    4. Hm-rpc 1.2.0
    Hm-rpc 1.2.0
    • nieIP
      nieIP last edited by
      Hallo
      bei mir funktioniert die 1.2 nicht.
      ich habe 1.2 installiert.
      Ich bekomme nur noch Daten von "system.xxx" nicht mehr von der CCU
      Umgestellt auf XML - funktioniert
      Umgestellt auf BIN-RPC funktioniert nicht.
      Im Logfile bitte mal die Adresse der CCU beachten, auf die Zugegriffen wird.
      Da steht ["xmlrpc_bin://192.168.1.161:2001","hm-rpc.0"]
      was mir nicht richtig erscheint.
      hm-rpc-0	2016-06-18 22:34:08.603	info	binrpc client is trying to connect to 192.168.1.55:2001 with ["xmlrpc_bin://192.168.1.161:2001","hm-rpc.0"]
      hm-rpc-0	2016-06-18 22:34:08.601	info	binrpc server is trying to listen on 192.168.1.161:2001
      hm-rpc-0	2016-06-18 22:34:08.061	info	Connected
      hm-rpc-0	2016-06-18 22:34:07.633	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.hm-rpc
      host-raspi-3	2016-06-18 22:34:06.322	info	instance system.adapter.hm-rpc.0 started with pid 4254
      host-raspi-3	2016-06-18 22:34:03.844	info	instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
      hm-rpc-0	2016-06-18 22:34:03.826	info	terminating
      hm-rpc-0	2016-06-18 22:34:03.816	info	Disconnected
      hm-rpc-0	2016-06-18 22:34:03.798	info	xmlrpc -> 192.168.1.55:2001 init ["http://192.168.1.161:2001",""]
      host-raspi-3	2016-06-18 22:34:03.794	info	stopInstance system.adapter.hm-rpc.0 killing pid 4244
      host-raspi-3	2016-06-18 22:34:03.793	info	object change system.adapter.hm-rpc.0
      hm-rpc-0	2016-06-18 22:33:30.260	info	xmlrpc -> 680 devices
      hm-rpc-0	2016-06-18 22:33:30.198	info	xmlrpc <- listDevices ["hm-rpc.0"]
      hm-rpc-0	2016-06-18 22:33:30.176	info	xmlrpc <- system.listMethods ["hm-rpc.0"]
      hm-rpc-0	2016-06-18 22:33:30.144	info	xmlrpc client is trying to connect to 192.168.1.55:2001 with ["http://192.168.1.161:2001","hm-rpc.0"]
      hm-rpc-0	2016-06-18 22:33:30.143	info	xmlrpc server is trying to listen on 192.168.1.161:2001
      hm-rpc-0	2016-06-18 22:33:29.435	info	Connected
      hm-rpc-0	2016-06-18 22:33:29.194	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.hm-rpc
      host-raspi-3	2016-06-18 22:33:27.915	info	instance system.adapter.hm-rpc.0 started with pid 4244
      host-raspi-3	2016-06-18 22:33:25.463	info	instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
      hm-rpc-0	2016-06-18 22:33:25.413	info	Disconnected
      hm-rpc-0	2016-06-18 22:33:25.396	info	binrpc -> 192.168.1.55:2001 init ["xmlrpc_bin://192.168.1.161:2001",""]
      host-raspi-3	2016-06-18 22:33:25.390	info	stopInstance system.adapter.hm-rpc.0 killing pid 4201
      host-raspi-3	2016-06-18 22:33:25.388	info	object change system.adapter.hm-rpc.0
      hm-rpc-0	2016-06-18 22:26:18.096	info	binrpc client is trying to connect to 192.168.1.55:2001 with ["xmlrpc_bin://192.168.1.161:2001","hm-rpc.0"]
      hm-rpc-0	2016-06-18 22:26:18.094	info	binrpc server is trying to listen on 192.168.1.161:2001
      hm-rpc-0	2016-06-18 22:26:17.482	info	Connected
      • nieIP
        @Homoran:
        Aber in der Konfiguration des hm-rpc gibt es jetzt neben rs485, rf, cuxD auch noch die Option HM-IP
        Rainer `
        Bist Du ganz sicher, dass Du nicht das hm-Rega Fenster meinst ????
