    4. JavaScript
    5. [Vorlage] Generisches Fensteroffenskript + Vis
      sigi234 Forum Testing Most Active @Pittini last edited by sigi234
      @Pittini
      11:02:54.102	warn	javascript.0 (184) script.js.common.Fenster_Pittini3: Unknown Windowstate undefined detected at hm-rpc.0.OEQ0926852.1, please check your configuration
      RAW vom DP:
        "type": "state",
        "common": {
          "def": false,
          "type": "boolean",
          "read": false,
          "write": false,
          "role": "indicator",
          "name": "Badfenster.INSTALL_TEST"
        "native": {
          "DEFAULT": false,
          "FLAGS": 3,
          "ID": "INSTALL_TEST",
          "MAX": true,
          "MIN": false,
          "OPERATIONS": 4,
          "TAB_ORDER": 3,
          "TYPE": "ACTION",
          "UNIT": ""
        "from": "system.adapter.hm-rega.0",
        "user": "system.user.admin",
        "ts": 1580848013546,
        "_id": "hm-rpc.0.OEQ0926852.1.INSTALL_TEST",
        "acl": {
          "object": 1636,
          "state": 1636,
          "owner": "system.user.admin",
      Erledigt, habe die Funktion vom DP gelöscht.
        @Pittini
        Hallo, warum habe ich im Esszimmer ein Fenster?
        11:50:51.653	info	javascript.0 (184) Stop script script.js.common.Fenster_Pittini3
        11:50:51.654	info	javascript.0 (184) script.js.common.Fenster_Pittini3: reaching ClearWarnTime - [x] = 0
        11:50:51.654	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Clearing Interval for 0
        11:50:51.654	info	javascript.0 (184) script.js.common.Fenster_Pittini3: reaching ClearWarnTime - [x] = 1
        11:50:51.654	info	javascript.0 (184) script.js.common.Fenster_Pittini3: reaching ClearWarnTime - [x] = 2
        11:50:52.014	info	javascript.0 (184) Start javascript script.js.common.Fenster_Pittini3
        11:50:52.026	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Raum- 0 = Badzimmer hat Fenstersensor/en
        11:50:52.027	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Raum- 1 = Vorraum hat Türsensor/en
        11:50:52.027	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Raum- 2 = Esszimmer hat Türsensor/en
        11:50:52.028	info	javascript.0 (184) script.js.common.Fenster_Pittini3: registered 0 subscriptions and 0 schedules
        11:50:52.049	info	javascript.0 (184) script.js.common.Fenster_Pittini3: CreateStates fertig!
        11:50:52.049	info	javascript.0 (184) script.js.common.Fenster_Pittini3: x=0=Badzimmer SendWindowWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
        11:50:52.050	info	javascript.0 (184) script.js.common.Fenster_Pittini3: x=1=Esszimmer SendWindowWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
        11:50:52.050	info	javascript.0 (184) script.js.common.Fenster_Pittini3: x=2=Vorraum SendWindowWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
        11:50:52.050	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Reaching CheckForHmShit val=true typof val=string x=0 Sensor[x]=hm-rpc.0.OEQ0926852.1.STATE
        11:50:52.051	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Reaching GetRoom x=0
        11:50:52.051	info	javascript.0 (184) script.js.common.Fenster_Pittini3: reaching CheckWindow, SensorVal[0]=open SensorOldVal= TempRoom=Badzimmer SensorType[x]=Window TempRoomIndex=0
        11:50:52.051	info	javascript.0 (184) script.js.common.Fenster_Pittini3: RoomOpenWindowCount für Badzimmer=1
        11:50:52.051	info	javascript.0 (184) script.js.common.Fenster_Pittini3: SendWindowWarnMsg=true TempRoomIndex=0
        11:50:52.051	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Setting Interval to Room:Badzimmer
        11:50:52.052	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Offene Fenster gesamt= 1
        11:50:52.052	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Alle Türen geschlossen.
        11:50:52.052	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Offene Türen gesamt= 0
        11:50:52.053	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Reaching CheckForHmShit val=false typof val=string x=1 Sensor[x]=hm-rpc.0.NEQ1818500.1.STATE
        11:50:52.053	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Reaching GetRoom x=1
        11:50:52.053	info	javascript.0 (184) script.js.common.Fenster_Pittini3: reaching CheckWindow, SensorVal[1]=closed SensorOldVal= TempRoom=Vorraum SensorType[x]=Door TempRoomIndex=2
        11:50:52.053	info	javascript.0 (184) script.js.common.Fenster_Pittini3: RoomOpenDoorCount[TempRoomIndex]=0 TempRoom=Vorraum TempRoomIndex=2
        11:50:52.054	info	javascript.0 (184) script.js.common.Fenster_Pittini3: reaching ClearWarnTime - [x] = 2
        11:50:52.055	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Offene Fenster gesamt= 1
        11:50:52.055	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Alle Türen geschlossen.
        11:50:52.055	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Offene Türen gesamt= 0
        11:50:52.055	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Reaching CheckForHmShit val=true typof val=string x=2 Sensor[x]=hm-rpc.0.NEQ1826414.1.STATE
        11:50:52.055	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Reaching GetRoom x=2
        11:50:52.055	info	javascript.0 (184) script.js.common.Fenster_Pittini3: reaching CheckWindow, SensorVal[2]=open SensorOldVal= TempRoom=Esszimmer SensorType[x]=Door TempRoomIndex=1
        11:50:52.056	info	javascript.0 (184) script.js.common.Fenster_Pittini3: RoomOpenDoorCount für Esszimmer=1
        11:50:52.056	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Offene Fenster gesamt= 1
        11:50:52.056	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Offene Türen gesamt= 1
        11:50:52.056	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Reaching VentCheck x=0 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1593248764873
        11:50:52.056	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Room 0 = Badzimmer is open or disabled, no vent warning set
        11:50:52.056	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Reaching CreateRoomsWithVentWarnings
        11:50:52.057	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Reaching VentCheck x=1 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1593248450539
        11:50:52.057	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Room 1 = Esszimmer is open or disabled, no vent warning set
        11:50:52.057	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Reaching CreateRoomsWithVentWarnings
        11:50:52.057	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Reaching VentCheck x=2 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1593248450539
        11:50:52.057	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Room 2 = Vorraum is open or disabled, no vent warning set
        11:50:52.059	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Reaching CreateRoomsWithOpenDoorsList
        11:50:52.059	info	javascript.0 (184) script.js.common.Fenster_Pittini3: RoomsWithOpenDoors: Esszimmer 1 offene Tür
        11:50:52.059	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Reaching CreateRoomsWithOpenWindowsList
        11:50:52.060	info	javascript.0 (184) script.js.common.Fenster_Pittini3: RoomsWithOpenWindows: Badzimmer 1 offenes Fenster
        11:50:52.060	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Reaching CreateRoomsWithTiltedWindowsList
        11:50:52.060	info	javascript.0 (184) script.js.common.Fenster_Pittini3: RoomsWithTiltedWindows: Keine Fenster gekippt
        11:50:52.060	info	javascript.0 (184) script.js.common.Fenster_Pittini3: CreateOpenRoomsList()
        11:50:52.060	info	javascript.0 (184) script.js.common.Fenster_Pittini3: RoomsWithOpenings: Badzimmer 1 offenes Fenster<br>Esszimmer 1 offene Tür<br>
        11:50:52.060	info	javascript.0 (184) script.js.common.Fenster_Pittini3: Reaching CreateRoomsWithVentWarnings
          Pittini Developer @sigi234 last edited by Pittini
          @sigi234 sagte in [Vorlage] Generisches Fensteroffenskript + Vis:
          Wo siehst Du das? Ich seh nur ne offene Tür im Esszimmer. Oder überseh ich was Du mir zeigen willst?
