      exv2 last edited by
      Hallo
      ich versuche seit Tagen die Sonnenschutzfunktion zum arbeiten zu überreden leider gänzlich ohne Erfolg.
      Ich bin jetzt am ende und finde meinen Fehler nicht. Kann im eventuell einer helfen.
      Was wird benötigt um zu helfen?
      Diese Zeile im Log ist für mich unverständlich.
      EG Wohnzimmer Fenster: Check basis for sunprotect. Height:0 > HeightDownSun: 80 AND Height:0 == currentHeight:0 AND currentHeight:0 == heightUp:0
      "native": {
          "livingAutomatic": "livingSunriseSunset",
          "W_shutterDownLiving": "22:00",
          "W_shutterUpLivingMin": "07:00",
          "W_shutterUpLivingMax": "07:30",
          "driveDelayUpLiving": "10",
          "WE_shutterDownLiving": "22:00",
          "WE_shutterUpLivingMin": "08:00",
          "WE_shutterUpLivingMax": "09:00",
          "sleepAutomatic": "sleepSunriseSunset",
          "W_shutterDownSleep": "22:00",
          "W_shutterUpSleepMin": "07:00",
          "W_shutterUpSleepMax": "07:30",
          "driveDelayUpSleep": "10",
          "WE_shutterDownSleep": "22:00",
          "WE_shutterUpSleepMin": "08:00",
          "WE_shutterUpSleepMax": "09:00",
          "latitude": "52.71439660",
          "longitude": "13.27626290",
          "astroDelayUp": "30",
          "astroDelayDown": "30",
          "driveDelayUpAstro": "10",
          "sunProtEndElevation": "10",
          "HolidayDP": "",
          "triggerAutoSleep": "",
          "triggerAutoLiving": "",
          "LateAllDown": false,
          "LateAllDownTime": "",
          "SummerStart": "01.03.",
          "SummerEnd": "30.09.",
          "currentShutterState": false,
          "publicHolidays": true,
          "publicHolInstance": "feiertage.0",
          "heightDownSun": "80",
          "direction": "120",
          "type": "only outside temperature",
          "directionRange": "50",
          "actualValueTemp": "hm-rega.0.2640",
          "actualValueLight": "zigbee.0.04cf8cdf3c787eff.illuminance",
          "actualValueTempInside": "",
          "typeDown": "living",
          "typeUp": "living",
          "triggerStateShutter": "true",
          "triggerChangeShutter": "off",
          "triggerDriveShutter": "100",
          "autoDriveShutter": "off",
          "heightDownShutter": "100",
          "heightUpShutter": "0",
          "triggerID": "",
          "LateDown": false,
          "inSummerNotDown": false,
          "events": [
              "enabled": true,
              "shutterName": "EG Wohnzimmer Fenster",
              "name": "homepilot20.0.Actuator.2-14234511.Position",
              "triggerID": "",
              "typeUp": "living",
              "direction": "120",
              "tempInside": "23",
              "tempSensor": "",
              "outsideTempSensor": "hm-rega.0.2640",
              "tempOutside": "23",
              "lightSensor": "zigbee.0.04cf8cdf3c787eff.illuminance",
              "valueLight": "30000",
              "heightUp": "0",
              "heightDown": "100",
              "triggerState": "true",
              "triggerDrive": "100",
              "triggerChange": "off",
              "elevation": "",
              "autoDrive": "off",
              "hysteresisOutside": "0",
              "hysteresisInside": "5",
              "hysteresisLight": "0",
              "currentAction": "",
              "currentHeight": "",
              "oldHeight": "",
              "firstCompleteUp": "",
              "triggerHeight": "",
              "LateDown": false,
        andi2055 @exv2 last edited by
        @exv2
        Das ist das Log der Prüfung, ob der Sonnenschutz angefahren werden soll
        -> Aktuelle Höhe ist 0. Diese ist KLEINER als 80 und damit FALSE und deshalb wird kein Sonnenschutz angefahren
        Normalerweise ist es so als Beispiel: Rollladen auf 100% = AUF
        Sonnenschutzhöhe = 30% = "fast zu"
        wenn die anderen Kriterien erfüllt sind, dann wird der Sonnenschutz angefahren.