          • nieIP
            Hallo
            ok, ich habe den Adapter gelöscht und neu angelegt. Allerdings hat er die vorhandene Version 1.2 wieder genommen. Damit sind sinnloser Weise alle meine History Einstellungen erst mal wieder weg 😞
            Die Konfiguration für HMIP ist jetzt da.
            RPC funktioniert trotzdem nicht. Nur XML.
            Ich bastel jetzt die Historyeinstellungen erst einmal grob wieder zusammen 😞
            Über VPN aus dem Urlaub nicht grade schnell 😞
              @nieIP:
              Über VPN aus dem Urlaub nicht grade schnell `
              Schon wieder? Du warst doch gerade erst in Frankreich!
              @nieIP:
              ich habe den Adapter gelöscht und neu angelegt. `
              Es wird jetzt wohl nicht hilfreich sein, dir zu sagen, dass es auch anders geht.
              Den Weg wie nobody es mit npm beschrieben hatte, kannte ich vorher auch noch nicht
              Viel Glück
              Rainer
              • nieIP
                hallo
                ich wollte ja eigentlich wieder auf die aktuelle 1.1.x zurück
                Und das geht so weit ich weiss nur über löschen und neu installieren.
                BTW ich war auf einer Hochzeit eingeladen und hänge noch 5 Tage Erholung dran. 🙂
                Geht bei Dir denn der RPC Adapter 1.2 ? Bekommst Du Daten von der CCU ?
                  @nieIP:
                  Geht bei Dir denn der RPC Adapter 1.2 ? Bekommst Du Daten von der CCU ? `
                  Aber auch nur über xml!
                  Mit bin geht gar nichts 😞
                  @nieIP:
                  ich wollte ja eigentlich wieder auf die aktuelle 1.1.x zurück `
                  Auch das scheint zu gehen.
                  Hat bluefox in einem anderen Zusammenhang vor ein paar Tagen gepostet.
                  Muss ich suchen.
                  Rainer
                  • nieIP
                    Hallo
                    ich habe einen RPC Adapter auf HMIP und XML konfiguriert.
                    Im Log File stehen Zeilen mit "send to developer". Also mache ich das mal …
                    hm-rpc-1	2016-06-18 23:20:13.981	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{}}
                    hm-rpc-1	2016-06-18 23:20:13.981	info	setObject hm-rpc.meta.VALUES.HMIP-eTRV.HEATING_KEY_RECEIVER.1
                    hm-rpc-1	2016-06-18 23:20:13.961	info	xmlrpc -> getParamsetDescription ["000393C98D1E6A:7","VALUES"]
                    hm-rpc-1	2016-06-18 23:20:13.948	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{}}
                    hm-rpc-1	2016-06-18 23:20:13.947	info	setObject hm-rpc.meta.VALUES.HMIP-eTRV.HEATING_ROOM_TH_RECEIVER.1
                    hm-rpc-1	2016-06-18 23:20:13.915	info	xmlrpc -> getParamsetDescription ["000393C98D1E6A:6","VALUES"]
                    hm-rpc-1	2016-06-18 23:20:13.903	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{}}
                    hm-rpc-1	2016-06-18 23:20:13.903	info	setObject hm-rpc.meta.VALUES.HMIP-eTRV.HEATING_ROOM_TH_TRANSCEIVER.1
                    hm-rpc-1	2016-06-18 23:20:13.882	info	xmlrpc -> getParamsetDescription ["000393C98D1E6A:5","VALUES"]
                    hm-rpc-1	2016-06-18 23:20:13.871	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{}}
                    hm-rpc-1	2016-06-18 23:20:13.871	info	setObject hm-rpc.meta.VALUES.HMIP-eTRV.HEATING_SHUTTER_CONTACT_RECEIVER.1
