    4. JavaScript
    5. [Vorlage] Flexibles Timerskript + Vis
      terne last edited by terne
      Hi
      ich bekomme das script irgendwie nicht zum laufen!
      javascript.0	2020-06-28 08:50:16.238	error	(13852) at processTicksAndRejections (internal/process/task_queues.js:97:5)
      javascript.0	2020-06-28 08:50:16.238	error	(13852) at runMicrotasks (<anonymous>)
      javascript.0	2020-06-28 08:50:16.238	error	(13852) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
      javascript.0	2020-06-28 08:50:16.238	error	(13852) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      javascript.0	2020-06-28 08:50:16.238	error	(13852) at /opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:93703
      javascript.0	2020-06-28 08:50:16.238	error	(13852) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1910:38
      javascript.0	2020-06-28 08:50:16.238	error	(13852) at Object.<anonymous> (script.js.common.TimerScript:254:17)
      javascript.0	2020-06-28 08:50:16.238	error	(13852) at FillTimerArray (script.js.common.TimerScript:279:74)
      javascript.0	2020-06-28 08:50:16.238	error	(13852) Error in callback: TypeError: Cannot read property 'common' of null
      javascript.0	2020-06-28 08:50:16.237	warn	(13852) Object "" does not exist
      javascript.0	2020-06-28 08:50:16.237	info	(13852) script.js.common.TimerScript: Timer CreateState(s) finished!
      javascript.0	2020-06-28 08:50:16.237	error	(13852) at processTicksAndRejections (internal/process/task_queues.js:97:5)
      javascript.0	2020-06-28 08:50:16.237	error	(13852) at runMicrotasks (<anonymous>)
      javascript.0	2020-06-28 08:50:16.237	error	(13852) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
      javascript.0	2020-06-28 08:50:16.237	error	(13852) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      javascript.0	2020-06-28 08:50:16.237	error	(13852) at /opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:93703
      javascript.0	2020-06-28 08:50:16.236	error	(13852) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1910:38
      javascript.0	2020-06-28 08:50:16.236	error	(13852) at Object.<anonymous> (script.js.common.TimerScript:254:17)
      javascript.0	2020-06-28 08:50:16.236	error	(13852) at FillTimerArray (script.js.common.TimerScript:279:74)
      javascript.0	2020-06-28 08:50:16.236	error	(13852) Error in callback: TypeError: Cannot read property 'common' of null
      javascript.0	2020-06-28 08:50:16.236	warn	(13852) Object "" does not exist
      javascript.0	2020-06-28 08:50:16.235	info	(13852) script.js.common.TimerScript: Timer CreateState(s) finished!
      javascript.0	2020-06-28 08:50:16.234	info	(13852) script.js.common.TimerScript: Reaching CreateTrigger()
      javascript.0	2020-06-28 08:50:16.234	info	(13852) script.js.common.TimerScript: Reaching ConvertPresence. TempPresence=true
      javascript.0	2020-06-28 08:50:16.234	info	(13852) script.js.common.TimerScript: Reaching SetValueListPairs()
      javascript.0	2020-06-28 08:50:16.234	info	(13852) script.js.common.TimerScript: Reaching CreateTimerCountList()
      javascript.0	2020-06-28 08:50:16.231	info	(13852) script.js.common.TimerScript: 1 Targets found - Targets are: sonoff.0.DVES_334397.POWER
      javascript.0	2020-06-28 08:50:16.231	info	(13852) script.js.common.TimerScript: Reaching Init()
      javascript.0	2020-06-28 08:50:16.231	info	(13852) script.js.common.TimerScript: Reaching Main
      javascript.0	2020-06-28 08:50:16.230	info	(13852) script.js.common.TimerScript: Initial CreateStates finished!
      javascript.0	2020-06-28 08:50:16.227	info	(13852) script.js.common.TimerScript: registered 0 subscriptions and 0 schedules
      javascript.0	2020-06-28 08:50:16.226	info	(13852) script.js.common.TimerScript: Starting TimerSkript V2.1.1
      javascript.0	2020-06-28 08:50:16.221	info	(13852) Start javascript script.js.common.TimerScript
      javascript.0	2020-06-28 08:50:14.121	info	(13852) Stop script script.js.common.TimerScript
      was mach ich falsch bzw was übersehe ich? 😵
      gruß Thorsten
        Pittini Developer @terne last edited by
        @terne sagte in [Vorlage] Flexibles Timerskript + Vis:
        Zeig mal nen Screenshot der Objektliste mit dem genutzten Datenpunkt und der Zuweisung.
          terne @Pittini last edited by terne
          @Pittini
            Annonymus1988 last edited by
            ich schaffe es nicht, den Smartnamen zu ändern, bzw in der Tabelle wird immer mein alter Name angezeigt. In der Auswahlliste sind die neuen Namen, nur in der Tabelle erscheint immer der alte.