          Edit: Ah, ja, jetzt seh ichs. Muss ich mal guggen warum er das meldet.
            @Pittini sagte in [Vorlage] Generisches Fensteroffenskript + Vis:
            Vielleicht mag er ja das Türen nicht:
            //Grundeinstellungen
            const logging = true; //Erweiterte Logs ausgeben?
            const praefix = "javascript.0.FensterUeberwachung."; //Grundpfad für Script DPs - Muß innerhalb javascript.x sein.
            const PresenceDp = "" //Pfad zum Anwesenheitsdatenpunkt, leer lassen wenn nicht vorhanden
            const WhichWindowFunctionToUse = "Fenster"; // Legt fest nach welchem Begriff in Funktionen gesucht wird. Diese Funktion nur dem Datenpunkt zuweisen, NICHT dem ganzen Channel!
            const WhichDoorFunctionToUse = "Türen"; // Legt fest nach welchem Begriff in Funktionen gesucht wird. Diese Funktion nur dem Datenpunkt zuweisen, NICHT dem ganzen Channel!
            const IgnoreTime = 10000; // 10000 ms = 10 Sekunden - Zeit in ms für die kurzzeitiges öffnen/schliessen ignoriert wird
              Sollte egal sein (auch wenn ich persönlich bei sowas NIE deutsche Umlaute verwende). Er hats ja erstmal auch richtig erkannt:
              Hast Du den js Adapter neugestartet nach den Aufzählungsänderungen? Wenn ja, muß ch später mal genauer guggen woher das kommen könnte, kann theoretisch schon durchaus ein Bug sein, is ja ganz frisch mit den Türen, auch wenn mir hier zuhaus im Test nix auffiel.
                Ja, und Türen auf Tueren geändert, gleiches Ergebnis.
                Browser Cache auch geleert.
                • dslraser
                  dslraser Forum Testing Most Active @sigi234 last edited by dslraser
                  @sigi234
                  starte mal die admin Instanz neu (Achtung nicht stoppen, nur auf dem Pfeilkreis neu starten)
                  (immer wenn ich Aufzählungen ändere hilft das meistens)
                  Also nicht nur die JS-Instanz neu starten.
                  damit
                  admin puffert und js puffert.
                  Danach das Browserfenster aktualisieren, nicht nur in Objekten aktualisieren.
                    sigi234 Forum Testing Most Active @dslraser last edited by
                    @dslraser sagte in [Vorlage] Generisches Fensteroffenskript + Vis:
                    Keine Änderung.
                    Dominik F. 1 Reply Last reply Reply Quote 0
                    • Dominik F.
                      Dominik F. @sigi234 last edited by
                      @Pittini
                      Ich habe das gleiche wie @sigi234
                        Pittini Developer last edited by
                        @sigi234 @Dominik-F - Ich kann das grad nicht reproduzieren. Und obiges Log sagt eigentlich alles ok. Trotzdem biegt das Skript zweifellos iwo falsch ab. Also bitte mal von beiden ein startlog und das Log wenn Ihr entsprechende Türen die als Fenster gemeldet werden aufmacht.
                          @Pittini
                          Start:
                          javascript.0	2020-06-27 14:31:42.375	info	(68160) script.js.common.Fenster_Pittini3: Reaching CreateRoomsWithVentWarnings
                          javascript.0	2020-06-27 14:31:42.375	info	(68160) script.js.common.Fenster_Pittini3: RoomsWithOpenings:
                          javascript.0	2020-06-27 14:31:42.375	info	(68160) script.js.common.Fenster_Pittini3: CreateOpenRoomsList()
                          javascript.0	2020-06-27 14:31:42.375	info	(68160) script.js.common.Fenster_Pittini3: RoomsWithTiltedWindows: Keine Fenster gekippt
                          javascript.0	2020-06-27 14:31:42.375	info	(68160) script.js.common.Fenster_Pittini3: Reaching CreateRoomsWithTiltedWindowsList
                          javascript.0	2020-06-27 14:31:42.374	info	(68160) script.js.common.Fenster_Pittini3: RoomsWithOpenWindows: Alle Fenster sind geschlossen
                          javascript.0	2020-06-27 14:31:42.374	info	(68160) script.js.common.Fenster_Pittini3: Reaching CreateRoomsWithOpenWindowsList
                          javascript.0	2020-06-27 14:31:42.374	info	(68160) script.js.common.Fenster_Pittini3: RoomsWithOpenDoors: Keine Tür/en geöffnet
                          javascript.0	2020-06-27 14:31:42.374	info	(68160) script.js.common.Fenster_Pittini3: Reaching CreateRoomsWithOpenDoorsList
                          javascript.0	2020-06-27 14:31:42.371	info	(68160) script.js.common.Fenster_Pittini3: Reaching CreateRoomsWithVentWarnings
                          javascript.0	2020-06-27 14:31:42.371	info	(68160) script.js.common.Fenster_Pittini3: Room 2 = Vorraum is open or disabled, no vent warning set
                          javascript.0	2020-06-27 14:31:42.371	info	(68160) script.js.common.Fenster_Pittini3: Reaching VentCheck x=2 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1593248450539
                          javascript.0	2020-06-27 14:31:42.370	info	(68160) script.js.common.Fenster_Pittini3: Room 1 = Esszimmer is open or disabled, no vent warning set
                          javascript.0	2020-06-27 14:31:42.370	info	(68160) script.js.common.Fenster_Pittini3: Reaching VentCheck x=1 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1593248450539
                          javascript.0	2020-06-27 14:31:42.370	info	(68160) script.js.common.Fenster_Pittini3: Reaching CreateRoomsWithVentWarnings
                          javascript.0	2020-06-27 14:31:42.370	info	(68160) script.js.common.Fenster_Pittini3: Room 0 = Badzimmer is open or disabled, no vent warning set
                          javascript.0	2020-06-27 14:31:42.370	info	(68160) script.js.common.Fenster_Pittini3: Reaching VentCheck x=0 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1593259024290
                          javascript.0	2020-06-27 14:31:42.369	info	(68160) script.js.common.Fenster_Pittini3: Offene Türen gesamt= 0
                          javascript.0	2020-06-27 14:31:42.369	info	(68160) script.js.common.Fenster_Pittini3: Alle Türen geschlossen.
                          javascript.0	2020-06-27 14:31:42.369	info	(68160) script.js.common.Fenster_Pittini3: Offene Fenster gesamt= 0
                          javascript.0	2020-06-27 14:31:42.369	info	(68160) script.js.common.Fenster_Pittini3: Alle Fenster geschlossen.
