    4. Probleme nach Update node.js
    UNSOLVED Probleme nach Update node.js
      Thomas Braun Most Active @Andy200877 last edited by
      @Andy200877
      Nicht als root rumhampeln.
      Als user:
      iobroker fix
      cd /opt/iobroker
      npm cache clean --force
      iobroker update
      iobroker upgrade
      iobroker rebuild
        Andy200877 last edited by Andy200877
        Ich habe mir vorher einen neuen User angelegt, mit ssh und sudo rechten.
        iobroker fix, update, upgrade usw. läuft ohne Fehler durch.
        Bei "iobroker rebuild" bricht er mir relativ schnell ab :
        andreas@NAS:/opt/iobroker$ iobroker rebuild
        /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:487
                    if (name.indexOf('@') !== -1) {
        TypeError: Cannot read property 'indexOf' of undefined
            at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:487:22)
            at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2601:5)
            at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
            at Module._compile (internal/modules/cjs/loader.js:1138:30)
            at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
            at Module.load (internal/modules/cjs/loader.js:986:32)
            at Function.Module._load (internal/modules/cjs/loader.js:879:14)
            at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)
            at internal/main/run_main_module.js:17:47
          @Andy200877
          Da klemmt es irgendwo tiefer, scheint mir.
          Ich würde mal versuchen den js-controller neuzuinstallieren.
          cd /opt/iobroker
          sudo -H -u iobroker npm install iobroker.js-controller
            js-controller als user neu installiert...
            andreas@NAS:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controlle                                                            r
            [sudo] password for andreas:
            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/31                           42
            > iobroker.js-controller@3.1.5 preinstall /opt/iobroker/node_modules/iobroker.js-controller
            > node lib/preinstallCheck.js
            NPM version: 6.14.4
            > iobroker.js-controller@3.1.5 install /opt/iobroker/node_modules/iobroker.js-controller
            > node iobroker.js setup first
            Existing earlier generated certificate is invalid (too old, validity longer then 345 days or keylength too short). Generating new Certificate!
            object system.certificates updated
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
            + iobroker.js-controller@3.1.5
            updated 2 packages in 21.034s
            43 packages are looking for funding
              run `npm fund` for details
            Danach aber der gleiche Fehler wie vorher...
            tobowers created this issue in request/request
            closed Error on piping a request to a destination #31
              Djpredator69 last edited by Djpredator69
              hi habe auch probleme nach update mit dem serialport@6.2.2 unter
              Windows server 2016
              Node.js
              v12.18.0
              NPM
              6.14.5
              i hatte den WM-BUS installiert duch den fehler mit dem serial lässt der sich nicht mehr starten oder neu installieren!
                Niemand eine Idee ? Oder muss ich wirklich das komplette System neu aufsetzen ?
                G D 2 Replies Last reply Reply Quote 0
                  gifftstaub @Andy200877 last edited by
                  @Andy200877
                  link text
                  Vllt hilft der Link weiter
                  Lg
                    Djpredator69 @Andy200877 last edited by Djpredator69
                    @Andy200877
                    es scheint dass serialport@6.2.2 nur unter Node.js v10 läuft und nicht unter der v12
                    habe ein downdrade auf 10 gemacht da läuft alles
                    bei einem update auf 12 wieder ,taucht das problem wieder auf
                    finde keine lösung , der WM-bus adapter muss umgeschrieben werden damit er die neuste serialport
                    lib nutzt und nicht die 6.2.2, die ist leider veraltet
                    v522533 Thomas Braun 2 Replies Last reply Reply Quote 0
                    • v522533
                      v522533 @Djpredator69 last edited by
                      @Djpredator69
                      kann zwar bei dem problem nicht helfen, ich kann aber sagen dass bei mir alles unter node 12.x.x problemlos läuft. das kann also nicht das problem sein.
                        Thomas Braun Most Active @Djpredator69 last edited by
                        @Djpredator69 sagte in Probleme nach Update node.js:
                        @Andy200877
                        Mal den serialport gegen node12 neugebaut?
                          Djpredator69 @v522533 last edited by
                          @v522533
                          hast du auch den WM-bus am laufen
                          denn ich habe nur mit diesem adapter probleme alles andere läuft auch bei mir super
                          v522533 1 Reply Last reply Reply Quote 0
                          • v522533
                            @Djpredator69
                            ne den habe ich nicht am laufen
                              habe es jetzt am laufen
                              habe den adapter vom git installiert dann per hand die instanz installiert jetzt läuft es
                              wenn ich aber das ganze über iobroker installiere kommen nur die oben genanten fehler
                              ich teste den adapter jetzt ob er auch 100% läuft
                              node.js update serialport@6.2.2
                              1588
