    4. Modbus adapter
    Modbus adapter
      lstorm last edited by
      @wendy2702 :Danke für den Hinweis. Habe nun die Modbus Instanz auf Debug gestellt. Leider ist der Log auch nicht viel aussagekräftiger.
      Hier der Log von Version 3.0.0. Zuerst läuft die Kommunikation noch, dann kommt der Timeout.
      modbus.0	2020-04-13 11:19:58.842	debug	(819) connect to serial /dev/ttyUSB0 with 9600
      modbus.0	2020-04-13 11:18:58.846	debug	(819) Cleaning up request fifo.
      modbus.0	2020-04-13 11:18:58.845	debug	(819) Clearing timeout of the current request.
      modbus.0	2020-04-13 11:18:58.839	info	(819) Disconnected from slave
      modbus.0	2020-04-13 11:18:57.838	warn	(819) Poll error count: 2 code: {"err":"timeout"}
      modbus.0	2020-04-13 11:18:57.837	error	(819) Request timed out.
      modbus.0	2020-04-13 11:18:57.835	warn	(819) Error: undefined
      modbus.0	2020-04-13 11:18:52.833	debug	(819) Poll inputRegs DevID(1) address 0 - 88 bytes
      modbus.0	2020-04-13 11:18:52.831	debug	(819) Poll device 1
      modbus.0	2020-04-13 11:18:52.828	info	(819) Connected to slave
      modbus.0	2020-04-13 11:18:52.819	debug	(819) connect to serial /dev/ttyUSB0 with 9600
      modbus.0	2020-04-13 11:17:52.824	debug	(819) Cleaning up request fifo.
      modbus.0	2020-04-13 11:17:52.823	debug	(819) Clearing timeout of the current request.
      modbus.0	2020-04-13 11:17:52.815	info	(819) Disconnected from slave
      modbus.0	2020-04-13 11:17:51.813	warn	(819) Poll error count: 1 code: {"err":"timeout"}
      modbus.0	2020-04-13 11:17:51.811	error	(819) Request timed out.
      modbus.0	2020-04-13 11:17:51.809	warn	(819) Error: undefined
      modbus.0	2020-04-13 11:17:46.805	debug	(819) Poll inputRegs DevID(1) address 0 - 88 bytes
      modbus.0	2020-04-13 11:17:46.804	debug	(819) Poll device 1
      modbus.0	2020-04-13 11:17:45.643	debug	(819) Poll inputRegs DevID(1) address 334 - 48 bytes
      modbus.0	2020-04-13 11:17:45.459	debug	(819) Poll inputRegs DevID(1) address 224 - 46 bytes
      modbus.0	2020-04-13 11:17:45.389	debug	(819) Poll inputRegs DevID(1) address 200 - 8 bytes
      modbus.0	2020-04-13 11:17:45.337	debug	(819) Poll inputRegs DevID(1) address 100 - 8 bytes
      modbus.0	2020-04-13 11:17:45.014	debug	(819) Poll inputRegs DevID(1) address 0 - 88 bytes
      modbus.0	2020-04-13 11:17:45.013	debug	(819) Poll device 1
      modbus.0	2020-04-13 11:17:43.852	debug	(819) Poll inputRegs DevID(1) address 334 - 48 bytes
      modbus.0	2020-04-13 11:17:43.678	debug	(819) Poll inputRegs DevID(1) address 224 - 46 bytes
      modbus.0	2020-04-13 11:17:43.606	debug	(819) Poll inputRegs DevID(1) address 200 - 8 bytes
      modbus.0	2020-04-13 11:17:43.553	debug	(819) Poll inputRegs DevID(1) address 100 - 8 bytes
      modbus.0	2020-04-13 11:17:43.233	debug	(819) Poll inputRegs DevID(1) address 0 - 88 bytes
      modbus.0	2020-04-13 11:17:43.231	debug	(819) Poll device 1
      Hier der Log mit Version 3.0.1 Modbus Adapter bleibt gelb:
      modbus.0	2020-04-13 12:01:57.100	info	(1126) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.modbus, node: v10.20.0
