    3. Entwicklung
    4. Adapter: broadlink2
    Adapter: broadlink2
      muckel @frankjoke last edited by
      @frankjoke
      Hallo Frank!
      Falls es dich interressiert:
      Temperatur und Feuchte werden auch bei mir nicht angezeigt. Ich brauch es aber auch nicht.
      broadlink2.0	2020-06-24 19:02:43.385	info	(8842) found macs: 24:df:a7:d3:27:57, 24:df:a7:7a:b0:5f
      broadlink2.0	2020-06-24 19:02:43.384	info	(8842) broadlink2.0 started and found 2 devices named RM:Broadlink_RM4Pro, RM:Broadlink_RM3Mini
      broadlink2.0	2020-06-24 19:02:41.174	info	(8842) discover [ '192.168.0.140' ] from 0.0.0.0:53133
      broadlink2.0	2020-06-24 19:02:41.172	info	(8842) Unrecoverable Send packet error The device storage is full on RM4, RM:Broadlink_RM3Mini, 24:df:a7:7a:b0:5f, 192.168.0.140
      broadlink2.0	2020-06-24 19:02:41.052	warn	(8842) Invalid State without name or 'on' string: { name: '', on: '', off: '' }
      broadlink2.0	2020-06-24 19:02:35.269	info	(8842) Device RM:Broadlink_RM3Mini dedected: address=192.168.0.140, mac=24:df:a7:7a:b0:5f, typ=rm4, id=0x5f36 devtype=RM Mini 3
      broadlink2.0	2020-06-24 19:02:35.239	info	(8842) Device RM:Broadlink_RM4Pro dedected: address=192.168.0.141, mac=24:df:a7:d3:27:57, typ=rm4p, id=0x6026 devtype=RM4 Pro
      broadlink2.0	2020-06-24 19:02:34.829	info	(8842) discover [ '192.168.0.255', '255.255.255.255', '224.0.0.251' ] from 0.0.0.0:56611
      broadlink2.0	2020-06-24 19:02:34.771	info	(8842) Discover Broadlink devices for 10sec on broadlink2.0
      broadlink2.0	2020-06-24 19:02:34.769	info	(8842) macObjects: []
      broadlink2.0	2020-06-24 19:02:34.769	info	}:
      broadlink2.0	2020-06-24 19:02:34.769	info	(8842) interface to be used: { netmaskBits: 24, address: '192.168.0.230/24', addrs: [ 192, 168, 0, 230 ], cidr: '192.168.0.230/24', bcaddr: '192.168.0.255'
      broadlink2.0	2020-06-24 19:02:34.767	info	(8842) broadlink2 has 0 old devices!
      broadlink2.0	2020-06-24 19:02:34.767	info	(8842) Devices to rename:
      broadlink2.0	2020-06-24 19:02:34.766	info	(8842) Devices to add: []
      broadlink2.0	2020-06-24 19:02:34.766	info	(8842) Scanning additional IP's:
      broadlink2.0	2020-06-24 19:02:34.764	info	(8842) broadlink2 initialization started...
      broadlink2.0	2020-06-24 19:02:34.688	info	(8842) starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v12.16.2, js-controller: 3.1.6
      broadlink2.0	2020-06-24 19:02:31.660	info	(20478) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      broadlink2.0	2020-06-24 19:02:31.660	info	(20478) terminating
      broadlink2.0	2020-06-24 19:02:31.659	info	(20478) Adapter disconnected and stopped with dostop(null) and callback(true)
      Liebe Grüße Erich
      frankjoke 1 Reply Last reply Reply Quote 0
      • frankjoke
        frankjoke @muckel last edited by
        @muckel , @MathiasJ
        Ich nehme an ihr habt keinen RM4 Pro, sondern normal RM4 oder Minis, dort geht es nicht.
        @Dischro hat sogar berichtet dass er ein spezielles Kabel dafür braucht, kenne das gar nicht 😞
        Mein RM4 Mini kann nix, mein alter RM Pro kann nur Temperatur.
        M D 2 Replies Last reply Reply Quote 0
          @frankjoke
          Ja, ich habe zwei minis: RM4miniPro und RM3mini.
