    4. [HowTo] ioBroker unter Docker auf Synology DiskStation
      Teemoe @andre last edited by
      @andre said in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
      Bitte versuche es mal mit der aktuellen Beta-Version. Da ist bereits ein Fix drin.
      Ich bleibe an gleicher Stelle hängen. Allerdings handelt es sich bei mir um Windows 10 (2004) mit Docker. Die Beta habe ich ebenso ausprobiert.
      PS C:\Users\admin> docker run -p 8081:8081 --name iobroker -v iobrokerdata:/opt/iobroker buanet/iobroker:beta
      Unable to find image 'buanet/iobroker:beta' locally
      beta: Pulling from buanet/iobroker
      e9afc4f90ab0: Already exists
      f75876172ace: Pull complete
      a8017f6d0b34: Pull complete
      cff9d5526f24: Pull complete
      b39ce5b512b8: Pull complete
      850295f3ec6e: Pull complete
      bba795283710: Pull complete
      e224ea9ae0c9: Pull complete
      cbe5d9419cc9: Pull complete
      bbdf66708177: Pull complete
      1db0105cd3f7: Pull complete
      ba5989988bb7: Pull complete
      fbbfbe797064: Pull complete
      bee3036abe02: Pull complete
      9ef38f7af53d: Pull complete
      ae286c690b97: Pull complete
      ebf4f11b7405: Pull complete
      Digest: sha256:452a3e8c802186b8fadf8f824a152e2cf23e59de3c54e7b75bcd86bf46efdf07
      Status: Downloaded newer image for buanet/iobroker:beta
      ---------------     2020-06-24 20:42:12      ---------------
      -----       Welcome to your ioBroker-container!        -----
      -----          Startupscript is now running.           -----
      -----                Please be patient!                -----
      -----              Debugging information               -----
      -----                      System                      -----
      -----               arch:      x86_64                  -----
      -----                     Versions                     -----
      -----               image:     v4.2.4beta              -----
      -----               node:      v12.18.1                -----
      -----               npm:       6.14.5                  -----
      -----                       ENV                        -----
      -----               SETGID:    1000                    -----
      -----               SETUID:    1000                    -----
      -----         Step 1 of 5: Preparing container         -----
      Nothing to do here.
      -----   Step 2 of 5: Detecting ioBroker installation   -----
      Existing installation of ioBroker detected in /opt/iobroker.
      -----   Step 3 of 5: Checking ioBroker installation    -----
      (Re)Setting folder permissions (This might take a while! Please be patient!)...
      Done.
      Fixing "sudo-bug" by replacing sudo in iobroker with gosu...
      Done.
      Hostname in ioBroker does not match the hostname of this container.
      Updating hostname to  d72b708e1eb2...
      No instances found for host "a2e2a3097bbf"!
      Done.
      -----      Step 4 of 5: Applying special settings      -----
      Some adapters have special requirements/ settings which can be activated by the use of environment variables.
      For more information take a look at readme.md on Github!
      -----          Step 5 of 5: ioBroker startup           -----
      Starting ioBroker...
      host.d72b708e1eb2 check instance "system.adapter.admin.0" for host "a2e2a3097bbf"
      host.d72b708e1eb2 check instance "system.adapter.discovery.0" for host "a2e2a3097bbf"
      host.d72b708e1eb2 check instance "system.adapter.info.0" for host "a2e2a3097bbf"
      • andre
        andre Developer @Teemoe last edited by
        @Teemoe sagte in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
        Machst du ne Datenübernahme? Falls ja, musst du den js-controller vorab auf mind. v3.1.5 bringen weil sonst das Umbenennen nicht funktioniert:
        Done.
        Wenn du kein ioBroker-Verzeichnis einer anderen/ vorherigen Installation übernehmen willst, dann versuche es mal mit einem leeren ioBroker-Verzeichnis.
        MfG,
        André
        • Negalein
          Negalein Global Moderator last edited by Negalein
          Ich habe seit einem Stromausfall Probleme den ioBroker-Container zu starten.
          Es wird am MACVLAN gemeckert.