      modbus.0	2020-04-13 12:01:56.275	debug	(1126) statesDB connected
      modbus.0	2020-04-13 12:01:56.272	debug	(1126) States connected to redis: 192.168.0.117:9000
      modbus.0	2020-04-13 12:01:56.248	debug	(1126) States create System PubSub Client
      modbus.0	2020-04-13 12:01:56.236	debug	(1126) States create User PubSub Client
      modbus.0	2020-04-13 12:01:56.216	debug	(1126) Redis States: Use Redis connection: 192.168.0.117:9000
      modbus.0	2020-04-13 12:01:56.207	debug	(1126) objectDB connected
      modbus.0	2020-04-13 12:01:56.183	debug	(1126) Objects connected to redis: 192.168.0.117:9001
      modbus.0	2020-04-13 12:01:56.145	debug	(1126) Objects client initialize lua scripts
      modbus.0	2020-04-13 12:01:56.142	debug	(1126) Objects create User PubSub Client
      modbus.0	2020-04-13 12:01:56.138	debug	(1126) Objects create System PubSub Client
      modbus.0	2020-04-13 12:01:56.122	debug	(1126) Objects client ready ... initialize now
      modbus.0	2020-04-13 12:01:55.991	debug	(1126) Redis Objects: Use Redis connection: 192.168.0.117:9001
      host.iobroker2	2020-04-13 12:01:53.219	info	instance system.adapter.modbus.0 started with pid 1126
      host.iobroker2	2020-04-13 12:01:51.344	info	instance system.adapter.modbus.0 terminated with code 156 (156)
      host.iobroker2	2020-04-13 12:01:50.682	info	stopInstance system.adapter.modbus.0 send kill signal
      modbus.0	2020-04-13 12:01:50.654	info	(1111) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      modbus.0	2020-04-13 12:01:50.648	info	(1111) terminating
      modbus.0	2020-04-13 12:01:50.640	info	(1111) Got terminate signal TERMINATE_YOURSELF
      • ChristianM
        ChristianM @lstorm last edited by
        @lstorm Zeig doch mal deine Konfiguration, hab auch den SDM630 hier am laufen allerdings mit einem Modbus TCP Gateway. Sollte aber vom Prinzip her identisch sein.
        • ChristianM
          ChristianM last edited by
          Aber wo wir gerade bei Problemen sind. Gibt es bei dem Modbus irgendeine Adressen Beschränkung ? ab Holdingregister 8300 werden komische Register abgefragt.modbus problem.png
          • wendy2702
            wendy2702 last edited by
            Die erste Adresse Im Log kommt mir komisch hoch vor.
              lstorm last edited by lstorm
              @ChristianM hier meine Konfig.
              Wie schon geschrieben, damit läuft es auch immer mal wieder ne halbe Stunde und dann get der Modbus Adapter auf den Status "Verbunden mit Modbus = falsch".
              • ChristianM
                  mittlerweile habe ich meine SDM630 einigermaßen stabil laufen. Es fehlen in unregelmäßigen Abständen immer mal wieder 2 Minuten Daten. Nun habe ich von solch einem Moment mal den Log im Debugmode mitgeschnitten.
                  Vielleicht hat von euch noch einer eine Idee. Ich hab übrigens mittlerweile die Version 3.0.4 laufen.
                  Der Log beinhaltet den Moment wo noch Daten kommen bis zu dem Moment, wo er wohl den Adater komplett neu startet und dann auch wieder Daten kommen.
