    4. IOBroker schon wieder kaputt
    • Bluefox
      Bluefox last edited by
      @ChristianM:
      Leider bringt das nicht den gewünschten Erfolg. 😞 `
      Wie prüfst du, dass ioBroker nicht läuft?
      Was liefern die Befehle?
      cd /opt/iobroker
      ps -A | grep io
      netstat -n -a | grep 9000
      iobroker stop
      iobroker l i
      • ChristianM
        ChristianM last edited by
        Also
        ps -A | grep io
        liefert
        root@ioBroker:/opt/iobroker# ps -A | grep io
           10 ?        00:00:02 migration/0
           11 ?        00:00:02 migration/1
           15 ?        00:00:02 migration/2
           19 ?        00:00:02 migration/3
           30 ?        00:00:00 bioset
           33 ?        00:00:00 rpciod
           36 ?        00:00:00 nfsiod
           49 ?        00:00:00 DWC Notificatio
         2094 ?        00:00:44 iobroker.js-con
        root@ioBroker:/opt/iobroker# netstat -n -a | grep 9000
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN
        iobroker stop
        iobroker controller daemon stopped.
        Exit code for "killall.sh": 123
        iobroker l i
        root@ioBroker:/opt/iobroker# iobroker l i
        system.adapter.admin.0                 : admin       -  enabled, port: 8081, bin                                          d: 0.0.0.0, run as: admin
        system.adapter.hm-rpc.0                : hm-rpc      -  enabled
        system.adapter.hm-rega.0               : hm-rega     -  enabled
        system.adapter.hm-rpc.1                : hm-rpc      -  enabled
        system.adapter.hmm.0                   : hmm         - disabled
        system.adapter.samsung.0               : samsung     -  enabled
        system.adapter.web.0                   : web         -  enabled, port: 8082, bin                                          d: 192.168.1.110, run as: admin
        system.adapter.squeezebox.0            : squeezebox  -  enabled
        system.adapter.history.0               : history     -  enabled
        system.adapter.vis.0                   : vis         -  enabled
        system.adapter.vis-colorpicker.0       : vis-colorpicker -  enabled
        system.adapter.vis-bars.0              : vis-bars    -  enabled
        system.adapter.vis-justgage.0          : vis-justgage -  enabled
        system.adapter.vis-fancyswitch.0       : vis-fancyswitch -  enabled
        system.adapter.vis-hqwidgets.0         : vis-hqwidgets -  enabled
        system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd -  enabled
        system.adapter.vis-keyboard.0          : vis-keyboard -  enabled
        system.adapter.vis-metro.0             : vis-metro   -  enabled
        system.adapter.vis-rgraph.0            : vis-rgraph  -  enabled
        system.adapter.vis-timeandweather.0    : vis-timeandweather -  enabled
        system.adapter.rickshaw.0              : rickshaw    -  enabled
        system.adapter.scenes.0                : scenes      -  enabled
        system.adapter.flot.0                  : flot        -  enabled
        system.adapter.icons-mfd-png.0         : icons-mfd-png -  enabled
        system.adapter.dwd.0                   : dwd         - disabled
        system.adapter.admin.1                 : admin       -  enabled, port: 8083, bin                                          d: 0.0.0.0, run as: admin
        system.adapter.admin.2                 : admin       -  enabled, port: 8085, bin                                          d: 0.0.0.0, run as: admin
        • derAuge
          derAuge last edited by
          mach mal bitte einen "iobroker restart"
          danach sollen mindestens
          -> iobroker.js-con
          -> io.admin.0
          laufen
          root@RPi3-1:/opt/iobroker# ps -A | grep " io.*"
           3392 ?        00:21:36 iobroker.js-con
           3411 ?        00:10:44 io.admin.0
           3535 ?        00:05:17 io.rpi.0
           3589 ?        00:09:27 io.javascript.0
           4642 ?        00:00:36 io.node-red.0
           4890 ?        00:04:38 io.sonos.0
          wenn admin nicht läuft
          mit "iobroker start admin.0" versuchen den Adapter zu starten
          Jürgen
          • Bluefox
            Dein admin läuft nicht, obwohl enabled. Als erstes muss man natürlich logs schauen unter /opt/log/*
            oder einfach das probieren:
            cd /opt/iobroker
            iobroker stop admin
            npm install iobroker.admin
            • ChristianM
              Ich komme auf die :8081 Seite nicht drauf.
              Ich habe nun ein reboot gemacht und auch den admin.0 versucht zu starten.
