x808"},"43B948DB73":{"create date":"2019-10-21T17:21:08","last use date":"2019-10-21T18:09:49","name":"Phoscon#B1707x838"},"43BB8BA61F":{"create date":"2019-10-20T15:14:20","last use date":"2019-10-20T20:20:10","name":"Phoscon#B1920x943"},"46B9EE1CE0":{"create date":"2020-01-26T14:48:17","last use date":"2020-01-26T15:05:11","name":"Phoscon#B800x808"},"4781445B0C":{"create date":"2019-12-22T04:33:55","last use date":"2020-06-06T21:21:20","name":"hueDynamic1#Android9.0.184467"},"4AA1DFAC96":{"create date":"2020-01-07T01:09:10","last use date":"2020-01-26T11:17:16","name":"Phoscon#B360x258"},"4AE358E26E":{"create date":"2020-06-05T17:55:41","last use date":"2020-06-05T17:59:19","name":"Phoscon#B800x1112"},"4B7EE27383":{"create date":"2019-10-20T21:42:21","last use date":"2020-01-18T09:44:47","name":"Echo"},"4C2FFDFB98":{"create date":"2020-01-18T10:20:53","last use date":"2020-06-12T08:02:56","name":"Echo"},"506C063E3B":{"create date":"2019-11-27T20:34:41","last use date":"2019-12-01T07:12:25","name":"Phoscon#B360x258"},"5149B6030D":{"create date":"2020-01-26T23:08:02","last use date":"2020-01-29T00:28:40","name":"Phoscon#B800x808"},"5B5329E958":{"create date":"2020-06-06T20:04:07","last use date":"2020-06-06T20:12:56","name":"Hue Essentials#SM-N9005"},"5EC39E70F2":{"create date":"2019-12-29T19:30:06","last use date":"2019-12-29T23:52:47","name":"Phoscon#B1707x838"},"64FE0F7D70":{"create date":"2019-11-10T14:48:00","last use date":"2019-11-10T21:37:17","name":"Phoscon#B1707x838"},"65802F8091":{"create date":"2020-06-05T19:43:44","last use date":"2020-06-06T21:17:31","name":"Phoscon#B1280x280"},"69848FBF73":{"create date":"2019-11-30T01:52:12","last use date":"2019-12-19T21:38:22","name":"all 4 hue#KFMAWI"},"69A6C67A87":{"create date":"2019-12-28T01:08:01","last use date":"2019-12-28T01:08:01","name":"192.168.178.38#null"},"6A688C0296":{"create date":"2020-06-11T12:00:23","last use date":"2020-06-11T12:00:23","name":"ioBroker"},"6C15D7C99E":{"create date":"2019-12-31T00:55:37","last use date":"2019-12-31T00:56:18","name":"Phoscon#B602x475"},"6C676F5422":{"create date":"2020-05-17T14:15:14","last use date":"2020-05-17T20:22:36","name":"Phoscon#B1396x641"},"6F7AAD9770":{"create date":"2019-12-28T00:43:39","last use date":"2019-12-28T00:44:34","name":"all 4 hue#KFMAWI"},"6FAB4DA903":{"create date":"2020-01-23T06:23:07","last use date":"2020-01-23T19:14:48","name":"Phoscon#B800x808"},"74DE1A0CBB":{"create date":"2019-12-27T15:11:52","last use date":"2019-12-27T19:09:08","name":"Phoscon#B1707x838"},"764F03D8A6":{"create date":"2019-12-15T08:47:59","last use date":"2019-12-15T19:49:09","name":"Phoscon#B1707x838"},"76561720A0":{"create date":"2019-12-27T19:32:43","last use date":"2019-12-29T01:07:20","name":"Phoscon#B1707x838"},"76B4584924":{"create date":"2019-11-04T17:05:01","last use date":"2019-11-30T21:53:11","name":"Phoscon#B601x456"},"785BABF8BB":{"create date":"2019-10-27T14:37:54","last use date":"2019-12-08T14:24:42","name":"Hue Essentials#SM-N9005"},"7886A45611":{"create date":"2020-03-08T08:46:57","last use date":"2020-03-15T12:09:04","name":"Phoscon#B360x258"},"79BEF4AA6A":{"create date":"2020-06-10T22:26:01","last use date":"2020-06-10T22:26:01","name":"ioBroker"},"7A34D3292F":{"create date":"2020-03-25T09:03:41","last use date":"2020-03-25T09:28:18","name":"Phoscon#B1396x686"},"7BC4D10E79":{"create date":"2020-03-12T05:34:43","last use date":"2020-05-16T19:23:48","name":"Phoscon#B601x456"},"7D491F122E":{"create date":"2019-12-30T01:28:01","last use date":"2020-05-17T06:49:46","name":"Hue Essentials#SM-N9005"},"7FE4ED9558":{"create date":"2019-12-04T20:16:57","last use date":"2019-12-07T05:19:06","name":"Phoscon#B602x475"},"814A05288A":{"create date":"2020-01-10T15:25:03","last use date":"2020-01-11T12:22:05","name":"Phoscon#B800x1112"},"83A4D539F5":{"create date":"2019-11-10T21:37:56","last use date":"2019-11-10T22:54:36","name":"Phoscon#B1707x838"},"858B99B5C1":{"create date":"2020-01-14T18:22:01","last use date":"2020-03-26T20:39:48","name":"Phoscon#B602x475"},"85BD45E402":{"create date":"2019-12-15T13:18:22","last use date":"2019-12-15T13:18:22","name":"192.168.178.38#null"},"86BC1A1073":{"create date":"2019-12-22T19:31:11","last use date":"2019-12-23T19:05:54","name":"Phoscon#B800x808"},"89BA064429":{"create date":"2019-12-22T04:52:06","last use date":"2019-12-22T04:54:57","name":"Phoscon#B800x808"},"8B1E081C71":{"create date":"2020-01-09T17:40:00","last use date":"2020-03-19T08:35:11","name":"Phoscon#B1920x943"},"8C7E877873":{"create date":"2019-10-20T20:20:14","last use date":"2019-10-20T20:20:17","name":"Phoscon#B360x258"},"8F284393AD":{"create date":"2019-11-30T07:59:25","last use date":"2019-12-10T20:54:04","name":"Phoscon#B800x760"},"8FE2467DF1":{"create date":"2020-05-17T09:38:23","last use date":"2020-05-17T12:32:41","name":"Phoscon#B1396x686"},"9174FA9204":{"create date":"2020-02-01T10:24:59","last use date":"2020-02-01T10:46:04","name":"Phoscon#B800x808"},"9201A0AF82":{"create date":"2020-01-24T22:06:51","last use date":"2020-01-26T01:27:19","name":"Phoscon#B800x808"},"92A8402F0A":{"create date":"2019-12-29T11:14:17","last use date":"2019-12-29T18:51:21","name":"Phoscon#B1707x838"},"971660D323":{"create date":"2020-06-07T14:58:12","last use date":"2020-06-11T16:23:44","name":"Phoscon#B360x306"},"97A6A3E8FA":{"create date":"2020-01-18T14:17:48","last use date":"2020-01-18T20:34:58","name":"ioBroker"},"9FA85D8A24":{"create date":"2020-06-06T21:22:08","last use date":"2020-06-07T11:25:33","name":"Phoscon#B1280x280"},"A0205B0385":{"create date":"2020-01-08T23:01:33","last use date":"2020-01-10T05:48:48","name":"Phoscon#B800x808"},"A063A3E252":{"create date":"2019-12-27T18:50:21","last use date":"2019-12-28T00:54:09","name":"192.168.178.50#null"},"A0911F6631":{"create date":"2020-02-01T14:45:42","last use date":"2020-02-06T06:42:43","name":"Phoscon#B800x808"},"A0F3E63310":{"create date":"2019-12-31T20:22:59","last use date":"2020-01-01T22:04:09","name":"Phoscon#B800x808"},"A223F8FAA2":{"create date":"2019-11-09T19:03:07","last use date":"2019-11-09T20:13:16","name":"Phoscon#B360x258"},"A2B3F03AEB":{"create date":"2019-10-21T15:33:19","last use date":"2019-10-21T16:16:00","name":"Phoscon#B1707x838"},"A342ED977A":{"create date":"2019-11-10T16:50:58","last use date":"2019-11-26T06:37:17","name":"Phoscon#B360x258"},"A45B838DDE":{"create date":"2020-06-07T12:51:44","last use date":"2020-06-07T22:42:55","name":"Phoscon#B1396x686"},"A46CB67950":{"create date":"2019-10-20T21:19:26","last use date":"2019-10-21T00:06:17","name":"Phoscon#B1707x838"},"A4EFF19E47":{"create date":"2019-12-19T07:18:21","last use date":"2019-12-28T00:41:41","name":"Phoscon#B360x258"},"A62392AF32":{"create date":"2019-11-30T02:09:58","last use date":"2019-12-19T22:00:41","name":"Hue Essentials#KFMAWI"},"A825142249":{"create date":"2019-12-30T15:33:56","last use date":"2019-12-31T00:15:08","name":"Phoscon#B1692x820"},"A96CE01349":{"create date":"2020-06-11T10:52:42","last use date":"2020-06-12T08:03:39","name":"Phoscon#B1396x686"},"A978282A50":{"create date":"2019-12-30T10:24:42","last use date":"2019-12-31T18:05:54","name":"Phoscon#B800x808"},"AA3D02BBF3":{"create date":"2020-01-29T17:30:05","last use date":"2020-01-30T02:36:11","name":"Phoscon#B1536x754"},"AA9F431E95":{"create date":"2019-10-26T09:01:07","last use date":"2019-10-26T10:00:27","name":"Phoscon#B1692x828"},"AB4DA90329":{"create date":"2019-10-21T05:22:07","last use date":"2019-10-21T05:23:42","name":"Phoscon#B1707x838"},"ABB17ACEDA":{"create date":"2019-12-07T05:19:36","last use date":"2019-12-08T23:24:04","name":"Phoscon#B602x475"},"AE92F525AC":{"create date":"2020-01-07T18:11:47","last use date":"2020-01-07T22:34:33","name":"Phoscon#B1536x754"},"B27A4AC264":{"create date":"2020-03-29T19:14:22","last use date":"2020-03-30T13:09:14","name":"Phoscon#B360x258"},"B2CF7BD201":{"create date":"2019-12-28T00:43:19","last use date":"2020-01-04T05:29:53","name":"Phoscon#B360x258"},"B2FF498883":{"create date":"2020-01-08T19:15:15","last use date":"2020-01-09T06:43:55","name":"Phoscon#B1707x838"},"B6768D8BBB":{"create date":"2020-01-26T15:17:06","last use date":"2020-01-26T17:13:13","name":"Phoscon#B800x808"},"B7E340768B":{"create date":"2020-05-01T20:36:15","last use date":"2020-05-01T21:13:59","name":"Phoscon#B1396x686"},"B996C9F2C9":{"create date":"2020-05-17T20:22:55","last use date":"2020-05-17T20:24:49","name":"Phoscon#B1396x686"},"BBE6C022DB":{"create date":"2020-04-04T06:48:20","last use date":"2020-04-05T10:36:51","name":"Phoscon#B360x258"},"BBFD1EF246":{"create date":"2019-11-07T17:09:34","last use date":"2019-11-09T12:38:04","name":"Phoscon#B360x258"},"BD77BA53F2":{"create date":"2020-01-19T10:31:45","last use date":"2020-01-19T12:07:36","name":"Phoscon#B1536x754"},"BE3CE75E01":{"create date":"2020-01-29T19:13:10","last use date":"2020-03-08T08:46:29","name":"Phoscon#B360x258"},"C0760AAE07":{"create date":"2020-01-19T06:17:05","last use date":"2020-01-19T06:31:58","name":"Phoscon#B800x808"},"C142644B5F":{"create date":"2020-06-11T07:53:17","last use date":"2020-06-11T07:53:17","name":"ioBroker"},"C1FD274383":{"create date":"2020-01-18T18:50:32","last use date":"2020-01-18T20:35:04","name":"Phoscon#B1536x754"},"C271D51719":{"create date":"2019-12-28T01:55:31","last use date":"2019-12-29T10:55:17","name":"Phoscon#B1280x328"},"C538AAC9DB":{"create date":"2019-12-10T21:08:10","last use date":"2019-12-11T22:10:52","name":"Phoscon#B800x760"},"C5762837AF":{"create date":"2020-03-15T12:09:32","last use date":"2020-03-15T12:14:44","name":"Phoscon#B360x258"},"C688E44E98":{"create date":"2019-11-30T01:51:24","last use date":"2019-11-30T01:51:24","name":"all 4 hue#KFMAWI"},"C80776EF19":{"create date":"2020-05-17T15:20:44","last use