                  modbus.0	2020-06-05 17:15:17.317	debug	(3203) Poll inputRegs DevID(1) address 334 - 48 bytes
                  modbus.0	2020-06-05 17:15:17.125	debug	(3203) Poll inputRegs DevID(1) address 224 - 46 bytes
                  modbus.0	2020-06-05 17:15:17.050	debug	(3203) Poll inputRegs DevID(1) address 200 - 8 bytes
                  modbus.0	2020-06-05 17:15:16.984	debug	(3203) Poll inputRegs DevID(1) address 100 - 8 bytes
                  modbus.0	2020-06-05 17:15:16.895	debug	(3203) Poll inputRegs DevID(1) address 80 - 8 bytes
                  modbus.0	2020-06-05 17:15:16.563	debug	(3203) Poll inputRegs DevID(1) address 0 - 80 bytes
                  modbus.0	2020-06-05 17:15:16.558	debug	(3203) Poll device 1
                  modbus.0	2020-06-05 17:15:16.553	info	(3203) Connected to slave
                  modbus.0	2020-06-05 17:15:16.525	debug	(3203) connect to serial /dev/ttyUSB0 with 9600
                  modbus.0	2020-06-05 17:15:13.713	info	(3203) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.modbus, node: v12.18.0, js-controller: 3.1.4
                  modbus.0	2020-06-05 17:14:39.180	info	(3182) Terminated (NO_ERROR): Without reason
                  modbus.0	2020-06-05 17:14:39.176	info	(3182) terminating
                  modbus.0	2020-06-05 17:14:39.168	debug	(3182) Cleaning up request fifo.
                  modbus.0	2020-06-05 17:14:39.166	debug	(3182) Clearing timeout of the current request.
                  modbus.0	2020-06-05 17:14:39.151	error	(3182) Error: Reconnect did not help, restart adapter at pollResult (/opt/iobroker/node_modules/iobroker.modbus/lib/master.js:254:23) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker
                  modbus.0	2020-06-05 17:14:39.147	error	(3182) uncaught exception: Reconnect did not help, restart adapter
                  modbus.0	2020-06-05 17:14:39.139	warn	(3182) Poll error count: 13 code: "App Timeout"
                  modbus.0	2020-06-05 17:14:35.407	debug	(3182) Poll inputRegs DevID(1) address 0 - 80 bytes
                  modbus.0	2020-06-05 17:14:35.405	debug	(3182) Poll device 1
                  modbus.0	2020-06-05 17:14:35.403	info	(3182) Connected to slave
                  modbus.0	2020-06-05 17:14:35.397	debug	(3182) connect to serial /dev/ttyUSB0 with 9600
                  modbus.0	2020-06-05 17:14:33.401	debug	(3182) Cleaning up request fifo.
                  modbus.0	2020-06-05 17:14:33.399	debug	(3182) Clearing timeout of the current request.
                  modbus.0	2020-06-05 17:14:33.393	info	(3182) Disconnected from slave
                  modbus.0	2020-06-05 17:14:33.387	warn	(3182) Poll error count: 12 code: "App Timeout"
                  modbus.0	2020-06-05 17:14:28.939	debug	(3182) Poll inputRegs DevID(1) address 0 - 80 bytes
                  modbus.0	2020-06-05 17:14:28.937	debug	(3182) Poll device 1
                  modbus.0	2020-06-05 17:14:28.934	info	(3182) Connected to slave
                  modbus.0	2020-06-05 17:14:28.928	debug	(3182) connect to serial /dev/ttyUSB0 with 9600
                  modbus.0	2020-06-05 17:14:26.930	debug	(3182) Cleaning up request fifo.
                  modbus.0	2020-06-05 17:14:26.928	debug	(3182) Clearing timeout of the current request.
                  modbus.0	2020-06-05 17:14:26.923	info	(3182) Disconnected from slave
                  modbus.0	2020-06-05 17:14:26.919	warn	(3182) Poll error count: 11 code: "App Timeout"
                  modbus.0	2020-06-05 17:14:23.186	debug	(3182) Poll inputRegs DevID(1) address 0 - 80 bytes
                  modbus.0	2020-06-05 17:14:23.185	debug	(3182) Poll device 1
                  modbus.0	2020-06-05 17:14:23.182	info	(3182) Connected to slave
                  modbus.0	2020-06-05 17:14:23.175	debug	(3182) connect to serial /dev/ttyUSB0 with 9600
                  modbus.0	2020-06-05 17:14:21.178	debug	(3182) Cleaning up request fifo.
                  modbus.0	2020-06-05 17:14:21.176	debug	(3182) Clearing timeout of the current request.