                 10 ?        00:00:04 migration/0
                 11 ?        00:00:04 migration/1
                 15 ?        00:00:04 migration/2
                 19 ?        00:00:04 migration/3
               1660 ?        00:00:04 iobroker.js-con
              root@ioBroker:/opt/iobroker# iobroker start admin.0
              events.js:72
                      throw er; // Unhandled 'error' event
              Error: listen EADDRINUSE
                  at errnoException (net.js:901:11)
                  at Server._listen2 (net.js:1039:14)
                  at listen (net.js:1061:10)
                  at Server.listen (net.js:1127:5)
                  at _initWebServer (/root/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2594:24)
                  at /root/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:147:9
                  at new ObjectsInMemServer (/root/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:154:7)
                  at null._onTimeout (/root/node_modules/iobroker.js-controller/lib/setup.js:2237:27)
                  at Timer.listOnTimeout [as ontimeout] (timers.js:110:15)
               1660 ?        00:00:05 iobroker.js-con
              • derAuge
                und da liegt das Problem
                events.js:72
                der Adapter startet nicht
                Dann schau mal bitte unter
                http://forum.iobroker.net/viewtopic.php?f=22&t=1544
                nach.
                Das sollte dir helfen
                Jürgen
                • ruhr70
                  ruhr70 last edited by
                  Hat heute genau das gleich Problem, nur ohne das EADDRINUSE.
                  Auf meinem iobroker Hauptrechen kam ich nicht mehr auf Admin nach einem Reboot. Kurz davor hatte ich im Netz ein Problem und der Mac meckerte, dass sein Name schon vergeben ist und hat diesen dann geändert (aus dem Augenwinkel gesehen).
                  Nach einem Reblot lief auf einmal ioBroker nicht mehr.
                  Nach langer Suche… es lag am Hostnamen beim Mac
                    marschmello last edited by
                    ich habe heute morgen meine Iobroker admin versucht zu updaten.
                    Leide ist das Update nicht durchgelaufen und seit dem funktioniert leider überhaupt nichts mehr.
                    Ich habe schon versucht über die "IoBroker läuft nicht mehr " Hilfe seite das Problem an zu gehen.
                    leider läuft der js-controller scheinbar nicht mehr.
                    Eine Neuinstallation mit
                    npm install iobroker.js-controller
                    in der Konsole funktioniert leider auch nicht. Es gibt keine Fehlermeldung aber die INstallation läuft
                    leider nicht durch.
                    Weiß jemand einen Rat, wie ich jetzt weiter machen kann???
                    Gruß Ralf
                    Beim Starten kommt folgende Fehlermeldung:
                    Starting iobroker controller daemon...
                    /opt/iobroker/node_modules/iobroker.js-controller/node_modules/daemonize2/lib/daemonize.js:136
                                throw new Error(msg.error);
                    Error: Error: Cannot find module 'utf8'
                        at Function.Module._resolveFilename (module.js:336:15)
                        at Function.Module._load (module.js:278:25)
                        at Module.require (module.js:365:17)
                        at require (module.js:384:17)
                        at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/lib/index.js:5:12)
                        at Module._compile (module.js:460:26)
                        at Object.Module._extensions..js (module.js:478:10)
                        at Module.load (module.js:355:32)
                        at Function.Module._load (module.js:310:12)
                        at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/daemonize2/lib/daemonize.js:136:19)
                        at ChildProcess.emit (events.js:110:17)
                        at handleMessage (child_process.js:324:10)
                        at Pipe.channel.onread (child_process.js:352:11)</anonymous></anonymous>
                      aquapro last edited by
                      Log wär schon nicht schlecht. 🙂
                        Hallo
                        Danke für die schnelle antwort, bin aber Neuling.
                        Wo finde ich das Log??
                        gruß
                          @marschmello:
                          in der Konsole funktioniert leide `
                          leider nicht durch.
                          Genau die Ausgabe von der console würde schon etwas helfen. Damit wir schneller helfen können.
                            Log Datei im Iobrker Verzeichniss habe ich gefunden.
                            Es sind aber endlose Seiten. Wie kann ich da relevante Daten herausfiltern??
                              Bitte versuche:
                              cd /opt/iobroker
                              npm cache clean
                              npm install iobroker.js-controller --production
                              Vorausgesetzt du arbeitest auf einem Raspi et al. (??)
                              Dann bitte ergebnis mit cut and paste hier posten
                              Rainer
                                ` > root@raspberrypi:/opt/iobroker# npm install iobroker.js-controller
                                genaus an dieser Steller passiert leider überhaupt nichts mehr.