                          javascript.0	2020-06-27 14:31:42.368	info	(68160) script.js.common.Fenster_Pittini3: reaching ClearWarnTime - [x] = 1
                          javascript.0	2020-06-27 14:31:42.368	info	(68160) script.js.common.Fenster_Pittini3: RoomOpenDoorCount[TempRoomIndex]=0 TempRoom=Esszimmer TempRoomIndex=1
                          javascript.0	2020-06-27 14:31:42.368	info	(68160) script.js.common.Fenster_Pittini3: reaching CheckWindow, SensorVal[2]=closed SensorOldVal= TempRoom=Esszimmer SensorType[x]=Door TempRoomIndex=1
                          javascript.0	2020-06-27 14:31:42.368	info	(68160) script.js.common.Fenster_Pittini3: Reaching GetRoom x=2
                          javascript.0	2020-06-27 14:31:42.368	info	(68160) script.js.common.Fenster_Pittini3: Reaching CheckForHmShit val=false typof val=string x=2 Sensor[x]=hm-rpc.0.NEQ1826414.1.STATE
                          javascript.0	2020-06-27 14:31:42.368	info	(68160) script.js.common.Fenster_Pittini3: Offene Türen gesamt= 0
                          javascript.0	2020-06-27 14:31:42.368	info	(68160) script.js.common.Fenster_Pittini3: Alle Türen geschlossen.
                          javascript.0	2020-06-27 14:31:42.367	info	(68160) script.js.common.Fenster_Pittini3: Offene Fenster gesamt= 0
                          javascript.0	2020-06-27 14:31:42.367	info	(68160) script.js.common.Fenster_Pittini3: Alle Fenster geschlossen.
                          javascript.0	2020-06-27 14:31:42.366	info	(68160) script.js.common.Fenster_Pittini3: reaching ClearWarnTime - [x] = 2
                          javascript.0	2020-06-27 14:31:42.366	info	(68160) script.js.common.Fenster_Pittini3: RoomOpenDoorCount[TempRoomIndex]=0 TempRoom=Vorraum TempRoomIndex=2
                          javascript.0	2020-06-27 14:31:42.364	info	(68160) script.js.common.Fenster_Pittini3: reaching CheckWindow, SensorVal[1]=closed SensorOldVal= TempRoom=Vorraum SensorType[x]=Door TempRoomIndex=2
                          javascript.0	2020-06-27 14:31:42.364	info	(68160) script.js.common.Fenster_Pittini3: Reaching GetRoom x=1
                          javascript.0	2020-06-27 14:31:42.364	info	(68160) script.js.common.Fenster_Pittini3: Reaching CheckForHmShit val=false typof val=string x=1 Sensor[x]=hm-rpc.0.NEQ1818500.1.STATE
                          javascript.0	2020-06-27 14:31:42.364	info	(68160) script.js.common.Fenster_Pittini3: Offene Türen gesamt= 0
                          javascript.0	2020-06-27 14:31:42.364	info	(68160) script.js.common.Fenster_Pittini3: Alle Türen geschlossen.
                          javascript.0	2020-06-27 14:31:42.363	info	(68160) script.js.common.Fenster_Pittini3: Offene Fenster gesamt= 0
                          javascript.0	2020-06-27 14:31:42.363	info	(68160) script.js.common.Fenster_Pittini3: Alle Fenster geschlossen.
                          javascript.0	2020-06-27 14:31:42.362	info	(68160) script.js.common.Fenster_Pittini3: reaching ClearWarnTime - [x] = 0
                          javascript.0	2020-06-27 14:31:42.361	info	(68160) script.js.common.Fenster_Pittini3: reaching CheckWindow, SensorVal[0]=closed SensorOldVal= TempRoom=Badzimmer SensorType[x]=Window TempRoomIndex=0
                          javascript.0	2020-06-27 14:31:42.361	info	(68160) script.js.common.Fenster_Pittini3: Reaching GetRoom x=0
                          javascript.0	2020-06-27 14:31:42.360	info	(68160) script.js.common.Fenster_Pittini3: Reaching CheckForHmShit val=false typof val=string x=0 Sensor[x]=hm-rpc.0.OEQ0926852.1.STATE
                          javascript.0	2020-06-27 14:31:42.360	info	(68160) script.js.common.Fenster_Pittini3: x=2=Vorraum SendWindowWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
                          javascript.0	2020-06-27 14:31:42.360	info	(68160) script.js.common.Fenster_Pittini3: x=1=Esszimmer SendWindowWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
                          javascript.0	2020-06-27 14:31:42.359	info	(68160) script.js.common.Fenster_Pittini3: x=0=Badzimmer SendWindowWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
                          javascript.0	2020-06-27 14:31:42.358	info	(68160) script.js.common.Fenster_Pittini3: CreateStates fertig!
                          javascript.0	2020-06-27 14:31:42.342	info	(68160) script.js.common.Fenster_Pittini3: registered 0 subscriptions and 0 schedules
                          javascript.0	2020-06-27 14:31:42.340	info	(68160) script.js.common.Fenster_Pittini3: Raum- 2 = Esszimmer hat Türsensor/en
                          javascript.0	2020-06-27 14:31:42.340	info	(68160) script.js.common.Fenster_Pittini3: Raum- 1 = Vorraum hat Türsensor/en
                          javascript.0	2020-06-27 14:31:42.339	info	(68160) script.js.common.Fenster_Pittini3: Raum- 0 = Badzimmer hat Fenstersensor/en
                          javascript.0	2020-06-27 14:31:42.318	info	(68160) Start javascript script.js.common.Fenster_Pittini3
                          javascript.0	2020-06-27 14:31:41.838	info	(68160) script.js.common.Fenster_Pittini3: reaching ClearWarnTime - [x] = 2
                          javascript.0	2020-06-27 14:31:41.838	info	(68160) script.js.common.Fenster_Pittini3: reaching ClearWarnTime - [x] = 1
                          javascript.0	2020-06-27 14:31:41.838	info	(68160) script.js.common.Fenster_Pittini3: Clearing Interval for 0
                          javascript.0	2020-06-27 14:31:41.838	info	(68160) script.js.common.Fenster_Pittini3: reaching ClearWarnTime - [x] = 0
                          Terrassentür geöffnet:
                          javascript.0	2020-06-27 14:32:56.467	info	(68160) script.js.common.Fenster_Pittini3: RoomsWithOpenings: Esszimmer 1 offene Tür<br>
                          javascript.0	2020-06-27 14:32:56.467	info	(68160) script.js.common.Fenster_Pittini3: CreateOpenRoomsList()
                          javascript.0	2020-06-27 14:32:56.467	info	(68160) script.js.common.Fenster_Pittini3: RoomsWithOpenDoors: Esszimmer 1 offene Tür
                          javascript.0	2020-06-27 14:32:56.466	info	(68160) script.js.common.Fenster_Pittini3: Reaching CreateRoomsWithOpenDoorsList
                          javascript.0	2020-06-27 14:32:56.466	info	(68160) script.js.common.Fenster_Pittini3: RoomsWithTiltedWindows: Keine Fenster gekippt
                          javascript.0	2020-06-27 14:32:56.465	info	(68160) script.js.common.Fenster_Pittini3: Reaching CreateRoomsWithTiltedWindowsList
                          javascript.0	2020-06-27 14:32:56.465	info	(68160) script.js.common.Fenster_Pittini3: RoomsWithOpenWindows: Alle Fenster sind geschlossen
                          javascript.0	2020-06-27 14:32:56.465	info	(68160) script.js.common.Fenster_Pittini3: Reaching CreateRoomsWithOpenWindowsList
                          javascript.0	2020-06-27 14:32:56.465	info	(68160) script.js.common.Fenster_Pittini3: RoomStateTimeStamp at checkWindow= 1593248450539 ms =27.06.2020 11:00:50
                          javascript.0	2020-06-27 14:32:56.465	info	(68160) script.js.common.Fenster_Pittini3: Reaching CreateRoomsWithVentWarnings
                          javascript.0	2020-06-27 14:32:56.465	info	(68160) script.js.common.Fenster_Pittini3: Room 1 = Esszimmer is open or disabled, no vent warning set
                          javascript.0	2020-06-27 14:32:56.465	info	(68160) script.js.common.Fenster_Pittini3: Reaching VentCheck x=1 Init=false VentwarnTime[x]=0 RoomStateTimeStamp[x]=1593248450539
                          javascript.0	2020-06-27 14:32:56.465	info	(68160) script.js.common.Fenster_Pittini3: Offene Türen gesamt= 1
                          javascript.0	2020-06-27 14:32:56.465	info	(68160) script.js.common.Fenster_Pittini3: Offene Fenster gesamt= 0
                          javascript.0	2020-06-27 14:32:56.465	info	(68160) script.js.common.Fenster_Pittini3: Alle Fenster geschlossen.
