Adapter: ebus
@Hiltex Danke für Deine genauen Anweisungen !
Ich habe jetzt die Config-Dateien nach Deinen Anweisungen auf mein System geladen und die ebusd angepasst.
Es läuft jetzt im Prinzip alles wie vorher und zusätzlich werden Daten von VMS ausgegeben bzw. sind abrufbar über Telnet. Hier eine Auszug der ... 8890/data}, "vms": { "messages": { "ASIDetected": { "name": "ASIDetected", "passive": false, "write": false, "lastup": 0 }, "BufferPumpPower": { "name": "BufferPumpPower", "passive": false, "write": false, "lastup": 0 }, "CountryZone": { "name": "CountryZone", "passive": false, "write": false, "lastup": 0 }, "CurrentASCStateforASI": { "name": "CurrentASCStateforASI", "passive": false, "write": false, "lastup": 0 }, "CurrentASCStateforExternals": { "name": "CurrentASCStateforExternals", "passive": false, "write": false, "lastup": 0 }, "currenterror": { "name": "currenterror", "passive": false, "write": false, "lastup": 0 }, "CurrentFlow": { "name": "CurrentFlow", "passive": false, "write": false, "lastup": 0 }, "CurrentSystemMode": { "name": "CurrentSystemMode", "passive": false, "write": false, "lastup": 0 }, "CurrentVPMLoadingMode": { "name": "CurrentVPMLoadingMode", "passive": false, "write": false, "lastup": 0 }, "Date": { "name": "Date", "passive": false, "write": false, "lastup": 0 }, "DateAndTimeIsSet": { "name": "DateAndTimeIsSet", "passive": false, "write": false, "lastup": 0 }, "errorhistory": { "name": "errorhistory", "passive": false, "write": false, "lastup": 0 }, "ExternalHcRequest": { "name": "ExternalHcRequest", "passive": false, "write": false, "lastup": 0 }, "ExternalHcTempDesired": { "name": "ExternalHcTempDesired", "passive": false, "write": false, "lastup": 0 }, "ExternalHwcRequest": { "name": "ExternalHwcRequest", "passive": false, "write": false, "lastup": 0 }, "ExternalHwcTempDesired": { "name": "ExternalHwcTempDesired", "passive": false, "write": false, "lastup": 0 }, "FlowSensorFrequency": { "name": "FlowSensorFrequency", "passive": false, "write": false, "lastup": 0 }, "ForceStartSolPumpKick": { "name": "ForceStartSolPumpKick", "passive": false, "write": false, "lastup": 0 }, "InternalHcTempDesired": { "name": "InternalHcTempDesired", "passive": false, "write": false, "lastup": 0 }, "InternalHwcTempDesired": { "name": "InternalHwcTempDesired", "passive": false, "write": false, "lastup": 0 }, "MonitorMatlabLast5minSolAverage": { "name": "MonitorMatlabLast5minSolAverage", "passive": false, "write": false, "lastup": 0 }, "MonitorMatlabState": { "name": "MonitorMatlabState", "passive": false, "write": false, "lastup": 0 }, "MonitorOverheatState": { "name": "MonitorOverheatState", "passive": false, "write": false, "lastup": 0 }, "Ntc1Sensor": { "name": "Ntc1Sensor", "passive": false, "write": false, "lastup": 1592139005, "zz": 6, "fields": { "temp": {"value": 36.12}, "sensor": {"value": "ok"} } }, "Ntc2Sensor": { "name": "Ntc2Sensor", "passive": false, "write": false, "lastup": 1592139005, "zz": 6, "fields": { "temp": {"value": 0.00}, "sensor": {"value": "ok"} } }, "RequestForExternalDateTimeSetting": { "name": "RequestForExternalDateTimeSetting", "passive": false, "write": false, "lastup": 0 }, "RunTimeBufferPumpHours": { "name": "RunTimeBufferPumpHours", "passive": false, "write": false, "lastup": 0 }, "RunTimeBufferPumpMinutes": { "name": "RunTimeBufferPumpMinutes", "passive": false, "write": false, "lastup": 0 }, "RunTimePump1Hours": { "name": "RunTimePump1Hours", "passive": false, "write": false, "lastup": 0 }, "RunTimePump1Minutes": { "name": "RunTimePump1Minutes", "passive": false, "write": false, "lastup": 0 }, "SolPumpPower": { "name": "SolPumpPower", "passive": false, "write": false, "lastup": 1592138701, "zz": 6, "fields": { "power": {"value": 0} } }, "SolPumpRelay": { "name": "SolPumpRelay", "passive": false, "write": false, "lastup": 0 }, "Time": { "name": "Time", "passive": false, "write": false, "lastup": 0 }, "Variante": { "name": "Variante", "passive": false, "write": false, "lastup": 0 }, "YieldCurrentDay": { "name": "YieldCurrentDay", "passive": false, "write": false, "lastup": 0 }, "YieldTotal": { "name": "YieldTotal", "passive": false, "write": false, "lastup": 0 } } }, "global": { "version": "3.4.v3.4-16-g9e152da", "updatecheck": "revision v3.4 available, vaillant/08.bai.csv: different version available, vaillant/15.700.csv: different version available, vaillant/bai.0010015600.inc: different version available, vaillant/hcmode.inc: different version available", "signal": true, "symbolrate": 24, "maxsymbolrate": 129, "minarbitrationmicros": 21, "maxarbitrationmicros": 79, "minsymbollatency": 6, "maxsymbollatency": 39, "qq": 49, "reconnects": 0, "masters": 4, "messages": 669, "lastup": 1592139293 } }Jetzt habe ich im iobroker Adapter die Ntc1Sensor eingeben, die werden auch abgefragt und im Log der wert ausgegeben.