                  modbus.0	2020-06-05 17:14:21.170	info	(3182) Disconnected from slave
                  modbus.0	2020-06-05 17:14:21.167	warn	(3182) Poll error count: 10 code: "App Timeout"
                  modbus.0	2020-06-05 17:14:16.719	debug	(3182) Poll inputRegs DevID(1) address 0 - 80 bytes
                  modbus.0	2020-06-05 17:14:16.717	debug	(3182) Poll device 1
                  modbus.0	2020-06-05 17:14:16.715	info	(3182) Connected to slave
                  modbus.0	2020-06-05 17:14:16.707	debug	(3182) connect to serial /dev/ttyUSB0 with 9600
                  modbus.0	2020-06-05 17:14:14.712	debug	(3182) Cleaning up request fifo.
                  modbus.0	2020-06-05 17:14:14.710	debug	(3182) Clearing timeout of the current request.
                  modbus.0	2020-06-05 17:14:14.703	info	(3182) Disconnected from slave
                  modbus.0	2020-06-05 17:14:14.699	warn	(3182) Poll error count: 9 code: "App Timeout"
                  modbus.0	2020-06-05 17:14:10.965	debug	(3182) Poll inputRegs DevID(1) address 0 - 80 bytes
                  modbus.0	2020-06-05 17:14:10.964	debug	(3182) Poll device 1
                  modbus.0	2020-06-05 17:14:10.961	info	(3182) Connected to slave
                  modbus.0	2020-06-05 17:14:10.955	debug	(3182) connect to serial /dev/ttyUSB0 with 9600
                  modbus.0	2020-06-05 17:14:08.960	debug	(3182) Cleaning up request fifo.
                  modbus.0	2020-06-05 17:14:08.958	debug	(3182) Clearing timeout of the current request.
                  modbus.0	2020-06-05 17:14:08.950	info	(3182) Disconnected from slave
                  modbus.0	2020-06-05 17:14:08.946	warn	(3182) Poll error count: 8 code: "App Timeout"
                  modbus.0	2020-06-05 17:14:04.499	debug	(3182) Poll inputRegs DevID(1) address 0 - 80 bytes
                  modbus.0	2020-06-05 17:14:04.497	debug	(3182) Poll device 1
                  modbus.0	2020-06-05 17:14:04.495	info	(3182) Connected to slave
                  modbus.0	2020-06-05 17:14:04.488	debug	(3182) connect to serial /dev/ttyUSB0 with 9600
                  modbus.0	2020-06-05 17:14:02.491	debug	(3182) Cleaning up request fifo.
                  modbus.0	2020-06-05 17:14:02.490	debug	(3182) Clearing timeout of the current request.
                  modbus.0	2020-06-05 17:14:02.484	info	(3182) Disconnected from slave
                  modbus.0	2020-06-05 17:14:02.481	warn	(3182) Poll error count: 7 code: "App Timeout"
                  modbus.0	2020-06-05 17:13:58.745	debug	(3182) Poll inputRegs DevID(1) address 0 - 80 bytes
                  modbus.0	2020-06-05 17:13:58.744	debug	(3182) Poll device 1
                  modbus.0	2020-06-05 17:13:58.741	info	(3182) Connected to slave
                  modbus.0	2020-06-05 17:13:58.734	debug	(3182) connect to serial /dev/ttyUSB0 with 9600
                  modbus.0	2020-06-05 17:13:56.739	debug	(3182) Cleaning up request fifo.
                  modbus.0	2020-06-05 17:13:56.737	debug	(3182) Clearing timeout of the current request.
                  modbus.0	2020-06-05 17:13:56.731	info	(3182) Disconnected from slave
                  modbus.0	2020-06-05 17:13:56.727	warn	(3182) Poll error count: 6 code: "App Timeout"
                  modbus.0	2020-06-05 17:13:52.281	debug	(3182) Poll inputRegs DevID(1) address 0 - 80 bytes
                  modbus.0	2020-06-05 17:13:52.279	debug	(3182) Poll device 1
                  modbus.0	2020-06-05 17:13:52.277	info	(3182) Connected to slave
                  modbus.0	2020-06-05 17:13:52.271	debug	(3182) connect to serial /dev/ttyUSB0 with 9600
                  modbus.0	2020-06-05 17:13:50.275	debug	(3182) Cleaning up request fifo.