                          javascript.0	2020-06-27 14:32:56.465	info	(68160) script.js.common.Fenster_Pittini3: TempMessageLog=27.06.2020 14:32:56: Esszimmer Tür geöffnet!,27.06.2020 14:11:41: Esszimmer Tür geschlossen!,27.06.2020 13:57:04: Badzimmer Fenster geschlosse
                          javascript.0	2020-06-27 14:32:56.465	info	(68160) script.js.common.Fenster_Pittini3: Reaching WriteMessageLog, Message=Esszimmer Tür geöffnet!
                          javascript.0	2020-06-27 14:32:56.464	info	(68160) script.js.common.Fenster_Pittini3: Reaching Meldung, msg= Esszimmer Tür geöffnet!
                          javascript.0	2020-06-27 14:32:56.464	info	(68160) script.js.common.Fenster_Pittini3: Esszimmer Tür geöffnet
                          javascript.0	2020-06-27 14:32:56.464	info	(68160) script.js.common.Fenster_Pittini3: RoomOpenDoorCount für Esszimmer=1
                          javascript.0	2020-06-27 14:32:56.464	info	(68160) script.js.common.Fenster_Pittini3: reaching CheckWindow, SensorVal[2]=open SensorOldVal=closed TempRoom=Esszimmer SensorType[x]=Door TempRoomIndex=1
                          javascript.0	2020-06-27 14:32:56.464	info	(68160) script.js.common.Fenster_Pittini3: Reaching GetRoom x=2
                          javascript.0	2020-06-27 14:32:56.464	info	(68160) script.js.common.Fenster_Pittini3: Reaching CheckForHmShit val=true typof val=string x=2 Sensor[x]=hm-rpc.0.NEQ1826414.1.STATE
                          javascript.0	2020-06-27 14:32:56.464	info	(68160) script.js.common.Fenster_Pittini3: Ignore Timeout for 2 exceeded, Value change happend, starting Functions
                          javascript.0	2020-06-27 14:32:56.463	info	(68160) script.js.common.Fenster_Pittini3: InTimeout - Trigger= 2 Wert= true Alter Wert= false
                          javascript.0	2020-06-27 14:32:46.462	info	(68160) script.js.Ereignisse.Erstellt_eine_Ereignisliste_mit_50_Einträgen: neuer Event zum verarbeiten: &nbsp;&nbsp;&nbsp;&nbsp; <b>Terrassentür geöffnet</b>
                          javascript.0	2020-06-27 14:32:46.454	info	(68160) script.js.common.Fenster_Pittini3: Activating Ignore Timeout for 2, Value to ignore=closed
                          javascript.0	2020-06-27 14:32:46.454	info	(68160) script.js.common.Fenster_Pittini3: Reaching CheckForHmShit val=false typof val=string x=2 Sensor[x]=hm-rpc.0.NEQ1826414.1.STATE
                          javascript.0	2020-06-27 14:32:46.454	info	(68160) script.js.common.Fenster_Pittini3: Oldstate=false
                          javascript.0	2020-06-27 14:32:46.453	info	(68160) script.js.common.Fenster_Pittini3: Trigger= 2 Wert= true Alter Wert= false
                          • Dominik F.
                            Dominik F. @sigi234 last edited by Dominik F.
                            @Pittini
                            Ich glaube es wird schon alles richtig erkannt, nur falsch in der Tabelle ausgegeben
                            Skriptstart:
                            javascript.0	2020-06-27 14:40:06.523	info	(30431) script.js.common.Fensterauswertung: CreateOpenRoomsList()
                            javascript.0	2020-06-27 14:40:06.523	info	(30431) script.js.common.Fensterauswertung: RoomsWithTiltedWindows: Keine Fenster gekippt
                            javascript.0	2020-06-27 14:40:06.523	info	(30431) script.js.common.Fensterauswertung: Reaching CreateRoomsWithTiltedWindowsList
                            javascript.0	2020-06-27 14:40:06.523	info	(30431) script.js.common.Fensterauswertung: RoomsWithOpenWindows: EG Bad 1 offenes Fenster<br>OG Bad 2 offene Fenster
                            javascript.0	2020-06-27 14:40:06.522	info	(30431) script.js.common.Fensterauswertung: Reaching CreateRoomsWithOpenWindowsList
                            javascript.0	2020-06-27 14:40:06.522	info	(30431) script.js.common.Fensterauswertung: RoomsWithOpenDoors: Keine Tür/en geöffnet
                            javascript.0	2020-06-27 14:40:06.522	info	(30431) script.js.common.Fensterauswertung: Reaching CreateRoomsWithOpenDoorsList
                            javascript.0	2020-06-27 14:40:06.522	info	(30431) script.js.common.Fensterauswertung: Reaching CreateRoomsWithVentWarnings
                            javascript.0	2020-06-27 14:40:06.522	info	(30431) script.js.common.Fensterauswertung: Room 4 = OG_Bad is open or disabled, no vent warning set
                            javascript.0	2020-06-27 14:40:06.521	info	(30431) script.js.common.Fensterauswertung: Reaching VentCheck x=4 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1593252348836
                            javascript.0	2020-06-27 14:40:06.521	info	(30431) script.js.common.Fensterauswertung: Reaching CreateRoomsWithVentWarnings
                            javascript.0	2020-06-27 14:40:06.521	info	(30431) script.js.common.Fensterauswertung: Room 3 = Keller is open or disabled, no vent warning set
                            javascript.0	2020-06-27 14:40:06.521	info	(30431) script.js.common.Fensterauswertung: Reaching VentCheck x=3 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1593252348535
                            javascript.0	2020-06-27 14:40:06.521	info	(30431) script.js.common.Fensterauswertung: Room 2 = EG_Wohnzimmer is open or disabled, no vent warning set
                            javascript.0	2020-06-27 14:40:06.521	info	(30431) script.js.common.Fensterauswertung: Reaching VentCheck x=2 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1593252930633
                            javascript.0	2020-06-27 14:40:06.521	info	(30431) script.js.common.Fensterauswertung: Room 1 = EG_Küche is open or disabled, no vent warning set
                            javascript.0	2020-06-27 14:40:06.521	info	(30431) script.js.common.Fensterauswertung: Reaching VentCheck x=1 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1593252348534
                            javascript.0	2020-06-27 14:40:06.520	info	(30431) script.js.common.Fensterauswertung: Reaching CreateRoomsWithVentWarnings
                            javascript.0	2020-06-27 14:40:06.520	info	(30431) script.js.common.Fensterauswertung: Room 0 = EG_Bad is open or disabled, no vent warning set
                            javascript.0	2020-06-27 14:40:06.520	info	(30431) script.js.common.Fensterauswertung: Reaching VentCheck x=0 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1593252348836
                            javascript.0	2020-06-27 14:40:06.520	info	(30431) script.js.common.Fensterauswertung: Offene Türen gesamt= 0
                            javascript.0	2020-06-27 14:40:06.520	info	(30431) script.js.common.Fensterauswertung: Alle Türen geschlossen.
