    4. Probleme nach Update node.js
    UNSOLVED Probleme nach Update node.js
      Thomas Braun Most Active @Andy200877 last edited by
      @Andy200877
      node gerade im System?
      which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
        root@NAS:~# which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
        /usr/bin/nodejs
        v12.18.0
        /usr/bin/node
        v12.18.0
        /usr/bin/npm
        6.14.4
        nodejs:
          Installed: 12.18.0-1nodesource1
          Candidate: 12.18.0-1nodesource1
          Version table:
         *** 12.18.0-1nodesource1 500
                500 https://deb.nodesource.com/node_12.x stretch/main amd64 Packages
                100 /var/lib/dpkg/status
             8.11.1~dfsg-2~bpo9+1 100
                100 http://httpredir.debian.org/debian stretch-backports/main amd64 Packages
             4.8.2~dfsg-1 500
                500 http://ftp.de.debian.org/debian stretch/main amd64 Packages
        root@NAS:~#
          @Andy200877
          Nicht als root rumhampeln.
          Als user:
          iobroker fix
          cd /opt/iobroker
          npm cache clean --force
          iobroker update
          iobroker upgrade
          iobroker rebuild
            Andy200877 last edited by Andy200877
            Ich habe mir vorher einen neuen User angelegt, mit ssh und sudo rechten.
            iobroker fix, update, upgrade usw. läuft ohne Fehler durch.
            Bei "iobroker rebuild" bricht er mir relativ schnell ab :
            andreas@NAS:/opt/iobroker$ iobroker rebuild
            /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:487
                        if (name.indexOf('@') !== -1) {
            TypeError: Cannot read property 'indexOf' of undefined
                at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:487:22)
                at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2601:5)
                at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
                at Module._compile (internal/modules/cjs/loader.js:1138:30)
                at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
                at Module.load (internal/modules/cjs/loader.js:986:32)
                at Function.Module._load (internal/modules/cjs/loader.js:879:14)
                at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)
                at internal/main/run_main_module.js:17:47
              @Andy200877
              Da klemmt es irgendwo tiefer, scheint mir.
              Ich würde mal versuchen den js-controller neuzuinstallieren.
              cd /opt/iobroker
              sudo -H -u iobroker npm install iobroker.js-controller
                js-controller als user neu installiert...
                andreas@NAS:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controlle                                                            r
                [sudo] password for andreas:
                npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/31                           42
                > iobroker.js-controller@3.1.5 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                > node lib/preinstallCheck.js
                NPM version: 6.14.4
                > iobroker.js-controller@3.1.5 install /opt/iobroker/node_modules/iobroker.js-controller
                > node iobroker.js setup first
                Existing earlier generated certificate is invalid (too old, validity longer then 345 days or keylength too short). Generating new Certificate!
                object system.certificates updated
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                + iobroker.js-controller@3.1.5
                updated 2 packages in 21.034s
                43 packages are looking for funding
                  run `npm fund` for details
                Danach aber der gleiche Fehler wie vorher...
                tobowers created this issue in request/request
                closed Error on piping a request to a destination #31
                  Djpredator69 last edited by Djpredator69
                  hi habe auch probleme nach update mit dem serialport@6.2.2 unter
                  Windows server 2016
                  Node.js
                  v12.18.0
                  NPM
                  6.14.5
                  i hatte den WM-BUS installiert duch den fehler mit dem serial lässt der sich nicht mehr starten oder neu installieren!
                    Niemand eine Idee ? Oder muss ich wirklich das komplette System neu aufsetzen ?
                    G D 2 Replies Last reply Reply Quote 0
                      gifftstaub @Andy200877 last edited by
                      @Andy200877
                      link text
                      Vllt hilft der Link weiter
                      Lg
                        Djpredator69 @Andy200877 last edited by Djpredator69
                        @Andy200877
                        es scheint dass serialport@6.2.2 nur unter Node.js v10 läuft und nicht unter der v12
                        habe ein downdrade auf 10 gemacht da läuft alles
                        bei einem update auf 12 wieder ,taucht das problem wieder auf
                        finde keine lösung , der WM-bus adapter muss umgeschrieben werden damit er die neuste serialport
                        lib nutzt und nicht die 6.2.2, die ist leider veraltet
                        v522533 Thomas Braun 2 Replies Last reply Reply Quote 0
                        • v522533
                          v522533 @Djpredator69 last edited by
                          @Djpredator69
                          kann zwar bei dem problem nicht helfen, ich kann aber sagen dass bei mir alles unter node 12.x.x problemlos läuft. das kann also nicht das problem sein.
                            Thomas Braun Most Active @Djpredator69 last edited by
                            @Djpredator69 sagte in Probleme nach Update node.js:
                            @Andy200877
                            Mal den serialport gegen node12 neugebaut?
                              Djpredator69 @v522533 last edited by
                              @v522533
                              hast du auch den WM-bus am laufen
                              denn ich habe nur mit diesem adapter probleme alles andere läuft auch bei mir super
                              v522533 1 Reply Last reply Reply Quote 0
                              • v522533
                                @Djpredator69
                                ne den habe ich nicht am laufen
                                  habe es jetzt am laufen
                                  habe den adapter vom git installiert dann per hand die instanz installiert jetzt läuft es
                                  wenn ich aber das ganze über iobroker installiere kommen nur die oben genanten fehler
                                  ich teste den adapter jetzt ob er auch 100% läuft
                                  node.js update serialport@6.2.2
                                  1590
