    4. [iot] Andere Probleme mit dem iot-Adapter bzw der Nutzung
      Thomas Braun Most Active @Danny Köhn last edited by
      @Danny-Köhn Keine Screenshots, den kompletten Text in CodeTags hier rein.
      • Danny Köhn
        code_text[    0.000000] Booting Linux on physical CPU 0x0
        [    0.000000] Linux version 4.19.118-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1311 SMP Mon Apr 27 14:26:42 BST 2020
        [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
        [    0.000000] CPU: div instructions available: patching division code
        [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
        [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
        [    0.000000] Memory policy: Data cache writealloc
        [    0.000000] cma: Reserved 256 MiB at 0x000000001ec00000
        [    0.000000] On node 0 totalpages: 1012736
        [    0.000000]   DMA zone: 1728 pages used for memmap
        [    0.000000]   DMA zone: 0 pages reserved
        [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
        [    0.000000]   HighMem zone: 816128 pages, LIFO batch:63
        [    0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0
        [    0.000000] percpu: Embedded 17 pages/cpu s36928 r8192 d24512 u69632
        [    0.000000] pcpu-alloc: s36928 r8192 d24512 u69632 alloc=17*4096
        [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
        [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1011008
        [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 cma=256M video=HDMI-A-1:1280x720M@60,margin_left=48,margin_right=48,margin_top=48,margin_bottom=48 smsc95xx.macaddr=DC:A6:32:5A:A9:F4 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=ea7d04d6-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
        [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
        [    0.000000] Memory: 3735552K/4050944K available (8192K kernel code, 690K rwdata, 2420K rodata, 2048K init, 860K bss, 53248K reserved, 262144K cma-reserved, 3264512K highmem)
        [    0.000000] Virtual kernel memory layout:
                           vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                           fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                           vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                           lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
                           pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
                           modules : 0xbf000000 - 0xbfe00000   (  14 MB)
                             .text : 0x(ptrval) - 0x(ptrval)   (10208 kB)
                             .init : 0x(ptrval) - 0x(ptrval)   (2048 kB)
                             .data : 0x(ptrval) - 0x(ptrval)   ( 691 kB)
                              .bss : 0x(ptrval) - 0x(ptrval)   ( 861 kB)
        [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
        [    0.000000] ftrace: allocating 28928 entries in 85 pages
        [    0.000000] rcu: Hierarchical RCU implementation.
        [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
        [    0.000000] GIC: Using split EOI/Deactivate mode
        [    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
        [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
        [    0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
        [    0.000018] Switching to timer-based delay loop, resolution 18ns
        [    0.000250] Console: colour dummy device 80x30
        [    0.000274] console [tty1] enabled
        [    0.000319] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
        [    0.000336] pid_max: default: 32768 minimum: 301
        [    0.000609] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)[    0.000627] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
        [    0.001388] CPU: Testing write buffer coherency: ok
        [    0.001806] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
        [    0.002453] Setting up static identity map for 0x200000 - 0x20003c
        [    0.002612] rcu: Hierarchical SRCU implementation.
        [    0.003474] smp: Bringing up secondary CPUs ...
        [    0.004280] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
        [    0.005205] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
        [    0.006087] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
        [    0.006206] smp: Brought up 1 node, 4 CPUs
        [    0.006219] SMP: Total of 4 processors activated (432.00 BogoMIPS).
        [    0.006229] CPU: All CPU(s) started in HYP mode.
        [    0.006237] CPU: Virtualization extensions available.
        [    0.007036] devtmpfs: initialized
        [    0.017851] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
        [    0.018068] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
        [    0.018088] futex hash table entries: 1024 (order: 4, 65536 bytes)
        [    0.025479] pinctrl core: initialized pinctrl subsystem
        [    0.026336] NET: Registered protocol family 16
        [    0.029450] DMA: preallocated 1024 KiB pool for atomic coherent allocations
        [    0.031075] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
        [    0.031086] hw-breakpoint: maximum watchpoint size is 8 bytes.