          Docker-API fehlgeschlagen. Weitere Informationen finden sie im Docker-Protokoll.
          Im Protokoll steht dann Start container ioBroker_V3 failed: {"message":"failed to create the macvlan port: device or resource busy"}..
          Altes MACVLAN löschen und neues erstellen hat nichts gebracht.
          Was kann ich noch versuchen?
          Synology_Nega_3 - Synology DiskStation.png Synology_Nega_3 - Synology DiskStation (1).png
          • Glasfaser
            Glasfaser @Negalein last edited by
            @Negalein
            Starte die Synology nochmal neu ..
            hatte ich letztenz auch zweimal das der Container so wie bei dir mit der Meldung zusammengebrochen ist ....
            Fehler habe ich diesbezüglich noch nicht gefunden .
            Nur das im Absturzmoment die CPU längere Zeit zu 100% belastet ist .
            • Negalein
              Negalein Global Moderator @Glasfaser last edited by
              @Glasfaser sagte in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
              Ok, versuche es mit Neustart Nr. 3
              • Glasfaser
                Glasfaser @Negalein last edited by Glasfaser
                @Negalein sagte in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
                Neustart Nr. 3
                Uhii ... hatt ich nicht erlesen 😉 , dann ist es wohl was anderes 🤔 😠 da du es ja schon selber mit einem Neustart Versucht hast .
                Schalte den Container aus und dann einen Neustart ... und dann wenn alles hochgefahren ist den Container wieder starten !?
                • Negalein
                  So, das Teil läuft wieder.
                  Im MACVLAN hab ich jetzt nicht eth1 als Schnittstelle eingetragen, sondern ovs_eth1. Mit eth1lief er nicht!
                  Wo das ovshergekommen ist, kein Ahnung.
                  xxxxxxxx@Synology_Nega_3:/$ ifconfig
                  docker0   Link encap:Ethernet  HWaddr 02:42:FF:89:10:31
                            inet addr:172.17.0.1  Bcast:172.17.255.255  Mask:255.255.0.0
                            inet6 addr: fe80::42:ffff:fe89:1031/64 Scope:Link
                            UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
                            RX packets:2508 errors:0 dropped:0 overruns:0 frame:0
                            TX packets:3493 errors:0 dropped:0 overruns:0 carrier:0
                            collisions:0 txqueuelen:0
                            RX bytes:308865 (301.6 KiB)  TX bytes:8323857 (7.9 MiB)
                  docker885 Link encap:Ethernet  HWaddr 16:64:6B:DB:35:C1
                            inet6 addr: fe80::1464:6bff:fedb:35c1/64 Scope:Link
                            RX packets:220 errors:0 dropped:0 overruns:0 frame:0
                            TX packets:317 errors:0 dropped:0 overruns:0 carrier:0
                            RX bytes:186603 (182.2 KiB)  TX bytes:115574 (112.8 KiB)
                  docker60c Link encap:Ethernet  HWaddr DA:13:C2:6E:63:13
                            inet6 addr: fe80::d813:c2ff:fe6e:6313/64 Scope:Link
                            RX packets:123 errors:0 dropped:0 overruns:0 frame:0
                            TX packets:133 errors:0 dropped:0 overruns:0 carrier:0
                            RX bytes:11676 (11.4 KiB)  TX bytes:44687 (43.6 KiB)
                  dockera56 Link encap:Ethernet  HWaddr 1A:A7:31:32:21:DD
                            inet6 addr: fe80::18a7:31ff:fe32:21dd/64 Scope:Link
                            RX packets:37 errors:0 dropped:0 overruns:0 frame:0
                            TX packets:56 errors:0 dropped:0 overruns:0 carrier:0
                            RX bytes:3000 (2.9 KiB)  TX bytes:17977 (17.5 KiB)
                  eth0      Link encap:Ethernet  HWaddr 00:11:32:90:7A:1C
                            RX packets:164113 errors:0 dropped:0 overruns:0 frame:0
                            TX packets:126803 errors:0 dropped:0 overruns:0 carrier:0
                            collisions:0 txqueuelen:1000
                            RX bytes:79519245 (75.8 MiB)  TX bytes:24042644 (22.9 MiB)
                  eth1      Link encap:Ethernet  HWaddr 00:11:32:90:7A:1D
                            RX packets:20439 errors:0 dropped:0 overruns:0 frame:0
                            TX packets:511 errors:0 dropped:0 overruns:0 carrier:0
                            RX bytes:3520665 (3.3 MiB)  TX bytes:154080 (150.4 KiB)
                  lo        Link encap:Local Loopback
                            inet addr:127.0.0.1  Mask:255.0.0.0