Jedoch NICHT unter Objekte! Der Ordner vms ist ohne Werte.
Hier ein Auszug der iobroker Log Datei:ebus.0 2020-06-14 14:50:06.571 info (2588) Terminated (NO_ERROR): Without reason ebus.0 2020-06-14 14:50:06.569 info (2588) all history done (exit) ebus.0 2020-06-14 14:50:06.568 debug (2588) delete ebus.0 2020-06-14 14:50:06.566 debug (2588) delete ebus.0 2020-06-14 14:50:06.148 info (2588) all http done ebus.0 2020-06-14 14:50:05.971 debug (2588) oData {"700":{"messages":{"AdaptHeatCurve":{"name":"AdaptHeatCurve","passive":false,"write":false,"lastup":0},"BankHolidayEndPeriod":{"name":"BankHolidayEndPeriod","passive":false,"write":false ebus.0 2020-06-14 14:50:05.937 debug (2588) request data from http://192.168.178.47:8890/data ebus.0 2020-06-14 14:50:05.935 debug (2588) all telnet done ebus.0 2020-06-14 14:50:05.934 debug (2588) received usage: read [-f] [-m SECONDS] [-s QQ] [-d ZZ] [-c CIRCUIT] [-p PRIO] [-v|-V] [-n|-N] [-i VALUE[;VALUE]*] NAME [FIELD[.N]] or: read [-f] [-m SECONDS] [-s QQ] [-d ZZ] [-v|-V] [-n|-N] ebus.0 2020-06-14 14:50:05.933 debug (2588) received 0.00;ok for Ntc2Sensor ebus.0 2020-06-14 14:50:05.776 debug (2588) received 36.12;ok for Ntc1Sensor ebus.0 2020-06-14 14:50:05.626 debug (2588) received no for HwcDemand ebus.0 2020-06-14 14:50:05.472 debug (2588) received 50 for HwcTempDesired ebus.0 2020-06-14 14:50:05.269 debug (2588) received 38.56;ok for HwcTemp ebus.0 2020-06-14 14:50:05.113 debug (2588) received 43.5 for HwcStorageTemp ebus.0 2020-06-14 14:50:04.919 debug (2588) received 43.44;ok for StorageExitTemp ebus.0 2020-06-14 14:50:04.700 debug (2588) received 43.81;ok for StorageTemp ebus.0 2020-06-14 14:50:04.495 debug (2588) received off for Flame ebus.0 2020-06-14 14:50:04.342 debug (2588) received 19 for z1NightTemp ebus.0 2020-06-14 14:50:04.152 debug (2588) received 23 for z1DayTemp ebus.0 2020-06-14 14:50:03.959 debug (2588) received 35.5 for Hc1FlowTemp ebus.0 2020-06-14 14:50:03.766 debug (2588) received 1.7 for WaterPressure ebus.0 2020-06-14 14:50:03.576 debug (2588) received 0 for z1ValveStatus ebus.0 2020-06-14 14:50:03.378 debug (2588) received 23.1875 for z1RoomTemp ebus.0 2020-06-14 14:50:03.175 debug (2588) received 0.0 for z1ActualRoomTempDesired ebus.0 2020-06-14 14:50:02.639 debug (2588) received 23.625 for DisplayedOutsideTemp ebus.0 2020-06-14 14:50:01.869 debug (2588) telnet connected ebus.0 2020-06-14 14:50:01.848 debug (2588) connect telnet to IP 192.168.178.47 port 8888 ebus.0 2020-06-14 14:50:01.847 debug (2588) to poll ctr 18 vals: DisplayedOutsideTemp,z1ActualRoomTempDesired,z1RoomTemp,z1ValveStatus,WaterPressure,Hc1FlowTemp,z1DayTemp,z1NightTemp,Flame,StorageTemp,StorageExitTemp,HwcStorageTemp,HwcT ebus.0 2020-06-14 14:50:01.817 debug (2588) init common variables ebus.0 2020-06-14 14:50:01.813 debug (2588) init variables ebus.0 2020-06-14 14:50:01.812 debug (2588) start with interface ebusd ebus.0 2020-06-14 14:50:01.811 debug (2588) set timeout to 60 sec ebus.0 2020-06-14 14:50:01.771 info (2588) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.ebus, node: v10.19.0, js-controller: 3.1.4Und so sieht es unter Objekte aus:
In der Statusansicht wird das Objekt gar nicht angezeigt.
Kann mir jemand helfen, dass die Datenpunkte angezeigt werden?
Danke.
Jetzt habe ich den ebus Adapter de- und dann wieder installiert, jetzt bekomme ich unter Objekte gar keine Werte mehr angezeigt
ebus Adapter 2.0.0
Jetzt wollte ich auf die Version 1.0.0 zurück wechseln, aber wie?