date":"2020-06-11T07:40:38","name":"ioBroker"},"C9DF10EAB1":{"create date":"2020-01-18T20:48:00","last use date":"2020-04-10T12:39:49","name":"ioBroker"},"D4A8848F9A":{"create date":"2020-03-19T08:35:24","last use date":"2020-03-19T08:48:39","name":"Phoscon#B1536x754"},"D6348701EB":{"create date":"2019-12-29T18:52:11","last use date":"2019-12-29T19:21:59","name":"Phoscon#B1707x838"},"D66B8B5714":{"create date":"2019-12-04T19:45:25","last use date":"2019-12-22T23:27:44","name":"Phoscon#B601x456"},"D69B15DD1A":{"create date":"2020-06-11T07:52:13","last use date":"2020-06-11T07:52:13","name":"ioBroker"},"D725B1D9C2":{"create date":"2019-12-08T21:04:19","last use date":"2019-12-10T05:34:19","name":"Phoscon#B360x258"},"DA0E0BEDD3":{"create date":"2019-11-30T01:50:56","last use date":"2019-12-19T20:42:02","name":"Phoscon#B800x742"},"DB042007D9":{"create date":"2020-04-05T10:37:22","last use date":"2020-04-05T10:43:55","name":"Phoscon#B360x258"},"E0224D6187":{"create date":"2020-04-03T19:41:38","last use date":"2020-04-04T08:30:46","name":"Phoscon#B1396x641"},"E03CE41E07":{"create date":"2019-12-26T10:52:32","last use date":"2019-12-26T10:55:22","name":"Phoscon#B800x1112"},"E1F7CB4D3C":{"create date":"2019-12-10T05:34:58","last use date":"2019-12-11T16:40:55","name":"Phoscon#B360x258"},"E2AB1F8A5B":{"create date":"2019-12-18T18:43:10","last use date":"2019-12-19T07:17:50","name":"Phoscon#B360x258"},"E520485B88":{"create date":"2019-12-12T18:24:56","last use date":"2019-12-16T18:35:24","name":"Phoscon#B602x475"},"E56B900296":{"create date":"2020-02-07T19:15:34","last use date":"2020-06-05T05:18:49","name":"Phoscon#B1280x328"},"E728AA95B5":{"create date":"2020-05-17T07:28:06","last use date":"2020-05-17T09:37:14","name":"Phoscon#B1377x667"},"E925CD168C":{"create date":"2019-11-26T18:11:35","last use date":"2019-11-27T19:19:31","name":"Phoscon#B360x258"},"E9FEC4380B":{"create date":"2020-04-10T18:39:48","last use date":"2020-05-17T08:38:13","name":"ioBroker"},"EC7B3FC5C6":{"create date":"2019-12-11T18:36:08","last use date":"2019-12-11T21:37:16","name":"Phoscon#B602x475"},"EE796CF369":{"create date":"2020-01-01T22:54:58","last use date":"2020-01-01T22:55:09","name":"Phoscon#B800x808"},"F4C9A2171E":{"create date":"2019-12-22T04:32:56","last use date":"2019-12-22T04:33:08","name":"Phoscon#B800x808"},"F5AC42783C":{"create date":"2020-01-31T02:40:41","last use date":"2020-01-31T05:59:42","name":"Phoscon#B1506x722"},"F65D53CD98":{"create date":"2020-01-20T02:41:53","last use date":"2020-01-20T06:53:54","name":"Phoscon#B800x808"},"F85082A995":{"create date":"2019-10-22T19:49:32","last use date":"2019-10-22T22:04:58","name":"Phoscon#B1707x838"},"FA28AE9797":{"create date":"2020-04-01T20:20:25","last use date":"2020-04-02T17:29:41","name":"Phoscon#B360x258"},"FBD1933232":{"create date":"2019-12-08T13:25:28","last use date":"2019-12-08T13:34:57","name":"Phoscon#B360x320"},"FBF2236491":{"create date":"2020-02-19T11:04:33","last use date":"2020-02-19T19:42:16","name":"Phoscon#B1536x754"},"FC163A80D8":{"create date":"2020-05-18T22:22:10","last use date":"2020-05-18T22:29:42","name":"Phoscon#B1396x686"},"FC8F4F2CFB":{"create date":"2020-06-11T12:01:18","last use date":"2020-06-12T08:03:43","name":"ioBroker"},"FE351E5483":{"create date":"2020-04-09T17:43:17","last use date":"2020-05-14T05:50:33","name":"Phoscon#B360x258"}},"zigbeechannel":15}
            2020-06-12 09:03:43.511 - info: deconz.0 (32442) deConz Version: 2.5.77; API version: 1.16.0
            2020-06-12 09:03:43.545 - debug: deconz.0 (32442) Subscribed to updates...
            2020-06-12 09:03:43.597 - debug: deconz.0 (32442) Code 200: Request succeded get all lights: {"1":{"ctmax":500,"ctmin":153,"etag":"4aa80c3f2f5735dfdd4fc29213ff1673","hascolor":true,"lastseen":"2020-06-12T08:03:22.919","manufacturername":"Philips","modelid":"LCT010","name":"Stehlampe","state":{"alert":"none","bri":109,"colormode":"hs","ct":233,"effect":"none","hue":39206,"on":true,"reachable":true,"sat":12,"xy":[0.37,0.3726]},"swversion":"1.46.13_r26312","type":"Extended color light","uniqueid":"00:17:88:01:02:50:72:27-0b"},"10":{"ctmax":500,"ctmin":153,"etag":"f39f09c560a5f1fdb320570c77288136","hascolor":true,"lastseen":"2020-06-12T08:03:32.704","manufacturername":"Philips","modelid":"LCT015","name":"Mitte links","state":{"alert":"none","bri":101,"colormode":"ct","ct":292,"effect":"none","hue":9187,"on":false,"reachable":true,"sat":61,"xy":[0.4102,0.3941]},"swversion":"1.46.13_r26312","type":"Extended color light","uniqueid":"00:17:88:01:04:cc:15:93-0b"},"11":{"ctmax":500,"ctmin":153,"etag":"f39f09c560a5f1fdb320570c77288136","hascolor":true,"lastseen":"2020-06-12T08:03:33.800","manufacturername":"Philips","modelid":"LST002","name":"LED Schrank","state":{"alert":"none","bri":148,"colormode":"ct","ct":201,"effect":"none","hue":40655,"on":false,"reachable":true,"sat":40,"xy":[0.3454,0.3557]},"swversion":"1.46.13_r26312","type":"Extended color light","uniqueid":"00:17:88:01:03:e3:07:45-0b"},"12":{"ctmax":500,"ctmin":153,"etag":"f39f09c560a5f1fdb320570c77288136","hascolor":true,"lastseen":"2020-06-12T08:03:34.999","manufacturername":"Philips","modelid":"LST002","name":"LED TV","state":{"alert":"none","bri":161,"colormode":"ct","ct":227,"effect":"none","hue":39820,"on":false,"reachable":true,"sat":19,"xy":[0.3638,0.3687]},"swversion":"1.46.13_r26312","type":"Extended color light","uniqueid":"00:17:88:01:03:e3:08:28-0b"},"13":{"ctmax":500,"ctmin":153,"etag":"086664a008531e8473cf3f97b39c5824","hascolor":true,"lastseen":"2020-06-12T08:03:36.507","manufacturername":"Philips","modelid":"LCT015","name":"TV Spot links","state":{"alert":"none","bri":24,"colormode":"ct","ct":250,"effect":"none","hue":13248,"on":true,"reachable":true,"sat":5,"xy":[0.3812,0.3794]},"swversion":"1.46.13_r26312","type":"Extended color light","uniqueid":"00:17:88:01:04:fd:be:71-0b"},"14":{"ctmax":500,"ctmin":153,"etag":"113bc0e56926de0ee7cd4a47b4d95205","hascolor":true,"lastseen":"2020-06-12T08:03:41.356","manufacturername":"Philips","modelid":"LCT015","name":"TV Spot rechts","state":{"alert":"none","bri":81,"colormode":"ct","ct":230,"effect":"none","hue":39563,"on":true,"reachable":true,"sat":15,"xy":[0.3673,0.3709]},"swversion":"1.46.13_r26312","type":"Extended color light","uniqueid":"00:17:88:01:04:fd:c1:b5-0b"},"16":{"ctmax":500,"ctmin":153,"etag":"f39f09c560a5f1fdb320570c77288136","hascolor":true,"lastseen":"2020-06-12T08:03:38.401","manufacturername":"Philips","modelid":"LCT010","name":"Kühlschrank","state":{"alert":"none","bri":76,"colormode":"ct","ct":234,"effect":"none","hue":39206,"on":false,"reachable":true,"sat":12,"xy":[0.37,0.3726]},"swversion":"1.46.13_r26312","type":"Extended color light","uniqueid":"00:17:88:01:02:4c:91:1d-0b"},"17":{"ctmax":500,"ctmin":153,"etag":"f81c4381837b87d6ff321be7fba69c87","hascolor":true,"lastseen":"2020-06-12T08:03:39.931","manufacturername":"Philips","modelid":"LCT010","name":"Leselampe","state":{"alert":"none","bri":28,"colormode":"ct","ct":266,"effect":"none","hue":9788,"on":true,"reachable":true,"sat":27,"xy":[0.3923,0.3854]},"swversion":"1.46.13_r26312","type":"Extended color light","uniqueid":"00:17:88:01:02:54:89:65-0b"},"18":{"ctmax":500,"ctmin":153,"etag":"d5df79a65561de3419f9d9d9f34693bf","hascolor":true,"lastseen":"2020-06-12T08:03:40.599","manufacturername":"Philips","modelid":"LCT015","name":"Deckenlampe Flur","state":{"alert":"none","bri":40,"colormode":"ct","ct":231,"effect":"none","hue":39563,"on":false,"reachable":true,"sat":15,"xy":[0.3673,0.3709]},"swversion":"1.46.13_r26312","type":"Extended color light","uniqueid":"00:17:88:01:03:8a:81:b9-0b"},"19":{"ctmax":500,"ctmin":153,"etag":"f905166a0919b736a493b28d20bd6d41","hascolor":true,"lastseen":"2020-06-12T08:03:41.696","manufacturername":"Philips","modelid":"LCT012","name":"Spiegel Badezimmer","state":{"alert":"none","bri":80,"colormode":"ct","ct":234,"effect":"none","hue":39206,"on":false,"reachable":true,"sat":12,"xy":[0.37,0.3726]},"swversion":"1.46.13_r26312","type":"Extended color light","uniqueid":"00:17:88:01:04:18:90:33-0b"},"2":{"ctmax":500,"ctmin":153,"etag":"fdcfa24e611b30da1906cb73c7f4a8fd","hascolor":true,"lastseen":"2020-06-12T08:03:24.106","manufacturername":"Philips","modelid":"LCT010","name":"Lounge","state":{"alert":"none","bri":81,"colormode":"ct","ct":230,"effect":"none","hue":39563,"on":true,"reachable":true,"sat":15,"xy":[0.3673,0.3709]},"swversion":"1.46.13_r26312","type":"Extended color light","uniqueid":"00:17:88:01:02:47:bd:52-0b"},"20":{"ctmax":500,"ctmin":153,"etag":"6e02a9035e0a4ede4fdbd170108bf06f","hascolor":true,"lastseen":null,"manufacturername":"Philips","modelid":"LST002","name":"Stripe Sofa","state":{"alert":"none","bri":101,"colormode":"ct","ct":317,"effect":"none","hue":8895,"on":false,"reachable":false,"sat":89,"xy":[0.4259,0.4005]},"swversion":"5.127.1.26420","type":"Extended color light","uniqueid":"00:17:88:01:02:ac:67:22-0b"},"21":{"etag":"065edf82673cb55fc42c45942b838ad1","hascolor":false,"lastseen":"2020-06-12T08:00:45.816","manufacturername":"OSRAM","modelid":"Plug 01","name":"TV Küche","state":{"alert":"none","on":false,"reachable":true},"swversion":"V1.04.12","type":"On/Off plug-in unit","uniqueid":"84:18:26:00:00:0e:b8:36-03"},"22":{"etag":"6e02a9035e0a4ede4fdbd170108bf06f","hascolor":false,"lastseen":"2020-06-12T07:59:04.981","manufacturername":"OSRAM","modelid":"Plug 01","name":"Abzug","state":{"alert":"none","on":false,"reachable":true},"swversion":"V1.04.12","type":"On/Off plug-in unit","uniqueid":"84:18:26:00:00:0f:22:1b-03"},"23":{"etag":"6e02a9035e0a4ede4fdbd170108bf06f","hascolor":false,"lastseen":null,"manufacturername":"OSRAM","modelid":"Plug 01","name":"noch frei 1","state":{"alert":"none","on":false,"reachable":false},"swversion":"V1.04.12","type":"On/Off plug-in