        [    0.031281] Serial: AMBA PL011 UART driver
        [    0.034385] bcm2835-mbox fe00b880.mailbox: mailbox enabled
        [    0.050036] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-06-01 13:23, variant start
        [    0.060050] raspberrypi-firmware soc:firmware: Firmware hash is 6379679d1ec6a8c746d7e77e015f5b56b939976f
        [    0.102846] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
        [    0.105949] vgaarb: loaded
        [    0.106309] SCSI subsystem initialized
        [    0.106498] usbcore: registered new interface driver usbfs
        [    0.106555] usbcore: registered new interface driver hub
        [    0.106624] usbcore: registered new device driver usb
        [    0.108013] clocksource: Switched to clocksource arch_sys_counter
        [    0.186398] VFS: Disk quotas dquot_6.6.0
        [    0.186478] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
        [    0.186621] FS-Cache: Loaded
        [    0.186818] CacheFiles: Loaded
        [    0.187370] simple-framebuffer 3e8f6000.framebuffer: framebuffer at 0x3e8f6000, 0x2d1800 bytes, mapped to 0x(ptrval)
        [    0.187385] simple-framebuffer 3e8f6000.framebuffer: format=a8r8g8b8, mode=1184x624x32, linelength=4736
        [    0.191495] Console: switching to colour frame buffer device 148x39
        [    0.194997] simple-framebuffer 3e8f6000.framebuffer: fb0: simplefb registered!
        [    0.204085] NET: Registered protocol family 2
        [    0.204724] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
        [    0.204748] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
        [    0.204815] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
        [    0.204885] TCP: Hash tables configured (established 8192 bind 8192)
        [    0.205004] UDP hash table entries: 512 (order: 2, 16384 bytes)
        [    0.205030] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
        [    0.205235] NET: Registered protocol family 1
        [    0.205772] RPC: Registered named UNIX socket transport module.
        [    0.205782] RPC: Registered udp transport module.
        [    0.205791] RPC: Registered tcp transport module.
        [    0.205800] RPC: Registered tcp NFSv4.1 backchannel transport module.
        [    0.205815] PCI: CLS 0 bytes, default 64
        [    0.207763] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7
        counters available
        [    0.209934] Initialise system trusted keyrings
        [    0.210125] workingset: timestamp_bits=14 max_order=20 bucket_order=6
        [    0.219200] FS-Cache: Netfs 'nfs' registered for caching
        [    0.219710] NFS: Registering the id_resolver key type
        [    0.219734] Key type id_resolver registered
        [    0.219743] Key type id_legacy registered
        [    0.219767] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
        [    0.224286] Key type asymmetric registered
        [    0.224296] Asymmetric key parser 'x509' registered
        [    0.224408] bounce: pool size: 64 pages
        [    0.224455] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
        [    0.224622] io scheduler noop registered
        [    0.224633] io scheduler deadline registered (default)
        [    0.224800] io scheduler cfq registered
        [    0.224811] io scheduler mq-deadline registered (default)
        [    0.224822] io scheduler kyber registered
        [    0.256301] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
        [    0.256319] brcm-pcie fd500000.pcie: could not get clock
        [    0.256381] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
        [    0.256418] brcm-pcie fd500000.pcie:   MEM 0x600000000..0x603ffffff ->
        0xf8000000
        [    0.308048] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
        [    0.308332] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
        [    0.308348] pci_bus 0000:00: root bus resource [bus 00-01]
        [    0.308365] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
        [    0.308409] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
        [    0.308550] pci 0000:00:00.0: PME# supported from D0 D3hot
        [    0.311279] PCI: bus0: Fast back to back transfers disabled
        [    0.311297] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
        [    0.311505] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
        [    0.311629] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
        [    0.311945] pci 0000:01:00.0: PME# supported from D0 D3cold
        [    0.314662] PCI: bus1: Fast back to back transfers disabled
        [    0.314678] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
        [    0.314725] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
        [    0.314744] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
        [    0.314815] pci 0000:00:00.0: PCI bridge to [bus 01]
        [    0.314832] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
        [    0.315043] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
        [    0.315219] pcieport 0000:00:00.0: Signaling PME with IRQ 52
        [    0.315381] pcieport 0000:00:00.0: AER enabled with IRQ 52
        [    0.315546] pci 0000:01:00.0: enabling device (0140 -> 0142)
        [    0.319603] iproc-rng200 fe104000.rng: hwrng registered
        [    0.319815] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
        [    0.320312] vc-sm: Videocore shared memory driver
        [    0.320703] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
        [    0.330882] brd: module loaded
        [    0.340578] loop: module loaded
        [    0.341331] Loading iSCSI transport class v2.0-870.