                            inet6 addr: ::1/128 Scope:Host
                            UP LOOPBACK RUNNING  MTU:65536  Metric:1
                            RX packets:109394 errors:0 dropped:0 overruns:0 frame:0
                            TX packets:109394 errors:0 dropped:0 overruns:0 carrier:0
                            RX bytes:15553552 (14.8 MiB)  TX bytes:15553552 (14.8 MiB)
                  ovs_eth0  Link encap:Ethernet  HWaddr 00:11:32:90:7A:1C
                            inet addr:10.0.1.22  Bcast:10.0.1.255  Mask:255.255.255.0
                            inet6 addr: fe80::211:32ff:fe90:7a1c/64 Scope:Link
                            RX packets:156645 errors:0 dropped:0 overruns:0 frame:0
                            TX packets:117835 errors:0 dropped:0 overruns:0 carrier:0
                            RX bytes:76808413 (73.2 MiB)  TX bytes:23515813 (22.4 MiB)
                  ovs_eth1  Link encap:Ethernet  HWaddr 00:11:32:90:7A:1D
                            inet addr:10.0.1.23  Bcast:10.0.1.255  Mask:255.255.255.0
                            inet6 addr: fe80::211:32ff:fe90:7a1d/64 Scope:Link
                            RX packets:19379 errors:0 dropped:0 overruns:0 frame:0
                            TX packets:518 errors:0 dropped:0 overruns:0 carrier:0
                            RX bytes:3159711 (3.0 MiB)  TX bytes:154630 (151.0 KiB)
                  • RK62
                    RK62 @andre last edited by
                    @andre v4.2.4beta (2020-06-23)
                    • Update im Testsystem gefahren
                    • Danach Update js-controller auf 3.1.6. eingespielt.
                    • Starten und Beenden über Docker-Console läuft auch problemlos.
                    Danke, Ralf
                    • andre
                      andre Developer @Negalein last edited by
                      @Negalein Hast du vielleicht kürzlich den Virtual Machine Manager aktiviert?
                      • andre
                        andre Developer @RK62 last edited by
                        @RK62 Danke für das Feedback!
                        • Negalein
                          Negalein Global Moderator @andre last edited by
                          @andre sagte in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
                          Ja, der läuft auch seit kurzem.
                          • andre
                            @Negalein Dann weißt du jetzt wo das ovs hergekommen ist.
                            ovs = Open Vswitch
                            MfG,
                            André
                            • Negalein
                              Ah ok!
                              Und durch das ist dann der eth1 nach einem Neustart der DS nicht mehr aktiv und dafür der ovs?
                                markuslommer last edited by Negalein
                                Hallo Andre,
                                hier nun das komplette Log, wie im v3 Anleitungsthread requested:
                                Nach Ausführung ist die Instanz unter ihrer IP Adresse nicht erreichbar.
                                Kannst du daraus erkennen, wo das Problem liegt?
                                Viele Grüße
                                Markus
                                ---------------     2020-06-27 08:04:44      ---------------
                                -----                      System                      -----
                                -----                       ENV                        -----
                                -----               AVAHI:     false                   -----
                                -----               PACKAGES:  nano                    -----
                                Installing additional packages is set by ENV.
                                The following packages will be installed: nano...
                                debconf: unable to initialize frontend: Dialog
                                debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
                                debconf: falling back to frontend: Readline
                                debconf: unable to initialize frontend: Readline
                                debconf: (This frontend requires a controlling tty.)
                                debconf: falling back to frontend: Teletype
                                dpkg-preconfigure: unable to re-open stdin:
                                Vormals nicht ausgewähltes Paket nano wird gewählt.