                            javascript.0	2020-06-27 14:40:06.520	info	(30431) script.js.common.Fensterauswertung: Offene Fenster gesamt= 3
                            javascript.0	2020-06-27 14:40:06.519	info	(30431) script.js.common.Fensterauswertung: reaching ClearWarnTime - [x] = 2
                            javascript.0	2020-06-27 14:40:06.519	info	(30431) script.js.common.Fensterauswertung: RoomOpenDoorCount[TempRoomIndex]=0 TempRoom=EG_Wohnzimmer TempRoomIndex=2
                            javascript.0	2020-06-27 14:40:06.519	info	(30431) script.js.common.Fensterauswertung: reaching CheckWindow, SensorVal[10]=closed SensorOldVal= TempRoom=EG_Wohnzimmer SensorType[x]=Door TempRoomIndex=2
                            javascript.0	2020-06-27 14:40:06.519	info	(30431) script.js.common.Fensterauswertung: Reaching GetRoom x=10
                            javascript.0	2020-06-27 14:40:06.519	info	(30431) script.js.common.Fensterauswertung: Reaching CheckForHmShit val=0 typof val=string x=10 Sensor[x]=hm-rpc.2.0007DA49992A68.1.STATE
                            javascript.0	2020-06-27 14:40:06.519	info	(30431) script.js.common.Fensterauswertung: Offene Türen gesamt= 0
                            javascript.0	2020-06-27 14:40:06.519	info	(30431) script.js.common.Fensterauswertung: Alle Türen geschlossen.
                            javascript.0	2020-06-27 14:40:06.519	info	(30431) script.js.common.Fensterauswertung: Offene Fenster gesamt= 3
                            javascript.0	2020-06-27 14:40:06.518	info	(30431) script.js.common.Fensterauswertung: reaching ClearWarnTime - [x] = 3
                            javascript.0	2020-06-27 14:40:06.518	info	(30431) script.js.common.Fensterauswertung: RoomOpenDoorCount[TempRoomIndex]=0 TempRoom=Keller TempRoomIndex=3
                            javascript.0	2020-06-27 14:40:06.518	info	(30431) script.js.common.Fensterauswertung: reaching CheckWindow, SensorVal[9]=closed SensorOldVal= TempRoom=Keller SensorType[x]=Door TempRoomIndex=3
                            javascript.0	2020-06-27 14:40:06.518	info	(30431) script.js.common.Fensterauswertung: Reaching GetRoom x=9
                            javascript.0	2020-06-27 14:40:06.517	info	(30431) script.js.common.Fensterauswertung: Reaching CheckForHmShit val=false typof val=string x=9 Sensor[x]=zigbee.0.00158d0003e72e2d.opened
                            javascript.0	2020-06-27 14:40:06.517	info	(30431) script.js.common.Fensterauswertung: Offene Türen gesamt= 0
                            javascript.0	2020-06-27 14:40:06.517	info	(30431) script.js.common.Fensterauswertung: Alle Türen geschlossen.
                            javascript.0	2020-06-27 14:40:06.517	info	(30431) script.js.common.Fensterauswertung: Offene Fenster gesamt= 3
                            javascript.0	2020-06-27 14:40:06.517	info	(30431) script.js.common.Fensterauswertung: reaching ClearWarnTime - [x] = 1
                            javascript.0	2020-06-27 14:40:06.516	info	(30431) script.js.common.Fensterauswertung: reaching CheckWindow, SensorVal[8]=closed SensorOldVal= TempRoom=EG_Küche SensorType[x]=Window TempRoomIndex=1
                            javascript.0	2020-06-27 14:40:06.516	info	(30431) script.js.common.Fensterauswertung: Reaching GetRoom x=8
                            javascript.0	2020-06-27 14:40:06.516	info	(30431) script.js.common.Fensterauswertung: Reaching CheckForHmShit val=false typof val=string x=8 Sensor[x]=zigbee.0.00158d0003e79084.opened
                            javascript.0	2020-06-27 14:40:06.516	info	(30431) script.js.common.Fensterauswertung: Offene Türen gesamt= 0
                            javascript.0	2020-06-27 14:40:06.516	info	(30431) script.js.common.Fensterauswertung: Alle Türen geschlossen.
                            javascript.0	2020-06-27 14:40:06.516	info	(30431) script.js.common.Fensterauswertung: Offene Fenster gesamt= 3
                            javascript.0	2020-06-27 14:40:06.515	info	(30431) script.js.common.Fensterauswertung: RoomOpenWindowCount für OG_Bad=2
                            javascript.0	2020-06-27 14:40:06.515	info	(30431) script.js.common.Fensterauswertung: reaching CheckWindow, SensorVal[7]=open SensorOldVal= TempRoom=OG_Bad SensorType[x]=Window TempRoomIndex=4
                            javascript.0	2020-06-27 14:40:06.515	info	(30431) script.js.common.Fensterauswertung: Reaching GetRoom x=7
                            javascript.0	2020-06-27 14:40:06.515	info	(30431) script.js.common.Fensterauswertung: Reaching CheckForHmShit val=true typof val=string x=7 Sensor[x]=zigbee.0.00158d0003e78e9c.opened
                            javascript.0	2020-06-27 14:40:06.515	info	(30431) script.js.common.Fensterauswertung: Offene Türen gesamt= 0
                            javascript.0	2020-06-27 14:40:06.515	info	(30431) script.js.common.Fensterauswertung: Alle Türen geschlossen.