        [    0.342993] libphy: Fixed MDIO Bus: probed
        [    0.343403] bcmgenet fd580000.genet: failed to get enet clock
        [    0.343420] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
        [    0.343437] bcmgenet fd580000.genet: failed to get enet-wol clock
        [    0.343452] bcmgenet fd580000.genet: failed to get enet-eee clock
        [    0.343475] bcmgenet: Skipping UMAC reset
        [    0.343719] unimac-mdio unimac-mdio.-19: DMA mask not set
        [    0.358050] libphy: bcmgenet MII bus: probed
        [    0.398545] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
        [    0.399454] usbcore: registered new interface driver r8152
        [    0.399516] usbcore: registered new interface driver lan78xx
        [    0.399574] usbcore: registered new interface driver smsc95xx
        [    0.399881] xhci_hcd 0000:01:00.0: xHCI Host Controller
        [    0.399910] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
        [    0.402118] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
        [    0.402426] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 53
        [    0.403254] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
        [    0.403268] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
        [    0.403281] usb usb1: Product: xHCI Host Controller
        [    0.403292] usb usb1: Manufacturer: Linux 4.19.118-v7l+ xhci-hcd
        [    0.403303] usb usb1: SerialNumber: 0000:01:00.0
        [    0.403826] hub 1-0:1.0: USB hub found
        [    0.403906] hub 1-0:1.0: 1 port detected
        [    0.404376] xhci_hcd 0000:01:00.0: xHCI Host Controller
        [    0.404397] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
        [    0.404416] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
        [    0.404822] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
        [    0.404835] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
        [    0.404847] usb usb2: Product: xHCI Host Controller
        [    0.404858] usb usb2: Manufacturer: Linux 4.19.118-v7l+ xhci-hcd
        [    0.404869] usb usb2: SerialNumber: 0000:01:00.0
        [    0.405349] hub 2-0:1.0: USB hub found
        [    0.405421] hub 2-0:1.0: 4 ports detected
        [    0.406609] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
        [    0.406793] dwc_otg: FIQ enabled
        [    0.406802] dwc_otg: NAK holdoff enabled
        [    0.406811] dwc_otg: FIQ split-transaction FSM enabled
        [    0.406823] Module dwc_common_port init
        [    0.407027] usbcore: registered new interface driver uas
        [    0.407128] usbcore: registered new interface driver usb-storage
        [    0.407307] mousedev: PS/2 mouse device common for all mice
        [    0.408496] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
        [    0.410116] sdhci: Secure Digital Host Controller Interface driver
        [    0.410125] sdhci: Copyright(c) Pierre Ossman
        [    0.410535] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
        [    0.410935] sdhci-pltfm: SDHCI platform and OF driver helper
        [    0.413950] ledtrig-cpu: registered to indicate activity on CPUs
        [    0.414094] hidraw: raw HID events driver (C) Jiri Kosina
        [    0.414219] usbcore: registered new interface driver usbhid
        [    0.414227] usbhid: USB HID core driver
        [    0.414992] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master =
        0
        [    0.416754] [vc_sm_connected_init]: start
        [    0.426077] [vc_sm_connected_init]: end - returning 0
        [    0.427178] Initializing XFRM netlink socket
        [    0.427205] NET: Registered protocol family 17
        [    0.427303] Key type dns_resolver registered
        [    0.427770] Registering SWP/SWPB emulation handler
        [    0.428386] registered taskstats version 1
        [    0.428404] Loading compiled-in X.509 certificates
        [    0.435357] uart-pl011 fe201000.serial: cts_event_workaround enabled
        [    0.435419] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
        [    0.440553] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
        [    0.441079] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
        [    0.441723] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
        [    0.441735] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
        [    0.467776] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.3
        [    0.467866] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.4
        [    0.487104] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
        [    0.488696] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
        [    0.490287] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
        [    0.493150] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
        [    0.494739] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
        [    0.503951] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
        [    0.506415] of_cfs_init
        [    0.506500] of_cfs_init: OK
        [    0.507091] Waiting for root device PARTUUID=ea7d04d6-02...