@Rene_HM
Hallo Rene,
Habe Schwierigkeiten mit der ebus Version 2.0.0
Es werden in Objekte keine Werte mehr angezeigt, nach der NEU Installation des Adapter 2.0.0 gar nichts mehr.Hier der Auszug aus der LOG Datei des ioBroker.
host.raspberrypi 2020-06-15 19:35:03.583 info instance system.adapter.ebus.0 terminated with code 0 (NO_ERROR) ebus.0 2020-06-15 19:35:03.071 info (18102) Terminated (NO_ERROR): Without reason ebus.0 2020-06-15 19:35:03.069 info (18102) all history done (exit) ebus.0 2020-06-15 19:35:03.068 debug (18102) delete ebus.0 2020-06-15 19:35:03.066 debug (18102) delete sql.0 2020-06-15 19:35:02.972 info (18899) disabled logging of ebus.0.700.messages.DisplayedOutsideTemp.fields.tempv.value ebus.0 2020-06-15 19:35:02.925 info (18102) all http done ebus.0 2020-06-15 19:35:02.778 debug (18102) oData {"700":{"messages":{"AdaptHeatCurve":{"name":"AdaptHeatCurve","passive":false,"write":false,"lastup":0},"BankHolidayEndPeriod":{"name":"BankHolidayEndPeriod","passive":false,"write":fals ebus.0 2020-06-15 19:35:02.716 debug (18102) request data from http://192.168.178.47:8890/data ebus.0 2020-06-15 19:35:02.713 debug (18102) all telnet done ebus.0 2020-06-15 19:35:02.711 debug (18102) received 33.31;ok for Ntc1Sensor ebus.0 2020-06-15 19:35:02.559 debug (18102) received 23.4375 for DisplayedOutsideTemp ebus.0 2020-06-15 19:35:01.530 debug (18102) telnet connected ebus.0 2020-06-15 19:35:01.509 debug (18102) connect telnet to IP 192.168.178.47 port 8888 ebus.0 2020-06-15 19:35:01.508 debug (18102) to poll ctr 2 vals: DisplayedOutsideTemp,Ntc1Sensor org DisplayedOutsideTemp,Ntc1Sensor org length 31 ebus.0 2020-06-15 19:35:01.478 debug (18102) init common variables ebus.0 2020-06-15 19:35:01.473 debug (18102) init variables ebus.0 2020-06-15 19:35:01.473 debug (18102) start with interface ebusd ebus.0 2020-06-15 19:35:01.472 debug (18102) set timeout to 60 sec ebus.0 2020-06-15 19:35:01.444 info (18102) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.ebus, node: v10.19.0, js-controller: 3.1.4 host.raspberrypi 2020-06-15 19:35:00.015 info instance system.adapter.ebus.0 started with pid 18102 -
@Jui sagte in Adapter: ebus:
Das log hier sieht nicht schlecht aus, aus meiner Sicht macht der Adapter was er soll... kannst du mal alle Objekte von ebus.0 löschen und dann beobachten, welche Objekte der Adapter wieder anlegt? bitte davon mal einen screenshoot posten....
Danke für Deine Antwort und Hilfe!
Habe die Objekte gelöscht, danach kam das im log:host.raspberrypi 2020-06-16 17:15:02.476 info instance system.adapter.ebus.0 terminated with code 0 (NO_ERROR) sql.0 2020-06-16 17:15:02.239 info (16559) disabled logging of ebus.0.700.messages.DisplayedOutsideTemp.fields.tempv.value ebus.0 2020-06-16 17:15:02.016 warn (8746) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:15:02.016 warn (8746) Object ebus.0.global.lastup is invalid: obj.type has to exist ebus.0 2020-06-16 17:15:02.015 warn (8746) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:15:02.014 warn (8746) Object ebus.0.global.messages is invalid: obj.type has to exist ebus.0 2020-06-16 17:15:02.013 warn (8746) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:15:02.013 warn (8746) Object ebus.0.global.masters is invalid: obj.type has to exist ebus.0 2020-06-16 17:15:02.012 warn (8746) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:15:02.011 warn (8746) Object ebus.0.global.reconnects is invalid: obj.type has to exist ebus.0 2020-06-16 17:15:02.011 warn (8746) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:15:02.010 warn (8746) Object ebus.0.global.qq is invalid: obj.type has to exist ebus.0 2020-06-16 17:15:02.009 warn (8746) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:15:02.009 warn (8746) Object ebus.0.global.maxsymbollatency is invalid: obj.type has to exist ebus.0 2020-06-16 17:15:02.008 warn (8746) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:15:02.007 warn (8746) Object ebus.0.global.minsymbollatency is invalid: obj.type has to exist ebus.0 2020-06-16 17:15:02.006 warn (8746) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:15:02.006 warn (8746) Object ebus.0.global.maxarbitrationmicros is invalid: obj.type has to exist ebus.0 2020-06-16 17:15:02.005 warn (8746) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:15:02.004 warn (8746) Object ebus.0.global.minarbitrationmicros is invalid: obj.type has to exist ebus.0 2020-06-16 17:15:02.003 warn (8746) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:15:02.003 warn (8746) Object ebus.0.global.maxsymbolrate is invalid: obj.type has to exist ebus.0 2020-06-16 17:15:02.002 warn (8746) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:15:02.001 warn (8746) Object ebus.0.global.symbolrate is invalid: obj.type has to exist ebus.0 2020-06-16 17:15:01.952 info (8746) Terminated (NO_ERROR): Without reason ebus.0 2020-06-16 17:15:01.950 info (8746) all history done (exit) ebus.0 2020-06-16 17:15:01.949 debug (8746) delete ebus.0 2020-06-16 17:15:01.947 debug (8746) delete ebus.0 2020-06-16 17:15:01.903 info (8746) all http done ebus.0 2020-06-16 17:15:01.734 debug (8746) oData {"700":{"messages":{"AdaptHeatCurve":{"name":"AdaptHeatCurve","passive":false,"write":false,"lastup":0},"BankHolidayEndPeriod":{"name":"BankHolidayEndPeriod","passive":false,"write":false ebus.0 2020-06-16 17:15:01.703 debug (8746) request data from http://192.168.178.47:8890/data ebus.0 2020-06-16 17:15:01.701 debug (8746) all telnet done ebus.0 2020-06-16 17:15:01.700 debug (8746) received 38.94;ok for Ntc1Sensor ebus.0 2020-06-16 17:15:01.534 debug (8746) received 24.25 for DisplayedOutsideTemp ebus.0 2020-06-16 17:15:01.342 debug (8746) telnet connected ebus.0 2020-06-16 17:15:01.323 debug (8746) connect telnet to IP 192.168.178.47 port 8888 ebus.0 2020-06-16 17:15:01.322 debug (8746) to poll ctr 2 vals: DisplayedOutsideTemp,Ntc1Sensor org DisplayedOutsideTemp,Ntc1Sensor org length 31 ebus.0 2020-06-16 17:15:01.294 debug (8746) init common variables ebus.0 2020-06-16 17:15:01.290 debug (8746) init variables ebus.0 2020-06-16 17:15:01.289 debug (8746) start with interface ebusd ebus.0 2020-06-16 17:15:01.289 debug (8746) set timeout to 60 sec ebus.0 2020-06-16 17:15:01.263 info (8746) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.ebus, node: v10.19.0, js-controller: 3.1.4 host.raspberrypi 2020-06-16 17:15:00.016 info instance system.adapter.ebus.0 started with pid 8746 fritzdect.0 2020-06-16 17:14:06.644 info (15925) Comet ID: 133560913928 identified for command (mode) : 1 fritzdect.0 2020-06-16 17:14:06.636 info (15925) Comet ID: 133560851704 identified for command (mode) : 0 sql.0 2020-06-16 17:10:03.434 info (16559) disabled logging of ebus.0.700.messages.DisplayedOutsideTemp.fields.tempv.value host.raspberrypi 2020-06-16 17:10:03.364 info instance system.adapter.ebus.0 terminated with code 0 (NO_ERROR) sql.0 2020-06-16 17:10:03.155 info (16559) disabled logging of ebus.0.700.messages.DisplayedOutsideTemp.fields.tempv.value ebus.0 2020-06-16 17:10:02.972 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.971 warn (7557) Object ebus.0.global.lastup is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.971 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.970 warn (7557) Object ebus.0.global.messages is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.969 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.968 warn (7557) Object ebus.0.global.masters is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.967 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.966 warn (7557) Object ebus.0.global.reconnects is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.965 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.964 warn (7557) Object ebus.0.global.qq is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.964 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.963 warn (7557) Object ebus.0.global.maxsymbollatency is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.962 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.962 warn (7557) Object ebus.0.global.minsymbollatency is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.962 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.961 warn (7557) Object ebus.0.global.maxarbitrationmicros is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.960 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.959 warn (7557) Object ebus.0.global.minarbitrationmicros is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.958 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.958 warn (7557) Object ebus.0.global.maxsymbolrate is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.956 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.956 warn (7557) Object ebus.0.global.symbolrate is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.742 info (7557) Terminated (NO_ERROR): Without reason ebus.0 2020-06-16 17:10:02.740 info (7557) all history done (exit) ebus.0 2020-06-16 17:10:02.739 debug (7557) delete ebus.0 2020-06-16 17:10:02.735 debug (7557) delete ebus.0 2020-06-16 17:10:02.652 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.652 warn (7557) Object ebus.0.global.signal is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.650 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.650 warn (7557) Object ebus.0.global.updatecheck is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.649 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.648 warn (7557) Object ebus.0.global.version is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.642 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.641 warn (7557) Object ebus.0.vms.messages.Ntc1Sensor.fields.sensor.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.641 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.640 warn (7557) Object ebus.0.vms.messages.Ntc1Sensor.fields.sensor.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.639 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.639 warn (7557) Object ebus.0.vms.messages.Ntc1Sensor.fields.temp.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.638 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.638 warn (7557) Object ebus.0.vms.messages.Ntc1Sensor.fields.temp.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.637 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.636 warn (7557) Object ebus.0.vms.messages.Ntc1Sensor.lastup is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.636 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.635 warn (7557) Object ebus.0.scan.ed.messages.id.fields.suffix.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.635 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.634 warn (7557) Object ebus.0.scan.ed.messages.id.fields.suffix.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.633 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.633 warn (7557) Object ebus.0.scan.ed.messages.id.fields.counter.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.632 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.632 warn (7557) Object ebus.0.scan.ed.messages.id.fields.counter.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.631 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.631 warn (7557) Object ebus.0.scan.ed.messages.id.fields.supplier.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.630 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.630 warn (7557) Object ebus.0.scan.ed.messages.id.fields.supplier.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.629 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.629 warn (7557) Object ebus.0.scan.ed.messages.id.fields.product.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.628 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.627 warn (7557) Object ebus.0.scan.ed.messages.id.fields.product.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.627 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.626 warn (7557) Object ebus.0.scan.ed.messages.id.fields.week.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.626 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.625 warn (7557) Object ebus.0.scan.ed.messages.id.fields.week.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.624 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.624 warn (7557) Object ebus.0.scan.ed.messages.id.fields.year.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.623 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.623 warn (7557) Object ebus.0.scan.ed.messages.id.fields.year.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.622 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.622 warn (7557) Object ebus.0.scan.ed.messages.id.fields.prefix.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.621 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.620 warn (7557) Object ebus.0.scan.ed.messages.id.fields.prefix.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.620 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.619 warn (7557) Object ebus.0.scan.ed.messages.id.lastup is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.619 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.618 warn (7557) Object ebus.0.scan.ed.messages..fields.HW.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.617 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.617 warn (7557) Object ebus.0.scan.ed.messages..fields.HW.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.616 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.616 warn (7557) Object ebus.0.scan.ed.messages..fields.SW.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.615 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.615 warn (7557) Object ebus.0.scan.ed.messages..fields.SW.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.614 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.613 warn (7557) Object ebus.0.scan.ed.messages..fields.ID.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.613 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.612 warn (7557) Object ebus.0.scan.ed.messages..fields.ID.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.612 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.611 warn (7557) Object ebus.0.scan.ed.messages..fields.MF.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.610 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.610 warn (7557) Object ebus.0.scan.ed.messages..fields.MF.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.609 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.609 warn (7557) Object ebus.0.scan.ed.messages..lastup is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.608 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.608 warn (7557) Object ebus.0.scan.15.messages.id.fields.suffix.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.607 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.606 warn (7557) Object ebus.0.scan.15.messages.id.fields.suffix.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.605 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.605 warn (7557) Object ebus.0.scan.15.messages.id.fields.counter.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.604 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.604 warn (7557) Object ebus.0.scan.15.messages.id.fields.counter.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.603 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.603 warn (7557) Object ebus.0.scan.15.messages.id.fields.supplier.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.602 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.602 warn (7557) Object ebus.0.scan.15.messages.id.fields.supplier.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.601 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.600 warn (7557) Object ebus.0.scan.15.messages.id.fields.product.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.600 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.599 warn (7557) Object ebus.0.scan.15.messages.id.fields.product.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.599 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.598 warn (7557) Object ebus.0.scan.15.messages.id.fields.week.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.597 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.597 warn (7557) Object ebus.0.scan.15.messages.id.fields.week.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.596 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.596 warn (7557) Object ebus.0.scan.15.messages.id.fields.year.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.595 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.595 warn (7557) Object ebus.0.scan.15.messages.id.fields.year.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.594 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.593 warn (7557) Object ebus.0.scan.15.messages.id.fields.prefix.