                    hm-rpc-1	2016-06-18 23:20:13.850	info	xmlrpc -> getParamsetDescription ["000393C98D1E6A:4","VALUES"]
                    hm-rpc-1	2016-06-18 23:20:13.833	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{}}
                    hm-rpc-1	2016-06-18 23:20:13.832	info	setObject hm-rpc.meta.VALUES.HMIP-eTRV.HEATING_CLIMATECONTROL_CL_RECEIVER.1
                    hm-rpc-1	2016-06-18 23:20:13.808	info	xmlrpc -> getParamsetDescription ["000393C98D1E6A:3","VALUES"]
                    hm-rpc-1	2016-06-18 23:20:13.792	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{}}
                    hm-rpc-1	2016-06-18 23:20:13.791	info	setObject hm-rpc.meta.VALUES.HMIP-eTRV.HEATING_CLIMATECONTROL_RECEIVER.1
                    hm-rpc-1	2016-06-18 23:20:13.757	info	xmlrpc -> getParamsetDescription ["000393C98D1E6A:2","VALUES"]
                    hm-rpc-1	2016-06-18 23:20:13.681	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"PARTY_MODE":{"MAX":true,"CONTROL":"HEATING_CONTROL_HMIP.PARTY_MODE","MIN":f
                    hm-rpc-1	2016-06-18 23:20:13.681	info	setObject hm-rpc.meta.VALUES.HMIP-eTRV.HEATING_CLIMATECONTROL_TRANSCEIVER.1
                    hm-rpc-1	2016-06-18 23:20:13.408	info	xmlrpc -> getParamsetDescription ["000393C98D1E6A:1","VALUES"]
                    hm-rpc-1	2016-06-18 23:20:13.371	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"DUTY_CYCLE":{"MAX":true,"MIN":false,"ID":"DUTY_CYCLE","OPERATIONS":5,"FLAGS
                    hm-rpc-1	2016-06-18 23:20:13.370	info	setObject hm-rpc.meta.VALUES.HMIP-eTRV.MAINTENANCE.1
                    hm-rpc-1	2016-06-18 23:20:13.120	info	xmlrpc -> getParamsetDescription ["000393C98D1E6A:0","VALUES"]
                    hm-rpc-1	2016-06-18 23:20:13.102	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"STATE":{"TAB_ORDER":0,"MAX":"OPEN","UNIT":"\"\"","CONTROL":"DOOR_SENSOR.STA
                    hm-rpc-1	2016-06-18 23:20:13.101	info	setObject hm-rpc.meta.VALUES.HMIP-SWDO.SHUTTER_CONTACT.1
                    hm-rpc-1	2016-06-18 23:20:13.065	info	xmlrpc -> getParamsetDescription ["0000D3C98C9B3A:1","VALUES"]
                    hm-rpc-1	2016-06-18 23:20:13.021	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"DUTY_CYCLE":{"MAX":true,"MIN":false,"ID":"DUTY_CYCLE","OPERATIONS":5,"FLAGS
                    hm-rpc-1	2016-06-18 23:20:13.020	info	setObject hm-rpc.meta.VALUES.HMIP-SWDO.MAINTENANCE.1
                    hm-rpc-1	2016-06-18 23:20:12.942	info	xmlrpc -> getParamsetDescription ["0000D3C98C9B3A:0","VALUES"]
                    hm-rpc-1	2016-06-18 23:20:12.930	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{}}
                    hm-rpc-1	2016-06-18 23:20:12.930	info	setObject hm-rpc.meta.VALUES.HMIP-WTH.HEATING_KEY_RECEIVER.1
                    hm-rpc-1	2016-06-18 23:20:12.899	info	xmlrpc -> getParamsetDescription ["000313C9906EDE:6","VALUES"]
                    hm-rpc-1	2016-06-18 23:20:12.889	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{}}
                    hm-rpc-1	2016-06-18 23:20:12.888	info	setObject hm-rpc.meta.VALUES.HMIP-WTH.HEATING_CLIMATECONTROL_SWITCH_TRANSMITTER.1
                    hm-rpc-1	2016-06-18 23:20:12.864	info	xmlrpc -> getParamsetDescription ["000313C9906EDE:5","VALUES"]
                    hm-rpc-1	2016-06-18 23:20:12.854	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{}}