        [    0.550160] random: fast init done
        [    0.562611] mmc1: new high speed SDIO card at address 0001
        [    0.610212] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
        [    0.611339] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
        [    0.613985]  mmcblk0: p1 p2
        [    0.626125] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [    0.626167] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [    0.626973] devtmpfs: mounted
        [    0.634326] Freeing unused kernel memory: 2048K
        [    0.668268] Run /sbin/init as init process
        [    0.768064] usb 1-1: new high-speed USB device number 2 using xhci_hcd
        [    0.950708] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
        [    0.950722] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
        [    0.950734] usb 1-1: Product: USB2.0 Hub
        [    0.952619] hub 1-1:1.0: USB hub found
        [    0.952945] hub 1-1:1.0: 4 ports detected
        [    1.093979] systemd[1]: System time before build time, advancing clock.[    1.184284] NET: Registered protocol family 10
        [    1.185515] Segment Routing with IPv6
        [    1.216342] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
        [    1.217015] systemd[1]: Detected architecture arm.
        [    1.225590] systemd[1]: Set hostname to <raspberrypi4-iobroker>.
        [    1.278093] usb 1-1.2: new low-speed USB device number 3 using xhci_hcd[    1.423923] usb 1-1.2: New USB device found, idVendor=046a, idProduct=0001, bcdDevice= 1.00
        [    1.423940] usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
        [    1.445181] input: HID 046a:0001 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:046A:0001.0001/input/input0
        [    1.508582] hid-generic 0003:046A:0001.0001: input,hidraw0: USB HID v1.11 Keyboard [HID 046a:0001] on usb-0000:01:00.0-1.2/input0
        [    1.618095] usb 1-1.4: new full-speed USB device number 4 using xhci_hcd
        [    1.787130] usb 1-1.4: New USB device found, idVendor=0451, idProduct=16a8, bcdDevice= 0.09
        [    1.787145] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
        [    1.787158] usb 1-1.4: Product: TI CC2531 USB CDC
        [    1.787169] usb 1-1.4: Manufacturer: Texas Instruments
        [    1.787180] usb 1-1.4: SerialNumber: __0X00124B001936DBFD
        [    1.932293] random: systemd: uninitialized urandom read (16 bytes read)[    1.940932] random: systemd: uninitialized urandom read (16 bytes read)[    1.941007] systemd[1]: Reached target Swap.
        [    1.941389] random: systemd: uninitialized urandom read (16 bytes read)[    1.941988] systemd[1]: Listening on Journal Socket (/dev/log).
        [    1.942413] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
        [    1.942752] systemd[1]: Listening on initctl Compatibility Named Pipe.
        [    1.943328] systemd[1]: Listening on udev Control Socket.
        [    1.947482] systemd[1]: Created slice User and Session Slice.
        [    1.947956] systemd[1]: Listening on udev Kernel Socket.
        [    2.033929] i2c /dev entries driver
        [    2.571227] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        [    2.663276] systemd-journald[120]: Received request to flush runtime journal from PID 1
        [    2.778075] usb 1-1.3: new low-speed USB device number 5 using xhci_hcd[    2.917126] usb 1-1.3: New USB device found, idVendor=1d57, idProduct=2400, bcdDevice= 0.21
        [    2.917144] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
        [    2.917157] usb 1-1.3: Product: HID compliant-mouse
        [    2.917169] usb 1-1.3: Manufacturer: HID compliant-mouse
        [    2.926538] input: HID compliant-mouse HID compliant-mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:1D57:2400.0002/input/input1
        [    2.926902] hid-generic 0003:1D57:2400.0002: input,hidraw1: USB HID v1.10 Mouse [HID compliant-mouse HID compliant-mouse] on usb-0000:01:00.0-1.3/input0
        [    3.274645] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
        [    3.276646] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
        [    3.276662] [vc_sm_connected_init]: start
        [    3.286151] [vc_sm_connected_init]: installed successfully
        [    3.310140] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
        [    3.317149] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
        [    3.322760] media: Linux media interface: v0.10
        [    3.323455] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
        [    3.324514] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
        [    3.382688] videodev: Linux video capture interface: v2.00
        [    3.417593] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
        [    3.417800] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
        [    3.444660] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
        [    3.467180] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
        [    3.484947] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
        [    3.484996] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
        [    3.494052] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
        [    3.494086] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
        [    3.500203] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
        [    3.500242] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
        [    3.633738] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
        [    3.668199] bcm2835_audio soc:audio: card created with 4 channels
        [    3.706191] cfg80211: Loading compiled-in X.509 certificates for regulatory database
        [    3.717495] bcm2835_audio soc:audio: card created with 4 channels
        [    3.779642] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
        [    3.790513] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
        [    3.828981] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
        [    3.828999] checking generic (3e8f6000 2d1800) vs hw (0 ffffffffffffffff)
        [    3.829010] fb: switching to vc4drmfb from simple
        [    3.829240] Console: switching to colour dummy device 80x30
        [    3.830219] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1[    3.830231] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).[    3.830241] [drm] No driver support for vblank timestamp query.
