    5. [gelöst] Gerät per Mac Adr & Blockly ansprechen
    • Aphofis
      Aphofis @fastfoot last edited by
      @fastfoot
        <variables>
          <variable id="aQubq9Vy-qj1gT{2OW;x">MAC</variable>
          <variable id="@[II(5R#h[a47`qET5k.">cmd</variable>
          <variable id="0@Y{~/hRy0d:vMQ1kCo@">url</variable>
          <variable id="Fk6H`kq}eo!FPH!Ld2Ii">result</variable>
        </variables>
        <block type="variables_set" id="Gj`MNS[$a0S:B!TUcx-%" x="38" y="138">
          <field name="VAR" id="aQubq9Vy-qj1gT{2OW;x">MAC</field>
            <block type="text" id="V?)NQY:Z1bfh@J6KO8xg">
              <field name="TEXT">2c:f4:32:57:b7:14</field>
            <block type="variables_set" id="$c5Ud:#38C(q.uOF_;YC">
              <field name="VAR" id="@[II(5R#h[a47`qET5k.">cmd</field>
                <block type="text_join" id="2t+}?FeN#iG0J=~8q#|w" inline="true">
                  <value name="ADD0">
                    <block type="text" id="w;^U.Vi%Z+6O=_j{oVD(">
                      <field name="TEXT">arp -a|grep </field>
                  <value name="ADD1">
                    <block type="variables_get" id="tH;y-cdpJdNS0#XCa8{X">
                  <value name="ADD2">
                    <block type="text" id="/t^Hm3;6![lRLzr3V@FX">
                      <field name="TEXT">|cut -f2 -d" "|cut -f2|cut -c2-16|cut -f1 -d ")"</field>
                <block type="exec" id="Ra4`1SB0/Eog44pt9iJZ" inline="true">
                  <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
                  <field name="WITH_STATEMENT">TRUE</field>
                  <field name="LOG"></field>
                  <value name="COMMAND">
                    <shadow type="text" id="@QX{2frW2vhyd`CI;c:s">
                      <field name="TEXT">arp -a|grep 24:5e:be:0d:f1:b9|cut -f2 -d" "|cut -f2|cut -c2-16|cut -f1 -d ")"</field>
                    <block type="variables_get" id="|uJ{n?p{=za?mcVLIRON">
                    <block type="variables_set" id="2;J*T*TpGNH`Ml_U^%63">
                      <field name="VAR" id="0@Y{~/hRy0d:vMQ1kCo@">url</field>
                        <block type="text_join" id="uNUY7tNxUZ3!oh#}bHXB" inline="true">
                          <value name="ADD0">
                            <block type="text" id="2GJK-1Bvmp)s6NC9.,:2">
                              <field name="TEXT">http://</field>
                          <value name="ADD1">
                            <block type="variables_get" id="/Dkdf,;.$]{U?-+%6q]I">
                              <field name="VAR" id="Fk6H`kq}eo!FPH!Ld2Ii">result</field>
                          <value name="ADD2">
                            <block type="text" id="W[)hj~HEq7,*GOK28V%|">
                              <field name="TEXT">/cm?user=benutzer&amp;passwort=passwort</field>
                        <block type="debug" id="?{mh|9:IPCBzf@bm4g=y" inline="true">
                          <value name="TEXT">
                            <shadow type="text" id="g/_Y3S(JG]HJS{wR6YI[">
                            <block type="variables_get" id="63@w*D4._cHwf:)n~#Nh">
                            <block type="update" id="QIux{@Cmil$IGVm2^=AS">
                              <field name="OID">Aqua_Control.0.IP_MAC_Abgleich.Aqua_Control</field>
                                <block type="variables_get" id="o09,K@:bm8P/u6/rKMsj">
        fastfoot @Aphofis last edited by
        @Aphofis
        Kann ich nicht nachvollziehen, steht bei mir so da. Außer: An result wird wohl noch ein LF angehangen, das sollte im Log wie ein Leerzeichen aussehen. Abhilfe schafft ein 'Entferne Leerzeichen....' Block aus Text
        Aphofis 1 Reply Last reply Reply Quote 0
        • Aphofis
          @fastfoot
          ist nur die Frage warum im Datenpunkt zweimal die IP ausgegeben wird!
          192.168.0.57192.168.0.57
          • Aphofis
            @fastfoot
            wohin muss den der block
              @Aphofis sagte in Gerät per Mac Adr & Blockly ansprechen:
              @fastfoot
               <variables>
               </variables>
                     <field name="TEXT">24:5e:be:0d:f1:b9</field>
                         <value name="ADD0">
                         <value name="ADD1">
                         <value name="ADD2">
                           <block type="variables_set" id="?iyp2/H]@8^4[PC2zLRB">
                               <block type="text_trim" id="n^cdC!!B_}1rfyX0Jf54">
                                 <field name="MODE">RIGHT</field>
                                 <value name="TEXT">
                                   <shadow type="text">
                                     <field name="TEXT">abc</field>
                                   <block type="variables_get" id=",|hfzf!Nd.fM|aAqMvS3">
                                     <value name="ADD0">
                                     <value name="ADD1">
                                     <value name="ADD2">
                                     <value name="TEXT">
                                         <field name="OID">0_userdata.0.BlocklyXML</field>
                @fastfoot
                was sagt denn der LOG, bzw wenn du den DP kopierst? Ist vlt nur eine Sache der Optik, bei mir ist das nicht! Auch nicht mit deinem Blockly
                • Aphofis
                  Aphofis @fastfoot last edited by Aphofis
                  @fastfoot sagte in Gerät per Mac Adr & Blockly ansprechen:
                  jetzt kommen fehler!!!