unit","uniqueid":"7c:b0:3e:aa:0a:02:76:7d-03"},"24":{"etag":"6e02a9035e0a4ede4fdbd170108bf06f","hascolor":false,"lastseen":null,"manufacturername":"OSRAM","modelid":"Plug 01","name":"noch frei 2","state":{"alert":"none","on":false,"reachable":false},"swversion":"V1.04.12","type":"On/Off plug-in unit","uniqueid":"7c:b0:3e:aa:0a:02:ff:d9-03"},"25":{"etag":"ea57415567a100746b821deda72f0ff9","hascolor":false,"lastseen":"2020-06-12T08:00:13.014","manufacturername":"OSRAM","modelid":"Plug 01","name":"XBOX ONE X","state":{"alert":"none","on":false,"reachable":true},"swversion":"V1.04.12","type":"On/Off plug-in unit","uniqueid":"84:18:26:00:00:0f:37:76-03"},"26":{"etag":"cdba864d147952feb525a37ac8859d8e","hascolor":false,"lastseen":"2020-06-12T08:00:09.762","manufacturername":"OSRAM","modelid":"Plug 01","name":"Ambilight","state":{"alert":"none","on":false,"reachable":true},"swversion":"V1.04.12","type":"On/Off plug-in unit","uniqueid":"7c:b0:3e:aa:0a:02:75:f0-03"},"27":{"etag":"6e02a9035e0a4ede4fdbd170108bf06f","hascolor":false,"lastseen":"2020-06-12T08:01:23.342","manufacturername":"OSRAM","modelid":"Plug 01","name":"XBOX ONE S","state":{"alert":"none","on":false,"reachable":true},"swversion":"V1.04.12","type":"On/Off plug-in unit","uniqueid":"7c:b0:3e:aa:00:af:10:a7-03"},"28":{"etag":"8bdec2f38d673727854007e4361ffc1f","hascolor":false,"lastseen":"2020-06-12T08:00:51.300","manufacturername":"OSRAM","modelid":"Plug 01","name":"NVIDIA Shield TV","state":{"alert":"none","on":false,"reachable":true},"swversion":"V1.04.12","type":"On/Off plug-in unit","uniqueid":"84:18:26:00:00:0f:f4:d6-03"},"29":{"etag":"54fb1a815d8b3db3e19868cecb9437c0","hascolor":false,"lastseen":"2020-06-12T08:03:15.621","manufacturername":"OSRAM","modelid":"Plug 01","name":"AVR X4300h","state":{"alert":"none","on":false,"reachable":true},"swversion":"V1.04.12","type":"On/Off plug-in unit","uniqueid":"84:18:26:00:00:0e:f4:7f-03"},"3":{"ctmax":500,"ctmin":153,"etag":"d23fa5617726f2847ad2e0f432ab232b","hascolor":true,"lastseen":"2020-06-12T08:03:24.903","manufacturername":"Philips","modelid":"LCT012","name":"Nachttisch rechts","state":{"alert":"none","bri":64,"colormode":"ct","ct":339,"effect":"none","hue":8672,"on":false,"reachable":true,"sat":113,"xy":[0.4402,0.4053]},"swversion":"1.46.13_r26312","type":"Extended color light","uniqueid":"00:17:88:01:04:6e:16:3d-0b"},"30":{"ctmax":500,"ctmin":153,"etag":"d23fa5617726f2847ad2e0f432ab232b","hascolor":true,"lastseen":"2020-06-12T08:03:07.496","manufacturername":"Philips","modelid":"LCT012","name":"Nachttisch links","state":{"alert":"none","bri":64,"colormode":"ct","ct":339,"effect":"none","hue":8672,"on":false,"reachable":true,"sat":113,"xy":[0.4402,0.4053]},"swversion":"1.46.13_r26312","type":"Extended color light","uniqueid":"00:17:88:01:04:19:36:ed-0b"},"31":{"ctmax":500,"ctmin":153,"etag":"acd4c0c36b9ded9b3bda789f89374a8a","hascolor":true,"lastseen":"2020-06-12T08:03:19.413","manufacturername":"Philips","modelid":"LST002","name":"Wohnzimmertür","state":{"alert":"none","bri":83,"colormode":"ct","ct":230,"effect":"none","hue":39563,"on":true,"reachable":true,"sat":15,"xy":[0.3673,0.3709]},"swversion":"1.46.13_r26312","type":"Extended color light","uniqueid":"00:17:88:01:03:e3:07:43-0b"},"32":{"ctmax":65535,"ctmin":0,"etag":"6e02a9035e0a4ede4fdbd170108bf06f","hascolor":true,"lastseen":null,"manufacturername":"Philips","modelid":"LCA001","name":"TimBlue","state":{"alert":"none","bri":254,"colormode":"ct","ct":366,"effect":"none","hue":8256,"on":true,"reachable":false,"sat":140,"xy":[0.4573,0.41]},"swversion":"1.53.3_r27175","type":"Extended color light","uniqueid":"00:17:88:01:06:79:03:c9-0b"},"33":{"ctmax":65535,"ctmin":0,"etag":"6e02a9035e0a4ede4fdbd170108bf06f","hascolor":true,"lastseen":null,"manufacturername":"Philips","modelid":"LCA001","name":"NiklasBlue","state":{"alert":"none","bri":126,"colormode":"ct","ct":204,"effect":"none","hue":0,"on":false,"reachable":false,"sat":0,"xy":[0.1845,0.1857]},"swversion":"1.53.3_r27175","type":"Extended color light","uniqueid":"00:17:88:01:06:4f:f7:07-0b"},"34":{"etag":"6e02a9035e0a4ede4fdbd170108bf06f","hascolor":false,"lastseen":null,"manufacturername":"LEDVANCE","modelid":"Plug Z3","name":"Ledvance1","state":{"alert":"none","on":false,"reachable":false},"swversion":"00103101","type":"On/Off plug-in unit","uniqueid":"f0:d1:b8:00:00:13:3e:92-01"},"35":{"ctmax":65535,"ctmin":0,"etag":"f39f09c560a5f1fdb320570c77288136","hascolor":true,"lastseen":"2020-06-12T08:03:20.154","manufacturername":"Philips","modelid":"LCG002","name":"Alkohol","state":{"alert":"none","bri":103,"colormode":"ct","ct":292,"effect":"none","hue":9030,"on":false,"reachable":true,"sat":61,"xy":[0.4102,0.3941]},"swversion":"1.55.7_r28193","type":"Extended color light","uniqueid":"00:17:88:01:08:40:60:23-0b"},"36":{"ctmax":65535,"ctmin":0,"etag":"f39f09c560a5f1fdb320570c77288136","hascolor":true,"lastseen":"2020-06-12T08:03:21.329","manufacturername":"Philips","modelid":"LCG002","name":"Messer","state":{"alert":"none","bri":103,"colormode":"ct","ct":292,"effect":"none","hue":9030,"on":false,"reachable":true,"sat":61,"xy":[0.4102,0.3941]},"swversion":"1.55.7_r28193","type":"Extended color light","uniqueid":"00:17:88:01:08:50:7e:7f-0b"},"38":{"etag":"76610dce580ab59c5bc8832b2600d854","hascolor":false,"lastseen":"2020-06-12T08:03:26.066","manufacturername":"Philips","modelid":"LWA001","name":"Abstellraum","state":{"alert":"none","bri":77,"on":false,"reachable":true},"swversion":"1.53.3_r27175","type":"Dimmable light","uniqueid":"00:17:88:01:08:26:b8:d9-0b"},"39":{"etag":"6e02a9035e0a4ede4fdbd170108bf06f","hascolor":false,"lastseen":null,"manufacturername":"LEDVANCE","modelid":"Plug Z3","name":"Ledvance 2","state":{"alert":"none","on":false,"reachable":false},"swversion":"00103101","type":"On/Off plug-in unit","uniqueid":"f0:d1:b8:00:00:13:23:d1-01"},"4":{"ctmax":500,"ctmin":153,"etag":"f39f09c560a5f1fdb320570c77288136","hascolor":true,"lastseen":"2020-06-12T08:03:28.197","manufacturername":"Philips","modelid":"LST002","name":"Arbeitsplatte","state":{"alert":"none","bri":79,"colormode":"ct","ct":234,"effect":"none","hue":39206,"on":false,"reachable":true,"sat":12,"xy":[0.37,0.3726]},"swversion":"1.46.13_r26312","type":"Extended color light","uniqueid":"00:17:88:01:03:f5:08:a3-0b"},"40":{"etag":"6e02a9035e0a4ede4fdbd170108bf06f","hascolor":false,"lastseen":null,"manufacturername":"LEDVANCE","modelid":"Plug Z3","name":"Ledvance 3","state":{"alert":"none","on":false,"reachable":false},"swversion":"00103101","type":"On/Off plug-in unit","uniqueid":"f0:d1:b8:00:00:13:32:fc-01"},"41":{"etag":"6e02a9035e0a4ede4fdbd170108bf06f","hascolor":false,"lastseen":null,"manufacturername":"LEDVANCE","modelid":"Plug Z3","name":"Ledvance 4","state":{"alert":"none","on":false,"reachable":false},"swversion":"00103101","type":"On/Off plug-in unit","uniqueid":"f0:d1:b8:00:00:13:1b:a5-01"},"42":{"ctmax":65535,"ctmin":0,"etag":"7ba07d9831d719d151f7b0b5a63b1bc7","hascolor":true,"lastseen":"2020-06-12T08:03:27.086","manufacturername":"Philips","modelid":"LCG002","name":"Spot Wanduhr","state":{"alert":"none","bri":65,"colormode":"xy","ct":484,"effect":"none","hue":6192,"on":false,"reachable":true,"sat":195,"xy":[0.5207,0.3982]},"swversion":"1.55.7_r28193","type":"Extended color light","uniqueid":"00:17:88:01:08:40:62:39-0b"},"5":{"ctmax":500,"ctmin":153,"etag":"d5df79a65561de3419f9d9d9f34693bf","hascolor":true,"lastseen":"2020-06-12T08:03:29.405","manufacturername":"Philips","modelid":"LST002","name":"Stripe Flur","state":{"alert":"none","bri":40,"colormode":"ct","ct":231,"effect":"none","hue":39563,"on":false,"reachable":true,"sat":15,"xy":[0.3673,0.3709]},"swversion":"1.46.13_r26312","type":"Extended color light","uniqueid":"00:17:88:01:03:f7:5e:ad-0b"},"6":{"ctmax":500,"ctmin":153,"etag":"d23fa5617726f2847ad2e0f432ab232b","hascolor":true,"lastseen":"2020-06-12T08:03:30.497","manufacturername":"Philips","modelid":"LCT015","name":"Deckenlampe Schalfzimmer","state":{"alert":"none","bri":64,"colormode":"ct","ct":339,"effect":"none","hue":8672,"on":false,"reachable":true,"sat":113,"xy":[0.4402,0.4053]},"swversion":"1.46.13_r26312","type":"Extended color light","uniqueid":"00:17:88:01:04:3c:ec:ac-0b"},"7":{"ctmax":500,"ctmin":153,"etag":"f39f09c560a5f1fdb320570c77288136","hascolor":true,"lastseen":"2020-06-12T08:03:31.592","manufacturername":"Philips","modelid":"LCT015","name":"Mitte rechts","state":{"alert":"none","bri":101,"colormode":"ct","ct":252,"effect":"none","hue":11719,"on":false,"reachable":true,"sat":8,"xy":[0.3827,0.3803]},"swversion":"1.46.13_r26312","type":"Extended color light","uniqueid":"00:17:88:01:04:16:fc:cb-0b"}}