                            javascript.0	2020-06-27 14:40:06.515	info	(30431) script.js.common.Fensterauswertung: Offene Fenster gesamt= 2
                            javascript.0	2020-06-27 14:40:06.514	info	(30431) script.js.common.Fensterauswertung: reaching ClearWarnTime - [x] = 1
                            javascript.0	2020-06-27 14:40:06.514	info	(30431) script.js.common.Fensterauswertung: reaching CheckWindow, SensorVal[6]=closed SensorOldVal= TempRoom=EG_Küche SensorType[x]=Window TempRoomIndex=1
                            javascript.0	2020-06-27 14:40:06.514	info	(30431) script.js.common.Fensterauswertung: Reaching GetRoom x=6
                            javascript.0	2020-06-27 14:40:06.514	info	(30431) script.js.common.Fensterauswertung: Reaching CheckForHmShit val=false typof val=string x=6 Sensor[x]=zigbee.0.00158d0003e72d1b.opened
                            javascript.0	2020-06-27 14:40:06.514	info	(30431) script.js.common.Fensterauswertung: Offene Türen gesamt= 0
                            javascript.0	2020-06-27 14:40:06.514	info	(30431) script.js.common.Fensterauswertung: Alle Türen geschlossen.
                            javascript.0	2020-06-27 14:40:06.514	info	(30431) script.js.common.Fensterauswertung: Offene Fenster gesamt= 2
                            javascript.0	2020-06-27 14:40:06.513	info	(30431) script.js.common.Fensterauswertung: reaching ClearWarnTime - [x] = 2
                            javascript.0	2020-06-27 14:40:06.513	info	(30431) script.js.common.Fensterauswertung: reaching CheckWindow, SensorVal[5]=closed SensorOldVal= TempRoom=EG_Wohnzimmer SensorType[x]=Window TempRoomIndex=2
                            javascript.0	2020-06-27 14:40:06.513	info	(30431) script.js.common.Fensterauswertung: Reaching GetRoom x=5
                            javascript.0	2020-06-27 14:40:06.513	info	(30431) script.js.common.Fensterauswertung: Reaching CheckForHmShit val=false typof val=string x=5 Sensor[x]=zigbee.0.00158d0003e72ce7.opened
                            javascript.0	2020-06-27 14:40:06.513	info	(30431) script.js.common.Fensterauswertung: Offene Türen gesamt= 0
                            javascript.0	2020-06-27 14:40:06.513	info	(30431) script.js.common.Fensterauswertung: Alle Türen geschlossen.
                            javascript.0	2020-06-27 14:40:06.513	info	(30431) script.js.common.Fensterauswertung: Offene Fenster gesamt= 2
                            javascript.0	2020-06-27 14:40:06.511	info	(30431) script.js.common.Fensterauswertung: Setting Interval to Room:EG_Bad
                            javascript.0	2020-06-27 14:40:06.511	info	(30431) script.js.common.Fensterauswertung: SendWindowWarnMsg=true TempRoomIndex=0
                            javascript.0	2020-06-27 14:40:06.511	info	(30431) script.js.common.Fensterauswertung: RoomOpenWindowCount für EG_Bad=1
                            javascript.0	2020-06-27 14:40:06.511	info	(30431) script.js.common.Fensterauswertung: reaching CheckWindow, SensorVal[4]=open SensorOldVal= TempRoom=EG_Bad SensorType[x]=Window TempRoomIndex=0
                            javascript.0	2020-06-27 14:40:06.510	info	(30431) script.js.common.Fensterauswertung: Reaching GetRoom x=4
                            javascript.0	2020-06-27 14:40:06.510	info	(30431) script.js.common.Fensterauswertung: Reaching CheckForHmShit val=true typof val=string x=4 Sensor[x]=zigbee.0.00158d0003d41914.opened
                            javascript.0	2020-06-27 14:40:06.510	info	(30431) script.js.common.Fensterauswertung: Offene Türen gesamt= 0
                            javascript.0	2020-06-27 14:40:06.510	info	(30431) script.js.common.Fensterauswertung: Alle Türen geschlossen.
                            javascript.0	2020-06-27 14:40:06.510	info	(30431) script.js.common.Fensterauswertung: Offene Fenster gesamt= 1
                            javascript.0	2020-06-27 14:40:06.510	info	(30431) script.js.common.Fensterauswertung: reaching ClearWarnTime - [x] = 1
                            javascript.0	2020-06-27 14:40:06.509	info	(30431) script.js.common.Fensterauswertung: reaching CheckWindow, SensorVal[3]=closed SensorOldVal= TempRoom=EG_Küche SensorType[x]=Window TempRoomIndex=1
                            javascript.0	2020-06-27 14:40:06.509	info	(30431) script.js.common.Fensterauswertung: Reaching GetRoom x=3
                            javascript.0	2020-06-27 14:40:06.509	info	(30431) script.js.common.Fensterauswertung: Reaching CheckForHmShit val=false typof val=string x=3 Sensor[x]=zigbee.0.00158d0003d418de.opened
                            javascript.0	2020-06-27 14:40:06.509	info	(30431) script.js.common.Fensterauswertung: Offene Türen gesamt= 0
                            javascript.0	2020-06-27 14:40:06.509	info	(30431) script.js.common.Fensterauswertung: Alle Türen geschlossen.
                            javascript.0	2020-06-27 14:40:06.509	info	(30431) script.js.common.Fensterauswertung: Offene Fenster gesamt= 1
                            javascript.0	2020-06-27 14:40:06.509	info	(30431) script.js.common.Fensterauswertung: Setting Interval to Room:OG_Bad
                            javascript.0	2020-06-27 14:40:06.508	info	(30431) script.js.common.Fensterauswertung: SendWindowWarnMsg=true TempRoomIndex=4
                            javascript.0	2020-06-27 14:40:06.508	info	(30431) script.js.common.Fensterauswertung: RoomOpenWindowCount für OG_Bad=1
                            javascript.0	2020-06-27 14:40:06.508	info	(30431) script.js.common.Fensterauswertung: reaching CheckWindow, SensorVal[2]=open SensorOldVal= TempRoom=OG_Bad SensorType[x]=Window TempRoomIndex=4
                            javascript.0	2020-06-27 14:40:06.508	info	(30431) script.js.common.Fensterauswertung: Reaching GetRoom x=2
                            javascript.0	2020-06-27 14:40:06.508	info	(30431) script.js.common.Fensterauswertung: Reaching CheckForHmShit val=true typof val=string x=2 Sensor[x]=zigbee.0.00158d00034d800a.opened
                            javascript.0	2020-06-27 14:40:06.508	info	(30431) script.js.common.Fensterauswertung: Offene Türen gesamt= 0
                            javascript.0	2020-06-27 14:40:06.508	info	(30431) script.js.common.Fensterauswertung: Alle Türen geschlossen.
                            javascript.0	2020-06-27 14:40:06.507	info	(30431) script.js.common.Fensterauswertung: Offene Fenster gesamt= 0
                            javascript.0	2020-06-27 14:40:06.507	info	(30431) script.js.common.Fensterauswertung: Alle Fenster geschlossen.
