    4. BLE-Adapter startet nicht mehr
    SOLVED BLE-Adapter startet nicht mehr
      crunchip Forum Testing Most Active @kenny384 last edited by
      @kenny384
      This adapter needs additional libraries to compile. See https://github.com/sandeepmistry/noble#prerequisites for detailed instructions.
      On Raspberry Pi and similar, this should do it: sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin
      If the adapter starts but won't connect to your bluetooth hardware, please check the info.driverState state in ioBroker. If it is unauthorized, you need to give node additional permissions. For Linux, this is as simple as
      sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
      which requires libcap2-bin to be installed.
        Ich würde nach solchen Stunts einfach das passende OS frisch neuinstallieren. Dann passen auch die Treiber zur Hardware.
          kenny384 @crunchip last edited by
          @crunchip Ich glaube das hatte ich schonmal gemacht. Von den genannten Paketen war scheinbar auch schon alles installiert. Der Befehl "sudo setcap cap_net_raw+eip $(eval readlink -f which node)" läuft so durch, aber hat auch nichts geändert. Log beim Starten vom BLE weiterhin so:
          ble.0	2020-06-24 15:58:07.288	info	(30522) Terminated (NO_ERROR): Without reason
          ble.0	2020-06-24 15:58:07.286	info	(30522) terminating
          ble.0	2020-06-24 15:58:07.237	error	at process._tickCallback (internal/process/next_tick.js:61:11)
          ble.0	2020-06-24 15:58:07.237	error	at process.nextTick (/opt/iobroker/node_modules/@abandonware/noble/lib/noble.js:60:24)
          ble.0	2020-06-24 15:58:07.237	error	at NobleBindings.init (/opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/bindings.js:78:13)
          ble.0	2020-06-24 15:58:07.237	error	at Hci.init (/opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/hci.js:100:35)
          ble.0	2020-06-24 15:58:07.237	error	(30522) Error: ENODEV, No such device
          ble.0	2020-06-24 15:58:07.236	error	(30522) uncaught exception: ENODEV, No such device
          ble.0	2020-06-24 15:58:06.954	info	(30522) monitored services: fe95
          ble.0	2020-06-24 15:58:06.952	info	(30522) enabled plugins: Xiaomi, _default
          ble.0	2020-06-24 15:58:06.950	info	(30522) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
          ble.0	2020-06-24 15:58:06.783	info	(30522) starting. Version 0.11.6 in /opt/iobroker/node_modules/iobroker.ble, node: v10.21.0, js-controller: 3.1.4
            A Former User @kenny384 last edited by
            @kenny384 hmm vielleicht in der config bluetooth deaktiviert?
            in der /boot/config.text schauen ob bluetooth disabled ist..
            crunchip K 2 Replies Last reply Reply Quote 0
              crunchip Forum Testing Most Active @Guest last edited by
              @ilovegym wollte ich auch gerade schreiben.
              Und nach den Befehlen, System neu starten
                kenny384 @Guest last edited by kenny384
                @ilovegym Finde keine Einstellung die BT disabled haben könnte. Oder übersehe ich etwas? Die allerletzte Zeile finde ich aber interessant. Ist das richtig so? Habe einen Pi4.
                #hdmi_mode=1
                # uncomment to force a HDMI mode rather than DVI. This can make audio work in
                # DMT (computer monitor) modes
                #hdmi_drive=2
                # uncomment to increase signal to HDMI, if you have interference, blanking, or
                # no display
                #config_hdmi_boost=4
                # uncomment for composite PAL
                #sdtv_mode=2
                #uncomment to overclock the arm. 700 MHz is the default.
                #arm_freq=800
                # Uncomment some or all of these to enable the optional hardware interfaces
                #dtparam=i2c_arm=on
                #dtparam=i2s=on
                #dtparam=spi=on
                # Uncomment this to enable the lirc-rpi module
                #dtoverlay=lirc-rpi
                # Additional overlays and parameters are documented /boot/overlays/README
                # Enable audio (loads snd_bcm2835)
                dtparam=audio=on
                enable_uart=1
                [pi4]
                # Enable DRM VC4 V3D driver on top of the dispmanx display stack
                dtoverlay=vc4-fkms-v3d
                max_framebuffers=2
                [all]
                #dtoverlay=vc4-fkms-v3d
                dtoverlay=pi3-miniuart-bt-overlay
                harrym 1 Reply Last reply Reply Quote 0
                • harrym
                  harrym @kenny384 last edited by
                  @kenny384 sagte in BLE-Adapter startet nicht mehr:
                  dtoverlay=miniuart-bt .... sollte das jetzt sein, mWn
                    kenny384 @harrym last edited by
                    @harrym Habe ich testweise mal ganz unten drunter gesetzt und die Zeile darüber auskommentiert. Neustart --> Leider keine Veränderung
                    Ich habe noch folgenden Befehl im Netz gefunden und mal ausgeführt:
                    pi@ioBroker-RasPi4:~ $ systemctl status hciuart.service
                    ● hciuart.service - Configure Bluetooth Modems connected by UART
                       Loaded: loaded (/lib/systemd/system/hciuart.service; enabled; vendor preset: enabled)
                       Active: failed (Result: exit-code) since Wed 2020-06-24 16:25:35 CEST; 10min ago
                      Process: 365 ExecStart=/usr/bin/btuart (code=exited, status=1/FAILURE)
                    Jun 24 16:25:05 ioBroker-RasPi4 systemd[1]: Starting Configure Bluetooth Modems connected by UART...