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.593 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.592 warn (7557) Object ebus.0.scan.15.messages.id.fields.prefix.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.592 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.591 warn (7557) Object ebus.0.scan.15.messages.id.lastup is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.590 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.590 warn (7557) Object ebus.0.scan.15.messages..fields.HW.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.589 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.589 warn (7557) Object ebus.0.scan.15.messages..fields.HW.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.588 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.588 warn (7557) Object ebus.0.scan.15.messages..fields.SW.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.587 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.586 warn (7557) Object ebus.0.scan.15.messages..fields.SW.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.586 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.585 warn (7557) Object ebus.0.scan.15.messages..fields.ID.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.585 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.584 warn (7557) Object ebus.0.scan.15.messages..fields.ID.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.583 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.583 warn (7557) Object ebus.0.scan.15.messages..fields.MF.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.582 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.582 warn (7557) Object ebus.0.scan.15.messages..fields.MF.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.581 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.581 warn (7557) Object ebus.0.scan.15.messages..lastup is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.580 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.579 warn (7557) Object ebus.0.scan.08.messages.id.fields.suffix.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.579 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.578 warn (7557) Object ebus.0.scan.08.messages.id.fields.suffix.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.578 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.577 warn (7557) Object ebus.0.scan.08.messages.id.fields.counter.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.576 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.576 warn (7557) Object ebus.0.scan.08.messages.id.fields.counter.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.575 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.575 warn (7557) Object ebus.0.scan.08.messages.id.fields.supplier.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.574 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.574 warn (7557) Object ebus.0.scan.08.messages.id.fields.supplier.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.573 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.572 warn (7557) Object ebus.0.scan.08.messages.id.fields.product.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.572 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.571 warn (7557) Object ebus.0.scan.08.messages.id.fields.product.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.571 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.570 warn (7557) Object ebus.0.scan.08.messages.id.fields.week.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.569 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.569 warn (7557) Object ebus.0.scan.08.messages.id.fields.week.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.568 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.568 warn (7557) Object ebus.0.scan.08.messages.id.fields.year.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.567 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.566 warn (7557) Object ebus.0.scan.08.messages.id.fields.year.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.566 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.565 warn (7557) Object ebus.0.scan.08.messages.id.fields.prefix.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.565 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.564 warn (7557) Object ebus.0.scan.08.messages.id.fields.prefix.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.563 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.563 warn (7557) Object ebus.0.scan.08.messages.id.lastup is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.562 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.562 warn (7557) Object ebus.0.scan.08.messages..fields.HW.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.561 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.561 warn (7557) Object ebus.0.scan.08.messages..fields.HW.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.560 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.559 warn (7557) Object ebus.0.scan.08.messages..fields.SW.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.559 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.558 warn (7557) Object ebus.0.scan.08.messages..fields.SW.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.558 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.557 warn (7557) Object ebus.0.scan.08.messages..fields.ID.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.556 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.556 warn (7557) Object ebus.0.scan.08.messages..fields.ID.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.555 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.555 warn (7557) Object ebus.0.scan.08.messages..fields.MF.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.554 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.553 warn (7557) Object ebus.0.scan.08.messages..fields.MF.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.553 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.552 warn (7557) Object ebus.0.scan.08.messages..lastup is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.551 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.551 warn (7557) Object ebus.0.scan.06.messages.id.fields.suffix.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.550 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.550 warn (7557) Object ebus.0.scan.06.messages.id.fields.suffix.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.549 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.549 warn (7557) Object ebus.0.scan.06.messages.id.fields.counter.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.548 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.547 warn (7557) Object ebus.0.scan.06.messages.id.fields.counter.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.547 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.546 warn (7557) Object ebus.0.scan.06.messages.id.fields.supplier.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.545 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.545 warn (7557) Object ebus.0.scan.06.messages.id.fields.supplier.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.544 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.544 warn (7557) Object ebus.0.scan.06.messages.id.fields.product.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.543 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.542 warn (7557) Object ebus.0.scan.06.messages.id.fields.product.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.542 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.541 warn (7557) Object ebus.0.scan.06.messages.id.fields.week.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.541 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.540 warn (7557) Object ebus.0.scan.06.messages.id.fields.week.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.539 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.539 warn (7557) Object ebus.0.scan.06.messages.id.fields.year.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.538 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.537 warn (7557) Object ebus.0.scan.06.messages.id.fields.year.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.536 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.536 warn (7557) Object ebus.0.scan.06.messages.id.fields.prefix.