                            javascript.0	2020-06-27 14:40:06.507	info	(30431) script.js.common.Fensterauswertung: reaching ClearWarnTime - [x] = 1
                            javascript.0	2020-06-27 14:40:06.507	info	(30431) script.js.common.Fensterauswertung: reaching CheckWindow, SensorVal[1]=closed SensorOldVal= TempRoom=EG_Küche SensorType[x]=Window TempRoomIndex=1
                            javascript.0	2020-06-27 14:40:06.507	info	(30431) script.js.common.Fensterauswertung: Reaching GetRoom x=1
                            javascript.0	2020-06-27 14:40:06.507	info	(30431) script.js.common.Fensterauswertung: Reaching CheckForHmShit val=false typof val=string x=1 Sensor[x]=zigbee.0.00158d00034d7fb0.opened
                            javascript.0	2020-06-27 14:40:06.507	info	(30431) script.js.common.Fensterauswertung: Offene Türen gesamt= 0
                            javascript.0	2020-06-27 14:40:06.506	info	(30431) script.js.common.Fensterauswertung: Alle Türen geschlossen.
                            javascript.0	2020-06-27 14:40:06.506	info	(30431) script.js.common.Fensterauswertung: Offene Fenster gesamt= 0
                            javascript.0	2020-06-27 14:40:06.506	info	(30431) script.js.common.Fensterauswertung: Alle Fenster geschlossen.
                            javascript.0	2020-06-27 14:40:06.506	info	(30431) script.js.common.Fensterauswertung: reaching ClearWarnTime - [x] = 2
                            javascript.0	2020-06-27 14:40:06.506	info	(30431) script.js.common.Fensterauswertung: reaching CheckWindow, SensorVal[0]=closed SensorOldVal= TempRoom=EG_Wohnzimmer SensorType[x]=Window TempRoomIndex=2
                            javascript.0	2020-06-27 14:40:06.505	info	(30431) script.js.common.Fensterauswertung: Reaching GetRoom x=0
                            javascript.0	2020-06-27 14:40:06.505	info	(30431) script.js.common.Fensterauswertung: Reaching CheckForHmShit val=false typof val=string x=0 Sensor[x]=zigbee.0.00158d00034d695f.opened
                            javascript.0	2020-06-27 14:40:06.505	info	(30431) script.js.common.Fensterauswertung: x=4=OG_Bad SendWindowWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
                            javascript.0	2020-06-27 14:40:06.505	info	(30431) script.js.common.Fensterauswertung: x=3=Keller SendWindowWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
                            javascript.0	2020-06-27 14:40:06.505	info	(30431) script.js.common.Fensterauswertung: x=2=EG_Wohnzimmer SendWindowWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
                            javascript.0	2020-06-27 14:40:06.505	info	(30431) script.js.common.Fensterauswertung: x=1=EG_Küche SendWindowWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
                            javascript.0	2020-06-27 14:40:06.505	info	(30431) script.js.common.Fensterauswertung: x=0=EG_Bad SendWindowWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
                            javascript.0	2020-06-27 14:40:06.505	info	(30431) script.js.common.Fensterauswertung: CreateStates fertig!
                            javascript.0	2020-06-27 14:40:06.462	info	(30431) script.js.common.Fensterauswertung: registered 0 subscriptions and 0 schedules
                            javascript.0	2020-06-27 14:40:06.458	info	(30431) script.js.common.Fensterauswertung: Raum- 0 = EG_Wohnzimmer hat Tür- und Fenstersensor/en
                            javascript.0	2020-06-27 14:40:06.458	info	(30431) script.js.common.Fensterauswertung: Raum- 4 = Keller hat Türsensor/en
                            javascript.0	2020-06-27 14:40:06.458	info	(30431) script.js.common.Fensterauswertung: Raum- 1 = EG_Küche hat Fenstersensor/en
                            javascript.0	2020-06-27 14:40:06.458	info	(30431) script.js.common.Fensterauswertung: Raum- 2 = OG_Bad hat Fenstersensor/en
                            javascript.0	2020-06-27 14:40:06.458	info	(30431) script.js.common.Fensterauswertung: Raum- 0 = EG_Wohnzimmer hat Fenstersensor/en
                            javascript.0	2020-06-27 14:40:06.458	info	(30431) script.js.common.Fensterauswertung: Raum- 3 = EG_Bad hat Fenstersensor/en
                            javascript.0	2020-06-27 14:40:06.452	info	(30431) Start javascript script.js.common.Fensterauswertung
                            javascript.0	2020-06-27 14:40:06.305	info	(30431) script.js.common.Fensterauswertung: Clearing Interval for 4
                            javascript.0	2020-06-27 14:40:06.305	info	(30431) script.js.common.Fensterauswertung: reaching ClearWarnTime - [x] = 4
                            javascript.0	2020-06-27 14:40:06.305	info	(30431) script.js.common.Fensterauswertung: reaching ClearWarnTime - [x] = 3
                            javascript.0	2020-06-27 14:40:06.305	info	(30431) script.js.common.Fensterauswertung: reaching ClearWarnTime - [x] = 2
                            javascript.0	2020-06-27 14:40:06.305	info	(30431) script.js.common.Fensterauswertung: reaching ClearWarnTime - [x] = 1
                            javascript.0	2020-06-27 14:40:06.304	info	(30431) script.js.common.Fensterauswertung: Clearing Interval for 0
                            javascript.0	2020-06-27 14:40:06.304	info	(30431) script.js.common.Fensterauswertung: reaching ClearWarnTime - [x] = 0
                            javascript.0	2020-06-27 14:40:06.304	info	(30431) Stop script script.js.common.Fensterauswertung
                            Wohnzimmer Tür wird geöffnet: (HM IP Drehgriff):
                            javascript.0	2020-06-27 14:53:28.793	info	(30431) script.js.common.Fensterauswertung: RoomsWithOpenings: EG Bad 1 offenes Fenster<br>EG Wohnzimmer 1 offene Tür<br>OG Bad undefined<br>
                            javascript.0	2020-06-27 14:53:28.793	info	(30431) script.js.common.Fensterauswertung: CreateOpenRoomsList()
                            javascript.0	2020-06-27 14:53:28.793	info	(30431) script.js.common.Fensterauswertung: RoomsWithOpenDoors: EG Wohnzimmer 1 offene Tür
                            javascript.0	2020-06-27 14:53:28.793	info	(30431) script.js.common.Fensterauswertung: Reaching CreateRoomsWithOpenDoorsList
                            javascript.0	2020-06-27 14:53:28.793	info	(30431) script.js.common.Fensterauswertung: RoomsWithTiltedWindows: Keine Fenster gekippt
                            javascript.0	2020-06-27 14:53:28.793	info	(30431) script.js.common.Fensterauswertung: Reaching CreateRoomsWithTiltedWindowsList
                            javascript.0	2020-06-27 14:53:28.793	info	(30431) script.js.common.Fensterauswertung: RoomsWithOpenWindows: EG Bad 1 offenes Fenster<br>OG Bad 2 offene Fenster
                            javascript.0	2020-06-27 14:53:28.792	info	(30431) script.js.common.Fensterauswertung: Reaching CreateRoomsWithOpenWindowsList
                            javascript.0	2020-06-27 14:53:28.792	info	(30431) script.js.common.Fensterauswertung: RoomStateTimeStamp at checkWindow= 1593262382632 ms =27.06.2020 14:53:02
                            javascript.0	2020-06-27 14:53:28.792	info	(30431) script.js.common.Fensterauswertung: Reaching CreateRoomsWithVentWarnings
                            javascript.0	2020-06-27 14:53:28.792	info	(30431) script.js.common.Fensterauswertung: Room 2 = EG_Wohnzimmer is open or disabled, no vent warning set
                            javascript.0	2020-06-27 14:53:28.792	info	(30431) script.js.common.Fensterauswertung: Reaching VentCheck x=2 Init=false VentwarnTime[x]=0 RoomStateTimeStamp[x]=1593262382632
                            javascript.0	2020-06-27 14:53:28.792	info	(30431) script.js.common.Fensterauswertung: Offene Türen gesamt= 1
                            javascript.0	2020-06-27 14:53:28.792	info	(30431) script.js.common.Fensterauswertung: Offene Fenster gesamt= 3
                            javascript.0	2020-06-27 14:53:28.791	info	(30431) script.js.common.Fensterauswertung: TempMessageLog=27.06.2020 14:53:28: EG Wohnzimmer Tür geöffnet!,27.06.2020 14:53:02: EG Wohnzimmer Fenster geschlossen!,27.06.2020 14:52:45: EG Wohnzimmer F
                            javascript.0	2020-06-27 14:53:28.791	info	(30431) script.js.common.Fensterauswertung: Reaching WriteMessageLog, Message=EG Wohnzimmer Tür geöffnet!