        [    3.830250] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
        [    3.869091] brcmfmac: F1 signature read @0x18000000=0x15264345
        [    3.881123] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
        [    3.881766] usbcore: registered new interface driver brcmfmac
        [    3.891706] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
        [    3.893346] usbcore: registered new interface driver cdc_acm
        [    3.893357] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
        [    3.996405] vc4-drm soc:gpu: HDMI-A-1: EDID is invalid:
        [    3.996422] [00] BAD  00 ff ff ff ff ff ff 00 36 83 01 0b e9 03 00 00
        [    3.996433] [00] BAD  01 12 01 03 80 46 27 78 0a 19 90 a7 55 46 98 24
        [    3.996442] [00] BAD  00 49 4b 01 08 00 01 01 01 01 01 01 01 01 01 01
        [    3.996451] [00] BAD  01 01 01 01 01 01 01 1d 00 72 51 d0 1e 20 6e 28
        [    3.996461] [00] BAD  55 00 c4 8e 21 00 00 1e 01 1d 80 18 71 1c 16 20
        [    3.996470] [00] BAD  58 2c 25 00 c4 8e 21 00 00 9e 00 00 00 fc 00 4d
        [    3.996479] [00] BAD  54 43 32 36 54 34 32 0a 20 20 20 20 00 00 00 fd
        [    3.996488] [00] BAD  00 16 50 0e 5b 10 00 0a 20 20 20 20 20 20 01 9a
        [    4.001790] Console: switching to colour frame buffer device 160x45
        [    4.001827] vc4-drm soc:gpu: fb0: DRM emulated frame buffer device
        [    4.149022] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
        [    4.163047] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar  2 2020 23:30:41 version 7.45.202 (r724630 CY) FWID 01-72f6ece2
        [    6.177856] uart-pl011 fe201000.serial: no DMA platform data
        [    6.237641] random: crng init done
        [    6.237658] random: 7 urandom warning(s) missed due to ratelimiting
        [    6.331301] 8021q: 802.1Q VLAN Support v1.8
        [    6.583853] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
        [    6.732647] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
        [    6.732744] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled[    7.080764] bcmgenet: Skipping UMAC reset
        [    7.178758] bcmgenet fd580000.genet: configuring instance for external
        RGMII (no delay)
        [    7.179088] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
        [    8.248117] bcmgenet fd580000.genet eth0: Link is Down
        [   12.408220] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
        [   12.408244] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
        [   12.846002] Bluetooth: Core ver 2.22
        [   12.846073] NET: Registered protocol family 31
        [   12.846079] Bluetooth: HCI device and connection manager initialized
        [   12.847863] Bluetooth: HCI socket layer initialized
        [   12.847875] Bluetooth: L2CAP socket layer initialized
        [   12.847918] Bluetooth: SCO socket layer initialized
        [   12.864092] Bluetooth: HCI UART driver ver 2.3
        [   12.864101] Bluetooth: HCI UART protocol H4 registered
        [   12.864155] Bluetooth: HCI UART protocol Three-wire (H5) registered
        [   12.864327] Bluetooth: HCI UART protocol Broadcom registered
        [   14.421598] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
        [   14.421615] Bluetooth: BNEP filters: protocol multicast
        [   14.421645] Bluetooth: BNEP socket layer initialized
        [   14.486666] Bluetooth: RFCOMM TTY layer initialized
        [   14.486687] Bluetooth: RFCOMM socket layer initialized
          apollon77 @Danny Köhn last edited by
          @Danny-Köhn installiere iot mal neu
          • Danny Köhn
            @apollon77 ist dann das gleiche Problem
            Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
            • Danny Köhn
              code_ host.raspberrypi4-iobroker	2020-06-28 00:34:31.386	info	Restart adapter system.adapter.iot.0 because enabled
              host.raspberrypi4-iobroker	2020-06-28 00:34:31.385	error	instance system.adapter.iot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.raspberrypi4-iobroker	2020-06-28 00:34:31.384	error	Caught by controller[0]: }
              host.raspberrypi4-iobroker	2020-06-28 00:34:31.383	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.iot/main.js' ]
              host.raspberrypi4-iobroker	2020-06-28 00:34:31.383	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
              host.raspberrypi4-iobroker	2020-06-28 00:34:31.382	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12) {
              host.raspberrypi4-iobroker	2020-06-28 00:34:31.382	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
              host.raspberrypi4-iobroker	2020-06-28 00:34:31.381	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
