    5. Blockly Zähler reset spinnt
    • Aphofis
      Aphofis last edited by
      ist es möglich die Datums Angabe auch hier zu integrieren???
        <variables>
          <variable id="K.oz,4#UMgx/|!4vK/!}">Start Datum</variable>
        </variables>
        <block type="schedule" id="[H5qz$AU(jK-g*ohRGew" x="37" y="588">
          <field name="SCHEDULE">0 18 * * *</field>
            <block type="variables_set" id="t:07|=Y]Z5[Y{dE)b=Wr">
              <field name="VAR" id="K.oz,4#UMgx/|!4vK/!}">Start Datum</field>
                <block type="lists_split" id="p|s;MB5#-TA#_9w0Cc6A">
                  <mutation mode="SPLIT"></mutation>
                  <field name="MODE">SPLIT</field>
                  <value name="INPUT">
                    <block type="get_value" id="`[ncv(,}hRD8H=@Gbbal">
                      <field name="OID">Aqua_Control.0.System.Reaktoren_Datum</field>
                  <value name="DELIM">
                    <shadow type="text" id=":E?qi1Qh:_V-7F:wfz)N">
                      <field name="TEXT">.</field>
                <block type="variables_set" id="D_?.J%U)+DwN;%w?,H+D">
                    <block type="text_join" id="bKmk8!W6Qfif--ETUyf;">
                      <mutation items="5"></mutation>
                      <value name="ADD0">
                        <block type="lists_getIndex" id="EW9`4zy[fngnWwTTrz[f">
                            <block type="variables_get" id="8%36kyqEKIkba3QjoXFu">
                          <value name="AT">
                            <block type="math_number" id="G!UqN.${lfbX?9?fC(]7">
                              <field name="NUM">3</field>
                      <value name="ADD1">
                        <block type="text" id="175Fww}yzf/:Li=:7EFZ">
                          <field name="TEXT">-</field>
                      <value name="ADD2">
                        <block type="lists_getIndex" id="7=%sMFe1TfVXiENyv])X">
                            <block type="variables_get" id="B%zI(=|@mQ$E!;xWQ53/">
                          <value name="AT">
                            <block type="math_number" id="L?@Yy0.FrC|HpAD,19.:">
                              <field name="NUM">2</field>
                      <value name="ADD3">
                        <block type="text" id=";eW0_/sun%t5@K5bJ2Nf">
                      <value name="ADD4">
                        <block type="lists_getIndex" id="(khUT%*jN`U6hCz;|u?/">
                            <block type="variables_get" id="y-r;mKOl[yuUNAI9S%cx">
                          <value name="AT">
                            <block type="math_number" id="^CoREjH=BLQx+w[+VBvn">
                              <field name="NUM">1</field>
                    <block type="variables_set" id="l$Ya))eB-9)DbmW`$8f]">
                        <block type="convert_from_date" id=";sg/oP`v/X{GBst#`iwE">
                          <field name="OPTION">object</field>
                            <block type="variables_get" id="|G[Nx#SHgEXX9z@KaO)I">
                        <block type="controls_if" id="(`^{GKOFHmiu=!*~V}3C">
                            <block type="logic_compare" id="ICTqO:*ALjLX2g@Mo`U~">
                              <field name="OP">GTE</field>
                                <block type="time_get" id="v9.z:sj3U1CgjlI[pOff">
                                <block type="math_arithmetic" id=":/*YP!I6tE30OrDM_{$Y">
                                  <field name="OP">ADD</field>
                                    <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="iaLFl0tm+gwBmIB;^Fa@">
                                    <block type="variables_get" id="@v*2#Igz]tqz4ae~_$Ni">
                                    <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id=";@a8$1DnJrvd5G`#eIrh">
                                    <block type="math_arithmetic" id="vf6KSTN}bXy.4ntVdSfI">
                                        <shadow type="math_number" id="xw[OCp^B6+7i^ggq232o">
                                          <field name="NUM">720</field>
                                        <shadow type="math_number" id="JF?T)=jlgQTMcXF7V0hP">
                                          <field name="NUM">3600000</field>
                            <block type="telegram" id="?2YC.60?J)M%@bPzt_qe">
                              <field name="INSTANCE">.0</field>
                              <field name="LOG"></field>
                              <value name="MESSAGE">
                                <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="Ae-*h@qEA(|^L^IU-o-J">
                                <block type="text_join" id="p/`G_kh+j|GClHdd8-(,">
                                  <value name="ADD0">
                                    <block type="text" id="JZGB0zZ;([-oQZBUb]rL">
                                      <field name="TEXT">Reaktoren Absorber Wechsel steht an</field>
                                  <value name="ADD1">
                                    <block type="text_newline" id="6__.:CFUXypx8vvV~C9,">