                    Jun 24 16:25:35 ioBroker-RasPi4 btuart[365]: Initialization timed out.
                    Jun 24 16:25:35 ioBroker-RasPi4 btuart[365]: bcm43xx_init
                    Jun 24 16:25:35 ioBroker-RasPi4 systemd[1]: hciuart.service: Control process exited, code=exited, status=1/FAILURE
                    Jun 24 16:25:35 ioBroker-RasPi4 systemd[1]: hciuart.service: Failed with result 'exit-code'.
                    Jun 24 16:25:35 ioBroker-RasPi4 systemd[1]: Failed to start Configure Bluetooth Modems connected by UART.
                      @kenny384 Ei jo, wenn du dein bluetooth device verschiebst, dann isses nicht mehr, wo es sein soll 🙂
                      schau mal hier
                      https://forum.homegear.eu/t/bluetooth-ohne-funktion-nach-dtoverlaypi3-miniuart-bt/2013/7
                        @ilovegym Puuh, das bekomme ich irgendwie nicht hin. Ich habe die config.txt jetzt so (Auszug), aber das hat nichts verändert:
                        dtparam=audio=on
                        enable_uart=1
                        [pi4]
                        max_framebuffers=2
                        [all]
                        core_freq=250
                        Hinter dem dtoverlay=pi3-miniuart-bt stand vorher noch -overlay. Das habe ich im Beispiel oben weggenommen, hat aber auch nichts verändert.
                          kenny384 @kenny384 last edited by
                          Die in dem verlinkten Thread beschriebene hciuart.service sieht bei mir so aus:
                          [Unit]
                          Description=Configure Bluetooth Modems connected by UART
                          ConditionFileNotEmpty=/proc/device-tree/soc/gpio@7e200000/bt_pins/brcm,pins
                          Requires=dev-serial1.device
                          After=dev-serial1.device
                          [Service]
                          Type=forking
                          [Install]
                          WantedBy=multi-user.target
                            Noch jemand eine Idee? @crunchip @harrym @ilovegym ?
                              @kenny384
                              neue SD-Karte, und nochmal von Anfang an.. irgendwo ist da was geschossen.. normal ist bluetooth kein Thema und auch nicht deaktiviert.
                                @ilovegym Okay, muss ich dann wohl tun, wenn ich mal die Zeit habe. Liegt bestimmt daran, dass das System ursprünglich mal auf einem Raspi 3 erstellt wurde, dann auf einen Raspi 4 umgezogen ist und jetzt noch von SD auf SSD. Kennt man ja aus dem echten Leben: Bei jedem Umzug geht irgendwas verloren und/oder kaputt 😉
                                ? haselchen 2 Replies Last reply Reply Quote 0
                                  @kenny384 ahh okay..
                                  oder alles was bluetooth angeht, deinstallieren und noch mal neu.. aber bevor du dir ne bestehende installation müllst.. lieber ne andere Karte rein... und ganz neu frisch aufgesetzt.
                                  • haselchen
                                    haselchen Most Active @kenny384 last edited by
                                    @kenny384
                                    Ich misch mal mit 🙂
                                    Gib mal
                                    sudo service bluetooth status
                                    ein
                                      kenny384 @haselchen last edited by
                                      @haselchen sagte in BLE-Adapter startet nicht mehr:
                                      pi@ioBroker-RasPi4:~ $ sudo service bluetooth status
                                      ● bluetooth.service - Bluetooth service
                                         Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
                                         Active: inactive (dead)
                                           Docs: man:bluetoothd(8)
                                      Jun 24 16:53:02 ioBroker-RasPi4 systemd[1]: Condition check resulted in Bluetooth service being skipped.
                                      • haselchen
                                        @kenny384
                                        sudo service bluetooth start
                                        dann nochmal
                                          Oh, das sieht erstmals gar nicht schlecht aus:
                                             Active: active (running) since Fri 2020-06-26 14:00:54 CEST; 6s ago
                                           Main PID: 6514 (bluetoothd)
                                             Status: "Running"
                                              Tasks: 1 (limit: 4915)
                                             Memory: 1.9M
                                             CGroup: /system.slice/bluetooth.service
                                                     └─6514 /usr/lib/bluetooth/bluetoothd
                                          Jun 26 14:00:54 ioBroker-RasPi4 systemd[1]: Starting Bluetooth service...
                                          Jun 26 14:00:54 ioBroker-RasPi4 bluetoothd[6514]: Bluetooth daemon 5.50
                                          Jun 26 14:00:54 ioBroker-RasPi4 systemd[1]: Started Bluetooth service.
                                          Jun 26 14:00:54 ioBroker-RasPi4 bluetoothd[6514]: Starting SDP server
                                          Jun 26 14:00:54 ioBroker-RasPi4 bluetoothd[6514]: Bluetooth management interface 1.14 initialized
                                            Der BLE Adapter startet allerdings weiterhin nicht mit der selben Fehlermeldung wie bisher (siehe oben)
                                            • haselchen
                                              @kenny384
                                              was sagt
                                              sudo bluetoothctl
                                              ble adapter node npm error umzug
                                              4786