              host.raspberrypi4-iobroker	2020-06-28 00:34:31.381	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
              host.raspberrypi4-iobroker	2020-06-28 00:34:31.380	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
              host.raspberrypi4-iobroker	2020-06-28 00:34:31.380	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.iot/main.js:6:22)
              host.raspberrypi4-iobroker	2020-06-28 00:34:31.379	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
              host.raspberrypi4-iobroker	2020-06-28 00:34:31.378	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
              host.raspberrypi4-iobroker	2020-06-28 00:34:31.378	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:842:27)
              host.raspberrypi4-iobroker	2020-06-28 00:34:31.377	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:966:15)
              host.raspberrypi4-iobroker	2020-06-28 00:34:31.377	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.iot/main.js
              host.raspberrypi4-iobroker	2020-06-28 00:34:31.376	error	Caught by controller[0]: Require stack:
              host.raspberrypi4-iobroker	2020-06-28 00:34:31.375	error	Caught by controller[0]: Error: Cannot find module 'aws-iot-device-sdk'
              host.raspberrypi4-iobroker	2020-06-28 00:34:31.375	error	Caught by controller[0]: ^
              host.raspberrypi4-iobroker	2020-06-28 00:34:31.374	error	Caught by controller[0]: throw err;
              host.raspberrypi4-iobroker	2020-06-28 00:34:31.373	error	Caught by controller[0]: internal/modules/cjs/loader.js:969
              host.raspberrypi4-iobroker	2020-06-28 00:34:31.144	info	instance system.adapter.iot.0 started with pid 6525
              host.raspberrypi4-iobroker	2020-06-28 00:34:31.068	info	"system.adapter.iot.0" enabled
                @Danny-Köhn
                mount | grep ^/dev
                • Danny Köhn
                  root@raspberrypi4-iobroker:~# mount | grep ^/dev
                  /dev/mmcblk0p2 on / type ext4 (rw,noatime)
                  /dev/mmcblk0p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
                    @Danny-Köhn Och, root-shell. Dann bin ich raus. Viel Erfolg noch.
                    • Danny Köhn
                      @Thomas-Braun ist das ein Problem bin leider nicht so bewandert bei linux.
                        @Danny-Köhn Ja, gerade DANN ist es ein Problem.
                        Debian/Raspbian wird nicht per root login, sonder per 'sudo' administriert.
                        • Danny Köhn
                          @Thomas-Braun bin über SSH als Root User eingeloggt
                            @Danny-Köhn Und das ist Quark.
                            Log dich mit dem Standard-User, vermutlich 'pi' ein.
                            • Danny Köhn
                              Schon geschehen
                                @Danny-Köhn
                                which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                                • Danny Köhn
                                  code_text
                                  /usr/bin/nodejs
                                  v12.18.1
                                  /usr/local/bin/node
                                  v12.18.1
                                  /usr/local/bin/npm
                                  6.14.5
                                  nodejs:
                                    Installiert:           12.18.1-1nodesource1
                                    Installationskandidat: 12.18.1-1nodesource1
                                    Versionstabelle:
                                   *** 12.18.1-1nodesource1 500
                                          500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                                          100 /var/lib/dpkg/status
                                       10.21.0~dfsg-1~deb10u1+rpi1 500
                                  pi@raspberrypi4-iobroker:~ $
                                    @Danny-Köhn Auch mal wieder ein Klassiker.
                                    node ist falsch installiert.
                                    sudo rm /usr/local/bin/node
                                    sudo rm /usr/local/bin/npm
                                    sudo apt update
                                    sudo apt dist-upgrade
                                    sudo apt install nodejs --reinstall
                                    sudo reboot
                                    • Danny Köhn
                                      Nach dieser Operation werden 38,9 MB Plattenplatz zusätzlich benutzt.
                                      Möchten Sie fortfahren? [J/n] J
                                      Abbruch.