            2020-06-12 09:03:44.434 - debug: deconz.0 (32442) Code 200: Request succeded get all sensors: {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"2334563be4c6d57c134355871e29a7ac","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"dark":false,"daylight":true,"lastupdated":"2020-06-12T04:04:08.858","status":160,"sunrise":"2020-06-12T03:10:20","sunset":"2020-06-12T19:43:38"},"swversion":"1.0","type":"Daylight","uniqueid":"00:21:2e:ff:ff:04:d5:ad-01"},"10":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2400},"ep":1,"etag":"7cd11399a3704a3f659ae1ab137a3048","lastseen":"2020-06-12T07:42:29.350","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"empty","state":{"lastupdated":"2020-06-12T07:42:29.352","open":true},"swversion":"20161128","type":"ZHAOpenClose","uniqueid":"00:15:8d:00:02:38:6d:59-01-0006"},"11":{"config":{"battery":95,"on":true,"reachable":true,"temperature":2600},"ep":1,"etag":"c19a167b252b987ece5d868145e0cf27","lastseen":"2020-06-12T07:41:37.657","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"Türklingel","state":{"lastupdated":"2020-06-12T07:41:37.157","open":true},"swversion":"20161128","type":"ZHAOpenClose","uniqueid":"00:15:8d:00:04:23:96:5f-01-0006"},"12":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2300},"ep":1,"etag":"f519c7e48c74c7b38c29dfcd8d21a4a0","lastseen":"2020-06-12T07:54:20.752","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"Fenster Wohnzimmer","state":{"lastupdated":"2020-06-12T07:54:20.253","open":true},"swversion":"20161128","type":"ZHAOpenClose","uniqueid":"00:15:8d:00:03:cd:44:03-01-0006"},"13":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2200},"ep":1,"etag":"8df900b986a3f29fd4902804f0a38967","lastseen":"2020-06-12T07:23:19.805","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"Fenster Küche","state":{"lastupdated":"2020-06-12T07:23:19.306","open":true},"swversion":"20161128","type":"ZHAOpenClose","uniqueid":"00:15:8d:00:04:13:db:4b-01-0006"},"14":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2100},"ep":1,"etag":"85fabf3b056101ee3badd63949a1320f","lastseen":"2020-06-12T07:30:23.186","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"Wohnungstür","state":{"lastupdated":"2020-06-12T07:30:22.689","open":false},"swversion":"20161128","type":"ZHAOpenClose","uniqueid":"00:15:8d:00:02:4e:4e:c1-01-0006"},"15":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2100},"ep":1,"etag":"49c1a5e1a69fabd4c0964149a7dfaf90","lastseen":"2020-06-12T07:30:05.627","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"Fenster Badezimmer","state":{"lastupdated":"2020-06-12T07:30:05.627","open":true},"swversion":"20161128","type":"ZHAOpenClose","uniqueid":"00:15:8d:00:02:36:ee:f3-01-0006"},"16":{"config":{"battery":95,"on":true,"reachable":true,"temperature":2700},"ep":1,"etag":"fd310692e264f89862ce0bbd286b1681","lastseen":"2020-06-12T07:28:52.330","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"Fenster Schlafzimmer","state":{"lastupdated":"2020-06-12T07:28:51.832","open":true},"swversion":"20161128","type":"ZHAOpenClose","uniqueid":"00:15:8d:00:02:53:16:04-01-0006"},"17":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2300},"ep":1,"etag":"9952f38df3c1bd025c65357466c94b32","lastseen":"2020-06-12T07:50:54.451","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"Tür Badezimmer","state":{"lastupdated":"2020-06-12T07:50:54.452","open":true},"swversion":"20161128","type":"ZHAOpenClose","uniqueid":"00:15:8d:00:02:32:9b:52-01-0006"},"2":{"config":{"battery":100,"group":"26780","on":true,"reachable":true},"ep":2,"etag":"34cd134bc06e4a703690f32cc1451656","lastseen":"2020-06-12T08:00:49.884","manufacturername":"Philips","mode":1,"modelid":"RWL021","name":"Dimmer 1","state":{"buttonevent":1002,"eventduration":0,"lastupdated":"2020-06-12T07:47:39.390"},"swversion":"6.1.1.28573","type":"ZHASwitch","uniqueid":"00:17:88:01:04:ee:06:1a-02-fc00"},"21":{"config":{"alert":"none","battery":50,"delay":12,"ledindication":false,"on":true,"pending":[],"reachable":true,"sensitivity":2,"sensitivitymax":2,"usertest":false},"ep":2,"etag":"d0d45594ac71b292524c14e1b39f7d9e","lastseen":"2020-06-12T08:02:10.919","manufacturername":"Philips","modelid":"SML001","name":"Bewegungsmelder Bad","state":{"lastupdated":"2020-06-12T08:00:18.911","presence":false},"swversion":"6.1.1.27575","type":"ZHAPresence","uniqueid":"00:17:88:01:06:f4:e3:9b-02-0406"},"22":{"config":{"alert":"none","battery":50,"ledindication":false,"offset":0,"on":true,"pending":[],"reachable":true,"usertest":false},"ep":2,"etag":"44954e3640b5a55ea1de850df5e7d01c","lastseen":"2020-06-12T08:02:10.919","manufacturername":"Philips","modelid":"SML001","name":"Bewegungsmelder Bad","state":{"lastupdated":"2020-06-12T08:02:10.919","temperature":1832},"swversion":"6.1.1.27575","type":"ZHATemperature","uniqueid":"00:17:88:01:06:f4:e3:9b-02-0402"},"23":{"config":{"alert":"none","battery":50,"ledindication":false,"on":true,"pending":[],"reachable":true,"tholddark":12000,"tholdoffset":7000,"usertest":false},"ep":2,"etag":"90d3864d8bcc827904fc4b5c39fd154c","lastseen":"2020-06-12T08:02:10.919","manufacturername":"Philips","modelid":"SML001","name":"Bewegungsmelder Bad","state":{"dark":false,"daylight":false,"lastupdated":"2020-06-12T08:00:03.535","lightlevel":13211,"lux":21},"swversion":"6.1.1.27575","type":"ZHALightLevel","uniqueid":"00:17:88:01:06:f4:e3:9b-02-0400"},"24":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2400,"tholddark":12000,"tholdoffset":7000},"ep":1,"etag":"e64c375545800989290db30b116338b2","lastseen":"2020-06-12T07:08:51.300","manufacturername":"LUMI","modelid":"lumi.sensor_motion.aq2","name":"Bewegungsmelder Kammer","state":{"dark":true,"daylight":false,"lastupdated":"2020-06-12T07:08:51.301","lightlevel":0,"lux":0},"swversion":"20170627","type":"ZHALightLevel","uniqueid":"00:15:8d:00:02:75:27:ed-01-0400"},"25":{"config":{"battery":100,"duration":90,"on":true,"reachable":true,"temperature":2400},"ep":1,"etag":"e64c375545800989290db30b116338b2","lastseen":"2020-06-12T07:08:51.301","manufacturername":"LUMI","modelid":"lumi.sensor_motion.aq2","name":"Bewegungsmelder Kammer","state":{"lastupdated":"2020-06-12T07:08:51.302","presence":false},"swversion":"20170627","type":"ZHAPresence","uniqueid":"00:15:8d:00:02:75:27:ed-01-0406"},"26":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2500,"tholddark":12000,"tholdoffset":7000},"ep":1,"etag":"0fc353f6ac31c4ca19571c139f803ee7","lastseen":"2020-06-12T07:58:36.252","manufacturername":"LUMI","modelid":"lumi.sensor_motion.aq2","name":"Bewegungsmelder Flur","state":{"dark":true,"daylight":false,"lastupdated":"2020-06-12T07:58:36.253","lightlevel":0,"lux":0},"swversion":"20170627","type":"ZHALightLevel","uniqueid":"00:15:8d:00:02:53:59:e5-01-0400"},"27":{"config":{"battery":100,"duration":90,"on":true,"reachable":true,"temperature":2500},"ep":1,"etag":"0fc353f6ac31c4ca19571c139f803ee7","lastseen":"2020-06-12T07:58:36.253","manufacturername":"LUMI","modelid":"lumi.sensor_motion.aq2","name":"Bewegungsmelder Flur","state":{"lastupdated":"2020-06-12T07:58:36.253","presence":false},"swversion":"20170627","type":"ZHAPresence","uniqueid":"00:15:8d:00:02:53:59:e5-01-0406"},"28":{"config":{"battery":95,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"4c5d3bb9bbe5df681c630c008eb1f956","lastseen":"2020-06-12T07:52:12.498","manufacturername":"LUMI","modelid":"lumi.weather","name":"Temperatur Bad","state":{"lastupdated":"2020-06-12T07:52:12.498","temperature":2047},"swversion":"20161129","type":"ZHATemperature","uniqueid":"00:15:8d:00:04:11:a9:c5-01-0402"},"29":{"config":{"battery":95,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"4c5d3bb9bbe5df681c630c008eb1f956","lastseen":"2020-06-12T07:52:12.498","manufacturername":"LUMI","modelid":"lumi.weather","name":"Temperatur Bad","state":{"humidity":6643,"lastupdated":"2020-06-12T07:52:12.498"},"swversion":"20161129","type":"ZHAHumidity","uniqueid":"00:15:8d:00:04:11:a9:c5-01-0405"},"3":{"config":{"battery":87,"group":"24347","on":true,"reachable":true},"ep":2,"etag":"30d2d89fcd81752af354f5f51f6d5efa","lastseen":"2020-06-12T08:01:41.333","manufacturername":"Philips","mode":1,"modelid":"RWL021","name":"Dimmer 2","state":{"buttonevent":4002,"eventduration":1,"lastupdated":"2020-06-11T08:27:19.437"},"swversion":"6.1.1.28573","type":"ZHASwitch","uniqueid":"00:17:88:01:03:ca:1e:58-02-fc00"},"30":{"config":{"battery":95,"on":true,"reachable":true},"ep":1,"etag":"4c5d3bb9bbe5df681c630c008eb1f956","lastseen":"2020-06-12T07:52:12.498","manufacturername":"LUMI","modelid":"lumi.weather","name":"Temperatur Bad","state":{"lastupdated":"2020-06-12T07:52:12.498","pressure":995},"swversion":"20161129","type":"ZHAPressure","uniqueid":"00:15:8d:00:04:11:a9:c5-01-0403"},"31":{"config":{"battery":98,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"99264dc364bdf5fec23b45f4a463e537","lastseen":"2020-06-12T07:16:48.545","manufacturername":"LUMI","modelid":"lumi.weather","name":"Temperatur Küche","state":{"lastupdated":"2020-06-12T07:16:48.352","temperature":2102},"swversion":"20161129","type":"ZHATemperature","uniqueid":"00:15:8d:00:03:f1:1b:28-01-0402"},"32":{"config":{"battery":98,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"99264dc364bdf5fec23b45f4a463e537","lastseen":"2020-06-12T07:16:48.545","manufacturername":"LUMI","modelid":"lumi.weather","name":"Temperatur Küche","state":{"humidity":6107,"lastupdated":"2020-06-12T07:16:48.375"},"swversion":"20161129","type":"ZHAHumidity","uniqueid":"00:15:8d:00:03:f1:1b:28-01-0405"},"33":{"config":{"battery":98,"on":true,"reachable":true},"ep":1,"etag":"99264dc364bdf5fec23b45f4a463e537","lastseen":"2020-06-12T07:16:48.545","manufacturername":"LUMI","modelid":"lumi.weather","name":"Temperatur Küche","state":{"lastupdated":"2020-06-12T07:16:48.545","pressure":995},"swversion":"20161129","type":"ZHAPressure","uniqueid":"00:15:8d:00:03:f1:1b:28-01-0403"},"34":{"config":{"battery":100,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"30d2d89fcd81752af354f5f51f6d5efa","lastseen":"2020-06-12T08:01:41.817","manufacturername":"LUMI","modelid":"lumi.weather","name":"Temp Schlafzimmer","state":{"lastupdated":"2020-06-12T08:01:41.818","temperature":2133},"swversion":"20161129","type":"ZHATemperature","uniqueid":"00:15:8d:00:03:f4:bf:e8-01-0402"},"35":{"config":{"battery":100,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"30d2d89fcd81752af354f5f51f6d5efa","lastseen":"2020-06-12T08:01:41.818","manufacturername":"LUMI","modelid":"lumi.weather","name":"Temp Schlafzimmer","state":{"humidity":6190,"lastupdated":"2020-06-12T08:01:41.818"},"swversion":"20161129","type":"ZHAHumidity","uniqueid":"00:15:8d:00:03:f4:bf:e8-01-0405"},"36":{"config":{"battery":100,"on":true,"reachable":true},"ep":1,"etag":"30d2d89fcd81752af354f5f51f6d5efa","lastseen":"2020-06-12T08:01:41.819","manufacturername":"LUMI","modelid":"lumi.weather","name":"Temp