    4. Test Adapter melcloud v1.0.x Latest
      meicker @Vadim last edited by
      @Vadim
      sure you mean vertical ? Your picture shows two white bars at horizontal. Here it seems to be possible to set one direction left 100% and one direction right 100%. In between you only van set one white bar (direction)
      br Marc
      • V
        Vadim @meicker last edited by
        @meicker said in Test Adapter melcloud v1.0.x GitHub:
        @Vadim
        br Marc
        You are exactly right.
        Of course, Horizontal, sorry 🙂
        • Black Thunder
          Black Thunder Developer @Vadim last edited by Black Thunder
          @Vadim
          1. Yep, you're totally right about that additional setting for the horizontal vane. Please try with v1.0.4 (delete 'devices' after updating). Should be working now.
          2. Might/should be possible, but I haven't found any documentation on that. Maybe the network traffic has to be monitored when using the reports in the app to find out the relevant calls to the cloud. That doesn't have a high priority for me at the moment, but I've noted your request as a GitHub issue. 😉
          • V
            @Black-Thunder
            "50\50" mode for Horizontal vans is working.
            Thank you, Great work.
              mbad last edited by
              I have still installed "0.0.2-alpha9". This was working ok to switch on/off my aircondition and to pass actual room temperature to my home automation system.
              Will I destroy my scripts upgrading to the latest version or can I just update the adapter?
              btw: are we communicating in English now? Or dependent on who is asking a question.
              Black Thunder 1 Reply Last reply Reply Quote 0
              • Black Thunder
                Black Thunder Developer @mbad last edited by Black Thunder
                @mbad
                Wir können gerne bei Deutsch bleiben, wenn beide der Sprache mächtig sind. 😉
                Also beim Update sollten deine Skripte weiterhin funktionieren, da die grundlegenden States gleich geblieben sind. Ohne die Skripte zu kennen, kann ich das natürlich nicht garantieren.
                Allerdings sind ein paar neue States dazu gekommen und bestehende wurden leicht modifiziert. Daher würde ich dir nach dem Update empfehlen, den "devices"-Ordner zu löschen, damit er neu angelegt wird. An den Geräte-IDs selbst ändert sich nichts, da diese von MELCloud geliefert werden.
                Außerdem wurden in der Zwischenzeit einige Bugs behoben (gerade, falls du mehr als 1 Innengerät hast) und die Performance des Adapters deutlich verbessert. Von daher empfehle ich schon, das Update durchzuführen.
                • hanan
                  hanan last edited by hanan
                  Guten Morgen Black Thunder
                  Bei mir funzt mit der Version 1.0.5 etwas nicht, daher habe ich mal eine Verständnis-Frage.
                  Ich habe zwei Scenen angelegt, eine für Ein / Aus und eine für Betriebsmodus Vollkühlung und Sleep.
                  Leider werden die Befehle nicht oder nur teilweise übernommen. Der Wert wird in den Objekten geändert aber gleich wieder überschrieben... Ich muss die jeweilige Scene zwei bis drei Mal ausführen bis es vom Gerät übernommen wird.
                  Hier die beiden Scenen (habe es auch schon ohne Verzögerungen versucht):
                  Jetzt die Frage, wie werden die Änderungen gesendet, als Gesamtpaket (alle sechs Parameter zusammen) oder nacheinander?
                  2020-06-27 07:28:05.776 - info: sql.0 (13342) enabled logging of synology.0.DiskStationManager.info.temperature, Alias=false
                  2020-06-27 07:28:10.188 - debug: melcloud.0 (19146) Trying to get device object with id 177841...
                  2020-06-27 07:28:10.189 - debug: melcloud.0 (19146) Processing change for device object with id 177841 (Schlafzimmer)...
                  2020-06-27 07:28:10.190 - info: melcloud.0 (19146) Getting device data for 177841 (Schlafzimmer)
                  2020-06-27 07:28:10.352 - debug: melcloud.0 (19146) Received response from: https://app.melcloud.com/Mitsubishi.Wifi.Client/Device/Get?id=177841&buildingID=112112 (status code: 200 - OK)
                  2020-06-27 07:28:10.353 - debug: melcloud.0 (19146) Parsed response from cloud: {"EffectiveFlags":0,"LocalIPAddress":null,"RoomTemperature":23,"SetTemperature":20,"SetFanSpeed":1,"OperationMode":3,"VaneHorizontal":5,"VaneVertical":5,"Name":null,"NumberOfFanSpeeds":5,"WeatherObservations":[{"Date":"2020-06-27T06:00:00","Sunrise":"2020-06-27T05:35:00","Sunset":"2020-06-27T21:32:00","Condition":116,"ID":335469463,"Humidity":81,"Temperature":20,"Icon":"wsymbol_0002_sunny_intervals","ConditionName":"Teilweise bewölkt","Day":6,"WeatherType":0},{"Date":"2020-06-27T15:00:00","Sunrise":"2020-06-27T05:35:00","Sunset":"2020-06-27T21:32:00","Condition":116,"ID":335469466,"Humidity":55,"Temperature":27,"Icon":"wsymbol_0002_sunny_intervals","ConditionName":"Teilweise bewölkt","Day":6,"WeatherType":1},{"Date":"2020-06-28T03:00:00","Sunrise":"2020-06-28T05:35:00","Sunset":"2020-06-28T21:32:00","Condition":176,"ID":335945998,"Humidity":87,"Temperature":17,"Icon":"wsymbol_0025_light_rain_showers_night","ConditionName":"Stellenweise Regen in der Nähe","Day":6,"WeatherType":2},{"Date":"2020-06-28T15:00:00","Sunrise":"2020-06-28T05:35:00","Sunset":"2020-06-28T21:32:00","Condition":176,"ID":335946002,"Humidity":71,"Temperature":21,"Icon":"wsymbol_0009_light_rain_showers","ConditionName":"Stellenweise Regen in der Nähe","Day":0,"WeatherType":1}],"ErrorMessage":null,"ErrorCode":8000,"DefaultHeatingSetTemperature":24,"DefaultCoolingSetTemperature":20,"HideVaneControls":false,"HideDryModeControl":false,"RoomTemperatureLabel":0,"InStandbyMode":false,"TemperatureIncrementOverride":0,"ProhibitSetTemperature":false,"ProhibitOperationMode":false,"ProhibitPower":false,"DeviceID":177841,"DeviceType":0,"LastCommunication":"2020-06-27T05:27:23.817","NextCommunication":"2020-06-27T05:28:23.817","Power":false,"HasPendingCommand":false,"Offline":false,"Scene":null,"SceneOwner":null}
                  2020-06-27 07:28:10.354 - info: melcloud.0 (19146) Changing device option 'TargetTemperature' to '18'...