                                      Bei Ja macht er trotzdem einen Abbruch
                                        Thomas Braun Most Active @Danny Köhn last edited by Thomas Braun
                                        @Danny-Köhn Kompletten input wie auch output zeigen.
                                        sudo apt update
                                        sudo apt upgrade
                                        • Danny Köhn
                                          Mit den Befehlen ging es.
                                          code_text
                                          pi@raspberrypi4-iobroker:~ $ sudo apt update
                                          OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                          OK:2 http://archive.raspberrypi.org/debian buster InRelease
                                          OK:3 https://deb.nodesource.com/node_12.x buster InRelease
                                          Aktualisierung für 3 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                                          pi@raspberrypi4-iobroker:~ $ sudo apt upgrade
                                          Paketaktualisierung (Upgrade) wird berechnet... Fertig
                                          Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                                            gyp libc-ares2 libjs-inherits libjs-is-typedarray libmicrodns0 libssl-dev libuv1 libuv1-dev node-abbrev node-ajv node-ansi
                                            node-ansi-align node-ansi-regex node-ansi-styles node-ansistyles node-aproba node-archy node-are-we-there-yet node-asn1 node-assert-plus
                                            node-asynckit node-aws-sign2 node-aws4 node-balanced-match node-bcrypt-pbkdf node-bluebird node-boxen node-brace-expansion
                                            node-builtin-modules node-builtins node-cacache node-call-limit node-camelcase node-caseless node-chalk node-chownr node-cli-boxes
                                            node-cliui node-clone node-co node-color-convert node-color-name node-combined-stream node-concat-map node-concat-stream
                                            node-config-chain node-console-control-strings node-copy-concurrently node-core-util-is node-cross-spawn node-cyclist node-dashdash
                                            node-decamelize node-decompress-response node-deep-extend node-defaults node-delayed-stream node-delegates node-detect-indent
                                            node-detect-newline node-duplexer3 node-duplexify node-ecc-jsbn node-editor node-encoding node-end-of-stream node-errno
                                            node-escape-string-regexp node-execa node-extend node-extsprintf node-find-up node-flush-write-stream node-forever-agent node-form-data
                                            node-from2 node-fs-vacuum node-fs-write-stream-atomic node-fs.realpath node-gauge node-get-caller-file node-get-stream node-getpass
                                            node-glob node-got node-graceful-fs node-har-schema node-har-validator node-has-flag node-has-symbol-support-x node-has-to-string-tag-x
                                            node-has-unicode node-hosted-git-info node-http-signature node-iconv-lite node-iferr node-import-lazy node-imurmurhash node-inflight
                                            node-inherits node-ini node-invert-kv node-is-builtin-module node-is-npm node-is-object node-is-plain-obj node-is-retry-allowed
                                            node-is-stream node-is-typedarray node-isarray node-isexe node-isstream node-isurl node-jsbn node-json-parse-better-errors
                                            node-json-schema node-json-stable-stringify node-json-stringify-safe node-jsonify node-jsonparse node-jsonstream node-jsprim
                                            node-latest-version node-lazy-property node-lcid node-libnpx node-locate-path node-lockfile node-lowercase-keys node-lru-cache node-mem
                                            node-mime-types node-mimic-fn node-mimic-response node-minimatch node-minimist node-mississippi node-mkdirp node-move-concurrently
                                            node-mute-stream node-node-uuid node-nopt node-normalize-package-data node-npm-package-arg node-npm-run-path node-npmlog node-oauth-sign
                                            node-object-assign node-once node-opener node-os-locale node-osenv node-p-cancelable node-p-finally node-p-limit node-p-locate
                                            node-p-timeout node-package-json node-parallel-transform node-path-exists node-path-is-absolute node-path-is-inside node-performance-now
                                            node-prepend-http node-process-nextick-args node-promise-inflight node-promzard node-proto-list node-prr node-pump node-pumpify
                                            node-punycode node-qs node-qw node-rc node-read node-read-package-json node-readable-stream node-registry-auth-token node-registry-url
                                            node-request node-require-directory node-require-main-filename node-resolve-from node-retry node-rimraf node-run-queue node-safe-buffer
                                            node-semver node-semver-diff node-set-blocking node-sha node-shebang-command node-shebang-regex node-signal-exit node-slash node-slide