        Kann es sein, dass bei dir offen/geschlossen vertauscht ist? Also offen = 0%
          exv2 @andi2055 last edited by
          @andi2055
          Ah OK Danke
          bei mir ist hoch 0% und runter 100%
          Für das normale hoch und runter fahren funktioniert das ganze.
          Mal sehen was ich da machen kann.
            @simatec
            Darf aktuell auf/zu so über die Einstellungen beliebig festgelegt werden (laut Einstellung ist es möglich).
            Ist das so vorgesehen?
            Beim Sonnenschutz wird und wurde das so nicht berücksichtigt mit den kleiner/größer Vergleichen
            Ist das nur beim Sonnenschutz ein Problem?
            Bug oder Feature-Request?
              @andi2055
              Es ist nur beim Sonnenschutz das Problem. Aber ich habe noch einen inverten DP dann muss ich den nehmen und die Einstellungen anpassen.
              Ich versuche das dann mal und gebe bescheid ob es dann klappt.
              Ich habe Gurtwickler von Rademacher und diese per Homepilot20 in ioBroker.
              • simatec
                simatec Developer Most Active @exv2 last edited by
                @exv2 sagte in Test Adapter shuttercontrol v0.6.x:
                Ja entweder so, oder mit der Alias Funktion von iobroker.
                Shuttercontrol benötigt für die Funktion 0% = geschlossen und 100% = offen
                • tobasium
                  tobasium last edited by
                  Guten Morgen,
                  ich hab ein komisches Problem. Meine Rolladen fahren Teilweise den Sonnenschutz andere nicht. Was übersehe ich?
                  Eigentlich sollte dieser Rolladen Morgens runterfahren, das tut er aber nicht.
                  Rolladen die Himmelsrichtung 210 haben fahren bei mir Mittags ganz normal.
                  Woran könnte dies liegen?
                  Ich verzweifle langsam.
                  Danke vorab
                    exv2 @simatec last edited by
                    @simatec
                    habe gestern den inverten DP eingestellt.
                    Runter und hoch fahre haben geklappt.
                    Runterfahren zur Beschattung hat auch geklappt. nur der Rollladen fährt nicht wieder hoch.
                    Der Sollwert ist 30000 und wir haben seit einer Stunde nur noch werte um 2000.
                    Anbei die Configuration. Ich mache bestimmt was falsch.
                    "native": {
                        "sunProtEndElevation": "65",
                        "HolidayDP": "",
                        "heightDownSun": "20",
                        "direction": "120",
                        "typeUp": "living",
                        "heightDownShutter": "0",
                        "heightUpShutter": "100",
                        "triggerID": "",
                        "LateDown": false,
                        "events": [
                            "enabled": true,
                            "shutterName": "Position_inverted EG Wohnzimmer Fenster",
                            "name": "homepilot20.0.Actuator.2-14234511.Position_inverted",
                            "triggerID": "",
                            "typeUp": "living",
                            "direction": "120",
                            "tempInside": "23",
                            "tempSensor": "",
                            "heightUp": "100",
                            "heightDown": "0",
                            "elevation": "",
                            "autoDrive": "off",
                            "hysteresisLight": "5",
                            "oldHeight": "",
                            "LateDown": false,
                    • simatec
                      @exv2
                      Ich kann mich erinnern, dass hier mal ein User einen Bug gemeldet hat.
                      Bin aber nicht sicher, ob der behoben wurde.
                      Trage mal den Lichtsensor bei Außentemperatur ein und die Werte dann dementsprechend auch.
                      Eventuell ist da ein fehler beim Lichtsensor
                      B E 2 Replies Last reply Reply Quote 0
                        bishop @simatec last edited by
                        @simatec
                        in der log steht
                        "autoDrive": "off",
                        sollte da nicht "updown" stehen damit er fährt?
                          @simatec
                          Habe ich pobehalber mal getauscht aber keine reaktion.
                          Noch ne andere Idee?