                  der erste Blockly war besser nur das halt im datenpunkt die IP doppelt angegeben ist
                  javascript.0	2020-06-23 23:07:29.237	warn	(31412) at Pipe._handle.close (net.js:607:12)
                  javascript.0	2020-06-23 23:07:29.237	warn	(31412) at Socket.EventEmitter.emit (domain.js:448:20)
                  javascript.0	2020-06-23 23:07:29.236	warn	(31412) at Socket.emit (events.js:198:13)
                  javascript.0	2020-06-23 23:07:29.235	warn	(31412) at Socket.stream.socket.on (internal/child_process.js:389:11)
                  javascript.0	2020-06-23 23:07:29.234	warn	(31412) at maybeClose (internal/child_process.js:982:16)
                  javascript.0	2020-06-23 23:07:29.233	warn	(31412) at ChildProcess.EventEmitter.emit (domain.js:448:20)
                  javascript.0	2020-06-23 23:07:29.232	warn	(31412) at ChildProcess.emit (events.js:198:13)
                  javascript.0	2020-06-23 23:07:29.231	warn	(31412) at ChildProcess.exithandler (child_process.js:285:7)
                  javascript.0	2020-06-23 23:07:29.230	warn	(31412) at script.js.ESP_Reboot.Aqu_Control_IP_Abfrage:10:3
                  javascript.0	2020-06-23 23:07:29.229	warn	(31412) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
                  javascript.0	2020-06-23 23:07:29.225	warn	(31412) You are assigning a string to the state "Aqua_Control.0.IP_MAC_Abgleich.Aqua_Control" which expects a number. Please fix your code to use a number or change the state type to string. This war
                  javascript.0	2020-06-23 23:07:29.224	info	192.168.0.57/cm?user=benutzer&passwort=passwort
                  javascript.0	2020-06-23 23:07:29.224	info	(31412) script.js.ESP_Reboot.Aqu_Control_IP_Abfrage: http://192.168.0.57
                  javascript.0	2020-06-23 23:07:29.188	info	(31412) script.js.ESP_Reboot.Aqu_Control_IP_Abfrage: registered 0 subscriptions and 0 schedules
                  javascript.0	2020-06-23 23:07:29.146	info	(31412) Start javascript script.js.ESP_Reboot.Aqu_Control_IP_Abfrage
                  javascript.0	2020-06-23 23:07:28.224	info	(31412) Stop script script.js.ESP_Reboot.Aqu_Control_IP_Abfrage
                  Kopierte Datenpunkt Ausgabe ist so:
                    @Aphofis
                    das liegt an deinem DP!!! auch die reine IP ist ein string und keine number. Musst du abändern, ist dann evtl auch der Grund für das doppelte Erscheinen
                    • Aphofis
                      @fastfoot
                      Ich prüfe
                      klappt nicht am besten wir machen morgen weiter!
                        @fastfoot
                        Ich prüfe
                        im RAW unter common den type von number nach string abändern, das sollte es tun
                        • Aphofis
                          @fastfoot
                          ist so trotzdessen doppelte IP
                          Aqua_Control	state     IP MAC Abgleich.Aqua_Control      state	       string			192.168.0.57 192.168.0.57
                            @fastfoot
                            und im LOG ist der Fehler weg?
                            • Aphofis
                              @fastfoot
                              In der LOG stehts so da:
                              javascript.0	2020-06-23 23:30:26.524	info	192.168.0.57
                              javascript.0	2020-06-23 23:30:26.524	info	(31412) script.js.ESP_Reboot.Aqu_Control_IP_Abfrage: http://192.168.0.57
                              javascript.0	2020-06-23 23:30:26.481	info	(31412) script.js.ESP_Reboot.Aqu_Control_IP_Abfrage: registered 0 subscriptions and 0 schedules
                              javascript.0	2020-06-23 23:30:26.456	info	(31412) Start javascript script.js.ESP_Reboot.Aqu_Control_IP_Abfrage
                              so ist es komplett ab dem stoppen
                              javascript.0	2020-06-23 23:30:26.524	info	/cm?user=benutzer&passwort=passwort
                              javascript.0	2020-06-23 23:30:25.485	info	(31412) Stop script script.js.ESP_Reboot.Aqu_Control_IP_Abfrage
                                @Aphofis
                                wenn du in den state reinklickst, ist es dann auch so? Kann eig. nicht sein
                                • Aphofis
                                    @Aphofis
                                    probier mal noch die role zu ändern
                                      "common": {
                                        "name": "Aqua_Control.0.IP_MAC_Abgleich.Aqua_Control",
                                        "role": "text",
                                        "type": "string",
                                    • Aphofis
                                      @fastfoot wird trotzdessen doppelt angezeigt
                                      • Aphofis
                                        lass uns Morgen weiter machen ich muss Augenlappenpflege machen morgen eine Stressige Grossbaustelle!
                                          ja ok, ich hätte auch nur noch eine einzige Idee, die du morgen testen kannst: ein Blockly mit nur diesem Inhalt
                                          • Aphofis
                                            @fastfoot
                                            Hatte ich heute früh getestet! Wenn nur die Aktualisierung wird nur einmal die IP angezeigt.
                                            Aber woran es liebt das die nun zweimal ausgegeben wird keine Ahnung
                                            12083