              Pittini Developer @Annonymus1988 last edited by
              @Annonymus1988 sagte in [Vorlage] Flexibles Timerskript + Vis:
              Gespeichert haste? Wenn ja, brauch ich das Log wenn Du den Namen änderst.
                @terne Zuweisung schaut soweit gut aus. JS Adapter nach den Aufzählungsänderungen neu gestartet? Wenn ja und es geht trotzdem nicht, bitte den Screenshot nochmal und so dass ich auch die oberste Ebene seh, da tritt der Fehler nämlich auf. Das Skript versucht die ParentId bzw. Namen rauszufinden und scheitert. Was is das fürn Adapter? Sonoff?
                  Aachen1305 last edited by
                  Hallo, ich könnte auch mal wieder Hilfe gebrauchen 🙂
                  Ich habe das Skript installiert, in den Aufzählungen die Funktion TimerTarget hinzugefügt trotzdem zeigt er mir nen Error an.
                  28.6.2020, 12:34:46.692	[info ]: javascript.0 (17932) Stop script script.js.smarthome.steckdosen.Timeskript
                  28.6.2020, 12:34:46.847	[info ]: javascript.0 (17932) Start javascript script.js.smarthome.steckdosen.Timeskript
                  28.6.2020, 12:34:46.862	[info ]: javascript.0 (17932) script.js.smarthome.steckdosen.Timeskript: Starting TimerSkript V2.1.1
                  28.6.2020, 12:34:46.868	[info ]: javascript.0 (17932) script.js.smarthome.steckdosen.Timeskript: registered 0 subscriptions and 0 schedules
                  28.6.2020, 12:34:46.912	[info ]: javascript.0 (17932) script.js.smarthome.steckdosen.Timeskript: Initial CreateStates finished!
                  28.6.2020, 12:34:46.912	[info ]: javascript.0 (17932) script.js.smarthome.steckdosen.Timeskript: Reaching Main
                  28.6.2020, 12:34:46.913	[info ]: javascript.0 (17932) script.js.smarthome.steckdosen.Timeskript: Reaching Init()
                  28.6.2020, 12:34:46.913	[info ]: javascript.0 (17932) script.js.smarthome.steckdosen.Timeskript: 3 Targets found - Targets are: sonoff.0.Pool-Pumpe.POWER,sonoff.0.Schalter-Kompressor.POWER,shelly.0.SHSW-1#C42A03#1.Relay0.Switch
                  28.6.2020, 12:34:46.922	[info ]: javascript.0 (17932) script.js.smarthome.steckdosen.Timeskript: Reaching CreateTimerCountList()
                  28.6.2020, 12:34:46.923	[info ]: javascript.0 (17932) script.js.smarthome.steckdosen.Timeskript: Reaching SetValueListPairs()
                  28.6.2020, 12:34:46.924	[info ]: javascript.0 (17932) script.js.smarthome.steckdosen.Timeskript: Reaching ConvertPresence. TempPresence=true
                  28.6.2020, 12:34:46.924	[info ]: javascript.0 (17932) script.js.smarthome.steckdosen.Timeskript: Reaching CreateTrigger()
                  28.6.2020, 12:34:46.983	[info ]: javascript.0 (17932) script.js.smarthome.steckdosen.Timeskript: Timer CreateState(s) finished!
                  28.6.2020, 12:34:46.986	[error]: javascript.0 (17932)     at FillTimerArray (script.js.smarthome.steckdosen.Timeskript:279:74)
                  28.6.2020, 12:34:46.986	[error]: javascript.0 (17932)     at Object.<anonymous> (script.js.smarthome.steckdosen.Timeskript:254:17)
                  28.6.2020, 12:34:46.989	[info ]: javascript.0 (17932) script.js.smarthome.steckdosen.Timeskript: Timer CreateState(s) finished!