                  modbus.0	2020-06-05 17:13:50.274	debug	(3182) Clearing timeout of the current request.
                  modbus.0	2020-06-05 17:13:50.269	info	(3182) Disconnected from slave
                  modbus.0	2020-06-05 17:13:49.269	warn	(3182) Poll error count: 5 code: {"err":"timeout"}
                  modbus.0	2020-06-05 17:13:49.268	error	(3182) Request timed out.
                  modbus.0	2020-06-05 17:13:49.266	warn	(3182) Error: undefined
                  modbus.0	2020-06-05 17:13:46.526	debug	(3182) Poll inputRegs DevID(1) address 0 - 80 bytes
                  modbus.0	2020-06-05 17:13:46.525	debug	(3182) Poll device 1
                  modbus.0	2020-06-05 17:13:45.521	warn	(3182) Poll error count: 4 code: "App Timeout"
                  modbus.0	2020-06-05 17:13:39.263	debug	(3182) Poll inputRegs DevID(1) address 0 - 80 bytes
                  modbus.0	2020-06-05 17:13:39.261	debug	(3182) Poll device 1
                  modbus.0	2020-06-05 17:13:39.259	info	(3182) Connected to slave
                  modbus.0	2020-06-05 17:13:39.253	debug	(3182) connect to serial /dev/ttyUSB0 with 9600
                  modbus.0	2020-06-05 17:13:37.257	debug	(3182) Cleaning up request fifo.
                  modbus.0	2020-06-05 17:13:37.255	debug	(3182) Clearing timeout of the current request.
                  modbus.0	2020-06-05 17:13:37.249	info	(3182) Disconnected from slave
                  modbus.0	2020-06-05 17:13:36.249	warn	(3182) Poll error count: 3 code: {"err":"timeout"}
                  modbus.0	2020-06-05 17:13:36.248	error	(3182) Request timed out.
                  modbus.0	2020-06-05 17:13:36.247	warn	(3182) Error: undefined
                  modbus.0	2020-06-05 17:13:35.320	debug	(3182) Poll inputRegs DevID(1) address 0 - 80 bytes
                  modbus.0	2020-06-05 17:13:35.318	debug	(3182) Poll device 1
                  modbus.0	2020-06-05 17:13:34.315	warn	(3182) Poll error count: 2 code: "App Timeout"
                  modbus.0	2020-06-05 17:13:26.243	debug	(3182) Poll inputRegs DevID(1) address 0 - 80 bytes
                  modbus.0	2020-06-05 17:13:26.242	debug	(3182) Poll device 1
                  modbus.0	2020-06-05 17:13:26.239	info	(3182) Connected to slave
                  modbus.0	2020-06-05 17:13:26.231	debug	(3182) connect to serial /dev/ttyUSB0 with 9600
                  modbus.0	2020-06-05 17:13:24.238	debug	(3182) Cleaning up request fifo.
                  modbus.0	2020-06-05 17:13:24.236	debug	(3182) Clearing timeout of the current request.
                  modbus.0	2020-06-05 17:13:24.227	info	(3182) Disconnected from slave
                  modbus.0	2020-06-05 17:13:24.115	debug	(3182) Poll inputRegs DevID(1) address 0 - 80 bytes
                  modbus.0	2020-06-05 17:13:24.113	debug	(3182) Poll device 1
                  modbus.0	2020-06-05 17:13:23.223	error	(3182) Request timed out.