                  2020-06-27 07:28:10.497 - debug: melcloud.0 (19146) Received response from: https://app.melcloud.com/Mitsubishi.Wifi.Client/Device/SetAta (status code: 200 - OK)
                  2020-06-27 07:28:10.498 - debug: melcloud.0 (19146) Parsed response from cloud: {"EffectiveFlags":4,"LocalIPAddress":null,"RoomTemperature":23,"SetTemperature":18,"SetFanSpeed":1,"OperationMode":3,"VaneHorizontal":5,"VaneVertical":5,"Name":null,"NumberOfFanSpeeds":5,"WeatherObservations":[{"Date":"2020-06-27T06:00:00","Sunrise":"2020-06-27T05:35:00","Sunset":"2020-06-27T21:32:00","Condition":116,"ID":335469463,"Humidity":81,"Temperature":20,"Icon":"wsymbol_0002_sunny_intervals","ConditionName":"Teilweise bewölkt","Day":6,"WeatherType":0},{"Date":"2020-06-27T15:00:00","Sunrise":"2020-06-27T05:35:00","Sunset":"2020-06-27T21:32:00","Condition":116,"ID":335469466,"Humidity":55,"Temperature":27,"Icon":"wsymbol_0002_sunny_intervals","ConditionName":"Teilweise bewölkt","Day":6,"WeatherType":1},{"Date":"2020-06-28T03:00:00","Sunrise":"2020-06-28T05:35:00","Sunset":"2020-06-28T21:32:00","Condition":176,"ID":335945998,"Humidity":87,"Temperature":17,"Icon":"wsymbol_0025_light_rain_showers_night","ConditionName":"Stellenweise Regen in der Nähe","Day":6,"WeatherType":2},{"Date":"2020-06-28T15:00:00","Sunrise":"2020-06-28T05:35:00","Sunset":"2020-06-28T21:32:00","Condition":176,"ID":335946002,"Humidity":71,"Temperature":21,"Icon":"wsymbol_0009_light_rain_showers","ConditionName":"Stellenweise Regen in der Nähe","Day":0,"WeatherType":1}],"ErrorMessage":null,"ErrorCode":8000,"DefaultHeatingSetTemperature":24,"DefaultCoolingSetTemperature":20,"HideVaneControls":false,"HideDryModeControl":false,"RoomTemperatureLabel":0,"InStandbyMode":false,"TemperatureIncrementOverride":0,"ProhibitSetTemperature":false,"ProhibitOperationMode":false,"ProhibitPower":false,"DeviceID":177841,"DeviceType":0,"LastCommunication":"2020-06-27T05:27:23.817","NextCommunication":"2020-06-27T05:28:23.817","Power":false,"HasPendingCommand":true,"Offline":false,"Scene":null,"SceneOwner":null}
                  2020-06-27 07:28:10.709 - debug: melcloud.0 (19146) Updated device data for device 177841 (Schlafzimmer)
                  2020-06-27 07:28:20.154 - debug: melcloud.0 (19146) Trying to get device object with id 177841...
                  2020-06-27 07:28:20.155 - debug: melcloud.0 (19146) Processing change for device object with id 177841 (Schlafzimmer)...
                  2020-06-27 07:28:20.155 - debug: melcloud.0 (19146) Data already available for: 177841 (Schlafzimmer)
                  2020-06-27 07:28:20.156 - info: melcloud.0 (19146) Changing device option 'PowerState' to 'true'...
                  2020-06-27 07:28:20.163 - debug: melcloud.0 (19146) Trying to get device object with id 177841...
                  2020-06-27 07:28:20.164 - debug: melcloud.0 (19146) Processing change for device object with id 177841 (Schlafzimmer)...
                  2020-06-27 07:28:20.165 - debug: melcloud.0 (19146) Data already available for: 177841 (Schlafzimmer)
                  2020-06-27 07:28:20.165 - info: melcloud.0 (19146) Changing device option 'TargetHeatingCoolingState' to '3'...
                  2020-06-27 07:28:20.318 - debug: melcloud.0 (19146) Received response from: https://app.melcloud.com/Mitsubishi.Wifi.Client/Device/SetAta (status code: 200 - OK)
                  2020-06-27 07:28:20.319 - debug: melcloud.0 (19146) Parsed response from cloud: {"EffectiveFlags":1,"LocalIPAddress":null,"RoomTemperature":23,"SetTemperature":18,"SetFanSpeed":1,"OperationMode":3,"VaneHorizontal":5,"VaneVertical":5,"Name":null,"NumberOfFanSpeeds":5,"WeatherObservations":[{"Date":"2020-06-27T06:00:00","Sunrise":"2020-06-27T05:35:00","Sunset":"2020-06-27T21:32:00","Condition":116,"ID":335469463,"Humidity":81,"Temperature":20,"Icon":"wsymbol_0002_sunny_intervals","ConditionName":"Teilweise bewölkt","Day":6,"WeatherType":0},{"Date":"2020-06-27T15:00:00","Sunrise":"2020-06-27T05:35:00","Sunset":"2020-06-27T21:32:00","Condition":116,"ID":335469466,"Humidity":55,"Temperature":27,"Icon":"wsymbol_0002_sunny_intervals","ConditionName":"Teilweise bewölkt","Day":6,"WeatherType":1},{"Date":"2020-06-28T03:00:00","Sunrise":"2020-06-28T05:35:00","Sunset":"2020-06-28T21:32:00","Condition":176,"ID":335945998,"Humidity":87,"Temperature":17,"Icon":"wsymbol_0025_light_rain_showers_night","ConditionName":"Stellenweise Regen in der Nähe","Day":6,"WeatherType":2},{"Date":"2020-06-28T15:00:00","Sunrise":"2020-06-28T05:35:00","Sunset":"2020-06-28T21:32:00","Condition":176,"ID":335946002,"Humidity":71,"Temperature":21,"Icon":"wsymbol_0009_light_rain_showers","ConditionName":"Stellenweise Regen in der Nähe","Day":0,"WeatherType":1}],"ErrorMessage":null,"ErrorCode":8000,"DefaultHeatingSetTemperature":24,"DefaultCoolingSetTemperature":20,"HideVaneControls":false,"HideDryModeControl":false,"RoomTemperatureLabel":0,"InStandbyMode":false,"TemperatureIncrementOverride":0,"ProhibitSetTemperature":false,"ProhibitOperationMode":false,"ProhibitPower":false,"DeviceID":177841,"DeviceType":0,"LastCommunication":"2020-06-27T05:27:23.817","NextCommunication":"2020-06-27T05:28:23.817","Power":true,"HasPendingCommand":true,"Offline":false,"Scene":null,"SceneOwner":null}
                  2020-06-27 07:28:20.414 - debug: melcloud.0 (19146) Received response from: https://app.melcloud.com/Mitsubishi.Wifi.Client/Device/SetAta (status code: 200 - OK)
                  2020-06-27 07:28:20.415 - debug: melcloud.0 (19146) Parsed response from cloud: {"EffectiveFlags":3,"LocalIPAddress":null,"RoomTemperature":23,"SetTemperature":18,"SetFanSpeed":1,"OperationMode":3,"VaneHorizontal":5,"VaneVertical":5,"Name":null,"NumberOfFanSpeeds":5,"WeatherObservations":[{"Date":"2020-06-27T06:00:00","Sunrise":"2020-06-27T05:35:00","Sunset":"2020-06-27T21:32:00","Condition":116,"ID":335469463,"Humidity":81,"Temperature":20,"Icon":"wsymbol_0002_sunny_intervals","ConditionName":"Teilweise bewölkt","Day":6,"WeatherType":0},{"Date":"2020-06-27T15:00:00","Sunrise":"2020-06-27T05:35:00","Sunset":"2020-06-27T21:32:00","Condition":116,"ID":335469466,"Humidity":55,"Temperature":27,"Icon":"wsymbol_0002_sunny_intervals","ConditionName":"Teilweise bewölkt","Day":6,"WeatherType":1},{"Date":"2020-06-28T03:00:00","Sunrise":"2020-06-28T05:35:00","Sunset":"2020-06-28T21:32:00","Condition":176,"ID":335945998,"Humidity":87,"Temperature":17,"Icon":"wsymbol_0025_light_rain_showers_night","ConditionName":"Stellenweise Regen in der Nähe","Day":6,"WeatherType":2},{"Date":"2020-06-28T15:00:00","Sunrise":"2020-06-28T05:35:00","Sunset":"2020-06-28T21:32:00","Condition":176,"ID":335946002,"Humidity":71,"Temperature":21,"Icon":"wsymbol_0009_light_rain_showers","ConditionName":"Stellenweise Regen in der Nähe","Day":0,"WeatherType":1}],"ErrorMessage":null,"ErrorCode":8000,"DefaultHeatingSetTemperature":24,"DefaultCoolingSetTemperature":20,"HideVaneControls":false,"HideDryModeControl":false,"RoomTemperatureLabel":0,"InStandbyMode":false,"TemperatureIncrementOverride":0,"ProhibitSetTemperature":false,"ProhibitOperationMode":false,"ProhibitPower":false,"DeviceID":177841,"DeviceType":0,"LastCommunication":"2020-06-27T05:27:23.817","NextCommunication":"2020-06-27T05:28:23.817","Power":true,"HasPendingCommand":true,"Offline":false,"Scene":null,"SceneOwner":null}
                  2020-06-27 07:28:20.478 - debug: melcloud.0 (19146) Updated device data for device 177841 (Schlafzimmer)
                  2020-06-27 07:28:20.513 - info: sql.0 (13342) enabled logging of synology.0.DiskStationManager.info.temperature, Alias=false
                  2020-06-27 07:28:20.541 - debug: melcloud.0 (19146) Updated device data for device 177841 (Schlafzimmer)
                  2020-06-27 07:28:26.592 - info: sql.0 (13342) enabled logging of synology.1.DiskStationManager.info.temperature, Alias=false
                  2020-06-27 07:28:30.185 - debug: melcloud.0 (19146) Trying to get device object with id 177841...