                  28.6.2020, 12:34:46.992	[error]: javascript.0 (17932)     at FillTimerArray (script.js.smarthome.steckdosen.Timeskript:279:74)
                  28.6.2020, 12:34:46.992	[error]: javascript.0 (17932)     at Object.<anonymous> (script.js.smarthome.steckdosen.Timeskript:254:17)
                    Annonymus1988 @Pittini last edited by Annonymus1988
                    @Pittini ja gespeichert habe ich
                    wie bekomme ich den ausschnitt des log hier rein ? einfach reinkopieren ?
                    javascript.0	2020-06-28 13:23:42.331	info	(9038) script.js.common.Timerscript: Settings saved
                    javascript.0	2020-06-28 13:23:41.330	info	(9038) script.js.common.Timerscript: Reaching MakeTable
                    javascript.0	2020-06-28 13:23:41.329	info	(9038) script.js.common.Timerscript: Reaching MakeTable
                    javascript.0	2020-06-28 13:23:41.329	info	(9038) script.js.common.Timerscript: Reaching SwitchEditMode(whichone, onoff), whichonex=1 TimerCount=4 onoff=false
                    javascript.0	2020-06-28 13:23:41.327	info	(9038) script.js.common.Timerscript: CronString for Timer 2 created 00 00 10 * * *
                    javascript.0	2020-06-28 13:23:41.326	info	(9038) script.js.common.Timerscript: Reaching MakeCronString(whichone=1)
                    javascript.0	2020-06-28 13:23:41.326	info	(9038) script.js.common.Timerscript: Reaching CreateTimeDaysString(whichone=1)
                    javascript.0	2020-06-28 13:23:41.326	info	(9038) script.js.common.Timerscript: Timer 2 will be set, GoToTommorrow=false
                    javascript.0	2020-06-28 13:23:41.326	info	(9038) script.js.common.Timerscript: Timer Schedule 2 killed
                    javascript.0	2020-06-28 13:23:41.323	info	(9038) script.js.common.Timerscript: Reaching WriteToTimer, whichone=1
                      Ja reinkopieren. Aber bitte in Code Tags setzen, sonst wirds unleserlich.
                        Pittini Developer last edited by
                        @terne @Aachen1305 - Ihr habt beide das gleiche Problem, ich hab mal was geändert und neue Version hochgeladen. Testet bitte mal obs jetzt klappt.
                          @Pittini
                          javascript.0	2020-06-28 13:33:01.996	info	(9038) script.js.common.Timerscript: Settings saved
                          javascript.0	2020-06-28 13:33:00.996	info	(9038) script.js.common.Timerscript: Reaching MakeTable
                          javascript.0	2020-06-28 13:33:00.994	info	(9038) script.js.common.Timerscript: Reaching MakeTable
                          javascript.0	2020-06-28 13:33:00.993	info	(9038) script.js.common.Timerscript: Reaching SwitchEditMode(whichone, onoff), whichonex=4 TimerCount=5 onoff=false
                          javascript.0	2020-06-28 13:33:00.992	info	(9038) script.js.common.Timerscript: CronString for Timer 5 created 00 35 13 * * *
                          javascript.0	2020-06-28 13:33:00.992	info	(9038) script.js.common.Timerscript: Reaching MakeCronString(whichone=4)
                          javascript.0	2020-06-28 13:33:00.991	info	(9038) script.js.common.Timerscript: Reaching CreateTimeDaysString(whichone=4)
                          javascript.0	2020-06-28 13:33:00.991	info	(9038) script.js.common.Timerscript: Timer 5 will be set, GoToTommorrow=false
                          javascript.0	2020-06-28 13:33:00.988	info	(9038) script.js.common.Timerscript: Timer Schedule 5 killed
                          javascript.0	2020-06-28 13:33:00.984	info	(9038) script.js.common.Timerscript: Reaching WriteToTimer, whichone=4
                          javascript.0	2020-06-28 13:32:55.512	info	(9038) script.js.common.Timerscript: Reaching MakeTable
                          javascript.0	2020-06-28 13:32:55.512	info	(9038) script.js.common.Timerscript: Reaching SwitchEditMode(whichone, onoff), whichonex=4 TimerCount=5 onoff=true
                            @Pittini
                            Danke Dir, jetzt klappt es👍
                              @Annonymus1988 Ich seh da nix vom umbenennen, bitte ganzes Log, Schnipsel helfen mir nix.