          Seit unserer letzten Testsession funktioniert alles bestens. 🙂
          Mein Kino tschäckt jetzt mit einem Knopfdruck > Licht, Leinwand, Rollladen, Beamer, FireTV oder SAT, HDMI Switch und die Sourroundanlage. Echt cool!
            Dischro @frankjoke last edited by
            @frankjoke
            https://www.amazon.de/gp/product/B081GDH5TM/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
            so sieht es aus
            • Pepsi1183
              Pepsi1183 last edited by
              Hi muss hier mal rein grätschen.
              Ich versuche gerade ein Mini 3 einzubinden und bekomme im Log leider immer wieder die Meldung:
              (29780) Device UN:RM3-df-0d-49 dedected: address=192.168.XXX.XXX, mac=XX:XX:xx:XX:xx:XX, typ=unknown, id=0x5f36 devtype=UKN
              Bzw. beim Straten der Instanz zusätzlich noch eine Warnung:
              (29780) Unknown UN:RM3-df-0d-49 with { address: '192.168.XXX.XXX', port: 80, devtype: 24374, maco: <Buffer 49 0d df a7 df 24>, mac: '24:df:a7:df:0d:49', type: 'unknown', name: 'UN:RM3-df-0d-49', devna )
              Mein RM Pro läuft aber noch ohne Probleme weiter.
              Als Objekt wir der Mini 3 aufgeführt, aber lediglich mit "_notReachable" Status
              Gibt es eine Möglichkeit dem Adapter zu erklären das dieses Gerät ein Mini 3 ist?
              (Hoffe ich habe keinen der 863 Einträge hier übersehen, bei dem genau das Problem schon geklärt wurde.)
              • frankjoke
                frankjoke @Pepsi1183 last edited by
                @Pepsi1183 sagte in Adapter: broadlink2:
                Pepsi, der typ 0x5f36 ist bei mir als 0x5f36: 'RM Mini 3' eingetragen, ich nehme an es ist ein neueres Gerät und laut meiner Liste sollte es das RM4-Protokoll unterstützen, also die Broadlink cloud.
                Wenn das Gerät wirklich ein solches ist dann hast du es vielleicht (wie hier einige zuvor) mit einem der neuen apps ins Wlan-Netz geholt und es verwendet jetzt das Cloud-Protokoll und der broadlink2 kann sich nicht verbinden und das Gerät bleibt unknown da broadlink2 keine Antwort bekommt!
                Versuche mit einer älteren broadlink e-control app das Gerät in ein 2.4GHz Netz zu holen damit es nach dem alten Broadlink-Protokoll spricht.
                Wenn das nicht der Grund ist dann weiß ich nicht was man noch machen könnte.
                Pepsi1183 J 2 Replies Last reply Reply Quote 0
                • frankjoke
                  frankjoke @Dischro last edited by
                  @Dischro
                  Danke, das scheint ja den Sensor im Kabel zu haben!
                  Hab mal eins bestellt um testen zu können 🙂 Habe ja ein Bier gespendet bekommen 🙂
                  • Pepsi1183
                    Pepsi1183 @frankjoke last edited by Pepsi1183
                    @frankjoke Ok, danke für die schnelle Antwort, versuche ich gleich mal.
                    EDIT:
                    Hmm, das scheint das Problem zu sein, wobei ich den Mini 3 mit der E-Control App jetzt auch nicht mehr ansteuern kann und er wird als unbekanntes Gerät aufgeführt. 😞
                    Habe schon einige Reset Versuche unternommen, ohne Erfolg.
                    Werde den jetzt zurück schicken und auf einen Mini 4 umsteigen.
                    • frankjoke
                      @Pepsi1183
                      Die Frage ist ob du beide Geräte jetzt im iobroker.broadlink2 hast oder nicht.
                      Ich würde die Geräte sowieso nie mit den apps steuern, sondern nur über iobroker (und dazu die iobroker app und vis benutzen).
                      Sobald man die broadlink app's benutzt geht alles über china oder cloud server was wir alle nicht wollen!
                      Pepsi1183 Gargano 2 Replies Last reply Reply Quote 0
                        jamesdiener88285 @frankjoke last edited by jamesdiener88285
                        @frankjoke e-control funktioniert leider nicht mit den aktuellen RM Mini 3. Siehe Screenshot, Device wird nicht richtig erkannt und kann nicht ausgewaehlt werden. Andere Apps funktionieren auch nicht. Kann man den Adapter auch irgendwie mit der neuen / bzw. ohne App zum laufen bringen?