                                      <field name="Type">\n</field>
                                  <value name="ADD2">
                                    <block type="text" id="0T$YX467PDa]rSz$=7z!">
                                      <field name="TEXT">Reaktoren müßen neu bestückt werden</field>
                                <block type="control" id="{)KwDaVN%@R)p;1oue!R">
                                  <field name="OID">alexa2.0.Echo-Devices.G090LV0371040175.Commands.speak</field>
                                    <block type="text_join" id="DFgL?D_|.Lx#djY;*0^z">
                                      <value name="ADD0">
                                        <block type="text" id="!ADXURU^temtR1(UjD5w">
                                          <field name="TEXT">Reaktoren Absorber Wechsel steht an, Du musst,, Deine Reaktoren neu bestücken</field>
                                    <block type="control" id="bztvKmxJ_0x-M8s`LVt@">
                                      <field name="OID">Aqua_Control.0.VIS.Meldungen.Info</field>
                                        <block type="text_join" id="yLx@~$=p(^7;}8A4;}|7">
                                          <value name="ADD0">
                                            <block type="text" id="AYR_#o]I(3]hgGWD])^=">
                                          <value name="ADD1">
                                            <block type="text_newline" id="iAz.I4F*nHr_Qa_dmB;]">
                                          <value name="ADD2">
                                            <block type="text" id="3k/#fXZzf#S^/MlM;`S1">
        paul53 @Aphofis last edited by
        @Aphofis sagte:
        Ja, auf die gleiche Weise wie hier.
        Aphofis 1 Reply Last reply Reply Quote 0
        • Aphofis
          Aphofis @paul53 last edited by
          also so:
            <variables>
              <variable id="=hdidY4}B|L;6..|G=D_">erster Tag</variable>
              <variable id="+G_CFrCr9TLsYxNuK2Kc">Datum</variable>
            </variables>
                          <value name="ADD0">
                              <value name="AT">
                          <value name="ADD1">
                          <value name="ADD2">
                              <value name="AT">
                          <value name="ADD3">
                          <value name="ADD4">
                              <value name="AT">
                                      <value name="ADD0">
                                          <value name="ADD0">
                                          <value name="ADD1">
                                          <value name="ADD2">
                                        <block type="controls_if" id="/(OQbd.ZC`Lhn`/r[n!m">
                                            <block type="logic_negate" id="e@rn3Zf(2;@lSZnOl)Of">
                                              <value name="BOOL">
                                                <block type="variables_get" id="uJ$K~j9pi1foBShY?CES">
                                                  <field name="VAR" id="=hdidY4}B|L;6..|G=D_">erster Tag</field>
                                            <block type="variables_set" id="Y#29kGTW*rsQRU42Evyc">
                                              <field name="VAR" id="+G_CFrCr9TLsYxNuK2Kc">Datum</field>
                                                <block type="time_get" id="jM1q.*:.:O~0rlB,Y#MJ">
                                                  <field name="OPTION">DD.MM.</field>
                                                <block type="variables_set" id="1=ZTTn@Uog~Xssww(7Us">
                                                    <block type="logic_boolean" id="V`lxG5fb#+%5T4lp9hYE">
                                                  <mutation items="6"></mutation>
                                                  <value name="ADD0">
                                                  <value name="ADD1">
                                                  <value name="ADD2">
                                                    <block type="text" id="_%u7ANuZ^]KYvO4dkQ`s">
                                                      <field name="TEXT">Wechsel steht seid dem: </field>
                                                  <value name="ADD3">
                                                    <block type="variables_get" id="lU/G,/@iO?~s]rvkYJ^V">
                                                  <value name="ADD4">
                                                    <block type="text" id="3doJLLAR1#4K[AebE[.O">
                                                      <field name="TEXT"> an</field>
                                                  <value name="ADD5">
                              <statement name="ELSE">
                                <block type="variables_set" id="Nm/JI$blRQ#]EgIsmMl7">
                                    <block type="logic_boolean" id="NqGA;/7*k%!AtTj|6w@w">
            @Aphofis sagte:
            also so:
            Ja.