                                @Pittini
                                neue Version kopiert, und jetzt geht es auf einmal
                                aber jetzt werden ungenutzte namen gelöscht
                                javascript.0	2020-06-28 13:43:53.214	info	(9038) script.js.common.Timerscript: Reaching MakeTable
                                javascript.0	2020-06-28 13:43:53.213	info	(9038) script.js.common.Timerscript: Reaching SwitchEditMode(whichone, onoff), whichonex=4 TimerCount=5 onoff=true
                                javascript.0	2020-06-28 13:43:51.643	info	(9038) script.js.common.Timerscript: Settings saved
                                javascript.0	2020-06-28 13:43:50.640	info	(9038) script.js.common.Timerscript: Reaching MakeTable
                                javascript.0	2020-06-28 13:43:50.639	info	(9038) script.js.common.Timerscript: Reaching MakeTable
                                javascript.0	2020-06-28 13:43:50.639	info	(9038) script.js.common.Timerscript: Reaching SwitchEditMode(whichone, onoff), whichonex=4 TimerCount=5 onoff=false
                                javascript.0	2020-06-28 13:43:50.639	info	(9038) script.js.common.Timerscript: Timer Schedule 5 killed
                                javascript.0	2020-06-28 13:43:50.638	info	(9038) script.js.common.Timerscript: CreateTimerTargetsNameList() refresh done, MyTimerTemplate[17].indexOf(TargetNames)=-1
                                javascript.0	2020-06-28 13:43:50.638	info	(9038) script.js.common.Timerscript: ['Brunnen',null,'Media']
                                javascript.0	2020-06-28 13:43:50.637	info	(9038) script.js.common.Timerscript: ['sonoff.0.Terrassenschrank.POWER3','sonoff.0.Terrassenschrank.POWER1','sonoff.0.Terrassenschrank.POWER2','sonoff.0.Terrassenschrank.POWER4','sonoff.0.Laterne.POWE
                                javascript.0	2020-06-28 13:43:50.637	info	(9038) script.js.common.Timerscript: NewTargetNames[2] undefined corrected to Media y=4
                                javascript.0	2020-06-28 13:43:50.636	info	(9038) script.js.common.Timerscript: NewTargetNames[0] Brunnen set to Brunnen y=0
                                javascript.0	2020-06-28 13:43:50.632	info	(9038) script.js.common.Timerscript: Reaching WriteToTimer, whichone=4
                                javascript.0	2020-06-28 13:43:47.566	info	(9038) script.js.common.Timerscript: Reaching MakeTable
                                javascript.0	2020-06-28 13:43:47.566	info	(9038) script.js.common.Timerscript: Reaching SwitchEditMode(whichone, onoff), whichonex=4 TimerCount=5 onoff=true
                                javascript.0	2020-06-28 13:43:46.531	info	(9038) script.js.common.Timerscript: Reaching MakeTable
                                javascript.0	2020-06-28 13:43:46.531	info	(9038) script.js.common.Timerscript: Reaching SwitchEditMode(whichone, onoff), whichonex=4 TimerCount=5 onoff=true
                                javascript.0	2020-06-28 13:43:39.881	info	(9038) script.js.common.Timerscript: Reaching MakeTable
                                javascript.0	2020-06-28 13:43:39.881	info	(9038) script.js.common.Timerscript: Reaching SwitchEditMode(whichone, onoff), whichonex=4 TimerCount=5 onoff=true
                                javascript.0	2020-06-28 13:42:44.921	info	(9038) script.js.common.Timerscript: Reaching MakeTable
                                javascript.0	2020-06-28 13:42:44.920	info	(9038) script.js.common.Timerscript: ['Brunnen','Sonoro']
                                javascript.0	2020-06-28 13:42:44.920	info	(9038) script.js.common.Timerscript: ['sonoff.0.Terrassenschrank.POWER3','sonoff.0.Terrassenschrank.POWER1','sonoff.0.Terrassenschrank.POWER2','sonoff.0.Terrassenschrank.POWER4','sonoff.0.Laterne.POWE
                                javascript.0	2020-06-28 13:42:44.919	info	(9038) script.js.common.Timerscript: NewTargetNames[1] Terrassenschrank corrected to Sonoro y=4
                                javascript.0	2020-06-28 13:42:44.918	info	(9038) script.js.common.Timerscript: NewTargetNames[0] Terrassenschrank corrected to Brunnen y=3
                                javascript.0	2020-06-28 13:42:44.918	info	(9038) script.js.common.Timerscript: NewTargetNames[0] Terrassenschrank corrected to Brunnen y=2
                                javascript.0	2020-06-28 13:42:44.917	info	(9038) script.js.common.Timerscript: NewTargetNames[0] Terrassenschrank corrected to Brunnen y=1