                            javascript.0	2020-06-27 14:53:28.791	info	(30431) script.js.common.Fensterauswertung: Reaching Meldung, msg= EG Wohnzimmer Tür geöffnet!
                            javascript.0	2020-06-27 14:53:28.791	info	(30431) script.js.common.Fensterauswertung: EG_Wohnzimmer Tür geöffnet
                            javascript.0	2020-06-27 14:53:28.791	info	(30431) script.js.common.Fensterauswertung: RoomOpenDoorCount für EG_Wohnzimmer=1
                            javascript.0	2020-06-27 14:53:28.791	info	(30431) script.js.common.Fensterauswertung: reaching CheckWindow, SensorVal[10]=open SensorOldVal=closed TempRoom=EG_Wohnzimmer SensorType[x]=Door TempRoomIndex=2
                            javascript.0	2020-06-27 14:53:28.790	info	(30431) script.js.common.Fensterauswertung: Reaching GetRoom x=10
                            javascript.0	2020-06-27 14:53:28.790	info	(30431) script.js.common.Fensterauswertung: Reaching CheckForHmShit val=2 typof val=string x=10 Sensor[x]=hm-rpc.2.0007DA49992A68.1.STATE
                            javascript.0	2020-06-27 14:53:28.790	info	(30431) script.js.common.Fensterauswertung: Ignore Timeout for 10 exceeded, Value change happend, starting Functions
                            javascript.0	2020-06-27 14:53:28.790	info	(30431) script.js.common.Fensterauswertung: InTimeout - Trigger= 10 Wert= 2 Alter Wert= 0
                            javascript.0	2020-06-27 14:53:27.790	info	(30431) script.js.common.Fensterauswertung: Activating Ignore Timeout for 10, Value to ignore=closed
                              Pittini Developer @Dominik F. last edited by
                              @Dominik-F sagte in [Vorlage] Generisches Fensteroffenskript + Vis:
                              Jetzt verwirrste mich aber. Die Tabelle sieht oben doch gut aus? Wo ist da ein Problem? Überseh ich was? Für mich ist das Problem nur dass er ne falsche Nachricht schickt und auch nen Interval macht.
                              • Dominik F.
                                Dominik F. @Pittini last edited by
                                @Pittini
                                Okay, ich hab nur das Bild von Siggi gesehen und gesehen, dass es bei mir gleich aussieht. Müsste bei mir nicht dort stehen :Tür geöffnet? Das hatte mich irgendwie verwirrt, dass dort eine offene Tür angezeigt wird und dort steht Fenster geschlossen. Bei Siggi sah es genauso aus und da bin ich davon ausgegangen, dass wir den gleichen Fehler haben.
                                P 2 Replies Last reply Reply Quote 0
                                  Ja, die Darstellung ist etwas verwirrend, das hab ich auch gemerkt und besser da grad nach. Wenns Fenster und Türen gibt, werd ich jetzt einfach beides anzeigen lassen, ansonsten das zutreffende. Bisher bezieht sich dieser Teil eigentlich nur auf Fenster.
                                  • Murmelbaerchen69
                                    Murmelbaerchen69 last edited by
                                    ich erhalte bei allen Geräten folgende Fehlermeldung:
                                    Hier meine Konfiguration:
                                    Wo liegt der Fehler?
                                    Gruß Ralf
                                      Pittini Developer @Murmelbaerchen69 last edited by Pittini
                                      @Murmelbaerchen69 sagte in [Vorlage] Generisches Fensteroffenskript + Vis:
                                      Vor dem Monitor 😉 .
                                      Du hast entgegen der deutlichen Anweisung in der Anleitung dem ganzen Channel die Funktion Fenster verpasst, das kann nicht gehen.
                                      2020-06-28 09_39_44-Pittini_iobroker-Fensterauswertung_ Zählt geöffnete Fenster pro Raum und gesamt..png
                                        @Dominik-F @sigi234 , bitte mal das update einspielen und Feedback.
                                        Dominik F. sigi234 2 Replies Last reply Reply Quote 1
                                        • Dominik F.
                                          Dominik F. @Pittini last edited by Dominik F.
                                          @Pittini
                                          Habs eingespielt und die Darstellung ist jetzt richtig.
                                          Persönlich finde ich die Darstellung aber noch nicht ganz optimal.
                                          Ich hätte da ein paar Vorschläge:
                                          • Wenn es nur Türen oder nur Fenster in einem Raum gibt bräuchte man in der dritten Spalte keine 0 für die die nichtvorhandene Tür oder das Fenster.
                                          • Die Zeit, seit dem ein Fenster oder eine Tür geöffnet oder geschlossen ist hat einen doofen Zeilenumbruch drin, es könnte schöner aussehen wenn die Zeit generell eine Zeile unter Fenster/Tür geöffnet steht.
                                          • Die Schriftart ist z.B. beim Keller normal, überall sonst Fett. Es würde glaube ich besser aussehen wenn es einheitlich wäre. Das fettgedruckte würde mir persönlich nur beim Raumnamen ausreichen.
                                          • Wenn es Türen und Fenster in einem Raum gibt, dann fände ich es glaube ich schöner, wenn in meinem Bild bei EG Wohnzimmer in der dritten Spalte die 0 auf der gleichen Höhe wie Fenster geschlossen stünde und die 1 auf der gleichen Höhe wie Tür geöffnet.
                                          Meine Vorschläge würden die Tabelle in der Höhe auf jedenfall vergrößern, dass ist mir klar. Vielleicht gibt es auch bessere Ideen das Aussehen noch zu optimieren. Sind einfach nur Gedanken/Vorschläge. Die Frage ist auch ob sich das alles so umsetzen lässt, da bist du dann gefragt 😄
                                            Funktioniert! 👍
                                            javascript monitoring template
                                            81
                                            768
                                            213375