Schlafzimmer","state":{"lastupdated":"2020-06-12T08:01:41.819","pressure":995},"swversion":"20161129","type":"ZHAPressure","uniqueid":"00:15:8d:00:03:f4:bf:e8-01-0403"},"37":{"config":{"battery":95,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"48d8100865dae6c744a5b9f009e7d0e4","lastseen":"2020-06-12T07:28:00.159","manufacturername":"LUMI","modelid":"lumi.weather","name":"Multisensor","state":{"lastupdated":"2020-06-12T07:28:00.161","temperature":2110},"swversion":"20161129","type":"ZHATemperature","uniqueid":"00:15:8d:00:03:f4:be:91-01-0402"},"38":{"config":{"battery":95,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"48d8100865dae6c744a5b9f009e7d0e4","lastseen":"2020-06-12T07:28:00.161","manufacturername":"LUMI","modelid":"lumi.weather","name":"Multisensor","state":{"humidity":6070,"lastupdated":"2020-06-12T07:28:00.162"},"swversion":"20161129","type":"ZHAHumidity","uniqueid":"00:15:8d:00:03:f4:be:91-01-0405"},"39":{"config":{"battery":95,"on":true,"reachable":true},"ep":1,"etag":"48d8100865dae6c744a5b9f009e7d0e4","lastseen":"2020-06-12T07:28:00.162","manufacturername":"LUMI","modelid":"lumi.weather","name":"Multisensor","state":{"lastupdated":"2020-06-12T07:28:00.164","pressure":996},"swversion":"20161129","type":"ZHAPressure","uniqueid":"00:15:8d:00:03:f4:be:91-01-0403"},"4":{"config":{"battery":100,"group":"5405","on":true,"reachable":true},"ep":2,"etag":"be37ec30f0a9af214f32163874321f3d","lastseen":"2020-06-12T08:01:57.898","manufacturername":"Philips","mode":1,"modelid":"RWL021","name":"Dimmer 3","state":{"buttonevent":2003,"eventduration":null,"lastupdated":"2020-04-04T18:58:07.000"},"swversion":"6.1.1.28573","type":"ZHASwitch","uniqueid":"00:17:88:01:04:e4:80:6a-02-fc00"},"40":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2300},"ep":1,"etag":"91f4f0fd83d46d1615500d835e196f5c","lastseen":"2020-06-12T07:30:10.313","manufacturername":"LUMI","mode":1,"modelid":"lumi.remote.b1acn01","name":"Switch_Badezimmer","state":{"buttonevent":1002,"lastupdated":"2020-06-12T07:30:10.312"},"swversion":"20180525","type":"ZHASwitch","uniqueid":"00:15:8d:00:04:23:b5:50-01-0012"},"41":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2500},"ep":1,"etag":"065edf82673cb55fc42c45942b838ad1","lastseen":"2020-06-12T07:45:51.658","manufacturername":"LUMI","mode":1,"modelid":"lumi.remote.b1acn01","name":"Switch_TV_Kueche","state":{"buttonevent":1004,"lastupdated":"2020-06-12T07:45:51.658"},"swversion":"20180525","type":"ZHASwitch","uniqueid":"00:15:8d:00:04:4d:90:cc-01-0012"},"42":{"config":{"battery":98,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"31e4321f714b8e5a511048a2ec5a8dd9","lastseen":"2020-06-12T07:40:24.208","manufacturername":"LUMI","modelid":"lumi.weather","name":"Multisensor (2)","state":{"lastupdated":"2020-06-12T07:40:24.210","temperature":2110},"swversion":"20161129","type":"ZHATemperature","uniqueid":"00:15:8d:00:04:4a:64:fd-01-0402"},"43":{"config":{"battery":98,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"31e4321f714b8e5a511048a2ec5a8dd9","lastseen":"2020-06-12T07:40:24.210","manufacturername":"LUMI","modelid":"lumi.weather","name":"Multisensor (2)","state":{"humidity":6332,"lastupdated":"2020-06-12T07:40:24.211"},"swversion":"20161129","type":"ZHAHumidity","uniqueid":"00:15:8d:00:04:4a:64:fd-01-0405"},"44":{"config":{"battery":98,"on":true,"reachable":true},"ep":1,"etag":"31e4321f714b8e5a511048a2ec5a8dd9","lastseen":"2020-06-12T07:40:24.212","manufacturername":"LUMI","modelid":"lumi.weather","name":"Multisensor (2)","state":{"lastupdated":"2020-06-12T07:40:24.213","pressure":995},"swversion":"20161129","type":"ZHAPressure","uniqueid":"00:15:8d:00:04:4a:64:fd-01-0403"},"45":{"config":{"battery":98,"on":true,"reachable":true,"temperature":2800},"ep":1,"etag":"80d6282304b65351cca8217631e43ddf","lastseen":"2020-06-12T07:25:36.711","manufacturername":"LUMI","mode":1,"modelid":"lumi.remote.b1acn01","name":"Switch 42","state":{"buttonevent":1002,"lastupdated":"2020-06-09T05:52:42.498"},"swversion":"20180525","type":"ZHASwitch","uniqueid":"00:15:8d:00:04:4b:5e:4f-01-0012"},"46":{"config":{"battery":95,"on":true,"reachable":true,"temperature":2800},"ep":1,"etag":"97767b1d6fc0228baa06c18b254d7e9e","lastseen":"2020-06-12T07:24:37.909","manufacturername":"LUMI","mode":1,"modelid":"lumi.remote.b1acn01","name":"Switch_Schalfzimmer","state":{"buttonevent":1002,"lastupdated":"2020-06-10T23:41:27.335"},"swversion":"20180525","type":"ZHASwitch","uniqueid":"00:15:8d:00:04:4b:5c:ec-01-0012"},"49":{"config":{"alert":"none","battery":50,"delay":0,"ledindication":false,"on":true,"pending":[],"reachable":true,"sensitivity":2,"sensitivitymax":2,"usertest":false},"ep":2,"etag":"4bae15aefac2a08996c2558f055cb76d","lastseen":"2020-06-12T08:02:47.769","manufacturername":"Philips","modelid":"SML001","name":"BWM Flur","state":{"lastupdated":"2020-06-12T08:00:22.037","presence":false},"swversion":"6.1.1.27575","type":"ZHAPresence","uniqueid":"00:17:88:01:06:f6:86:ef-02-0406"},"5":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2500},"ep":1,"etag":"ff18a1894575836f755550f7477cfe1b","lastseen":"2020-06-12T07:18:06.279","manufacturername":"LUMI","mode":1,"modelid":"lumi.remote.b286acn01","name":"DoppelTaster 1","state":{"buttonevent":2002,"lastupdated":"2020-05-17T08:35:36.000"},"swversion":"20180809","type":"ZHASwitch","uniqueid":"00:15:8d:00:03:16:aa:b2-01-0012"},"50":{"config":{"alert":"none","battery":50,"ledindication":false,"offset":0,"on":true,"pending":[],"reachable":true,"usertest":false},"ep":2,"etag":"21af8b2a8fccfc36ecdb84cd347c6d8b","lastseen":"2020-06-12T08:02:47.769","manufacturername":"Philips","modelid":"SML001","name":"BWM Flur","state":{"lastupdated":"2020-06-12T08:02:47.768","temperature":1979},"swversion":"6.1.1.27575","type":"ZHATemperature","uniqueid":"00:17:88:01:06:f6:86:ef-02-0402"},"51":{"config":{"alert":"none","battery":50,"ledindication":false,"on":true,"pending":[],"reachable":true,"tholddark":12000,"tholdoffset":7000,"usertest":false},"ep":2,"etag":"7339bacc4aa21c4a03acbb112394bdbc","lastseen":"2020-06-12T08:02:47.769","manufacturername":"Philips","modelid":"SML001","name":"BWM Flur","state":{"dark":true,"daylight":false,"lastupdated":"2020-06-12T08:00:12.975","lightlevel":3645,"lux":2},"swversion":"6.1.1.27575","type":"ZHALightLevel","uniqueid":"00:17:88:01:06:f6:86:ef-02-0400"},"52":{"config":{"alert":"none","battery":52,"delay":0,"ledindication":false,"on":true,"pending":[],"reachable":true,"sensitivity":2,"sensitivitymax":2,"usertest":false},"ep":2,"etag":"30d2d89fcd81752af354f5f51f6d5efa","lastseen":"2020-06-12T08:01:41.185","manufacturername":"Philips","modelid":"SML001","name":"BWM Schlafzimmer","state":{"lastupdated":"2020-06-12T07:59:38.744","presence":false},"swversion":"6.1.1.27575","type":"ZHAPresence","uniqueid":"00:17:88:01:03:29:a0:eb-02-0406"},"53":{"config":{"alert":"none","battery":52,"ledindication":false,"offset":0,"on":true,"pending":[],"reachable":true,"usertest":false},"ep":2,"etag":"30d2d89fcd81752af354f5f51f6d5efa","lastseen":"2020-06-12T08:01:41.185","manufacturername":"Philips","modelid":"SML001","name":"BWM Schlafzimmer","state":{"lastupdated":"2020-06-12T07:59:43.636","temperature":2165},"swversion":"6.1.1.27575","type":"ZHATemperature","uniqueid":"00:17:88:01:03:29:a0:eb-02-0402"},"54":{"config":{"alert":"none","battery":52,"ledindication":false,"on":true,"pending":[],"reachable":true,"tholddark":12000,"tholdoffset":7000,"usertest":false},"ep":2,"etag":"30d2d89fcd81752af354f5f51f6d5efa","lastseen":"2020-06-12T08:01:41.185","manufacturername":"Philips","modelid":"SML001","name":"BWM Schlafzimmer","state":{"dark":true,"daylight":false,"lastupdated":"2020-06-12T07:59:29.461","lightlevel":1215,"lux":1},"swversion":"6.1.1.27575","type":"ZHALightLevel","uniqueid":"00:17:88:01:03:29:a0:eb-02-0400"},"55":{"config":{"on":true,"reachable":true},"etag":"2334563be4c6d57c134355871e29a7ac","manufacturername":"all 4 hue","modelid":"Model 2015","name":"Licht-Status","state":{"lastupdated":"2020-06-11T15:16:22.095","status":0},"swversion":"1.0","type":"CLIPGenericStatus","uniqueid":"PFHS-LIGHT-STATE"},"56":{"config":{"duration":60,"on":true,"reachable":true},"etag":"2334563be4c6d57c134355871e29a7ac","manufacturername":"Phoscon","modelid":"PHOSCON_VPIR","name":"VPIR Testing","state":{"lastupdated":"2020-01-18T11:40:27.000","presence":false},"swversion":"1.0","type":"CLIPPresence","uniqueid":"vpir-1579347626836"},"57":{"config":{"on":true,"reachable":true},"etag":"2334563be4c6d57c134355871e29a7ac","manufacturername":"Phoscon","modelid":"PHOSCON_FSM_STATE","name":"FSM_STATE Testing","state":{"lastupdated":"2020-06-11T15:16:22.100","status":0},"swversion":"1.0","type":"CLIPGenericStatus","uniqueid":"fsm-state-1579347626836"},"58":{"config":{"alert":"none","battery":53,"delay":0,"ledindication":false,"on":true,"pending":[],"reachable":true,"sensitivity":2,"sensitivitymax":2,"usertest":false},"ep":2,"etag":"f85d6f82d4f9b5a3f2f9b3dece3eaefa","lastseen":"2020-06-12T08:03:29.137","manufacturername":"Philips","modelid":"SML001","name":"BWM Kueche","state":{"lastupdated":"2020-06-12T08:02:43.461","presence":false},"swversion":"6.1.1.27575","type":"ZHAPresence","uniqueid":"00:17:88:01:06:f6:73:8c-02-0406"},"59":{"config":{"alert":"none","battery":53,"ledindication":false,"offset":0,"on":true,"pending":[],"reachable":true,"usertest":false},"ep":2,"etag":"44954e3640b5a55ea1de850df5e7d01c","lastseen":"2020-06-12T08:03:29.137","manufacturername":"Philips","modelid":"SML001","name":"BWM Kueche","state":{"lastupdated":"2020-06-12T08:02:10.479","temperature":1973},"swversion":"6.1.1.27575","type":"ZHATemperature","uniqueid":"00:17:88:01:06:f6:73:8c-02-0402"},"6":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2100},"ep":1,"etag":"8ef350ef4d9b01a3ad2aaa96aeaf3abb","lastseen":"2020-06-12T07:37:02.276","manufacturername":"LUMI","mode":1,"modelid":"lumi.remote.b286acn01","name":"DoppelTaster 