                                Ich habe es bestimmt 1,5 Stunden laufen lassen und dann Terminal beendet und mich neu eingeloggt
                                  @marschmello:
                                  genaus an dieser Steller passiert leider überhaupt nichts mehr. `
                                  Fehlglaube 😉
                                  Was hast du als host? RPi1????
                                  Dann dauert das ewig!
                                  selbst bei einem RPi2 oder 3 tut sich da anscheinend nichts. Das liegt an der node-Version früher wurde alles angezeigt, jetzt läuft es silent!
                                  Es dauert da (2/3) bestimmt einige Minuten, bervor die zweite Zeile erscheint, dann nochmal mindestens doppelt so lange bis dann der Erfolg bestätigt wird.
                                  Rainer
                                  PS log wäre wirklich nicht schlecht - vielleicht ist ja auch deine Karte voll???
                                    Ist in Arbeit.
                                    Wie lange kann so eine Installation dauern??
                                    Mein System ist auf einem Pi
                                      @marschmello:
                                      Mein System ist auf einem Pi `
                                      das habe ich mir gedacht:
                                      @marschmello:
                                      root@raspberrypi: `
                                      Aber:
                                      @Homoran:
                                      RPi1?…
                                      ...RPi2 oder 3 `
                                      Rainer
                                        der cache clean hat etwas gebracht
                                        iobroker.js-controller@0.9.0 install /opt/iobroker/node_modules/iobroker.js-controller
                                        node lib/setup.js setup first
                                        iobroker.js-controller@0.9.0 node_modules/iobroker.js-controller
                                        ├── winston-daily-rotate-file@1.1.4
                                        ├── daemonize2@0.4.2
                                        ├── mime@1.3.4
                                        ├── ncp@2.0.0
                                        ├── node.extend@1.1.5 (is@3.1.0)
                                        ├── adm-zip@0.4.7
                                        ├── semver@4.3.6
                                        ├── node-schedule@1.0.0 (long-timeout@0.0.2, cron-parser@1.1.0)
                                        ├── yargs@3.32.0 (decamelize@1.2.0, camelcase@2.1.1, y18n@3.2.1, window-size@0.1.4, cliui@3.2.0, string-width@1.0.1, os-locale@1.4.0)
                                        ├── socket.io@1.4.6 (has-binary@0.1.7, debug@2.2.0, socket.io-parser@2.2.6, engine.io@1.6.9, socket.io-adapter@0.4.0)
                                        ├── socket.io-client@1.4.6 (to-array@0.1.4, indexof@0.0.1, component-emitter@1.2.0, object-component@0.0.3, component-bind@1.0.0, backo2@1.0.2, has-binary@0.1.7, debug@2.2.0, parseuri@0.0.4, socket.io-parser@2.2.6, engine.io-client@1.6.9)
                                        ├── prompt@1.0.0 (revalidator@0.1.8, colors@1.1.2, pkginfo@0.4.0, read@1.0.7, winston@2.1.1, utile@0.3.0)
                                        ├── request@2.72.0 (is-typedarray@1.0.0, oauth-sign@0.8.2, aws-sign2@0.6.0, forever-agent@0.6.1, tunnel-agent@0.4.3, caseless@0.11.0, stringstream@0.0.5, isstream@0.1.2, json-stringify-safe@5.0.1, extend@3.0.0, aws4@1.4.1, node-uuid@1.4.7, combined-stream@1.0.5, qs@6.1.0, tough-cookie@2.2.2, mime-types@2.1.11, form-data@1.0.0-rc4, bl@1.1.2, http-signature@1.1.1, hawk@3.1.3, har-validator@2.0.6)
                                        ├── tar.gz@1.0.5 (commander@2.9.0, tar@2.2.1, bluebird@2.10.2, fstream@1.0.9, mout@0.11.1)
                                        └── npm@2.15.7 `
                                          einige sachen sind jetzt gestartet.
                                          ` > root@raspberrypi:/opt/iobroker# ps -A | grep io
                                          10 ? 00:00:00 migration/0
                                          11 ? 00:00:00 migration/1
                                          15 ? 00:00:00 migration/2
                                          19 ? 00:00:00 migration/3
                                          4376 ? 00:00:10 iobroker.js-con
                                          4395 ? 00:00:05 io.hm-rpc.0
                                          4406 ? 00:00:09 io.hm-rega.0
                                          4415 ? 00:00:06 io.web.0
                                          4447 ? 00:00:03 io.hm-rpc.1 `
                                          die Admin Seite kann ich aber leider noch nicht öffnen
                                            @marschmello:
                                            der cache clean hat etwas gebracht `
                                            sach bloß 😉
                                            und nu?
                                            Rainer
                                            4278