                                javascript.0	2020-06-28 13:42:44.917	info	(9038) script.js.common.Timerscript: NewTargetNames[0] Terrassenschrank corrected to Brunnen y=0
                                javascript.0	2020-06-28 13:42:44.913	info	(9038) script.js.common.Timerscript: CronString for Timer 5 created 00 35 13 * * *
                                javascript.0	2020-06-28 13:42:44.912	info	(9038) script.js.common.Timerscript: Reaching MakeCronString(whichone=4)
                                javascript.0	2020-06-28 13:42:44.912	info	(9038) script.js.common.Timerscript: Reaching CreateTimeDaysString(whichone=4)
                                javascript.0	2020-06-28 13:42:44.911	info	(9038) script.js.common.Timerscript: Timer 5 will be set, GoToTommorrow=false
                                javascript.0	2020-06-28 13:42:44.911	info	(9038) script.js.common.Timerscript: Reaching CreateDeviceTrigger() Trigger added for sonoff.0.Terrassenschrank.POWER1 whichone= 1
                                javascript.0	2020-06-28 13:42:44.910	info	(9038) script.js.common.Timerscript: Timer CreateState(s) finished!
                                javascript.0	2020-06-28 13:42:44.903	info	(9038) script.js.common.Timerscript: CronString for Timer 4 created 00 00 23 * * *
                                javascript.0	2020-06-28 13:42:44.902	info	(9038) script.js.common.Timerscript: Reaching MakeCronString(whichone=3)
                                javascript.0	2020-06-28 13:42:44.902	info	(9038) script.js.common.Timerscript: Reaching CreateTimeDaysString(whichone=3)
                                javascript.0	2020-06-28 13:42:44.901	info	(9038) script.js.common.Timerscript: Timer 4 will be set, GoToTommorrow=false
                                javascript.0	2020-06-28 13:42:44.900	info	(9038) script.js.common.Timerscript: Timer CreateState(s) finished!
                                javascript.0	2020-06-28 13:42:44.898	info	(9038) script.js.common.Timerscript: CronString for Timer 3 created 00 00 16 * * *
                                javascript.0	2020-06-28 13:42:44.898	info	(9038) script.js.common.Timerscript: Reaching MakeCronString(whichone=2)
                                javascript.0	2020-06-28 13:42:44.897	info	(9038) script.js.common.Timerscript: Reaching CreateTimeDaysString(whichone=2)
                                javascript.0	2020-06-28 13:42:44.897	info	(9038) script.js.common.Timerscript: Timer 3 will be set, GoToTommorrow=false
                                javascript.0	2020-06-28 13:42:44.895	info	(9038) script.js.common.Timerscript: Timer CreateState(s) finished!
                                javascript.0	2020-06-28 13:42:44.879	info	(9038) script.js.common.Timerscript: CronString for Timer 2 created 00 00 10 * * *
                                javascript.0	2020-06-28 13:42:44.878	info	(9038) script.js.common.Timerscript: Reaching MakeCronString(whichone=1)
                                javascript.0	2020-06-28 13:42:44.877	info	(9038) script.js.common.Timerscript: Reaching CreateTimeDaysString(whichone=1)
                                javascript.0	2020-06-28 13:42:44.877	info	(9038) script.js.common.Timerscript: Timer 2 will be set, GoToTommorrow=false
                                javascript.0	2020-06-28 13:42:44.875	info	(9038) script.js.common.Timerscript: Timer CreateState(s) finished!
                                javascript.0	2020-06-28 13:42:44.865	info	(9038) script.js.common.Timerscript: CronString for Timer 1 created 00 15 05 * * *
                                javascript.0	2020-06-28 13:42:44.864	info	(9038) script.js.common.Timerscript: Reaching MakeCronString(whichone=0)
                                javascript.0	2020-06-28 13:42:44.864	info	(9038) script.js.common.Timerscript: Reaching CreateTimeDaysString(whichone=0)
                                javascript.0	2020-06-28 13:42:44.863	info	(9038) script.js.common.Timerscript: Timer 1 will be set, GoToTommorrow=false
                                javascript.0	2020-06-28 13:42:44.863	info	(9038) script.js.common.Timerscript: Reaching CreateDeviceTrigger() Trigger added for sonoff.0.Terrassenschrank.POWER3 whichone= 0
                                javascript.0	2020-06-28 13:42:44.862	info	(9038) script.js.common.Timerscript: Timer CreateState(s) finished!