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.535 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.535 warn (7557) Object ebus.0.scan.06.messages.id.fields.prefix.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.534 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.534 warn (7557) Object ebus.0.scan.06.messages.id.lastup is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.533 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.532 warn (7557) Object ebus.0.scan.06.messages..fields.HW.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.532 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.531 warn (7557) Object ebus.0.scan.06.messages..fields.HW.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.530 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.530 warn (7557) Object ebus.0.scan.06.messages..fields.SW.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.529 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.529 warn (7557) Object ebus.0.scan.06.messages..fields.SW.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.528 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.527 warn (7557) Object ebus.0.scan.06.messages..fields.ID.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.527 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.526 warn (7557) Object ebus.0.scan.06.messages..fields.ID.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.525 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.525 warn (7557) Object ebus.0.scan.06.messages..fields.MF.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.524 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.524 warn (7557) Object ebus.0.scan.06.messages..fields.MF.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.523 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.522 warn (7557) Object ebus.0.scan.06.messages..lastup is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.522 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.521 warn (7557) Object ebus.0.broadcast.messages.vdatetime.fields.date.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.520 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.520 warn (7557) Object ebus.0.broadcast.messages.vdatetime.fields.date.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.519 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.519 warn (7557) Object ebus.0.broadcast.messages.vdatetime.fields.time.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.518 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.518 warn (7557) Object ebus.0.broadcast.messages.vdatetime.fields.time.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.517 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.516 warn (7557) Object ebus.0.broadcast.messages.vdatetime.lastup is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.516 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.515 warn (7557) Object ebus.0.broadcast.messages.outsidetemp.fields.temp2.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.515 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.514 warn (7557) Object ebus.0.broadcast.messages.outsidetemp.fields.temp2.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.513 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.513 warn (7557) Object ebus.0.broadcast.messages.outsidetemp.lastup is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.512 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.512 warn (7557) Object ebus.0.bai.messages.StatusCirPump.fields.0.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.511 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.511 warn (7557) Object ebus.0.bai.messages.StatusCirPump.fields.0.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.510 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.509 warn (7557) Object ebus.0.bai.messages.StatusCirPump.lastup is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.509 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.508 warn (7557) Object ebus.0.bai.messages.Status02.fields.4.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.508 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.507 warn (7557) Object ebus.0.bai.messages.Status02.fields.4.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.506 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.506 warn (7557) Object ebus.0.bai.messages.Status02.fields.3.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.505 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.505 warn (7557) Object ebus.0.bai.messages.Status02.fields.3.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.504 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.503 warn (7557) Object ebus.0.bai.messages.Status02.fields.2.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.503 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.502 warn (7557) Object ebus.0.bai.messages.Status02.fields.2.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.502 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.501 warn (7557) Object ebus.0.bai.messages.Status02.fields.1.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.500 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.500 warn (7557) Object ebus.0.bai.messages.Status02.fields.1.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.499 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.499 warn (7557) Object ebus.0.bai.messages.Status02.fields.0.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.498 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.497 warn (7557) Object ebus.0.bai.messages.Status02.fields.0.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.497 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.496 warn (7557) Object ebus.0.bai.messages.Status02.lastup is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.495 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.495 warn (7557) Object ebus.0.bai.messages.Status01.fields.5.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.494 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.494 warn (7557) Object ebus.0.bai.messages.Status01.fields.5.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.493 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.493 warn (7557) Object ebus.0.bai.messages.Status01.fields.4.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.492 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.491 warn (7557) Object ebus.0.bai.messages.Status01.fields.4.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.490 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.490 warn (7557) Object ebus.0.bai.messages.Status01.fields.3.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.489 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.489 warn (7557) Object ebus.0.bai.messages.Status01.fields.3.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.486 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.486 warn (7557) Object ebus.0.bai.messages.Status01.fields.2.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.485 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.485 warn (7557) Object ebus.0.bai.messages.Status01.fields.2.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.484 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.484 warn (7557) Object ebus.0.bai.messages.Status01.fields.1.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.483 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.482 warn (7557) Object ebus.0.bai.messages.Status01.fields.1.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.481 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.481 warn (7557) Object ebus.0.bai.messages.Status01.fields.0.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.480 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.480 warn (7557) Object ebus.0.bai.messages.Status01.fields.0.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.479 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.478 warn (7557) Object ebus.0.bai.messages.Status01.lastup is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.478 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.477 warn (7557) Object ebus.0.bai.messages.SetMode.fields.releaseCooling.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.477 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.476 warn (7557) Object ebus.0.bai.messages.SetMode.fields.releaseCooling.