2","state":{"buttonevent":3002,"lastupdated":"2020-05-17T16:56:35.000"},"swversion":"20180809","type":"ZHASwitch","uniqueid":"00:15:8d:00:03:1e:37:bd-01-0012"},"60":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2400},"ep":1,"etag":"524da81b99a52c177a278fb505cbc3f7","lastseen":"2020-06-12T07:28:39.093","manufacturername":"LUMI","mode":1,"modelid":"lumi.remote.b1acn01","name":"Switch testing","state":{"buttonevent":1004,"lastupdated":"2020-06-11T12:14:59.160"},"swversion":"20180525","type":"ZHASwitch","uniqueid":"00:15:8d:00:04:4d:d2:e5-01-0012"},"61":{"config":{"battery":98,"on":true,"reachable":true,"temperature":3000},"ep":1,"etag":"399c32f1c0d13a829aeb9619764118c3","lastseen":"2020-06-12T07:40:12.337","manufacturername":"LUMI","mode":1,"modelid":"lumi.remote.b1acn01","name":"Switch Flur","state":{"buttonevent":1002,"lastupdated":"2020-06-11T18:18:39.404"},"swversion":"20180525","type":"ZHASwitch","uniqueid":"00:15:8d:00:04:23:b7:b4-01-0012"},"62":{"config":{"alert":"none","battery":53,"ledindication":false,"on":true,"pending":[],"reachable":true,"tholddark":12000,"tholdoffset":7000,"usertest":false},"ep":2,"etag":"bd652942bc41047628a267545128cc29","lastseen":"2020-06-12T08:03:29.136","manufacturername":"Philips","modelid":"SML001","name":"BWM Kueche","state":{"dark":false,"daylight":false,"lastupdated":"2020-06-12T08:03:29.136","lightlevel":12096,"lux":16},"swversion":"6.1.1.27575","type":"ZHALightLevel","uniqueid":"00:17:88:01:06:f6:73:8c-02-0400"},"7":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2300},"ep":1,"etag":"298779077a94be57058b763b7f1221d7","lastseen":"2020-06-12T07:28:27.271","manufacturername":"LUMI","mode":1,"modelid":"lumi.remote.b286acn01","name":"DoppelTaster 3","state":{"buttonevent":1002,"lastupdated":"2020-05-17T08:35:36.000"},"swversion":"20180809","type":"ZHASwitch","uniqueid":"00:15:8d:00:03:1e:37:53-01-0012"},"8":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2700},"ep":1,"etag":"2a3ba6eabfdd98825a4c380832cc8ec0","lastseen":"2020-06-12T07:22:18.407","manufacturername":"LUMI","mode":1,"modelid":"lumi.remote.b286acn01","name":"DoppelTaster 4","state":{"buttonevent":2002,"lastupdated":"2020-05-16T14:54:46.000"},"swversion":"20180809","type":"ZHASwitch","uniqueid":"00:15:8d:00:03:15:b5:70-01-0012"},"9":{"config":{"battery":95,"on":true,"reachable":true,"temperature":2900},"ep":1,"etag":"e0e624d7d0c3108ad46b4d91fd3e41ce","lastseen":"2020-06-12T07:42:48.244","manufacturername":"LUMI","mode":1,"modelid":"lumi.remote.b286acn01","name":"DoppelTaster 5","state":{"buttonevent":3002,"lastupdated":"2020-05-17T16:56:33.000"},"swversion":"20180809","type":"ZHASwitch","uniqueid":"00:15:8d:00:03:1e:36:a5-01-0012"}}
            2020-06-12 09:03:44.441 - debug: deconz.0 (32442) Code 200: Request succeded get all groups: {"1":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"26e66429686f496d71f576912d60b54d","id":"1","lights":["1","2","13","14","17","20","31","42"],"name":"Wohnzimmer","scenes":[{"id":"1","lightcount":7,"name":"Orange","transitiontime":50}],"state":{"all_on":false,"any_on":true},"type":"LightGroup"},"10":{"action":{"bri":40,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"f39f09c560a5f1fdb320570c77288136","id":"10","lights":["4","16"],"name":"Küche_BWM","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"},"11":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"f39f09c560a5f1fdb320570c77288136","id":"11","lights":["11","42"],"name":"KlingelAlarm","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"},"2":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"f39f09c560a5f1fdb320570c77288136","id":"2","lights":["4","7","10","11","12","16","35","36"],"name":"Küche","scenes":[{"id":"1","lightcount":8,"name":"Spülen","transitiontime":20}],"state":{"all_on":false,"any_on":false},"type":"LightGroup"},"24347":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["3"],"etag":"f39f09c560a5f1fdb320570c77288136","id":"24347","lights":["4","7","10"],"name":"RWL021 8","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"},"26780":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":true,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["2"],"etag":"fdcfa24e611b30da1906cb73c7f4a8fd","id":"26780","lights":["1","2","13","14","17","31"],"name":"RWL021 7","scenes":[],"state":{"all_on":true,"any_on":true},"type":"LightGroup"},"3":{"action":{"bri":200,"colormode":"ct","ct":234,"effect":"none","hue":0,"on":true,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"f905166a0919b736a493b28d20bd6d41","id":"3","lights":["19"],"name":"Badezimmer","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"},"4":{"action":{"bri":64,"colormode":"ct","ct":339,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"d23fa5617726f2847ad2e0f432ab232b","id":"4","lights":["3","6","30"],"name":"Schlafzimmer","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"},"5":{"action":{"bri":40,"colormode":"ct","ct":231,"effect":"none","hue":54262,"on":false,"sat":67,"scene":null,"xy":[0.344381,0.242908]},"devicemembership":[],"etag":"d5df79a65561de3419f9d9d9f34693bf","id":"5","lights":["5","18"],"name":"Flur","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"},"5405":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["4"],"etag":"f905166a0919b736a493b28d20bd6d41","id":"5405","lights":["19"],"name":"RWL021 9","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"},"6":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"065edf82673cb55fc42c45942b838ad1","id":"6","lights":["21","22","23","24","25","26","27","28","29","34","39","40","41"],"name":"OSRAM Smart Plug","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"},"7":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"76610dce580ab59c5bc8832b2600d854","id":"7","lights":["38"],"name":"Kammer","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}}
            2020-06-12 09:03:44.451 - info: deconz.0 (32442) Code 404: Ressource not found get devices: []
            2020-06-12 09:03:46.091 - debug: deconz.0 (32442) Code 200: Request succeded get group attributes 1: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"26e66429686f496d71f576912d60b54d","id":"1","lights":["1","2","13","14","17","20","31","42"],"name":"Wohnzimmer","scenes":[{"id":"1","lightcount":7,"name":"Orange","transitiontime":50}],"state":{"all_on":false,"any_on":true},"type":"LightGroup"}
            2020-06-12 09:03:46.139 - debug: deconz.0 (32442) Code 200: Request succeded get group attributes 2: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"f39f09c560a5f1fdb320570c77288136","id":"2","lights":["4","7","10","11","12","16","35","36"],"name":"Küche","scenes":[{"id":"1","lightcount":8,"name":"Spülen","transitiontime":20}],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}
            2020-06-12 09:03:46.157 - debug: deconz.0 (32442) Code 200: Request succeded get group attributes 3: {"action":{"bri":200,"colormode":"ct","ct":234,"effect":"none","hue":0,"on":true,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"f905166a0919b736a493b28d20bd6d41","id":"3","lights":["19"],"name":"Badezimmer","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}
            2020-06-12 09:03:46.169 - debug: deconz.0 (32442) Code 200: Request succeded get group attributes 4: {"action":{"bri":64,"colormode":"ct","ct":339,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"d23fa5617726f2847ad2e0f432ab232b","id":"4","lights":["3","6","30"],"name":"Schlafzimmer","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}
            2020-06-12 09:03:46.178 - debug: deconz.0 (32442) Code 200: Request succeded get group attributes 5: {"action":{"bri":40,"colormode":"ct","ct":231,"effect":"none","hue":54262,"on":false,"sat":67,"scene":null,"xy":[0.344381,0.242908]},"devicemembership":[],"etag":"d5df79a65561de3419f9d9d9f34693bf","id":"5","lights":["5","18"],"name":"Flur","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}
            2020-06-12 09:03:46.194 - debug: deconz.0 (32442) Code 200: Request succeded get group attributes 6: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"065edf82673cb55fc42c45942b838ad1","id":"6","lights":["21","22","23","24","25","26","27","28","29","34","39","40","41"],"name":"OSRAM Smart Plug","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}
            2020-06-12 09:03:46.209 - debug: deconz.0 (32442) Code 200: Request succeded get group attributes 7: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"76610dce580ab59c5bc8832b2600d854","id":"7","lights":["38"],"name":"Kammer","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}
            2020-06-12 09:03:46.223 - debug: deconz.0 (32442) Code 200: Request succeded get group attributes 10: {"action":{"bri":40,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"f39f09c560a5f1fdb320570c77288136","id":"10","lights":["4","16"],"name":"Küche_BWM","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}
            2020-06-12 09:03:46.236 - debug: deconz.0 (32442) Code 200: Request succeded get group attributes 11: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"f39f09c560a5f1fdb320570c77288136","id":"11","lights":["11","42"],"name":"KlingelAlarm","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}
            2020-06-12 09:03:46.245 - debug: deconz.0 (32442) Code 200: Request succeded get group attributes 5405: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["4"],"etag":"f905166a0919b736a493b28d20bd6d41","id":"5405","lights":["19"],"name":"RWL021 9","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}