                  modbus.0	2020-06-05 17:13:23.220	warn	(3182) Error: undefined
                  modbus.0	2020-06-05 17:13:23.109	warn	(3182) Poll error count: 1 code: "App Timeout"
                  modbus.0	2020-06-05 17:13:13.216	debug	(3182) Poll inputRegs DevID(1) address 80 - 8 bytes
                  modbus.0	2020-06-05 17:13:12.907	debug	(3182) Poll inputRegs DevID(1) address 0 - 80 bytes
                  modbus.0	2020-06-05 17:13:12.906	debug	(3182) Poll device 1
                  modbus.0	2020-06-05 17:13:11.741	debug	(3182) Poll inputRegs DevID(1) address 334 - 48 bytes
                  modbus.0	2020-06-05 17:13:11.561	debug	(3182) Poll inputRegs DevID(1) address 224 - 46 bytes
                  modbus.0	2020-06-05 17:13:11.490	debug	(3182) Poll inputRegs DevID(1) address 200 - 8 bytes
                  modbus.0	2020-06-05 17:13:11.434	debug	(3182) Poll inputRegs DevID(1) address 100 - 8 bytes
                  modbus.0	2020-06-05 17:13:11.376	debug	(3182) Poll inputRegs DevID(1) address 80 - 8 bytes
                  modbus.0	2020-06-05 17:13:11.074	debug	(3182) Poll inputRegs DevID(1) address 0 - 80 bytes
                  modbus.0	2020-06-05 17:13:11.072	debug	(3182) Poll device 1
                  modbus.0	2020-06-05 17:13:09.910	debug	(3182) Poll inputRegs DevID(1) address 334 - 48 bytes
                  modbus.0	2020-06-05 17:13:09.728	debug	(3182) Poll inputRegs DevID(1) address 224 - 46 bytes
                  modbus.0	2020-06-05 17:13:09.655	debug	(3182) Poll inputRegs DevID(1) address 200 - 8 bytes
                  modbus.0	2020-06-05 17:13:09.598	debug	(3182) Poll inputRegs DevID(1) address 100 - 8 bytes
                  modbus.0	2020-06-05 17:13:09.540	debug	(3182) Poll inputRegs DevID(1) address 80 - 8 bytes
                  modbus.0	2020-06-05 17:13:09.230	debug	(3182) Poll inputRegs DevID(1) address 0 - 80 bytes
                  modbus.0	2020-06-05 17:13:09.228	debug	(3182) Poll device 1
                    Mehmet Tarhan last edited by Mehmet Tarhan
                    Edit: Hab eine Verbindung herstellen können. Mit anderem Programm. Wollte nur die richtige Konfiguration wissen und die Kommunikation zwischen Adapter und ESP.
                    Schöne Grüße
                    Hallo Leute,
                    ich versuche seit Tagen mit meinem NodeMcu esp8266 Board eine Verbindung zu herstellen über ModBus. Leider haut es nicht hin. Habe alles mögliche ausprobiert. Iobroker-Modbus adapter ist Master und NodeMcu als Sk eingestellt.
                    Eigentlich will ich meine Garage damit steuern mit rs485. Die Garage ist weit weg, mit Wlan ist unmöglich, bricht immer wieder ab. Ich hab mich noch nie mit Modbus befasst. Bin sehr dankbar für alle mögliche Tips oder Hinweise
                    Gruss Memo.
                    Hier ist das Programm mit Arduino-IDE geschrieben für Esp8266.
                      Modbus-Arduino Beispiel - Lampe (Modbus Serial)
                      Copyright by André Sarmento Barbosa
                      http://github.com/andresarmento/modbus-arduino
                    #include <ModbusRTU.h>
                    #define SLAVE_ID 1
                    // Modbus registriert Offsets (0-9999)
                    const  int LAMP1_COIL = 100 ;
                    // Verwendete Pins
                    const  int ledPin = 0 ;
                    // ModbusSerial Objekt
                    ModbusRTU mb;
                    void  setup () {
                        // Modbus Serial konfigurieren (Port, Geschwindigkeit, Byte-Format)
                        Serial.begin(9600, SERIAL_8N1);
                        mb.begin(&Serial);
                        // Setze die Slave ID (1-247)
                        mb.slave(SLAVE_ID);
                        // LEDPin-Modus einstellen
                        pinMode (ledPin, OUTPUT);
                        // LAMP1_COIL-Register hinzufügen - Verwenden Sie addCoil () für digitale Ausgänge
                        mb. addCoil (LAMP1_COIL);
                    void  loop () {
                       // Einmal in loop () aufrufen - alles Magie hier
                       mb. task ();
                       // füge ledPin an das LAMP1_COIL Register an
                       digitalWrite (ledPin, mb. Coil (LAMP1_COIL));
                    Und hier ist mein Steckboard mit NodeMcu
                    Modbus Konfiguration
                    Iobroker Log
                      Leo84 last edited by
                      ich bin neu hier und erstmal Danke für den klasse Modbus Adapter!