                  2020-06-27 07:28:30.186 - debug: melcloud.0 (19146) Processing change for device object with id 177841 (Schlafzimmer)...
                  2020-06-27 07:28:30.187 - debug: melcloud.0 (19146) Data already available for: 177841 (Schlafzimmer)
                  2020-06-27 07:28:30.187 - info: melcloud.0 (19146) Changing device option 'FanSpeed' to '0'...
                  2020-06-27 07:28:30.394 - debug: melcloud.0 (19146) Received response from: https://app.melcloud.com/Mitsubishi.Wifi.Client/Device/SetAta (status code: 200 - OK)
                  2020-06-27 07:28:30.395 - debug: melcloud.0 (19146) Parsed response from cloud: {"EffectiveFlags":8,"LocalIPAddress":null,"RoomTemperature":23,"SetTemperature":18,"SetFanSpeed":0,"OperationMode":3,"VaneHorizontal":5,"VaneVertical":5,"Name":null,"NumberOfFanSpeeds":5,"WeatherObservations":[{"Date":"2020-06-27T06:00:00","Sunrise":"2020-06-27T05:35:00","Sunset":"2020-06-27T21:32:00","Condition":116,"ID":335469463,"Humidity":81,"Temperature":20,"Icon":"wsymbol_0002_sunny_intervals","ConditionName":"Teilweise bewölkt","Day":6,"WeatherType":0},{"Date":"2020-06-27T15:00:00","Sunrise":"2020-06-27T05:35:00","Sunset":"2020-06-27T21:32:00","Condition":116,"ID":335469466,"Humidity":55,"Temperature":27,"Icon":"wsymbol_0002_sunny_intervals","ConditionName":"Teilweise bewölkt","Day":6,"WeatherType":1},{"Date":"2020-06-28T03:00:00","Sunrise":"2020-06-28T05:35:00","Sunset":"2020-06-28T21:32:00","Condition":176,"ID":335945998,"Humidity":87,"Temperature":17,"Icon":"wsymbol_0025_light_rain_showers_night","ConditionName":"Stellenweise Regen in der Nähe","Day":6,"WeatherType":2},{"Date":"2020-06-28T15:00:00","Sunrise":"2020-06-28T05:35:00","Sunset":"2020-06-28T21:32:00","Condition":176,"ID":335946002,"Humidity":71,"Temperature":21,"Icon":"wsymbol_0009_light_rain_showers","ConditionName":"Stellenweise Regen in der Nähe","Day":0,"WeatherType":1}],"ErrorMessage":null,"ErrorCode":8000,"DefaultHeatingSetTemperature":24,"DefaultCoolingSetTemperature":20,"HideVaneControls":false,"HideDryModeControl":false,"RoomTemperatureLabel":0,"InStandbyMode":false,"TemperatureIncrementOverride":0,"ProhibitSetTemperature":false,"ProhibitOperationMode":false,"ProhibitPower":false,"DeviceID":177841,"DeviceType":0,"LastCommunication":"2020-06-27T05:28:23.21","NextCommunication":"2020-06-27T05:29:23.21","Power":true,"HasPendingCommand":true,"Offline":false,"Scene":null,"SceneOwner":null}
                  2020-06-27 07:28:30.619 - debug: melcloud.0 (19146) Updated device data for device 177841 (Schlafzimmer)
                  2020-06-27 07:28:44.347 - info: unifi.0 (13422) Update done
                  2020-06-27 07:28:50.189 - debug: melcloud.0 (19146) Trying to get device object with id 177841...
                  2020-06-27 07:28:50.190 - debug: melcloud.0 (19146) Processing change for device object with id 177841 (Schlafzimmer)...
                  2020-06-27 07:28:50.190 - debug: melcloud.0 (19146) Data already available for: 177841 (Schlafzimmer)
                  2020-06-27 07:28:50.190 - info: melcloud.0 (19146) Changing device option 'VaneHorizontalDirection' to '12'...
                  2020-06-27 07:28:50.316 - debug: melcloud.0 (19146) Received response from: https://app.melcloud.com/Mitsubishi.Wifi.Client/Device/SetAta (status code: 200 - OK)
                  2020-06-27 07:28:50.317 - debug: melcloud.0 (19146) Parsed response from cloud: {"EffectiveFlags":256,"LocalIPAddress":null,"RoomTemperature":23,"SetTemperature":18,"SetFanSpeed":0,"OperationMode":3,"VaneHorizontal":12,"VaneVertical":7,"Name":null,"NumberOfFanSpeeds":5,"WeatherObservations":[{"Date":"2020-06-27T06:00:00","Sunrise":"2020-06-27T05:35:00","Sunset":"2020-06-27T21:32:00","Condition":116,"ID":335469463,"Humidity":81,"Temperature":20,"Icon":"wsymbol_0002_sunny_intervals","ConditionName":"Teilweise bewölkt","Day":6,"WeatherType":0},{"Date":"2020-06-27T15:00:00","Sunrise":"2020-06-27T05:35:00","Sunset":"2020-06-27T21:32:00","Condition":116,"ID":335469466,"Humidity":55,"Temperature":27,"Icon":"wsymbol_0002_sunny_intervals","ConditionName":"Teilweise bewölkt","Day":6,"WeatherType":1},{"Date":"2020-06-28T03:00:00","Sunrise":"2020-06-28T05:35:00","Sunset":"2020-06-28T21:32:00","Condition":176,"ID":335945998,"Humidity":87,"Temperature":17,"Icon":"wsymbol_0025_light_rain_showers_night","ConditionName":"Stellenweise Regen in der Nähe","Day":6,"WeatherType":2},{"Date":"2020-06-28T15:00:00","Sunrise":"2020-06-28T05:35:00","Sunset":"2020-06-28T21:32:00","Condition":176,"ID":335946002,"Humidity":71,"Temperature":21,"Icon":"wsymbol_0009_light_rain_showers","ConditionName":"Stellenweise Regen in der Nähe","Day":0,"WeatherType":1}],"ErrorMessage":null,"ErrorCode":8000,"DefaultHeatingSetTemperature":24,"DefaultCoolingSetTemperature":20,"HideVaneControls":false,"HideDryModeControl":false,"RoomTemperatureLabel":0,"InStandbyMode":false,"TemperatureIncrementOverride":0,"ProhibitSetTemperature":false,"ProhibitOperationMode":false,"ProhibitPower":false,"DeviceID":177841,"DeviceType":0,"LastCommunication":"2020-06-27T05:28:23.21","NextCommunication":"2020-06-27T05:29:23.21","Power":true,"HasPendingCommand":true,"Offline":false,"Scene":null,"SceneOwner":null}
                  2020-06-27 07:28:50.449 - debug: melcloud.0 (19146) Updated device data for device 177841 (Schlafzimmer)
                  2020-06-27 07:28:54.759 - info: sql.0 (13342) enabled logging of synology.0.DiskStationManager.info.temperature, Alias=false
                  2020-06-27 07:29:09.379 - info: sql.0 (13342) enabled logging of synology.0.DiskStationManager.info.temperature, Alias=false
                  2020-06-27 07:29:10.186 - debug: melcloud.0 (19146) Trying to get device object with id 177841...