            2020-06-12 09:03:46.251 - debug: deconz.0 (32442) Code 200: Request succeded get group attributes 24347: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["3"],"etag":"f39f09c560a5f1fdb320570c77288136","id":"24347","lights":["4","7","10"],"name":"RWL021 8","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}
            2020-06-12 09:03:46.258 - debug: deconz.0 (32442) Code 200: Request succeded get group attributes 26780: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":true,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["2"],"etag":"fdcfa24e611b30da1906cb73c7f4a8fd","id":"26780","lights":["1","2","13","14","17","31"],"name":"RWL021 7","scenes":[],"state":{"all_on":true,"any_on":true},"type":"LightGroup"}
            2020-06-12 09:03:46.603 - debug: deconz.0 (32442) system.adapter.admin.0: logging false
            2020-06-12 09:03:47.754 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2020-06-12 09:03:47.756 - error: deconz.0 (32442) unhandled promise rejection: ids.push is not a function
            2020-06-12 09:03:47.776 - error: deconz.0 (32442) TypeError: ids.push is not a function
            at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:1438:60)
            at runMicrotasks ()
            at processTicksAndRejections (internal/process/task_queues.js:97:5)
            2020-06-12 09:03:47.782 - info: deconz.0 (32442) cleaned everything up...
            2020-06-12 09:03:47.817 - debug: deconz.0 (32442) Websocket connection closed
            2020-06-12 09:03:47.900 - info: deconz.0 (32442) terminating
            2020-06-12 09:03:47.903 - debug: deconz.0 (32442) Plugin sentry destroyed
            2020-06-12 09:03:47.904 - info: deconz.0 (32442) Terminated (NO_ERROR): Without reason
            2020-06-12 09:03:48.488 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2020-06-12 09:03:48.490 - error: host.raspberrypi Caught by controller[1]: TypeError: ids.push is not a function
            2020-06-12 09:03:48.491 - error: host.raspberrypi Caught by controller[1]: at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:1438:60)
            2020-06-12 09:03:48.491 - error: host.raspberrypi Caught by controller[1]: at runMicrotasks ()
            2020-06-12 09:03:48.492 - error: host.raspberrypi Caught by controller[1]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
            2020-06-12 09:03:48.493 - info: host.raspberrypi instance system.adapter.deconz.0 terminated with code 0 (NO_ERROR)
            2020-06-12 09:03:48.494 - info: host.raspberrypi Restart adapter system.adapter.deconz.0 because enabled
            2020-06-12 09:03:52.627 - info: host.raspberrypi "system.adapter.deconz.0" disabled
            2020-06-12 09:04:21.131 - debug: deconz.0 (1246) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2020-06-12 09:04:21.200 - debug: deconz.0 (1246) Objects client ready ... initialize now
            2020-06-12 09:04:21.207 - debug: deconz.0 (1246) Objects create System PubSub Client
            2020-06-12 09:04:21.210 - debug: deconz.0 (1246) Objects create User PubSub Client
            2020-06-12 09:04:21.212 - debug: deconz.0 (1246) Objects client initialize lua scripts
            2020-06-12 09:04:21.237 - debug: deconz.0 (1246) Objects connected to redis: 127.0.0.1:9001
            2020-06-12 09:04:21.252 - debug: deconz.0 (1246) objectDB connected
            2020-06-12 09:04:21.257 - debug: deconz.0 (1246) Redis States: Use Redis connection: 127.0.0.1:9000
            2020-06-12 09:04:21.280 - debug: deconz.0 (1246) States create User PubSub Client
            2020-06-12 09:04:21.289 - debug: deconz.0 (1246) States create System PubSub Client
            2020-06-12 09:04:21.313 - debug: deconz.0 (1246) States connected to redis: 127.0.0.1:9000
            2020-06-12 09:04:21.315 - debug: deconz.0 (1246) statesDB connected
            2020-06-12 09:04:22.268 - debug: deconz.0 (1246) Plugin sentry Initialize Plugin (enabled=true)
            2020-06-12 09:04:22.601 - error: deconz.0 (1246) adapter disabled
            2020-06-12 09:04:22.659 - debug: deconz.0 (1246) Plugin sentry destroyed
            2020-06-12 09:04:22.660 - warn: deconz.0 (1246) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
            2020-06-12 09:04:23.218 - error: host.raspberrypi instance system.adapter.deconz.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
            2020-06-12 09:04:23.220 - info: host.raspberrypi Do not restart adapter system.adapter.deconz.0 because disabled or deleted
            Gehe jetzt erstmal wieder auf 1.3.8 zurück, damit meine BWM wieder funktionieren.
            • Jey Cee
              Jey Cee Developer @dickimo last edited by
              @dickimo danke schon mal.
              • S0NIC
                S0NIC last edited by
                Moin, bei mir wird die 2.0 nicht grün...
                2020-06-14 23:01:36.053 - info: host.ioBroker instance system.adapter.deconz.0 started with pid 17312
                2020-06-14 23:01:37.574 - info: deconz.0 (17312) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.deconz, node: v12.18.0, js-controller: 3.1.5
                2020-06-14 23:01:37.645 - info: deconz.0 (17312) deConz Version: 2.5.75; API version: 1.16.0
                2020-06-14 23:01:37.806 - info: deconz.0 (17312) Code 404: Ressource not found get devices: []
                2020-06-14 23:01:41.994 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2020-06-14 23:01:41.999 - error: deconz.0 (17312) unhandled promise rejection: Cannot read property 'toString' of null
                2020-06-14 23:01:42.010 - error: deconz.0 (17312) TypeError: Cannot read property 'toString' of null
                at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:1401:68)
                at runMicrotasks ()
                2020-06-14 23:01:42.014 - info: deconz.0 (17312) cleaned everything up...
                2020-06-14 23:01:42.099 - info: deconz.0 (17312) terminating
                2020-06-14 23:01:42.101 - info: deconz.0 (17312) Terminated (NO_ERROR): Without reason
                2020-06-14 23:01:42.636 - error: host.ioBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                2020-06-14 23:01:42.636 - error: host.ioBroker Caught by controller[1]: TypeError: Cannot read property 'toString' of null
                2020-06-14 23:01:42.636 - error: host.ioBroker Caught by controller[1]: at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:1401:68)
                2020-06-14 23:01:42.637 - error: host.ioBroker Caught by controller[1]: at runMicrotasks ()
                2020-06-14 23:01:42.637 - error: host.ioBroker Caught by controller[1]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
                2020-06-14 23:01:42.637 - info: host.ioBroker instance system.adapter.deconz.0 terminated with code 0 (NO_ERROR)
                2020-06-14 23:01:42.637 - info: host.ioBroker Restart adapter system.adapter.deconz.0 because enabled
                2020-06-14 23:02:12.660 - info: host.ioBroker instance system.adapter.deconz.0 started with pid 17662
                2020-06-14 23:02:14.393 - info: deconz.0 (17662) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.deconz, node: v12.18.0, js-controller: 3.1.5
                2020-06-14 23:02:14.468 - info: deconz.0 (17662) deConz Version: 2.5.75; API version: 1.16.0
                2020-06-14 23:02:14.589 - info: deconz.0 (17662) Code 404: Ressource not found get devices: []
                2020-06-14 23:02:15.183 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2020-06-14 23:02:15.183 - error: deconz.0 (17662) unhandled promise rejection: Cannot read property 'toString' of null
                2020-06-14 23:02:15.189 - error: deconz.0 (17662) TypeError: Cannot read property 'toString' of null
                at runMicrotasks ()
                2020-06-14 23:02:15.190 - info: deconz.0 (17662) cleaned everything up...
                2020-06-14 23:02:15.222 - info: deconz.0 (17662) terminating
                2020-06-14 23:02:15.223 - info: deconz.0 (17662) Terminated (NO_ERROR): Without reason
                2020-06-14 23:02:15.738 - error: host.ioBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                2020-06-14 23:02:15.739 - error: host.ioBroker Caught by controller[0]: TypeError: Cannot read property 'toString' of null
                2020-06-14 23:02:15.739 - error: host.ioBroker Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:1401:68)
                2020-06-14 23:02:15.739 - error: host.ioBroker Caught by controller[0]: at runMicrotasks ()
                2020-06-14 23:02:15.739 - error: host.ioBroker Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
                2020-06-14 23:02:15.739 - info: host.ioBroker instance system.adapter.deconz.0 terminated with code 0 (NO_ERROR)
                2020-06-14 23:02:15.739 - info: host.ioBroker Restart adapter system.adapter.deconz.0 because enabled
                2020-06-14 23:02:45.761 - info: host.ioBroker instance system.adapter.deconz.0 started with pid 18024
                2020-06-14 23:02:47.211 - info: deconz.0 (18024) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.deconz, node: v12.18.0, js-controller: 3.1.5
                2020-06-14 23:02:47.279 - info: deconz.0 (18024) deConz Version: 2.5.75; API version: 1.16.0
                2020-06-14 23:02:47.406 - info: deconz.0 (18024) Code 404: Ressource not found get devices: []
                2020-06-14 23:02:47.976 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2020-06-14 23:02:47.976 - error: deconz.0 (18024) unhandled promise rejection: Cannot read property 'toString' of null
                2020-06-14 23:02:47.979 - error: deconz.0 (18024) TypeError: Cannot read property 'toString' of null
                at runMicrotasks ()
                2020-06-14 23:02:47.980 - info: deconz.0 (18024) cleaned everything up...