                                (Lese Datenbank ...
                                (Lese Datenbank ... 5%
                                (Lese Datenbank ... 10%
                                (Lese Datenbank ... 15%
                                (Lese Datenbank ... 20%
                                (Lese Datenbank ... 25%
                                (Lese Datenbank ... 30%
                                (Lese Datenbank ... 35%
                                (Lese Datenbank ... 40%
                                (Lese Datenbank ... 45%
                                (Lese Datenbank ... 50%
                                (Lese Datenbank ... 55%
                                (Lese Datenbank ... 60%
                                (Lese Datenbank ... 65%
                                (Lese Datenbank ... 70%
                                (Lese Datenbank ... 75%
                                (Lese Datenbank ... 80%
                                (Lese Datenbank ... 85%
                                (Lese Datenbank ... 90%
                                (Lese Datenbank ... 95%
                                (Lese Datenbank ... 100%
                                (Lese Datenbank ... 25565 Dateien und Verzeichnisse sind derzeit installiert.)
                                Vorbereitung zum Entpacken von .../archives/nano_3.2-3_amd64.deb ...
                                Entpacken von nano (3.2-3) ...
                                nano (3.2-3) wird eingerichtet ...
                                update-alternatives: /bin/nano wird verwendet, um /usr/bin/editor (editor) im automatischen Modus bereitzustellen
                                update-alternatives: /bin/nano wird verwendet, um /usr/bin/pico (pico) im automatischen Modus bereitzustellen
                                Done.
                                Done.
                                Done.
                                Updating hostname to  iobroker...
                                A host with the name "iobroker" already exists!
                                Done.
                                host.iobroker check instance "system.adapter.admin.0" for host "a2e2a3097bbf"
                                host.iobroker check instance "system.adapter.discovery.0" for host "a2e2a3097bbf"
                                host.iobroker check instance "system.adapter.info.0" for host "a2e2a3097bbf"
                                Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
                                Hier gehts zur Hilfe.
                                revil.o andre 2 Replies Last reply Reply Quote 0
                                • revil.o
                                  revil.o @markuslommer last edited by revil.o
                                  @markuslommer hihi zusammen, dasselbe problem wie Markus hab ich jetzt seit 2 stunden auch. Selbst das Host ( wobei ich davon ausgehe, dass das eine geclearte Mac-Adresse ist ) host "a2e2a3097bbf" stimmt bei mir überein.
                                  kleiner logAuszug nach der frischen Installation auf der Syno (WebUI is not reachable):
                                  gibts vielleicht Probleme bei 2 aktivierten Netzwerkschnittstellen? das 172er netz ist ja vom DockerContainer
                                  2020-06-29 15:45:27.698  - info: host.iobroker iobroker.js-controller version 3.1.4 js-controller starting
                                  2020-06-29 15:45:27.708  - info: host.iobroker Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
                                  2020-06-29 15:45:27.709  - info: host.iobroker hostname: iobroker, node: v10.21.0
                                  2020-06-29 15:45:27.712  - info: host.iobroker ip addresses: 192.168.1.10 192.168.1.32  172.17.0.1
                                  2020-06-29 15:45:27.820  - info: host.iobroker connected to Objects and States
                                  2020-06-29 15:45:28.056  - info: host.iobroker Delete host system.host.dsm.local
                                  2020-06-29 15:45:28.059  - info: host.iobroker Delete state "system.host.dsm.local.plugins.sentry.enabled"
                                  2020-06-29 15:45:28.060  - info: host.iobroker Delete state "system.host.dsm.local.compactModeEnabled"
                                  2020-06-29 15:45:28.061  - info: host.iobroker Delete state "system.host.dsm.local.compactgroupProcesses"
                                  2020-06-29 15:45:28.062  - info: host.iobroker Delete state "system.host.dsm.local.instancesAsProcess"
                                  2020-06-29 15:45:28.063  - info: host.iobroker Delete state "system.host.dsm.local.instancesAsCompact"
                                  2020-06-29 15:45:28.065  - info: host.iobroker Delete state "system.host.dsm.local.cpu"
                                  2020-06-29 15:45:28.066  - info: host.iobroker Delete state "system.host.dsm.local.cputime"