                  2020-06-27 07:29:10.187 - debug: melcloud.0 (19146) Processing change for device object with id 177841 (Schlafzimmer)...
                  2020-06-27 07:29:10.187 - debug: melcloud.0 (19146) Data already available for: 177841 (Schlafzimmer)
                  2020-06-27 07:29:10.188 - info: melcloud.0 (19146) Changing device option 'VaneVerticalDirection' to '7'...
                  2020-06-27 07:29:10.396 - debug: melcloud.0 (19146) Received response from: https://app.melcloud.com/Mitsubishi.Wifi.Client/Device/SetAta (status code: 200 - OK)
                  2020-06-27 07:29:10.397 - debug: melcloud.0 (19146) Parsed response from cloud: {"EffectiveFlags":16,"LocalIPAddress":null,"RoomTemperature":23,"SetTemperature":18,"SetFanSpeed":0,"OperationMode":3,"VaneHorizontal":12,"VaneVertical":7,"Name":null,"NumberOfFanSpeeds":5,"WeatherObservations":[{"Date":"2020-06-27T06:00:00","Sunrise":"2020-06-27T05:35:00","Sunset":"2020-06-27T21:32:00","Condition":116,"ID":335469463,"Humidity":81,"Temperature":20,"Icon":"wsymbol_0002_sunny_intervals","ConditionName":"Teilweise bewölkt","Day":6,"WeatherType":0},{"Date":"2020-06-27T15:00:00","Sunrise":"2020-06-27T05:35:00","Sunset":"2020-06-27T21:32:00","Condition":116,"ID":335469466,"Humidity":55,"Temperature":27,"Icon":"wsymbol_0002_sunny_intervals","ConditionName":"Teilweise bewölkt","Day":6,"WeatherType":1},{"Date":"2020-06-28T03:00:00","Sunrise":"2020-06-28T05:35:00","Sunset":"2020-06-28T21:32:00","Condition":176,"ID":335945998,"Humidity":87,"Temperature":17,"Icon":"wsymbol_0025_light_rain_showers_night","ConditionName":"Stellenweise Regen in der Nähe","Day":6,"WeatherType":2},{"Date":"2020-06-28T15:00:00","Sunrise":"2020-06-28T05:35:00","Sunset":"2020-06-28T21:32:00","Condition":176,"ID":335946002,"Humidity":71,"Temperature":21,"Icon":"wsymbol_0009_light_rain_showers","ConditionName":"Stellenweise Regen in der Nähe","Day":0,"WeatherType":1}],"ErrorMessage":null,"ErrorCode":8000,"DefaultHeatingSetTemperature":24,"DefaultCoolingSetTemperature":20,"HideVaneControls":false,"HideDryModeControl":false,"RoomTemperatureLabel":0,"InStandbyMode":false,"TemperatureIncrementOverride":0,"ProhibitSetTemperature":false,"ProhibitOperationMode":false,"ProhibitPower":false,"DeviceID":177841,"DeviceType":0,"LastCommunication":"2020-06-27T05:28:23.21","NextCommunication":"2020-06-27T05:29:23.21","Power":true,"HasPendingCommand":true,"Offline":false,"Scene":null,"SceneOwner":null}
                  2020-06-27 07:29:10.518 - debug: melcloud.0 (19146) Updated device data for device 177841 (Schlafzimmer)
                  2020-06-27 07:31:27.874 - debug: melcloud.0 (19146) Trying to get device object with id 177841...
                  2020-06-27 07:31:27.875 - debug: melcloud.0 (19146) Processing change for device object with id 177841 (Schlafzimmer)...
                  2020-06-27 07:31:27.876 - info: melcloud.0 (19146) Getting device data for 177841 (Schlafzimmer)
                  2020-06-27 07:31:27.892 - debug: melcloud.0 (19146) Trying to get device object with id 177841...
                  2020-06-27 07:31:27.893 - debug: melcloud.0 (19146) Processing change for device object with id 177841 (Schlafzimmer)...
                  2020-06-27 07:31:27.894 - info: melcloud.0 (19146) Getting device data for 177841 (Schlafzimmer)
                  2020-06-27 07:31:28.078 - debug: melcloud.0 (19146) Received response from: https://app.melcloud.com/Mitsubishi.Wifi.Client/Device/Get?id=177841&buildingID=112112 (status code: 200 - OK)
                  2020-06-27 07:31:28.079 - debug: melcloud.0 (19146) Parsed response from cloud: {"EffectiveFlags":0,"LocalIPAddress":null,"RoomTemperature":23,"SetTemperature":18,"SetFanSpeed":0,"OperationMode":3,"VaneHorizontal":12,"VaneVertical":7,"Name":null,"NumberOfFanSpeeds":5,"WeatherObservations":[{"Date":"2020-06-27T09:00:00","Sunrise":"2020-06-27T05:35:00","Sunset":"2020-06-27T21:32:00","Condition":116,"ID":335469464,"Humidity":65,"Temperature":24,"Icon":"wsymbol_0002_sunny_intervals","ConditionName":"Teilweise bewölkt","Day":6,"WeatherType":0},{"Date":"2020-06-27T15:00:00","Sunrise":"2020-06-27T05:35:00","Sunset":"2020-06-27T21:32:00","Condition":116,"ID":335469466,"Humidity":55,"Temperature":27,"Icon":"wsymbol_0002_sunny_intervals","ConditionName":"Teilweise bewölkt","Day":6,"WeatherType":1},{"Date":"2020-06-28T03:00:00","Sunrise":"2020-06-28T05:35:00","Sunset":"2020-06-28T21:32:00","Condition":176,"ID":335945998,"Humidity":87,"Temperature":17,"Icon":"wsymbol_0025_light_rain_showers_night","ConditionName":"Stellenweise Regen in der Nähe","Day":6,"WeatherType":2},{"Date":"2020-06-28T15:00:00","Sunrise":"2020-06-28T05:35:00","Sunset":"2020-06-28T21:32:00","Condition":176,"ID":335946002,"Humidity":71,"Temperature":21,"Icon":"wsymbol_0009_light_rain_showers","ConditionName":"Stellenweise Regen in der Nähe","Day":0,"WeatherType":1}],"ErrorMessage":null,"ErrorCode":8000,"DefaultHeatingSetTemperature":24,"DefaultCoolingSetTemperature":20,"HideVaneControls":false,"HideDryModeControl":false,"RoomTemperatureLabel":0,"InStandbyMode":false,"TemperatureIncrementOverride":0,"ProhibitSetTemperature":false,"ProhibitOperationMode":false,"ProhibitPower":false,"DeviceID":177841,"DeviceType":0,"LastCommunication":"2020-06-27T05:31:27.793","NextCommunication":"2020-06-27T05:32:27.793","Power":false,"HasPendingCommand":false,"Offline":false,"Scene":null,"SceneOwner":null}
                  2020-06-27 07:31:28.080 - info: melcloud.0 (19146) Changing device option 'TargetHeatingCoolingState' to '3'...