                                            node-sorted-object node-spdx-correct node-spdx-expression-parse node-spdx-license-ids node-sshpk node-ssri node-stream-each
                                            node-stream-iterate node-stream-shift node-string-decoder node-string-width node-strip-ansi node-strip-eof node-strip-json-comments
                                            node-supports-color node-tar node-term-size node-text-table node-through node-through2 node-timed-out node-tough-cookie node-tunnel-agent
                                            node-tweetnacl node-typedarray node-uid-number node-unique-filename node-unpipe node-url-parse-lax node-url-to-options
                                            node-util-deprecate node-uuid node-validate-npm-package-license node-validate-npm-package-name node-verror node-wcwidth.js node-which
                                            node-which-module node-wide-align node-widest-line node-wrap-ansi node-wrappy node-write-file-atomic node-xdg-basedir node-xtend
                                            node-y18n node-yallist node-yargs node-yargs-parser nodejs-doc rpi-eeprom-images
                                          Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                                          Die folgenden NEUEN Pakete werden installiert:
                                            agnostics fio ibverbs-providers libaio1 libboost-atomic1.67.0 libboost-iostreams1.67.0 libboost-regex1.67.0 libboost-system1.67.0
                                            libboost-thread1.67.0 libgfapi0 libgfrpc0 libgfxdr0 libglusterfs0 libibverbs1 libnuma1 librados2 librbd1 librdmacm1 lxplug-magnifier
                                            rp-bookshelf rpi.gpio-common
                                          Die folgenden Pakete werden aktualisiert (Upgrade):
                                            python-rpi.gpio python3-rpi.gpio raspberrypi-ui-mods
                                          3 aktualisiert, 21 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                          Es müssen 15,8 MB an Archiven heruntergeladen werden.
                                          Möchten Sie fortfahren? [J/n] j
                                          Holen:1 http://archive.raspberrypi.org/debian buster/main armhf agnostics armhf 0.4 [10,6 kB]
                                          Holen:2 http://archive.raspberrypi.org/debian buster/main armhf lxplug-magnifier armhf 0.2 [6.280 B]
                                          Holen:3 http://archive.raspberrypi.org/debian buster/main armhf rpi.gpio-common armhf 0.7.0-0.1~bpo10+1 [5.776 B]
                                          Holen:4 http://archive.raspberrypi.org/debian buster/main armhf python-rpi.gpio armhf 0.7.0-0.1~bpo10+1 [20,8 kB]
                                          Holen:5 http://archive.raspberrypi.org/debian buster/main armhf python3-rpi.gpio armhf 0.7.0-0.1~bpo10+1 [20,7 kB]
                                          python-rpi.gpio (0.7.0-0.1~bpo10+1) wird eingerichtet ...
                                          libboost-system1.67.0:armhf (1.67.0-13+deb10u1) wird eingerichtet ...
                                          libaio1:armhf (0.3.112-3) wird eingerichtet ...
                                          libgfxdr0:armhf (5.5-3) wird eingerichtet ...
                                          librdmacm1:armhf (22.1-1) wird eingerichtet ...
                                          libboost-thread1.67.0:armhf (1.67.0-13+deb10u1) wird eingerichtet ...
                                          libgfrpc0:armhf (5.5-3) wird eingerichtet ...
                                          librados2:armhf (12.2.11+dfsg1-2.1+rpi1) wird eingerichtet ...
                                          librbd1:armhf (12.2.11+dfsg1-2.1+rpi1) wird eingerichtet ...
                                          libgfapi0:armhf (5.5-3) wird eingerichtet ...
                                          fio (3.12-2) wird eingerichtet ...
                                          agnostics (0.4) wird eingerichtet ...
                                          Trigger für man-db (2.8.5-2) werden verarbeitet ...
                                          Trigger für shared-mime-info (1.10-1) werden verarbeitet ...
                                          Trigger für desktop-file-utils (0.23-4) werden verarbeitet ...
                                          Trigger für mime-support (3.62) werden verarbeitet ...
                                          Trigger für hicolor-icon-theme (0.17-2) werden verarbeitet ...
                                          Trigger für gnome-menus (3.31.4-3) werden verarbeitet ...
                                          Trigger für libc-bin (2.28-10+rpi1) werden verarbeitet ...
                                          Trigger für systemd (241-7~deb10u4+rpi1) werden verarbeitet ...
                                            @Danny-Köhn
                                            Da schleppst du ja noch den kompletten Desktop mit...
                                            sudo apt autoremove
                                            cloud
                                            48
                                            256
                                            38041