                                  2020-06-29 15:45:28.067  - info: host.iobroker Delete state "system.host.dsm.local.mem"
                                  2020-06-29 15:45:28.068  - info: host.iobroker Delete state "system.host.dsm.local.memHeapUsed"
                                  2020-06-29 15:45:28.069  - info: host.iobroker Delete state "system.host.dsm.local.memAvailable"
                                  2020-06-29 15:45:28.070  - info: host.iobroker Delete state "system.host.dsm.local.memHeapTotal"
                                  2020-06-29 15:45:28.071  - info: host.iobroker Delete state "system.host.dsm.local.memRss"
                                  2020-06-29 15:45:28.073  - info: host.iobroker Delete state "system.host.dsm.local.uptime"
                                  2020-06-29 15:45:28.074  - info: host.iobroker Delete state "system.host.dsm.local.load"
                                  2020-06-29 15:45:28.075  - info: host.iobroker Delete state "system.host.dsm.local.alive"
                                  2020-06-29 15:45:28.077  - info: host.iobroker Delete state "system.host.dsm.local.freemem"
                                  2020-06-29 15:45:28.078  - info: host.iobroker Delete state "system.host.dsm.local.inputCount"
                                  2020-06-29 15:45:28.079  - info: host.iobroker Delete state "system.host.dsm.local.outputCount"
                                  2020-06-29 15:45:28.080  - info: host.iobroker Delete state "system.host.dsm.local.eventLoopLag"
                                  2020-06-29 15:45:28.080  - info: host.iobroker Delete state "system.host.dsm.local.logLevel"
                                  2020-06-29 15:45:28.081  - info: host.iobroker Delete state "system.host.dsm.local.diskSize"
                                  2020-06-29 15:45:28.082  - info: host.iobroker Delete state "system.host.dsm.local.diskFree"
                                  2020-06-29 15:45:28.082  - info: host.iobroker Delete state "system.host.dsm.local.diskWarning"
                                  2020-06-29 15:45:28.097  - info: host.iobroker 3 instances found
                                  2020-06-29 15:45:28.106  - warn: host.iobroker does not start any instances on this host
                                  VG Olly
                                  • andre
                                    andre Developer @markuslommer last edited by
                                    @markuslommer sagte in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
                                    Machst du eine Neuinstallation oder willst du Daten übernehmen? Falls es eine Neuinstallation ist,
                                    starte mal bitte mit einem leeren Verzeichnis für /opt/iobroker.
                                    MfG,
                                    André
                                    revil.o M 2 Replies Last reply Reply Quote 0
                                    • revil.o
                                      revil.o @andre last edited by
                                      @andre hi andre, das ist eine Neuinstallation mit leerem /opt/iobroker - Directory ... habs eben nochmal komplett von der grünen wiese aus gestartet... selbes verhalten.
                                      • andre
                                        andre Developer @revil.o last edited by
                                        @revil-o Ein Auszug aus dem Log bringt mir nichts. Bitte das gesamte Log aus dem Container posten.
                                        @revil-o sagte in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
                                        Falsch. "a2e2a3097bbf" ist ein Hostname aus dem build Prozess des Images. Auf diesen Namen sind die Adapter beim start gebunden und durch ein renaming der ioBroker Instanz wird dies durch das startup Script kotrrigiert...
                                        MfG,
                                        André
                                        • andre
                                          Wenn ich das recht erinnere habe ich Markus geantwortet. Bei dir ist leider kein Log dabei... Also kann ich dazu auch nichts sagen...
                                          MfG,
                                          André
                                            markuslommer @andre last edited by
                                            @andre es handelt sich um eine clean install nach deiner Anleitung. Zuvor hatte ich die Anleitung mit ioBroker direkt in dokker versucht, diese threads aber wieder gelöscht, nachdem ich gelesen hatte, dass die Anleitung outdated war.
                                            81.1k
                                            buanet diskstation docker iobroker synology
                                            248
                                            2854
                                            1546253