                      Ich habe meine Heizung ETA PC40 per Modbus TCP angebunden und kann hier auch mehrere Register auslesen.
                      Allerdings kann ich nur ca. 10 Register auslesen, wenn ich mehr versuche zu lesen bricht der Modbus zusammen und er wird rot.
                      Dann immer wieder gelb grün und sofort wieder rot.
                      Sobald ich die auszulesenden Register reduziere werd der Bus wieder Grün.
                      Ich habe das ganze auch mit Node Red getestet, hier kann ich ohne Probleme wesentlich mehr Register auslesen. Ich habe auch die Zeiten geändert, leider alles ohne Erfolg.
                      Habt ihr noch einen Rat?
                      Vielen Dank für eure Hilfe.
                        peterfido last edited by
                        ich nutze auch Node-Red für Modbus. Mit dem Modus Adapter kam ich auf keinen grünen Zweig.
                        Allerdings klappte es bei Node-Red auch nicht auf Anhieb. Ich musste mehrere USB-RS 485 Adapter probieren, bis endlich einer durchlief. Allerdings klappt es auch mit diesem Stick nicht per Modbus Adapter.
                        Somit spricht für mich nichts dagegen bei Node-Red zu bleiben.
                        Wenn der Umbau weitergeht, will ich den Modbus per TCP anbinden. Dann probiere ich es nochmal mit dem Modbus Adapter. Das dauert allerdings noch etwas.
                          cmoehler @Bluefox last edited by
                          @Bluefox
                          Re: Modbus adapter
                          Hallo Zusammen,
                          vielen Dank für diesen tollen Adapter 👍
                          Da ich bei meinem CELSA WECM80-E M das RegSet1 verwende, bin ich leider auch mit Signed 64 bit (Big Endian) Werten konfrontiert.
                          Leider habe ich im Adapter aber nur Unsigned 64 als Auswahlmöglichkeit gefunden. Oder habe ich da etwas übersehen 🤔 ?
                          Falls nicht, könnte man das dann eventuell noch implementieren? Ansonsten müsste ich halt, vor dem weiterverarbeiten der entsprechenden Werte, selbst von UINT64 nach INT64 umwandeln, was aber unschön wäre da in den Objekten dann ja, bei negatieven Werten, riesige Zahlen stehen würden.
                          Vielen Dank für eure Antworten.
                            cmoehler @cmoehler last edited by cmoehler
                            @cmoehler
                            Ich antworte mir mal selbst:
                            doublebe - Double ist wohl der richtige Typ ... habe ich wohl übersehen 😬
                            Allerdings erhalte ich ich bei Double leider immer 0 zurück. Da mache ich wohl immer noch etwas falsch ... aber was ??? 🙄
                            Falls mir jemand auf die Sprünge helfen kann, schon einmal vielen Dank im Voraus.
                            Hier noch die Definition im Adapter und die entsprechenden Objekte:
                            definition modbus (2 x gleichen Register mit unterschiedlichem Datentyp):
                            inhalt der beiden Objekte:
                            QModMaster
                            • O
                              onkel-ede @cmoehler last edited by
                              ich habe 2 Instanzen des Modbus-Adapter im Einsatz (1xWechselrichter PV-Anlage, 1x Batteriewechselrichter).
                              Läuft seit ca. 1 Jahr alles prima.
                              Habe nach Neuinstallation des gesamten Systems Probleme, deren Ursache (Zeitpunkt/Versionen) ich leider nicht mehr nachvollziehen kann.
                              Ich berechne den Gesamtverbrauch des Hauses mit:
                              Alle Werte aus dem Adapter in kWh, da quasi Zählerstände.