                                javascript.0	2020-06-28 13:42:44.856	info	(9038) script.js.common.Timerscript: Reaching CreateTrigger()
                                javascript.0	2020-06-28 13:42:44.855	info	(9038) script.js.common.Timerscript: Reaching ConvertPresence. TempPresence=true
                                javascript.0	2020-06-28 13:42:44.854	info	(9038) script.js.common.Timerscript: Reaching SetValueListPairs()
                                javascript.0	2020-06-28 13:42:44.853	info	(9038) script.js.common.Timerscript: Reaching CreateTimerCountList()
                                javascript.0	2020-06-28 13:42:44.839	info	(9038) script.js.common.Timerscript: 5 Targets found - Targets are: sonoff.0.Terrassenschrank.POWER3,sonoff.0.Terrassenschrank.POWER1,sonoff.0.Terrassenschrank.POWER2,sonoff.0.Terrassenschrank.POWER4,
                                javascript.0	2020-06-28 13:42:44.837	info	(9038) script.js.common.Timerscript: Reaching Init()
                                javascript.0	2020-06-28 13:42:44.837	info	(9038) script.js.common.Timerscript: Reaching Main
                                javascript.0	2020-06-28 13:42:44.836	info	(9038) script.js.common.Timerscript: Initial CreateStates finished!
                                javascript.0	2020-06-28 13:42:44.790	info	(9038) script.js.common.Timerscript: registered 0 subscriptions and 0 schedules
                                javascript.0	2020-06-28 13:42:44.786	info	(9038) script.js.common.Timerscript: Starting TimerSkript V2.1.3
                                javascript.0	2020-06-28 13:42:44.775	info	(9038) Start javascript script.js.common.Timerscript
                                javascript.0	2020-06-28 13:42:44.616	info	(9038) script.js.common.Timerscript: Timer Schedule 5 killed
                                javascript.0	2020-06-28 13:42:44.616	info	(9038) script.js.common.Timerscript: Timer Schedule 4 killed
                                javascript.0	2020-06-28 13:42:44.616	info	(9038) script.js.common.Timerscript: Timer Schedule 3 killed
                                javascript.0	2020-06-28 13:42:44.616	info	(9038) script.js.common.Timerscript: Timer Schedule 2 killed
                                javascript.0	2020-06-28 13:42:44.616	info	(9038) script.js.common.Timerscript: Timer Schedule 1 killed
                                javascript.0	2020-06-28 13:42:44.614	info	(9038) Stop script script.js.common.Timerscript
                                  @Pittini
                                  Hi, funktioniert bei mir leider nicht richtig. Log bringt grad keine Fehler, aber einige Funktionen bleiben leer und ich kann keine Timer setzen in VIS.
                                  javascript.0	2020-06-28 17:36:15.016	info	(11338) script.js.common.TimerScript: Reaching MakeTable
                                  javascript.0	2020-06-28 17:36:15.016	info	(11338) script.js.common.TimerScript: []
                                  javascript.0	2020-06-28 17:36:15.016	info	(11338) script.js.common.TimerScript: ['sonoff.0.DVES_334397.POWER','sonoff.0.DVES_8F50DE.POWER']
                                  javascript.0	2020-06-28 17:36:15.015	info	(11338) script.js.common.TimerScript: Timer CreateState(s) finished!
                                  javascript.0	2020-06-28 17:36:15.014	info	(11338) script.js.common.TimerScript: Timer CreateState(s) finished!
                                  javascript.0	2020-06-28 17:36:15.013	info	(11338) script.js.common.TimerScript: Reaching CreateTrigger()
                                  javascript.0	2020-06-28 17:36:15.013	info	(11338) script.js.common.TimerScript: Reaching ConvertPresence. TempPresence=true
                                  javascript.0	2020-06-28 17:36:15.012	info	(11338) script.js.common.TimerScript: Reaching SetValueListPairs()
                                  javascript.0	2020-06-28 17:36:15.012	info	(11338) script.js.common.TimerScript: Reaching CreateTimerCountList()
                                  javascript.0	2020-06-28 17:36:15.011	info	(11338) script.js.common.TimerScript: 2 Targets found - Targets are: sonoff.0.DVES_334397.POWER,sonoff.0.DVES_8F50DE.POWER
                                  javascript.0	2020-06-28 17:36:15.010	info	(11338) script.js.common.TimerScript: Reaching Init()
                                  javascript.0	2020-06-28 17:36:15.010	info	(11338) script.js.common.TimerScript: Reaching Main
                                  javascript.0	2020-06-28 17:36:15.010	info	(11338) script.js.common.TimerScript: Initial CreateStates finished!