                    hm-rpc-1	2016-06-18 23:20:12.844	info	setObject hm-rpc.meta.VALUES.HMIP-WTH.HEATING_SHUTTER_CONTACT_RECEIVER.1
                    hm-rpc-1	2016-06-18 23:20:12.813	info	xmlrpc -> getParamsetDescription ["000313C9906EDE:4","VALUES"]
                    hm-rpc-1	2016-06-18 23:20:12.802	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{}}
                    hm-rpc-1	2016-06-18 23:20:12.801	info	setObject hm-rpc.meta.VALUES.HMIP-WTH.HEATING_CLIMATECONTROL_CL_TRANSMITTER.1
                    hm-rpc-1	2016-06-18 23:20:12.781	info	xmlrpc -> getParamsetDescription ["000313C9906EDE:3","VALUES"]
                    hm-rpc-1	2016-06-18 23:20:12.769	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{}}
                    hm-rpc-1	2016-06-18 23:20:12.769	info	setObject hm-rpc.meta.VALUES.HMIP-WTH.HEATING_CLIMATECONTROL_RECEIVER.1
                    hm-rpc-1	2016-06-18 23:20:12.745	info	xmlrpc -> getParamsetDescription ["000313C9906EDE:2","VALUES"]
                    hm-rpc-1	2016-06-18 23:20:12.654	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"PARTY_MODE":{"MAX":true,"CONTROL":"HEATING_CONTROL_HMIP.PARTY_MODE","MIN":f
                    hm-rpc-1	2016-06-18 23:20:12.653	info	setObject hm-rpc.meta.VALUES.HMIP-WTH.HEATING_CLIMATECONTROL_TRANSCEIVER.1
                    hm-rpc-1	2016-06-18 23:20:12.409	info	xmlrpc -> getParamsetDescription ["000313C9906EDE:1","VALUES"]
                    hm-rpc-1	2016-06-18 23:20:12.350	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"DUTY_CYCLE":{"MAX":true,"MIN":false,"ID":"DUTY_CYCLE","OPERATIONS":5,"FLAGS
                    hm-rpc-1	2016-06-18 23:20:12.350	info	setObject hm-rpc.meta.VALUES.HMIP-WTH.MAINTENANCE.1
                    hm-rpc-1	2016-06-18 23:20:12.262	info	xmlrpc -> getParamsetDescription ["000313C9906EDE:0","VALUES"]
                    hm-rpc-1	2016-06-18 23:20:12.074	warn	No image for "HMIP-eTRV" found.
                    hm-rpc-1	2016-06-18 23:20:12.074	warn	No image for "HMIP-SWDO" found.
                    hm-rpc-1	2016-06-18 23:20:12.071	warn	No image for "HMIP-WTH" found.
                    hm-rpc-1	2016-06-18 23:20:12.069	info	xmlrpc <- newDevices 20
                    hm-rpc-1	2016-06-18 23:20:11.556	info	xmlrpc -> 0 devices
                    hm-rpc-1	2016-06-18 23:20:11.543	info	xmlrpc <- listDevices ["hm-rpc.1"]
                    hm-rpc-1	2016-06-18 23:20:11.252	info	xmlrpc client is trying to connect to 192.168.1.55:2010 with ["http://192.168.1.161:2011","hm-rpc.1"]
                    hm-rpc-1	2016-06-18 23:20:11.250	info	xmlrpc server is trying to listen on 192.168.1.161:2011
                    hm-rpc-1	2016-06-18 23:20:11.055	info	Connected
                    hm-rpc-1	2016-06-18 23:20:10.904	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.hm-rpc
                    host-raspi-3	2016-06-18 23:20:09.558	info	instance system.adapter.hm-rpc.1 started with pid 4494
                    host-raspi-3	2016-06-18 23:20:07.055	info	Restart adapter system.adapter.hm-rpc.1 because enabled
                      Hab den Hinweis zur Installation alter Versionen gefunden.
                      http://forum.iobroker.net/viewtopic.php … 350#p28350
                      Rainer
                      • nieIP
                        Danke, für das nächste mal dann.