            Aphofis 2 Replies Last reply Reply Quote 1
            • Aphofis
              @paul53 OK dann versuche ich das so!
              Vielen Dank
              • Aphofis
                Also Telegram gibt das Datum korrekt aus! nur Alexa sagt das Datum nicht, woran kann das liegen?
                  @Aphofis sagte:
                  Ich sehe nicht, dass das Datum an Alexa übergeben wird. Wenn die Alexa-Ausgabe so erweitert wird, muss Alexa aufgerufen werden, nachdem das Datum in die Variable datum geschrieben wurde.
                  • Aphofis
                    @paul53 ups Sorry
                      <variables>
                      </variables>
                                    <value name="ADD0">
                                        <value name="AT">
                                    <value name="ADD1">
                                    <value name="ADD2">
                                        <value name="AT">
                                    <value name="ADD3">
                                    <value name="ADD4">
                                        <value name="AT">
                                                <value name="ADD0">
                                                    <field name="TEXT">Reaktoren Absorber Wechsel steht seid dem,,</field>
                                                <value name="ADD1">
                                                  <block type="variables_get" id="J=0tV1{ud=lca,7DB6+L">
                                                <value name="ADD2">
                                                  <block type="text" id="FS#QNqjv.,hMV2kf*YZU">
                                                    <field name="TEXT"> an,, Du musst,, Deine Reaktoren neu bestücken</field>
                                                    <value name="ADD0">
                                                        <field name="TEXT">Reaktoren Absorber Wechsel steht seid dem </field>
                                                    <value name="ADD1">
                                                    <value name="ADD2">
                                                      <block type="variables_get" id="moO?0hiF?607[@F#[Zuk">
                                                    <value name="ADD3">
                                                      <block type="text" id="Z4/g17s5*8l[qDMtw~G7">
                                                    <value name="ADD4">
                                                        <value name="BOOL">
                                                            <value name="ADD0">
        <field name="TEXT">Reaktoren Absorber Wechsel steht seid dem</field>
                                                            <value name="ADD1">
                                                            <value name="ADD2">
                                                            <value name="ADD3">
                                                            <value name="ADD4">
                                                              <block type="text_newline" id="FExw[XZ@~t^r(mcZUQ]}">
                                                            <value name="ADD5">
                      paul53 @Aphofis last edited by paul53
                      @Aphofis sagte:
                      ups Sorry
                      Wie schon geschrieben: Erst die Variable Datum setzen, dann ausgeben (steuere).
                      Aphofis 2 Replies Last reply Reply Quote 0
                      • Aphofis
                        Ich teste das heute Abend mal!
                        • Aphofis
                          funktioniert schon mal so weit nur alexa sagt seid dem 18 komma 0 6 kann alexa kein normales datum ansagen !?
                          1032