                                  javascript.0	2020-06-28 17:36:15.009	info	(11338) script.js.common.TimerScript: registered 0 subscriptions and 0 schedules
                                  javascript.0	2020-06-28 17:36:15.008	info	(11338) script.js.common.TimerScript: Starting TimerSkript V2.1.3
                                  javascript.0	2020-06-28 17:36:15.001	info	(11338) Start javascript script.js.common.TimerScript
                                  javascript.0	2020-06-28 17:36:07.655	info	(11338) script.js.common.TimerScript: Timer Schedule 3 killed
                                  javascript.0	2020-06-28 17:36:07.655	info	(11338) script.js.common.TimerScript: Timer Schedule 2 killed
                                  javascript.0	2020-06-28 17:36:07.655	info	(11338) script.js.common.TimerScript: Timer Schedule 1 killed
                                  javascript.0	2020-06-28 17:36:07.653	info	(11338) Stop script script.js.common.TimerScript
                                  Gruß Thorsten
                                    Also ich seh nur ein Ziel in dem Screenshot. Somit kanns auch nur einen Namen geben, wo, bzw. was genau siehst Du jetzt da als Fehler?
                                      Also bei Dir scheint einiges nicht zu stimmen und ich vermute fast mal dasses nicht am Skript liegt, aber wie gesagt, Vermutung.
                                      Ich komm da drauf weil bei Dir Logs und Zustände sind, die es eigentlich gar nicht geben darf/kann.
                                      In Deinem ersten Screenshot steht addtimer auf true, das sollte es nicht geben (bzw. nur ne Sekunde) und was mich vorallem stutzig macht ist das da:
                                      Dass das einmal kommt is ok, aber dreimal gibt der Skriptaufbau gar nicht her. Bis dahin ist alles ok, danach fehlt etliches.
                                      Lass uns mal auf Nummer sicher gehen, Lösch mal das Skript und den gesamten javascript.0.Timer Channel. Dann machste nen Neustart des JS Adapters. Danach das Skript wieder installieren und starten. Nix manuell an den Objekten ändern, alle Änderungen ausschließlich über Vis machen. Und dann bitte wieder hier berichten.
                                        @Pittini muss ich beim js-adapter noch was zusätzlich angeben, wie zb request?
                                          Ich wüßte nicht wo man beim js Adapter iwo request angeben könnte. Also nein.
                                            @Pittini
                                            habs jetzt auch mal im root-verzeichnis probiert und im common-verzeichnis.
                                            hier das log aus dem root-verzeichnis
                                            host.ioBroker-deb	2020-06-29 08:38:49.027	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                            host.ioBroker-deb	2020-06-29 08:38:49.027	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                            host.ioBroker-deb	2020-06-29 08:38:49.027	error	Caught by controller[0]: at runMicrotasks (<anonymous>)
                                            host.ioBroker-deb	2020-06-29 08:38:49.027	error	Caught by controller[0]: at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
                                            host.ioBroker-deb	2020-06-29 08:38:49.027	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                            host.ioBroker-deb	2020-06-29 08:38:49.027	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:547:55
                                            host.ioBroker-deb	2020-06-29 08:38:49.027	error	Caught by controller[0]: at script.js.Timerscript:254:17
                                            host.ioBroker-deb	2020-06-29 08:38:49.027	error	Caught by controller[0]: at FillTimerArray (script.js.Timerscript:275:9)
                                            host.ioBroker-deb	2020-06-29 08:38:49.026	error	Caught by controller[0]: at CreateDeviceTrigger (script.js.Timerscript:1029:5)
                                            host.ioBroker-deb	2020-06-29 08:38:49.026	error	Caught by controller[0]: at on (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1151:28)
                                            host.ioBroker-deb	2020-06-29 08:38:49.026	error	Caught by controller[0]: at Object.subscribe (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:973:112)
                                            host.ioBroker-deb	2020-06-29 08:38:49.026	error	Caught by controller[0]: TypeError: Cannot read property 'period' of null
                                            javascript.0	2020-06-29 08:38:48.968	info	(28775) Stop script script.js.common.Generiere_Servicemeldungen
                                            javascript.0	2020-06-29 08:38:48.952	error	(28775) at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                            javascript.0	2020-06-29 08:38:48.952	error	(28775) at runMicrotasks (<anonymous>)