                  2020-06-27 07:31:28.088 - debug: melcloud.0 (19146) Received response from: https://app.melcloud.com/Mitsubishi.Wifi.Client/Device/Get?id=177841&buildingID=112112 (status code: 200 - OK)
                  2020-06-27 07:31:28.089 - debug: melcloud.0 (19146) Parsed response from cloud: {"EffectiveFlags":0,"LocalIPAddress":null,"RoomTemperature":23,"SetTemperature":18,"SetFanSpeed":0,"OperationMode":3,"VaneHorizontal":12,"VaneVertical":7,"Name":null,"NumberOfFanSpeeds":5,"WeatherObservations":[{"Date":"2020-06-27T09:00:00","Sunrise":"2020-06-27T05:35:00","Sunset":"2020-06-27T21:32:00","Condition":116,"ID":335469464,"Humidity":65,"Temperature":24,"Icon":"wsymbol_0002_sunny_intervals","ConditionName":"Teilweise bewölkt","Day":6,"WeatherType":0},{"Date":"2020-06-27T15:00:00","Sunrise":"2020-06-27T05:35:00","Sunset":"2020-06-27T21:32:00","Condition":116,"ID":335469466,"Humidity":55,"Temperature":27,"Icon":"wsymbol_0002_sunny_intervals","ConditionName":"Teilweise bewölkt","Day":6,"WeatherType":1},{"Date":"2020-06-28T03:00:00","Sunrise":"2020-06-28T05:35:00","Sunset":"2020-06-28T21:32:00","Condition":176,"ID":335945998,"Humidity":87,"Temperature":17,"Icon":"wsymbol_0025_light_rain_showers_night","ConditionName":"Stellenweise Regen in der Nähe","Day":6,"WeatherType":2},{"Date":"2020-06-28T15:00:00","Sunrise":"2020-06-28T05:35:00","Sunset":"2020-06-28T21:32:00","Condition":176,"ID":335946002,"Humidity":71,"Temperature":21,"Icon":"wsymbol_0009_light_rain_showers","ConditionName":"Stellenweise Regen in der Nähe","Day":0,"WeatherType":1}],"ErrorMessage":null,"ErrorCode":8000,"DefaultHeatingSetTemperature":24,"DefaultCoolingSetTemperature":20,"HideVaneControls":false,"HideDryModeControl":false,"RoomTemperatureLabel":0,"InStandbyMode":false,"TemperatureIncrementOverride":0,"ProhibitSetTemperature":false,"ProhibitOperationMode":false,"ProhibitPower":false,"DeviceID":177841,"DeviceType":0,"LastCommunication":"2020-06-27T05:31:27.793","NextCommunication":"2020-06-27T05:32:27.793","Power":false,"HasPendingCommand":false,"Offline":false,"Scene":null,"SceneOwner":null}
                  2020-06-27 07:31:28.090 - info: melcloud.0 (19146) Changing device option 'PowerState' to 'false'...
                  2020-06-27 07:31:28.235 - debug: melcloud.0 (19146) Received response from: https://app.melcloud.com/Mitsubishi.Wifi.Client/Device/SetAta (status code: 200 - OK)
                  2020-06-27 07:31:28.236 - debug: melcloud.0 (19146) Parsed response from cloud: {"EffectiveFlags":3,"LocalIPAddress":null,"RoomTemperature":23,"SetTemperature":18,"SetFanSpeed":0,"OperationMode":3,"VaneHorizontal":12,"VaneVertical":7,"Name":null,"NumberOfFanSpeeds":5,"WeatherObservations":[{"Date":"2020-06-27T09:00:00","Sunrise":"2020-06-27T05:35:00","Sunset":"2020-06-27T21:32:00","Condition":116,"ID":335469464,"Humidity":65,"Temperature":24,"Icon":"wsymbol_0002_sunny_intervals","ConditionName":"Teilweise bewölkt","Day":6,"WeatherType":0},{"Date":"2020-06-27T15:00:00","Sunrise":"2020-06-27T05:35:00","Sunset":"2020-06-27T21:32:00","Condition":116,"ID":335469466,"Humidity":55,"Temperature":27,"Icon":"wsymbol_0002_sunny_intervals","ConditionName":"Teilweise bewölkt","Day":6,"WeatherType":1},{"Date":"2020-06-28T03:00:00","Sunrise":"2020-06-28T05:35:00","Sunset":"2020-06-28T21:32:00","Condition":176,"ID":335945998,"Humidity":87,"Temperature":17,"Icon":"wsymbol_0025_light_rain_showers_night","ConditionName":"Stellenweise Regen in der Nähe","Day":6,"WeatherType":2},{"Date":"2020-06-28T15:00:00","Sunrise":"2020-06-28T05:35:00","Sunset":"2020-06-28T21:32:00","Condition":176,"ID":335946002,"Humidity":71,"Temperature":21,"Icon":"wsymbol_0009_light_rain_showers","ConditionName":"Stellenweise Regen in der Nähe","Day":0,"WeatherType":1}],"ErrorMessage":null,"ErrorCode":8000,"DefaultHeatingSetTemperature":24,"DefaultCoolingSetTemperature":20,"HideVaneControls":false,"HideDryModeControl":false,"RoomTemperatureLabel":0,"InStandbyMode":false,"TemperatureIncrementOverride":0,"ProhibitSetTemperature":false,"ProhibitOperationMode":false,"ProhibitPower":false,"DeviceID":177841,"DeviceType":0,"LastCommunication":"2020-06-27T05:31:27.793","NextCommunication":"2020-06-27T05:32:27.793","Power":false,"HasPendingCommand":true,"Offline":false,"Scene":null,"SceneOwner":null}
                  2020-06-27 07:31:28.274 - debug: melcloud.0 (19146) Received response from: https://app.melcloud.com/Mitsubishi.Wifi.Client/Device/SetAta (status code: 200 - OK)
                  2020-06-27 07:31:28.275 - debug: melcloud.0 (19146) Parsed response from cloud: {"EffectiveFlags":1,"LocalIPAddress":null,"RoomTemperature":23,"SetTemperature":18,"SetFanSpeed":0,"OperationMode":3,"VaneHorizontal":12,"VaneVertical":7,"Name":null,"NumberOfFanSpeeds":5,"WeatherObservations":[{"Date":"2020-06-27T09:00:00","Sunrise":"2020-06-27T05:35:00","Sunset":"2020-06-27T21:32:00","Condition":116,"ID":335469464,"Humidity":65,"Temperature":24,"Icon":"wsymbol_0002_sunny_intervals","ConditionName":"Teilweise bewölkt","Day":6,"WeatherType":0},{"Date":"2020-06-27T15:00:00","Sunrise":"2020-06-27T05:35:00","Sunset":"2020-06-27T21:32:00","Condition":116,"ID":335469466,"Humidity":55,"Temperature":27,"Icon":"wsymbol_0002_sunny_intervals","ConditionName":"Teilweise bewölkt","Day":6,"WeatherType":1},{"Date":"2020-06-28T03:00:00","Sunrise":"2020-06-28T05:35:00","Sunset":"2020-06-28T21:32:00","Condition":176,"ID":335945998,"Humidity":87,"Temperature":17,"Icon":"wsymbol_0025_light_rain_showers_night","ConditionName":"Stellenweise Regen in der Nähe","Day":6,"WeatherType":2},{"Date":"2020-06-28T15:00:00","Sunrise":"2020-06-28T05:35:00","Sunset":"2020-06-28T21:32:00","Condition":176,"ID":335946002,"Humidity":71,"Temperature":21,"Icon":"wsymbol_0009_light_rain_showers","ConditionName":"Stellenweise Regen in der Nähe","Day":0,"WeatherType":1}],"ErrorMessage":null,"ErrorCode":8000,"DefaultHeatingSetTemperature":24,"DefaultCoolingSetTemperature":20,"HideVaneControls":false,"HideDryModeControl":false,"RoomTemperatureLabel":0,"InStandbyMode":false,"TemperatureIncrementOverride":0,"ProhibitSetTemperature":false,"ProhibitOperationMode":false,"ProhibitPower":false,"DeviceID":177841,"DeviceType":0,"LastCommunication":"2020-06-27T05:31:27.793","NextCommunication":"2020-06-27T05:32:27.793","Power":false,"HasPendingCommand":true,"Offline":false,"Scene":null,"SceneOwner":null}
                  2020-06-27 07:31:28.691 - debug: melcloud.0 (19146) Updated device data for device 177841 (Schlafzimmer)
                  2020-06-27 07:31:28.744 - debug: melcloud.0 (19146) Updated device data for device 177841 (Schlafzimmer)
                  2020-06-27 07:31:32.347 - info: melcloud.0 (19146) Fetching context key...