                        Jetzt bin ich dann morgen mal darauf gespannt, warum bei mir die 1.2 nicht (nur mit XML) funktioniert 😞
                        • eric2905
                          eric2905 last edited by
                          Moin,
                          hab's nun auch mal ausgiebig durchgetestet (CCU bestimmt 10 x neu gestartet):
                          Kanalnamen, usw. kommen nur bei XML-RPC und nicht bei BIN-RPC.
                          Gruß,
                          Eric
                          • Bluefox
                            Bluefox last edited by
                            @nieIP:
                            RPC funktioniert trotzdem nicht. Nur XML. `
                            Ich nehme an, dass unter RPC meinst du bin-rpc.
                            HMIP geht nur über xml-rpc.
                              Guten Morgen Bluefox,
                              Aber auch bei nicht IP gibt es seltsame Phänomene.
                              Ich bekomme keine Refresh der Datenpunkte mit BIN-RPC. Erst nach Umstellung auf XML.
                              Jetzt habe ich noch ewas seltsames bemerkt.
                              Unter objects erscheint in der Spalte Name nichts, aber ich kann trotzdem danach filtern.
                              Rainer
                                paul53 last edited by
                                @Homoran:
                                Unter objects erscheint in der Spalte Name nichts, aber ich kann trotzdem danach filtern. `
                                Die Spalte ist auch da, die Namen sind aufrund einer zu geringen Bildschirmauflösung / Breite des Bowserfensters nur nicht zu sehen.
                                  So nach dem Motto : die ist nicht weg, die ist nur woanders 😄
                                  Mag sein, dass es an der Bildschirmauflösung liegt. Ist ein Tablet mit HD (nicht Full-HD).
                                  Aber auch die Spaltentrenner sind nicht zu sehen.
                                  Rainer
                                  • htrecksler
                                    htrecksler Forum Testing last edited by
                                    @all - welche CCU2 FW habt ihr im Einsatz? Mit der 2.19 kriege ich nach wie vor unter Zustände keine Werte. Und das LowBat Script zeigt für alle LowBat Datenpunkte "undefined".
                                    Eingestellt ist XML-Rpc.
                                    • nieIP
                                      Hallo
                                      1. das mit der Namens Spalte hatte ich ja von einer Woche? auch schon mal. Browser Auflösung mit CTRL - verringern.
                                      Dann ist die Spalte wieder breit.
                                      2. @ Bluefox
                                      Das HMIP nur per XML geht habe ich verstanden. Das ist aber nicht das Probelm.
                                      Der HM-RPC Adapter, der bisher mit RPC-bin funktioniert hat, liefert keine Daten von der CCU. Nach umstellen auf XML geht es.
                                      Deshalb mein Hinweis auf die Zeile im Logfile. (das hat nichts mit HMIP zu tun)
                                      • nieIP
                                        @Bluefox:
                                        Im hm-rpc 1.2.0 wurde für bin-rpc ein Reconnectproblem gelöst. `
                                        Hallo
                                        ich möchte noch mal nachfragen, ob es einen User gibt, bei dem hm-rpc 1.2 in der Einstellung bin-rpc Daten von der CCU bekommmt ??
                                        Falls es nicht funktioniert, gern auch ein "geht bei mir nicht" an der Stelle.
                                        Danke.
                                        • N
                                          nobody last edited by
                                          @nieIP:
                                          @Bluefox:
                                          Danke. `
                                          Geht bei mir nicht. Bin auf die 1.1.3 zurück.
                                            cybertron last edited by
                                            Ich hatte es schon in einem separaten Thread beschrieben,
                                            Bei mir lässt sich die 1.2.0 gar nicht installieren derzeit.
                                            Das Update aus dem Admin-Webif endete mit Return-Code 25.
                                            Danach gab es zwar noch eine Instanz, jedoch laut Webif eigentlich keinen Adapter mehr.
                                            Habe dann die Instanz noch gelöscht, und versucht erneut zu installieren, aber ohne Chance.
                                            Weiterhin der Returncode 25
                                            Silvio
                                            31.7k
                                            79.8k
                                            63
                                            6617