                                            javascript.0	2020-06-29 08:38:48.952	error	(28775) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
                                            javascript.0	2020-06-29 08:38:48.952	error	(28775) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                            javascript.0	2020-06-29 08:38:48.951	error	(28775) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:547:55
                                            javascript.0	2020-06-29 08:38:48.951	error	(28775) at script.js.Timerscript:254:17
                                            javascript.0	2020-06-29 08:38:48.951	error	(28775) at FillTimerArray (script.js.Timerscript:275:9)
                                            javascript.0	2020-06-29 08:38:48.951	error	(28775) at CreateDeviceTrigger (script.js.Timerscript:1029:5)
                                            javascript.0	2020-06-29 08:38:48.951	error	(28775) at on (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1151:28)
                                            javascript.0	2020-06-29 08:38:48.951	error	(28775) at Object.subscribe (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:973:112)
                                            javascript.0	2020-06-29 08:38:48.951	error	(28775) script.js.Timerscript: TypeError: Cannot read property 'period' of null
                                            javascript.0	2020-06-29 08:38:48.935	info	(28775) script.js.Timerscript: Reaching MakeTable
                                            javascript.0	2020-06-29 08:38:48.934	info	(28775) script.js.Timerscript: []
                                            javascript.0	2020-06-29 08:38:48.934	info	(28775) script.js.Timerscript: ['sonoff.0.DVES_334397.POWER','sonoff.0.DVES_8F50DE.POWER']
                                            danach startet der js-adapter neu und es treten keine warnungen mehr im log auf.
                                            siehe hier:
                                            javascript.0	2020-06-29 08:39:20.586	info	(29516) script.js.Timerscript: Reaching MakeTable
                                            javascript.0	2020-06-29 08:39:20.586	info	(29516) script.js.Timerscript: []
                                            javascript.0	2020-06-29 08:39:20.586	info	(29516) script.js.Timerscript: ['sonoff.0.DVES_334397.POWER','sonoff.0.DVES_8F50DE.POWER']
                                            javascript.0	2020-06-29 08:39:20.585	info	(29516) script.js.Timerscript: Timer CreateState(s) finished!
                                            javascript.0	2020-06-29 08:39:20.584	info	(29516) script.js.Timerscript: Timer CreateState(s) finished!
                                            javascript.0	2020-06-29 08:39:20.579	info	(29516) script.js.Timerscript: Reaching CreateTrigger()
                                            javascript.0	2020-06-29 08:39:20.578	info	(29516) script.js.Timerscript: Reaching ConvertPresence. TempPresence=true
                                            javascript.0	2020-06-29 08:39:20.578	info	(29516) script.js.Timerscript: Reaching SetValueListPairs()
                                            javascript.0	2020-06-29 08:39:20.577	info	(29516) script.js.Timerscript: Reaching CreateTimerCountList()
                                            javascript.0	2020-06-29 08:39:20.575	info	(29516) script.js.Timerscript: 2 Targets found - Targets are: sonoff.0.DVES_334397.POWER,sonoff.0.DVES_8F50DE.POWER
                                            javascript.0	2020-06-29 08:39:20.575	info	(29516) script.js.Timerscript: Reaching Init()
                                            javascript.0	2020-06-29 08:39:20.574	info	(29516) script.js.Timerscript: Reaching Main
                                            javascript.0	2020-06-29 08:39:20.574	info	(29516) script.js.Timerscript: Initial CreateStates finished!
                                            javascript.0	2020-06-29 08:39:20.568	info	(29516) script.js.Timerscript: registered 0 subscriptions and 0 schedules
                                            javascript.0	2020-06-29 08:39:20.565	info	(29516) script.js.Timerscript: Starting TimerSkript V2.1.3
                                            javascript.0	2020-06-29 08:39:20.562	info	(29516) Start javascript script.js.Timerscript
                                            Jetzt scheint es zu funktionieren, jedoch:
                                            sind in der Auswahl (siehe Maus) keine Namen hinterlegt.
                                            Gruß Thorsten
                                            P 2 Replies Last reply Reply Quote 0
                                            javascript template
                                            40
                                            500
                                            111750