                        Verwenden RM Mini 3 und RM Mini 4 das selbe Protokoll? Oder lohnt sich ein Umstiegt von 3 auf 4?
                        J frankjoke 2 Replies Last reply Reply Quote 0
                        • Pepsi1183
                          @frankjoke Ich nutze die App nur um den Broadlink ins WLAN zu bekommen. Danach direkt internet Zugang sperren und nur noch mit ioBroker nutzen.
                          Wie bisher den RM 3 Pro, den ich damals mit der gleichen App initialisiert hatte wie jetzt mit dem Mini3.
                          Oder gibt es einen weg ohne App den Broadlink ins WLAN zu bekommen?
                          Anyway: Sonntag geht es damit weiter.....mit der eSmart Home App und dem Mini 4.
                            jamesdiener88285 @jamesdiener88285 last edited by
                            @jamesdiener88285 Tipp: Falls die Android App nicht zum einbinden ins Netzwerk funktioniert. Es funktioniert mit der Windows-Anwendung Broadlink Manager. Jetzt wird auch alles in IOBroker erkannt.
                            padrino 1 Reply Last reply Reply Quote 1
                            • padrino
                              padrino Most Active @jamesdiener88285 last edited by
                              @jamesdiener88285
                              Wo gibt es die denn? 🤔
                              • Wszene
                                Wszene last edited by
                                @padrino
                                https://sourceforge.net/projects/broadlink-manager/
                                • Christoph1337
                                  Christoph1337 last edited by
                                  @frankjoke
                                  Ich hab mal ne frage. Wie mache ich das am einfachsten für folgendes beispiel.
                                  Ich hab eine Klimaanlage wo ich für jede temperatur einen eigenen steuercode habe.
                                  Wie bau ich das am besten für die steuerung ein? ein blockly was für jeden gültigen wert einen dp hat?
                                  ? frankjoke 2 Replies Last reply Reply Quote 0
                                  • MathiasJ
                                    MathiasJ last edited by
                                    Ich habe Broadlink2 gerade deinstalliert.
                                    Habe weder die Lust, noch die Zeit, mich täglich mit irgendwelchen Fehlersuchen zu beschäftigen.
                                    Ich habe auch ein Leben jenseits von Homematic und IObroker.
                                    Nach dem letzten Update wieder keine Geräte gefunden.
                                    Log: "no Devices found" als ich den TV getestet habe.
                                    Gruß,
                                    Mathias
                                      A Former User @Christoph1337 last edited by
                                      @Christoph1337
                                      Hi, ist bei meiner auch so, hab n Datenpunkt angelegt, wo ich die Temp einstellen kann ( level.temperatur) und ein trigger auf den gesetzt, wenn klima an, und der wert temp.klima ändert sich, dann sende code ..
                                        A Former User @MathiasJ last edited by
                                        @MathiasJ warum das denn? unten hast du noch geschrieben, dass alles geht, bis auf die Temp, aber das ist ja klar..
                                        hast du die mit der richtigen App eingebunden?
                                        MathiasJ 1 Reply Last reply Reply Quote 0
                                        • MathiasJ
                                          MathiasJ @Guest last edited by
                                          @ilovegym
                                          Bis zum letzten Update der Instanz ging es ja, nachdem ich TV & Co wieder angelernt habe.
                                          Nun, seit dem Update vorgestern ist wieder alles weg. Now I'm not amused.
                                          Sorry, habe keine Lust, nach jedem Update alles neu anzulegen.
                                          Gruß,
                                          Mathias
                                            @MathiasJ Ei, warum hast du auch kein Backup der Datenpunkte gezogen? .....
                                            Dass alles weg ist, ist mir schon lange nicht mehr passiert, aber bei so kritischen Dingen wie 100 angelernte Befehle mach ich doch n Backup.. ist doch nur n Mausklick.
                                            1.0k
                                            81.1k
                                            broad2 broadlink rm pro rm3 mini rm4
                                            169
                                            1365
                                            614371