                            andi2055 @tobasium last edited by
                            @tobasium
                            Ich habe einen meiner Rollladen gestern testweise auf ähnliche Werte gestellt. Dieser ist heute Morgen korrekt in den Sonnenschutz gefahren.
                            Stelle deinen doch mal exakt so ein wie dein anderer, der funktioniert. Oder du hast mit diesem einen Rollladen irgendein anderes Problem?!
                            @simatec
                            Ich habe dir einen PR gesendet für den Bug von exv2. Ungetestet, aber ich denke das ist das Problem
                            • simatec
                              Ab sofort ist die Version 0.7.2 auf Github und auch im latest verfügbar ...
                              Changelog
                              0.7.2 (2020-06-26)
                              • (simatec) Bugfix sunprotect for outsidetemp
                              • (simatec) better translation for all languages
                              • (simatec) better overview in the user interface
                                steimi last edited by steimi
                                Irgendwie hat sich bei mir ein Fehler eingeschlichen. Ich habe eingestellt das er in der Arbeitswoche spätestens 21:30 die Rollos runterfahren soll, am Wochenende um 22:00. Heute am Freitag hat er die Rollos um 21:51 runter gefahren, statt um 21:30 - 21:31 war Sonnenuntergang und ich habe eine Verzögerung von 20 Minuten. Vorigen Sonntag hat er die Rollos um 21:30 runtergefahren, obwohl mMn ja noch Wochenende ist. Scheint so als zählen Fr/Sa zum Wochenende und nicht Sa/So.
                                Ist das richtig so oder habe ich ein Verständnisproblem?
                                Dabei kommt gleich der Wunsch/Gedanke auf die Tage für die Wochenende-Schaltung konfigurierbar zu machen.
                                system.adapter.shuttercontrol.0.json
                                • simatec
                                  simatec Developer Most Active @steimi last edited by
                                  @steimi
                                  Freitag gehört beim runterfahren zum Wochenende und Sonntag beim runterfahren zur Arbeitswoche
                                  • 2
                                    2hot4you last edited by
                                    Mir ist mit Version 0.7.2 folgendes aufgefallen.
                                    Jalousien sind im Sonnenschutz bei > 14.000 lux hochgefahren, obwohl in den Einstellungen
                                    der Sollwert bei 9000 und die Hysterese bei 40 steht
                                    Die Türen habe ich mit einen Homatic Fenstergriff Kontakt überwacht. Wenn die Tür abends offen steht, geht die Jalousie nicht runter, was auch so gewollt ist, jedoch wenn ich morgens die Tür schließe, fährt die Jalousie herunter . Beide Türen stehen bei Art der Steuerung auf Wohnbereich und Schlafbereich (Automatik)
                                    FredF simatec 2 Replies Last reply Reply Quote 0
                                    • FredF
                                      FredF Most Active Forum Testing @2hot4you last edited by
                                      @2hot4you
                                      @simatec
                                      Ich verstehe das bei Sollwert 9000 und Hysterese 40 so:
                                      Sonnenschutz aktiv ab 5400
                                      Sonnenschutz inaktiv ab 12600
                                      • simatec
                                        simatec Developer Most Active @2hot4you last edited by
                                        @2hot4you
                                        Bitte mache mal genaue Angaben zu deiner Config
                                        2 1 Reply Last reply Reply Quote 0
                                        • simatec
                                          simatec Developer Most Active @FredF last edited by
                                          @FredF
                                          Nein die Hysterese greift nur nach unten.
                                          Größer 9000 Lux geht der Rollladen in Sonnenschutz.
                                          Um Schwankungen abzufangen, gibt es dann die Hysterese nach unten, damit der Rollladen nicht ständig hoch und runter fährt
                                          • FredF
                                            FredF Most Active Forum Testing @simatec last edited by
                                            @simatec
                                            Also im Fall von 2hot4you:
                                            Der Sonnenschutz ist aktiv ab 9000 Lux und bleibt aktiv bis der Wert unter 5400 Lux fällt
                                            332
                                            7408
                                            10584714