                2020-06-14 23:02:48.030 - info: deconz.0 (18024) terminating
                2020-06-14 23:02:48.031 - info: deconz.0 (18024) Terminated (NO_ERROR): Without reason
                2020-06-14 23:02:48.546 - error: host.ioBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                2020-06-14 23:02:48.547 - error: host.ioBroker Caught by controller[1]: TypeError: Cannot read property 'toString' of null
                2020-06-14 23:02:48.547 - error: host.ioBroker Caught by controller[1]: at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:1401:68)
                2020-06-14 23:02:48.547 - error: host.ioBroker Caught by controller[1]: at runMicrotasks ()
                2020-06-14 23:02:48.547 - error: host.ioBroker Caught by controller[1]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
                2020-06-14 23:02:48.547 - info: host.ioBroker instance system.adapter.deconz.0 terminated with code 0 (NO_ERROR)
                2020-06-14 23:02:48.547 - info: host.ioBroker Restart adapter system.adapter.deconz.0 because enabled
                  Pittini Developer last edited by
                  So, ich teste grad auch mal mit. Ich hab ein frisch aufgesetzten ConBee2 mit Phoscon in ner Proxmox Debian VM laufen. Es wurde in Phoscon EIN Aqara Bewegungsmelder angelernt, sonst nix. (Ich hab aber 50+ Xiaomi Sachen via Gateway(s) laufen und plane, diese nach und nach zum ConBee zu migrieren).
                  Mein Iobrokersystem läuft ebenfalls in ner Proxmox VM und ist soweit auf aktuellem latest Stand, Node.js is noch die 10er.
                  Ich hatte vorher DeConz 1.x kurz testweise installiert, was einwandfrei geklappt hat, fand die Ordnerbezeichnungen und das mir drölfzig Geräte angelegt wurden obwohls nur 1 BWM war ziemlich sch... und bin beim forschen ob das wohl so sein muß u.a. auf diesen Thread gestoßen.
                  Also mal die 2er installiert, alles unauffällig, wurde sofort grün. Bekam auch gleich 2 Geräte angelegt, einmal mein Bewegungsmelder, und dann ein Gerät namens "daylight", was wie ich inzwischen erfahren hab wohl ein virtuelles Gerät ist und sich intern via Astro errechnet.
                  Als DeConz Noob war das für mich erst mal seltsam, da würde ich mir wünschen dass da bei der Namensgebung erkenntlich ist, dass das kein physkalisches Gerät ist. Der Versuch das Gerät im Einstelldialog zu entfernen, verdoppelte jedesmal die komplette Geräteliste, möglicherweise wird da beim refresh angehängt statt zu überschreiben. Ich hab das dann einfach nicht gespeichert, war aber eben ungewöhliches Verhalten.
                  Dann zum Bewegungsmelder, ich hab keine Ahnung wofür bestimmte Datenpunkte stehen (und finde trotz Suche keinerlei Doku dazu), aber einige sind ja selbserklärend, aktualisiert hat soweit alles sauber..
                  Als nächstes hab ich mal direkt aus der Objektliste raus (deconz.0.Gateway_info.network_open auf true) versucht 2 weitere Geräte (Ein Aqara TF Kontakt und nochn Bwm) anzulernen. Das hat soweit prima geklappt.
                  Was sich mir nicht erschließt, ist warum der TFK als "OpenClose 4" und der Bwm als "LightLevel 5" angelegt wurde bzw, was den die Geräte 0,1,2,3 sind (eins davon ist der erste Bwm, schon klar)? Warum der erste Bwm, "Bewegungsmelder" und der 2te "LightLevel" heißt, und was "Lightlevel mit nem Bewegungsmelder zu tun hat...unklar? Das zudem die Numerierung über alle Sensoren geht find ich persönlich unglücklich, das würde ich mir pro Typ wünschen, also Bwm 0-1-2-3-... und OpenClose 0-1-2-3-...
                  Gut, soviel zum ersten Eindruck, werde mich bei Auffälligkeiten melden.
                    Wildbill last edited by
                    @Pittini
                    Das virtuelle Gerät daylight legt nicht der Adapter an, das ist schon in Deconz vorhanden. Da wirst Du nicht viel machen können.
                    Zu der menge an Datenpunkten: Ich habe Ikea-Bewegungsmelder und sehe bei denen eigentlich nur sinnvolle Datenpunkte:
                    Entweder senden Deine da viele "unnütze" Datenpunkte raus, oder der Adapter macht in Version 2.0 irgendwas anders. Ich bin noch auf der 1.x und da ist eigentlich alles, wie es sein soll. Teste doch mal ein anderes Gerät (Lampe z.B.) und schau, wie es da aussieht.
                    Gruss, Jürgen
                    • Jey Cee
                      Jey Cee Developer @Pittini last edited by
                      @Pittini mach mal screenshots von den Objekten.
                      @Pittini sagte in Test Adapter deConz v2.0.x:
                      Das liegt daran das die sensoren in deConz als seperate Geräte geführt werden und jedes hat sein eigenen Namen. Deshalb wird einfach einer Namen genommen.
                      Du kannst die Geräte so bennen wie du willst, das wird dann auch übernommen. Dabei ist es egal ob in ioBroker oder Phoscon.
                        Pittini Developer @Jey Cee last edited by
                        @Jey-Cee sagte in Test Adapter deConz v2.0.x:
                        • Falk Pe.
                          Falk Pe. last edited by
                          Wollte Grade nach langem nicht benutzen mein Ikea Tradfri Leuchtmittel per XY bedienen, allerdings funktionierte es nicht mehr.
                          Hatte die aktuelle Deconz 1.3.9 installiert. Da es schonmal funktionierte, habe ich mich jetzt langsam durch die Versionen getestet, und bin bei der 1.3.3 gelandet in der es wieder funktioniert.
                          Ist das manchmal ein Bug?
                          E Jey Cee 2 Replies Last reply Reply Quote 0
                            e-s @Falk Pe. last edited by
                            @Falk-Pe
                            Du musst den xy Wert jetzt als array übergeben.
                            • Jey Cee
                              Jey Cee Developer @Falk Pe. last edited by
                              @Falk-Pe das hier ist das falsche Thema fürdein Problem. Bitte beim nächsten mal in einem Passenden fragen oder ein neues aufmachen.
                              Du musst alle Objekte löschen und den Adapter neu starten dann läuft das wieder.
                                Markus84 @Jey Cee last edited by
                                @Jey-Cee Aus dem Forum gewinne ich gerade den Eindruck, dass manch einer überlegt auf den Zigbee Adapter zu wechseln, da dieser inzwischen auch den Conbee II unterstützt. Das kann ich ehrlich gesagt nicht nachvollziehen, weil dein Adapter wirklich super funktioniert und ich bei einem Defekt einfach den Stick tauschen kann und ein Backup wieder einspielen kann. Letzteres scheint mit dem Zigbee Adapter nicht möglich zu sein und ist daher alleine zumindest für mich schon ein K.O. Kriterium...
                                Darf ich davon ausgehen, dass die Unterstützung des Conbee II im Zigbee Adapter auf die weitere Entwicklung des deConz Adapters keinen Einfluss hat? Oder ist geplant die Projekte zu verschmelzen (was aufgrund der unterschiedlichen Ansätze der Adapter nach meinem technischen Verständnis gar nicht möglich ist)?
                                siggi85 Jey Cee 2 Replies Last reply Reply Quote 0
                                • siggi85
                                  siggi85 @Markus84 last edited by
                                  @Markus84 sagte in Test Adapter deConz v2.0.x:
                                  Interessante Frage! Eigentlich ist ja gedacht, dass es eine neue Version geben wird, die auf den Hardwareadressen der Zigbee Geräte diese in den Objekten gruppiert, statt auf der laufenden ID innerhalb von deconz.
                                  Zusätzlich zum zigbee Adapter unterstützt wohl auch die neue beta des hue-extended den Conbee II. Bin gespannt wo das ganze endet.
                                  Bin auch ganz zufrieden mit dem deconz Adapter und habe bisher keinen Bedarf zu wechseln.
                                  • Jey Cee
                                    Jey Cee Developer @Markus84 last edited by
                                    Ja davon kannst du ausgehen. Die beiden Adapter unterscheiden sich Grundsätzlich darin wie sie funktionieren, das würde also keinen sinn machen.
                                    @siggi85 sagte in Test Adapter deConz v2.0.x:
                                    Macht die v2 ja auch. Muss aber noch ein paar Fehler untersuchen die gemeldet wurden.
                                    Der Hue Adapter und auch der Hue-extended haben deConz schon immer ansprechen können, da deConz eine Hue Kompatible API hat. Aber deConz unterstütz halt viel mehr Hardware als Hue und so dürfte in den Adaptern nicht alles Abgebildet werden.
                                    • Jey Cee
                                      Jey Cee Developer @S0NIC last edited by
                                      @S0NIC kannst du mal mit der 1.3.9 ein log erstellen. Bitte das Log Level der Instanz auf debug stellen und dann Log Herunterladen und hier posten.
                                      Scheint als Gebe es hier Ausreißer bei den MAC Addressen zu geben. Aber um das weiter zu Untersuchen brauche ich eben das Log.
                                      • Jey Cee
                                        Jey Cee Developer last edited by Jey Cee
                                        Nicht Installieren das ist noch irgendwo ein großer Bug, den ich auf dem Entwicklersystem nicht hatte.
                                        So die V2 ist jetzt im Hauptzweig und läuft bei mir auf dem Produktiv System.
                                        Installiert werden kann sie momentan nur über Github, Link im ersten Beitrag angepasst.
                                        S0NIC 1 Reply Last reply Reply Quote 0
                                          Kugelkopf last edited by
                                          Hallo @Jey-Cee!
                                          Aktuell bekomme ich in ioBroker ein Update von v 1.3.9 auf 1.3.10 angeboten. Jedoch scheint es mir so, als wenn dann ein Update auf Version 2.0.1 vollzogen wird. Ist das korrekt? Weil unter diesen Umständen denken sicherlich viele, dass sie weiterhin mit dem alten ID System arbeiten können und noch nicht auf das neue MAC System updaten. Wenn sie dann Updaten, stehen sie auf einmal vor einem nicht mehr funktionierenden System..
                                          Evtl. Wäre es sehr wichtig, wenn du im Changelog auch nochmal für alle die nicht deinen Beiträgen im Forum folgen, erwähnst, dass es sich um Breaking Changes handelt.
                                          Viele Grüße, und vielen Dank für diesen tollen Adapter! 😃
                                          • Jey Cee
                                            Jey Cee Developer @Kugelkopf last edited by
                                            @Kugelkopf leider verstehe ich deinen Gedanken gang nicht. Hast du die 1.3.10 installiert und Probleme?
                                            Die 1.3.10 ist auf npm und kommt über latest, die 2.0.2 gibt es nur von Github.
                                            1.3.10 gibt es nur weil in deConz .78 eine Änderung drin ist die größere Probleme verursacht.
                                            79.9k
                                            conbee deconz phoscon
                                            38
                                            196
                                            21736