                  2020-06-27 07:31:32.348 - debug: melcloud.0 (19146) MELCloud email address: andyxxxx - MELCloud password: xxxx
                  2020-06-27 07:31:32.521 - debug: melcloud.0 (19146) Received response from: https://app.melcloud.com/Mitsubishi.Wifi.Client/Login/ClientLogin (status code: 200 - OK)
                  2020-06-27 07:31:32.522 - debug: melcloud.0 (19146) Parsed response from cloud: {"ErrorId":null,"ErrorMessage":null,"LoginStatus":0,"UserId":0,"RandomKey":null,"AppVersionAnnouncement":null,"LoginData":{"ContextKey":"622Axxxx","Client":54423,"Terms":1252,"AL":1,"ML":0,"CMI":true,"IsStaff":false,"CUTF":false,"CAA":false,"ReceiveCountryNotifications":false,"ReceiveAllNotifications":false,"CACA":false,"CAGA":false,"MaximumDevices":10,"ShowDiagnostics":false,"Language":4,"Country":218,"RealClient":0,"Name":"Andy Hänggi","UseFahrenheit":false,"Duration":525600,"Expiry":"2021-06-27T05:31:32.423","CMSC":false,"PartnerApplicationVersion":null,"EmailSettingsReminderShown":true,"EmailUnitErrors":1,"EmailCommsErrors":0,"ChartSeriesHidden":0,"IsImpersonated":false,"LanguageCode":"de","CountryName":"Schweiz","CurrencySymbol":"CHF","SupportEmailAddress":null,"DateSeperator":"/","TimeSeperator":":","AtwLogoFile":"ecodan_logo.png","DECCReport":false,"CSVReport1min":false,"HidePresetPanel":false,"EmailSettingsReminderRequired":false,"TermsText":null,"MapView":false,"MapZoom":18,"MapLongitude":xxxx7410789690332,"MapLatitude":xxxx219371642502},"ListPendingInvite":[],"ListOwnershipChangeRequest":[],"ListPendingAnnouncement":[],"LoginMinutes":0,"LoginAttempts":0}
                  2020-06-27 07:31:32.523 - debug: melcloud.0 (19146) Login successful. ContextKey: 622Axxxx
                  2020-06-27 07:31:32.523 - info: melcloud.0 (19146) Fetching devices...
                  2020-06-27 07:31:32.708 - debug: melcloud.0 (19146) Received response from: https://app.melcloud.com/Mitsubishi.Wifi.Client/User/ListDevices (status code: 200 - OK)
                  2020-06-27 07:31:32.711 - debug: melcloud.0 (19146) Parsed response from cloud: [{"ID":112112,"Name":"Hänggi","AddressLine1":"Teichstrasse 92","AddressLine2":null,"City":"Therwil","Postcode":"4106","Latitude":47.502419,"Longitude":7.5478945,"District":null,"FPDefined":false,"FPEnabled":false,"FPMinTemperature":14,"FPMaxTemperature":16,"HMDefined":false,"HMEnabled":false,"HMStartDate":null,"HMEndDate":null,"BuildingType":2,"PropertyType":1,"DateBuilt":"1989-06-30T00:00:00","HasGasSupply":false,"LocationLookupDate":"2019-07-24T16:53:44.327","Country":218,"TimeZoneContinent":3,"TimeZoneCity":52,"TimeZone":119,"Location":4855,"CoolingDisabled":false,"Expanded":true,"Structure":{"Floors":[{"ID":30332,"Name":"OG","BuildingId":112112,"AccessLevel":4,"DirectAccess":false,"EndDate":"2500-01-01T00:00:00","Areas":[{"ID":37254,"Name":"Schlafzimmer","BuildingId":112112,"FloorId":30332,"AccessLevel":4,"DirectAccess":false,"EndDate":"2500-01-01T00:00:00","MinTemperature":0,"MaxTemperature":40,"Expanded":true,"Devices":[{"DeviceID":177841,"DeviceName":"Schlafzimmer","BuildingID":112112,"BuildingName":null,"FloorID":30332,"FloorName":null,"AreaID":37254,"AreaName":null,"ImageID":-10000,"InstallationDate":"2019-05-31T00:00:00","LastServiceDate":"2019-05-31T00:00:00","Presets":[{"SetTemperature":18,"Power":true,"OperationMode":3,"VaneHorizontal":0,"VaneVertical":0,"FanSpeed":0,"ID":79060,"Client":54423,"DeviceLocation":177841,"Number":1,"Configuration":"18true3000","NumberDescription":"Vollkühlen"},{"SetTemperature":20,"Power":true,"OperationMode":3,"VaneHorizontal":5,"VaneVertical":5,"FanSpeed":1,"ID":79063,"Client":54423,"DeviceLocation":177841,"Number":2,"Configuration":"20true3551","NumberDescription":"Nachtbetrieb"},{"SetTemperature":23,"Power":true,"OperationMode":8,"VaneHorizontal":0,"VaneVertical":0,"FanSpeed":0,"ID":111673,"Client":54423,"DeviceLocation":177841,"Number":3,"Configuration":"23true8000","NumberDescription":"Automatik"}],"OwnerID":null,"OwnerName":null,"OwnerEmail":null,"AccessLevel":4,"DirectAccess":false,"EndDate":"2500-01-01T00:00:00","Zone1Name":null,"Zone2Name":null,"MinTemperature":0,"MaxTemperature":40,"HideVaneControls":false,"HideDryModeControl":false,"HideRoomTemperature":false,"HideSupplyTemperature":false,"HideOutdoorTemperature":false,"BuildingCountry":null,"OwnerCountry":null,"AdaptorType":-1,"LinkedDevice":null,"Type":0,"MacAddress":"10:98xxxx","SerialNumber":"1903193341","Device":{"ListHistory24Formatters":[null,null,{"Delegate":{},"target0":{},"method0":{"Name":"<.cctor>b__352_0","AssemblyName":"Mitsubishi.Wifi.Data, Version=1.20.0.5, Culture=neutral, PublicKeyToken=3677xxxx","ClassName":"Mitsubishi.Wifi.Data.Entities.Device.AtaDeviceSettings+<>c","Signature":"System.String <.cctor>b__352_0(System.Object)","Signature2":"System.String <.cctor>b__352_0(System.Object)","MemberType":8,"GenericArguments":null}},{"Delegate":{},"target0":{},"method0":{"Name":"<.cctor>b__352_1","AssemblyName":"Mitsubishi.Wifi.Data, Version=1.20.0.5, Culture=neutral, PublicKeyToken=3677xxxx","ClassName":"Mitsubishi.Wifi.Data.Entities.Device.AtaDeviceSettings+<>c","Signature":"System.String <.cctor>b__352_1(System.Object)","Signature2":"System.String <.cctor>b__352_1(System.Object)","MemberType":8,"GenericArguments":null}},{"Delegate":{},"target0":{},"method0":{"Name":"<.cctor>b__352_2","AssemblyName":"Mitsubishi.Wifi.Data, Version=1.20.0.5, Culture=neutral, PublicKeyToken=3677xxxx","ClassName":"Mitsubishi.Wifi.Data.Entities.Device.AtaDeviceSettings+<>c","Signature":"System.String <.cctor>b__352_2(System.Object)","Signature2":"System.String <.cctor>b__352_2(System.Object)","MemberType":8,"GenericArguments":null}},{"Delegate":{},"target0":{},"method0":{"Name":"<.cctor>b__352_3","AssemblyName":"Mitsubishi.Wifi.Data, Version=1.20.0.5, Culture=neutral, PublicKeyToken=3677xxxx","ClassName":"Mitsubishi.Wifi.Data.Entities.Device.AtaDeviceSettings+<>c","Signature":"System.String <.cctor>b__352_3(System.Object)","Signature2":"System.String <.cctor>b__352_3(System.Object)","MemberType":8,"GenericArguments":null}},{"Delegate":{},"target0":{},"method0":{"Name":"<.cctor>b__352_4","AssemblyName":"Mitsubishi.Wifi.Data, Version=1.20.0.5, Culture=neutral, PublicKeyToken=3677xxxx","ClassName":"Mitsubishi.Wifi.Data.Entities.Device.AtaDeviceSettings+<>c","Signature":"System.String <.cctor>b__352_4(System.Object)","Signature2":"System.String <.cctor>b__352_4(System.Object)","MemberType":8,"GenericArguments":null}},null,null,null,null,{"Delegate":{},"target0":{},"method0":{"Name":"<.cctor>b__352_5","AssemblyName":"Mitsubishi.Wifi.Data, Version=1.20.0.5, Culture=neutral, PublicKeyToken=36776ba0808eb702","ClassName":"Mitsubishi.Wifi.Data.Entities.Device.AtaDeviceSettings+<>c","Signature":"System.String <.cctor>b__352_5(System.Object)","Signature2":"System.String <.cctor>b__352_5(System.Object)","MemberType":8,"GenericArguments":null}},{"Delegate":{},"target0":{},"method0":{"Name":"<.cctor>b__352_6","AssemblyName":"Mitsubishi.Wifi.Data, Version=1.20.0.5, Culture=neutral, PublicKeyToken=3677xxxx","ClassName":"Mitsubishi.Wifi.Data.Entities.Device.AtaDeviceSettings+<>c","Signature":"System.String <.cctor>b__352_6(System.Object)","Signature2":"System.String <.cctor>b__352_6(System.Object)","MemberType":8,"GenericArguments":null}},{"Delegate":{},"target0":{},"method0":{"Name":"<.cctor>b__352_7","AssemblyName":"Mitsubishi.Wifi.Data, Version=1.20.0.5, Culture=neutral, PublicKeyToken=36776ba0808eb702","ClassName":"Mitsubishi.Wifi.Data.Entities.Device.AtaDeviceSettings+<>c","Signature":"System.String <.cctor>b__352_7(System.Object)","Signature2":"System.String <.cctor>b__352_7(System.Object)","MemberType":8,"GenericArguments":null}},{"Delegate":{},"target0":{},"method0":{"Name":"<.cctor>b__352_8","AssemblyName":"Mitsubishi.Wifi.Data, Version=1.20.0.5, Culture=neutral, PublicKeyToken=36776ba0808eb702","ClassName":"Mitsubishi.Wifi.Data.Entities.Device.AtaDeviceSettings+<>c","Signature":"System.String <.cctor>b__352_8(System.Object)","Signature2":"System.String <.cctor>b__352_8(System.Object)","MemberType":8,"GenericArguments":null}},{"Delegate":{},"target0":{},"method0":{"Name":"<.cctor>b__352_9","AssemblyName":"Mitsubishi.Wifi.Data, Version=1.20.0.5, Culture=neutral, PublicKeyToken=3677xxxx","ClassName":"Mitsubishi.Wifi.Data.Entities.Device.AtaDeviceSettings+<>c","Signature":"System.String <.cctor>b__352_9(System.Object)","Signature2":"System.String <.cctor>b__352_9(System.Object)","MemberType":8,"GenericArguments":null}},null,null,null],"DeviceType":0,"CanCool":true,"CanHeat":true,"CanDry":true,"HasAutomaticFanSpeed":true,"AirDirectionFunction":true,"SwingFunction":true,"NumberOfFanSpeeds":5,"UseTemperatureA":true,"TemperatureIncrementOverride":0,"TemperatureIncrement":0.5,"MinTempCoolDry":16,"MaxTempCoolDry":31,"MinTempHeat":10,"MaxTempHeat":31,"MinTempAutomatic":16,"MaxTempAutomatic":31,"LegacyDevice":false,"UnitSupportsStandbyMode":true,"HasWideVane":false,"ModelIsAirCurtain":false,"ModelSupportsFanSpeed":true,"ModelSupportsAuto":true,"ModelSupportsHeat":true,"ModelSupportsDry":true,"ModelSupportsVaneVertical":true,"ModelSupportsVaneHorizontal":true,"ModelSupportsWideVane":true,"ModelDisableEnergyReport":false,"ModelSupportsStandbyMode":true,"ModelSupportsEnergyReporting":true,"ProhibitSetTemperature":false,"ProhibitOperationMode":false,"ProhibitPower":false,"Power":false,"RoomTemperature":23,"SetTemperature":18,"ActualFanSpeed":0,"FanSpeed":0,"AutomaticFanSpeed":true,"VaneVerticalDirection":7,"VaneVerticalSwing":true,"VaneHorizontalDirection":12,"VaneHorizontalSwing":true,"OperationMode":3,"EffectiveFlags":3,"LastEffectiveFlags":0,"InStandbyMode":false,"DefaultCoolingSetTemperature":20,"DefaultHeatingSetTemperature":24,"RoomTemperatureLabel":0,"HeatingEnergyConsumedRate1":0,"HeatingEnergyConsumedRate2":0,"CoolingEnergyConsumedRate1":0,"CoolingEnergyConsumedRate2":0,"AutoEnergyConsumedRate1":0,"AutoEnergyConsumedRate2":0,"DryEnergyConsumedRate1":0,"DryEnergyConsumedRate2":0,"FanEnergyConsumedRate1":0,"FanEnergyConsumedRate2":0,"OtherEnergyConsumedRate1":0,"OtherEnergyConsumedRate2":0,"HasEnergyConsumedMeter":true,"CurrentEnergyConsumed":12800,"CurrentEnergyMode":3,"CoolingDisabled":false,"MinPcycle":1,"MaxPcycle":1,"EffectivePCycle":1,"MaxOutdoorUnits":255,"MaxIndoorUnits":255,"MaxTemperatureControlUnits":0,"DeviceID":177841,"MacAddress":"10:98:xxxxx","SerialNumber":"1903xxxxx","TimeZoneID":119,"DiagnosticMode":0,"DiagnosticEndDate":null,"ExpectedCommand":1,"Owner":null,"DetectedCountry":null,"AdaptorType":-1,"FirmwareDeployment":null,"FirmwareUpdateAborted":false,"LinkedDevice":null,"WifiSignalStrength":-65,"WifiAdapterStatus":"NORMAL","Position":"Unknown","PCycle":1,"RecordNumMax":0,"LastTimeStamp":"2020-06-27T07:31:00","ErrorCode":8000,"HasError":false,"LastReset":"2019-07-24T16:46:41.14","FlashWrites":0,"Scene":null,"SSLExpirationDate":"2037-12-31T00:00:00","SPTimeout":1,"Passcode":null,"ServerCommunicationDisabled":false,"ConsecutiveUploadErrors":0,"DoNotRespondAfter":null,"OwnerRoleAccessLevel":1,"OwnerCountry":218,"HideEnergyReport":false,"ExceptionHash":null,"ExceptionDate":null,"ExceptionCount":null,"Rate1StartTime":null,"Rate2StartTime":null,"ProtocolVersion":0,"UnitVersion":0,"FirmwareAppVersion":15000,"FirmwareWebVersion":0,"FirmwareWlanVersion":0,"HasErrorMessages":false,"HasZone2":false,"Offline":false,"Units":[]},"DiagnosticMode":0,"DiagnosticEndDate":null,"Location":4855,"DetectedCountry":null,"Registrations":121,"LocalIPAddress":null,"TimeZone":119,"RegistReason":"STARTUP","ExpectedCommand":1,"RegistRetry":0,"DateCreated":"2019-07-24T16:46:41.137","FirmwareDeployment":null,"FirmwareUpdateAborted":false,"Permissions":{"CanSetOperationMode":true,"CanSetFanSpeed":true,"CanSetVaneDirection":true,"CanSetPower":true,"CanSetTemperatureIncrementOverride":true,"CanDisableLocalController":true}}]}],"Devices":[],"MinTemperature":0,"MaxTemperature":40,"Expanded":true}],"Areas":[],"Devices":[],"Clients":[]},"AccessLevel":4,"DirectAccess":true,"MinTemperature":0,"MaxTemperature":40,"Owner":null,"EndDate":"2500-01-01T00:00:00","iDateBuilt":null,"QuantizedCoordinates":{"Latitude":47.5,"Longitude":7.55}}]
                  2020-06-27 07:31:32.711 - debug: melcloud.0 (19146) Got device from cloud: 177841 (Schlafzimmer)
                  2020-06-27 07:31:32.712 - info: melcloud.0 (19146) Saving device data...