                              Ich ziehe vom PV-Ertrag die Batterieladung und die Netzeinspeisung ab und addiere die Batteieentladung und den Netzbezug auf.
                              Funktioniert auch tadellos.
                              Der Adapter setzt die Werte für PV-Ertrag, Batterie(ent-)ladung um Mitternacht auf "0", weshalb meine Berechnung durcheinanderkommt.
                              PV-Ertrag:
                              Batterieladung:
                              Batterie-Entladung:
                              Die "0"-Werte machen ja bei dem "Zählerstand" keinen Sinn. Kann ich in den Einstellungen des Adapters verhindern, dass die "0"-Werte geschrieben werden?
                              Viele Grüße
                              onkel-ede
                              • O
                                onkel-ede @onkel-ede last edited by
                                Ich habe es erstmal so gelöst, indem ich eigene Datenpunkte angelegt habe, in die ich die Werte bereinigt schreibe. Also wenn Wert > 0, dann schriebe in Datenpunkt.
                                Mit diesen Datenpunkten berechne ich dann den Gesamtverbrauch des Hauses.
                                  TimoS. @Umsteiger last edited by TimoS.
                                  @Umsteiger Hast du dein Gerät irgendwie mit dem Modbusadapter ansprechen können? Mein Gerät akzeptiert immer noch keine Werte. Es kann definitiv nur etwas mit FC16 anfangen.
                                  EDIT: Habe einen weg gefunden: https://github.com/ioBroker/ioBroker.modbus/issues/54
                                  Wenn man in der master.js (Version 3.1.4) die Zeile:
                                  if (objects[id].native.len > 1 && !options.config.doNotUseWriteMultipleRegisters) {
                                  auskommentiert bzw. löscht und stattdessen:
                                  if ( !options.config.doNotUseWriteMultipleRegisters) {
                                  nutzt, funktioniert es mit dem Schreiben eines Wertes.
                                  TmShaz created this issue in ioBroker/ioBroker.modbus
                                  closed Write Multiple Registers #54
                                    Habedere last edited by Habedere
                                    Servus zusammen,
                                    weiß nicht ob das Problem schon mal angesprochen wurde, aber bei mir stehen in den Objekten andere ID´s als im Eingangsregister des Adapters.
                                    Jemand eine Idee woran das liegen kann?!
                                    EDIT: Problem gefunden bzw. Logik. In den Objekten wird jede ID eine Stufe tiefer erstellt!!
                                    Aus 30002 wird dann 30001. Wtf?!
                                    PS: wenn ich die Werte im Eingangsregister eintrage, übernimmt er die Nummern auch nicht, sondern zählt fortlaufend weiter...
                                    • O
                                      oliver2017 @Habedere last edited by
                                      @Habedere
                                      Ich habe eine neue Heizung bekommen die ich nun einbinden wollte, da dachte das ist ja einfach es gibt ja schon einen Adapter. Den ganzen Tag probiere ich es.
                                      Mit ModBus Scanner die Adressen ausgelesen ob die laut Hersteller auch stimmen. Klappte auch ohne Probleme, nur im Adapter lief das nicht. Bis mir eben aufgefallen ist, dass wenn man den Adapter STOPPT und die Werte nun ändert und danach den Adapter wieder aktiviert, läuft alles wie es soll und der liest auch die richtigen Werte aus von der richtigen Adresse.
                                      K H 2 Replies Last reply Reply Quote 1
                                        klassisch Most Active @oliver2017 last edited by
                                        @oliver2017 Danke, gut zu wissen.
                                          Habedere @oliver2017 last edited by
                                          @oliver2017 sagte in Modbus adapter:
                                          @Habedere
                                          Hmm aber der Adapter macht ja automatisch einen restart wenn man etwas ändert oder?
                                            peterfido @Habedere last edited by
                                            möglich, dass die Pause beim Neustart nicht reicht, um den Modbus in einen definierten | stabilen Zustand zu bekommen.
                                            modbus modbus adapter
                                            140
                                            978
                                            369233