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.475 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.475 warn (7557) Object ebus.0.bai.messages.SetMode.fields.releaseBackup.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.474 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.474 warn (7557) Object ebus.0.bai.messages.SetMode.fields.releaseBackup.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.473 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.473 warn (7557) Object ebus.0.bai.messages.SetMode.fields.remoteControlHcPump.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.472 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.471 warn (7557) Object ebus.0.bai.messages.SetMode.fields.remoteControlHcPump.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.471 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.470 warn (7557) Object ebus.0.bai.messages.SetMode.fields.disablehwcload.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.470 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.469 warn (7557) Object ebus.0.bai.messages.SetMode.fields.disablehwcload.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.468 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.468 warn (7557) Object ebus.0.bai.messages.SetMode.fields.disablehwctapping.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.467 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.467 warn (7557) Object ebus.0.bai.messages.SetMode.fields.disablehwctapping.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.466 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.465 warn (7557) Object ebus.0.bai.messages.SetMode.fields.disablehc.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.465 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.464 warn (7557) Object ebus.0.bai.messages.SetMode.fields.disablehc.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.464 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.463 warn (7557) Object ebus.0.bai.messages.SetMode.fields.hwcflowtempdesired.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.462 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.462 warn (7557) Object ebus.0.bai.messages.SetMode.fields.hwcflowtempdesired.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.461 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.461 warn (7557) Object ebus.0.bai.messages.SetMode.fields.hwctempdesired.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.460 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.460 warn (7557) Object ebus.0.bai.messages.SetMode.fields.hwctempdesired.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.459 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.458 warn (7557) Object ebus.0.bai.messages.SetMode.fields.flowtempdesired.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.458 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.457 warn (7557) Object ebus.0.bai.messages.SetMode.fields.flowtempdesired.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.456 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.456 warn (7557) Object ebus.0.bai.messages.SetMode.fields.hcmode.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.455 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.455 warn (7557) Object ebus.0.bai.messages.SetMode.fields.hcmode.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.454 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.454 warn (7557) Object ebus.0.bai.messages.SetMode.lastup is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.453 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.452 warn (7557) Object ebus.0.bai.messages.DateTime.fields.temp2.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.452 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.451 warn (7557) Object ebus.0.bai.messages.DateTime.fields.temp2.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.451 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.450 warn (7557) Object ebus.0.bai.messages.DateTime.fields.bdate.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.449 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.449 warn (7557) Object ebus.0.bai.messages.DateTime.fields.bdate.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.448 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.448 warn (7557) Object ebus.0.bai.messages.DateTime.fields.btime.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.447 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.447 warn (7557) Object ebus.0.bai.messages.DateTime.fields.btime.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.446 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.445 warn (7557) Object ebus.0.bai.messages.DateTime.fields.dcfstate.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.445 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.444 warn (7557) Object ebus.0.bai.messages.DateTime.fields.dcfstate.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.443 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.443 warn (7557) Object ebus.0.bai.messages.DateTime.lastup is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.442 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.442 warn (7557) Object ebus.0.700.messages.DisplayedOutsideTemp.fields.tempv.name is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.441 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.441 warn (7557) Object ebus.0.700.messages.DisplayedOutsideTemp.fields.tempv.value is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.440 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:02.439 warn (7557) Object ebus.0.700.messages.DisplayedOutsideTemp.lastup is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:02.374 info (7557) all http done ebus.0 2020-06-16 17:10:02.133 debug (7557) oData {"700":{"messages":{"AdaptHeatCurve":{"name":"AdaptHeatCurve","passive":false,"write":false,"lastup":0},"BankHolidayEndPeriod":{"name":"BankHolidayEndPeriod","passive":false,"write":false ebus.0 2020-06-16 17:10:02.091 debug (7557) request data from http://192.168.178.47:8890/data ebus.0 2020-06-16 17:10:02.089 debug (7557) all telnet done ebus.0 2020-06-16 17:10:02.088 debug (7557) received 38.94;ok for Ntc1Sensor ebus.0 2020-06-16 17:10:01.871 debug (7557) received 24.25 for DisplayedOutsideTemp ebus.0 2020-06-16 17:10:01.553 debug (7557) telnet connected ebus.0 2020-06-16 17:10:01.549 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:01.548 warn (7557) Object ebus.0.history.error is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:01.519 debug (7557) connect telnet to IP 192.168.178.47 port 8888 ebus.0 2020-06-16 17:10:01.518 debug (7557) to poll ctr 2 vals: DisplayedOutsideTemp,Ntc1Sensor org DisplayedOutsideTemp,Ntc1Sensor org length 31 ebus.0 2020-06-16 17:10:01.506 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:01.506 warn (7557) Object ebus.0.history.date is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:01.505 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:01.504 warn (7557) Object ebus.0.history.value1 is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:01.504 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:01.503 warn (7557) Object ebus.0.cmdResult is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:01.502 warn (7557) This object will not be created in future versions. Please report this to the developer. ebus.0 2020-06-16 17:10:01.501 warn (7557) Object ebus.0.cmd is invalid: obj.type has to exist ebus.0 2020-06-16 17:10:01.473 debug (7557) init common variables ebus.0 2020-06-16 17:10:01.468 debug (7557) init variables ebus.0 2020-06-16 17:10:01.468 debug (7557) start with interface ebusd ebus.0 2020-06-16 17:10:01.467 debug (7557) set timeout to 60 sec ebus.0 2020-06-16 17:10:01.438 info (7557) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.ebus, node: v10.19.0, js-controller: 3.1.4 host.raspberrypi 2020-06-16 17:10:00.016 info instance system.adapter.ebus.0 started with pid 7557In Objekte legt er Ordner an, jedoch keine Werte:
Und wenn ich die Statusansicht wechsel, wird ebus nicht angezeigt:
Es hatte Wochen funktioniert???
@Jui muss ich mir anschauen, scheint ein bug zu sein...
@Rene_HM
Okay , Die Version 1.0.0 hatte Wochen funktioniert.Vielleicht hilft es Dir bei der Fehlersuche:
- ich hatte von 1.0.0 auf 2.0.0 gewechselt, danach lief alles tadellos weiter, Werte wurden angezeigt und erneuert.