                  2020-06-27 07:31:32.989 - debug: melcloud.0 (19146) Created and saved device 177841 (Schlafzimmer)
                    meicker last edited by meicker
                    @Black-Thunder
                    ich schließe mich hanan mal an. Ich habe ebenfalls das Gefühl das mehrfach gesendet werden muss damit etwas passiert. Bei mir ist es ein Blocky wie dieses:
                    Hier das komplette:
                    wobei ich das immer noch am umstricken bin 🙂
                    Im Log steht das '4' erfüllt ist und sollte eigentlich auch anlaufen ...
                    Irgendwann macht sie das dann auch ... liegt es am Script oder am Adapter ?
                    Der Power Status im Adapter wird von mir auf TRUE gesetzt und von Melcloud auf FALSE
                    vg
                    Marc
                    • Black Thunder
                      Black Thunder Developer last edited by
                      Also im Moment ist es so, dass für jede Änderung eine Anfrage abgesendet wird. Anscheinend kommt es da dann bei mehreren Änderungen gleichzeitig (z.B. via Skripte oder Szenen) zu Konflikten, die dann dazu führen können, dass die Änderungen wieder überschrieben werden.
                      Ich versuch mal da eine Art Sammelpool einzubauen und meld mich wieder, wenn's was neues zum Testen gibt.
                        @Black-Thunder
                        Danke 🙂
                        • Black Thunder
                          @meicker @hanan
                          Also , das Problem konnte ich bei mir auch nachstellen. Hab soeben v1.0.6-pre1 hochgeladen, die nun eine Warteschlagen für requests enthält. D.h. jede Anfrage wird nun komplett (inkl. Antwort) abgearbeitet, bevor die nächste bearbeitet wird. Damit löst sich das Problem bei mir und jede Wertänderung wird nun korrekt übernommen.
                          Könntet ihr das bitte auch bei euch testen und mir kurz Rückmeldung geben?
                            meicker @Black Thunder last edited by meicker
                            @Black-Thunder
                            scheint zuverlässiger zu sein ...
                            Power geht ziemlich zügig. Kann es sein das Ventilation und Temperatur tzrotzdem lange brauchen ? Ich habe im Script 3 Parameter geändert und es hat trotzdem lange gedauert bis sie auf AUTO oder auf einen Wert eingestellt wurden. Power ging aber ziemlich zügig ... Behandelst Du alle gleich ? Oder werden sie nach wie vor nur einzeln abgearbeitet aber dafür sicher ? Bei mir funken im schlimmsten Fall alle 5 Minuten 3 Innengeräte Speed, Mode, Power, temp und VVane ... Wie werden diese 15 Signale abgearbeitet ? Minimum sind 5 Signale die gleichzeitig gesendet werden.
                            vg
                            Marc
                            • Black Thunder
                              Black Thunder Developer @meicker last edited by Black Thunder
                              @meicker
                              Es werden weiterhin alle Änderungen einzeln übertragen, so wie es manuell über die App auch erfolgen würde. Nur dass jetzt jede Änderung separat bearbeitet und vollständig abgeschlossen wird, bevor die nächste Änderung dran ist.
                              Die Änderungen an sich werden alle gleich behandelt, auf die tatsächliche Reaktionszeit der Geräte habe ich aber keinen Einfluss. Mir ist allerdings auch schon aufgefallen, dass Power am schnellsten reagiert.
                              Edit: Die Warteschlange gilt übrigens nur pro Gerät, d.h. wenn du bei 3 Innengeräten die Änderungen durch führst, werden diese schon parallel abgearbeitet. Nur eben pro Gerät nacheinander.
                                @Black-Thunder
                                ok - hört sich gut an. Mal abwarten - Aber die Tests eben waren gut und zumindest AN und AUS ging sehr zuverlässig. Der Rest ist auch OK so ... Danke Dir !
                                vg
                                Marc
                                • hanan
                                  Hallo Black-Thunder
                                  Mit dem Szenen-Adapter und zwischen den einzelnen Befehl 10 Sekunden Verzögerung funktioniert es super. Habe bis jetzt keinen verschlungenen Befehl mehr gefunden.
                                  Besten Dank und noch einen schönen Sonntag.
                                  • Black Thunder
                                    Black Thunder Developer last edited by Black Thunder
                                    Nur eine kleine Info: Seit kurzem ist der Adapter auch nun im offiziellen latest Repository aufgenommen, d.h. ihr könnt den Adapter regulär wie andere direkt über der Admin-Oberfläche installieren, ohne den Umweg über GitHub gehen zu müssen. Dazu muss in den ioBroker-Einstellungen der "Aktive Verwahrungsort" auf "latest" gestellt werden.
                                    Auf GitHub liegen dann zukünftig ggf. Versionen zum Alpha-Test, bevor sie als Beta ins latest kommen. Da geb ich dann aber Bescheid, falls es was neues zum Testen gibt.
                                    Edit 03.07.: Jetzt ist v1.0.6 auch im offiziellen stable Repository zu finden und kann ganz regulär installiert werden.
                                    • U
                                      UwesSmartHome @Black Thunder last edited by
                                      @Black-Thunder
                                      Hallo, ich habe den Adapter gefunden und denke er ist sicher auch für die Panasonic Wärmepumpen Cloud geeignet.
                                      Wäre es möglich die Cloud https Adresse editierbar zu machen im ersten Schritt?
                                      Hier habe ich die webadresse der Cloud.https://aquarea-smart.panasonic.com/
                                      Ich kann auch gerne die Zugangsdaten zum Testen zur Verfügung stellen.
                                      Vorerst würde auch nur der Login mit Passwort und Benutzer genügen, den Rest der Daten kann man auch mit dem Parser Adapter erstmal auslesen. Steuern wäre natürch im 2. Schritt traumhaft.
                                      Da ich etwas Programmiererfahrung in C/C# habe, wäre auch eine Mitarbeit machbar.
                                      Grüsse Uwe
                                      • Black Thunder
                                        Black Thunder Developer @UwesSmartHome last edited by
                                        @UwesSmartHome
                                        Eine andere Adresse aufzurufen, wäre sicherlich nicht das Problem. Allerdings ist der Adapter schon sehr spezifisch für MELCloud entwickelt. Von daher denke ich nicht, dass es reicht, die URL zu ändern. Leider fehlt mir die Zeit, mich damit näher zu beschäftigen. 😉
                                        Du kannst ja gerne mein Repo auf GitHub forken und etwas experimentieren, wenn du möchtest. Der erste Ansatzpunkt, um den Aufruf zu ändern, wäre an dieser Stelle.
                                        • hanan
                                          Guten Tag Black-Thunder
                                          Nur als Info...
                                          Irgendwie funzt bei meinem Innengerät die Steuerung der Luftauslasse nicht.
                                          Ich habe zwei Szenen welche ich sende. Die Daten werden gesendet und in den Objekten übernommen sowie in der Cloud auch angezeigt, doch das Gerät ändert die Lamellen nicht. Gehe davon aus, das dieses ein Problem von Mitsu ist und nicht von Deinem Adapter.
                                          • Black Thunder
                                            Black Thunder Developer @hanan last edited by Black Thunder
                                            @hanan
                                            Also wenn die Änderungen korrekt in der Cloud angezeigt werden, gehe ich auch davon aus, dass es ein Kommunikationsproblem MELCloud -> Innengerät ist und nicht am Adapter selbst liegt.
                                            Funktioniert es denn, wenn du die Änderungen direkt in der App durchführst?
                                            31.7k
                                            79.8k
                                            klimaanlage melcloud mitsubishi test
                                            10
                                            59
                                            6718