- dann habe ich neue Datenpunkte hinzu genommen, die Config im ebusd erneuert, die alten Werte wurden weiter tadellos angezeigt , die neuen Werte erschienen nicht unter Objekte
- dann ebus Adapter deinstalliert und neu installiert
- dann kamen unter Objekte gar keine Werte mehr (so wie jetzt), im Log und unter http//.../data sind aktuelle Werte immer zu sehen
- dann ebusd Config wieder auf die letzte Einstellung geändert, auch ohne Erfolg ...
Auf die alte Version kann ich nicht wechseln um zu testen.
@Jui ich habe die version 2.1.0 im github und npm (latest repo). Die sollte das Problem beheben...
@Rene_HM TOP!
Update auf 2.1.0 durchgeführt, dann unter Objekte ebus.0 gelöscht und mit dem nächsten Abruf sind die Werte wieder da.
DANKE! -
Mit der Version 2.1.0 habe ich alle 5min folgende Fehlermeldung im Log
ebus.0 2020-06-19 19:35:03.268 error (1063) history.value1 not found null ebus.0 2020-06-19 19:35:03.266 error (1063) history.date not found null ebus.0 2020-06-19 19:35:02.306 error (1063) object cmd not found nullDas hatte ich vorher nicht.
Ich hatte beim Umstieg auf 2.1.0 alle Ebus Objekte gelöscht und neu anlegen lassen.Kann ich hier etwas tun, um die Fehler zu beseitigen?
@Knallochse Das sind nur logs, die ich beim Umbau eingebaut hatte. Im Moment bitte ignorieren, außer irgendetwas geht nicht (z.Bsp. Kommandos direkt auf ebusd schreiben...)
@Rene_HM Danke, dann weiß ich Bescheid
@Rene_HM sagte in Adapter: ebus:
Aus meiner Sicht zwei Möglichkeiten:
Integration des Vaillant-Internetmodul VR 920 als Adapter in ioBroker
Bei der ersten Variante kann ich leider nicht helfen, da ich dieses Modul nicht zur Verfügung habe…
Wegen Heizungs Neuanschaffung bekomme ich ein VR 921 I-Modul dazu was auch EEbus kann .
Laut I-Net soll es auch mit Homematic CCU3 laufen , aber leider keine Infos dazu im I-Net wie es einzubinden ist gefunden .eQ-3 integriert EEBUS in Smart Home Systeme
Wie kann ich dich darin unterstützen , damit du dieses Modul integrieren kannst ?
@Glasfaser
eebus ist nicht ebus. Was auch immer EQ3 da treibt, mit diesen Adapter hier hat das nichts zu tun denke ich.
Ob der HMIP Adapter damit etwas anfangen kann müsste an jener Stelle im Forum diskutiert werden. -
@cactus-online sagte in Adapter: ebus:
@Glasfaser
eebus ist nicht ebus.Das ist mir schon klar
Hallo ... war nur eine Andeutung ...mehr nicht
Ich wollte hier keine diskutieren anfangen , habe nur @Rene_HM angefragt ob ich Ihn bei dem integrieren des VR 921 I-Net Modul was auch eBus kann , unterstützen kann .
@Glasfaser: Ok, das konnte ich dem Post so nicht entnehmen. Wenn eBus unterstützt wird, müsste dann nicht der eBus-Daemon die Nachrichten dekodieren (können). Der Adapter holt sich doch alles vom ebusd. Eine Anpassung des Adapters wäre doch gar nicht nötig, oder was meinst Du?
ich dachte es geht eventuell ohne den Ebusd , also per Schnittstelle direkt zum Internetmodul VR 921 den ich habe .
Hatte auch in der Zwischenzeit etwas gefunden Test Adapter Vaillant multiMatic v0.0.x, ist aber nicht so doll ..Bin deinem Rat zu Ebusd gefolgt
... klappt auch alles mit diesem Ebus Adapter ,
aber da ich den Witterungsgeführte Regelung sensoCOMFORT VRC 720 haben, sind nicht alle Werte vorhanden nur leider ein kleiner Bruchteil davon.
Die 15.700.cvs auf 15.720.cvs geändert.
@cactus-online hast du vielleicht ein Rat woran das liegen kann ?@Timmerx hat du alle Daten vorhanden , da du schreibst es funktioniert bei dir !?
@Glasfaser Aus meiner Sicht ist das kein Thema für das ioBroker Forum. ICh würde diese Frage eher hier (https://ebusd.eu/discussion/) platzieren.
VG,
TF
Ich habe eine Vaillant aurocompacht VSC 196/3-5 mit Regler VR470 und integrierten Solarregler.
Mein ebus läuft nach anfänglichen Schwierigkeiten super und ich bekomme eine Menge Daten von der Heizung.
Was mir nur nicht gelingt, sind Daten von der Solaranlage zu empfangen. Ist eventuell der integrierte Solarregler nicht am ebus angeschlossen oder gibt es andere Ursachen?
Ich benutze ebusd 3.4 mit automatischer Konfiguration. Fehlt da eventuell noch eine spezifische .csv-Konfig-Datei?
Kann mir da jemans helfen? -
@Kanumouse Weißt du, welcher Solarregler da eingebaut ist?
Ich bin nicht ganz sicher, ob es sich dabei tatsächlich um ein separates Bauteil handelt, aber bei mir ist der VR700 Regler eingebaut und der Solarregler meldet sich unter einer anderen Adresse mit dem Namen VMS01. Dafür habe ich eine separate Konfiguration erstellt. Findest du in meinem Github-Repository:https://github.com/Standarduser/ebusd-configuration
Ich habe dazu ein Pullrequest erstellt, das bisher jedoch noch nicht angenommen wurde.
Was dir also momentan bleibt, ist auf lokale Konfigurationsdateien umzustellen und zu probieren, ob die Datei geladen wird.
